MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file iMOAB.cpp 00002 */ 00003 00004 #include "moab/MOABConfig.h" 00005 #include "moab/Core.hpp" 00006 00007 #ifdef MOAB_HAVE_MPI 00008 #include "moab_mpi.h" 00009 #include "moab/ParallelComm.hpp" 00010 #include "moab/ParCommGraph.hpp" 00011 #include "moab/ParallelMergeMesh.hpp" 00012 #include "moab/IntxMesh/IntxUtils.hpp" 00013 #endif 00014 #include "DebugOutput.hpp" 00015 #include "moab/iMOAB.h" 00016 00017 /* this is needed because of direct access to hdf5/mhdf */ 00018 #ifdef MOAB_HAVE_HDF5 00019 #include "mhdf.h" 00020 #include <H5Tpublic.h> 00021 #endif 00022 00023 #include "moab/CartVect.hpp" 00024 #include "MBTagConventions.hpp" 00025 #include "moab/MeshTopoUtil.hpp" 00026 #include "moab/ReadUtilIface.hpp" 00027 #include "moab/MergeMesh.hpp" 00028 00029 #ifdef MOAB_HAVE_TEMPESTREMAP 00030 #include "STLStringHelper.h" 00031 #include "moab/IntxMesh/IntxUtils.hpp" 00032 00033 #include "moab/Remapping/TempestRemapper.hpp" 00034 #include "moab/Remapping/TempestOnlineMap.hpp" 00035 #endif 00036 00037 // C++ includes 00038 #include <cassert> 00039 #include <sstream> 00040 #include <iostream> 00041 00042 using namespace moab; 00043 00044 // #define VERBOSE 00045 00046 // global variables ; should they be organized in a structure, for easier references? 00047 // or how do we keep them global? 00048 00049 #ifdef __cplusplus 00050 extern "C" { 00051 #endif 00052 00053 #ifdef MOAB_HAVE_TEMPESTREMAP 00054 struct TempestMapAppData 00055 { 00056 moab::TempestRemapper* remapper; 00057 std::map< std::string, moab::TempestOnlineMap* > weightMaps; 00058 iMOAB_AppID pid_src; 00059 iMOAB_AppID pid_dest; 00060 }; 00061 #endif 00062 00063 struct appData 00064 { 00065 EntityHandle file_set; 00066 int global_id; // external component id, unique for application 00067 std::string name; 00068 Range all_verts; 00069 Range local_verts; // it could include shared, but not owned at the interface 00070 // these vertices would be all_verts if no ghosting was required 00071 Range ghost_vertices; // locally ghosted from other processors 00072 Range primary_elems; 00073 Range owned_elems; 00074 Range ghost_elems; 00075 int dimension; // 2 or 3, dimension of primary elements (redundant?) 00076 long num_global_elements; // reunion of all elements in primary_elements; either from hdf5 00077 // reading or from reduce 00078 long num_global_vertices; // reunion of all nodes, after sharing is resolved; it could be 00079 // determined from hdf5 reading 00080 Range mat_sets; 00081 std::map< int, int > matIndex; // map from global block id to index in mat_sets 00082 Range neu_sets; 00083 Range diri_sets; 00084 std::map< std::string, Tag > tagMap; 00085 std::vector< Tag > tagList; 00086 bool point_cloud; 00087 bool is_fortran; 00088 00089 #ifdef MOAB_HAVE_MPI 00090 // constructor for this ParCommGraph takes the joint comm and the MPI groups for each 00091 // application 00092 std::map< int, ParCommGraph* > pgraph; // map from context () to the parcommgraph* 00093 #endif 00094 00095 #ifdef MOAB_HAVE_TEMPESTREMAP 00096 TempestMapAppData tempestData; 00097 #endif 00098 }; 00099 00100 struct GlobalContext 00101 { 00102 // are there reasons to have multiple moab inits? Is ref count needed? 00103 Interface* MBI; 00104 // we should also have the default tags stored, initialized 00105 Tag material_tag, neumann_tag, dirichlet_tag, 00106 globalID_tag; // material, neumann, dirichlet, globalID 00107 int refCountMB; 00108 int iArgc; 00109 iMOAB_String* iArgv; 00110 int unused_pid; 00111 00112 std::map< std::string, int > appIdMap; // from app string (uppercase) to app id 00113 std::map< int, int > appIdCompMap; // from component id to app id 00114 00115 #ifdef MOAB_HAVE_MPI 00116 std::vector< ParallelComm* > pcomms; // created in order of applications, one moab::ParallelComm for each 00117 #endif 00118 00119 std::vector< appData > appDatas; // the same order as pcomms 00120 int globalrank, worldprocs; 00121 bool MPI_initialized; 00122 00123 GlobalContext() 00124 { 00125 MBI = 0; 00126 refCountMB = 0; 00127 unused_pid = 0; 00128 } 00129 }; 00130 00131 static struct GlobalContext context; 00132 00133 ErrCode iMOAB_Initialize( int argc, iMOAB_String* argv ) 00134 { 00135 if( argc ) IMOAB_CHECKPOINTER( argv, 1 ); 00136 00137 context.iArgc = argc; 00138 context.iArgv = argv; // shallow copy 00139 00140 if( 0 == context.refCountMB ) 00141 { 00142 context.MBI = new( std::nothrow ) moab::Core; 00143 // retrieve the default tags 00144 const char* const shared_set_tag_names[] = { MATERIAL_SET_TAG_NAME, NEUMANN_SET_TAG_NAME, 00145 DIRICHLET_SET_TAG_NAME, GLOBAL_ID_TAG_NAME }; 00146 // blocks, visible surfaceBC(neumann), vertexBC (Dirichlet), global id, parallel partition 00147 Tag gtags[4]; 00148 00149 for( int i = 0; i < 4; i++ ) 00150 { 00151 00152 ErrorCode rval = 00153 context.MBI->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, gtags[i], MB_TAG_ANY );MB_CHK_ERR( rval ); 00154 } 00155 00156 context.material_tag = gtags[0]; 00157 context.neumann_tag = gtags[1]; 00158 context.dirichlet_tag = gtags[2]; 00159 context.globalID_tag = gtags[3]; 00160 } 00161 00162 context.MPI_initialized = false; 00163 #ifdef MOAB_HAVE_MPI 00164 int flagInit; 00165 MPI_Initialized( &flagInit ); 00166 00167 if( flagInit && !context.MPI_initialized ) 00168 { 00169 MPI_Comm_size( MPI_COMM_WORLD, &context.worldprocs ); 00170 MPI_Comm_rank( MPI_COMM_WORLD, &context.globalrank ); 00171 context.MPI_initialized = true; 00172 } 00173 #endif 00174 00175 context.refCountMB++; 00176 return moab::MB_SUCCESS; 00177 } 00178 00179 ErrCode iMOAB_InitializeFortran() 00180 { 00181 return iMOAB_Initialize( 0, 0 ); 00182 } 00183 00184 ErrCode iMOAB_Finalize() 00185 { 00186 context.refCountMB--; 00187 00188 if( 0 == context.refCountMB ) 00189 { 00190 delete context.MBI; 00191 } 00192 00193 return MB_SUCCESS; 00194 } 00195 00196 ErrCode iMOAB_RegisterApplication( const iMOAB_String app_name, 00197 #ifdef MOAB_HAVE_MPI 00198 MPI_Comm* comm, 00199 #endif 00200 int* compid, 00201 iMOAB_AppID pid ) 00202 { 00203 IMOAB_CHECKPOINTER( app_name, 1 ); 00204 #ifdef MOAB_HAVE_MPI 00205 IMOAB_CHECKPOINTER( comm, 2 ); 00206 IMOAB_CHECKPOINTER( compid, 3 ); 00207 #else 00208 IMOAB_CHECKPOINTER( compid, 2 ); 00209 #endif 00210 00211 // will create a parallel comm for this application too, so there will be a 00212 // mapping from *pid to file set and to parallel comm instances 00213 std::string name( app_name ); 00214 00215 if( context.appIdMap.find( name ) != context.appIdMap.end() ) 00216 { 00217 std::cout << " application " << name << " already registered \n"; 00218 return moab::MB_FAILURE; 00219 } 00220 00221 *pid = context.unused_pid++; 00222 context.appIdMap[name] = *pid; 00223 int rankHere = 0; 00224 #ifdef MOAB_HAVE_MPI 00225 MPI_Comm_rank( *comm, &rankHere ); 00226 #endif 00227 if( !rankHere ) std::cout << " application " << name << " with ID = " << *pid << " is registered now \n"; 00228 if( *compid <= 0 ) 00229 { 00230 std::cout << " convention for external application is to have its id positive \n"; 00231 return moab::MB_FAILURE; 00232 } 00233 00234 if( context.appIdCompMap.find( *compid ) != context.appIdCompMap.end() ) 00235 { 00236 std::cout << " external application with comp id " << *compid << " is already registered\n"; 00237 return moab::MB_FAILURE; 00238 } 00239 00240 context.appIdCompMap[*compid] = *pid; 00241 00242 // now create ParallelComm and a file set for this application 00243 #ifdef MOAB_HAVE_MPI 00244 if( *comm ) 00245 { 00246 ParallelComm* pco = new ParallelComm( context.MBI, *comm ); 00247 00248 #ifndef NDEBUG 00249 int index = pco->get_id(); // it could be useful to get app id from pcomm instance ... 00250 assert( index == *pid ); 00251 // here, we assert the the pid is the same as the id of the ParallelComm instance 00252 // useful for writing in parallel 00253 #endif 00254 context.pcomms.push_back( pco ); 00255 } 00256 else 00257 { 00258 context.pcomms.push_back( 0 ); 00259 } 00260 #endif 00261 00262 // create now the file set that will be used for loading the model in 00263 EntityHandle file_set; 00264 ErrorCode rval = context.MBI->create_meshset( MESHSET_SET, file_set );MB_CHK_ERR( rval ); 00265 00266 appData app_data; 00267 app_data.file_set = file_set; 00268 app_data.global_id = *compid; // will be used mostly for par comm graph 00269 app_data.name = name; // save the name of application 00270 00271 #ifdef MOAB_HAVE_TEMPESTREMAP 00272 app_data.tempestData.remapper = NULL; // Only allocate as needed 00273 #endif 00274 00275 app_data.point_cloud = false; 00276 app_data.is_fortran = false; 00277 00278 context.appDatas.push_back( 00279 app_data ); // it will correspond to app_FileSets[*pid] will be the file set of interest 00280 return moab::MB_SUCCESS; 00281 } 00282 00283 ErrCode iMOAB_RegisterApplicationFortran( const iMOAB_String app_name, 00284 #ifdef MOAB_HAVE_MPI 00285 int* comm, 00286 #endif 00287 int* compid, 00288 iMOAB_AppID pid ) 00289 { 00290 IMOAB_CHECKPOINTER( app_name, 1 ); 00291 #ifdef MOAB_HAVE_MPI 00292 IMOAB_CHECKPOINTER( comm, 2 ); 00293 IMOAB_CHECKPOINTER( compid, 3 ); 00294 #else 00295 IMOAB_CHECKPOINTER( compid, 2 ); 00296 #endif 00297 00298 ErrCode err; 00299 assert( app_name != nullptr ); 00300 std::string name( app_name ); 00301 00302 #ifdef MOAB_HAVE_MPI 00303 MPI_Comm ccomm; 00304 if( comm ) 00305 { 00306 // convert from Fortran communicator to a C communicator 00307 // see transfer of handles 00308 // http://www.mpi-forum.org/docs/mpi-2.2/mpi22-report/node361.htm 00309 ccomm = MPI_Comm_f2c( (MPI_Fint)*comm ); 00310 } 00311 #endif 00312 00313 // now call C style registration function: 00314 err = iMOAB_RegisterApplication( app_name, 00315 #ifdef MOAB_HAVE_MPI 00316 &ccomm, 00317 #endif 00318 compid, pid ); 00319 00320 // Now that we have created the application context, store that 00321 // the application being registered is from a Fortran context 00322 context.appDatas[*pid].is_fortran = true; 00323 00324 return err; 00325 } 00326 00327 ErrCode iMOAB_DeregisterApplication( iMOAB_AppID pid ) 00328 { 00329 // the file set , parallel comm are all in vectors indexed by *pid 00330 // assume we did not delete anything yet 00331 // *pid will not be reused if we register another application 00332 appData& data = context.appDatas[*pid]; 00333 int rankHere = 0; 00334 #ifdef MOAB_HAVE_MPI 00335 ParallelComm* pco = context.pcomms[*pid]; 00336 rankHere = pco->rank(); 00337 #endif 00338 if( !rankHere ) 00339 std::cout << " application with ID: " << *pid << " global id: " << data.global_id << " name: " << data.name 00340 << " is de-registered now \n"; 00341 00342 EntityHandle fileSet = data.file_set; 00343 // get all entities part of the file set 00344 Range fileents; 00345 ErrorCode rval = context.MBI->get_entities_by_handle( fileSet, fileents, /*recursive */ true );MB_CHK_ERR( rval ); 00346 00347 fileents.insert( fileSet ); 00348 00349 rval = context.MBI->get_entities_by_type( fileSet, MBENTITYSET, fileents );MB_CHK_ERR( rval ); // append all mesh sets 00350 00351 #ifdef MOAB_HAVE_TEMPESTREMAP 00352 if( data.tempestData.remapper ) delete data.tempestData.remapper; 00353 if( data.tempestData.weightMaps.size() ) data.tempestData.weightMaps.clear(); 00354 #endif 00355 00356 #ifdef MOAB_HAVE_MPI 00357 00358 // we could get the pco also with 00359 // ParallelComm * pcomm = ParallelComm::get_pcomm(context.MBI, *pid); 00360 00361 std::map< int, ParCommGraph* >& pargs = data.pgraph; 00362 00363 // free the parallel comm graphs associated with this app 00364 for( std::map< int, ParCommGraph* >::iterator mt = pargs.begin(); mt != pargs.end(); mt++ ) 00365 { 00366 ParCommGraph* pgr = mt->second; 00367 delete pgr; 00368 pgr = NULL; 00369 } 00370 if( pco ) delete pco; 00371 #endif 00372 00373 // delete first all except vertices 00374 Range vertices = fileents.subset_by_type( MBVERTEX ); 00375 Range noverts = subtract( fileents, vertices ); 00376 00377 rval = context.MBI->delete_entities( noverts );MB_CHK_ERR( rval ); 00378 // now retrieve connected elements that still exist (maybe in other sets, pids?) 00379 Range adj_ents_left; 00380 rval = context.MBI->get_adjacencies( vertices, 1, false, adj_ents_left, Interface::UNION );MB_CHK_ERR( rval ); 00381 rval = context.MBI->get_adjacencies( vertices, 2, false, adj_ents_left, Interface::UNION );MB_CHK_ERR( rval ); 00382 rval = context.MBI->get_adjacencies( vertices, 3, false, adj_ents_left, Interface::UNION );MB_CHK_ERR( rval ); 00383 00384 if( !adj_ents_left.empty() ) 00385 { 00386 Range conn_verts; 00387 rval = context.MBI->get_connectivity( adj_ents_left, conn_verts );MB_CHK_ERR( rval ); 00388 vertices = subtract( vertices, conn_verts ); 00389 } 00390 00391 rval = context.MBI->delete_entities( vertices );MB_CHK_ERR( rval ); 00392 00393 std::map< std::string, int >::iterator mit; 00394 00395 for( mit = context.appIdMap.begin(); mit != context.appIdMap.end(); mit++ ) 00396 { 00397 int pidx = mit->second; 00398 00399 if( *pid == pidx ) 00400 { 00401 break; 00402 } 00403 } 00404 00405 context.appIdMap.erase( mit ); 00406 std::map< int, int >::iterator mit1; 00407 00408 for( mit1 = context.appIdCompMap.begin(); mit1 != context.appIdCompMap.end(); mit1++ ) 00409 { 00410 int pidx = mit1->second; 00411 00412 if( *pid == pidx ) 00413 { 00414 break; 00415 } 00416 } 00417 00418 context.appIdCompMap.erase( mit1 ); 00419 00420 context.unused_pid--; // we have to go backwards always TODO 00421 context.appDatas.pop_back(); 00422 #ifdef MOAB_HAVE_MPI 00423 context.pcomms.pop_back(); 00424 #endif 00425 return moab::MB_SUCCESS; 00426 } 00427 00428 ErrCode iMOAB_DeregisterApplicationFortran( iMOAB_AppID pid ) 00429 { 00430 // release any Fortran specific allocations here before we pass it on 00431 context.appDatas[*pid].is_fortran = false; 00432 00433 // release all datastructure allocations 00434 return iMOAB_DeregisterApplication( pid ); 00435 } 00436 00437 // Utility function 00438 static void split_tag_names( std::string input_names, 00439 std::string& separator, 00440 std::vector< std::string >& list_tag_names ) 00441 { 00442 size_t pos = 0; 00443 std::string token; 00444 while( ( pos = input_names.find( separator ) ) != std::string::npos ) 00445 { 00446 token = input_names.substr( 0, pos ); 00447 if( !token.empty() ) list_tag_names.push_back( token ); 00448 // std::cout << token << std::endl; 00449 input_names.erase( 0, pos + separator.length() ); 00450 } 00451 if( !input_names.empty() ) 00452 { 00453 // if leftover something, or if not ended with delimiter 00454 list_tag_names.push_back( input_names ); 00455 } 00456 return; 00457 } 00458 00459 ErrCode iMOAB_ReadHeaderInfo( const iMOAB_String filename, 00460 int* num_global_vertices, 00461 int* num_global_elements, 00462 int* num_dimension, 00463 int* num_parts ) 00464 { 00465 IMOAB_CHECKPOINTER( filename, 1 ); 00466 IMOAB_ASSERT( strlen( filename ), "Invalid filename length." ); 00467 00468 #ifdef MOAB_HAVE_HDF5 00469 std::string filen( filename ); 00470 00471 int edges = 0; 00472 int faces = 0; 00473 int regions = 0; 00474 if( num_global_vertices ) *num_global_vertices = 0; 00475 if( num_global_elements ) *num_global_elements = 0; 00476 if( num_dimension ) *num_dimension = 0; 00477 if( num_parts ) *num_parts = 0; 00478 00479 mhdf_FileHandle file; 00480 mhdf_Status status; 00481 unsigned long max_id; 00482 struct mhdf_FileDesc* data; 00483 00484 file = mhdf_openFile( filen.c_str(), 0, &max_id, -1, &status ); 00485 00486 if( mhdf_isError( &status ) ) 00487 { 00488 fprintf( stderr, "%s: %s\n", filename, mhdf_message( &status ) ); 00489 return moab::MB_FAILURE; 00490 } 00491 00492 data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status, 00493 1 ); // will use extra set info; will get parallel partition tag info too! 00494 00495 if( mhdf_isError( &status ) ) 00496 { 00497 fprintf( stderr, "%s: %s\n", filename, mhdf_message( &status ) ); 00498 return moab::MB_FAILURE; 00499 } 00500 00501 if( num_dimension ) *num_dimension = data->nodes.vals_per_ent; 00502 if( num_global_vertices ) *num_global_vertices = (int)data->nodes.count; 00503 00504 for( int i = 0; i < data->num_elem_desc; i++ ) 00505 { 00506 struct mhdf_ElemDesc* el_desc = &( data->elems[i] ); 00507 struct mhdf_EntDesc* ent_d = &( el_desc->desc ); 00508 00509 if( 0 == strcmp( el_desc->type, mhdf_EDGE_TYPE_NAME ) ) 00510 { 00511 edges += ent_d->count; 00512 } 00513 00514 if( 0 == strcmp( el_desc->type, mhdf_TRI_TYPE_NAME ) ) 00515 { 00516 faces += ent_d->count; 00517 } 00518 00519 if( 0 == strcmp( el_desc->type, mhdf_QUAD_TYPE_NAME ) ) 00520 { 00521 faces += ent_d->count; 00522 } 00523 00524 if( 0 == strcmp( el_desc->type, mhdf_POLYGON_TYPE_NAME ) ) 00525 { 00526 faces += ent_d->count; 00527 } 00528 00529 if( 0 == strcmp( el_desc->type, mhdf_TET_TYPE_NAME ) ) 00530 { 00531 regions += ent_d->count; 00532 } 00533 00534 if( 0 == strcmp( el_desc->type, mhdf_PYRAMID_TYPE_NAME ) ) 00535 { 00536 regions += ent_d->count; 00537 } 00538 00539 if( 0 == strcmp( el_desc->type, mhdf_PRISM_TYPE_NAME ) ) 00540 { 00541 regions += ent_d->count; 00542 } 00543 00544 if( 0 == strcmp( el_desc->type, mdhf_KNIFE_TYPE_NAME ) ) 00545 { 00546 regions += ent_d->count; 00547 } 00548 00549 if( 0 == strcmp( el_desc->type, mdhf_HEX_TYPE_NAME ) ) 00550 { 00551 regions += ent_d->count; 00552 } 00553 00554 if( 0 == strcmp( el_desc->type, mhdf_POLYHEDRON_TYPE_NAME ) ) 00555 { 00556 regions += ent_d->count; 00557 } 00558 00559 if( 0 == strcmp( el_desc->type, mhdf_SEPTAHEDRON_TYPE_NAME ) ) 00560 { 00561 regions += ent_d->count; 00562 } 00563 } 00564 00565 if( num_parts ) *num_parts = data->numEntSets[0]; 00566 00567 // is this required? 00568 if( edges > 0 ) 00569 { 00570 if( num_dimension ) *num_dimension = 1; // I don't think it will ever return 1 00571 if( num_global_elements ) *num_global_elements = edges; 00572 } 00573 00574 if( faces > 0 ) 00575 { 00576 if( num_dimension ) *num_dimension = 2; 00577 if( num_global_elements ) *num_global_elements = faces; 00578 } 00579 00580 if( regions > 0 ) 00581 { 00582 if( num_dimension ) *num_dimension = 3; 00583 if( num_global_elements ) *num_global_elements = regions; 00584 } 00585 00586 mhdf_closeFile( file, &status ); 00587 00588 free( data ); 00589 00590 #else 00591 std::cout << filename 00592 << ": Please reconfigure with HDF5. Cannot retrieve header information for file " 00593 "formats other than a h5m file.\n"; 00594 if( num_global_vertices ) *num_global_vertices = 0; 00595 if( num_global_elements ) *num_global_elements = 0; 00596 if( num_dimension ) *num_dimension = 0; 00597 if( num_parts ) *num_parts = 0; 00598 #endif 00599 00600 return moab::MB_SUCCESS; 00601 } 00602 00603 ErrCode iMOAB_LoadMesh( iMOAB_AppID pid, 00604 const iMOAB_String filename, 00605 const iMOAB_String read_options, 00606 int* num_ghost_layers ) 00607 { 00608 IMOAB_CHECKPOINTER( filename, 2 ); 00609 IMOAB_ASSERT( strlen( filename ), "Invalid filename length." ); 00610 00611 // make sure we use the file set and pcomm associated with the *pid 00612 std::ostringstream newopts; 00613 if( read_options ) newopts << read_options; 00614 00615 #ifdef MOAB_HAVE_MPI 00616 00617 if( context.MPI_initialized ) 00618 { 00619 if( context.worldprocs > 1 ) 00620 { 00621 std::string opts( ( read_options ? read_options : "" ) ); 00622 std::string pcid( "PARALLEL_COMM=" ); 00623 std::size_t found = opts.find( pcid ); 00624 00625 if( found != std::string::npos ) 00626 { 00627 std::cerr << " cannot specify PARALLEL_COMM option, it is implicit \n"; 00628 return moab::MB_FAILURE; 00629 } 00630 00631 // in serial, apply PARALLEL_COMM option only for h5m files; it does not work for .g 00632 // files (used in test_remapping) 00633 std::string filen( filename ); 00634 std::string::size_type idx = filen.rfind( '.' ); 00635 00636 if( idx != std::string::npos ) 00637 { 00638 std::string extension = filen.substr( idx + 1 ); 00639 if( (extension == std::string( "h5m" )) || (extension == std::string( "nc" ))) newopts << ";;PARALLEL_COMM=" << *pid; 00640 } 00641 00642 if( *num_ghost_layers >= 1 ) 00643 { 00644 // if we want ghosts, we will want additional entities, the last .1 00645 // because the addl ents can be edges, faces that are part of the neumann sets 00646 std::string pcid2( "PARALLEL_GHOSTS=" ); 00647 std::size_t found2 = opts.find( pcid2 ); 00648 00649 if( found2 != std::string::npos ) 00650 { 00651 std::cout << " PARALLEL_GHOSTS option is already specified, ignore passed " 00652 "number of layers \n"; 00653 } 00654 else 00655 { 00656 // dimension of primary entities is 3 here, but it could be 2 for climate 00657 // meshes; we would need to pass PARALLEL_GHOSTS explicitly for 2d meshes, for 00658 // example: ";PARALLEL_GHOSTS=2.0.1" 00659 newopts << ";PARALLEL_GHOSTS=3.0." << *num_ghost_layers << ".3"; 00660 } 00661 } 00662 } 00663 } 00664 #else 00665 IMOAB_ASSERT( *num_ghost_layers == 0, "Cannot provide ghost layers in serial." ); 00666 #endif 00667 00668 // Now let us actually load the MOAB file with the appropriate read options 00669 ErrorCode rval = context.MBI->load_file( filename, &context.appDatas[*pid].file_set, newopts.str().c_str() );MB_CHK_ERR( rval ); 00670 00671 #ifdef VERBOSE 00672 // some debugging stuff 00673 std::ostringstream outfile; 00674 #ifdef MOAB_HAVE_MPI 00675 int rank = context.pcomms[*pid]->rank(); 00676 int nprocs = context.pcomms[*pid]->size(); 00677 outfile << "TaskMesh_n" << nprocs << "." << rank << ".h5m"; 00678 #else 00679 outfile << "TaskMesh_n1.0.h5m"; 00680 #endif 00681 // the mesh contains ghosts too, but they are not part of mat/neumann set 00682 // write in serial the file, to see what tags are missing 00683 rval = context.MBI->write_file( outfile.str().c_str() );MB_CHK_ERR( rval ); // everything on current task, written in serial 00684 #endif 00685 00686 // Update mesh information 00687 return iMOAB_UpdateMeshInfo( pid ); 00688 } 00689 00690 ErrCode iMOAB_WriteMesh( iMOAB_AppID pid, const iMOAB_String filename, const iMOAB_String write_options ) 00691 { 00692 IMOAB_CHECKPOINTER( filename, 2 ); 00693 IMOAB_ASSERT( strlen( filename ), "Invalid filename length." ); 00694 00695 appData& data = context.appDatas[*pid]; 00696 EntityHandle fileSet = data.file_set; 00697 00698 std::ostringstream newopts; 00699 #ifdef MOAB_HAVE_MPI 00700 std::string write_opts( ( write_options ? write_options : "" ) ); 00701 std::string pcid( "PARALLEL_COMM=" ); 00702 std::size_t found = write_opts.find( pcid ); 00703 00704 if( found != std::string::npos ) 00705 { 00706 std::cerr << " cannot specify PARALLEL_COMM option, it is implicit \n"; 00707 return moab::MB_FAILURE; 00708 } 00709 00710 // if write in parallel, add pc option, to be sure about which ParallelComm instance is used 00711 std::string pw( "PARALLEL=WRITE_PART" ); 00712 found = write_opts.find( pw ); 00713 00714 if( found != std::string::npos ) 00715 { 00716 newopts << "PARALLEL_COMM=" << *pid << ";"; 00717 } 00718 00719 #endif 00720 00721 if( write_options ) newopts << write_options; 00722 00723 std::vector< Tag > copyTagList = data.tagList; 00724 // append Global ID and Parallel Partition 00725 std::string gid_name_tag( "GLOBAL_ID" ); 00726 00727 // export global id tag, we need it always 00728 if( data.tagMap.find( gid_name_tag ) == data.tagMap.end() ) 00729 { 00730 Tag gid = context.MBI->globalId_tag(); 00731 copyTagList.push_back( gid ); 00732 } 00733 // also Parallel_Partition PARALLEL_PARTITION 00734 std::string pp_name_tag( "PARALLEL_PARTITION" ); 00735 00736 // write parallel part tag too, if it exists 00737 if( data.tagMap.find( pp_name_tag ) == data.tagMap.end() ) 00738 { 00739 Tag ptag; 00740 context.MBI->tag_get_handle( pp_name_tag.c_str(), ptag ); 00741 if( ptag ) copyTagList.push_back( ptag ); 00742 } 00743 00744 // Now let us actually write the file to disk with appropriate options 00745 ErrorCode rval = context.MBI->write_file( filename, 0, newopts.str().c_str(), &fileSet, 1, ©TagList[0], 00746 (int)copyTagList.size() );MB_CHK_ERR( rval ); 00747 00748 return moab::MB_SUCCESS; 00749 } 00750 00751 ErrCode iMOAB_WriteLocalMesh( iMOAB_AppID pid, iMOAB_String prefix ) 00752 { 00753 IMOAB_CHECKPOINTER( prefix, 2 ); 00754 IMOAB_ASSERT( strlen( prefix ), "Invalid prefix string length." ); 00755 00756 std::ostringstream file_name; 00757 int rank = 0, size = 1; 00758 #ifdef MOAB_HAVE_MPI 00759 rank = context.pcomms[*pid]->rank(); 00760 size = context.pcomms[*pid]->size(); 00761 #endif 00762 file_name << prefix << "_" << size << "_" << rank << ".h5m"; 00763 // Now let us actually write the file to disk with appropriate options 00764 ErrorCode rval = context.MBI->write_file( file_name.str().c_str(), 0, 0, &context.appDatas[*pid].file_set, 1 );MB_CHK_ERR( rval ); 00765 00766 return moab::MB_SUCCESS; 00767 } 00768 00769 ErrCode iMOAB_UpdateMeshInfo( iMOAB_AppID pid ) 00770 { 00771 // this will include ghost elements info 00772 appData& data = context.appDatas[*pid]; 00773 EntityHandle fileSet = data.file_set; 00774 00775 // first clear all data ranges; this can be called after ghosting 00776 data.all_verts.clear(); 00777 data.primary_elems.clear(); 00778 data.local_verts.clear(); 00779 data.ghost_vertices.clear(); 00780 data.owned_elems.clear(); 00781 data.ghost_elems.clear(); 00782 data.mat_sets.clear(); 00783 data.neu_sets.clear(); 00784 data.diri_sets.clear(); 00785 00786 // Let us get all the vertex entities 00787 ErrorCode rval = context.MBI->get_entities_by_type( fileSet, MBVERTEX, data.all_verts, true );MB_CHK_ERR( rval ); // recursive 00788 00789 // Let us check first entities of dimension = 3 00790 data.dimension = 3; 00791 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, data.primary_elems, true );MB_CHK_ERR( rval ); // recursive 00792 00793 if( data.primary_elems.empty() ) 00794 { 00795 // Now 3-D elements. Let us check entities of dimension = 2 00796 data.dimension = 2; 00797 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, data.primary_elems, true );MB_CHK_ERR( rval ); // recursive 00798 00799 if( data.primary_elems.empty() ) 00800 { 00801 // Now 3-D/2-D elements. Let us check entities of dimension = 1 00802 data.dimension = 1; 00803 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, data.primary_elems, true );MB_CHK_ERR( rval ); // recursive 00804 00805 if( data.primary_elems.empty() ) 00806 { 00807 // no elements of dimension 1 or 2 or 3; it could happen for point clouds 00808 data.dimension = 0; 00809 } 00810 } 00811 } 00812 00813 // check if the current mesh is just a point cloud 00814 data.point_cloud = ( ( data.primary_elems.size() == 0 && data.all_verts.size() > 0 ) || data.dimension == 0 ); 00815 00816 #ifdef MOAB_HAVE_MPI 00817 00818 if( context.MPI_initialized ) 00819 { 00820 ParallelComm* pco = context.pcomms[*pid]; 00821 00822 // filter ghost vertices, from local 00823 rval = pco->filter_pstatus( data.all_verts, PSTATUS_GHOST, PSTATUS_NOT, -1, &data.local_verts );MB_CHK_ERR( rval ); 00824 00825 // Store handles for all ghosted entities 00826 data.ghost_vertices = subtract( data.all_verts, data.local_verts ); 00827 00828 // filter ghost elements, from local 00829 rval = pco->filter_pstatus( data.primary_elems, PSTATUS_GHOST, PSTATUS_NOT, -1, &data.owned_elems );MB_CHK_ERR( rval ); 00830 00831 data.ghost_elems = subtract( data.primary_elems, data.owned_elems ); 00832 } 00833 else 00834 { 00835 data.local_verts = data.all_verts; 00836 data.owned_elems = data.primary_elems; 00837 } 00838 00839 #else 00840 00841 data.local_verts = data.all_verts; 00842 data.owned_elems = data.primary_elems; 00843 00844 #endif 00845 00846 // Get the references for some standard internal tags such as material blocks, BCs, etc 00847 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.material_tag ), 0, 1, 00848 data.mat_sets, Interface::UNION );MB_CHK_ERR( rval ); 00849 00850 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.neumann_tag ), 0, 1, 00851 data.neu_sets, Interface::UNION );MB_CHK_ERR( rval ); 00852 00853 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.dirichlet_tag ), 0, 1, 00854 data.diri_sets, Interface::UNION );MB_CHK_ERR( rval ); 00855 00856 return moab::MB_SUCCESS; 00857 } 00858 00859 ErrCode iMOAB_GetMeshInfo( iMOAB_AppID pid, 00860 int* num_visible_vertices, 00861 int* num_visible_elements, 00862 int* num_visible_blocks, 00863 int* num_visible_surfaceBC, 00864 int* num_visible_vertexBC ) 00865 { 00866 ErrorCode rval; 00867 appData& data = context.appDatas[*pid]; 00868 EntityHandle fileSet = data.file_set; 00869 00870 // this will include ghost elements 00871 // first clear all data ranges; this can be called after ghosting 00872 if( num_visible_elements ) 00873 { 00874 num_visible_elements[2] = static_cast< int >( data.primary_elems.size() ); 00875 // separate ghost and local/owned primary elements 00876 num_visible_elements[0] = static_cast< int >( data.owned_elems.size() ); 00877 num_visible_elements[1] = static_cast< int >( data.ghost_elems.size() ); 00878 } 00879 if( num_visible_vertices ) 00880 { 00881 num_visible_vertices[2] = static_cast< int >( data.all_verts.size() ); 00882 num_visible_vertices[1] = static_cast< int >( data.ghost_vertices.size() ); 00883 // local are those that are not ghosts 00884 num_visible_vertices[0] = num_visible_vertices[2] - num_visible_vertices[1]; 00885 } 00886 00887 if( num_visible_blocks ) 00888 { 00889 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.material_tag ), 0, 1, 00890 data.mat_sets, Interface::UNION );MB_CHK_ERR( rval ); 00891 00892 num_visible_blocks[2] = data.mat_sets.size(); 00893 num_visible_blocks[0] = num_visible_blocks[2]; 00894 num_visible_blocks[1] = 0; 00895 } 00896 00897 if( num_visible_surfaceBC ) 00898 { 00899 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.neumann_tag ), 0, 1, 00900 data.neu_sets, Interface::UNION );MB_CHK_ERR( rval ); 00901 00902 num_visible_surfaceBC[2] = 0; 00903 // count how many faces are in each neu set, and how many regions are 00904 // adjacent to them; 00905 int numNeuSets = (int)data.neu_sets.size(); 00906 00907 for( int i = 0; i < numNeuSets; i++ ) 00908 { 00909 Range subents; 00910 EntityHandle nset = data.neu_sets[i]; 00911 rval = context.MBI->get_entities_by_dimension( nset, data.dimension - 1, subents );MB_CHK_ERR( rval ); 00912 00913 for( Range::iterator it = subents.begin(); it != subents.end(); ++it ) 00914 { 00915 EntityHandle subent = *it; 00916 Range adjPrimaryEnts; 00917 rval = context.MBI->get_adjacencies( &subent, 1, data.dimension, false, adjPrimaryEnts );MB_CHK_ERR( rval ); 00918 00919 num_visible_surfaceBC[2] += (int)adjPrimaryEnts.size(); 00920 } 00921 } 00922 00923 num_visible_surfaceBC[0] = num_visible_surfaceBC[2]; 00924 num_visible_surfaceBC[1] = 0; 00925 } 00926 00927 if( num_visible_vertexBC ) 00928 { 00929 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.dirichlet_tag ), 0, 1, 00930 data.diri_sets, Interface::UNION );MB_CHK_ERR( rval ); 00931 00932 num_visible_vertexBC[2] = 0; 00933 int numDiriSets = (int)data.diri_sets.size(); 00934 00935 for( int i = 0; i < numDiriSets; i++ ) 00936 { 00937 Range verts; 00938 EntityHandle diset = data.diri_sets[i]; 00939 rval = context.MBI->get_entities_by_dimension( diset, 0, verts );MB_CHK_ERR( rval ); 00940 00941 num_visible_vertexBC[2] += (int)verts.size(); 00942 } 00943 00944 num_visible_vertexBC[0] = num_visible_vertexBC[2]; 00945 num_visible_vertexBC[1] = 0; 00946 } 00947 00948 return moab::MB_SUCCESS; 00949 } 00950 00951 ErrCode iMOAB_GetVertexID( iMOAB_AppID pid, int* vertices_length, iMOAB_GlobalID* global_vertex_ID ) 00952 { 00953 IMOAB_CHECKPOINTER( vertices_length, 2 ); 00954 IMOAB_CHECKPOINTER( global_vertex_ID, 3 ); 00955 00956 const Range& verts = context.appDatas[*pid].all_verts; 00957 // check for problems with array length 00958 IMOAB_ASSERT( *vertices_length == static_cast< int >( verts.size() ), "Invalid vertices length provided" ); 00959 00960 // global id tag is context.globalID_tag 00961 return context.MBI->tag_get_data( context.globalID_tag, verts, global_vertex_ID ); 00962 } 00963 00964 ErrCode iMOAB_GetVertexOwnership( iMOAB_AppID pid, int* vertices_length, int* visible_global_rank_ID ) 00965 { 00966 assert( vertices_length && *vertices_length ); 00967 assert( visible_global_rank_ID ); 00968 00969 Range& verts = context.appDatas[*pid].all_verts; 00970 int i = 0; 00971 #ifdef MOAB_HAVE_MPI 00972 ParallelComm* pco = context.pcomms[*pid]; 00973 00974 for( Range::iterator vit = verts.begin(); vit != verts.end(); vit++, i++ ) 00975 { 00976 ErrorCode rval = pco->get_owner( *vit, visible_global_rank_ID[i] );MB_CHK_ERR( rval ); 00977 } 00978 00979 if( i != *vertices_length ) 00980 { 00981 return moab::MB_FAILURE; 00982 } // warning array allocation problem 00983 00984 #else 00985 00986 /* everything owned by proc 0 */ 00987 if( (int)verts.size() != *vertices_length ) 00988 { 00989 return moab::MB_FAILURE; 00990 } // warning array allocation problem 00991 00992 for( Range::iterator vit = verts.begin(); vit != verts.end(); vit++, i++ ) 00993 { 00994 visible_global_rank_ID[i] = 0; 00995 } // all vertices are owned by processor 0, as this is serial run 00996 00997 #endif 00998 00999 return moab::MB_SUCCESS; 01000 } 01001 01002 ErrCode iMOAB_GetVisibleVerticesCoordinates( iMOAB_AppID pid, int* coords_length, double* coordinates ) 01003 { 01004 Range& verts = context.appDatas[*pid].all_verts; 01005 01006 // interleaved coordinates, so that means deep copy anyway 01007 if( *coords_length != 3 * (int)verts.size() ) 01008 { 01009 return moab::MB_FAILURE; 01010 } 01011 01012 ErrorCode rval = context.MBI->get_coords( verts, coordinates );MB_CHK_ERR( rval ); 01013 01014 return moab::MB_SUCCESS; 01015 } 01016 01017 ErrCode iMOAB_GetBlockID( iMOAB_AppID pid, int* block_length, iMOAB_GlobalID* global_block_IDs ) 01018 { 01019 // local id blocks? they are counted from 0 to number of visible blocks ... 01020 // will actually return material set tag value for global 01021 Range& matSets = context.appDatas[*pid].mat_sets; 01022 01023 if( *block_length != (int)matSets.size() ) 01024 { 01025 return moab::MB_FAILURE; 01026 } 01027 01028 // return material set tag gtags[0 is material set tag 01029 ErrorCode rval = context.MBI->tag_get_data( context.material_tag, matSets, global_block_IDs );MB_CHK_ERR( rval ); 01030 01031 // populate map with index 01032 std::map< int, int >& matIdx = context.appDatas[*pid].matIndex; 01033 for( unsigned i = 0; i < matSets.size(); i++ ) 01034 { 01035 matIdx[global_block_IDs[i]] = i; 01036 } 01037 01038 return moab::MB_SUCCESS; 01039 } 01040 01041 ErrCode iMOAB_GetBlockInfo( iMOAB_AppID pid, 01042 iMOAB_GlobalID* global_block_ID, 01043 int* vertices_per_element, 01044 int* num_elements_in_block ) 01045 { 01046 assert( global_block_ID ); 01047 01048 std::map< int, int >& matMap = context.appDatas[*pid].matIndex; 01049 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01050 01051 if( it == matMap.end() ) 01052 { 01053 return moab::MB_FAILURE; 01054 } // error in finding block with id 01055 01056 int blockIndex = matMap[*global_block_ID]; 01057 EntityHandle matMeshSet = context.appDatas[*pid].mat_sets[blockIndex]; 01058 Range blo_elems; 01059 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, blo_elems ); 01060 01061 if( MB_SUCCESS != rval || blo_elems.empty() ) 01062 { 01063 return moab::MB_FAILURE; 01064 } 01065 01066 EntityType type = context.MBI->type_from_handle( blo_elems[0] ); 01067 01068 if( !blo_elems.all_of_type( type ) ) 01069 { 01070 return moab::MB_FAILURE; 01071 } // not all of same type 01072 01073 const EntityHandle* conn = NULL; 01074 int num_verts = 0; 01075 rval = context.MBI->get_connectivity( blo_elems[0], conn, num_verts );MB_CHK_ERR( rval ); 01076 01077 *vertices_per_element = num_verts; 01078 *num_elements_in_block = (int)blo_elems.size(); 01079 01080 return moab::MB_SUCCESS; 01081 } 01082 01083 ErrCode iMOAB_GetVisibleElementsInfo( iMOAB_AppID pid, 01084 int* num_visible_elements, 01085 iMOAB_GlobalID* element_global_IDs, 01086 int* ranks, 01087 iMOAB_GlobalID* block_IDs ) 01088 { 01089 appData& data = context.appDatas[*pid]; 01090 #ifdef MOAB_HAVE_MPI 01091 ParallelComm* pco = context.pcomms[*pid]; 01092 #endif 01093 01094 ErrorCode rval = context.MBI->tag_get_data( context.globalID_tag, data.primary_elems, element_global_IDs );MB_CHK_ERR( rval ); 01095 01096 int i = 0; 01097 01098 for( Range::iterator eit = data.primary_elems.begin(); eit != data.primary_elems.end(); ++eit, ++i ) 01099 { 01100 #ifdef MOAB_HAVE_MPI 01101 rval = pco->get_owner( *eit, ranks[i] );MB_CHK_ERR( rval ); 01102 01103 #else 01104 /* everything owned by task 0 */ 01105 ranks[i] = 0; 01106 #endif 01107 } 01108 01109 for( Range::iterator mit = data.mat_sets.begin(); mit != data.mat_sets.end(); ++mit ) 01110 { 01111 EntityHandle matMeshSet = *mit; 01112 Range elems; 01113 rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01114 01115 int valMatTag; 01116 rval = context.MBI->tag_get_data( context.material_tag, &matMeshSet, 1, &valMatTag );MB_CHK_ERR( rval ); 01117 01118 for( Range::iterator eit = elems.begin(); eit != elems.end(); ++eit ) 01119 { 01120 EntityHandle eh = *eit; 01121 int index = data.primary_elems.index( eh ); 01122 01123 if( -1 == index ) 01124 { 01125 return moab::MB_FAILURE; 01126 } 01127 01128 if( -1 >= *num_visible_elements ) 01129 { 01130 return moab::MB_FAILURE; 01131 } 01132 01133 block_IDs[index] = valMatTag; 01134 } 01135 } 01136 01137 return moab::MB_SUCCESS; 01138 } 01139 01140 ErrCode iMOAB_GetBlockElementConnectivities( iMOAB_AppID pid, 01141 iMOAB_GlobalID* global_block_ID, 01142 int* connectivity_length, 01143 int* element_connectivity ) 01144 { 01145 assert( global_block_ID ); // ensure global block ID argument is not null 01146 assert( connectivity_length ); // ensure connectivity length argument is not null 01147 01148 appData& data = context.appDatas[*pid]; 01149 std::map< int, int >& matMap = data.matIndex; 01150 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01151 01152 if( it == matMap.end() ) 01153 { 01154 return moab::MB_FAILURE; 01155 } // error in finding block with id 01156 01157 int blockIndex = matMap[*global_block_ID]; 01158 EntityHandle matMeshSet = data.mat_sets[blockIndex]; 01159 std::vector< EntityHandle > elems; 01160 01161 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01162 01163 if( elems.empty() ) 01164 { 01165 return moab::MB_FAILURE; 01166 } 01167 01168 std::vector< EntityHandle > vconnect; 01169 rval = context.MBI->get_connectivity( &elems[0], elems.size(), vconnect );MB_CHK_ERR( rval ); 01170 01171 if( *connectivity_length != (int)vconnect.size() ) 01172 { 01173 return moab::MB_FAILURE; 01174 } // mismatched sizes 01175 01176 for( int i = 0; i < *connectivity_length; i++ ) 01177 { 01178 int inx = data.all_verts.index( vconnect[i] ); 01179 01180 if( -1 == inx ) 01181 { 01182 return moab::MB_FAILURE; 01183 } // error, vertex not in local range 01184 01185 element_connectivity[i] = inx; 01186 } 01187 01188 return moab::MB_SUCCESS; 01189 } 01190 01191 ErrCode iMOAB_GetElementConnectivity( iMOAB_AppID pid, 01192 iMOAB_LocalID* elem_index, 01193 int* connectivity_length, 01194 int* element_connectivity ) 01195 { 01196 assert( elem_index ); // ensure element index argument is not null 01197 assert( connectivity_length ); // ensure connectivity length argument is not null 01198 01199 appData& data = context.appDatas[*pid]; 01200 assert( ( *elem_index >= 0 ) && ( *elem_index < (int)data.primary_elems.size() ) ); 01201 01202 int num_nodes; 01203 const EntityHandle* conn; 01204 01205 EntityHandle eh = data.primary_elems[*elem_index]; 01206 01207 ErrorCode rval = context.MBI->get_connectivity( eh, conn, num_nodes );MB_CHK_ERR( rval ); 01208 01209 if( *connectivity_length < num_nodes ) 01210 { 01211 return moab::MB_FAILURE; 01212 } // wrong number of vertices 01213 01214 for( int i = 0; i < num_nodes; i++ ) 01215 { 01216 int index = data.all_verts.index( conn[i] ); 01217 01218 if( -1 == index ) 01219 { 01220 return moab::MB_FAILURE; 01221 } 01222 01223 element_connectivity[i] = index; 01224 } 01225 01226 *connectivity_length = num_nodes; 01227 01228 return moab::MB_SUCCESS; 01229 } 01230 01231 ErrCode iMOAB_GetElementOwnership( iMOAB_AppID pid, 01232 iMOAB_GlobalID* global_block_ID, 01233 int* num_elements_in_block, 01234 int* element_ownership ) 01235 { 01236 assert( global_block_ID ); // ensure global block ID argument is not null 01237 assert( num_elements_in_block ); // ensure number of elements in block argument is not null 01238 01239 std::map< int, int >& matMap = context.appDatas[*pid].matIndex; 01240 01241 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01242 01243 if( it == matMap.end() ) 01244 { 01245 return moab::MB_FAILURE; 01246 } // error in finding block with id 01247 01248 int blockIndex = matMap[*global_block_ID]; 01249 EntityHandle matMeshSet = context.appDatas[*pid].mat_sets[blockIndex]; 01250 Range elems; 01251 01252 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01253 01254 if( elems.empty() ) 01255 { 01256 return moab::MB_FAILURE; 01257 } 01258 01259 if( *num_elements_in_block != (int)elems.size() ) 01260 { 01261 return moab::MB_FAILURE; 01262 } // bad memory allocation 01263 01264 int i = 0; 01265 #ifdef MOAB_HAVE_MPI 01266 ParallelComm* pco = context.pcomms[*pid]; 01267 #endif 01268 01269 for( Range::iterator vit = elems.begin(); vit != elems.end(); vit++, i++ ) 01270 { 01271 #ifdef MOAB_HAVE_MPI 01272 rval = pco->get_owner( *vit, element_ownership[i] );MB_CHK_ERR( rval ); 01273 #else 01274 element_ownership[i] = 0; /* owned by 0 */ 01275 #endif 01276 } 01277 01278 return moab::MB_SUCCESS; 01279 } 01280 01281 ErrCode iMOAB_GetElementID( iMOAB_AppID pid, 01282 iMOAB_GlobalID* global_block_ID, 01283 int* num_elements_in_block, 01284 iMOAB_GlobalID* global_element_ID, 01285 iMOAB_LocalID* local_element_ID ) 01286 { 01287 assert( global_block_ID ); // ensure global block ID argument is not null 01288 assert( num_elements_in_block ); // ensure number of elements in block argument is not null 01289 01290 appData& data = context.appDatas[*pid]; 01291 std::map< int, int >& matMap = data.matIndex; 01292 01293 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01294 01295 if( it == matMap.end() ) 01296 { 01297 return moab::MB_FAILURE; 01298 } // error in finding block with id 01299 01300 int blockIndex = matMap[*global_block_ID]; 01301 EntityHandle matMeshSet = data.mat_sets[blockIndex]; 01302 Range elems; 01303 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01304 01305 if( elems.empty() ) 01306 { 01307 return moab::MB_FAILURE; 01308 } 01309 01310 if( *num_elements_in_block != (int)elems.size() ) 01311 { 01312 return moab::MB_FAILURE; 01313 } // bad memory allocation 01314 01315 rval = context.MBI->tag_get_data( context.globalID_tag, elems, global_element_ID );MB_CHK_ERR( rval ); 01316 01317 // check that elems are among primary_elems in data 01318 for( int i = 0; i < *num_elements_in_block; i++ ) 01319 { 01320 local_element_ID[i] = data.primary_elems.index( elems[i] ); 01321 01322 if( -1 == local_element_ID[i] ) 01323 { 01324 return moab::MB_FAILURE; 01325 } // error, not in local primary elements 01326 } 01327 01328 return moab::MB_SUCCESS; 01329 } 01330 01331 ErrCode iMOAB_GetPointerToSurfaceBC( iMOAB_AppID pid, 01332 int* surface_BC_length, 01333 iMOAB_LocalID* local_element_ID, 01334 int* reference_surface_ID, 01335 int* boundary_condition_value ) 01336 { 01337 // we have to fill bc data for neumann sets;/ 01338 ErrorCode rval; 01339 01340 // it was counted above, in GetMeshInfo 01341 appData& data = context.appDatas[*pid]; 01342 int numNeuSets = (int)data.neu_sets.size(); 01343 01344 int index = 0; // index [0, surface_BC_length) for the arrays returned 01345 01346 for( int i = 0; i < numNeuSets; i++ ) 01347 { 01348 Range subents; 01349 EntityHandle nset = data.neu_sets[i]; 01350 rval = context.MBI->get_entities_by_dimension( nset, data.dimension - 1, subents );MB_CHK_ERR( rval ); 01351 01352 int neuVal; 01353 rval = context.MBI->tag_get_data( context.neumann_tag, &nset, 1, &neuVal );MB_CHK_ERR( rval ); 01354 01355 for( Range::iterator it = subents.begin(); it != subents.end(); ++it ) 01356 { 01357 EntityHandle subent = *it; 01358 Range adjPrimaryEnts; 01359 rval = context.MBI->get_adjacencies( &subent, 1, data.dimension, false, adjPrimaryEnts );MB_CHK_ERR( rval ); 01360 01361 // get global id of the primary ents, and side number of the quad/subentity 01362 // this is moab ordering 01363 for( Range::iterator pit = adjPrimaryEnts.begin(); pit != adjPrimaryEnts.end(); pit++ ) 01364 { 01365 EntityHandle primaryEnt = *pit; 01366 // get global id 01367 /*int globalID; 01368 rval = context.MBI->tag_get_data(gtags[3], &primaryEnt, 1, &globalID); 01369 if (MB_SUCCESS!=rval) 01370 return moab::MB_FAILURE; 01371 global_element_ID[index] = globalID;*/ 01372 01373 // get local element id 01374 local_element_ID[index] = data.primary_elems.index( primaryEnt ); 01375 01376 if( -1 == local_element_ID[index] ) 01377 { 01378 return moab::MB_FAILURE; 01379 } // did not find the element locally 01380 01381 int side_number, sense, offset; 01382 rval = context.MBI->side_number( primaryEnt, subent, side_number, sense, offset );MB_CHK_ERR( rval ); 01383 01384 reference_surface_ID[index] = side_number + 1; // moab is from 0 to 5, it needs 1 to 6 01385 boundary_condition_value[index] = neuVal; 01386 index++; 01387 } 01388 } 01389 } 01390 01391 if( index != *surface_BC_length ) 01392 { 01393 return moab::MB_FAILURE; 01394 } // error in array allocations 01395 01396 return moab::MB_SUCCESS; 01397 } 01398 01399 ErrCode iMOAB_GetPointerToVertexBC( iMOAB_AppID pid, 01400 int* vertex_BC_length, 01401 iMOAB_LocalID* local_vertex_ID, 01402 int* boundary_condition_value ) 01403 { 01404 ErrorCode rval; 01405 01406 // it was counted above, in GetMeshInfo 01407 appData& data = context.appDatas[*pid]; 01408 int numDiriSets = (int)data.diri_sets.size(); 01409 int index = 0; // index [0, *vertex_BC_length) for the arrays returned 01410 01411 for( int i = 0; i < numDiriSets; i++ ) 01412 { 01413 Range verts; 01414 EntityHandle diset = data.diri_sets[i]; 01415 rval = context.MBI->get_entities_by_dimension( diset, 0, verts );MB_CHK_ERR( rval ); 01416 01417 int diriVal; 01418 rval = context.MBI->tag_get_data( context.dirichlet_tag, &diset, 1, &diriVal );MB_CHK_ERR( rval ); 01419 01420 for( Range::iterator vit = verts.begin(); vit != verts.end(); ++vit ) 01421 { 01422 EntityHandle vt = *vit; 01423 /*int vgid; 01424 rval = context.MBI->tag_get_data(gtags[3], &vt, 1, &vgid); 01425 if (MB_SUCCESS!=rval) 01426 return moab::MB_FAILURE; 01427 global_vertext_ID[index] = vgid;*/ 01428 local_vertex_ID[index] = data.all_verts.index( vt ); 01429 01430 if( -1 == local_vertex_ID[index] ) 01431 { 01432 return moab::MB_FAILURE; 01433 } // vertex was not found 01434 01435 boundary_condition_value[index] = diriVal; 01436 index++; 01437 } 01438 } 01439 01440 if( *vertex_BC_length != index ) 01441 { 01442 return moab::MB_FAILURE; 01443 } // array allocation issue 01444 01445 return moab::MB_SUCCESS; 01446 } 01447 01448 ErrCode iMOAB_DefineTagStorage( iMOAB_AppID pid, 01449 const iMOAB_String tag_storage_name, 01450 int* tag_type, 01451 int* components_per_entity, 01452 int* tag_index ) 01453 { 01454 // see if the tag is already existing, and if yes, check the type, length 01455 if( *tag_type < 0 || *tag_type > 5 ) 01456 { 01457 return moab::MB_FAILURE; 01458 } // we have 6 types of tags supported so far 01459 01460 DataType tagDataType; 01461 TagType tagType; 01462 void* defaultVal = NULL; 01463 int* defInt = new int[*components_per_entity]; 01464 double* defDouble = new double[*components_per_entity]; 01465 EntityHandle* defHandle = new EntityHandle[*components_per_entity]; 01466 01467 for( int i = 0; i < *components_per_entity; i++ ) 01468 { 01469 defInt[i] = 0; 01470 defDouble[i] = -1e+10; 01471 defHandle[i] = (EntityHandle)0; 01472 } 01473 01474 switch( *tag_type ) 01475 { 01476 case 0: 01477 tagDataType = MB_TYPE_INTEGER; 01478 tagType = MB_TAG_DENSE; 01479 defaultVal = defInt; 01480 break; 01481 01482 case 1: 01483 tagDataType = MB_TYPE_DOUBLE; 01484 tagType = MB_TAG_DENSE; 01485 defaultVal = defDouble; 01486 break; 01487 01488 case 2: 01489 tagDataType = MB_TYPE_HANDLE; 01490 tagType = MB_TAG_DENSE; 01491 defaultVal = defHandle; 01492 break; 01493 01494 case 3: 01495 tagDataType = MB_TYPE_INTEGER; 01496 tagType = MB_TAG_SPARSE; 01497 defaultVal = defInt; 01498 break; 01499 01500 case 4: 01501 tagDataType = MB_TYPE_DOUBLE; 01502 tagType = MB_TAG_SPARSE; 01503 defaultVal = defDouble; 01504 break; 01505 01506 case 5: 01507 tagDataType = MB_TYPE_HANDLE; 01508 tagType = MB_TAG_SPARSE; 01509 defaultVal = defHandle; 01510 break; 01511 01512 default: { 01513 delete[] defInt; 01514 delete[] defDouble; 01515 delete[] defHandle; 01516 return moab::MB_FAILURE; 01517 } // error 01518 } 01519 01520 Tag tagHandle; 01521 // split storage names if separated list 01522 01523 std::string tag_name( tag_storage_name ); 01524 01525 // first separate the names of the tags 01526 // we assume that there are separators ":" between the tag names 01527 std::vector< std::string > tagNames; 01528 std::string separator( ":" ); 01529 split_tag_names( tag_name, separator, tagNames ); 01530 01531 ErrorCode rval = moab::MB_SUCCESS; // assume success already :) 01532 appData& data = context.appDatas[*pid]; 01533 int already_defined_tags = 0; 01534 01535 for( size_t i = 0; i < tagNames.size(); i++ ) 01536 { 01537 rval = context.MBI->tag_get_handle( tagNames[i].c_str(), *components_per_entity, tagDataType, tagHandle, 01538 tagType | MB_TAG_EXCL | MB_TAG_CREAT, defaultVal ); 01539 01540 if( MB_ALREADY_ALLOCATED == rval ) 01541 { 01542 std::map< std::string, Tag >& mTags = data.tagMap; 01543 std::map< std::string, Tag >::iterator mit = mTags.find( tagNames[i].c_str() ); 01544 01545 if( mit == mTags.end() ) 01546 { 01547 // add it to the map 01548 mTags[tagNames[i]] = tagHandle; 01549 // push it to the list of tags, too 01550 *tag_index = (int)data.tagList.size(); 01551 data.tagList.push_back( tagHandle ); 01552 } 01553 rval = MB_SUCCESS; 01554 already_defined_tags++; 01555 } 01556 else if( MB_SUCCESS == rval ) 01557 { 01558 data.tagMap[tagNames[i]] = tagHandle; 01559 *tag_index = (int)data.tagList.size(); 01560 data.tagList.push_back( tagHandle ); 01561 } 01562 else 01563 { 01564 rval = moab::MB_FAILURE; // some tags were not created 01565 } 01566 } 01567 // we don't need default values anymore, avoid leaks 01568 int rankHere = 0; 01569 #ifdef MOAB_HAVE_MPI 01570 ParallelComm* pco = context.pcomms[*pid]; 01571 rankHere = pco->rank(); 01572 #endif 01573 if( !rankHere && already_defined_tags) 01574 std::cout << " application with ID: " << *pid << " global id: " << data.global_id << " name: " << data.name 01575 << " has " << already_defined_tags << " already defined tags out of " << tagNames.size() << " tags \n"; 01576 delete[] defInt; 01577 delete[] defDouble; 01578 delete[] defHandle; 01579 return rval; 01580 } 01581 01582 ErrCode iMOAB_SetIntTagStorage( iMOAB_AppID pid, 01583 const iMOAB_String tag_storage_name, 01584 int* num_tag_storage_length, 01585 int* ent_type, 01586 int* tag_storage_data ) 01587 { 01588 std::string tag_name( tag_storage_name ); 01589 01590 // Get the application data 01591 appData& data = context.appDatas[*pid]; 01592 01593 if( data.tagMap.find( tag_name ) == data.tagMap.end() ) 01594 { 01595 return moab::MB_FAILURE; 01596 } // tag not defined 01597 01598 Tag tag = data.tagMap[tag_name]; 01599 01600 int tagLength = 0; 01601 ErrorCode rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01602 01603 DataType dtype; 01604 rval = context.MBI->tag_get_data_type( tag, dtype ); 01605 01606 if( MB_SUCCESS != rval || dtype != MB_TYPE_INTEGER ) 01607 { 01608 return moab::MB_FAILURE; 01609 } 01610 01611 // set it on a subset of entities, based on type and length 01612 Range* ents_to_set; 01613 01614 if( *ent_type == 0 ) // vertices 01615 { 01616 ents_to_set = &data.all_verts; 01617 } 01618 else // if (*ent_type == 1) // *ent_type can be 0 (vertices) or 1 (elements) 01619 { 01620 ents_to_set = &data.primary_elems; 01621 } 01622 01623 int nents_to_be_set = *num_tag_storage_length / tagLength; 01624 01625 if( nents_to_be_set > (int)ents_to_set->size() || nents_to_be_set < 1 ) 01626 { 01627 return moab::MB_FAILURE; 01628 } // to many entities to be set or too few 01629 01630 // restrict the range; everything is contiguous; or not? 01631 01632 // Range contig_range ( * ( ents_to_set->begin() ), * ( ents_to_set->begin() + nents_to_be_set - 01633 // 1 ) ); 01634 rval = context.MBI->tag_set_data( tag, *ents_to_set, tag_storage_data );MB_CHK_ERR( rval ); 01635 01636 return moab::MB_SUCCESS; // no error 01637 } 01638 01639 ErrCode iMOAB_GetIntTagStorage( iMOAB_AppID pid, 01640 const iMOAB_String tag_storage_name, 01641 int* num_tag_storage_length, 01642 int* ent_type, 01643 int* tag_storage_data ) 01644 { 01645 ErrorCode rval; 01646 std::string tag_name( tag_storage_name ); 01647 01648 appData& data = context.appDatas[*pid]; 01649 01650 if( data.tagMap.find( tag_name ) == data.tagMap.end() ) 01651 { 01652 return moab::MB_FAILURE; 01653 } // tag not defined 01654 01655 Tag tag = data.tagMap[tag_name]; 01656 01657 int tagLength = 0; 01658 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01659 01660 DataType dtype; 01661 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 01662 01663 if( dtype != MB_TYPE_INTEGER ) 01664 { 01665 return moab::MB_FAILURE; 01666 } 01667 01668 // set it on a subset of entities, based on type and length 01669 Range* ents_to_get; 01670 01671 if( *ent_type == 0 ) // vertices 01672 { 01673 ents_to_get = &data.all_verts; 01674 } 01675 else // if (*ent_type == 1) 01676 { 01677 ents_to_get = &data.primary_elems; 01678 } 01679 01680 int nents_to_get = *num_tag_storage_length / tagLength; 01681 01682 if( nents_to_get > (int)ents_to_get->size() || nents_to_get < 1 ) 01683 { 01684 return moab::MB_FAILURE; 01685 } // to many entities to get, or too little 01686 01687 // restrict the range; everything is contiguous; or not? 01688 // Range contig_range ( * ( ents_to_get->begin() ), * ( ents_to_get->begin() + nents_to_get - 1 01689 // ) ); 01690 01691 rval = context.MBI->tag_get_data( tag, *ents_to_get, tag_storage_data );MB_CHK_ERR( rval ); 01692 01693 return moab::MB_SUCCESS; // no error 01694 } 01695 01696 ErrCode iMOAB_SetDoubleTagStorage( iMOAB_AppID pid, 01697 const iMOAB_String tag_storage_names, 01698 int* num_tag_storage_length, 01699 int* ent_type, 01700 double* tag_storage_data ) 01701 { 01702 ErrorCode rval; 01703 std::string tag_names( tag_storage_names ); 01704 // exactly the same code as for int tag :) maybe should check the type of tag too 01705 std::vector< std::string > tagNames; 01706 std::vector< Tag > tagHandles; 01707 std::string separator( ":" ); 01708 split_tag_names( tag_names, separator, tagNames ); 01709 01710 appData& data = context.appDatas[*pid]; 01711 Range* ents_to_set = NULL; 01712 01713 if( *ent_type == 0 ) // vertices 01714 { 01715 ents_to_set = &data.all_verts; 01716 } 01717 else if( *ent_type == 1 ) 01718 { 01719 ents_to_set = &data.primary_elems; 01720 } 01721 01722 int nents_to_be_set = (int)( *ents_to_set ).size(); 01723 int position = 0; 01724 01725 for( size_t i = 0; i < tagNames.size(); i++ ) 01726 { 01727 if( data.tagMap.find( tagNames[i] ) == data.tagMap.end() ) 01728 { 01729 return moab::MB_FAILURE; 01730 } // some tag not defined yet in the app 01731 01732 Tag tag = data.tagMap[tagNames[i]]; 01733 01734 int tagLength = 0; 01735 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01736 01737 DataType dtype; 01738 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 01739 01740 if( dtype != MB_TYPE_DOUBLE ) 01741 { 01742 return moab::MB_FAILURE; 01743 } 01744 01745 // set it on the subset of entities, based on type and length 01746 if( position + tagLength * nents_to_be_set > *num_tag_storage_length ) 01747 return moab::MB_FAILURE; // too many entity values to be set 01748 01749 rval = context.MBI->tag_set_data( tag, *ents_to_set, &tag_storage_data[position] );MB_CHK_ERR( rval ); 01750 // increment position to next tag 01751 position = position + tagLength * nents_to_be_set; 01752 } 01753 return moab::MB_SUCCESS; // no error 01754 } 01755 01756 ErrCode iMOAB_SetDoubleTagStorageWithGid( iMOAB_AppID pid, 01757 const iMOAB_String tag_storage_names, 01758 int* num_tag_storage_length, 01759 int* ent_type, 01760 double* tag_storage_data, 01761 int* globalIds ) 01762 { 01763 ErrorCode rval; 01764 std::string tag_names( tag_storage_names ); 01765 // exactly the same code as for int tag :) maybe should check the type of tag too 01766 std::vector< std::string > tagNames; 01767 std::vector< Tag > tagHandles; 01768 std::string separator( ":" ); 01769 split_tag_names( tag_names, separator, tagNames ); 01770 01771 appData& data = context.appDatas[*pid]; 01772 Range* ents_to_set = NULL; 01773 01774 if( *ent_type == 0 ) // vertices 01775 { 01776 ents_to_set = &data.all_verts; 01777 } 01778 else if( *ent_type == 1 ) 01779 { 01780 ents_to_set = &data.primary_elems; 01781 } 01782 01783 int nents_to_be_set = (int)( *ents_to_set ).size(); 01784 01785 Tag gidTag = context.MBI->globalId_tag(); 01786 std::vector< int > gids; 01787 gids.resize( nents_to_be_set ); 01788 rval = context.MBI->tag_get_data( gidTag, *ents_to_set, &gids[0] );MB_CHK_ERR( rval ); 01789 01790 // so we will need to set the tags according to the global id passed; 01791 // so the order in tag_storage_data is the same as the order in globalIds, but the order 01792 // in local range is gids 01793 std::map< int, EntityHandle > eh_by_gid; 01794 int i = 0; 01795 for( Range::iterator it = ents_to_set->begin(); it != ents_to_set->end(); ++it, ++i ) 01796 { 01797 eh_by_gid[gids[i]] = *it; 01798 } 01799 01800 std::vector< int > tagLengths( tagNames.size() ); 01801 std::vector< Tag > tagList; 01802 size_t total_tag_len = 0; 01803 for( size_t i = 0; i < tagNames.size(); i++ ) 01804 { 01805 if( data.tagMap.find( tagNames[i] ) == data.tagMap.end() ) 01806 { 01807 MB_SET_ERR( moab::MB_FAILURE, "tag missing" ); 01808 } // some tag not defined yet in the app 01809 01810 Tag tag = data.tagMap[tagNames[i]]; 01811 tagList.push_back( tag ); 01812 01813 int tagLength = 0; 01814 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01815 01816 total_tag_len += tagLength; 01817 tagLengths[i] = tagLength; 01818 DataType dtype; 01819 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 01820 01821 if( dtype != MB_TYPE_DOUBLE ) 01822 { 01823 MB_SET_ERR( moab::MB_FAILURE, "tag not double type" ); 01824 } 01825 } 01826 bool serial = true; 01827 #ifdef MOAB_HAVE_MPI 01828 ParallelComm* pco = context.pcomms[*pid]; 01829 unsigned num_procs = pco->size(); 01830 if( num_procs > 1 ) serial = false; 01831 #endif 01832 01833 if( serial ) 01834 { 01835 assert( total_tag_len * nents_to_be_set - *num_tag_storage_length == 0 ); 01836 // tags are unrolled, we loop over global ids first, then careful about tags 01837 for( int i = 0; i < nents_to_be_set; i++ ) 01838 { 01839 int gid = globalIds[i]; 01840 EntityHandle eh = eh_by_gid[gid]; 01841 // now loop over tags 01842 int indexInTagValues = 0; // 01843 for( size_t j = 0; j < tagList.size(); j++ ) 01844 { 01845 indexInTagValues += i * tagLengths[j]; 01846 rval = context.MBI->tag_set_data( tagList[j], &eh, 1, &tag_storage_data[indexInTagValues] );MB_CHK_ERR( rval ); 01847 // advance the pointer/index 01848 indexInTagValues += ( nents_to_be_set - i ) * tagLengths[j]; // at the end of tag data 01849 } 01850 } 01851 } 01852 #ifdef MOAB_HAVE_MPI 01853 else // it can be not serial only if pco->size() > 1, parallel 01854 { 01855 // in this case, we have to use 2 crystal routers, to send data to the processor that needs it 01856 // we will create first a tuple to rendevous points, then from there send to the processor that requested it 01857 // it is a 2-hop global gather scatter 01858 int nbLocalVals = *num_tag_storage_length / ( (int)tagNames.size() ); 01859 assert( nbLocalVals * tagNames.size() - *num_tag_storage_length == 0 ); 01860 TupleList TLsend; 01861 TLsend.initialize( 2, 0, 0, total_tag_len, nbLocalVals ); // to proc, marker(gid), total_tag_len doubles 01862 TLsend.enableWriteAccess(); 01863 // the processor id that processes global_id is global_id / num_ents_per_proc 01864 01865 int indexInRealLocal = 0; 01866 for( int i = 0; i < nbLocalVals; i++ ) 01867 { 01868 // to proc, marker, element local index, index in el 01869 int marker = globalIds[i]; 01870 int to_proc = marker % num_procs; 01871 int n = TLsend.get_n(); 01872 TLsend.vi_wr[2 * n] = to_proc; // send to processor 01873 TLsend.vi_wr[2 * n + 1] = marker; 01874 int indexInTagValues = 0; 01875 // tag data collect by number of tags 01876 for( size_t j = 0; j < tagList.size(); j++ ) 01877 { 01878 indexInTagValues += i * tagLengths[j]; 01879 for( int k = 0; k < tagLengths[j]; k++ ) 01880 { 01881 TLsend.vr_wr[indexInRealLocal++] = tag_storage_data[indexInTagValues + k]; 01882 } 01883 indexInTagValues += ( nbLocalVals - i ) * tagLengths[j]; 01884 } 01885 TLsend.inc_n(); 01886 } 01887 01888 assert( nbLocalVals * total_tag_len - indexInRealLocal == 0 ); 01889 // send now requests, basically inform the rendez-vous point who needs a particular global id 01890 // send the data to the other processors: 01891 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLsend, 0 ); 01892 TupleList TLreq; 01893 TLreq.initialize( 2, 0, 0, 0, nents_to_be_set ); 01894 TLreq.enableWriteAccess(); 01895 for( int i = 0; i < nents_to_be_set; i++ ) 01896 { 01897 // to proc, marker 01898 int marker = gids[i]; 01899 int to_proc = marker % num_procs; 01900 int n = TLreq.get_n(); 01901 TLreq.vi_wr[2 * n] = to_proc; // send to processor 01902 TLreq.vi_wr[2 * n + 1] = marker; 01903 // tag data collect by number of tags 01904 TLreq.inc_n(); 01905 } 01906 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLreq, 0 ); 01907 01908 // we know now that process TLreq.vi_wr[2 * n] needs tags for gid TLreq.vi_wr[2 * n + 1] 01909 // we should first order by global id, and then build the new TL with send to proc, global id and 01910 // tags for it 01911 // sort by global ids the tuple lists 01912 moab::TupleList::buffer sort_buffer; 01913 sort_buffer.buffer_init( TLreq.get_n() ); 01914 TLreq.sort( 1, &sort_buffer ); 01915 sort_buffer.reset(); 01916 sort_buffer.buffer_init( TLsend.get_n() ); 01917 TLsend.sort( 1, &sort_buffer ); 01918 sort_buffer.reset(); 01919 // now send the tag values to the proc that requested it 01920 // in theory, for a full partition, TLreq and TLsend should have the same size, and 01921 // each dof should have exactly one target proc. Is that true or not in general ? 01922 // how do we plan to use this? Is it better to store the comm graph for future 01923 01924 // start copy from comm graph settle 01925 TupleList TLBack; 01926 TLBack.initialize( 3, 0, 0, total_tag_len, 0 ); // to proc, marker, tag from proc , tag values 01927 TLBack.enableWriteAccess(); 01928 01929 int n1 = TLreq.get_n(); 01930 int n2 = TLsend.get_n(); 01931 01932 int indexInTLreq = 0; 01933 int indexInTLsend = 0; // advance both, according to the marker 01934 if( n1 > 0 && n2 > 0 ) 01935 { 01936 01937 while( indexInTLreq < n1 && indexInTLsend < n2 ) // if any is over, we are done 01938 { 01939 int currentValue1 = TLreq.vi_rd[2 * indexInTLreq + 1]; 01940 int currentValue2 = TLsend.vi_rd[2 * indexInTLsend + 1]; 01941 if( currentValue1 < currentValue2 ) 01942 { 01943 // we have a big problem; basically, we are saying that 01944 // dof currentValue is on one model and not on the other 01945 // std::cout << " currentValue1:" << currentValue1 << " missing in comp2" << "\n"; 01946 indexInTLreq++; 01947 continue; 01948 } 01949 if( currentValue1 > currentValue2 ) 01950 { 01951 // std::cout << " currentValue2:" << currentValue2 << " missing in comp1" << "\n"; 01952 indexInTLsend++; 01953 continue; 01954 } 01955 int size1 = 1; 01956 int size2 = 1; 01957 while( indexInTLreq + size1 < n1 && currentValue1 == TLreq.vi_rd[2 * ( indexInTLreq + size1 ) + 1] ) 01958 size1++; 01959 while( indexInTLsend + size2 < n2 && currentValue2 == TLsend.vi_rd[2 * ( indexInTLsend + size2 ) + 1] ) 01960 size2++; 01961 // must be found in both lists, find the start and end indices 01962 for( int i1 = 0; i1 < size1; i1++ ) 01963 { 01964 for( int i2 = 0; i2 < size2; i2++ ) 01965 { 01966 // send the info back to components 01967 int n = TLBack.get_n(); 01968 TLBack.reserve(); 01969 TLBack.vi_wr[3 * n] = TLreq.vi_rd[2 * ( indexInTLreq + i1 )]; // send back to the proc marker 01970 // came from, info from comp2 01971 TLBack.vi_wr[3 * n + 1] = currentValue1; // initial value (resend, just for verif ?) 01972 TLBack.vi_wr[3 * n + 2] = TLsend.vi_rd[2 * ( indexInTLsend + i2 )]; // from proc on comp2 01973 // also fill tag values 01974 for( size_t k = 0; k < total_tag_len; k++ ) 01975 { 01976 TLBack.vr_rd[total_tag_len * n + k] = 01977 TLsend.vr_rd[total_tag_len * indexInTLsend + k]; // deep copy of tag values 01978 } 01979 } 01980 } 01981 indexInTLreq += size1; 01982 indexInTLsend += size2; 01983 } 01984 } 01985 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLBack, 0 ); 01986 // end copy from comm graph 01987 // after we are done sending, we need to set those tag values, in a reverse process compared to send 01988 n1 = TLBack.get_n(); 01989 double* ptrVal = &TLBack.vr_rd[0]; // 01990 for( int i = 0; i < n1; i++ ) 01991 { 01992 int gid = TLBack.vi_rd[3 * i + 1]; // marker 01993 EntityHandle eh = eh_by_gid[gid]; 01994 // now loop over tags 01995 01996 for( size_t j = 0; j < tagList.size(); j++ ) 01997 { 01998 rval = context.MBI->tag_set_data( tagList[j], &eh, 1, (void*)ptrVal );MB_CHK_ERR( rval ); 01999 // advance the pointer/index 02000 ptrVal += tagLengths[j]; // at the end of tag data per call 02001 } 02002 } 02003 } 02004 #endif 02005 return MB_SUCCESS; 02006 } 02007 ErrCode iMOAB_GetDoubleTagStorage( iMOAB_AppID pid, 02008 const iMOAB_String tag_storage_names, 02009 int* num_tag_storage_length, 02010 int* ent_type, 02011 double* tag_storage_data ) 02012 { 02013 ErrorCode rval; 02014 // exactly the same code, except tag type check 02015 std::string tag_names( tag_storage_names ); 02016 // exactly the same code as for int tag :) maybe should check the type of tag too 02017 std::vector< std::string > tagNames; 02018 std::vector< Tag > tagHandles; 02019 std::string separator( ":" ); 02020 split_tag_names( tag_names, separator, tagNames ); 02021 02022 appData& data = context.appDatas[*pid]; 02023 02024 // set it on a subset of entities, based on type and length 02025 Range* ents_to_get = NULL; 02026 02027 if( *ent_type == 0 ) // vertices 02028 { 02029 ents_to_get = &data.all_verts; 02030 } 02031 else if( *ent_type == 1 ) 02032 { 02033 ents_to_get = &data.primary_elems; 02034 } 02035 int nents_to_get = (int)ents_to_get->size(); 02036 int position = 0; 02037 for( size_t i = 0; i < tagNames.size(); i++ ) 02038 { 02039 if( data.tagMap.find( tagNames[i] ) == data.tagMap.end() ) 02040 { 02041 return moab::MB_FAILURE; 02042 } // tag not defined 02043 02044 Tag tag = data.tagMap[tagNames[i]]; 02045 02046 int tagLength = 0; 02047 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 02048 02049 DataType dtype; 02050 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 02051 02052 if( dtype != MB_TYPE_DOUBLE ) 02053 { 02054 return moab::MB_FAILURE; 02055 } 02056 02057 if( position + nents_to_get * tagLength > *num_tag_storage_length ) 02058 return moab::MB_FAILURE; // too many entity values to get 02059 02060 rval = context.MBI->tag_get_data( tag, *ents_to_get, &tag_storage_data[position] );MB_CHK_ERR( rval ); 02061 position = position + nents_to_get * tagLength; 02062 } 02063 02064 return moab::MB_SUCCESS; // no error 02065 } 02066 02067 ErrCode iMOAB_SynchronizeTags( iMOAB_AppID pid, int* num_tag, int* tag_indices, int* ent_type ) 02068 { 02069 #ifdef MOAB_HAVE_MPI 02070 appData& data = context.appDatas[*pid]; 02071 Range ent_exchange; 02072 std::vector< Tag > tags; 02073 02074 for( int i = 0; i < *num_tag; i++ ) 02075 { 02076 if( tag_indices[i] < 0 || tag_indices[i] >= (int)data.tagList.size() ) 02077 { 02078 return moab::MB_FAILURE; 02079 } // error in tag index 02080 02081 tags.push_back( data.tagList[tag_indices[i]] ); 02082 } 02083 02084 if( *ent_type == 0 ) 02085 { 02086 ent_exchange = data.all_verts; 02087 } 02088 else if( *ent_type == 1 ) 02089 { 02090 ent_exchange = data.primary_elems; 02091 } 02092 else 02093 { 02094 return moab::MB_FAILURE; 02095 } // unexpected type 02096 02097 ParallelComm* pco = context.pcomms[*pid]; 02098 02099 ErrorCode rval = pco->exchange_tags( tags, tags, ent_exchange );MB_CHK_ERR( rval ); 02100 02101 #else 02102 /* do nothing if serial */ 02103 // just silence the warning 02104 // do not call sync tags in serial! 02105 int k = *pid + *num_tag + *tag_indices + *ent_type; 02106 k++; 02107 #endif 02108 02109 return moab::MB_SUCCESS; 02110 } 02111 02112 ErrCode iMOAB_ReduceTagsMax( iMOAB_AppID pid, int* tag_index, int* ent_type ) 02113 { 02114 #ifdef MOAB_HAVE_MPI 02115 appData& data = context.appDatas[*pid]; 02116 Range ent_exchange; 02117 02118 if( *tag_index < 0 || *tag_index >= (int)data.tagList.size() ) 02119 { 02120 return moab::MB_FAILURE; 02121 } // error in tag index 02122 02123 Tag tagh = data.tagList[*tag_index]; 02124 02125 if( *ent_type == 0 ) 02126 { 02127 ent_exchange = data.all_verts; 02128 } 02129 else if( *ent_type == 1 ) 02130 { 02131 ent_exchange = data.primary_elems; 02132 } 02133 else 02134 { 02135 return moab::MB_FAILURE; 02136 } // unexpected type 02137 02138 ParallelComm* pco = context.pcomms[*pid]; 02139 // we could do different MPI_Op; do not bother now, we will call from fortran 02140 ErrorCode rval = pco->reduce_tags( tagh, MPI_MAX, ent_exchange );MB_CHK_ERR( rval ); 02141 02142 #else 02143 /* do nothing if serial */ 02144 // just silence the warning 02145 // do not call sync tags in serial! 02146 int k = *pid + *tag_index + *ent_type; 02147 k++; // just do junk, to avoid complaints 02148 #endif 02149 return moab::MB_SUCCESS; 02150 } 02151 02152 ErrCode iMOAB_GetNeighborElements( iMOAB_AppID pid, 02153 iMOAB_LocalID* local_index, 02154 int* num_adjacent_elements, 02155 iMOAB_LocalID* adjacent_element_IDs ) 02156 { 02157 ErrorCode rval; 02158 02159 // one neighbor for each subentity of dimension-1 02160 MeshTopoUtil mtu( context.MBI ); 02161 appData& data = context.appDatas[*pid]; 02162 EntityHandle eh = data.primary_elems[*local_index]; 02163 Range adjs; 02164 rval = mtu.get_bridge_adjacencies( eh, data.dimension - 1, data.dimension, adjs );MB_CHK_ERR( rval ); 02165 02166 if( *num_adjacent_elements < (int)adjs.size() ) 02167 { 02168 return moab::MB_FAILURE; 02169 } // not dimensioned correctly 02170 02171 *num_adjacent_elements = (int)adjs.size(); 02172 02173 for( int i = 0; i < *num_adjacent_elements; i++ ) 02174 { 02175 adjacent_element_IDs[i] = data.primary_elems.index( adjs[i] ); 02176 } 02177 02178 return moab::MB_SUCCESS; 02179 } 02180 02181 #if 0 02182 02183 ErrCode iMOAB_GetNeighborVertices ( iMOAB_AppID pid, iMOAB_LocalID* local_vertex_ID, int* num_adjacent_vertices, iMOAB_LocalID* adjacent_vertex_IDs ) 02184 { 02185 return moab::MB_SUCCESS; 02186 } 02187 02188 #endif 02189 02190 ErrCode iMOAB_CreateVertices( iMOAB_AppID pid, int* coords_len, int* dim, double* coordinates ) 02191 { 02192 ErrorCode rval; 02193 appData& data = context.appDatas[*pid]; 02194 02195 if( !data.local_verts.empty() ) // we should have no vertices in the app 02196 { 02197 return moab::MB_FAILURE; 02198 } 02199 02200 int nverts = *coords_len / *dim; 02201 02202 rval = context.MBI->create_vertices( coordinates, nverts, data.local_verts );MB_CHK_ERR( rval ); 02203 02204 rval = context.MBI->add_entities( data.file_set, data.local_verts );MB_CHK_ERR( rval ); 02205 02206 // also add the vertices to the all_verts range 02207 data.all_verts.merge( data.local_verts ); 02208 return moab::MB_SUCCESS; 02209 } 02210 02211 ErrCode iMOAB_CreateElements( iMOAB_AppID pid, 02212 int* num_elem, 02213 int* type, 02214 int* num_nodes_per_element, 02215 int* connectivity, 02216 int* block_ID ) 02217 { 02218 // Create elements 02219 appData& data = context.appDatas[*pid]; 02220 02221 ReadUtilIface* read_iface; 02222 ErrorCode rval = context.MBI->query_interface( read_iface );MB_CHK_ERR( rval ); 02223 02224 EntityType mbtype = (EntityType)( *type ); 02225 EntityHandle actual_start_handle; 02226 EntityHandle* array = NULL; 02227 rval = read_iface->get_element_connect( *num_elem, *num_nodes_per_element, mbtype, 1, actual_start_handle, array );MB_CHK_ERR( rval ); 02228 02229 // fill up with actual connectivity from input; assume the vertices are in order, and start 02230 // vertex is the first in the current data vertex range 02231 EntityHandle firstVertex = data.local_verts[0]; 02232 02233 for( int j = 0; j < *num_elem * ( *num_nodes_per_element ); j++ ) 02234 { 02235 array[j] = connectivity[j] + firstVertex - 1; 02236 } // assumes connectivity uses 1 based array (from fortran, mostly) 02237 02238 Range new_elems( actual_start_handle, actual_start_handle + *num_elem - 1 ); 02239 02240 rval = context.MBI->add_entities( data.file_set, new_elems );MB_CHK_ERR( rval ); 02241 02242 data.primary_elems.merge( new_elems ); 02243 02244 // add to adjacency 02245 rval = read_iface->update_adjacencies( actual_start_handle, *num_elem, *num_nodes_per_element, array );MB_CHK_ERR( rval ); 02246 // organize all new elements in block, with the given block ID; if the block set is not 02247 // existing, create a new mesh set; 02248 Range sets; 02249 int set_no = *block_ID; 02250 const void* setno_ptr = &set_no; 02251 rval = context.MBI->get_entities_by_type_and_tag( data.file_set, MBENTITYSET, &context.material_tag, &setno_ptr, 1, 02252 sets ); 02253 EntityHandle block_set; 02254 02255 if( MB_FAILURE == rval || sets.empty() ) 02256 { 02257 // create a new set, with this block ID 02258 rval = context.MBI->create_meshset( MESHSET_SET, block_set );MB_CHK_ERR( rval ); 02259 02260 rval = context.MBI->tag_set_data( context.material_tag, &block_set, 1, &set_no );MB_CHK_ERR( rval ); 02261 02262 // add the material set to file set 02263 rval = context.MBI->add_entities( data.file_set, &block_set, 1 );MB_CHK_ERR( rval ); 02264 } 02265 else 02266 { 02267 block_set = sets[0]; 02268 } // first set is the one we want 02269 02270 /// add the new ents to the clock set 02271 rval = context.MBI->add_entities( block_set, new_elems );MB_CHK_ERR( rval ); 02272 02273 return moab::MB_SUCCESS; 02274 } 02275 02276 ErrCode iMOAB_SetGlobalInfo( iMOAB_AppID pid, int* num_global_verts, int* num_global_elems ) 02277 { 02278 appData& data = context.appDatas[*pid]; 02279 data.num_global_vertices = *num_global_verts; 02280 data.num_global_elements = *num_global_elems; 02281 return moab::MB_SUCCESS; 02282 } 02283 02284 ErrCode iMOAB_GetGlobalInfo( iMOAB_AppID pid, int* num_global_verts, int* num_global_elems ) 02285 { 02286 appData& data = context.appDatas[*pid]; 02287 if( NULL != num_global_verts ) 02288 { 02289 *num_global_verts = data.num_global_vertices; 02290 } 02291 if( NULL != num_global_elems ) 02292 { 02293 *num_global_elems = data.num_global_elements; 02294 } 02295 02296 return moab::MB_SUCCESS; 02297 } 02298 02299 #ifdef MOAB_HAVE_MPI 02300 02301 // this makes sense only for parallel runs 02302 ErrCode iMOAB_ResolveSharedEntities( iMOAB_AppID pid, int* num_verts, int* marker ) 02303 { 02304 appData& data = context.appDatas[*pid]; 02305 ParallelComm* pco = context.pcomms[*pid]; 02306 EntityHandle cset = data.file_set; 02307 int dum_id = 0; 02308 ErrorCode rval; 02309 if( data.primary_elems.empty() ) 02310 { 02311 // skip actual resolve, assume vertices are distributed already , 02312 // no need to share them 02313 } 02314 else 02315 { 02316 // create an integer tag for resolving ; maybe it can be a long tag in the future 02317 // (more than 2 B vertices;) 02318 02319 Tag stag; 02320 rval = context.MBI->tag_get_handle( "__sharedmarker", 1, MB_TYPE_INTEGER, stag, MB_TAG_CREAT | MB_TAG_DENSE, 02321 &dum_id );MB_CHK_ERR( rval ); 02322 02323 if( *num_verts > (int)data.local_verts.size() ) 02324 { 02325 return moab::MB_FAILURE; 02326 } // we are not setting the size 02327 02328 rval = context.MBI->tag_set_data( stag, data.local_verts, (void*)marker );MB_CHK_ERR( rval ); // assumes integer tag 02329 02330 rval = pco->resolve_shared_ents( cset, -1, -1, &stag );MB_CHK_ERR( rval ); 02331 02332 rval = context.MBI->tag_delete( stag );MB_CHK_ERR( rval ); 02333 } 02334 // provide partition tag equal to rank 02335 Tag part_tag; 02336 dum_id = -1; 02337 rval = context.MBI->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_tag, 02338 MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id ); 02339 02340 if( part_tag == NULL || ( ( rval != MB_SUCCESS ) && ( rval != MB_ALREADY_ALLOCATED ) ) ) 02341 { 02342 std::cout << " can't get par part tag.\n"; 02343 return moab::MB_FAILURE; 02344 } 02345 02346 int rank = pco->rank(); 02347 rval = context.MBI->tag_set_data( part_tag, &cset, 1, &rank );MB_CHK_ERR( rval ); 02348 02349 return moab::MB_SUCCESS; 02350 } 02351 02352 // this assumes that this was not called before 02353 ErrCode iMOAB_DetermineGhostEntities( iMOAB_AppID pid, int* ghost_dim, int* num_ghost_layers, int* bridge_dim ) 02354 { 02355 ErrorCode rval; 02356 02357 // verify we have valid ghost layers input specified. If invalid, exit quick. 02358 if( *num_ghost_layers <= 0 ) 02359 { 02360 return moab::MB_SUCCESS; 02361 } // nothing to do 02362 02363 appData& data = context.appDatas[*pid]; 02364 ParallelComm* pco = context.pcomms[*pid]; 02365 02366 int addl_ents = 02367 0; // maybe we should be passing this too; most of the time we do not need additional ents collective call 02368 rval = 02369 pco->exchange_ghost_cells( *ghost_dim, *bridge_dim, *num_ghost_layers, addl_ents, true, true, &data.file_set );MB_CHK_ERR( rval ); 02370 02371 // now re-establish all mesh info; will reconstruct mesh info, based solely on what is in the file set 02372 return iMOAB_UpdateMeshInfo( pid ); 02373 } 02374 02375 ErrCode iMOAB_SendMesh( iMOAB_AppID pid, MPI_Comm* join, MPI_Group* receivingGroup, int* rcompid, int* method ) 02376 { 02377 assert( join != nullptr ); 02378 assert( receivingGroup != nullptr ); 02379 assert( rcompid != nullptr ); 02380 02381 ErrorCode rval; 02382 int ierr; 02383 appData& data = context.appDatas[*pid]; 02384 ParallelComm* pco = context.pcomms[*pid]; 02385 02386 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02387 MPI_Group recvGroup = 02388 ( data.is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( receivingGroup ) ) : *receivingGroup ); 02389 MPI_Comm sender = pco->comm(); // the sender comm is obtained from parallel comm in moab; no need to pass it along 02390 // first see what are the processors in each group; get the sender group too, from the sender communicator 02391 MPI_Group senderGroup; 02392 ierr = MPI_Comm_group( sender, &senderGroup ); 02393 if( ierr != 0 ) return moab::MB_FAILURE; 02394 02395 // instantiate the par comm graph 02396 // ParCommGraph::ParCommGraph(MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, 02397 // int coid2) 02398 ParCommGraph* cgraph = 02399 new ParCommGraph( global, senderGroup, recvGroup, context.appDatas[*pid].global_id, *rcompid ); 02400 // we should search if we have another pcomm with the same comp ids in the list already 02401 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 02402 context.appDatas[*pid].pgraph[*rcompid] = cgraph; 02403 02404 int sender_rank = -1; 02405 MPI_Comm_rank( sender, &sender_rank ); 02406 02407 // decide how to distribute elements to each processor 02408 // now, get the entities on local processor, and pack them into a buffer for various processors 02409 // we will do trivial partition: first get the total number of elements from "sender" 02410 std::vector< int > number_elems_per_part; 02411 // how to distribute local elements to receiving tasks? 02412 // trivial partition: compute first the total number of elements need to be sent 02413 Range owned = context.appDatas[*pid].owned_elems; 02414 if( owned.size() == 0 ) 02415 { 02416 // must be vertices that we want to send then 02417 owned = context.appDatas[*pid].local_verts; 02418 // we should have some vertices here 02419 } 02420 02421 if( *method == 0 ) // trivial partitioning, old method 02422 { 02423 int local_owned_elem = (int)owned.size(); 02424 int size = pco->size(); 02425 int rank = pco->rank(); 02426 number_elems_per_part.resize( size ); // 02427 number_elems_per_part[rank] = local_owned_elem; 02428 #if( MPI_VERSION >= 2 ) 02429 // Use "in place" option 02430 ierr = MPI_Allgather( MPI_IN_PLACE, 0, MPI_DATATYPE_NULL, &number_elems_per_part[0], 1, MPI_INT, sender ); 02431 #else 02432 { 02433 std::vector< int > all_tmp( size ); 02434 ierr = MPI_Allgather( &number_elems_per_part[rank], 1, MPI_INT, &all_tmp[0], 1, MPI_INT, sender ); 02435 number_elems_per_part = all_tmp; 02436 } 02437 #endif 02438 02439 if( ierr != 0 ) 02440 { 02441 return moab::MB_FAILURE; 02442 } 02443 02444 // every sender computes the trivial partition, it is cheap, and we need to send it anyway 02445 // to each sender 02446 rval = cgraph->compute_trivial_partition( number_elems_per_part );MB_CHK_ERR( rval ); 02447 02448 rval = cgraph->send_graph( global );MB_CHK_ERR( rval ); 02449 } 02450 else // *method != 0, so it is either graph or geometric, parallel 02451 { 02452 // owned are the primary elements on this app 02453 rval = cgraph->compute_partition( pco, owned, *method );MB_CHK_ERR( rval ); 02454 02455 // basically, send the graph to the receiver side, with unblocking send 02456 rval = cgraph->send_graph_partition( pco, global );MB_CHK_ERR( rval ); 02457 } 02458 // pco is needed to pack, not for communication 02459 rval = cgraph->send_mesh_parts( global, pco, owned );MB_CHK_ERR( rval ); 02460 02461 // mark for deletion 02462 MPI_Group_free( &senderGroup ); 02463 return moab::MB_SUCCESS; 02464 } 02465 02466 ErrCode iMOAB_ReceiveMesh( iMOAB_AppID pid, MPI_Comm* join, MPI_Group* sendingGroup, int* scompid ) 02467 { 02468 assert( join != nullptr ); 02469 assert( sendingGroup != nullptr ); 02470 assert( scompid != nullptr ); 02471 02472 ErrorCode rval; 02473 appData& data = context.appDatas[*pid]; 02474 ParallelComm* pco = context.pcomms[*pid]; 02475 MPI_Comm receive = pco->comm(); 02476 EntityHandle local_set = data.file_set; 02477 02478 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02479 MPI_Group sendGroup = 02480 ( data.is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( sendingGroup ) ) : *sendingGroup ); 02481 02482 // first see what are the processors in each group; get the sender group too, from the sender 02483 // communicator 02484 MPI_Group receiverGroup; 02485 int ierr = MPI_Comm_group( receive, &receiverGroup );CHK_MPI_ERR( ierr ); 02486 02487 // instantiate the par comm graph 02488 ParCommGraph* cgraph = 02489 new ParCommGraph( global, sendGroup, receiverGroup, *scompid, context.appDatas[*pid].global_id ); 02490 // TODO we should search if we have another pcomm with the same comp ids in the list already 02491 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 02492 context.appDatas[*pid].pgraph[*scompid] = cgraph; 02493 02494 int receiver_rank = -1; 02495 MPI_Comm_rank( receive, &receiver_rank ); 02496 02497 // first, receive from sender_rank 0, the communication graph (matrix), so each receiver 02498 // knows what data to expect 02499 std::vector< int > pack_array; 02500 rval = cgraph->receive_comm_graph( global, pco, pack_array );MB_CHK_ERR( rval ); 02501 02502 // senders across for the current receiver 02503 int current_receiver = cgraph->receiver( receiver_rank ); 02504 02505 std::vector< int > senders_local; 02506 size_t n = 0; 02507 02508 while( n < pack_array.size() ) 02509 { 02510 if( current_receiver == pack_array[n] ) 02511 { 02512 for( int j = 0; j < pack_array[n + 1]; j++ ) 02513 { 02514 senders_local.push_back( pack_array[n + 2 + j] ); 02515 } 02516 02517 break; 02518 } 02519 02520 n = n + 2 + pack_array[n + 1]; 02521 } 02522 02523 #ifdef VERBOSE 02524 std::cout << " receiver " << current_receiver << " at rank " << receiver_rank << " will receive from " 02525 << senders_local.size() << " tasks: "; 02526 02527 for( int k = 0; k < (int)senders_local.size(); k++ ) 02528 { 02529 std::cout << " " << senders_local[k]; 02530 } 02531 02532 std::cout << "\n"; 02533 #endif 02534 02535 if( senders_local.empty() ) 02536 { 02537 std::cout << " we do not have any senders for receiver rank " << receiver_rank << "\n"; 02538 } 02539 rval = cgraph->receive_mesh( global, pco, local_set, senders_local );MB_CHK_ERR( rval ); 02540 02541 // after we are done, we could merge vertices that come from different senders, but 02542 // have the same global id 02543 Tag idtag; 02544 rval = context.MBI->tag_get_handle( "GLOBAL_ID", idtag );MB_CHK_ERR( rval ); 02545 02546 // data.point_cloud = false; 02547 Range local_ents; 02548 rval = context.MBI->get_entities_by_handle( local_set, local_ents );MB_CHK_ERR( rval ); 02549 02550 // do not do merge if point cloud 02551 if( !local_ents.all_of_type( MBVERTEX ) ) 02552 { 02553 if( (int)senders_local.size() >= 2 ) // need to remove duplicate vertices 02554 // that might come from different senders 02555 { 02556 02557 Range local_verts = local_ents.subset_by_type( MBVERTEX ); 02558 Range local_elems = subtract( local_ents, local_verts ); 02559 02560 // remove from local set the vertices 02561 rval = context.MBI->remove_entities( local_set, local_verts );MB_CHK_ERR( rval ); 02562 02563 #ifdef VERBOSE 02564 std::cout << "current_receiver " << current_receiver << " local verts: " << local_verts.size() << "\n"; 02565 #endif 02566 MergeMesh mm( context.MBI ); 02567 02568 rval = mm.merge_using_integer_tag( local_verts, idtag );MB_CHK_ERR( rval ); 02569 02570 Range new_verts; // local elems are local entities without vertices 02571 rval = context.MBI->get_connectivity( local_elems, new_verts );MB_CHK_ERR( rval ); 02572 02573 #ifdef VERBOSE 02574 std::cout << "after merging: new verts: " << new_verts.size() << "\n"; 02575 #endif 02576 rval = context.MBI->add_entities( local_set, new_verts );MB_CHK_ERR( rval ); 02577 } 02578 } 02579 else 02580 data.point_cloud = true; 02581 02582 if( !data.point_cloud ) 02583 { 02584 // still need to resolve shared entities (in this case, vertices ) 02585 rval = pco->resolve_shared_ents( local_set, -1, -1, &idtag );MB_CHK_ERR( rval ); 02586 } 02587 else 02588 { 02589 // if partition tag exists, set it to current rank; just to make it visible in VisIt 02590 Tag densePartTag; 02591 rval = context.MBI->tag_get_handle( "partition", densePartTag ); 02592 if( NULL != densePartTag && MB_SUCCESS == rval ) 02593 { 02594 Range local_verts; 02595 rval = context.MBI->get_entities_by_dimension( local_set, 0, local_verts );MB_CHK_ERR( rval ); 02596 std::vector< int > vals; 02597 int rank = pco->rank(); 02598 vals.resize( local_verts.size(), rank ); 02599 rval = context.MBI->tag_set_data( densePartTag, local_verts, &vals[0] );MB_CHK_ERR( rval ); 02600 } 02601 } 02602 // set the parallel partition tag 02603 Tag part_tag; 02604 int dum_id = -1; 02605 rval = context.MBI->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_tag, 02606 MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id ); 02607 02608 if( part_tag == NULL || ( ( rval != MB_SUCCESS ) && ( rval != MB_ALREADY_ALLOCATED ) ) ) 02609 { 02610 std::cout << " can't get par part tag.\n"; 02611 return moab::MB_FAILURE; 02612 } 02613 02614 int rank = pco->rank(); 02615 rval = context.MBI->tag_set_data( part_tag, &local_set, 1, &rank );MB_CHK_ERR( rval ); 02616 02617 // populate the mesh with current data info 02618 rval = iMOAB_UpdateMeshInfo( pid );MB_CHK_ERR( rval ); 02619 02620 // mark for deletion 02621 MPI_Group_free( &receiverGroup ); 02622 02623 return moab::MB_SUCCESS; 02624 } 02625 02626 ErrCode iMOAB_SendElementTag( iMOAB_AppID pid, const iMOAB_String tag_storage_name, MPI_Comm* join, int* context_id ) 02627 { 02628 appData& data = context.appDatas[*pid]; 02629 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *context_id ); 02630 if( mt == data.pgraph.end() ) 02631 { 02632 return moab::MB_FAILURE; 02633 } 02634 ParCommGraph* cgraph = mt->second; 02635 ParallelComm* pco = context.pcomms[*pid]; 02636 Range owned = data.owned_elems; 02637 ErrorCode rval; 02638 EntityHandle cover_set; 02639 02640 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02641 if( data.point_cloud ) 02642 { 02643 owned = data.local_verts; 02644 } 02645 02646 // another possibility is for par comm graph to be computed from iMOAB_ComputeCommGraph, for 02647 // after atm ocn intx, from phys (case from imoab_phatm_ocn_coupler.cpp) get then the cover set 02648 // from ints remapper 02649 #ifdef MOAB_HAVE_TEMPESTREMAP 02650 if( data.tempestData.remapper != NULL ) // this is the case this is part of intx;; 02651 { 02652 cover_set = data.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 02653 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02654 // should still have only quads ? 02655 } 02656 #else 02657 // now, in case we are sending from intx between ocn and atm, we involve coverage set 02658 // how do I know if this receiver already participated in an intersection driven by coupler? 02659 // also, what if this was the "source" mesh in intx? 02660 // in that case, the elements might have been instantiated in the coverage set locally, the 02661 // "owned" range can be different the elements are now in tempestRemap coverage_set 02662 cover_set = cgraph->get_cover_set(); // this will be non null only for intx app ? 02663 02664 if( 0 != cover_set ) 02665 { 02666 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02667 } 02668 #endif 02669 02670 std::string tag_name( tag_storage_name ); 02671 02672 // basically, we assume everything is defined already on the tag, 02673 // and we can get the tags just by its name 02674 // we assume that there are separators ":" between the tag names 02675 std::vector< std::string > tagNames; 02676 std::vector< Tag > tagHandles; 02677 std::string separator( ":" ); 02678 split_tag_names( tag_name, separator, tagNames ); 02679 for( size_t i = 0; i < tagNames.size(); i++ ) 02680 { 02681 Tag tagHandle; 02682 rval = context.MBI->tag_get_handle( tagNames[i].c_str(), tagHandle ); 02683 if( MB_SUCCESS != rval || NULL == tagHandle ) 02684 { 02685 std::cout << " can't get tag handle for tag named:" << tagNames[i].c_str() << " at index " << i << "\n";MB_CHK_SET_ERR( rval, "can't get tag handle" ); 02686 } 02687 tagHandles.push_back( tagHandle ); 02688 } 02689 02690 // pco is needed to pack, and for moab instance, not for communication! 02691 // still use nonblocking communication, over the joint comm 02692 rval = cgraph->send_tag_values( global, pco, owned, tagHandles );MB_CHK_ERR( rval ); 02693 // now, send to each corr_tasks[i] tag data for corr_sizes[i] primary entities 02694 02695 return moab::MB_SUCCESS; 02696 } 02697 02698 ErrCode iMOAB_ReceiveElementTag( iMOAB_AppID pid, const iMOAB_String tag_storage_name, MPI_Comm* join, int* context_id ) 02699 { 02700 appData& data = context.appDatas[*pid]; 02701 02702 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *context_id ); 02703 if( mt == data.pgraph.end() ) 02704 { 02705 return moab::MB_FAILURE; 02706 } 02707 ParCommGraph* cgraph = mt->second; 02708 02709 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02710 ParallelComm* pco = context.pcomms[*pid]; 02711 Range owned = data.owned_elems; 02712 02713 // how do I know if this receiver already participated in an intersection driven by coupler? 02714 // also, what if this was the "source" mesh in intx? 02715 // in that case, the elements might have been instantiated in the coverage set locally, the 02716 // "owned" range can be different the elements are now in tempestRemap coverage_set 02717 EntityHandle cover_set = cgraph->get_cover_set(); 02718 ErrorCode rval; 02719 if( 0 != cover_set ) 02720 { 02721 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02722 } 02723 if( data.point_cloud ) 02724 { 02725 owned = data.local_verts; 02726 } 02727 // another possibility is for par comm graph to be computed from iMOAB_ComputeCommGraph, for 02728 // after atm ocn intx, from phys (case from imoab_phatm_ocn_coupler.cpp) get then the cover set 02729 // from ints remapper 02730 #ifdef MOAB_HAVE_TEMPESTREMAP 02731 if( data.tempestData.remapper != NULL ) // this is the case this is part of intx;; 02732 { 02733 cover_set = data.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 02734 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02735 // should still have only quads ? 02736 } 02737 #endif 02738 /* 02739 * data_intx.remapper exists though only on the intersection application 02740 * how do we get from here ( we know the pid that receives, and the commgraph used by migrate 02741 * mesh ) 02742 */ 02743 02744 std::string tag_name( tag_storage_name ); 02745 02746 // we assume that there are separators ";" between the tag names 02747 std::vector< std::string > tagNames; 02748 std::vector< Tag > tagHandles; 02749 std::string separator( ":" ); 02750 split_tag_names( tag_name, separator, tagNames ); 02751 for( size_t i = 0; i < tagNames.size(); i++ ) 02752 { 02753 Tag tagHandle; 02754 rval = context.MBI->tag_get_handle( tagNames[i].c_str(), tagHandle ); 02755 if( MB_SUCCESS != rval || NULL == tagHandle ) 02756 { 02757 std::cout << " can't get tag handle for tag named:" << tagNames[i].c_str() << " at index " << i << "\n";MB_CHK_SET_ERR( rval, "can't get tag handle" ); 02758 } 02759 tagHandles.push_back( tagHandle ); 02760 } 02761 02762 #ifdef VERBOSE 02763 std::cout << pco->rank() << ". Looking to receive data for tags: " << tag_name 02764 << " and file set = " << ( data.file_set ) << "\n"; 02765 #endif 02766 // pco is needed to pack, and for moab instance, not for communication! 02767 // still use nonblocking communication 02768 rval = cgraph->receive_tag_values( global, pco, owned, tagHandles );MB_CHK_ERR( rval ); 02769 02770 #ifdef VERBOSE 02771 std::cout << pco->rank() << ". Looking to receive data for tags: " << tag_name << "\n"; 02772 #endif 02773 02774 return moab::MB_SUCCESS; 02775 } 02776 02777 ErrCode iMOAB_FreeSenderBuffers( iMOAB_AppID pid, int* context_id ) 02778 { 02779 // need first to find the pgraph that holds the information we need 02780 // this will be called on sender side only 02781 appData& data = context.appDatas[*pid]; 02782 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *context_id ); 02783 if( mt == data.pgraph.end() ) return moab::MB_FAILURE; // error 02784 02785 mt->second->release_send_buffers(); 02786 return moab::MB_SUCCESS; 02787 } 02788 02789 /** 02790 \brief compute a comm graph between 2 moab apps, based on ID matching 02791 <B>Operations:</B> Collective 02792 */ 02793 //#define VERBOSE 02794 ErrCode iMOAB_ComputeCommGraph( iMOAB_AppID pid1, 02795 iMOAB_AppID pid2, 02796 MPI_Comm* join, 02797 MPI_Group* group1, 02798 MPI_Group* group2, 02799 int* type1, 02800 int* type2, 02801 int* comp1, 02802 int* comp2 ) 02803 { 02804 assert( join ); 02805 assert( group1 ); 02806 assert( group2 ); 02807 ErrorCode rval = MB_SUCCESS; 02808 int localRank = 0, numProcs = 1; 02809 02810 bool isFortran = false; 02811 if (*pid1>=0) isFortran = isFortran || context.appDatas[*pid1].is_fortran; 02812 if (*pid2>=0) isFortran = isFortran || context.appDatas[*pid2].is_fortran; 02813 02814 MPI_Comm global = ( isFortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02815 MPI_Group srcGroup = ( isFortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( group1 ) ) : *group1 ); 02816 MPI_Group tgtGroup = ( isFortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( group2 ) ) : *group2 ); 02817 02818 MPI_Comm_rank( global, &localRank ); 02819 MPI_Comm_size( global, &numProcs ); 02820 // instantiate the par comm graph 02821 02822 // we should search if we have another pcomm with the same comp ids in the list already 02823 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 02824 bool already_exists = false; 02825 if( *pid1 >= 0 ) 02826 { 02827 appData& data = context.appDatas[*pid1]; 02828 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *comp2); 02829 if ( mt != data.pgraph.end() ) 02830 already_exists = true; 02831 } 02832 if( *pid2 >= 0 ) 02833 { 02834 appData& data = context.appDatas[*pid2]; 02835 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *comp1); 02836 if ( mt != data.pgraph.end() ) 02837 already_exists = true; 02838 } 02839 // nothing to do if it already exists 02840 if (already_exists) 02841 { 02842 #ifdef VERBOSE 02843 if (!localRank) 02844 std::cout << " parcomgraph already existing between components "<< 02845 *comp1 << " and " << *comp2 << ". Do not compute again\n"; 02846 #endif 02847 return moab::MB_SUCCESS; 02848 } 02849 02850 // ParCommGraph::ParCommGraph(MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, 02851 // int coid2) 02852 ParCommGraph* cgraph = NULL; 02853 if( *pid1 >= 0 ) cgraph = new ParCommGraph( global, srcGroup, tgtGroup, *comp1, *comp2 ); 02854 ParCommGraph* cgraph_rev = NULL; 02855 if( *pid2 >= 0 ) cgraph_rev = new ParCommGraph( global, tgtGroup, srcGroup, *comp2, *comp1 ); 02856 02857 if( *pid1 >= 0 ) context.appDatas[*pid1].pgraph[*comp2] = cgraph; // the context will be the other comp 02858 if( *pid2 >= 0 ) context.appDatas[*pid2].pgraph[*comp1] = cgraph_rev; // from 2 to 1 02859 // each model has a list of global ids that will need to be sent by gs to rendezvous the other 02860 // model on the joint comm 02861 TupleList TLcomp1; 02862 TLcomp1.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 02863 TupleList TLcomp2; 02864 TLcomp2.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 02865 // will push_back a new tuple, if needed 02866 02867 TLcomp1.enableWriteAccess(); 02868 02869 // tags of interest are either GLOBAL_DOFS or GLOBAL_ID 02870 Tag gdsTag; 02871 // find the values on first cell 02872 int lenTagType1 = 1; 02873 if( 1 == *type1 || 1 == *type2 ) 02874 { 02875 rval = context.MBI->tag_get_handle( "GLOBAL_DOFS", gdsTag );MB_CHK_ERR( rval ); 02876 rval = context.MBI->tag_get_length( gdsTag, lenTagType1 );MB_CHK_ERR( rval ); // usually it is 16 02877 } 02878 Tag tagType2 = context.MBI->globalId_tag(); 02879 02880 std::vector< int > valuesComp1; 02881 // populate first tuple 02882 if( *pid1 >= 0 ) 02883 { 02884 appData& data1 = context.appDatas[*pid1]; 02885 EntityHandle fset1 = data1.file_set; 02886 // in case of tempest remap, get the coverage set 02887 #ifdef MOAB_HAVE_TEMPESTREMAP 02888 if( data1.tempestData.remapper != NULL ) // this is the case this is part of intx;; 02889 { 02890 fset1 = data1.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 02891 // should still have only quads ? 02892 } 02893 #endif 02894 Range ents_of_interest; 02895 if( *type1 == 1 ) 02896 { 02897 assert( gdsTag ); 02898 rval = context.MBI->get_entities_by_type( fset1, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 02899 valuesComp1.resize( ents_of_interest.size() * lenTagType1 ); 02900 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); 02901 } 02902 else if( *type1 == 2 ) 02903 { 02904 rval = context.MBI->get_entities_by_type( fset1, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 02905 valuesComp1.resize( ents_of_interest.size() ); 02906 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 02907 } 02908 else if( *type1 == 3 ) // for FV meshes, just get the global id of cell 02909 { 02910 rval = context.MBI->get_entities_by_dimension( fset1, 2, ents_of_interest );MB_CHK_ERR( rval ); 02911 valuesComp1.resize( ents_of_interest.size() ); 02912 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 02913 } 02914 else 02915 { 02916 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 or 3 02917 } 02918 // now fill the tuple list with info and markers 02919 // because we will send only the ids, order and compress the list 02920 std::set< int > uniq( valuesComp1.begin(), valuesComp1.end() ); 02921 TLcomp1.resize( uniq.size() ); 02922 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 02923 { 02924 // to proc, marker, element local index, index in el 02925 int marker = *sit; 02926 int to_proc = marker % numProcs; 02927 int n = TLcomp1.get_n(); 02928 TLcomp1.vi_wr[2 * n] = to_proc; // send to processor 02929 TLcomp1.vi_wr[2 * n + 1] = marker; 02930 TLcomp1.inc_n(); 02931 } 02932 } 02933 02934 ProcConfig pc( global ); // proc config does the crystal router 02935 pc.crystal_router()->gs_transfer( 1, TLcomp1, 02936 0 ); // communication towards joint tasks, with markers 02937 // sort by value (key 1) 02938 #ifdef VERBOSE 02939 std::stringstream ff1; 02940 ff1 << "TLcomp1_" << localRank << ".txt"; 02941 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 02942 #endif 02943 moab::TupleList::buffer sort_buffer; 02944 sort_buffer.buffer_init( TLcomp1.get_n() ); 02945 TLcomp1.sort( 1, &sort_buffer ); 02946 sort_buffer.reset(); 02947 #ifdef VERBOSE 02948 // after sorting 02949 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 02950 #endif 02951 // do the same, for the other component, number2, with type2 02952 // start copy 02953 TLcomp2.enableWriteAccess(); 02954 // populate second tuple 02955 std::vector< int > valuesComp2; 02956 if( *pid2 >= 0 ) 02957 { 02958 appData& data2 = context.appDatas[*pid2]; 02959 EntityHandle fset2 = data2.file_set; 02960 // in case of tempest remap, get the coverage set 02961 #ifdef MOAB_HAVE_TEMPESTREMAP 02962 if( data2.tempestData.remapper != NULL ) // this is the case this is part of intx;; 02963 { 02964 fset2 = data2.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 02965 // should still have only quads ? 02966 } 02967 #endif 02968 02969 Range ents_of_interest; 02970 if( *type2 == 1 ) 02971 { 02972 assert( gdsTag ); 02973 rval = context.MBI->get_entities_by_type( fset2, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 02974 valuesComp2.resize( ents_of_interest.size() * lenTagType1 ); 02975 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &valuesComp2[0] );MB_CHK_ERR( rval ); 02976 } 02977 else if( *type2 == 2 ) 02978 { 02979 rval = context.MBI->get_entities_by_type( fset2, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 02980 valuesComp2.resize( ents_of_interest.size() ); // stride is 1 here 02981 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp2[0] );MB_CHK_ERR( rval ); // just global ids 02982 } 02983 else if( *type2 == 3 ) 02984 { 02985 rval = context.MBI->get_entities_by_dimension( fset2, 2, ents_of_interest );MB_CHK_ERR( rval ); 02986 valuesComp2.resize( ents_of_interest.size() ); // stride is 1 here 02987 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp2[0] );MB_CHK_ERR( rval ); // just global ids 02988 } 02989 else 02990 { 02991 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 02992 } 02993 // now fill the tuple list with info and markers 02994 std::set< int > uniq( valuesComp2.begin(), valuesComp2.end() ); 02995 TLcomp2.resize( uniq.size() ); 02996 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 02997 { 02998 // to proc, marker, element local index, index in el 02999 int marker = *sit; 03000 int to_proc = marker % numProcs; 03001 int n = TLcomp2.get_n(); 03002 TLcomp2.vi_wr[2 * n] = to_proc; // send to processor 03003 TLcomp2.vi_wr[2 * n + 1] = marker; 03004 TLcomp2.inc_n(); 03005 } 03006 } 03007 pc.crystal_router()->gs_transfer( 1, TLcomp2, 03008 0 ); // communication towards joint tasks, with markers 03009 // sort by value (key 1) 03010 #ifdef VERBOSE 03011 std::stringstream ff2; 03012 ff2 << "TLcomp2_" << localRank << ".txt"; 03013 TLcomp2.print_to_file( ff2.str().c_str() ); 03014 #endif 03015 sort_buffer.buffer_reserve( TLcomp2.get_n() ); 03016 TLcomp2.sort( 1, &sort_buffer ); 03017 sort_buffer.reset(); 03018 // end copy 03019 #ifdef VERBOSE 03020 TLcomp2.print_to_file( ff2.str().c_str() ); 03021 #endif 03022 // need to send back the info, from the rendezvous point, for each of the values 03023 /* so go over each value, on local process in joint communicator 03024 03025 now have to send back the info needed for communication; 03026 loop in in sync over both TLComp1 and TLComp2, in local process; 03027 So, build new tuple lists, to send synchronous communication 03028 populate them at the same time, based on marker, that is indexed 03029 */ 03030 03031 TupleList TLBackToComp1; 03032 TLBackToComp1.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc on comp2, 03033 TLBackToComp1.enableWriteAccess(); 03034 03035 TupleList TLBackToComp2; 03036 TLBackToComp2.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc, 03037 TLBackToComp2.enableWriteAccess(); 03038 03039 int n1 = TLcomp1.get_n(); 03040 int n2 = TLcomp2.get_n(); 03041 03042 int indexInTLComp1 = 0; 03043 int indexInTLComp2 = 0; // advance both, according to the marker 03044 if( n1 > 0 && n2 > 0 ) 03045 { 03046 03047 while( indexInTLComp1 < n1 && indexInTLComp2 < n2 ) // if any is over, we are done 03048 { 03049 int currentValue1 = TLcomp1.vi_rd[2 * indexInTLComp1 + 1]; 03050 int currentValue2 = TLcomp2.vi_rd[2 * indexInTLComp2 + 1]; 03051 if( currentValue1 < currentValue2 ) 03052 { 03053 // we have a big problem; basically, we are saying that 03054 // dof currentValue is on one model and not on the other 03055 // std::cout << " currentValue1:" << currentValue1 << " missing in comp2" << "\n"; 03056 indexInTLComp1++; 03057 continue; 03058 } 03059 if( currentValue1 > currentValue2 ) 03060 { 03061 // std::cout << " currentValue2:" << currentValue2 << " missing in comp1" << "\n"; 03062 indexInTLComp2++; 03063 continue; 03064 } 03065 int size1 = 1; 03066 int size2 = 1; 03067 while( indexInTLComp1 + size1 < n1 && currentValue1 == TLcomp1.vi_rd[2 * ( indexInTLComp1 + size1 ) + 1] ) 03068 size1++; 03069 while( indexInTLComp2 + size2 < n2 && currentValue2 == TLcomp2.vi_rd[2 * ( indexInTLComp2 + size2 ) + 1] ) 03070 size2++; 03071 // must be found in both lists, find the start and end indices 03072 for( int i1 = 0; i1 < size1; i1++ ) 03073 { 03074 for( int i2 = 0; i2 < size2; i2++ ) 03075 { 03076 // send the info back to components 03077 int n = TLBackToComp1.get_n(); 03078 TLBackToComp1.reserve(); 03079 TLBackToComp1.vi_wr[3 * n] = 03080 TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // send back to the proc marker 03081 // came from, info from comp2 03082 TLBackToComp1.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 03083 TLBackToComp1.vi_wr[3 * n + 2] = TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // from proc on comp2 03084 n = TLBackToComp2.get_n(); 03085 TLBackToComp2.reserve(); 03086 TLBackToComp2.vi_wr[3 * n] = 03087 TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // send back info to original 03088 TLBackToComp2.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 03089 TLBackToComp2.vi_wr[3 * n + 2] = TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // from proc on comp1 03090 // what if there are repeated markers in TLcomp2? increase just index2 03091 } 03092 } 03093 indexInTLComp1 += size1; 03094 indexInTLComp2 += size2; 03095 } 03096 } 03097 pc.crystal_router()->gs_transfer( 1, TLBackToComp1, 0 ); // communication towards original tasks, with info about 03098 pc.crystal_router()->gs_transfer( 1, TLBackToComp2, 0 ); 03099 03100 if( *pid1 >= 0 ) 03101 { 03102 // we are on original comp 1 tasks 03103 // before ordering 03104 // now for each value in TLBackToComp1.vi_rd[3*i+1], on current proc, we know the 03105 // processors it communicates with 03106 #ifdef VERBOSE 03107 std::stringstream f1; 03108 f1 << "TLBack1_" << localRank << ".txt"; 03109 TLBackToComp1.print_to_file( f1.str().c_str() ); 03110 #endif 03111 sort_buffer.buffer_reserve( TLBackToComp1.get_n() ); 03112 TLBackToComp1.sort( 1, &sort_buffer ); 03113 sort_buffer.reset(); 03114 #ifdef VERBOSE 03115 TLBackToComp1.print_to_file( f1.str().c_str() ); 03116 #endif 03117 // so we are now on pid1, we know now each marker were it has to go 03118 // add a new method to ParCommGraph, to set up the involved_IDs_map 03119 cgraph->settle_comm_by_ids( *comp1, TLBackToComp1, valuesComp1 ); 03120 } 03121 if( *pid2 >= 0 ) 03122 { 03123 // we are on original comp 1 tasks 03124 // before ordering 03125 // now for each value in TLBackToComp1.vi_rd[3*i+1], on current proc, we know the 03126 // processors it communicates with 03127 #ifdef VERBOSE 03128 std::stringstream f2; 03129 f2 << "TLBack2_" << localRank << ".txt"; 03130 TLBackToComp2.print_to_file( f2.str().c_str() ); 03131 #endif 03132 sort_buffer.buffer_reserve( TLBackToComp2.get_n() ); 03133 TLBackToComp2.sort( 2, &sort_buffer ); 03134 sort_buffer.reset(); 03135 #ifdef VERBOSE 03136 TLBackToComp2.print_to_file( f2.str().c_str() ); 03137 #endif 03138 cgraph_rev->settle_comm_by_ids( *comp2, TLBackToComp2, valuesComp2 ); 03139 // 03140 } 03141 return moab::MB_SUCCESS; 03142 } 03143 03144 //#undef VERBOSE 03145 03146 ErrCode iMOAB_MergeVertices( iMOAB_AppID pid ) 03147 { 03148 appData& data = context.appDatas[*pid]; 03149 ParallelComm* pco = context.pcomms[*pid]; 03150 // collapse vertices and transform cells into triangles/quads /polys 03151 // tags we care about: area, frac, global id 03152 std::vector< Tag > tagsList; 03153 Tag tag; 03154 ErrorCode rval = context.MBI->tag_get_handle( "GLOBAL_ID", tag ); 03155 if( !tag || rval != MB_SUCCESS ) return moab::MB_FAILURE; // fatal error, abort 03156 tagsList.push_back( tag ); 03157 rval = context.MBI->tag_get_handle( "area", tag ); 03158 if( tag && rval == MB_SUCCESS ) tagsList.push_back( tag ); 03159 rval = context.MBI->tag_get_handle( "frac", tag ); 03160 if( tag && rval == MB_SUCCESS ) tagsList.push_back( tag ); 03161 double tol = 1.0e-9; 03162 rval = IntxUtils::remove_duplicate_vertices( context.MBI, data.file_set, tol, tagsList );MB_CHK_ERR( rval ); 03163 03164 // clean material sets of cells that were deleted 03165 rval = context.MBI->get_entities_by_type_and_tag( data.file_set, MBENTITYSET, &( context.material_tag ), 0, 1, 03166 data.mat_sets, Interface::UNION );MB_CHK_ERR( rval ); 03167 03168 if( !data.mat_sets.empty() ) 03169 { 03170 EntityHandle matSet = data.mat_sets[0]; 03171 Range elems; 03172 rval = context.MBI->get_entities_by_dimension( matSet, 2, elems );MB_CHK_ERR( rval ); 03173 rval = context.MBI->remove_entities( matSet, elems );MB_CHK_ERR( rval ); 03174 // put back only cells from data.file_set 03175 elems.clear(); 03176 rval = context.MBI->get_entities_by_dimension( data.file_set, 2, elems );MB_CHK_ERR( rval ); 03177 rval = context.MBI->add_entities( matSet, elems );MB_CHK_ERR( rval ); 03178 } 03179 rval = iMOAB_UpdateMeshInfo( pid );MB_CHK_ERR( rval ); 03180 03181 ParallelMergeMesh pmm( pco, tol ); 03182 rval = pmm.merge( data.file_set, 03183 /* do not do local merge*/ false, 03184 /* 2d cells*/ 2 );MB_CHK_ERR( rval ); 03185 03186 // assign global ids only for vertices, cells have them fine 03187 rval = pco->assign_global_ids( data.file_set, /*dim*/ 0 );MB_CHK_ERR( rval ); 03188 03189 // set the partition tag on the file set 03190 Tag part_tag; 03191 int dum_id = -1; 03192 rval = context.MBI->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_tag, 03193 MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id ); 03194 03195 if( part_tag == NULL || ( ( rval != MB_SUCCESS ) && ( rval != MB_ALREADY_ALLOCATED ) ) ) 03196 { 03197 std::cout << " can't get par part tag.\n"; 03198 return moab::MB_FAILURE; 03199 } 03200 03201 int rank = pco->rank(); 03202 rval = context.MBI->tag_set_data( part_tag, &data.file_set, 1, &rank );MB_CHK_ERR( rval ); 03203 03204 return moab::MB_SUCCESS; 03205 } 03206 03207 #ifdef MOAB_HAVE_TEMPESTREMAP 03208 03209 // this call must be collective on the joint communicator 03210 // intersection tasks on coupler will need to send to the components tasks the list of 03211 // id elements that are relevant: they intersected some of the target elements (which are not needed 03212 // here) 03213 // in the intersection 03214 ErrCode iMOAB_CoverageGraph( MPI_Comm* join, 03215 iMOAB_AppID pid_src, 03216 iMOAB_AppID pid_migr, 03217 iMOAB_AppID pid_intx, 03218 int* src_id, 03219 int* migr_id, 03220 int* context_id ) 03221 { 03222 // first, based on the scompid and migrcomp, find the parCommGraph corresponding to this 03223 // exchange 03224 ErrorCode rval; 03225 std::vector< int > srcSenders; 03226 std::vector< int > receivers; 03227 ParCommGraph* sendGraph = NULL; 03228 int ierr; 03229 int default_context_id = -1; 03230 bool is_fortran_context = false; 03231 03232 // First, find the original graph between PE sets 03233 // And based on this one, we will build the newly modified one for coverage 03234 if( *pid_src >= 0 ) 03235 { 03236 default_context_id = *migr_id; // the other one 03237 assert( context.appDatas[*pid_src].global_id == *src_id ); 03238 is_fortran_context = context.appDatas[*pid_src].is_fortran || is_fortran_context; 03239 sendGraph = context.appDatas[*pid_src].pgraph[default_context_id]; // maybe check if it does not exist 03240 03241 // report the sender and receiver tasks in the joint comm 03242 srcSenders = sendGraph->senders(); 03243 receivers = sendGraph->receivers(); 03244 #ifdef VERBOSE 03245 std::cout << "senders: " << srcSenders.size() << " first sender: " << srcSenders[0] << std::endl; 03246 #endif 03247 } 03248 03249 ParCommGraph* recvGraph = NULL; // will be non null on receiver tasks (intx tasks) 03250 if( *pid_migr >= 0 ) 03251 { 03252 is_fortran_context = context.appDatas[*pid_migr].is_fortran || is_fortran_context; 03253 // find the original one 03254 default_context_id = *src_id; 03255 assert( context.appDatas[*pid_migr].global_id == *migr_id ); 03256 recvGraph = context.appDatas[*pid_migr].pgraph[default_context_id]; 03257 // report the sender and receiver tasks in the joint comm, from migrated mesh pt of view 03258 srcSenders = recvGraph->senders(); 03259 receivers = recvGraph->receivers(); 03260 #ifdef VERBOSE 03261 std::cout << "receivers: " << receivers.size() << " first receiver: " << receivers[0] << std::endl; 03262 #endif 03263 } 03264 03265 if( *pid_intx >= 0 ) is_fortran_context = context.appDatas[*pid_intx].is_fortran || is_fortran_context; 03266 03267 // loop over pid_intx elements, to see what original processors in joint comm have sent the 03268 // coverage mesh; 03269 // If we are on intx tasks, send coverage info towards original component tasks, 03270 // about needed cells 03271 TupleList TLcovIDs; 03272 TLcovIDs.initialize( 2, 0, 0, 0, 0 ); // to proc, GLOBAL ID; estimate about 100 IDs to be sent 03273 // will push_back a new tuple, if needed 03274 TLcovIDs.enableWriteAccess(); 03275 // the crystal router will send ID cell to the original source, on the component task 03276 // if we are on intx tasks, loop over all intx elements and 03277 03278 MPI_Comm global = ( is_fortran_context ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 03279 int currentRankInJointComm = -1; 03280 ierr = MPI_Comm_rank( global, ¤tRankInJointComm );CHK_MPI_ERR( ierr ); 03281 03282 // if currentRankInJointComm is in receivers list, it means that we are on intx tasks too, we 03283 // need to send information towards component tasks 03284 if( find( receivers.begin(), receivers.end(), currentRankInJointComm ) != 03285 receivers.end() ) // we are on receivers tasks, we can request intx info 03286 { 03287 // find the pcomm for the intx pid 03288 if( *pid_intx >= (int)context.appDatas.size() ) return moab::MB_FAILURE; 03289 03290 appData& dataIntx = context.appDatas[*pid_intx]; 03291 Tag parentTag, orgSendProcTag; 03292 03293 rval = context.MBI->tag_get_handle( "SourceParent", parentTag );MB_CHK_ERR( rval ); // global id of the blue, source element 03294 if( !parentTag ) return moab::MB_FAILURE; // fatal error, abort 03295 03296 rval = context.MBI->tag_get_handle( "orig_sending_processor", orgSendProcTag );MB_CHK_ERR( rval ); 03297 if( !orgSendProcTag ) return moab::MB_FAILURE; // fatal error, abort 03298 03299 // find the file set, red parents for intx cells, and put them in tuples 03300 EntityHandle intxSet = dataIntx.file_set; 03301 Range cells; 03302 // get all entities from the set, and look at their RedParent 03303 rval = context.MBI->get_entities_by_dimension( intxSet, 2, cells );MB_CHK_ERR( rval ); 03304 03305 std::map< int, std::set< int > > idsFromProcs; // send that info back to enhance parCommGraph cache 03306 for( Range::iterator it = cells.begin(); it != cells.end(); it++ ) 03307 { 03308 EntityHandle intx_cell = *it; 03309 int gidCell, origProc; // look at receivers 03310 03311 rval = context.MBI->tag_get_data( parentTag, &intx_cell, 1, &gidCell );MB_CHK_ERR( rval ); 03312 rval = context.MBI->tag_get_data( orgSendProcTag, &intx_cell, 1, &origProc );MB_CHK_ERR( rval ); 03313 // we have augmented the overlap set with ghost cells ; in that case, the 03314 // orig_sending_processor is not set so it will be -1; 03315 if( origProc < 0 ) continue; 03316 03317 std::set< int >& setInts = idsFromProcs[origProc]; 03318 setInts.insert( gidCell ); 03319 } 03320 03321 // if we have no intx cells, it means we are on point clouds; quick fix just use all cells 03322 // from coverage set 03323 if( cells.empty() ) 03324 { 03325 // get coverage set 03326 assert( *pid_intx >= 0 ); 03327 appData& dataIntx = context.appDatas[*pid_intx]; 03328 EntityHandle cover_set = dataIntx.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 03329 03330 // get all cells from coverage set 03331 Tag gidTag; 03332 rval = context.MBI->tag_get_handle( "GLOBAL_ID", gidTag );MB_CHK_ERR( rval ); 03333 rval = context.MBI->get_entities_by_dimension( cover_set, 2, cells );MB_CHK_ERR( rval ); 03334 // look at their orig_sending_processor 03335 for( Range::iterator it = cells.begin(); it != cells.end(); it++ ) 03336 { 03337 EntityHandle covCell = *it; 03338 int gidCell, origProc; // look at o 03339 03340 rval = context.MBI->tag_get_data( gidTag, &covCell, 1, &gidCell );MB_CHK_ERR( rval ); 03341 rval = context.MBI->tag_get_data( orgSendProcTag, &covCell, 1, &origProc );MB_CHK_ERR( rval ); 03342 // we have augmented the overlap set with ghost cells ; in that case, the 03343 // orig_sending_processor is not set so it will be -1; 03344 if( origProc < 0 ) // it cannot < 0, I think 03345 continue; 03346 std::set< int >& setInts = idsFromProcs[origProc]; 03347 setInts.insert( gidCell ); 03348 } 03349 } 03350 03351 #ifdef VERBOSE 03352 std::ofstream dbfile; 03353 std::stringstream outf; 03354 outf << "idsFromProc_0" << currentRankInJointComm << ".txt"; 03355 dbfile.open( outf.str().c_str() ); 03356 dbfile << "Writing this to a file.\n"; 03357 03358 dbfile << " map size:" << idsFromProcs.size() 03359 << std::endl; // on the receiver side, these show how much data to receive 03360 // from the sender (how many ids, and how much tag data later; we need to size up the 03361 // receiver buffer) arrange in tuples , use map iterators to send the ids 03362 for( std::map< int, std::set< int > >::iterator mt = idsFromProcs.begin(); mt != idsFromProcs.end(); mt++ ) 03363 { 03364 std::set< int >& setIds = mt->second; 03365 dbfile << "from id: " << mt->first << " receive " << setIds.size() << " cells \n"; 03366 int counter = 0; 03367 for( std::set< int >::iterator st = setIds.begin(); st != setIds.end(); st++ ) 03368 { 03369 int valueID = *st; 03370 dbfile << " " << valueID; 03371 counter++; 03372 if( counter % 10 == 0 ) dbfile << "\n"; 03373 } 03374 dbfile << "\n"; 03375 } 03376 dbfile.close(); 03377 #endif 03378 if( NULL != recvGraph ) 03379 { 03380 ParCommGraph* recvGraph1 = new ParCommGraph( *recvGraph ); // just copy 03381 recvGraph1->set_context_id( *context_id ); 03382 recvGraph1->SetReceivingAfterCoverage( idsFromProcs ); 03383 // this par comm graph will need to use the coverage set 03384 // so we are for sure on intx pes (the receiver is the coupler mesh) 03385 assert( *pid_intx >= 0 ); 03386 appData& dataIntx = context.appDatas[*pid_intx]; 03387 EntityHandle cover_set = dataIntx.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 03388 recvGraph1->set_cover_set( cover_set ); 03389 context.appDatas[*pid_migr].pgraph[*context_id] = recvGraph1; // possible memory leak if context_id is same 03390 } 03391 for( std::map< int, std::set< int > >::iterator mit = idsFromProcs.begin(); mit != idsFromProcs.end(); mit++ ) 03392 { 03393 int procToSendTo = mit->first; 03394 std::set< int >& idSet = mit->second; 03395 for( std::set< int >::iterator sit = idSet.begin(); sit != idSet.end(); sit++ ) 03396 { 03397 int n = TLcovIDs.get_n(); 03398 TLcovIDs.reserve(); 03399 TLcovIDs.vi_wr[2 * n] = procToSendTo; // send to processor 03400 TLcovIDs.vi_wr[2 * n + 1] = *sit; // global id needs index in the local_verts range 03401 } 03402 } 03403 } 03404 03405 ProcConfig pc( global ); // proc config does the crystal router 03406 pc.crystal_router()->gs_transfer( 1, TLcovIDs, 03407 0 ); // communication towards component tasks, with what ids are needed 03408 // for each task from receiver 03409 03410 // a test to know if we are on the sender tasks (original component, in this case, atmosphere) 03411 if( NULL != sendGraph ) 03412 { 03413 // collect TLcovIDs tuple, will set in a local map/set, the ids that are sent to each 03414 // receiver task 03415 ParCommGraph* sendGraph1 = new ParCommGraph( *sendGraph ); // just copy 03416 sendGraph1->set_context_id( *context_id ); 03417 context.appDatas[*pid_src].pgraph[*context_id] = sendGraph1; 03418 rval = sendGraph1->settle_send_graph( TLcovIDs );MB_CHK_ERR( rval ); 03419 } 03420 return moab::MB_SUCCESS; // success 03421 } 03422 03423 ErrCode iMOAB_DumpCommGraph( iMOAB_AppID pid, int* context_id, int* is_sender, const iMOAB_String prefix ) 03424 { 03425 assert( prefix && strlen( prefix ) ); 03426 03427 ParCommGraph* cgraph = context.appDatas[*pid].pgraph[*context_id]; 03428 std::string prefix_str( prefix ); 03429 03430 if( NULL != cgraph ) 03431 cgraph->dump_comm_information( prefix_str, *is_sender ); 03432 else 03433 { 03434 std::cout << " cannot find ParCommGraph on app with pid " << *pid << " name: " << context.appDatas[*pid].name 03435 << " context: " << *context_id << "\n"; 03436 } 03437 return moab::MB_SUCCESS; 03438 } 03439 03440 #endif // #ifdef MOAB_HAVE_TEMPESTREMAP 03441 03442 #endif // #ifdef MOAB_HAVE_MPI 03443 03444 #ifdef MOAB_HAVE_TEMPESTREMAP 03445 03446 #ifdef MOAB_HAVE_NETCDF 03447 ErrCode iMOAB_LoadMappingWeightsFromFile( 03448 iMOAB_AppID pid_intersection, 03449 iMOAB_AppID pid_cpl, 03450 int* col_or_row, 03451 int* type, 03452 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 03453 const iMOAB_String remap_weights_filename ) 03454 { 03455 ErrorCode rval; 03456 bool row_based_partition = true; 03457 if( *col_or_row == 1 ) row_based_partition = false; // do a column based partition; 03458 03459 // get the local degrees of freedom, from the pid_cpl and type of mesh 03460 03461 // Get the source and target data and pcomm objects 03462 appData& data_intx = context.appDatas[*pid_intersection]; 03463 TempestMapAppData& tdata = data_intx.tempestData; 03464 03465 // Get the handle to the remapper object 03466 if( tdata.remapper == NULL ) 03467 { 03468 // Now allocate and initialize the remapper object 03469 #ifdef MOAB_HAVE_MPI 03470 ParallelComm* pco = context.pcomms[*pid_intersection]; 03471 tdata.remapper = new moab::TempestRemapper( context.MBI, pco ); 03472 #else 03473 tdata.remapper = new moab::TempestRemapper( context.MBI ); 03474 #endif 03475 tdata.remapper->meshValidate = true; 03476 tdata.remapper->constructEdgeMap = true; 03477 // Do not create new filesets; Use the sets from our respective applications 03478 tdata.remapper->initialize( false ); 03479 tdata.remapper->GetMeshSet( moab::Remapper::OverlapMesh ) = data_intx.file_set; 03480 } 03481 03482 // Setup loading of weights onto TempestOnlineMap 03483 // Set the context for the remapping weights computation 03484 tdata.weightMaps[std::string( solution_weights_identifier )] = new moab::TempestOnlineMap( tdata.remapper ); 03485 03486 // Now allocate and initialize the remapper object 03487 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 03488 assert( weightMap != NULL ); 03489 03490 if( *pid_cpl >= 0 ) // it means we are looking for how to distribute the degrees of freedom, new map reader 03491 { 03492 appData& data1 = context.appDatas[*pid_cpl]; 03493 EntityHandle fset1 = data1.file_set; // this is source or target, depending on direction 03494 03495 // tags of interest are either GLOBAL_DOFS or GLOBAL_ID 03496 Tag gdsTag; 03497 03498 // find the values on first cell 03499 int lenTagType1 = 1; 03500 if( *type == 1 ) 03501 { 03502 rval = context.MBI->tag_get_handle( "GLOBAL_DOFS", gdsTag );MB_CHK_ERR( rval ); 03503 rval = context.MBI->tag_get_length( gdsTag, lenTagType1 );MB_CHK_ERR( rval ); // usually it is 16 03504 } 03505 Tag tagType2 = context.MBI->globalId_tag(); 03506 03507 std::vector< int > dofValues; 03508 03509 // populate first tuple 03510 Range 03511 ents_of_interest; // will be filled with entities on coupler, from which we will get the DOFs, based on type 03512 int ndofPerEl = 1; 03513 03514 if( *type == 1 ) 03515 { 03516 assert( gdsTag ); 03517 rval = context.MBI->get_entities_by_type( fset1, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 03518 dofValues.resize( ents_of_interest.size() * lenTagType1 ); 03519 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &dofValues[0] );MB_CHK_ERR( rval ); 03520 ndofPerEl = lenTagType1; 03521 } 03522 else if( *type == 2 ) 03523 { 03524 rval = context.MBI->get_entities_by_type( fset1, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 03525 dofValues.resize( ents_of_interest.size() ); 03526 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &dofValues[0] );MB_CHK_ERR( rval ); // just global ids 03527 } 03528 else if( *type == 3 ) // for FV meshes, just get the global id of cell 03529 { 03530 rval = context.MBI->get_entities_by_dimension( fset1, 2, ents_of_interest );MB_CHK_ERR( rval ); 03531 dofValues.resize( ents_of_interest.size() ); 03532 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &dofValues[0] );MB_CHK_ERR( rval ); // just global ids 03533 } 03534 else 03535 { 03536 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 or 3 03537 } 03538 // pass ordered dofs, and unique 03539 std::vector< int > orderDofs( dofValues.begin(), dofValues.end() ); 03540 03541 std::sort( orderDofs.begin(), orderDofs.end() ); 03542 orderDofs.erase( std::unique( orderDofs.begin(), orderDofs.end() ), orderDofs.end() ); // remove duplicates 03543 03544 rval = weightMap->ReadParallelMap( remap_weights_filename, orderDofs, row_based_partition );MB_CHK_ERR( rval ); 03545 03546 // if we are on target mesh (row based partition) 03547 if( row_based_partition ) 03548 { 03549 tdata.pid_dest = pid_cpl; 03550 tdata.remapper->SetMeshSet( Remapper::TargetMesh, fset1, ents_of_interest ); 03551 weightMap->SetDestinationNDofsPerElement( ndofPerEl ); 03552 weightMap->set_row_dc_dofs( dofValues ); // will set row_dtoc_dofmap 03553 } 03554 else 03555 { 03556 tdata.pid_src = pid_cpl; 03557 tdata.remapper->SetMeshSet( Remapper::SourceMesh, fset1, ents_of_interest ); 03558 weightMap->SetSourceNDofsPerElement( ndofPerEl ); 03559 weightMap->set_col_dc_dofs( dofValues ); // will set col_dtoc_dofmap 03560 } 03561 } 03562 else // old reader, trivial distribution by row 03563 { 03564 std::vector< int > tmp_owned_ids; // this will do a trivial row distribution 03565 rval = weightMap->ReadParallelMap( remap_weights_filename, tmp_owned_ids, row_based_partition );MB_CHK_ERR( rval ); 03566 } 03567 03568 return moab::MB_SUCCESS; 03569 } 03570 03571 ErrCode iMOAB_WriteMappingWeightsToFile( 03572 iMOAB_AppID pid_intersection, 03573 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 03574 const iMOAB_String remap_weights_filename ) 03575 { 03576 assert( solution_weights_identifier && strlen( solution_weights_identifier ) ); 03577 assert( remap_weights_filename && strlen( remap_weights_filename ) ); 03578 03579 ErrorCode rval; 03580 03581 // Get the source and target data and pcomm objects 03582 appData& data_intx = context.appDatas[*pid_intersection]; 03583 TempestMapAppData& tdata = data_intx.tempestData; 03584 03585 // Get the handle to the remapper object 03586 assert( tdata.remapper != NULL ); 03587 03588 // Now get online weights object and ensure it is valid 03589 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 03590 assert( weightMap != NULL ); 03591 03592 std::string filename = std::string( remap_weights_filename ); 03593 03594 // Write the map file to disk in parallel using either HDF5 or SCRIP interface 03595 rval = weightMap->WriteParallelMap( filename );MB_CHK_ERR( rval ); 03596 03597 return moab::MB_SUCCESS; 03598 } 03599 03600 #ifdef MOAB_HAVE_MPI 03601 ErrCode iMOAB_MigrateMapMesh( iMOAB_AppID pid1, 03602 iMOAB_AppID pid2, 03603 iMOAB_AppID pid3, 03604 MPI_Comm* jointcomm, 03605 MPI_Group* groupA, 03606 MPI_Group* groupB, 03607 int* type, 03608 int* comp1, 03609 int* comp2, 03610 int* direction ) 03611 { 03612 assert( jointcomm ); 03613 assert( groupA ); 03614 assert( groupB ); 03615 bool is_fortran = false; 03616 if (*pid1 >=0) is_fortran = context.appDatas[*pid1].is_fortran || is_fortran; 03617 if (*pid2 >=0) is_fortran = context.appDatas[*pid2].is_fortran || is_fortran; 03618 if (*pid3 >=0) is_fortran = context.appDatas[*pid3].is_fortran || is_fortran; 03619 03620 MPI_Comm joint_communicator = 03621 ( is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( jointcomm ) ) : *jointcomm ); 03622 MPI_Group group_first = 03623 ( is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( groupA ) ) : *groupA ); 03624 MPI_Group group_second = 03625 ( is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( groupB ) ) : *groupB ); 03626 03627 ErrorCode rval = MB_SUCCESS; 03628 int localRank = 0, numProcs = 1; 03629 03630 // Get the local rank and number of processes in the joint communicator 03631 MPI_Comm_rank( joint_communicator, &localRank ); 03632 MPI_Comm_size( joint_communicator, &numProcs ); 03633 03634 // Next instantiate the par comm graph 03635 // here we need to look at direction 03636 // this direction is good for atm source -> ocn target coupler example 03637 ParCommGraph* cgraph = NULL; 03638 if( *pid1 >= 0 ) cgraph = new ParCommGraph( joint_communicator, group_first, group_second, *comp1, *comp2 ); 03639 03640 ParCommGraph* cgraph_rev = NULL; 03641 if( *pid3 >= 0 ) cgraph_rev = new ParCommGraph( joint_communicator, group_second, group_first, *comp2, *comp1 ); 03642 03643 // we should search if we have another pcomm with the same comp ids in the list already 03644 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 03645 if( *pid1 >= 0 ) context.appDatas[*pid1].pgraph[*comp2] = cgraph; // the context will be the other comp 03646 if( *pid3 >= 0 ) context.appDatas[*pid3].pgraph[*comp1] = cgraph_rev; // from 2 to 1 03647 03648 // each model has a list of global ids that will need to be sent by gs to rendezvous the other 03649 // model on the joint_communicator 03650 TupleList TLcomp1; 03651 TLcomp1.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 03652 TupleList TLcomp2; 03653 TLcomp2.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 03654 03655 // will push_back a new tuple, if needed 03656 TLcomp1.enableWriteAccess(); 03657 03658 // tags of interest are either GLOBAL_DOFS or GLOBAL_ID 03659 Tag gdsTag; 03660 03661 // find the values on first cell 03662 int lenTagType1 = 1; 03663 if( *type == 1 ) 03664 { 03665 rval = context.MBI->tag_get_handle( "GLOBAL_DOFS", gdsTag );MB_CHK_ERR( rval ); 03666 rval = context.MBI->tag_get_length( gdsTag, lenTagType1 );MB_CHK_ERR( rval ); // usually it is 16 03667 } 03668 Tag tagType2 = context.MBI->globalId_tag(); 03669 03670 std::vector< int > valuesComp1; 03671 03672 // populate first tuple 03673 Range ents_of_interest; // will be filled with entities on pid1, that need to be distributed, 03674 // rearranged in split_ranges map 03675 if( *pid1 >= 0 ) 03676 { 03677 appData& data1 = context.appDatas[*pid1]; 03678 EntityHandle fset1 = data1.file_set; 03679 03680 if( *type == 1 ) 03681 { 03682 assert( gdsTag ); 03683 rval = context.MBI->get_entities_by_type( fset1, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 03684 valuesComp1.resize( ents_of_interest.size() * lenTagType1 ); 03685 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); 03686 } 03687 else if( *type == 2 ) 03688 { 03689 rval = context.MBI->get_entities_by_type( fset1, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 03690 valuesComp1.resize( ents_of_interest.size() ); 03691 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 03692 } 03693 else if( *type == 3 ) // for FV meshes, just get the global id of cell 03694 { 03695 rval = context.MBI->get_entities_by_dimension( fset1, 2, ents_of_interest );MB_CHK_ERR( rval ); 03696 valuesComp1.resize( ents_of_interest.size() ); 03697 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 03698 } 03699 else 03700 { 03701 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 or 3 03702 } 03703 // now fill the tuple list with info and markers 03704 // because we will send only the ids, order and compress the list 03705 std::set< int > uniq( valuesComp1.begin(), valuesComp1.end() ); 03706 TLcomp1.resize( uniq.size() ); 03707 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 03708 { 03709 // to proc, marker, element local index, index in el 03710 int marker = *sit; 03711 int to_proc = marker % numProcs; 03712 int n = TLcomp1.get_n(); 03713 TLcomp1.vi_wr[2 * n] = to_proc; // send to processor 03714 TLcomp1.vi_wr[2 * n + 1] = marker; 03715 TLcomp1.inc_n(); 03716 } 03717 } 03718 03719 ProcConfig pc( joint_communicator ); // proc config does the crystal router 03720 pc.crystal_router()->gs_transfer( 1, TLcomp1, 03721 0 ); // communication towards joint tasks, with markers 03722 // sort by value (key 1) 03723 #ifdef VERBOSE 03724 std::stringstream ff1; 03725 ff1 << "TLcomp1_" << localRank << ".txt"; 03726 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 03727 #endif 03728 moab::TupleList::buffer sort_buffer; 03729 sort_buffer.buffer_init( TLcomp1.get_n() ); 03730 TLcomp1.sort( 1, &sort_buffer ); 03731 sort_buffer.reset(); 03732 #ifdef VERBOSE 03733 // after sorting 03734 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 03735 #endif 03736 // do the same, for the other component, number2, with type2 03737 // start copy 03738 TLcomp2.enableWriteAccess(); 03739 03740 moab::TempestOnlineMap* weightMap = NULL; // declare it outside, but it will make sense only for *pid >= 0 03741 // we know that :) (or *pid2 >= 0, it means we are on the coupler PEs, read map exists, and coupler procs exist) 03742 // populate second tuple with ids from read map: we need row_gdofmap and col_gdofmap 03743 std::vector< int > valuesComp2; 03744 if( *pid2 >= 0 ) // we are now on coupler, map side 03745 { 03746 appData& data2 = context.appDatas[*pid2]; 03747 TempestMapAppData& tdata = data2.tempestData; 03748 // should be only one map, read from file 03749 assert( tdata.weightMaps.size() == 1 ); 03750 // maybe we need to check it is the map we expect 03751 weightMap = tdata.weightMaps.begin()->second; 03752 // std::vector<int> ids_of_interest; 03753 // do a deep copy of the ids of interest: row ids or col ids, target or source direction 03754 if( *direction == 1 ) 03755 { 03756 // we are interested in col ids, source 03757 // new method from moab::TempestOnlineMap 03758 rval = weightMap->fill_col_ids( valuesComp2 );MB_CHK_ERR( rval ); 03759 } 03760 else if( *direction == 2 ) 03761 { 03762 // we are interested in row ids, for target ids 03763 rval = weightMap->fill_row_ids( valuesComp2 );MB_CHK_ERR( rval ); 03764 } 03765 // 03766 03767 // now fill the tuple list with info and markers 03768 std::set< int > uniq( valuesComp2.begin(), valuesComp2.end() ); 03769 TLcomp2.resize( uniq.size() ); 03770 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 03771 { 03772 // to proc, marker, element local index, index in el 03773 int marker = *sit; 03774 int to_proc = marker % numProcs; 03775 int n = TLcomp2.get_n(); 03776 TLcomp2.vi_wr[2 * n] = to_proc; // send to processor 03777 TLcomp2.vi_wr[2 * n + 1] = marker; 03778 TLcomp2.inc_n(); 03779 } 03780 } 03781 pc.crystal_router()->gs_transfer( 1, TLcomp2, 03782 0 ); // communication towards joint tasks, with markers 03783 // sort by value (key 1) 03784 // in the rendez-vous approach, markers meet at meet point (rendez-vous) processor marker % nprocs 03785 #ifdef VERBOSE 03786 std::stringstream ff2; 03787 ff2 << "TLcomp2_" << localRank << ".txt"; 03788 TLcomp2.print_to_file( ff2.str().c_str() ); 03789 #endif 03790 sort_buffer.buffer_reserve( TLcomp2.get_n() ); 03791 TLcomp2.sort( 1, &sort_buffer ); 03792 sort_buffer.reset(); 03793 // end copy 03794 #ifdef VERBOSE 03795 TLcomp2.print_to_file( ff2.str().c_str() ); 03796 #endif 03797 // need to send back the info, from the rendezvous point, for each of the values 03798 /* so go over each value, on local process in joint communicator, 03799 03800 now have to send back the info needed for communication; 03801 loop in in sync over both TLComp1 and TLComp2, in local process; 03802 So, build new tuple lists, to send synchronous communication 03803 populate them at the same time, based on marker, that is indexed 03804 */ 03805 03806 TupleList TLBackToComp1; 03807 TLBackToComp1.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc on comp2, 03808 TLBackToComp1.enableWriteAccess(); 03809 03810 TupleList TLBackToComp2; 03811 TLBackToComp2.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc, 03812 TLBackToComp2.enableWriteAccess(); 03813 03814 int n1 = TLcomp1.get_n(); 03815 int n2 = TLcomp2.get_n(); 03816 03817 int indexInTLComp1 = 0; 03818 int indexInTLComp2 = 0; // advance both, according to the marker 03819 if( n1 > 0 && n2 > 0 ) 03820 { 03821 03822 while( indexInTLComp1 < n1 && indexInTLComp2 < n2 ) // if any is over, we are done 03823 { 03824 int currentValue1 = TLcomp1.vi_rd[2 * indexInTLComp1 + 1]; 03825 int currentValue2 = TLcomp2.vi_rd[2 * indexInTLComp2 + 1]; 03826 if( currentValue1 < currentValue2 ) 03827 { 03828 // we have a big problem; basically, we are saying that 03829 // dof currentValue is on one model and not on the other 03830 // std::cout << " currentValue1:" << currentValue1 << " missing in comp2" << "\n"; 03831 indexInTLComp1++; 03832 continue; 03833 } 03834 if( currentValue1 > currentValue2 ) 03835 { 03836 // std::cout << " currentValue2:" << currentValue2 << " missing in comp1" << "\n"; 03837 indexInTLComp2++; 03838 continue; 03839 } 03840 int size1 = 1; 03841 int size2 = 1; 03842 while( indexInTLComp1 + size1 < n1 && currentValue1 == TLcomp1.vi_rd[2 * ( indexInTLComp1 + size1 ) + 1] ) 03843 size1++; 03844 while( indexInTLComp2 + size2 < n2 && currentValue2 == TLcomp2.vi_rd[2 * ( indexInTLComp2 + size2 ) + 1] ) 03845 size2++; 03846 // must be found in both lists, find the start and end indices 03847 for( int i1 = 0; i1 < size1; i1++ ) 03848 { 03849 for( int i2 = 0; i2 < size2; i2++ ) 03850 { 03851 // send the info back to components 03852 int n = TLBackToComp1.get_n(); 03853 TLBackToComp1.reserve(); 03854 TLBackToComp1.vi_wr[3 * n] = 03855 TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // send back to the proc marker 03856 // came from, info from comp2 03857 TLBackToComp1.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 03858 TLBackToComp1.vi_wr[3 * n + 2] = TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // from proc on comp2 03859 n = TLBackToComp2.get_n(); 03860 TLBackToComp2.reserve(); 03861 TLBackToComp2.vi_wr[3 * n] = 03862 TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // send back info to original 03863 TLBackToComp2.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 03864 TLBackToComp2.vi_wr[3 * n + 2] = TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // from proc on comp1 03865 // what if there are repeated markers in TLcomp2? increase just index2 03866 } 03867 } 03868 indexInTLComp1 += size1; 03869 indexInTLComp2 += size2; 03870 } 03871 } 03872 pc.crystal_router()->gs_transfer( 1, TLBackToComp1, 0 ); // communication towards original tasks, with info about 03873 pc.crystal_router()->gs_transfer( 1, TLBackToComp2, 0 ); 03874 03875 TupleList TLv; // vertices 03876 TupleList TLc; // cells if needed (not type 2) 03877 03878 if( *pid1 >= 0 ) 03879 { 03880 // we are on original comp 1 tasks 03881 // before ordering 03882 // now for each value in TLBackToComp1.vi_rd[3*i+1], on current proc, we know the 03883 // processors it communicates with 03884 #ifdef VERBOSE 03885 std::stringstream f1; 03886 f1 << "TLBack1_" << localRank << ".txt"; 03887 TLBackToComp1.print_to_file( f1.str().c_str() ); 03888 #endif 03889 // so we are now on pid1, we know now each marker were it has to go 03890 // add a new method to ParCommGraph, to set up the split_ranges and involved_IDs_map 03891 rval = cgraph->set_split_ranges( *comp1, TLBackToComp1, valuesComp1, lenTagType1, ents_of_interest, *type );MB_CHK_ERR( rval ); 03892 // we can just send vertices and elements, with crystal routers; 03893 // on the receiving end, make sure they are not duplicated, by looking at the global id 03894 // if *type is 1, also send global_dofs tag in the element tuple 03895 rval = cgraph->form_tuples_to_migrate_mesh( context.MBI, TLv, TLc, *type, lenTagType1 );MB_CHK_ERR( rval ); 03896 } 03897 else 03898 { 03899 TLv.initialize( 2, 0, 0, 3, 0 ); // no vertices here, for sure 03900 TLv.enableWriteAccess(); // to be able to receive stuff, even if nothing is here yet, on this task 03901 if (*type != 2) // for point cloud, we do not need to initialize TLc (for cells) 03902 { 03903 // we still need to initialize the tuples with the right size, as in form_tuples_to_migrate_mesh 03904 int size_tuple = 2 + ( ( *type != 1 ) ? 0 : lenTagType1 ) + 1 + 10; // 10 is the max number of vertices in cell; kind of arbitrary 03905 TLc.initialize( size_tuple, 0, 0, 0, 0 ); 03906 TLc.enableWriteAccess(); 03907 } 03908 03909 } 03910 pc.crystal_router()->gs_transfer( 1, TLv, 0 ); // communication towards coupler tasks, with mesh vertices 03911 if( *type != 2 ) pc.crystal_router()->gs_transfer( 1, TLc, 0 ); // those are cells 03912 03913 if( *pid3 >= 0 ) // will receive the mesh, on coupler pes! 03914 { 03915 appData& data3 = context.appDatas[*pid3]; 03916 EntityHandle fset3 = data3.file_set; 03917 Range primary_ents3; // vertices for type 2, cells of dim 2 for type 1 or 3 03918 std::vector< int > values_entities; // will be the size of primary_ents3 * lenTagType1 03919 rval = cgraph_rev->form_mesh_from_tuples( context.MBI, TLv, TLc, *type, lenTagType1, fset3, primary_ents3, 03920 values_entities );MB_CHK_ERR( rval ); 03921 iMOAB_UpdateMeshInfo( pid3 ); 03922 int ndofPerEl = 1; 03923 if( 1 == *type ) ndofPerEl = (int)( sqrt( lenTagType1 ) ); 03924 // because we are on the coupler, we know that the read map pid2 exists 03925 assert( *pid2 >= 0 ); 03926 appData& dataIntx = context.appDatas[*pid2]; 03927 TempestMapAppData& tdata = dataIntx.tempestData; 03928 03929 // if we are on source coverage, direction 1, we can set covering mesh, covering cells 03930 if( 1 == *direction ) 03931 { 03932 tdata.pid_src = pid3; 03933 tdata.remapper->SetMeshSet( Remapper::CoveringMesh, fset3, primary_ents3 ); 03934 weightMap->SetSourceNDofsPerElement( ndofPerEl ); 03935 weightMap->set_col_dc_dofs( values_entities ); // will set col_dtoc_dofmap 03936 } 03937 // if we are on target, we can set the target cells 03938 else 03939 { 03940 tdata.pid_dest = pid3; 03941 tdata.remapper->SetMeshSet( Remapper::TargetMesh, fset3, primary_ents3 ); 03942 weightMap->SetDestinationNDofsPerElement( ndofPerEl ); 03943 weightMap->set_row_dc_dofs( values_entities ); // will set row_dtoc_dofmap 03944 } 03945 } 03946 03947 return moab::MB_SUCCESS; 03948 } 03949 03950 #endif // #ifdef MOAB_HAVE_MPI 03951 03952 #endif // #ifdef MOAB_HAVE_NETCDF 03953 03954 #define USE_API 03955 static ErrCode ComputeSphereRadius( iMOAB_AppID pid, double* radius ) 03956 { 03957 ErrorCode rval; 03958 moab::CartVect pos; 03959 03960 Range& verts = context.appDatas[*pid].all_verts; 03961 moab::EntityHandle firstVertex = ( verts[0] ); 03962 03963 // coordinate data 03964 rval = context.MBI->get_coords( &( firstVertex ), 1, (double*)&( pos[0] ) );MB_CHK_ERR( rval ); 03965 03966 // compute the distance from origin 03967 // TODO: we could do this in a loop to verify if the pid represents a spherical mesh 03968 *radius = pos.length(); 03969 return moab::MB_SUCCESS; 03970 } 03971 03972 ErrCode iMOAB_ComputeMeshIntersectionOnSphere( iMOAB_AppID pid_src, iMOAB_AppID pid_tgt, iMOAB_AppID pid_intx ) 03973 { 03974 ErrorCode rval; 03975 ErrCode ierr; 03976 bool validate = true; 03977 03978 double radius_source = 1.0; 03979 double radius_target = 1.0; 03980 const double epsrel = ReferenceTolerance; // ReferenceTolerance is defined in Defines.h in tempestremap source ; 03981 const double boxeps = 1.e-6; 03982 03983 // Get the source and target data and pcomm objects 03984 appData& data_src = context.appDatas[*pid_src]; 03985 appData& data_tgt = context.appDatas[*pid_tgt]; 03986 appData& data_intx = context.appDatas[*pid_intx]; 03987 #ifdef MOAB_HAVE_MPI 03988 ParallelComm* pco_intx = context.pcomms[*pid_intx]; 03989 #endif 03990 03991 // Mesh intersection has already been computed; Return early. 03992 TempestMapAppData& tdata = data_intx.tempestData; 03993 if( tdata.remapper != NULL ) return moab::MB_SUCCESS; // nothing to do 03994 03995 bool is_parallel = false, is_root = true; 03996 int rank = 0; 03997 #ifdef MOAB_HAVE_MPI 03998 if( pco_intx ) 03999 { 04000 rank = pco_intx->rank(); 04001 is_parallel = ( pco_intx->size() > 1 ); 04002 is_root = ( rank == 0 ); 04003 rval = pco_intx->check_all_shared_handles();MB_CHK_ERR( rval ); 04004 } 04005 #endif 04006 04007 moab::DebugOutput outputFormatter( std::cout, rank, 0 ); 04008 outputFormatter.set_prefix( "[iMOAB_ComputeMeshIntersectionOnSphere]: " ); 04009 04010 ierr = iMOAB_UpdateMeshInfo( pid_src );MB_CHK_ERR( ierr ); 04011 ierr = iMOAB_UpdateMeshInfo( pid_tgt );MB_CHK_ERR( ierr ); 04012 04013 // Rescale the radius of both to compute the intersection 04014 ComputeSphereRadius( pid_src, &radius_source ); 04015 ComputeSphereRadius( pid_tgt, &radius_target ); 04016 #ifdef VERBOSE 04017 if( is_root ) 04018 outputFormatter.printf( 0, "Radius of spheres: source = %12.14f, and target = %12.14f\n", radius_source, 04019 radius_target ); 04020 #endif 04021 04022 /* Let make sure that the radius match for source and target meshes. If not, rescale now and 04023 * unscale later. */ 04024 double defaultradius = 1.0; 04025 if( fabs( radius_source - radius_target ) > 1e-10 ) 04026 { /* the radii are different */ 04027 rval = IntxUtils::ScaleToRadius( context.MBI, data_src.file_set, defaultradius );MB_CHK_ERR( rval ); 04028 rval = IntxUtils::ScaleToRadius( context.MBI, data_tgt.file_set, defaultradius );MB_CHK_ERR( rval ); 04029 } 04030 04031 // Default area_method = lHuiller; Options: Girard, GaussQuadrature (if TR is available) 04032 #ifdef MOAB_HAVE_TEMPESTREMAP 04033 IntxAreaUtils areaAdaptor( IntxAreaUtils::GaussQuadrature ); 04034 #else 04035 IntxAreaUtils areaAdaptor( IntxAreaUtils::lHuiller ); 04036 #endif 04037 04038 // print verbosely about the problem setting 04039 bool use_kdtree_search = false; 04040 double srctgt_areas[2], srctgt_areas_glb[2]; 04041 { 04042 moab::Range rintxverts, rintxelems; 04043 rval = context.MBI->get_entities_by_dimension( data_src.file_set, 0, rintxverts );MB_CHK_ERR( rval ); 04044 rval = context.MBI->get_entities_by_dimension( data_src.file_set, data_src.dimension, rintxelems );MB_CHK_ERR( rval ); 04045 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_src.file_set );MB_CHK_ERR( rval ); 04046 rval = areaAdaptor.positive_orientation( context.MBI, data_src.file_set, defaultradius /*radius_source*/ );MB_CHK_ERR( rval ); 04047 srctgt_areas[0] = areaAdaptor.area_on_sphere( context.MBI, data_src.file_set, defaultradius /*radius_source*/ ); 04048 #ifdef VERBOSE 04049 if( is_root ) 04050 outputFormatter.printf( 0, "The red set contains %d vertices and %d elements \n", rintxverts.size(), 04051 rintxelems.size() ); 04052 #endif 04053 04054 moab::Range bintxverts, bintxelems; 04055 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, 0, bintxverts );MB_CHK_ERR( rval ); 04056 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, data_tgt.dimension, bintxelems );MB_CHK_ERR( rval ); 04057 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_tgt.file_set );MB_CHK_ERR( rval ); 04058 rval = areaAdaptor.positive_orientation( context.MBI, data_tgt.file_set, defaultradius /*radius_target*/ );MB_CHK_ERR( rval ); 04059 srctgt_areas[1] = areaAdaptor.area_on_sphere( context.MBI, data_tgt.file_set, defaultradius /*radius_target*/ ); 04060 #ifdef VERBOSE 04061 if( is_root ) 04062 outputFormatter.printf( 0, "The blue set contains %d vertices and %d elements \n", bintxverts.size(), 04063 bintxelems.size() ); 04064 #endif 04065 #ifdef MOAB_HAVE_MPI 04066 MPI_Allreduce( &srctgt_areas[0], &srctgt_areas_glb[0], 2, MPI_DOUBLE, MPI_SUM, pco_intx->comm() ); 04067 #else 04068 srctgt_areas_glb[0] = srctgt_areas[0]; 04069 srctgt_areas_glb[1] = srctgt_areas[1]; 04070 #endif 04071 use_kdtree_search = ( srctgt_areas_glb[0] < srctgt_areas_glb[1] ); 04072 } 04073 04074 data_intx.dimension = data_tgt.dimension; 04075 // set the context for the source and destination applications 04076 tdata.pid_src = pid_src; 04077 tdata.pid_dest = pid_tgt; 04078 04079 // Now allocate and initialize the remapper object 04080 #ifdef MOAB_HAVE_MPI 04081 tdata.remapper = new moab::TempestRemapper( context.MBI, pco_intx ); 04082 #else 04083 tdata.remapper = new moab::TempestRemapper( context.MBI ); 04084 #endif 04085 tdata.remapper->meshValidate = true; 04086 tdata.remapper->constructEdgeMap = true; 04087 04088 // Do not create new filesets; Use the sets from our respective applications 04089 tdata.remapper->initialize( false ); 04090 tdata.remapper->GetMeshSet( moab::Remapper::SourceMesh ) = data_src.file_set; 04091 tdata.remapper->GetMeshSet( moab::Remapper::TargetMesh ) = data_tgt.file_set; 04092 tdata.remapper->GetMeshSet( moab::Remapper::OverlapMesh ) = data_intx.file_set; 04093 04094 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::SourceMesh );MB_CHK_ERR( rval ); 04095 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::TargetMesh );MB_CHK_ERR( rval ); 04096 04097 // First, compute the covering source set. 04098 rval = tdata.remapper->ConstructCoveringSet( epsrel, 1.0, 1.0, boxeps, false );MB_CHK_ERR( rval ); 04099 04100 // Next, compute intersections with MOAB. 04101 rval = tdata.remapper->ComputeOverlapMesh( use_kdtree_search, false );MB_CHK_ERR( rval ); 04102 04103 // Mapping computation done 04104 if( validate ) 04105 { 04106 double local_area, 04107 global_areas[3]; // Array for Initial area, and through Method 1 and Method 2 04108 local_area = areaAdaptor.area_on_sphere( context.MBI, data_intx.file_set, radius_source ); 04109 04110 global_areas[0] = srctgt_areas_glb[0]; 04111 global_areas[1] = srctgt_areas_glb[1]; 04112 04113 #ifdef MOAB_HAVE_MPI 04114 if( is_parallel ) 04115 { 04116 MPI_Reduce( &local_area, &global_areas[2], 1, MPI_DOUBLE, MPI_SUM, 0, pco_intx->comm() ); 04117 } 04118 else 04119 { 04120 global_areas[2] = local_area; 04121 } 04122 #else 04123 global_areas[2] = local_area; 04124 #endif 04125 if( is_root ) 04126 { 04127 outputFormatter.printf( 0, 04128 "initial area: source mesh = %12.14f, target mesh = %12.14f, " 04129 "overlap mesh = %12.14f\n", 04130 global_areas[0], global_areas[1], global_areas[2] ); 04131 outputFormatter.printf( 0, " relative error w.r.t source = %12.14e, and target = %12.14e\n", 04132 fabs( global_areas[0] - global_areas[2] ) / global_areas[0], 04133 fabs( global_areas[1] - global_areas[2] ) / global_areas[1] ); 04134 } 04135 } 04136 04137 return moab::MB_SUCCESS; 04138 } 04139 04140 ErrCode iMOAB_ComputePointDoFIntersection( iMOAB_AppID pid_src, iMOAB_AppID pid_tgt, iMOAB_AppID pid_intx ) 04141 { 04142 ErrorCode rval; 04143 ErrCode ierr; 04144 04145 double radius_source = 1.0; 04146 double radius_target = 1.0; 04147 const double epsrel = ReferenceTolerance; // ReferenceTolerance is defined in Defines.h in tempestremap source ; 04148 const double boxeps = 1.e-8; 04149 04150 // Get the source and target data and pcomm objects 04151 appData& data_src = context.appDatas[*pid_src]; 04152 appData& data_tgt = context.appDatas[*pid_tgt]; 04153 appData& data_intx = context.appDatas[*pid_intx]; 04154 #ifdef MOAB_HAVE_MPI 04155 ParallelComm* pco_intx = context.pcomms[*pid_intx]; 04156 #endif 04157 04158 // Mesh intersection has already been computed; Return early. 04159 TempestMapAppData& tdata = data_intx.tempestData; 04160 if( tdata.remapper != NULL ) return moab::MB_SUCCESS; // nothing to do 04161 04162 #ifdef MOAB_HAVE_MPI 04163 if( pco_intx ) 04164 { 04165 rval = pco_intx->check_all_shared_handles();MB_CHK_ERR( rval ); 04166 } 04167 #endif 04168 04169 ierr = iMOAB_UpdateMeshInfo( pid_src );MB_CHK_ERR( ierr ); 04170 ierr = iMOAB_UpdateMeshInfo( pid_tgt );MB_CHK_ERR( ierr ); 04171 04172 // Rescale the radius of both to compute the intersection 04173 ComputeSphereRadius( pid_src, &radius_source ); 04174 ComputeSphereRadius( pid_tgt, &radius_target ); 04175 04176 IntxAreaUtils areaAdaptor; 04177 // print verbosely about the problem setting 04178 { 04179 moab::Range rintxverts, rintxelems; 04180 rval = context.MBI->get_entities_by_dimension( data_src.file_set, 0, rintxverts );MB_CHK_ERR( rval ); 04181 rval = context.MBI->get_entities_by_dimension( data_src.file_set, 2, rintxelems );MB_CHK_ERR( rval ); 04182 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_src.file_set );MB_CHK_ERR( rval ); 04183 rval = areaAdaptor.positive_orientation( context.MBI, data_src.file_set, radius_source );MB_CHK_ERR( rval ); 04184 #ifdef VERBOSE 04185 std::cout << "The red set contains " << rintxverts.size() << " vertices and " << rintxelems.size() 04186 << " elements \n"; 04187 #endif 04188 04189 moab::Range bintxverts, bintxelems; 04190 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, 0, bintxverts );MB_CHK_ERR( rval ); 04191 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, 2, bintxelems );MB_CHK_ERR( rval ); 04192 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_tgt.file_set );MB_CHK_ERR( rval ); 04193 rval = areaAdaptor.positive_orientation( context.MBI, data_tgt.file_set, radius_target );MB_CHK_ERR( rval ); 04194 #ifdef VERBOSE 04195 std::cout << "The blue set contains " << bintxverts.size() << " vertices and " << bintxelems.size() 04196 << " elements \n"; 04197 #endif 04198 } 04199 04200 data_intx.dimension = data_tgt.dimension; 04201 // set the context for the source and destination applications 04202 // set the context for the source and destination applications 04203 tdata.pid_src = pid_src; 04204 tdata.pid_dest = pid_tgt; 04205 data_intx.point_cloud = ( data_src.point_cloud || data_tgt.point_cloud ); 04206 assert( data_intx.point_cloud == true ); 04207 04208 // Now allocate and initialize the remapper object 04209 #ifdef MOAB_HAVE_MPI 04210 tdata.remapper = new moab::TempestRemapper( context.MBI, pco_intx ); 04211 #else 04212 tdata.remapper = new moab::TempestRemapper( context.MBI ); 04213 #endif 04214 tdata.remapper->meshValidate = true; 04215 tdata.remapper->constructEdgeMap = true; 04216 04217 // Do not create new filesets; Use the sets from our respective applications 04218 tdata.remapper->initialize( false ); 04219 tdata.remapper->GetMeshSet( moab::Remapper::SourceMesh ) = data_src.file_set; 04220 tdata.remapper->GetMeshSet( moab::Remapper::TargetMesh ) = data_tgt.file_set; 04221 tdata.remapper->GetMeshSet( moab::Remapper::OverlapMesh ) = data_intx.file_set; 04222 04223 /* Let make sure that the radius match for source and target meshes. If not, rescale now and 04224 * unscale later. */ 04225 if( fabs( radius_source - radius_target ) > 1e-10 ) 04226 { /* the radii are different */ 04227 rval = IntxUtils::ScaleToRadius( context.MBI, data_src.file_set, 1.0 );MB_CHK_ERR( rval ); 04228 rval = IntxUtils::ScaleToRadius( context.MBI, data_tgt.file_set, 1.0 );MB_CHK_ERR( rval ); 04229 } 04230 04231 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::SourceMesh );MB_CHK_ERR( rval ); 04232 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::TargetMesh );MB_CHK_ERR( rval ); 04233 04234 // First, compute the covering source set. 04235 rval = tdata.remapper->ConstructCoveringSet( epsrel, 1.0, 1.0, boxeps, false );MB_CHK_ERR( rval ); 04236 04237 #ifdef MOAB_HAVE_MPI 04238 /* VSM: This context should be set on the data_src but it would overwrite the source 04239 covering set context in case it is coupled to another APP as well. 04240 This needs a redesign. */ 04241 // data_intx.covering_set = tdata.remapper->GetCoveringSet(); 04242 // data_src.covering_set = tdata.remapper->GetCoveringSet(); 04243 #endif 04244 04245 // Now let us re-convert the MOAB mesh back to Tempest representation 04246 rval = tdata.remapper->ComputeGlobalLocalMaps();MB_CHK_ERR( rval ); 04247 04248 return moab::MB_SUCCESS; 04249 } 04250 04251 ErrCode iMOAB_ComputeScalarProjectionWeights( 04252 iMOAB_AppID pid_intx, 04253 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 04254 const iMOAB_String disc_method_source, 04255 int* disc_order_source, 04256 const iMOAB_String disc_method_target, 04257 int* disc_order_target, 04258 int* fNoBubble, 04259 int* fMonotoneTypeID, 04260 int* fVolumetric, 04261 int* fInverseDistanceMap, 04262 int* fNoConservation, 04263 int* fValidate, 04264 const iMOAB_String source_solution_tag_dof_name, 04265 const iMOAB_String target_solution_tag_dof_name ) 04266 { 04267 moab::ErrorCode rval; 04268 04269 assert( disc_order_source && disc_order_target && *disc_order_source > 0 && *disc_order_target > 0 ); 04270 assert( solution_weights_identifier && strlen( solution_weights_identifier ) ); 04271 assert( disc_method_source && strlen( disc_method_source ) ); 04272 assert( disc_method_target && strlen( disc_method_target ) ); 04273 assert( source_solution_tag_dof_name && strlen( source_solution_tag_dof_name ) ); 04274 assert( target_solution_tag_dof_name && strlen( target_solution_tag_dof_name ) ); 04275 04276 // Get the source and target data and pcomm objects 04277 appData& data_intx = context.appDatas[*pid_intx]; 04278 TempestMapAppData& tdata = data_intx.tempestData; 04279 04280 // Setup computation of weights 04281 // Set the context for the remapping weights computation 04282 tdata.weightMaps[std::string( solution_weights_identifier )] = new moab::TempestOnlineMap( tdata.remapper ); 04283 04284 // Call to generate the remap weights with the tempest meshes 04285 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 04286 assert( weightMap != NULL ); 04287 04288 GenerateOfflineMapAlgorithmOptions mapOptions; 04289 mapOptions.nPin = *disc_order_source; 04290 mapOptions.nPout = *disc_order_target; 04291 mapOptions.fSourceConcave = false; 04292 mapOptions.fTargetConcave = false; 04293 04294 mapOptions.strMethod = ""; 04295 if( fMonotoneTypeID ) 04296 { 04297 switch( *fMonotoneTypeID ) 04298 { 04299 case 0: 04300 mapOptions.fMonotone = false; 04301 break; 04302 case 3: 04303 mapOptions.strMethod += "mono3;"; 04304 break; 04305 case 2: 04306 mapOptions.strMethod += "mono2;"; 04307 break; 04308 default: 04309 mapOptions.fMonotone = true; 04310 } 04311 } 04312 else 04313 mapOptions.fMonotone = false; 04314 04315 mapOptions.fNoBubble = ( fNoBubble ? *fNoBubble : false ); 04316 mapOptions.fNoConservation = ( fNoConservation ? *fNoConservation > 0 : false ); 04317 mapOptions.fNoCorrectAreas = false; 04318 mapOptions.fNoCheck = !( fValidate ? *fValidate : true ); 04319 if( fVolumetric && *fVolumetric ) mapOptions.strMethod += "volumetric;"; 04320 if( fInverseDistanceMap && *fInverseDistanceMap ) mapOptions.strMethod += "invdist;"; 04321 04322 // Now let us compute the local-global mapping and store it in the context 04323 // We need this mapping when computing matvec products and to do reductions in parallel 04324 // Additionally, the call below will also compute weights with TempestRemap 04325 rval = weightMap->GenerateRemappingWeights( 04326 std::string( disc_method_source ), // const std::string& strInputType 04327 std::string( disc_method_target ), // const std::string& strOutputType 04328 mapOptions, // GenerateOfflineMapAlgorithmOptions& mapOptions 04329 std::string( source_solution_tag_dof_name ), // const std::string& srcDofTagName = "GLOBAL_ID" 04330 std::string( target_solution_tag_dof_name ) // const std::string& tgtDofTagName = "GLOBAL_ID" 04331 );MB_CHK_ERR( rval ); 04332 04333 return moab::MB_SUCCESS; 04334 } 04335 04336 ErrCode iMOAB_ApplyScalarProjectionWeights( 04337 iMOAB_AppID pid_intersection, 04338 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 04339 const iMOAB_String source_solution_tag_name, 04340 const iMOAB_String target_solution_tag_name ) 04341 { 04342 assert( solution_weights_identifier && strlen( solution_weights_identifier ) ); 04343 assert( source_solution_tag_name && strlen( source_solution_tag_name ) ); 04344 assert( target_solution_tag_name && strlen( target_solution_tag_name ) ); 04345 04346 moab::ErrorCode rval; 04347 04348 // Get the source and target data and pcomm objects 04349 appData& data_intx = context.appDatas[*pid_intersection]; 04350 TempestMapAppData& tdata = data_intx.tempestData; 04351 04352 // Now allocate and initialize the remapper object 04353 moab::TempestRemapper* remapper = tdata.remapper; 04354 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 04355 04356 // we assume that there are separators ";" between the tag names 04357 std::vector< std::string > srcNames; 04358 std::vector< std::string > tgtNames; 04359 std::vector< Tag > srcTagHandles; 04360 std::vector< Tag > tgtTagHandles; 04361 std::string separator( ":" ); 04362 std::string src_name( source_solution_tag_name ); 04363 std::string tgt_name( target_solution_tag_name ); 04364 split_tag_names( src_name, separator, srcNames ); 04365 split_tag_names( tgt_name, separator, tgtNames ); 04366 if( srcNames.size() != tgtNames.size() ) 04367 { 04368 std::cout << " error in parsing source and target tag names. \n"; 04369 return moab::MB_FAILURE; 04370 } 04371 04372 for( size_t i = 0; i < srcNames.size(); i++ ) 04373 { 04374 Tag tagHandle; 04375 rval = context.MBI->tag_get_handle( srcNames[i].c_str(), tagHandle ); 04376 if( MB_SUCCESS != rval || NULL == tagHandle ) 04377 { 04378 return moab::MB_FAILURE; 04379 } 04380 srcTagHandles.push_back( tagHandle ); 04381 rval = context.MBI->tag_get_handle( tgtNames[i].c_str(), tagHandle ); 04382 if( MB_SUCCESS != rval || NULL == tagHandle ) 04383 { 04384 return moab::MB_FAILURE; 04385 } 04386 tgtTagHandles.push_back( tagHandle ); 04387 } 04388 04389 std::vector< double > solSTagVals; 04390 std::vector< double > solTTagVals; 04391 04392 moab::Range sents, tents; 04393 if( data_intx.point_cloud ) 04394 { 04395 appData& data_src = context.appDatas[*tdata.pid_src]; 04396 appData& data_tgt = context.appDatas[*tdata.pid_dest]; 04397 if( data_src.point_cloud ) 04398 { 04399 moab::Range& covSrcEnts = remapper->GetMeshVertices( moab::Remapper::CoveringMesh ); 04400 solSTagVals.resize( covSrcEnts.size(), -1.0 ); 04401 sents = covSrcEnts; 04402 } 04403 else 04404 { 04405 moab::Range& covSrcEnts = remapper->GetMeshEntities( moab::Remapper::CoveringMesh ); 04406 solSTagVals.resize( covSrcEnts.size() * weightMap->GetSourceNDofsPerElement() * 04407 weightMap->GetSourceNDofsPerElement(), 04408 -1.0 ); 04409 sents = covSrcEnts; 04410 } 04411 if( data_tgt.point_cloud ) 04412 { 04413 moab::Range& tgtEnts = remapper->GetMeshVertices( moab::Remapper::TargetMesh ); 04414 solTTagVals.resize( tgtEnts.size(), -1.0 ); 04415 tents = tgtEnts; 04416 } 04417 else 04418 { 04419 moab::Range& tgtEnts = remapper->GetMeshEntities( moab::Remapper::TargetMesh ); 04420 solTTagVals.resize( tgtEnts.size() * weightMap->GetDestinationNDofsPerElement() * 04421 weightMap->GetDestinationNDofsPerElement(), 04422 -1.0 ); 04423 tents = tgtEnts; 04424 } 04425 } 04426 else 04427 { 04428 moab::Range& covSrcEnts = remapper->GetMeshEntities( moab::Remapper::CoveringMesh ); 04429 moab::Range& tgtEnts = remapper->GetMeshEntities( moab::Remapper::TargetMesh ); 04430 solSTagVals.resize( 04431 covSrcEnts.size() * weightMap->GetSourceNDofsPerElement() * weightMap->GetSourceNDofsPerElement(), -1.0 ); 04432 solTTagVals.resize( tgtEnts.size() * weightMap->GetDestinationNDofsPerElement() * 04433 weightMap->GetDestinationNDofsPerElement(), 04434 -1.0 ); 04435 04436 sents = covSrcEnts; 04437 tents = tgtEnts; 04438 } 04439 04440 for( size_t i = 0; i < srcTagHandles.size(); i++ ) 04441 { 04442 // The tag data is np*np*n_el_src 04443 Tag ssolnTag = srcTagHandles[i]; 04444 Tag tsolnTag = tgtTagHandles[i]; 04445 rval = context.MBI->tag_get_data( ssolnTag, sents, &solSTagVals[0] );MB_CHK_ERR( rval ); 04446 04447 // Compute the application of weights on the suorce solution data and store it in the 04448 // destination solution vector data Optionally, can also perform the transpose application 04449 // of the weight matrix. Set the 3rd argument to true if this is needed 04450 rval = weightMap->ApplyWeights( solSTagVals, solTTagVals, false );MB_CHK_ERR( rval ); 04451 04452 // The tag data is np*np*n_el_dest 04453 rval = context.MBI->tag_set_data( tsolnTag, tents, &solTTagVals[0] );MB_CHK_ERR( rval ); 04454 } 04455 04456 // #define VERBOSE 04457 #ifdef VERBOSE 04458 ParallelComm* pco_intx = context.pcomms[*pid_intersection]; 04459 04460 int ivar = 0; 04461 { 04462 Tag ssolnTag = srcTagHandles[ivar]; 04463 std::stringstream sstr; 04464 sstr << "covsrcTagData_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".txt"; 04465 std::ofstream output_file( sstr.str().c_str() ); 04466 for( unsigned i = 0; i < sents.size(); ++i ) 04467 { 04468 EntityHandle elem = sents[i]; 04469 std::vector< double > locsolSTagVals( 16 ); 04470 rval = context.MBI->tag_get_data( ssolnTag, &elem, 1, &locsolSTagVals[0] );MB_CHK_ERR( rval ); 04471 output_file << "\n" << remapper->GetGlobalID( Remapper::CoveringMesh, i ) << "-- \n\t"; 04472 for( unsigned j = 0; j < 16; ++j ) 04473 output_file << locsolSTagVals[j] << " "; 04474 } 04475 output_file.flush(); // required here 04476 output_file.close(); 04477 } 04478 { 04479 std::stringstream sstr; 04480 sstr << "outputSrcDest_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".h5m"; 04481 EntityHandle sets[2] = { context.appDatas[*tdata.pid_src].file_set, 04482 context.appDatas[*tdata.pid_dest].file_set }; 04483 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", sets, 2 );MB_CHK_ERR( rval ); 04484 } 04485 { 04486 std::stringstream sstr; 04487 sstr << "outputCovSrcDest_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".h5m"; 04488 // EntityHandle sets[2] = {data_intx.file_set, data_intx.covering_set}; 04489 EntityHandle covering_set = remapper->GetCoveringSet(); 04490 EntityHandle sets[2] = { covering_set, context.appDatas[*tdata.pid_dest].file_set }; 04491 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", sets, 2 );MB_CHK_ERR( rval ); 04492 } 04493 { 04494 std::stringstream sstr; 04495 sstr << "covMesh_" << *pid_intersection << "_" << pco_intx->rank() << ".vtk"; 04496 // EntityHandle sets[2] = {data_intx.file_set, data_intx.covering_set}; 04497 EntityHandle covering_set = remapper->GetCoveringSet(); 04498 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", &covering_set, 1 );MB_CHK_ERR( rval ); 04499 } 04500 { 04501 std::stringstream sstr; 04502 sstr << "tgtMesh_" << *pid_intersection << "_" << pco_intx->rank() << ".vtk"; 04503 // EntityHandle sets[2] = {data_intx.file_set, data_intx.covering_set}; 04504 EntityHandle target_set = remapper->GetMeshSet( Remapper::TargetMesh ); 04505 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", &target_set, 1 );MB_CHK_ERR( rval ); 04506 } 04507 { 04508 std::stringstream sstr; 04509 sstr << "colvector_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".txt"; 04510 std::ofstream output_file( sstr.str().c_str() ); 04511 for( unsigned i = 0; i < solSTagVals.size(); ++i ) 04512 output_file << i << " " << weightMap->col_dofmap[i] << " " << weightMap->col_gdofmap[i] << " " 04513 << solSTagVals[i] << "\n"; 04514 output_file.flush(); // required here 04515 output_file.close(); 04516 } 04517 #endif 04518 // #undef VERBOSE 04519 04520 return moab::MB_SUCCESS; 04521 } 04522 04523 #endif // MOAB_HAVE_TEMPESTREMAP 04524 04525 #ifdef __cplusplus 04526 } 04527 #endif
