MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/Range.hpp" 00003 #include "TestUtil.hpp" 00004 00005 #ifdef MOAB_HAVE_MPI 00006 #include "moab_mpi.h" 00007 #endif 00008 00009 #include <algorithm> 00010 #include <iostream> 00011 #include <sstream> 00012 #include <cstdlib> 00013 #include <cmath> 00014 00015 using namespace moab; 00016 00017 const char filename[] = "sets.h5m"; 00018 bool keep_file = false; 00019 00020 void read_write_file( Interface& output, Interface& input, EntityHandle* input_set = 0 ) 00021 { 00022 ErrorCode rval; 00023 rval = output.write_file( filename, 0, "DEBUG_BINIO" );CHECK_ERR( rval ); 00024 if( input_set ) 00025 { 00026 rval = input.create_meshset( MESHSET_SET, *input_set );CHECK_ERR( rval ); 00027 } 00028 rval = input.load_file( filename, input_set ); 00029 if( !keep_file ) remove( filename );CHECK_ERR( rval ); 00030 } 00031 00032 void test_ranged_set_with_stale_handles() 00033 { 00034 Core moab; 00035 Interface& mb = moab; 00036 ErrorCode rval; 00037 Range verts; 00038 00039 const int num_vtx = 40; 00040 std::vector< double > coords( 3 * num_vtx, 0.0 ); 00041 rval = mb.create_vertices( &coords[0], num_vtx, verts );CHECK_ERR( rval ); 00042 CHECK_EQUAL( num_vtx, (int)verts.size() ); 00043 00044 EntityHandle set; 00045 rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00046 rval = mb.add_entities( set, verts );CHECK_ERR( rval ); 00047 00048 std::vector< EntityHandle > dead_verts; 00049 for( int i = num_vtx / 4; i < num_vtx; i += num_vtx / 4 ) 00050 { 00051 Range::iterator j = verts.begin(); 00052 j += i; 00053 dead_verts.push_back( *j ); 00054 } 00055 rval = mb.delete_entities( &dead_verts[0], dead_verts.size() );CHECK_ERR( rval ); 00056 00057 Core moab2; 00058 Interface& mb2 = moab2; 00059 EntityHandle file_set; 00060 read_write_file( mb, mb2, &file_set ); 00061 Range sets; 00062 rval = mb2.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); 00063 CHECK_EQUAL( 2, (int)sets.size() ); 00064 EntityHandle other_set = sets.front() == file_set ? sets.back() : sets.front(); 00065 00066 int num_vtx2 = -5; 00067 rval = mb2.get_number_entities_by_type( other_set, MBVERTEX, num_vtx2 );CHECK_ERR( rval ); 00068 CHECK_EQUAL( (int)( num_vtx - dead_verts.size() ), num_vtx2 ); 00069 } 00070 00071 void test_list_set_with_stale_handles() 00072 { 00073 Core moab; 00074 Interface& mb = moab; 00075 ErrorCode rval; 00076 Range verts; 00077 00078 const int num_vtx = 40; 00079 std::vector< double > coords( 3 * num_vtx, 0.0 ); 00080 rval = mb.create_vertices( &coords[0], num_vtx, verts );CHECK_ERR( rval ); 00081 CHECK_EQUAL( num_vtx, (int)verts.size() ); 00082 00083 EntityHandle set; 00084 rval = mb.create_meshset( MESHSET_ORDERED, set );CHECK_ERR( rval ); 00085 rval = mb.add_entities( set, verts );CHECK_ERR( rval ); 00086 00087 std::vector< EntityHandle > dead_verts; 00088 for( int i = num_vtx / 4; i < num_vtx; i += num_vtx / 4 ) 00089 { 00090 Range::iterator j = verts.begin(); 00091 j += i; 00092 dead_verts.push_back( *j ); 00093 } 00094 rval = mb.delete_entities( &dead_verts[0], dead_verts.size() );CHECK_ERR( rval ); 00095 00096 Core moab2; 00097 Interface& mb2 = moab2; 00098 EntityHandle file_set; 00099 read_write_file( mb, mb2, &file_set ); 00100 Range sets; 00101 rval = mb2.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); 00102 CHECK_EQUAL( 2, (int)sets.size() ); 00103 EntityHandle other_set = sets.front() == file_set ? sets.back() : sets.front(); 00104 00105 std::vector< EntityHandle > list; 00106 rval = mb2.get_entities_by_handle( other_set, list );CHECK_ERR( rval ); 00107 CHECK_EQUAL( verts.size() - dead_verts.size(), list.size() ); 00108 } 00109 00110 void test_file_set() 00111 { 00112 ErrorCode rval; 00113 Core moab; 00114 double vtxcoords[] = { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0, 0.0 }; 00115 Range verts; 00116 rval = moab.create_vertices( vtxcoords, 3, verts );CHECK_ERR( rval ); 00117 CHECK_EQUAL( 3, (int)verts.size() ); 00118 00119 EntityHandle tri; 00120 EntityHandle conn[3]; 00121 std::copy( verts.begin(), verts.end(), conn ); 00122 rval = moab.create_element( MBTRI, conn, 3, tri );CHECK_ERR( rval ); 00123 00124 EntityHandle set; 00125 rval = moab.create_meshset( MESHSET_ORDERED, set );CHECK_ERR( rval ); 00126 rval = moab.add_entities( set, &tri, 1 );CHECK_ERR( rval ); 00127 00128 EntityHandle file; 00129 read_write_file( moab, moab, &file ); 00130 00131 int count; 00132 rval = moab.get_number_entities_by_type( 0, MBVERTEX, count );CHECK_ERR( rval ); 00133 CHECK_EQUAL( 6, count ); 00134 rval = moab.get_number_entities_by_type( file, MBVERTEX, count );CHECK_ERR( rval ); 00135 CHECK_EQUAL( 3, count ); 00136 00137 rval = moab.get_number_entities_by_type( 0, MBTRI, count );CHECK_ERR( rval ); 00138 CHECK_EQUAL( 2, count ); 00139 rval = moab.get_number_entities_by_type( file, MBTRI, count );CHECK_ERR( rval ); 00140 CHECK_EQUAL( 1, count ); 00141 00142 rval = moab.get_number_entities_by_type( 0, MBENTITYSET, count );CHECK_ERR( rval ); 00143 CHECK_EQUAL( 3, count ); 00144 rval = moab.get_number_entities_by_type( file, MBENTITYSET, count );CHECK_ERR( rval ); 00145 CHECK_EQUAL( 1, count ); 00146 } 00147 00148 void test_sets_fileids() 00149 { 00150 ErrorCode rval; 00151 Core moab; 00152 double vtxcoords[] = { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0, 0.0 }; 00153 Range verts; 00154 rval = moab.create_vertices( vtxcoords, 3, verts );CHECK_ERR( rval ); 00155 CHECK_EQUAL( 3, (int)verts.size() ); 00156 00157 EntityHandle tri; 00158 EntityHandle conn[3]; 00159 std::copy( verts.begin(), verts.end(), conn ); 00160 rval = moab.create_element( MBTRI, conn, 3, tri );CHECK_ERR( rval ); 00161 00162 EntityHandle set; 00163 rval = moab.create_meshset( MESHSET_ORDERED, set );CHECK_ERR( rval ); 00164 rval = moab.add_entities( set, &tri, 1 );CHECK_ERR( rval ); 00165 00166 rval = moab.write_file( filename );CHECK_ERR( rval ); 00167 00168 moab.delete_mesh(); 00169 00170 rval = moab.load_file( filename, 0, "STORE_SETS_FILEIDS;" );CHECK_ERR( rval ); 00171 00172 Tag setFileIdTag; 00173 00174 rval = moab.tag_get_handle( "__FILE_ID_FOR_SETS", setFileIdTag );CHECK_ERR( rval ); 00175 CHECK( setFileIdTag ); 00176 00177 Range sets; 00178 rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); 00179 00180 std::vector< long > vals( sets.size() ); 00181 rval = moab.tag_get_data( setFileIdTag, sets, &vals[0] );CHECK_ERR( rval ); 00182 00183 CHECK_EQUAL( 5, (int)vals[0] ); 00184 if( !keep_file ) remove( filename ); 00185 00186 return; 00187 } 00188 00189 int coords_by_idx( int idx, double coords[][3] ) 00190 { 00191 coords[0][0] = idx; 00192 coords[0][1] = 0; 00193 coords[0][2] = 0; 00194 coords[1][0] = 0; 00195 coords[1][1] = idx; 00196 coords[1][2] = 0; 00197 coords[2][0] = 0; 00198 coords[2][1] = 0; 00199 coords[2][2] = idx; 00200 coords[3][0] = 3.14 * idx; 00201 coords[3][1] = 1; 00202 coords[3][2] = 1; 00203 coords[4][0] = 1; 00204 coords[4][1] = 3.14 * idx; 00205 coords[4][2] = 1; 00206 coords[5][0] = 1; 00207 coords[5][1] = 1; 00208 coords[5][2] = 3.14 * idx; 00209 return idx % 5 + 1; 00210 } 00211 00212 void recursive_build_tree( int max_depth, Interface& mb, Tag tag, EntityHandle p, int depth, int& idx ) 00213 { 00214 ErrorCode rval = mb.tag_set_data( tag, &p, 1, &idx );CHECK_ERR( rval ); 00215 00216 Range verts; 00217 double coords[6][3]; 00218 int num_vtx = coords_by_idx( idx, coords ); 00219 rval = mb.create_vertices( &coords[0][0], num_vtx, verts ); 00220 rval = mb.add_entities( p, verts ); 00221 ++idx; 00222 if( depth == max_depth ) return; 00223 00224 EntityHandle l, r; 00225 rval = mb.create_meshset( MESHSET_SET, l );CHECK_ERR( rval ); 00226 rval = mb.create_meshset( MESHSET_SET, r );CHECK_ERR( rval ); 00227 rval = mb.add_parent_child( p, l );CHECK_ERR( rval ); 00228 rval = mb.add_parent_child( p, r );CHECK_ERR( rval ); 00229 00230 recursive_build_tree( max_depth, mb, tag, l, depth + 1, idx ); 00231 recursive_build_tree( max_depth, mb, tag, r, depth + 1, idx ); 00232 } 00233 00234 void recursive_check_tree( int max_depth, Interface& mb, Tag tag, EntityHandle p, int depth, int& idx ) 00235 { 00236 int id; 00237 ErrorCode rval = mb.tag_get_data( tag, &p, 1, &id );CHECK_ERR( rval ); 00238 CHECK_EQUAL( idx, id ); 00239 00240 Range verts; 00241 double coords[6][3]; 00242 int num_vtx = coords_by_idx( idx, coords ); 00243 rval = mb.get_entities_by_handle( p, verts ); 00244 CHECK( verts.all_of_type( MBVERTEX ) ); 00245 CHECK_EQUAL( num_vtx, (int)verts.size() ); 00246 double coords2[6][3]; 00247 rval = mb.get_coords( verts, &coords2[0][0] ); 00248 std::vector< bool > match( 6, true ); 00249 for( int i = 0; i < num_vtx; ++i ) 00250 { 00251 match[i] = false; 00252 for( int j = 0; j < num_vtx; ++j ) 00253 { 00254 if( !match[j] ) 00255 { 00256 double d[3] = { coords[i][0] - coords2[j][0], coords[i][1] - coords2[j][1], 00257 coords[i][2] - coords2[j][2] }; 00258 double ds = d[0] * d[0] + d[1] * d[1] + d[2] * d[2]; 00259 if( ds < 1e-12 ) 00260 { 00261 match[j] = true; 00262 break; 00263 } 00264 } 00265 } 00266 } 00267 CHECK( match[0] ); 00268 CHECK( match[1] ); 00269 CHECK( match[2] ); 00270 CHECK( match[3] ); 00271 CHECK( match[4] ); 00272 CHECK( match[5] ); 00273 00274 ++idx; 00275 00276 std::vector< EntityHandle > children, parents; 00277 00278 rval = mb.get_child_meshsets( p, children );CHECK_ERR( rval ); 00279 if( depth == max_depth ) 00280 { 00281 CHECK_EQUAL( (size_t)0, children.size() ); 00282 return; 00283 } 00284 00285 CHECK_EQUAL( (size_t)2, children.size() ); 00286 EntityHandle l = children.front(); 00287 EntityHandle r = children.back(); 00288 00289 parents.clear(); 00290 rval = mb.get_parent_meshsets( l, parents );CHECK_ERR( rval ); 00291 CHECK_EQUAL( (size_t)1, parents.size() ); 00292 CHECK_EQUAL( p, parents.front() ); 00293 parents.clear(); 00294 rval = mb.get_parent_meshsets( r, parents );CHECK_ERR( rval ); 00295 CHECK_EQUAL( (size_t)1, parents.size() ); 00296 CHECK_EQUAL( p, parents.front() ); 00297 00298 recursive_check_tree( max_depth, mb, tag, l, depth + 1, idx ); 00299 recursive_check_tree( max_depth, mb, tag, r, depth + 1, idx ); 00300 } 00301 00302 void test_tree( int max_depth ) 00303 { 00304 ErrorCode rval; 00305 Core moab; 00306 Interface& mb = moab; 00307 EntityHandle root; 00308 00309 // create tag in which to store number for each tree node, 00310 // in depth-first in-order search order. 00311 Tag tag; 00312 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 00313 00314 // create a binary tree to a depth of 20 (about 1 million nodes) 00315 rval = mb.create_meshset( MESHSET_SET, root );CHECK_ERR( rval ); 00316 int idx = 1; 00317 recursive_build_tree( max_depth, mb, tag, root, 1, idx ); 00318 const int last_idx = idx; 00319 std::cerr << "Created binary tree containing " << last_idx << " nodes." << std::endl; 00320 00321 std::ostringstream str; 00322 str << "tree-" << max_depth << ".h5m"; 00323 00324 // write file and read back in 00325 rval = mb.write_file( str.str().c_str(), 0, "BUFFER_SIZE=1024;DEBUG_BINIO" );CHECK_ERR( rval ); 00326 mb.delete_mesh(); 00327 rval = mb.load_file( str.str().c_str() ); 00328 if( !keep_file ) remove( str.str().c_str() );CHECK_ERR( rval ); 00329 00330 // get tree root 00331 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 00332 Range roots; 00333 idx = 1; 00334 const void* vals[] = { &idx }; 00335 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, vals, 1, roots ); 00336 CHECK_EQUAL( (size_t)1, roots.size() ); 00337 root = roots.front(); 00338 00339 // check that tree is as we expect it 00340 idx = 1; 00341 recursive_check_tree( max_depth, mb, tag, root, 1, idx ); 00342 CHECK_EQUAL( last_idx, idx ); 00343 } 00344 00345 void test_small_tree() 00346 { 00347 int max_depth = 8; 00348 const char* str = getenv( "MAX_DEPTH" ); 00349 if( str ) 00350 { 00351 max_depth = atoi( str ); 00352 CHECK( max_depth > 0 ); 00353 } 00354 test_tree( max_depth ); 00355 } 00356 00357 void test_big_tree() 00358 { 00359 test_tree( 20 ); 00360 } 00361 00362 void regression_mmiller_8_2010(); 00363 00364 void test_set_flags(); 00365 00366 int main( int argc, char* argv[] ) 00367 { 00368 #ifdef MOAB_HAVE_MPI 00369 int fail = MPI_Init( &argc, &argv ); 00370 if( fail ) return fail; 00371 #endif 00372 00373 bool do_big_tree_test = false; 00374 for( int i = 1; i < argc; ++i ) 00375 { 00376 if( std::string( argv[i] ) == "-k" ) 00377 keep_file = true; 00378 else if( std::string( argv[i] ) == "-b" ) 00379 do_big_tree_test = true; 00380 else 00381 { 00382 std::cerr << "Usage: " << argv[0] << " [-k] [-b]" << std::endl; 00383 return 1; 00384 } 00385 } 00386 00387 int exitval = 0; 00388 exitval += RUN_TEST( test_ranged_set_with_stale_handles ); 00389 exitval += RUN_TEST( test_list_set_with_stale_handles ); 00390 exitval += RUN_TEST( test_file_set ); 00391 exitval += RUN_TEST( test_small_tree ); 00392 exitval += RUN_TEST( test_set_flags ); 00393 exitval += RUN_TEST( regression_mmiller_8_2010 ); 00394 exitval += RUN_TEST( test_sets_fileids ); 00395 if( do_big_tree_test ) 00396 { 00397 exitval += RUN_TEST( test_big_tree ); 00398 } 00399 00400 #ifdef MOAB_HAVE_MPI 00401 fail = MPI_Finalize(); 00402 if( fail ) return fail; 00403 #endif 00404 00405 return exitval; 00406 } 00407 00408 // NOTE: this test makes some assuptions about handles: 00409 // mainly that they will be assigned sequentially 00410 // in the same order as defined in the file and 00411 // beginning with ID 1 00412 void regression_mmiller_8_2010() 00413 { 00414 Core moab; 00415 Interface& mb = moab; 00416 00417 const size_t num_vtx = 171; 00418 const size_t num_pri = 12; 00419 const size_t num_pyr = 8; 00420 const size_t num_hex = 100; 00421 const size_t num_set = 25; 00422 00423 mb.load_file( std::string( TestDir + "unittest/h5file/rocket_ents_in_assm.h5m" ).c_str() ); 00424 00425 /* Dump of set contents from input file: 00426 1r: 172, 4, 00427 2r: 192, 4, 204, 4, 216, 4, 228, 4, 240, 4, 252, 4, 264, 4, 276, 4, 00428 3r: 288, 4, 00429 4 : 181, 183, 185, 187, 00430 5r: 176, 5, 182, 1, 184, 1, 186, 1, 188, 4, 196, 8, 208, 8, 220, 8, 232, 8, 244, 8, 256, 8, 00431 268, 8, 280, 8, 6r: 172, 4, 192, 4, 204, 4, 216, 4, 228, 4, 240, 4, 252, 4, 264, 4, 276, 4, 288, 00432 4, 7r: 176, 4, 188, 4, 196, 8, 208, 8, 220, 8, 232, 8, 244, 8, 8r: 180, 8, 256, 8, 268, 8, 280, 00433 8, 9r: 172, 120, 301, 1, 309, 1, 10r: 176, 4, 188, 100, 302, 1, 308, 1, 11r: 176, 4, 188, 52, 00434 303, 1, 12r: 176, 4, 188, 4, 304, 4, 13 : 177, 189, 14 : 178, 190, 15 : 179, 191, 16 : 17r: 240, 00435 48, 18r: 172, 4, 180, 8, 288, 4, 310, 1, 312, 1, 19r: 180, 8, 288, 4, 311, 1, 20r: 180, 8, 21r: 00436 172, 4, 313, 4, 22 : 173, 23 : 174, 24 : 175, 25 : 176, 188 00437 */ 00438 00439 // check expected handles 00440 00441 const EntityHandle VTX1 = CREATE_HANDLE( MBVERTEX, 1 ); 00442 Range range, expected; 00443 mb.get_entities_by_type( 0, MBVERTEX, range ); 00444 CHECK_EQUAL( num_vtx, range.size() ); 00445 expected.insert( VTX1, VTX1 + num_vtx - 1 ); 00446 CHECK_EQUAL( expected, range ); 00447 00448 const EntityHandle PRI1 = CREATE_HANDLE( MBPRISM, 1 ); 00449 range.clear(); 00450 expected.clear(); 00451 mb.get_entities_by_type( 0, MBPRISM, range ); 00452 CHECK_EQUAL( num_pri, range.size() ); 00453 expected.insert( PRI1, PRI1 + num_pri - 1 ); 00454 CHECK_EQUAL( expected, range ); 00455 00456 const EntityHandle PYR1 = CREATE_HANDLE( MBPYRAMID, 1 ); 00457 range.clear(); 00458 expected.clear(); 00459 mb.get_entities_by_type( 0, MBPYRAMID, range ); 00460 CHECK_EQUAL( num_pyr, range.size() ); 00461 expected.insert( PYR1, PYR1 + num_pyr - 1 ); 00462 CHECK_EQUAL( expected, range ); 00463 00464 const EntityHandle HEX1 = CREATE_HANDLE( MBHEX, 1 ); 00465 range.clear(); 00466 expected.clear(); 00467 mb.get_entities_by_type( 0, MBHEX, range ); 00468 CHECK_EQUAL( num_hex, range.size() ); 00469 expected.insert( HEX1, HEX1 + num_hex - 1 ); 00470 CHECK_EQUAL( expected, range ); 00471 00472 const EntityHandle SET1 = CREATE_HANDLE( MBENTITYSET, 1 ); 00473 range.clear(); 00474 expected.clear(); 00475 mb.get_entities_by_type( 0, MBENTITYSET, range ); 00476 CHECK_EQUAL( num_set, range.size() ); 00477 expected.insert( SET1, SET1 + num_set - 1 ); 00478 CHECK_EQUAL( expected, range ); 00479 00480 // Check set contents 00481 00482 // Set 1: Pyramids 1 to 4 00483 range.clear(); 00484 mb.get_entities_by_handle( SET1, range ); 00485 expected.clear(); 00486 expected.insert( PYR1 + 0, PYR1 + 3 ); 00487 CHECK_EQUAL( expected, range ); 00488 00489 // Skip sets 2 through 8 because they're long and complicated and 00490 // I doubt I could code up the content lists explicitly from the 00491 // dump of the HDF5 file w/out many mistakes 00492 00493 // Set 9: Pyramids 1 to 8, Prism 1 to 12, Hex 1 to 100, and Sets 10 and 18 00494 range.clear(); 00495 mb.get_entities_by_handle( SET1 + 8, range ); 00496 expected.clear(); 00497 expected.insert( PYR1 + 0, PYR1 + 7 ); 00498 expected.insert( PRI1 + 0, PRI1 + 11 ); 00499 expected.insert( HEX1 + 0, HEX1 + 99 ); 00500 expected.insert( SET1 + 9 ); 00501 expected.insert( SET1 + 17 ); 00502 CHECK_EQUAL( expected, range ); 00503 00504 // Set 10: Pyramids 5 to 8, Prism 9 to 12, Hex 1 to 96, and Sets 11 and 17 00505 range.clear(); 00506 mb.get_entities_by_handle( SET1 + 9, range ); 00507 expected.clear(); 00508 expected.insert( PYR1 + 4, PYR1 + 7 ); 00509 expected.insert( PRI1 + 8, PRI1 + 11 ); 00510 expected.insert( HEX1 + 0, HEX1 + 95 ); 00511 expected.insert( SET1 + 10 ); 00512 expected.insert( SET1 + 16 ); 00513 CHECK_EQUAL( expected, range ); 00514 00515 // Set 11: Pyramids 5 to 8, Prism 9 to 12, Hex 1 to 48, and Set 12 00516 range.clear(); 00517 mb.get_entities_by_handle( SET1 + 10, range ); 00518 expected.clear(); 00519 expected.insert( PYR1 + 4, PYR1 + 7 ); 00520 expected.insert( PRI1 + 8, PRI1 + 11 ); 00521 expected.insert( HEX1 + 0, HEX1 + 47 ); 00522 expected.insert( SET1 + 11 ); 00523 CHECK_EQUAL( expected, range ); 00524 00525 // Set 12: Pyramids 5 to 8, Prism 9 to 12, and Sets 13 to 16 00526 range.clear(); 00527 mb.get_entities_by_handle( SET1 + 11, range ); 00528 expected.clear(); 00529 expected.insert( PYR1 + 4, PYR1 + 7 ); 00530 expected.insert( PRI1 + 8, PRI1 + 11 ); 00531 expected.insert( SET1 + 12, SET1 + 15 ); 00532 CHECK_EQUAL( expected, range ); 00533 00534 // Set 13: Pyramids 6 and Prism 10 00535 range.clear(); 00536 mb.get_entities_by_handle( SET1 + 12, range ); 00537 expected.clear(); 00538 expected.insert( PYR1 + 5 ); 00539 expected.insert( PRI1 + 9 ); 00540 CHECK_EQUAL( expected, range ); 00541 00542 // Set 14: Pyramids 7 and Prism 11 00543 range.clear(); 00544 mb.get_entities_by_handle( SET1 + 13, range ); 00545 expected.clear(); 00546 expected.insert( PYR1 + 6 ); 00547 expected.insert( PRI1 + 10 ); 00548 CHECK_EQUAL( expected, range ); 00549 00550 // Set 15: Pyramids 8 and Prism 12 00551 range.clear(); 00552 mb.get_entities_by_handle( SET1 + 14, range ); 00553 expected.clear(); 00554 expected.insert( PYR1 + 7 ); 00555 expected.insert( PRI1 + 11 ); 00556 CHECK_EQUAL( expected, range ); 00557 00558 // Set 16: Empty 00559 range.clear(); 00560 mb.get_entities_by_handle( SET1 + 15, range ); 00561 expected.clear(); 00562 CHECK_EQUAL( expected, range ); 00563 00564 // Set 17: Hex 49 to 96 00565 range.clear(); 00566 mb.get_entities_by_handle( SET1 + 16, range ); 00567 expected.clear(); 00568 expected.insert( HEX1 + 48, HEX1 + 95 ); 00569 CHECK_EQUAL( expected, range ); 00570 00571 // Set 18: Pyramids 1 to 4, Prism 1 to 8, Hex 97 to 100, and Sets 19 and 21 00572 range.clear(); 00573 mb.get_entities_by_handle( SET1 + 17, range ); 00574 expected.clear(); 00575 expected.insert( PYR1 + 0, PYR1 + 3 ); 00576 expected.insert( PRI1 + 0, PRI1 + 7 ); 00577 expected.insert( HEX1 + 96, HEX1 + 99 ); 00578 expected.insert( SET1 + 18 ); 00579 expected.insert( SET1 + 20 ); 00580 CHECK_EQUAL( expected, range ); 00581 00582 // Set 19: Prism 1 to 8, Hex 97 to 100, and Set 20 00583 range.clear(); 00584 mb.get_entities_by_handle( SET1 + 18, range ); 00585 expected.clear(); 00586 expected.insert( PRI1 + 0, PRI1 + 7 ); 00587 expected.insert( HEX1 + 96, HEX1 + 99 ); 00588 expected.insert( SET1 + 19 ); 00589 CHECK_EQUAL( expected, range ); 00590 00591 // Set 20: Prism 1 to 8 00592 range.clear(); 00593 mb.get_entities_by_handle( SET1 + 19, range ); 00594 expected.clear(); 00595 expected.insert( PRI1 + 0, PRI1 + 7 ); 00596 CHECK_EQUAL( expected, range ); 00597 00598 // Set 21: Pyramids 1 to 4, and Sets 22 to 25 00599 range.clear(); 00600 mb.get_entities_by_handle( SET1 + 20, range ); 00601 expected.clear(); 00602 expected.insert( PYR1 + 0, PYR1 + 3 ); 00603 expected.insert( SET1 + 21, SET1 + 24 ); 00604 CHECK_EQUAL( expected, range ); 00605 00606 // Set 22: Pyramid 2 00607 range.clear(); 00608 mb.get_entities_by_handle( SET1 + 21, range ); 00609 expected.clear(); 00610 expected.insert( PYR1 + 1 ); 00611 CHECK_EQUAL( expected, range ); 00612 00613 // Set 23: Pyramid 3 00614 range.clear(); 00615 mb.get_entities_by_handle( SET1 + 22, range ); 00616 expected.clear(); 00617 expected.insert( PYR1 + 2 ); 00618 CHECK_EQUAL( expected, range ); 00619 00620 // Set 24: Pyramid 4 00621 range.clear(); 00622 mb.get_entities_by_handle( SET1 + 23, range ); 00623 expected.clear(); 00624 expected.insert( PYR1 + 3 ); 00625 CHECK_EQUAL( expected, range ); 00626 00627 // Set 25: Pyramid 5 and Prism 9 00628 range.clear(); 00629 mb.get_entities_by_handle( SET1 + 24, range ); 00630 expected.clear(); 00631 expected.insert( PYR1 + 4 ); 00632 expected.insert( PRI1 + 8 ); 00633 CHECK_EQUAL( expected, range ); 00634 } 00635 00636 // Test to reproduce bug reported by brandom smith on 2011-3-7 00637 // and test other possible issues with the somewhat inconsistant 00638 // meshset creation flags. Bug was fixed in SVN revision 4548. 00639 void test_set_flags() 00640 { 00641 const char filename2[] = "test_set_flags.h5m"; 00642 ErrorCode rval; 00643 Core core; 00644 Interface& mb = core; 00645 00646 // create a bunch of vertices so we have something to put in sets 00647 const int nverts = 20; 00648 double coords[3 * nverts] = { 0.0 }; 00649 Range verts; 00650 rval = mb.create_vertices( coords, nverts, verts );CHECK_ERR( rval ); 00651 00652 // Assign IDs to things so that we can identify them in the 00653 // data we read back in. 00654 Tag tag; 00655 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 00656 int ids[nverts]; 00657 for( int i = 0; i < nverts; ++i ) 00658 ids[i] = i + 1; 00659 rval = mb.tag_set_data( tag, verts, ids );CHECK_ERR( rval ); 00660 00661 // define two lists of vertex ids corresponding to the 00662 // vertices that we are going to put into different sets 00663 const int set_verts1[] = { 1, 2, 3, 4, 8, 13, 14, 15 }; 00664 const int set_verts2[] = { 3, 9, 10, 11, 12, 13, 14, 15, 16, 17 }; 00665 const int num_verts1 = sizeof( set_verts1 ) / sizeof( set_verts1[0] ); 00666 const int num_verts2 = sizeof( set_verts1 ) / sizeof( set_verts1[0] ); 00667 00668 // convert to handle lists 00669 EntityHandle set_handles1[num_verts1], set_handles2[num_verts2]; 00670 for( int i = 0; i < num_verts1; ++i ) 00671 set_handles1[i] = *( verts.begin() + set_verts1[i] - 1 ); 00672 for( int i = 0; i < num_verts2; ++i ) 00673 set_handles2[i] = *( verts.begin() + set_verts2[i] - 1 ); 00674 00675 // now create some sets with different flag combinations 00676 EntityHandle sets[6]; 00677 rval = mb.create_meshset( 0, sets[0] ); 00678 rval = mb.create_meshset( MESHSET_TRACK_OWNER, sets[1] ); 00679 rval = mb.create_meshset( MESHSET_SET, sets[2] ); 00680 rval = mb.create_meshset( MESHSET_SET | MESHSET_TRACK_OWNER, sets[3] ); 00681 rval = mb.create_meshset( MESHSET_ORDERED, sets[4] ); 00682 rval = mb.create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, sets[5] ); 00683 00684 // assign IDs to sets so that we can identify them later 00685 rval = mb.tag_set_data( tag, sets, 6, ids );CHECK_ERR( rval ); 00686 // add entities to sets 00687 rval = mb.add_entities( sets[0], set_handles1, num_verts1 );CHECK_ERR( rval ); 00688 rval = mb.add_entities( sets[1], set_handles2, num_verts2 );CHECK_ERR( rval ); 00689 rval = mb.add_entities( sets[2], set_handles1, num_verts1 );CHECK_ERR( rval ); 00690 rval = mb.add_entities( sets[3], set_handles2, num_verts2 );CHECK_ERR( rval ); 00691 rval = mb.add_entities( sets[4], set_handles1, num_verts1 );CHECK_ERR( rval ); 00692 rval = mb.add_entities( sets[5], set_handles2, num_verts2 );CHECK_ERR( rval ); 00693 00694 // now write the file and read it back in 00695 rval = mb.write_file( filename2, 0, "BUFFER_SIZE=1024;DEBUG_BINIO" );CHECK_ERR( rval ); 00696 mb.delete_mesh(); 00697 rval = mb.load_file( filename2 ); 00698 if( !keep_file ) remove( filename2 );CHECK_ERR( rval ); 00699 rval = mb.tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 00700 00701 // find our sets 00702 Range tmp; 00703 for( int i = 0; i < 6; ++i ) 00704 { 00705 int id = i + 1; 00706 tmp.clear(); 00707 const void* vals[] = { &id }; 00708 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, vals, 1, tmp );CHECK_ERR( rval ); 00709 CHECK_EQUAL( 1u, (unsigned)tmp.size() ); 00710 sets[i] = tmp.front(); 00711 } 00712 00713 // check that sets have correct flags 00714 unsigned opts; 00715 rval = mb.get_meshset_options( sets[0], opts );CHECK_ERR( rval ); 00716 CHECK_EQUAL( 0u, opts ); 00717 rval = mb.get_meshset_options( sets[1], opts );CHECK_ERR( rval ); 00718 CHECK_EQUAL( (unsigned)MESHSET_TRACK_OWNER, opts ); 00719 rval = mb.get_meshset_options( sets[2], opts );CHECK_ERR( rval ); 00720 CHECK_EQUAL( (unsigned)MESHSET_SET, opts ); 00721 rval = mb.get_meshset_options( sets[3], opts );CHECK_ERR( rval ); 00722 CHECK_EQUAL( (unsigned)( MESHSET_SET | MESHSET_TRACK_OWNER ), opts ); 00723 rval = mb.get_meshset_options( sets[4], opts );CHECK_ERR( rval ); 00724 CHECK_EQUAL( (unsigned)MESHSET_ORDERED, opts ); 00725 rval = mb.get_meshset_options( sets[5], opts );CHECK_ERR( rval ); 00726 CHECK_EQUAL( (unsigned)( MESHSET_ORDERED | MESHSET_TRACK_OWNER ), opts ); 00727 00728 // check that sets have correct contents 00729 int set_ids1[num_verts1], set_ids2[num_verts2]; 00730 00731 tmp.clear(); 00732 rval = mb.get_entities_by_handle( sets[0], tmp );CHECK_ERR( rval ); 00733 CHECK_EQUAL( num_verts1, (int)tmp.size() ); 00734 rval = mb.tag_get_data( tag, tmp, set_ids1 );CHECK_ERR( rval ); 00735 std::sort( set_ids1, set_ids1 + num_verts1 ); 00736 CHECK_ARRAYS_EQUAL( set_verts1, num_verts1, set_ids1, num_verts1 ); 00737 00738 tmp.clear(); 00739 rval = mb.get_entities_by_handle( sets[1], tmp );CHECK_ERR( rval ); 00740 CHECK_EQUAL( num_verts2, (int)tmp.size() ); 00741 rval = mb.tag_get_data( tag, tmp, set_ids2 );CHECK_ERR( rval ); 00742 std::sort( set_ids2, set_ids2 + num_verts2 ); 00743 CHECK_ARRAYS_EQUAL( set_verts2, num_verts2, set_ids2, num_verts2 ); 00744 00745 tmp.clear(); 00746 rval = mb.get_entities_by_handle( sets[2], tmp );CHECK_ERR( rval ); 00747 CHECK_EQUAL( num_verts1, (int)tmp.size() ); 00748 rval = mb.tag_get_data( tag, tmp, set_ids1 );CHECK_ERR( rval ); 00749 std::sort( set_ids1, set_ids1 + num_verts1 ); 00750 CHECK_ARRAYS_EQUAL( set_verts1, num_verts1, set_ids1, num_verts1 ); 00751 00752 tmp.clear(); 00753 rval = mb.get_entities_by_handle( sets[3], tmp );CHECK_ERR( rval ); 00754 CHECK_EQUAL( num_verts2, (int)tmp.size() ); 00755 rval = mb.tag_get_data( tag, tmp, set_ids2 );CHECK_ERR( rval ); 00756 std::sort( set_ids2, set_ids2 + num_verts2 ); 00757 CHECK_ARRAYS_EQUAL( set_verts2, num_verts2, set_ids2, num_verts2 ); 00758 00759 tmp.clear(); 00760 rval = mb.get_entities_by_handle( sets[4], tmp );CHECK_ERR( rval ); 00761 CHECK_EQUAL( num_verts1, (int)tmp.size() ); 00762 rval = mb.tag_get_data( tag, tmp, set_ids1 );CHECK_ERR( rval ); 00763 std::sort( set_ids1, set_ids1 + num_verts1 ); 00764 CHECK_ARRAYS_EQUAL( set_verts1, num_verts1, set_ids1, num_verts1 ); 00765 00766 tmp.clear(); 00767 rval = mb.get_entities_by_handle( sets[5], tmp );CHECK_ERR( rval ); 00768 CHECK_EQUAL( num_verts2, (int)tmp.size() ); 00769 rval = mb.tag_get_data( tag, tmp, set_ids2 );CHECK_ERR( rval ); 00770 std::sort( set_ids2, set_ids2 + num_verts2 ); 00771 CHECK_ARRAYS_EQUAL( set_verts2, num_verts2, set_ids2, num_verts2 ); 00772 }
