MOAB: Mesh Oriented datABase
(version 5.4.1)
test geometrize method from GeomTopoTool More...
#include "moab/Core.hpp"#include <iostream>#include <cassert>#include <cstring>#include <cstdio>#include "TestUtil.hpp"#include "moab/GeomTopoTool.hpp"#include "MBTagConventions.hpp"
Include dependency graph for gttool_test.cpp:Go to the source code of this file.
Functions | |
| ErrorCode | geometrize_test (Interface *mb, EntityHandle inputSet) |
| ErrorCode | create_shell_test (Interface *mb) |
| ErrorCode | duplicate_model_test (Interface *mb) |
| ErrorCode | check_model_test (Interface *mb) |
| ErrorCode | test_root_sets_resize (Interface *mb) |
| ErrorCode | test_delete_obb_tree (Interface *mb) |
| ErrorCode | test_restore_obb_trees (Interface *mb, Interface *mb2, Interface *mb3) |
| void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
| int | main (int argc, char *argv[]) |
Variables | |
| std::string | filename |
| std::string | filename2 |
| std::string | ofile |
| std::string | ofile2 |
| std::string | ofile3 |
| std::string | ofile4 |
| std::string | ofile5 |
| const char | OBB_ROOT_TAG_NAME [] = "OBB_ROOT" |
| Tag | obbRootTag |
| bool | remove_output_file |
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition in file gttool_test.cpp.
| ErrorCode check_model_test | ( | Interface * | mb | ) |
Definition at line 424 of file gttool_test.cpp.
References moab::GeomTopoTool::check_model(), moab::Interface::delete_mesh(), ErrorCode, moab::Interface::load_file(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, ofile3, and remove_output_file.
Referenced by main().
ErrorCode rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "Can't delete existing mesh\n" );
rval = mb->load_file( ofile3.c_str() );MB_CHK_ERR( rval );
// do some tests on geometry
// it would be good to have a method on updating the geom topo tool
// so we do not have to create another one
if( remove_output_file )
remove( ofile3.c_str() );
moab::GeomTopoTool gTopoTool( mb, true );
if( !gTopoTool.check_model() ) return MB_FAILURE;
return MB_SUCCESS;
| ErrorCode create_shell_test | ( | Interface * | mb | ) |
Definition at line 196 of file gttool_test.cpp.
References moab::Interface::add_entities(), moab::GeomTopoTool::add_geo_set(), moab::Interface::add_parent_child(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Interface::delete_mesh(), ErrorCode, moab::GeomTopoTool::find_geomsets(), moab::Interface::load_file(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MBEDGE, MBTRI, MESHSET_SET, ofile2, remove_output_file, SENSE_FORWARD, SENSE_REVERSE, moab::GeomTopoTool::set_senses(), size, and moab::Interface::write_mesh().
// we should be able to delete mesh and create a model from scratch
// create some vertices
double coords[] = { 0, 0, 0, 1, 0, 0.1, 2, 0, 0, 3, 0, -0.1, 0, 1, 0, 1, 1, 0, 2, 1, 0,
3, 1, -0.1, 0, 2, 0, 1, 2, -0.1, 2, 2, -0.1, 3, 2, -0.2, 0, 0, 1, 1, 0, 0.9,
2, 0.1, 0.85, 3, 0.2, 0.8, 0, 0.1, 2, 1, 0.1, 2, 2.1, 0.2, 2.1, 3.1, 0.2, 2.1 };
int nvert = 20;
Range verts;
rval = mb->create_vertices( coords, nvert, verts );MB_CHK_SET_ERR( rval, "Can't create vertices\n" );
EntityHandle connec[] = {
1, 2, 5, 5, 2, 6, 2, 3, 6, 6, 3, 7, 3, 4, 7, 7, 4, 8,
5, 6, 9, 9, 6, 10, 6, 7, 10, 10, 7, 11, 7, 8, 11, 11, 8, 12, // first face, 1-12
13, 14, 1, 1, 14, 2, 14, 15, 2, 2, 15, 3, 15, 16, 3, 3, 16, 4,
17, 18, 13, 13, 18, 14, 18, 19, 14, 14, 19, 15, 19, 20, 15, 15, 20, 16 // second face, 13-24
EntityHandle elem;
int nbTri = sizeof( connec ) / 3 / sizeof( EntityHandle );
int i = 0;
std::vector< EntityHandle > tris;
for( i = 0; i < nbTri; i++ )
mb->create_element( MBTRI, &connec[3 * i], 3, elem );
tris.push_back( elem );
// create some edges too
EntityHandle edges[] = {
1, 2, 2, 3, 3, 4, // geo edge 1 1:3
4, 8, 8, 12, // geo 2 4:5
12, 11, 11, 10, 10, 9, // geo 3 6:8
9, 5, 5, 1, // geo 4 9:10
1, 13, 13, 17, // geo 5 11:12
17, 18, 18, 19, 19, 20, // geo 6 13:15
20, 16, 16, 4 // geo 7 16:17
int nbEdges = sizeof( edges ) / 2 / sizeof( EntityHandle );
std::vector< EntityHandle > edgs;
for( i = 0; i < nbEdges; i++ )
mb->create_element( MBEDGE, &edges[2 * i], 2, elem );
edgs.push_back( elem );
// create some sets, and create some ordered sets for edges
EntityHandle face1, face2;
rval = mb->create_meshset( MESHSET_SET, face1 );MB_CHK_ERR( rval );
rval = mb->add_entities( face1, &tris[0], 12 );MB_CHK_ERR( rval );
rval = mb->create_meshset( MESHSET_SET, face2 );MB_CHK_ERR( rval );
// next 12 triangles
rval = mb->add_entities( face2, &tris[12], 12 );MB_CHK_ERR( rval );
// the orientation and senses need to be set for face edges
moab::GeomTopoTool gTopoTool( mb, false );
rval = gTopoTool.add_geo_set( face1, 2 );MB_CHK_ERR( rval );
rval = gTopoTool.add_geo_set( face2, 2 );MB_CHK_ERR( rval );
EntityHandle edge[7]; // edge[0] has EH 1...
for( i = 0; i < 7; i++ )
rval = mb->create_meshset( MESHSET_ORDERED, edge[i] );MB_CHK_ERR( rval );
rval = gTopoTool.add_geo_set( edge[i], 1 );MB_CHK_ERR( rval );
// first 3 mesh edges...
rval = mb->add_entities( edge[0], &edgs[0], 3 );MB_CHK_ERR( rval );
rval = mb->add_entities( edge[1], &edgs[3], 2 );MB_CHK_ERR( rval );
rval = mb->add_entities( edge[2], &edgs[5], 3 );MB_CHK_ERR( rval );
rval = mb->add_entities( edge[3], &edgs[8], 2 );MB_CHK_ERR( rval );
rval = mb->add_entities( edge[4], &edgs[10], 2 );MB_CHK_ERR( rval );
rval = mb->add_entities( edge[5], &edgs[12], 3 );MB_CHK_ERR( rval );
rval = mb->add_entities( edge[6], &edgs[15], 2 );MB_CHK_ERR( rval );
// create some sets for vertices; also need to create some for parent/child relationships
EntityHandle vertSets[6]; // start from 0
for( i = 0; i < 6; i++ )
rval = mb->create_meshset( MESHSET_SET, vertSets[i] );MB_CHK_ERR( rval );
rval = gTopoTool.add_geo_set( vertSets[i], 0 );MB_CHK_ERR( rval );
EntityHandle v( 1 ); // first vertex;
rval = mb->add_entities( vertSets[0], &v, 1 );MB_CHK_ERR( rval );
v = EntityHandle( 4 );
rval = mb->add_entities( vertSets[1], &v, 1 );MB_CHK_ERR( rval );
v = EntityHandle( 9 );
rval = mb->add_entities( vertSets[2], &v, 1 );MB_CHK_ERR( rval );
v = EntityHandle( 12 );
rval = mb->add_entities( vertSets[3], &v, 1 );MB_CHK_ERR( rval );
v = EntityHandle( 17 );
rval = mb->add_entities( vertSets[4], &v, 1 );MB_CHK_ERR( rval );
v = EntityHandle( 20 );
rval = mb->add_entities( vertSets[5], &v, 1 );MB_CHK_ERR( rval );
// need to add parent-child relations between sets
// edge 1 : 1-2
rval = mb->add_parent_child( edge[0], vertSets[0] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[0], vertSets[1] );MB_CHK_ERR( rval );
// edge 2 : 2-4
rval = mb->add_parent_child( edge[1], vertSets[1] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[1], vertSets[3] );MB_CHK_ERR( rval );
// edge 3 : 4-3
rval = mb->add_parent_child( edge[2], vertSets[3] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[2], vertSets[2] );MB_CHK_ERR( rval );
// edge 4 : 4-1
rval = mb->add_parent_child( edge[3], vertSets[2] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[3], vertSets[0] );MB_CHK_ERR( rval );
// edge 5 : 1-5
rval = mb->add_parent_child( edge[4], vertSets[0] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[4], vertSets[4] );MB_CHK_ERR( rval );
// edge 6 : 5-6
rval = mb->add_parent_child( edge[5], vertSets[4] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[5], vertSets[5] );MB_CHK_ERR( rval );
// edge 7 : 6-2
rval = mb->add_parent_child( edge[6], vertSets[5] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( edge[6], vertSets[1] );MB_CHK_ERR( rval );
// face 1: edges 1, 2, 3, 4
rval = mb->add_parent_child( face1, edge[0] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( face1, edge[1] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( face1, edge[2] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( face1, edge[3] );MB_CHK_ERR( rval );
// face 2: edges 1, 5, 6, 7
rval = mb->add_parent_child( face2, edge[0] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( face2, edge[4] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( face2, edge[5] );MB_CHK_ERR( rval );
rval = mb->add_parent_child( face2, edge[6] );MB_CHK_ERR( rval );
// set senses !!
std::vector< EntityHandle > faces;
faces.push_back( face1 ); // the face1 has all edges oriented positively
std::vector< int > senses;
senses.push_back( moab::SENSE_FORWARD ); //
// faces.push_back(face1);
// faces.push_back(face2);
gTopoTool.set_senses( edge[1], faces, senses );
gTopoTool.set_senses( edge[2], faces, senses );
gTopoTool.set_senses( edge[3], faces, senses );
faces[0] = face2; // set senses for edges for face2
gTopoTool.set_senses( edge[4], faces, senses );
gTopoTool.set_senses( edge[5], faces, senses );
gTopoTool.set_senses( edge[6], faces, senses );
// the only complication is edge1 (edge[0]), that has face1 forward and face 2 reverse
faces[0] = face1;
faces.push_back( face2 );
senses.push_back( moab::SENSE_REVERSE ); // -1 is reverse; face 2 is reverse for edge1 (0)
// forward == 0, reverse ==1
gTopoTool.set_senses( edge[0], faces, senses );
rval = mb->write_mesh( ofile2.c_str() );MB_CHK_ERR( rval );
rval = mb->delete_mesh();MB_CHK_ERR( rval );
// now test loading it up
rval = mb->load_file( ofile2.c_str() );MB_CHK_ERR( rval );
remove( ofile2.c_str() );
moab::GeomTopoTool gTopoTool2( mb, true ); // to find the geomsets
Range ranges[5];
rval = gTopoTool2.find_geomsets( ranges );
assert( MB_SUCCESS == rval );
assert( ranges[0].size() == 6 );
assert( ranges[1].size() == 7 );
assert( ranges[2].size() == 2 );
assert( ranges[3].size() == 0 );
assert( ranges[4].size() == 0 );
return MB_SUCCESS;
| ErrorCode duplicate_model_test | ( | Interface * | mb | ) |
Definition at line 393 of file gttool_test.cpp.
References moab::GeomTopoTool::duplicate_model(), ErrorCode, moab::GeomTopoTool::find_geomsets(), moab::GeomTopoTool::get_root_model_set(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, ofile3, size, and moab::Interface::write_file().
GeomTopoTool* newModel = NULL;
ErrorCode rval = gTopoTool2.duplicate_model( newModel );
if( NULL == newModel || rval != MB_SUCCESS ) return MB_FAILURE;
Range ranges[5];
rval = newModel->find_geomsets( ranges );MB_CHK_ERR( rval );
// write the model to a test file
EntityHandle rootModelSet = newModel->get_root_model_set();
std::cout << "writing duplicated model file: " << ofile3.c_str() << " ";
rval = mb->write_file( ofile3.c_str(), 0, 0, &rootModelSet, 1 );MB_CHK_SET_ERR( rval, "Can't write output files\n" );
delete newModel; // we are done with the new geom topo tool
// do not delete yet the output file, delay after the next test
/*if (remove_output_file)
remove(ofile3.c_str());
return MB_SUCCESS;
| ErrorCode geometrize_test | ( | Interface * | mb, |
| EntityHandle | inputSet | ||
Definition at line 181 of file gttool_test.cpp.
References ErrorCode, moab::GeomTopoTool::geometrize_surface_set(), MB_CHK_SET_ERR, MB_SUCCESS, ofile, remove_output_file, and moab::Interface::write_file().
GeomTopoTool gtt( mb );
EntityHandle outSet;
ErrorCode rval = gtt.geometrize_surface_set( inputSet, outSet );MB_CHK_SET_ERR( rval, "Can't geometrize the set\n" );
std::cout << "writing output file: " << ofile.c_str() << " ";
rval = mb->write_file( ofile.c_str(), 0, 0, &outSet, 1 );MB_CHK_SET_ERR( rval, "Can't write output file\n" );
remove( ofile.c_str() );
return MB_SUCCESS;
| void handle_error_code | ( | ErrorCode | rv, |
| int & | number_failed, | ||
| int & | number_successful | ||
Definition at line 53 of file gttool_test.cpp.
References MB_SUCCESS.
if( rv == MB_SUCCESS )
std::cout << "Success";
number_successful++;
else
std::cout << "Failure";
number_failed++;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 67 of file gttool_test.cpp.
References check_model_test(), create_shell_test(), duplicate_model_test(), ErrorCode, filename, filename2, geometrize_test(), handle_error_code(), moab::Interface::load_file(), mb, MB_SUCCESS, mbcore, number_tests_failed, number_tests_successful, ofile, ofile2, ofile3, ofile4, ofile5, remove_output_file, test_delete_obb_tree(), test_restore_obb_trees(), and test_root_sets_resize().
filename = TestDir + "unittest/partBed.smf";
filename2 = TestDir + "unittest/test_geom.h5m";
ofile = "output.h5m";
ofile2 = "shell.h5m";
ofile3 = "shellCopy.h5m";
ofile4 = "geom_w_obbs.h5m";
ofile5 = "geom_missing_obb.h5m";
remove_output_file = true;
bool only_check = false;
bool only_geometrize = false;
if( argc == 1 )
std::cout << "Using default input file and output files " << filename << " " << ofile << " " << ofile2 << " "
<< ofile3 << std::endl;
else if( argc == 5 )
filename = argv[1];
ofile = argv[2];
ofile2 = argv[3];
ofile3 = argv[4];
remove_output_file = false;
else if( argc == 2 )
ofile3 = argv[1]; // check model only from file
only_check = true;
remove_output_file = false; // this is input now, do not delete it
else if( argc == 3 )
filename = argv[1];
ofile = argv[2];
only_geometrize = true;
else
std::cerr << "Usage: " << argv[0] << " [surface_mesh] [mbgeo_file] [shellfile] [copyshellfile] " << std::endl;
return 1;
int number_tests_successful = 0;
int number_tests_failed = 0;
Core mbcore;
Interface* mb = &mbcore;
// use this as a tool to check a model
if( only_check )
if( MB_SUCCESS == check_model_test( mb ) ) std::cout << ofile3 << " passed gtt check\n";
return 0;
mb->load_file( filename.c_str() );
// FBEngine * pFacet = new FBEngine(mb, NULL, true);// smooth facetting, no OBB tree passed
std::cout << "geometrize test: ";
ErrorCode rval = geometrize_test( mb, 0 ); // just pass the root set
handle_error_code( rval, number_tests_failed, number_tests_successful );
std::cout << "\n";
if( only_geometrize )
return number_tests_failed;
std::cout << "create shell test: ";
rval = create_shell_test( mb );
std::cout << "\n";
std::cout << "duplicate model test: ";
rval = duplicate_model_test( mb );
std::cout << "\n";
std::cout << "check_model test: ";
rval = check_model_test( mb );
std::cout << "\n";
std::cout << "test_rootsets_resize: ";
Interface* mb2 = new Core();
rval = test_root_sets_resize( mb2 );
delete mb2;
std::cout << "\n";
std::cout << "test_delete_obb_tree: ";
Interface* mb3 = new Core();
rval = test_delete_obb_tree( mb3 );
delete mb3;
std::cout << "\n";
std::cout << "test_restore_obb_trees: ";
Interface* mb4 = new Core();
Interface* mb5 = new Core();
Interface* mb6 = new Core();
rval = test_restore_obb_trees( mb4, mb5, mb6 );
delete mb4;
delete mb5;
delete mb6;
std::cout << "\n";
| ErrorCode test_delete_obb_tree | ( | Interface * | mb | ) |
Definition at line 512 of file gttool_test.cpp.
References moab::Range::begin(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::delete_obb_tree(), moab::Range::end(), ErrorCode, filename2, moab::Range::front(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::GeomTopoTool::get_root(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_CHK_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, moab::OBB_ROOT_TAG_NAME, obbRootTag, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
// Load the test file
ErrorCode rval = mb->load_file( filename2.c_str() );MB_CHK_SET_ERR( rval, "Failed to load input file" );
// Create a GTT with all default settings
moab::GeomTopoTool* gTopoTool = new GeomTopoTool( mb );
// Get all volumes and surfaces
Range vols, surfs;
rval = gTopoTool->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
rval = gTopoTool->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get surface gsets" );
// Build obb tree for volume
EntityHandle test_vol = vols.front();
rval = gTopoTool->construct_obb_tree( test_vol );MB_CHK_SET_ERR( rval, "Error constructing all trees." );
// Get the obbRootTag for vol
rval = mb->tag_get_handle( OBB_ROOT_TAG_NAME, 1, MB_TYPE_HANDLE, obbRootTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create obb root tag" );
EntityHandle gbroot;
rval = mb->tag_get_data( obbRootTag, &test_vol, 1, &gbroot );MB_CHK_SET_ERR( rval, "Failed to get the obb root tag" );
// Test if obb tree in ModelSet
EntityHandle test_vol_root;
rval = gTopoTool->get_root( test_vol, test_vol_root );MB_CHK_SET_ERR( rval, "Obb root not in ModelSet" );
// CASE 1: Delete vol obb tree including all child surface trees
rval = gTopoTool->delete_obb_tree( test_vol, false );MB_CHK_SET_ERR( rval, "Error deleting volume tree." );
// Make sure vol tree is gone
EntityHandle newroot;
rval = mb->tag_get_data( obbRootTag, &test_vol, 1, &newroot );
if( MB_SUCCESS == rval )
return MB_FAILURE;
// Make sure its child surf trees also gone
Range::iterator surf_it;
for( surf_it = surfs.begin(); surf_it != surfs.end(); ++surf_it )
EntityHandle test_surf_root_gone;
rval = mb->tag_get_data( obbRootTag, &( *surf_it ), 1, &test_surf_root_gone );
return MB_FAILURE;
// Rebuild vol tree
// CASE 2: Delete just vol, not surf trees
rval = gTopoTool->delete_obb_tree( test_vol, true );MB_CHK_SET_ERR( rval, "Error deleting volume tree." );
return MB_FAILURE;
// Make sure its child surf trees remain
EntityHandle test_surf_root;
rval = mb->tag_get_data( obbRootTag, &( *surf_it ), 1, &test_surf_root );MB_CHK_SET_ERR( rval, "Problem getting obb root of surface." );
// CASE 3: Delete surf tree
EntityHandle test_surf = surfs.front();
rval = gTopoTool->delete_obb_tree( test_surf, false );MB_CHK_SET_ERR( rval, "Error deleting surface tree." );
// Make sure surf tree is gone
rval = mb->tag_get_data( obbRootTag, &test_surf, 1, &gbroot );
return MB_FAILURE;
delete gTopoTool;
return MB_SUCCESS;
| ErrorCode test_restore_obb_trees | ( | Interface * | mb, |
| Interface * | mb2, | ||
| Interface * | mb3 | ||
Definition at line 598 of file gttool_test.cpp.
References moab::Range::begin(), CHECK, moab::Range::clear(), moab::GeomTopoTool::construct_obb_trees(), moab::GeomTopoTool::delete_obb_tree(), moab::Range::end(), ErrorCode, filename2, moab::Range::front(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::GeomTopoTool::get_root(), moab::Range::insert_list(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_CHK_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, moab::OBB_ROOT_TAG_NAME, obbRootTag, ofile4, ofile5, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
// Build all obb trees
rval = gTopoTool->construct_obb_trees();MB_CHK_SET_ERR( rval, "Error constructing all trees" );
// Write the file with all obbs
rval = mb->write_file( ofile4.c_str() );MB_CHK_SET_ERR( rval, "Can't write output file" );
// Delete a vol obb tree
Range vols;
rval = gTopoTool->delete_obb_tree( test_vol, false );MB_CHK_SET_ERR( rval, "Error deleting volume tree" );
// Write the file missing an obb
rval = mb->write_file( ofile5.c_str() );MB_CHK_SET_ERR( rval, "Can't write output file" );
// Load file containing obbs
rval = mb2->load_file( ofile4.c_str() );MB_CHK_SET_ERR( rval, "Failed to load file containing obbs" );
// 1) Check that roots are NOT restored by default GTT settings
// GeomTopoTool(Interface *impl, bool find_geoments = false, EntityHandle modelRootSet = 0,
// bool p_rootSets_vector = true, bool restore_rootSets = true);
moab::GeomTopoTool* gTopoTool2 = new GeomTopoTool( mb2, false, 0, true, true );
vols.clear();
Range surfs;
rval = gTopoTool2->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
rval = gTopoTool2->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
Range gsets;
gsets.insert_list( surfs.begin(), surfs.end() );
gsets.insert_list( vols.begin(), vols.end() );
EntityHandle test_root2;
for( Range::iterator rit = gsets.begin(); rit != gsets.end(); ++rit )
rval = gTopoTool2->get_root( *rit, test_root2 );
return MB_FAILURE;
// 2) Check that roots ARE restored by setting find_geoments and restore_rootSets to true
moab::GeomTopoTool* gTopoTool3 = new GeomTopoTool( mb2, true, 0, true, true );
vols.clear();
rval = gTopoTool3->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
surfs.clear();
rval = gTopoTool3->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
gsets.clear();
EntityHandle test_root3;
rval = gTopoTool3->get_root( *rit, test_root3 );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" );
CHECK( test_root3 );
// 3) Check that roots are deleted and then rebuilt if an obb tree is missing
// Load file missing obb
rval = mb3->load_file( ofile5.c_str() );MB_CHK_SET_ERR( rval, "Failed to load file containing obbs" );
// Create GTT and try to restore OBBs
moab::GeomTopoTool* gTopoTool4 = new GeomTopoTool( mb3, true, 0, true, true );
// Check that roots still exist
vols.clear();
rval = gTopoTool4->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
surfs.clear();
rval = gTopoTool4->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
gsets.clear();
EntityHandle test_root4;
rval = gTopoTool4->get_root( *rit, test_root4 );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" );
CHECK( test_root4 );
// 4) Check that roots exist but rootSets is NOT repopulated when find_geoments = true and
// restore_rootSets = false
moab::GeomTopoTool* gTopoTool5 = new GeomTopoTool( mb2, true, 0, true, false );
rval = mb2->tag_get_handle( OBB_ROOT_TAG_NAME, 1, MB_TYPE_HANDLE, obbRootTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create obb root tag" );
vols.clear();
rval = gTopoTool5->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
surfs.clear();
rval = gTopoTool5->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" );
gsets.clear();
EntityHandle test_root5, tagged_root;
// Check that root still exits, but not in rootSet
rval = mb2->tag_get_data( obbRootTag, &( *rit ), 1, &tagged_root );MB_CHK_SET_ERR( rval, "Failed to get root from tag" );
CHECK( tagged_root );
rval = gTopoTool5->get_root( *rit, test_root5 );
if( MB_SUCCESS == rval ) return MB_FAILURE;
delete gTopoTool;
delete gTopoTool2;
delete gTopoTool3;
delete gTopoTool4;
delete gTopoTool5;
return MB_SUCCESS;
| ErrorCode test_root_sets_resize | ( | Interface * | mb | ) |
Definition at line 444 of file gttool_test.cpp.
References moab::GeomTopoTool::add_geo_set(), moab::Range::begin(), CHECK, moab::GeomTopoTool::construct_obb_tree(), moab::Interface::delete_mesh(), dim, moab::Range::end(), ErrorCode, filename2, GEOM_DIMENSION_TAG_NAME, geomTag, moab::Interface::get_entities_by_type_and_tag(), moab::GeomTopoTool::get_root(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, moab::Range::rbegin(), moab::Range::rend(), and moab::Interface::tag_get_handle().
// load the test file
// create a GTT with all default settings
Tag geomTag;
rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Error: Failed to create geometry dimension tag" );
Range surfs;
const int dim = 2;
const void* const dim_val[] = { &dim };
rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geomTag, dim_val, 1, surfs );MB_CHK_SET_ERR( rval, "Failed to get entity sets by type and tag" );
// in reverse order, add surfaces and construct their trees
for( Range::reverse_iterator rit = surfs.rbegin(); rit != surfs.rend(); rit++ )
rval = gTopoTool->add_geo_set( *rit, 2 );MB_CHK_SET_ERR( rval, "Failed to add geometry set to GTT" );
rval = gTopoTool->construct_obb_tree( *rit );MB_CHK_SET_ERR( rval, "Failed to construct obb tree for surf " << *rit );
for( Range::iterator it = surfs.begin(); it != surfs.end(); it++ )
EntityHandle obb_root_set;
rval = gTopoTool->get_root( *it, obb_root_set );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" );
// make sure the returned root is valid
CHECK( obb_root_set );
// clean up GTT
delete gTopoTool;
gTopoTool = new moab::GeomTopoTool( mb, false, 0, false );
delete gTopoTool;
rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "Failed to delete mesh in MOAB instance." );
return MB_SUCCESS;
| std::string filename |
Definition at line 27 of file gttool_test.cpp.
| std::string filename2 |
Definition at line 28 of file gttool_test.cpp.
Referenced by main(), test_delete_obb_tree(), test_restore_obb_trees(), test_root_sets_resize(), and test_set_flags().
| const char OBB_ROOT_TAG_NAME[] = "OBB_ROOT" |
Definition at line 35 of file gttool_test.cpp.
Definition at line 36 of file gttool_test.cpp.
Referenced by test_delete_obb_tree(), and test_restore_obb_trees().
| std::string ofile |
Definition at line 29 of file gttool_test.cpp.
Referenced by geometrize_test(), moab::WriteGMV::local_write_mesh(), and main().
| std::string ofile2 |
Definition at line 30 of file gttool_test.cpp.
Referenced by create_shell_test(), and main().
| std::string ofile3 |
Definition at line 31 of file gttool_test.cpp.
Referenced by check_model_test(), duplicate_model_test(), and main().
| std::string ofile4 |
Definition at line 32 of file gttool_test.cpp.
Referenced by main(), and test_restore_obb_trees().
| std::string ofile5 |
Definition at line 33 of file gttool_test.cpp.
| bool remove_output_file |
Definition at line 38 of file gttool_test.cpp.
Referenced by check_model_test(), create_shell_test(), geometrize_test(), and main().
