MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include <vector> 00003 #include <string> 00004 #include <iomanip> 00005 #include <fstream> 00006 #if defined( __MINGW32__ ) 00007 #include <sys/time.h> 00008 #else 00009 #include <ctime> 00010 #endif 00011 00012 #include <ctime> 00013 #include <cmath> 00014 #include <cassert> 00015 #include <cfloat> 00016 00017 #include "moab/Core.hpp" 00018 #include "moab/Interface.hpp" 00019 #include "moab/verdict/VerdictWrapper.hpp" 00020 #include "moab/NestedRefine.hpp" 00021 00022 #ifdef MOAB_HAVE_MPI 00023 #include "moab_mpi.h" 00024 #include "moab/ParallelComm.hpp" 00025 #include "MBParallelConventions.h" 00026 #endif 00027 00028 /* Exit values */ 00029 #define SUCCESS 0 00030 #define USAGE_ERROR 1 00031 #define NOT_IMPLEMENTED 2 00032 00033 using namespace moab; 00034 00035 static void print_usage( const char* name, std::ostream& stream ) 00036 { 00037 stream << "Usage: " << name << " <options> <input_file> [<input_file2> ...]" << std::endl 00038 << "Options: " << std::endl 00039 << "\t-h - Print this help text and exit." << std::endl 00040 << "\t-d - Dimension of the mesh." << std::endl 00041 << "\t-n - Exact or a maximum number of levels for the hierarchy. Default 1." << std::endl 00042 << "\t-L - Degree of refinement for each level. Pass an array or a number. It " 00043 "is mandatory to pass dimension and num_levels before to use this option. If this flag " 00044 "is not used, a default of deg 2 refinement is used. " 00045 << std::endl 00046 << "\t-V - Pass a desired volume (absolute) . This will generate a hierarchy " 00047 "such that the maximum volume is reduced to the given amount approximately. The length " 00048 "of the hierarchy can be constrained further if a maximum number of levels is passed. " 00049 "It is mandatory to pass the dimension for this option. " 00050 << std::endl 00051 << "\t-q - Prints out the maximum volume of the mesh and exits the program. " 00052 "This option can be used as a guide to volume constrainted mesh hierarchy later. " 00053 << std::endl 00054 << "\t-t - Print out the time taken to generate hierarchy." << std::endl 00055 << "\t-s - Print out the mesh sizes of each level of the generated hierarchy." << std::endl 00056 << "\t-o - Specify true for output files for the mesh levels of the hierarchy." << std::endl 00057 //<< "\t-O option - Specify read option." << std::endl 00058 #ifdef MOAB_HAVE_MPI 00059 << "\t-p[0|1|2] - Read in parallel[0], optionally also doing resolve_shared_ents (1) " 00060 "and exchange_ghosts (2)" 00061 << std::endl 00062 #endif 00063 ; 00064 exit( USAGE_ERROR ); 00065 } 00066 00067 static void usage_error( const char* name ) 00068 { 00069 print_usage( name, std::cerr ); 00070 #ifdef MOAB_HAVE_MPI 00071 MPI_Finalize(); 00072 #endif 00073 exit( USAGE_ERROR ); 00074 } 00075 00076 bool parse_id_list( const char* string, int dim, int nval, std::vector< int >& results ); 00077 00078 bool make_opts_string( std::vector< std::string > options, std::string& opts ); 00079 00080 ErrorCode get_degree_seq( Core& mb, 00081 EntityHandle fileset, 00082 int dim, 00083 double desired_vol, 00084 int& num_levels, 00085 std::vector< int >& level_degs ); 00086 00087 ErrorCode get_max_volume( Core& mb, EntityHandle fileset, int dim, double& vmax ); 00088 00089 int main( int argc, char* argv[] ) 00090 { 00091 int proc_id = 0, size = 1; 00092 #ifdef MOAB_HAVE_MPI 00093 MPI_Init( &argc, &argv ); 00094 MPI_Comm_rank( MPI_COMM_WORLD, &proc_id ); 00095 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00096 #endif 00097 00098 int num_levels = 0, dim = 0; 00099 std::vector< int > level_degrees; 00100 bool optimize = false; 00101 bool do_flag = true; 00102 bool print_times = false, print_size = false, output = false; 00103 bool parallel = false, resolve_shared = false, exchange_ghosts = false; 00104 bool printusage = false, parselevels = true; 00105 bool qc_vol = false, only_quality = false; 00106 double cvol = 0; 00107 std::string infile; 00108 00109 int i = 1; 00110 while( i < argc ) 00111 { 00112 if( !argv[i][0] && 0 == proc_id ) 00113 { 00114 usage_error( argv[0] ); 00115 #ifdef MOAB_HAVE_MPI 00116 MPI_Finalize(); 00117 #endif 00118 } 00119 00120 if( do_flag && argv[i][0] == '-' ) 00121 { 00122 switch( argv[i][1] ) 00123 { 00124 // do flag arguments: 00125 case '-': 00126 do_flag = false; 00127 break; 00128 case 't': 00129 print_times = true; 00130 break; 00131 case 's': 00132 print_size = true; 00133 break; 00134 case 'h': 00135 case 'H': 00136 print_usage( argv[0], std::cerr ); 00137 printusage = true; 00138 break; 00139 case 'd': 00140 dim = atol( argv[i + 1] ); 00141 ++i; 00142 break; 00143 case 'n': 00144 num_levels = atol( argv[i + 1] ); 00145 ++i; 00146 break; 00147 case 'L': 00148 if( dim != 0 && num_levels != 0 ) 00149 { 00150 parselevels = parse_id_list( argv[i + 1], dim, num_levels, level_degrees ); 00151 ++i; 00152 } 00153 else 00154 { 00155 print_usage( argv[0], std::cerr ); 00156 printusage = true; 00157 } 00158 break; 00159 case 'V': 00160 qc_vol = true; 00161 cvol = strtod( argv[i + 1], NULL ); 00162 ++i; 00163 break; 00164 case 'q': 00165 only_quality = true; 00166 break; 00167 case 'o': 00168 output = true; 00169 break; 00170 case 'O': 00171 optimize = true; 00172 break; 00173 #ifdef MOAB_HAVE_MPI 00174 case 'p': 00175 parallel = true; 00176 resolve_shared = true; 00177 if( argv[i][1] == '1' ) exchange_ghosts = true; 00178 break; 00179 #endif 00180 default: 00181 ++i; 00182 switch( argv[i - 1][1] ) 00183 { 00184 // case 'O': read_opts.push_back(argv[i]); break; 00185 default: 00186 std::cerr << "Invalid option: " << argv[i] << std::endl; 00187 } 00188 } 00189 ++i; 00190 } 00191 // do file names 00192 else 00193 { 00194 infile = argv[i]; 00195 ++i; 00196 } 00197 } 00198 00199 if( infile.empty() && !printusage ) print_usage( argv[0], std::cerr ); 00200 00201 if( !parselevels ) exit( USAGE_ERROR ); 00202 00203 #ifdef MOAB_HAVE_MPI 00204 parallel = true; 00205 resolve_shared = true; 00206 #endif 00207 00208 ErrorCode error; 00209 00210 Core* moab = new Core; 00211 Interface* mb = (Interface*)moab; 00212 EntityHandle fileset; 00213 00214 // Create a fileset 00215 error = mb->create_meshset( MESHSET_SET, fileset );MB_CHK_ERR( error ); 00216 00217 // Set the read options for parallel file loading 00218 std::vector< std::string > read_opts, write_opts; 00219 std::string read_options, write_options; 00220 00221 if( parallel && size > 1 ) 00222 { 00223 read_opts.push_back( "PARALLEL=READ_PART" ); 00224 read_opts.push_back( "PARTITION=PARALLEL_PARTITION" ); 00225 if( resolve_shared ) read_opts.push_back( "PARALLEL_RESOLVE_SHARED_ENTS" ); 00226 if( exchange_ghosts ) read_opts.push_back( "PARALLEL_GHOSTS=3.0.1" ); 00227 00228 /* if (output) 00229 { 00230 write_opts.push_back(";;PARALLEL=WRITE_PART"); 00231 std::cout<<"Here"<<std::endl; 00232 }*/ 00233 } 00234 00235 if( !make_opts_string( read_opts, read_options ) || !make_opts_string( write_opts, write_options ) ) 00236 { 00237 #ifdef MOAB_HAVE_MPI 00238 MPI_Finalize(); 00239 #endif 00240 return USAGE_ERROR; 00241 } 00242 00243 // Load file 00244 std::cout << "READ OPTS=" << (char*)read_options.c_str() << std::endl; 00245 error = mb->load_file( infile.c_str(), &fileset, read_options.c_str() );MB_CHK_ERR( error ); 00246 00247 // Create the nestedrefine instance 00248 00249 #ifdef MOAB_HAVE_MPI 00250 ParallelComm* pc = new ParallelComm( mb, MPI_COMM_WORLD ); 00251 NestedRefine* uref = new NestedRefine( moab, pc, fileset ); 00252 #else 00253 NestedRefine* uref = new NestedRefine( moab ); 00254 #endif 00255 00256 std::vector< EntityHandle > lsets; 00257 00258 // std::cout<<"Read input file"<<std::endl; 00259 00260 if( only_quality ) 00261 { 00262 double vmax; 00263 error = get_max_volume( *moab, fileset, dim, vmax );MB_CHK_ERR( error ); 00264 #ifdef MOAB_HAVE_MPI 00265 int rank = 0; 00266 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00267 if( rank == 0 ) std::cout << "Maximum global volume = " << vmax << std::endl; 00268 #else 00269 std::cout << "Maximum volume = " << vmax << std::endl; 00270 #endif 00271 exit( SUCCESS ); 00272 } 00273 00274 // If a volume constraint is given, find an optimal degree sequence to reach the desired volume 00275 // constraint. 00276 if( qc_vol ) 00277 { 00278 error = get_degree_seq( *moab, fileset, dim, cvol, num_levels, level_degrees );MB_CHK_ERR( error ); 00279 00280 if( dim == 0 ) print_usage( argv[0], std::cerr ); 00281 } 00282 00283 if( num_levels == 0 ) num_levels = 1; 00284 00285 int* ldeg = new int[num_levels]; 00286 // std::cout<<"level_degrees.size = "<<level_degrees.size()<<std::endl; 00287 if( level_degrees.empty() ) 00288 { 00289 for( int l = 0; l < num_levels; l++ ) 00290 ldeg[l] = 2; 00291 } 00292 else 00293 { 00294 for( int l = 0; l < num_levels; l++ ) 00295 ldeg[l] = level_degrees[l]; 00296 } 00297 00298 std::cout << "Starting hierarchy generation" << std::endl; 00299 00300 std::cout << "opt = " << optimize << std::endl; 00301 00302 error = uref->generate_mesh_hierarchy( num_levels, ldeg, lsets, optimize );MB_CHK_ERR( error ); 00303 00304 if( print_times ) 00305 { 00306 std::cout << "Finished hierarchy generation in " << uref->timeall.tm_total << " secs" << std::endl; 00307 if( parallel ) 00308 { 00309 std::cout << "Time taken for refinement " << uref->timeall.tm_refine << " secs" << std::endl; 00310 std::cout << "Time taken for resolving shared interface " << uref->timeall.tm_resolve << " secs" 00311 << std::endl; 00312 } 00313 } 00314 else 00315 std::cout << "Finished hierarchy generation " << std::endl; 00316 00317 if( print_size ) 00318 { 00319 Range all_ents, ents[4]; 00320 error = mb->get_entities_by_handle( fileset, all_ents );MB_CHK_ERR( error ); 00321 00322 for( int k = 0; k < 4; k++ ) 00323 ents[k] = all_ents.subset_by_dimension( k ); 00324 00325 std::cout << std::endl; 00326 if( qc_vol ) 00327 { 00328 double volume; 00329 error = get_max_volume( *moab, fileset, dim, volume );MB_CHK_ERR( error ); 00330 std::cout << "Mesh size for level 0" 00331 << " :: nverts = " << ents[0].size() << ", nedges = " << ents[1].size() 00332 << ", nfaces = " << ents[2].size() << ", ncells = " << ents[3].size() << " :: Vmax = " << volume 00333 << std::endl; 00334 } 00335 else 00336 std::cout << "Mesh size for level 0" 00337 << " :: nverts = " << ents[0].size() << ", nedges = " << ents[1].size() 00338 << ", nfaces = " << ents[2].size() << ", ncells = " << ents[3].size() << std::endl; 00339 00340 for( int l = 0; l < num_levels; l++ ) 00341 { 00342 all_ents.clear(); 00343 ents[0].clear(); 00344 ents[1].clear(); 00345 ents[2].clear(); 00346 ents[3].clear(); 00347 error = mb->get_entities_by_handle( lsets[l + 1], all_ents );MB_CHK_ERR( error ); 00348 00349 for( int k = 0; k < 4; k++ ) 00350 ents[k] = all_ents.subset_by_dimension( k ); 00351 00352 // std::cout<<std::endl; 00353 00354 if( qc_vol ) 00355 { 00356 double volume; 00357 error = get_max_volume( *moab, lsets[l + 1], dim, volume );MB_CHK_ERR( error ); 00358 std::cout << "Mesh size for level " << l + 1 << " :: nverts = " << ents[0].size() 00359 << ", nedges = " << ents[1].size() << ", nfaces = " << ents[2].size() 00360 << ", ncells = " << ents[3].size() << " :: Vmax = " << volume << std::endl; 00361 } 00362 else 00363 std::cout << "Mesh size for level " << l + 1 << " :: nverts = " << ents[0].size() 00364 << ", nedges = " << ents[1].size() << ", nfaces = " << ents[2].size() 00365 << ", ncells = " << ents[3].size() << std::endl; 00366 } 00367 } 00368 00369 if( output ) 00370 { 00371 for( int l = 0; l < num_levels; l++ ) 00372 { 00373 std::string::size_type idx1 = infile.find_last_of( "\\/" ); 00374 std::string::size_type idx2 = infile.find_last_of( "." ); 00375 std::string file = infile.substr( idx1 + 1, idx2 - idx1 - 1 ); 00376 std::stringstream out; 00377 if( parallel ) 00378 out << "_ML_" << l + 1 << ".h5m"; 00379 else 00380 out << "_ML_" << l + 1 << ".vtk"; 00381 file = file + out.str(); 00382 const char* output_file = file.c_str(); 00383 #ifdef MOAB_HAVE_MPI 00384 error = mb->write_file( output_file, 0, ";;PARALLEL=WRITE_PART", &lsets[l + 1], 1 );MB_CHK_ERR( error ); 00385 #else 00386 error = mb->write_file( output_file, 0, NULL, &lsets[l + 1], 1 );MB_CHK_ERR( error ); 00387 #endif 00388 // const char* output_file = file.c_str(); 00389 // error = mb->write_file(output_file, 0, write_options.c_str(), &lsets[l+1], 00390 // 1);MB_CHK_ERR(error); 00391 // mb->list_entity(lsets[l+1]); 00392 // mb->write_file(output_file, 0, "PARALLEL=WRITE_PART", &lsets[l+1], 1); 00393 } 00394 } 00395 00396 delete uref; 00397 #ifdef MOAB_HAVE_MPI 00398 delete pc; 00399 #endif 00400 00401 delete[] ldeg; 00402 delete moab; 00403 00404 #ifdef MOAB_HAVE_MPI 00405 MPI_Finalize(); 00406 #endif 00407 00408 exit( SUCCESS ); 00409 } 00410 00411 ErrorCode get_degree_seq( Core& mb, 00412 EntityHandle fileset, 00413 int dim, 00414 double desired_vol, 00415 int& num_levels, 00416 std::vector< int >& level_degs ) 00417 { 00418 // Find max volume 00419 double vmax_global; 00420 ErrorCode error = get_max_volume( mb, fileset, dim, vmax_global );MB_CHK_ERR( error ); 00421 00422 int init_nl = num_levels; 00423 num_levels = 0; 00424 level_degs.clear(); 00425 00426 // Find a sequence that reduces the maximum volume to desired. 00427 // desired_vol should be a fraction or absolute value ? 00428 00429 // double remV = vmax_global*desired_vol/dim; 00430 double Vdesired = desired_vol; 00431 double try_x; 00432 double remV = vmax_global; 00433 int degs[3][3] = { { 5, 3, 2 }, { 25, 9, 4 }, { 0, 27, 8 } }; 00434 00435 if( dim == 1 || dim == 2 ) 00436 { 00437 while( remV - Vdesired >= 0 ) 00438 { 00439 try_x = degs[dim - 1][0]; 00440 if( ( remV / try_x - Vdesired ) >= 0 ) 00441 { 00442 level_degs.push_back( 5 ); 00443 num_levels += 1; 00444 remV /= try_x; 00445 } 00446 else 00447 { 00448 try_x = degs[dim - 1][1]; 00449 if( ( remV / try_x - Vdesired ) >= 0 ) 00450 { 00451 level_degs.push_back( 3 ); 00452 num_levels += 1; 00453 remV /= try_x; 00454 } 00455 else 00456 { 00457 try_x = degs[dim - 1][2]; 00458 if( ( remV / try_x - Vdesired ) >= 0 ) 00459 { 00460 level_degs.push_back( 2 ); 00461 num_levels += 1; 00462 remV /= try_x; 00463 } 00464 else 00465 break; 00466 } 00467 } 00468 } 00469 } 00470 else 00471 { 00472 while( remV - Vdesired >= 0 ) 00473 { 00474 try_x = degs[dim - 1][1]; 00475 if( ( remV / try_x - Vdesired ) >= 0 ) 00476 { 00477 level_degs.push_back( 3 ); 00478 num_levels += 1; 00479 remV /= try_x; 00480 } 00481 else 00482 { 00483 try_x = degs[dim - 1][2]; 00484 if( ( remV / try_x - Vdesired ) >= 0 ) 00485 { 00486 level_degs.push_back( 2 ); 00487 num_levels += 1; 00488 remV /= try_x; 00489 } 00490 else 00491 break; 00492 } 00493 } 00494 } 00495 00496 if( init_nl != 0 && init_nl < num_levels ) 00497 { 00498 for( int i = level_degs.size(); i >= init_nl; i-- ) 00499 level_degs.pop_back(); 00500 num_levels = init_nl; 00501 } 00502 00503 return MB_SUCCESS; 00504 } 00505 00506 ErrorCode get_max_volume( Core& mb, EntityHandle fileset, int dim, double& vmax ) 00507 { 00508 ErrorCode error; 00509 VerdictWrapper vw( &mb ); 00510 QualityType q; 00511 00512 switch( dim ) 00513 { 00514 case 1: 00515 q = MB_LENGTH; 00516 break; 00517 case 2: 00518 q = MB_AREA; 00519 break; 00520 case 3: 00521 q = MB_VOLUME; 00522 break; 00523 default: 00524 return MB_FAILURE; 00525 break; 00526 } 00527 00528 // Get all entities of the highest dimension which is passed as a command line argument. 00529 Range allents, owned; 00530 error = mb.get_entities_by_handle( fileset, allents );MB_CHK_ERR( error ); 00531 owned = allents.subset_by_dimension( dim );MB_CHK_ERR( error ); 00532 00533 // Get all owned entities 00534 #ifdef MOAB_HAVE_MPI 00535 int size = 1; 00536 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00537 int mpi_err; 00538 if( size > 1 ) 00539 { 00540 // filter the entities not owned, so we do not process them more than once 00541 ParallelComm* pcomm = moab::ParallelComm::get_pcomm( &mb, 0 ); 00542 Range current = owned; 00543 owned.clear(); 00544 error = pcomm->filter_pstatus( current, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned ); 00545 if( error != MB_SUCCESS ) 00546 { 00547 MPI_Finalize(); 00548 return MB_FAILURE; 00549 } 00550 } 00551 #endif 00552 00553 double vmax_local = 0; 00554 // Find the maximum volume of an entity in the owned mesh 00555 for( Range::iterator it = owned.begin(); it != owned.end(); it++ ) 00556 { 00557 double volume; 00558 error = vw.quality_measure( *it, q, volume );MB_CHK_ERR( error ); 00559 if( volume > vmax_local ) vmax_local = volume; 00560 } 00561 00562 // Get the global maximum 00563 double vmax_global = vmax_local; 00564 #ifdef MOAB_HAVE_MPI 00565 mpi_err = MPI_Reduce( &vmax_local, &vmax_global, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); 00566 if( mpi_err ) 00567 { 00568 MPI_Finalize(); 00569 return MB_FAILURE; 00570 } 00571 #endif 00572 00573 vmax = vmax_global; 00574 00575 return MB_SUCCESS; 00576 } 00577 00578 bool parse_id_list( const char* string, int dim, int nval, std::vector< int >& results ) 00579 { 00580 bool okay = true; 00581 char* mystr = strdup( string ); 00582 for( const char* ptr = strtok( mystr, "," ); ptr; ptr = strtok( 0, "," ) ) 00583 { 00584 char* endptr; 00585 int val = strtol( ptr, &endptr, 0 ); 00586 00587 if( dim == 1 || dim == 2 ) 00588 { 00589 if( val != 2 && val != 3 && val != 5 ) 00590 { 00591 std::cerr << "Not a valid degree for the passed dimension" << std::endl; 00592 okay = false; 00593 break; 00594 } 00595 } 00596 else if( dim == 3 ) 00597 { 00598 if( val != 2 && val != 3 ) 00599 { 00600 std::cerr << "Not a valid degree for the passed dimension" << std::endl; 00601 okay = false; 00602 break; 00603 } 00604 } 00605 00606 if( endptr == ptr || val <= 0 ) 00607 { 00608 std::cerr << "Not a valid id: " << ptr << std::endl; 00609 okay = false; 00610 break; 00611 } 00612 00613 results.push_back( val ); 00614 } 00615 00616 if( (int)results.size() < nval ) 00617 { 00618 for( int i = results.size(); i <= nval - 1; i++ ) 00619 results.push_back( results[0] ); 00620 } 00621 else if( (int)results.size() > nval ) 00622 { 00623 for( int i = results.size(); i > nval; i-- ) 00624 results.pop_back(); 00625 } 00626 00627 free( mystr ); 00628 return okay; 00629 } 00630 00631 bool make_opts_string( std::vector< std::string > options, std::string& opts ) 00632 { 00633 opts.clear(); 00634 if( options.empty() ) return true; 00635 00636 // choose a separator character 00637 std::vector< std::string >::const_iterator i; 00638 char separator = '\0'; 00639 const char* alt_separators = ";+,:\t\n"; 00640 for( const char* sep_ptr = alt_separators; *sep_ptr; ++sep_ptr ) 00641 { 00642 bool seen = false; 00643 for( i = options.begin(); i != options.end(); ++i ) 00644 if( i->find( *sep_ptr, 0 ) != std::string::npos ) 00645 { 00646 seen = true; 00647 break; 00648 } 00649 if( !seen ) 00650 { 00651 separator = *sep_ptr; 00652 break; 00653 } 00654 } 00655 if( !separator ) 00656 { 00657 std::cerr << "Error: cannot find separator character for options string" << std::endl; 00658 return false; 00659 } 00660 if( separator != ';' ) 00661 { 00662 opts = ";"; 00663 opts += separator; 00664 } 00665 00666 // concatenate options 00667 i = options.begin(); 00668 opts += *i; 00669 for( ++i; i != options.end(); ++i ) 00670 { 00671 opts += separator; 00672 opts += *i; 00673 } 00674 00675 return true; 00676 }
