MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <sstream>#include <ctime>#include <cstdlib>#include <cstdio>#include <cstring>#include "moab/Core.hpp"#include "moab/Interface.hpp"#include "moab/IntxMesh/Intx2MeshInPlane.hpp"#include "moab/IntxMesh/IntxUtils.hpp"#include "TestUtil.hpp"#include <cmath>
Include dependency graph for intx_in_plane_test.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 21 of file intx_in_plane_test.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), ErrorCode, moab::Intx2Mesh::FindMaxEdges(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), moab::Intx2Mesh::intersect_meshes(), moab::Interface::load_file(), mb, MB_CHK_ERR, MB_SUCCESS, MBPOLYGON, MESHSET_SET, moab::IntxAreaUtils::positive_orientation(), moab::Intx2Mesh::set_error_tolerance(), moab::Range::size(), STRINGIFY, moab::Interface::UNION, and moab::Interface::write_mesh().
// check command line arg
const char* filename_mesh1 = STRINGIFY( MESHDIR ) "/mbcslam/m1.vtk";
const char* filename_mesh2 = STRINGIFY( MESHDIR ) "/mbcslam/m2.vtk";
const char* newFile = "intx1.vtk";
const char* edgesFile = "polyWithEdges.vtk";
if( argc == 4 )
filename_mesh1 = argv[1];
filename_mesh2 = argv[2];
newFile = argv[3];
else
printf( "Usage: %s <mesh_filename1> <mesh_filename2> <newFile>\n", argv[0] );
if( argc != 1 ) return 1;
printf( "No files specified. Defaulting to: %s %s %s\n", filename_mesh1, filename_mesh2, newFile );
// read meshes in 2 file sets
Core moab;
Interface* mb = &moab; // global
EntityHandle sf1, sf2;
ErrorCode rval = mb->create_meshset( MESHSET_SET, sf1 );
if( MB_SUCCESS != rval ) return 1;
rval = mb->create_meshset( MESHSET_SET, sf2 );
rval = mb->load_file( filename_mesh1, &sf1 );
rval = mb->load_file( filename_mesh2, &sf2 );
EntityHandle outputSet;
rval = mb->create_meshset( MESHSET_SET, outputSet );
Intx2MeshInPlane worker( mb );
IntxAreaUtils areaAdaptor;
rval = areaAdaptor.positive_orientation( mb, sf1, -1 );MB_CHK_ERR( rval );
rval = areaAdaptor.positive_orientation( mb, sf2, -1 );MB_CHK_ERR( rval );
worker.set_error_tolerance( 1.e-5 );
rval = worker.FindMaxEdges( sf1, sf2 );MB_CHK_ERR( rval );
// worker.enable_debug();
rval = worker.intersect_meshes( sf1, sf2, outputSet );
rval = mb->write_mesh( newFile, &outputSet, 1 );
// retrieve polygons and get adjacent edges
Range polygons;
rval = mb->get_entities_by_type( outputSet, MBPOLYGON, polygons );
Range edges;
rval = mb->get_adjacencies( polygons, 1, true, edges, Interface::UNION );
std::cout << "number of edges:" << edges.size() << "\n";
// add edges to the output set
rval = mb->add_entities( outputSet, edges );
rval = mb->write_mesh( edgesFile, &outputSet, 1 );
return 0;
