MOAB: Mesh Oriented datABase
(version 5.4.1)
This graph shows which files directly or indirectly include this file:Go to the source code of this file.
Defines | |
| #define | PARALLEL_GID_TAG_NAME "GLOBAL_ID" |
| Global identifier for interface mesh. | |
| #define | PARALLEL_PARTITION_TAG_NAME "PARALLEL_PARTITION" |
| Tag on a meshset representing a parallel partition. | |
| #define | PARALLEL_PART_TAG_NAME PARALLEL_PARTITION_TAG_NAME |
| #define | PARALLEL_PARTITIONING_TAG_NAME "PARALLEL_MESH_PARTITIONING" |
| Tag that groups the set of parts/partitions that are a covering of the mesh. | |
| #define | PARALLEL_SHARED_PROC_TAG_NAME "__PARALLEL_SHARED_PROC" |
| Tag storing which other processor a given entity is shared with. | |
| #define | PARALLEL_SHARED_PROCS_TAG_NAME "__PARALLEL_SHARED_PROCS" |
| Tag storing which other processorS a given entity is shared with. | |
| #define | PARALLEL_SHARED_HANDLE_TAG_NAME "__PARALLEL_SHARED_HANDLE" |
| Tag storing the handle of a shared entity on the other proc. | |
| #define | PARALLEL_SHARED_HANDLES_TAG_NAME "__PARALLEL_SHARED_HANDLES" |
| Tag storing handles of a shared entity on other processors. | |
| #define | PARALLEL_STATUS_TAG_NAME "__PARALLEL_STATUS" |
| Tag storing parallel status (as bits in this tag) | |
| #define | PSTATUS_NOT_OWNED 0x1 |
| #define | PSTATUS_SHARED 0x2 |
| #define | PSTATUS_MULTISHARED 0x4 |
| #define | PSTATUS_INTERFACE 0x8 |
| #define | PSTATUS_GHOST 0x10 |
| #define | PSTATUS_AND 0x1 |
| #define | PSTATUS_OR 0x2 |
| #define | PSTATUS_NOT 0x3 |
| #define PARALLEL_GID_TAG_NAME "GLOBAL_ID" |
Tag conventions for naming parallel things. Note this header file belongs in the main MOAB directory because even serial applications (e.g. partitioners) may write tags for use in parallel applications. An integer identifier common to the corresponding mesh entity instances on each processor for a mesh entity on the interface.
Definition at line 15 of file MBParallelConventions.h.
Referenced by test_var_length_parallel().
Definition at line 24 of file MBParallelConventions.h.
| #define PARALLEL_PARTITION_TAG_NAME "PARALLEL_PARTITION" |
When the mesh is partitioned for use in a parallel environment, the each CPUs partition of the mesh is stored in a meshset with this tag. The value of the tag is an integer "part identifier".
Definition at line 23 of file MBParallelConventions.h.
Referenced by moab::ParallelComm::augment_default_sets_with_ghosts(), create_coarse_mesh(), create_fine_mesh(), moab::ReadParallel::create_partition_sets(), moab::ReadGmsh::create_sets(), moab::ParallelData::get_partition_sets(), moab::ReadParallel::load_file(), main(), moab::ParallelComm::partition_tag(), report_sets(), moab::ParallelComm::resolve_shared_sets(), moab::WriteGmsh::write_file(), and moab::WriteCCMIO::WriteCCMIO().
| #define PARALLEL_PARTITIONING_TAG_NAME "PARALLEL_MESH_PARTITIONING" |
This tag labels an entity set for which the child sets are part(ition)s that together are a single partitioning of the mesh. I.e. There should be no mesh entity that is contained in more than one child part(ition) set, and typically every mesh entity of the dimension used to partition the mesh is contained in exactly one of the child sets.
The data for this tag is a single integer value. The value of the tag is undefined.
Definition at line 38 of file MBParallelConventions.h.
Referenced by iMeshP_createPartitionAll().
| #define PARALLEL_SHARED_HANDLE_TAG_NAME "__PARALLEL_SHARED_HANDLE" |
This single-valued tag implies an entity is shared with one other proc
Definition at line 58 of file MBParallelConventions.h.
Referenced by get_sharing_processors(), print_partitioned_entities(), and moab::ParallelComm::sharedh_tag().
| #define PARALLEL_SHARED_HANDLES_TAG_NAME "__PARALLEL_SHARED_HANDLES" |
This multiple-valued tag implies an entity is shared with multiple other processors. Length of tag is application-dependent, and depends on what the maximum number of processors is which share an entity
Definition at line 66 of file MBParallelConventions.h.
Referenced by get_sharing_processors(), print_partitioned_entities(), and moab::ParallelComm::sharedhs_tag().
| #define PARALLEL_SHARED_PROC_TAG_NAME "__PARALLEL_SHARED_PROC" |
Definition at line 44 of file MBParallelConventions.h.
Referenced by moab::ParallelData::get_interface_sets(), get_sharing_processors(), print_partitioned_entities(), and moab::ParallelComm::sharedp_tag().
| #define PARALLEL_SHARED_PROCS_TAG_NAME "__PARALLEL_SHARED_PROCS" |
Definition at line 52 of file MBParallelConventions.h.
Referenced by moab::ParallelData::get_interface_sets(), get_sharing_processors(), print_partitioned_entities(), and moab::ParallelComm::sharedps_tag().
| #define PARALLEL_STATUS_TAG_NAME "__PARALLEL_STATUS" |
This tag stores various aspects of parallel status in bits; see also #define's following, to be used in bit mask operations. If an entity is not shared with any other processors, the pstatus is 0, otherwise it's > 0
bit 0: !owned (0=owned, 1=not owned) bit 1: shared (0=not shared, 1=shared) bit 2: multishared (shared by > 2 procs; 0=not shared, 1=shared) bit 3: interface (0=not interface, 1=interface) bit 4: ghost (0=not ghost, 1=ghost)
Definition at line 80 of file MBParallelConventions.h.
Referenced by get_sharing_processors(), print_partitioned_entities(), and moab::ParallelComm::pstatus_tag().
| #define PSTATUS_AND 0x1 |
Definition at line 89 of file MBParallelConventions.h.
Referenced by moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), moab::ParallelComm::filter_pstatus(), moab::WriteHDF5Parallel::gather_interface_meshes(), moab::ParallelComm::get_sent_ents(), moab::ParallelComm::get_shared_entities(), moab::LloydSmoother::perform_smooth(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::send_entities(), moab::ParallelComm::settle_intersection_points(), and test_filter_pstatus().
| #define PSTATUS_GHOST 0x10 |
Definition at line 87 of file MBParallelConventions.h.
Referenced by closedsurface_uref_hirec_convergence_study(), iMeshP_getEntStatusArr(), iMOAB_UpdateMeshInfo(), moab::HiReconstruction::initialize(), moab::HalfFacetRep::initialize(), moab::LloydSmoother::initialize(), moab::ParallelComm::list_entities(), main(), moab::ParallelComm::print_pstatus(), refine_entities(), moab::ParallelComm::set_sharing_data(), test_filter_pstatus(), moab::ParallelComm::unpack_entities(), and moab::ParallelComm::update_remote_data_old().
| #define PSTATUS_INTERFACE 0x8 |
Definition at line 85 of file MBParallelConventions.h.
Referenced by moab::ParallelComm::check_clean_iface(), moab::ParallelComm::create_interface_sets(), get_ghost_entities(), moab::ParallelComm::get_shared_entities(), iMeshP_getEntStatusArr(), moab::LloydSmoother::initialize(), moab::ParallelComm::list_entities(), moab::ParallelComm::print_pstatus(), moab::ParallelComm::resolve_shared_ents(), moab::RefinerTagManager::set_sharing(), moab::ParallelComm::set_sharing_data(), moab::ParallelComm::tag_iface_entities(), test_filter_pstatus(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::update_remote_data(), and moab::ParallelComm::update_remote_data_old().
| #define PSTATUS_MULTISHARED 0x4 |
Definition at line 84 of file MBParallelConventions.h.
Referenced by moab::ParallelComm::build_sharedhps_list(), moab::ParallelComm::check_clean_iface(), moab::ParallelComm::check_local_shared(), moab::ParallelComm::correct_thin_ghost_layers(), moab::ParallelComm::create_interface_sets(), moab::ParallelComm::filter_pstatus(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_sharing_data(), moab::ParallelComm::list_entities(), moab::ParallelComm::print_pstatus(), moab::ParallelComm::set_sharing_data(), moab::ParallelComm::tag_shared_verts(), test_filter_pstatus(), moab::ParallelComm::update_remote_data(), and moab::ParallelComm::update_remote_data_old().
| #define PSTATUS_NOT 0x3 |
Definition at line 91 of file MBParallelConventions.h.
Referenced by closedsurface_uref_hirec_convergence_study(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteGCRM::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), count_owned_entities(), create_fine_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::ParallelComm::exchange_tags(), moab::ParallelComm::filter_pstatus(), gather_one_cell_var(), moab::ParallelComm::get_ghosted_entities(), get_max_volume(), moab::ParallelComm::get_shared_entities(), hcFilter(), iMOAB_UpdateMeshInfo(), moab::HiReconstruction::initialize(), moab::HalfFacetRep::initialize(), moab::LloydSmoother::initialize(), laplacianFilter(), moab::ReadParallel::load_file(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), read_mesh_parallel(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), refine_entities(), test_filter_pstatus(), test_gather_onevar(), and test_read_parallel().
| #define PSTATUS_NOT_OWNED 0x1 |
Definition at line 82 of file MBParallelConventions.h.
Referenced by moab::ParallelComm::assign_global_ids(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::ParallelComm::build_sharedhps_list(), moab::ParallelComm::check_clean_iface(), moab::ParallelComm::check_local_shared(), moab::ParallelComm::check_my_shared_handles(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::ParallelComm::correct_thin_ghost_layers(), count_owned(), count_owned_entities(), create_fine_mesh(), moab::ParallelComm::create_interface_sets(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::ParallelComm::exchange_tags(), moab::WriteHDF5Parallel::gather_interface_meshes(), gather_one_cell_var(), get_ghost_entities(), moab::ParallelComm::get_ghosted_entities(), get_max_volume(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_owning_part(), moab::ParallelComm::get_shared_entities(), hcFilter(), laplacianFilter(), moab::ParallelComm::list_entities(), moab::ReadParallel::load_file(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), print_partitioned_entities(), moab::ParallelComm::print_pstatus(), read_mesh_parallel(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), report_iface_ents(), moab::ParallelComm::resolve_shared_ents(), moab::RefinerTagManager::set_sharing(), moab::ParallelComm::set_sharing_data(), moab::ParallelComm::tag_iface_entities(), test_filter_pstatus(), test_gather_onevar(), test_read_parallel(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::update_remote_data(), and moab::ParallelComm::update_remote_data_old().
| #define PSTATUS_OR 0x2 |
Definition at line 90 of file MBParallelConventions.h.
Referenced by moab::ParallelComm::filter_pstatus(), and moab::ParallelComm::resolve_shared_sets().
| #define PSTATUS_SHARED 0x2 |
Definition at line 83 of file MBParallelConventions.h.
Referenced by moab::ParallelComm::build_sharedhps_list(), moab::ParallelComm::check_clean_iface(), moab::ParallelComm::check_local_shared(), moab::ParallelComm::create_interface_sets(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), moab::ParallelComm::filter_pstatus(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_sent_ents(), moab::ParallelComm::get_shared_entities(), moab::ParallelComm::get_sharing_data(), moab::ParallelComm::get_sharing_parts(), get_sharing_processors(), moab::ParallelComm::list_entities(), moab::LloydSmoother::perform_smooth(), print_partitioned_entities(), moab::ParallelComm::print_pstatus(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::resolve_shared_sets(), moab::ParallelComm::send_entities(), moab::RefinerTagManager::set_sharing(), moab::ParallelComm::set_sharing_data(), moab::ParallelComm::settle_intersection_points(), moab::ParallelComm::tag_shared_verts(), test_filter_pstatus(), moab::ParallelComm::update_remote_data(), and moab::ParallelComm::update_remote_data_old().
