MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Interface.hpp" 00003 #ifndef IS_BUILDING_MB 00004 #define IS_BUILDING_MB 00005 #endif 00006 #include "TestUtil.hpp" 00007 #include "Internals.hpp" 00008 #include "moab/Core.hpp" 00009 #include "MBTagConventions.hpp" 00010 #include "moab/GeomTopoTool.hpp" 00011 #include "InitCGMA.hpp" 00012 #include "GeometryQueryTool.hpp" 00013 #include "CGMConfig.h" 00014 00015 #define SENSE_FORWARD 1 00016 #define SENSE_REVERSE ( -1 ) 00017 #define SENSE_UNKNOWN 0 00018 using namespace moab; 00019 00020 #define CHKERR( A ) \ 00021 do \ 00022 { \ 00023 if( MB_SUCCESS != ( A ) ) \ 00024 { \ 00025 std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ 00026 return A; \ 00027 } \ 00028 } while( false ) 00029 00030 #ifdef HAVE_OCC_STEP 00031 std::string input_cylcube = TestDir + "unittest/io/cylcube.stp"; 00032 #else 00033 std::string input_cylcube = TestDir + "unittest/io/cylcube.sat"; 00034 #endif 00035 00036 // Function used to load the test file 00037 void read_file( Interface* moab, const char* input_file ); 00038 00039 // Functions containing known sense data 00040 ErrorCode load_sat_curve_sense_data( Interface* moab, 00041 EntityHandle curve, 00042 std::vector< int >& surf_ids_out, 00043 std::vector< int >& senses_out ); 00044 ErrorCode load_stp_curve_sense_data( Interface* moab, 00045 EntityHandle curve, 00046 std::vector< int >& surf_ids_out, 00047 std::vector< int >& senses_out ); 00048 ErrorCode load_precgm14_stp_curve_sense_data( Interface* moab, 00049 EntityHandle curve, 00050 std::vector< int >& surf_ids_out, 00051 std::vector< int >& senses_out ); 00052 ErrorCode load_sat_surf_sense_data( Interface* moab, 00053 EntityHandle surf, 00054 std::vector< int >& vol_ids_out, 00055 std::vector< int >& senses_out ); 00056 ErrorCode load_stp_surf_sense_data( Interface* moab, 00057 EntityHandle surf, 00058 std::vector< int >& vol_ids_out, 00059 std::vector< int >& senses_out ); 00060 ErrorCode load_precgm14_stp_surf_sense_data( Interface* moab, 00061 EntityHandle surf, 00062 std::vector< int >& vol_ids_out, 00063 std::vector< int >& senses_out ); 00064 00065 // Functions used to compare sense information found in 00066 // the model to reference information 00067 void check_sense_data( Interface* moab, 00068 std::vector< EntityHandle > wrt_ents, 00069 std::vector< int > senses, 00070 std::vector< int > known_wrt_ids, 00071 std::vector< int > known_senses ); 00072 00073 // Function used to get id's from entity handles 00074 int geom_id_by_handle( Interface* moab, const EntityHandle set ); 00075 00076 // List of tests in this file 00077 void read_cylcube_curve_senses_test(); 00078 void read_cylcube_surf_senses_test(); 00079 void delete_mesh_test(); 00080 00081 int main( int /* argc */, char** /* argv */ ) 00082 { 00083 int result = 0; 00084 00085 result += RUN_TEST( read_cylcube_surf_senses_test ); 00086 result += RUN_TEST( read_cylcube_curve_senses_test ); 00087 00088 return result; 00089 } 00090 00091 void read_file( Interface* moab, const char* input_file ) 00092 { 00093 InitCGMA::initialize_cgma(); 00094 GeometryQueryTool::instance()->delete_geometry(); 00095 00096 ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval ); 00097 } 00098 00099 // Gets the sense data for each curve from a file 00100 // containing a cube and a cylinder. It then checks 00101 // that this sense data matches the reference 00102 // sense data from prior file reads. 00103 void read_cylcube_curve_senses_test() 00104 { 00105 ErrorCode rval; 00106 // Open the test file 00107 Core moab; 00108 Interface* mb = &moab; 00109 read_file( mb, input_cylcube.c_str() ); 00110 00111 // Get all curve handles 00112 Tag geom_tag; 00113 rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, 00114 moab::MB_TAG_DENSE | moab::MB_TAG_CREAT );CHECK_ERR( rval ); 00115 00116 // Check that the proper number of curves exist 00117 int dim = 1; 00118 void* val[] = { &dim }; 00119 int number_of_curves; 00120 rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_curves );CHECK_ERR( rval ); 00121 // Step format adds a surface on the barrel of the cylinder. 00122 // This created 4 extra surfaces in comparison to the .sat format from Cubit. 00123 //(New surface breaks the barrel of the cylinder into two half-pipes) 00124 #ifdef HAVE_OCC_STEP 00125 CHECK_EQUAL( 18, number_of_curves ); 00126 #else 00127 CHECK_EQUAL( 14, number_of_curves ); 00128 #endif 00129 00130 // Get curve handles 00131 Range curves; 00132 rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, curves );CHECK_ERR( rval ); 00133 00134 // Establish GeomTopoTool instance needed to get curve data 00135 moab::GeomTopoTool gt( mb, false ); 00136 // Initialize vectors for sense checking 00137 std::vector< EntityHandle > surfs; 00138 std::vector< int > senses; 00139 std::vector< int > known_surf_ids; 00140 std::vector< int > known_senses; 00141 00142 for( unsigned int i = 0; i < curves.size(); i++ ) 00143 { 00144 00145 // Clean data from previous curve 00146 surfs.clear(); 00147 senses.clear(); 00148 // Get sense info for the current curve 00149 rval = gt.get_senses( curves[i], surfs, senses );CHECK_ERR( rval ); 00150 00151 // Clear reference data from previous curve 00152 known_surf_ids.clear(); 00153 known_senses.clear(); 00154 // Load known curve-sense ID data 00155 #ifdef HAVE_OCC_STEP 00156 if( CGM_MAJOR_VERSION >= 14 ) 00157 { 00158 rval = load_stp_curve_sense_data( mb, curves[i], known_surf_ids, known_senses ); 00159 } 00160 else 00161 { 00162 rval = load_precgm14_stp_curve_sense_data( mb, curves[i], known_surf_ids, known_senses ); 00163 } 00164 CHECK_ERR( rval ); 00165 #else 00166 rval = load_sat_curve_sense_data( mb, curves[i], known_surf_ids, known_senses );CHECK_ERR( rval ); 00167 #endif 00168 00169 // Check that each surf and sense has a match in the references 00170 check_sense_data( mb, surfs, senses, known_surf_ids, known_senses ); 00171 } 00172 } 00173 00174 int geom_id_by_handle( Interface* moab, const EntityHandle set ) 00175 { 00176 00177 ErrorCode rval; 00178 // Get the id_tag handle 00179 Tag id_tag = moab->globalId_tag(); 00180 // Load the ID for the EntHandle given to the function 00181 int id; 00182 rval = moab->tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval ); 00183 return id; 00184 } 00185 00186 void check_sense_data( Interface* moab, 00187 std::vector< EntityHandle > wrt_ents, 00188 std::vector< int > senses, 00189 std::vector< int > known_wrt_ids, 00190 std::vector< int > known_senses ) 00191 { 00192 00193 // Get ID's of the wrt entities 00194 std::vector< int > wrt_ent_ids; 00195 for( unsigned int i = 0; i < wrt_ents.size(); i++ ) 00196 { 00197 wrt_ent_ids.push_back( geom_id_by_handle( moab, wrt_ents[i] ) ); 00198 } 00199 00200 for( unsigned int i = 0; i < wrt_ent_ids.size(); i++ ) 00201 { 00202 for( unsigned int j = 0; j < known_wrt_ids.size(); j++ ) 00203 { 00204 if( wrt_ent_ids[i] == known_wrt_ids[j] ) 00205 { 00206 // Make sure the senses of the matching wrt entities 00207 // are correct 00208 CHECK_EQUAL( senses[i], known_senses[j] ); 00209 // Once a wrt entity is matched with a known entity, 00210 // remove it from the list 00211 wrt_ent_ids.erase( wrt_ent_ids.begin() + i ); 00212 senses.erase( senses.begin() + i ); 00213 --i; 00214 break; 00215 } 00216 } 00217 } 00218 00219 // After both loops are complete, known_wrt_ents should be empty 00220 int leftovers = wrt_ent_ids.size(); 00221 CHECK_EQUAL( leftovers, 0 ); 00222 } 00223 00224 // Loads two vectors with reference curve and curve_sense data 00225 ErrorCode load_sat_curve_sense_data( Interface* moab, 00226 EntityHandle curve, 00227 std::vector< int >& surf_ids_out, 00228 std::vector< int >& senses_out ) 00229 { 00230 00231 int curve_id = geom_id_by_handle( moab, curve ); 00232 switch( curve_id ) 00233 { 00234 case 1: 00235 surf_ids_out.push_back( 1 ); 00236 surf_ids_out.push_back( 6 ); 00237 senses_out.push_back( SENSE_FORWARD ); 00238 senses_out.push_back( SENSE_REVERSE ); 00239 break; 00240 00241 case 2: 00242 surf_ids_out.push_back( 1 ); 00243 surf_ids_out.push_back( 5 ); 00244 senses_out.push_back( SENSE_FORWARD ); 00245 senses_out.push_back( SENSE_REVERSE ); 00246 break; 00247 00248 case 3: 00249 surf_ids_out.push_back( 1 ); 00250 surf_ids_out.push_back( 4 ); 00251 senses_out.push_back( SENSE_FORWARD ); 00252 senses_out.push_back( SENSE_REVERSE ); 00253 break; 00254 00255 case 4: 00256 surf_ids_out.push_back( 1 ); 00257 surf_ids_out.push_back( 3 ); 00258 senses_out.push_back( SENSE_FORWARD ); 00259 senses_out.push_back( SENSE_REVERSE ); 00260 break; 00261 00262 case 5: 00263 surf_ids_out.push_back( 2 ); 00264 surf_ids_out.push_back( 6 ); 00265 senses_out.push_back( SENSE_FORWARD ); 00266 senses_out.push_back( SENSE_REVERSE ); 00267 break; 00268 00269 case 6: 00270 surf_ids_out.push_back( 2 ); 00271 surf_ids_out.push_back( 3 ); 00272 senses_out.push_back( SENSE_FORWARD ); 00273 senses_out.push_back( SENSE_REVERSE ); 00274 break; 00275 00276 case 7: 00277 surf_ids_out.push_back( 2 ); 00278 surf_ids_out.push_back( 4 ); 00279 senses_out.push_back( SENSE_FORWARD ); 00280 senses_out.push_back( SENSE_REVERSE ); 00281 break; 00282 00283 case 8: 00284 surf_ids_out.push_back( 2 ); 00285 surf_ids_out.push_back( 5 ); 00286 senses_out.push_back( SENSE_FORWARD ); 00287 senses_out.push_back( SENSE_REVERSE ); 00288 break; 00289 00290 case 9: 00291 surf_ids_out.push_back( 3 ); 00292 surf_ids_out.push_back( 4 ); 00293 senses_out.push_back( SENSE_FORWARD ); 00294 senses_out.push_back( SENSE_REVERSE ); 00295 break; 00296 00297 case 10: 00298 surf_ids_out.push_back( 3 ); 00299 surf_ids_out.push_back( 6 ); 00300 senses_out.push_back( SENSE_REVERSE ); 00301 senses_out.push_back( SENSE_FORWARD ); 00302 break; 00303 00304 case 11: 00305 surf_ids_out.push_back( 4 ); 00306 surf_ids_out.push_back( 5 ); 00307 senses_out.push_back( SENSE_FORWARD ); 00308 senses_out.push_back( SENSE_REVERSE ); 00309 break; 00310 00311 case 12: 00312 surf_ids_out.push_back( 5 ); 00313 surf_ids_out.push_back( 6 ); 00314 senses_out.push_back( SENSE_FORWARD ); 00315 senses_out.push_back( SENSE_REVERSE ); 00316 break; 00317 00318 case 13: 00319 surf_ids_out.push_back( 7 ); 00320 surf_ids_out.push_back( 8 ); 00321 senses_out.push_back( SENSE_REVERSE ); 00322 senses_out.push_back( SENSE_FORWARD ); 00323 break; 00324 00325 case 14: 00326 surf_ids_out.push_back( 7 ); 00327 surf_ids_out.push_back( 9 ); 00328 senses_out.push_back( SENSE_REVERSE ); 00329 senses_out.push_back( SENSE_FORWARD ); 00330 break; 00331 default: 00332 return MB_FAILURE; 00333 } 00334 return MB_SUCCESS; 00335 } 00336 00337 // Loads two vectors with reference curve and curve_sense data 00338 ErrorCode load_stp_curve_sense_data( Interface* moab, 00339 EntityHandle curve, 00340 std::vector< int >& surf_ids_out, 00341 std::vector< int >& senses_out ) 00342 { 00343 00344 int curve_id = geom_id_by_handle( moab, curve ); 00345 switch( curve_id ) 00346 { 00347 case 1: 00348 surf_ids_out.push_back( 1 ); 00349 surf_ids_out.push_back( 6 ); 00350 senses_out.push_back( SENSE_FORWARD ); 00351 senses_out.push_back( SENSE_FORWARD ); 00352 break; 00353 00354 case 2: 00355 surf_ids_out.push_back( 1 ); 00356 surf_ids_out.push_back( 5 ); 00357 senses_out.push_back( SENSE_FORWARD ); 00358 senses_out.push_back( SENSE_FORWARD ); 00359 break; 00360 00361 case 3: 00362 surf_ids_out.push_back( 1 ); 00363 surf_ids_out.push_back( 4 ); 00364 senses_out.push_back( SENSE_FORWARD ); 00365 senses_out.push_back( SENSE_FORWARD ); 00366 break; 00367 00368 case 4: 00369 surf_ids_out.push_back( 1 ); 00370 surf_ids_out.push_back( 3 ); 00371 senses_out.push_back( SENSE_FORWARD ); 00372 senses_out.push_back( SENSE_FORWARD ); 00373 break; 00374 00375 case 5: 00376 surf_ids_out.push_back( 2 ); 00377 surf_ids_out.push_back( 6 ); 00378 senses_out.push_back( SENSE_REVERSE ); 00379 senses_out.push_back( SENSE_FORWARD ); 00380 break; 00381 00382 case 6: 00383 surf_ids_out.push_back( 2 ); 00384 surf_ids_out.push_back( 5 ); 00385 senses_out.push_back( SENSE_REVERSE ); 00386 senses_out.push_back( SENSE_FORWARD ); 00387 break; 00388 00389 case 7: 00390 surf_ids_out.push_back( 2 ); 00391 surf_ids_out.push_back( 4 ); 00392 senses_out.push_back( SENSE_REVERSE ); 00393 senses_out.push_back( SENSE_FORWARD ); 00394 break; 00395 00396 case 8: 00397 surf_ids_out.push_back( 2 ); 00398 surf_ids_out.push_back( 3 ); 00399 senses_out.push_back( SENSE_REVERSE ); 00400 senses_out.push_back( SENSE_FORWARD ); 00401 break; 00402 00403 case 9: 00404 surf_ids_out.push_back( 3 ); 00405 surf_ids_out.push_back( 4 ); 00406 senses_out.push_back( SENSE_REVERSE ); 00407 senses_out.push_back( SENSE_FORWARD ); 00408 break; 00409 00410 case 10: 00411 surf_ids_out.push_back( 3 ); 00412 surf_ids_out.push_back( 6 ); 00413 senses_out.push_back( SENSE_FORWARD ); 00414 senses_out.push_back( SENSE_REVERSE ); 00415 break; 00416 00417 case 11: 00418 surf_ids_out.push_back( 4 ); 00419 surf_ids_out.push_back( 5 ); 00420 senses_out.push_back( SENSE_REVERSE ); 00421 senses_out.push_back( SENSE_FORWARD ); 00422 break; 00423 00424 case 12: 00425 surf_ids_out.push_back( 5 ); 00426 surf_ids_out.push_back( 6 ); 00427 senses_out.push_back( SENSE_REVERSE ); 00428 senses_out.push_back( SENSE_FORWARD ); 00429 break; 00430 00431 case 13: 00432 surf_ids_out.push_back( 7 ); 00433 surf_ids_out.push_back( 8 ); 00434 senses_out.push_back( SENSE_REVERSE ); 00435 senses_out.push_back( SENSE_FORWARD ); 00436 break; 00437 00438 case 14: 00439 surf_ids_out.push_back( 7 ); 00440 surf_ids_out.push_back( 9 ); 00441 senses_out.push_back( SENSE_REVERSE ); 00442 senses_out.push_back( SENSE_FORWARD ); 00443 break; 00444 case 15: 00445 surf_ids_out.push_back( 7 ); 00446 surf_ids_out.push_back( 8 ); 00447 senses_out.push_back( SENSE_REVERSE ); 00448 senses_out.push_back( SENSE_FORWARD ); 00449 break; 00450 case 16: 00451 surf_ids_out.push_back( 7 ); 00452 surf_ids_out.push_back( 10 ); 00453 senses_out.push_back( SENSE_REVERSE ); 00454 senses_out.push_back( SENSE_FORWARD ); 00455 break; 00456 case 17: 00457 surf_ids_out.push_back( 8 ); 00458 surf_ids_out.push_back( 10 ); 00459 senses_out.push_back( SENSE_REVERSE ); 00460 senses_out.push_back( SENSE_FORWARD ); 00461 break; 00462 case 18: 00463 surf_ids_out.push_back( 8 ); 00464 surf_ids_out.push_back( 9 ); 00465 senses_out.push_back( SENSE_REVERSE ); 00466 senses_out.push_back( SENSE_FORWARD ); 00467 break; 00468 default: 00469 return MB_FAILURE; 00470 } 00471 return MB_SUCCESS; 00472 } 00473 00474 ErrorCode load_precgm14_stp_curve_sense_data( Interface* moab, 00475 EntityHandle curve, 00476 std::vector< int >& surf_ids_out, 00477 std::vector< int >& senses_out ) 00478 { 00479 00480 int curve_id = geom_id_by_handle( moab, curve ); 00481 switch( curve_id ) 00482 { 00483 case 1: 00484 surf_ids_out.push_back( 1 ); 00485 surf_ids_out.push_back( 6 ); 00486 senses_out.push_back( SENSE_FORWARD ); 00487 senses_out.push_back( SENSE_REVERSE ); 00488 break; 00489 00490 case 2: 00491 surf_ids_out.push_back( 1 ); 00492 surf_ids_out.push_back( 5 ); 00493 senses_out.push_back( SENSE_FORWARD ); 00494 senses_out.push_back( SENSE_REVERSE ); 00495 break; 00496 00497 case 3: 00498 surf_ids_out.push_back( 1 ); 00499 surf_ids_out.push_back( 4 ); 00500 senses_out.push_back( SENSE_FORWARD ); 00501 senses_out.push_back( SENSE_REVERSE ); 00502 break; 00503 00504 case 4: 00505 surf_ids_out.push_back( 1 ); 00506 surf_ids_out.push_back( 3 ); 00507 senses_out.push_back( SENSE_FORWARD ); 00508 senses_out.push_back( SENSE_REVERSE ); 00509 break; 00510 00511 case 5: 00512 surf_ids_out.push_back( 2 ); 00513 surf_ids_out.push_back( 6 ); 00514 senses_out.push_back( SENSE_FORWARD ); 00515 senses_out.push_back( SENSE_REVERSE ); 00516 break; 00517 00518 case 6: 00519 surf_ids_out.push_back( 2 ); 00520 surf_ids_out.push_back( 3 ); 00521 senses_out.push_back( SENSE_FORWARD ); 00522 senses_out.push_back( SENSE_REVERSE ); 00523 break; 00524 00525 case 7: 00526 surf_ids_out.push_back( 2 ); 00527 surf_ids_out.push_back( 4 ); 00528 senses_out.push_back( SENSE_FORWARD ); 00529 senses_out.push_back( SENSE_REVERSE ); 00530 break; 00531 00532 case 8: 00533 surf_ids_out.push_back( 2 ); 00534 surf_ids_out.push_back( 5 ); 00535 senses_out.push_back( SENSE_FORWARD ); 00536 senses_out.push_back( SENSE_REVERSE ); 00537 break; 00538 00539 case 9: 00540 surf_ids_out.push_back( 3 ); 00541 surf_ids_out.push_back( 4 ); 00542 senses_out.push_back( SENSE_FORWARD ); 00543 senses_out.push_back( SENSE_REVERSE ); 00544 break; 00545 00546 case 10: 00547 surf_ids_out.push_back( 3 ); 00548 surf_ids_out.push_back( 6 ); 00549 senses_out.push_back( SENSE_REVERSE ); 00550 senses_out.push_back( SENSE_FORWARD ); 00551 break; 00552 00553 case 11: 00554 surf_ids_out.push_back( 4 ); 00555 surf_ids_out.push_back( 5 ); 00556 senses_out.push_back( SENSE_FORWARD ); 00557 senses_out.push_back( SENSE_REVERSE ); 00558 break; 00559 00560 case 12: 00561 surf_ids_out.push_back( 5 ); 00562 surf_ids_out.push_back( 6 ); 00563 senses_out.push_back( SENSE_FORWARD ); 00564 senses_out.push_back( SENSE_REVERSE ); 00565 break; 00566 00567 case 13: 00568 surf_ids_out.push_back( 7 ); 00569 surf_ids_out.push_back( 8 ); 00570 senses_out.push_back( SENSE_REVERSE ); 00571 senses_out.push_back( SENSE_FORWARD ); 00572 break; 00573 00574 case 14: 00575 surf_ids_out.push_back( 7 ); 00576 surf_ids_out.push_back( 9 ); 00577 senses_out.push_back( SENSE_REVERSE ); 00578 senses_out.push_back( SENSE_FORWARD ); 00579 break; 00580 case 15: 00581 surf_ids_out.push_back( 7 ); 00582 surf_ids_out.push_back( 8 ); 00583 senses_out.push_back( SENSE_REVERSE ); 00584 senses_out.push_back( SENSE_FORWARD ); 00585 break; 00586 case 16: 00587 surf_ids_out.push_back( 7 ); 00588 surf_ids_out.push_back( 10 ); 00589 senses_out.push_back( SENSE_REVERSE ); 00590 senses_out.push_back( SENSE_FORWARD ); 00591 break; 00592 case 17: 00593 surf_ids_out.push_back( 8 ); 00594 surf_ids_out.push_back( 10 ); 00595 senses_out.push_back( SENSE_REVERSE ); 00596 senses_out.push_back( SENSE_FORWARD ); 00597 break; 00598 case 18: 00599 surf_ids_out.push_back( 8 ); 00600 surf_ids_out.push_back( 9 ); 00601 senses_out.push_back( SENSE_REVERSE ); 00602 senses_out.push_back( SENSE_FORWARD ); 00603 break; 00604 default: 00605 return MB_FAILURE; 00606 } 00607 return MB_SUCCESS; 00608 } 00609 00610 // SURFACE SENSE CHECKING 00611 // Gets the sense data for each surface from a file 00612 // containing a cube and a cylinder. It then checks 00613 // that this sense data matches the reference 00614 // sense data from prior file reads. 00615 void read_cylcube_surf_senses_test() 00616 { 00617 ErrorCode rval; 00618 // Open the test file 00619 Core moab; 00620 Interface* mb = &moab; 00621 read_file( mb, input_cylcube.c_str() ); 00622 00623 // Get geometry tag for gathering surface information from the mesh 00624 Tag geom_tag; 00625 rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, 00626 moab::MB_TAG_DENSE | moab::MB_TAG_CREAT );CHECK_ERR( rval ); 00627 00628 // Check that the proper number of surfaces exist 00629 int dim = 2; 00630 void* val[] = { &dim }; 00631 int number_of_surfs; 00632 rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_surfs );CHECK_ERR( rval ); 00633 // Step format adds a surface on barrel of the cylinder. 00634 // (Breaks it into two half-pipes) 00635 #ifdef HAVE_OCC_STEP 00636 CHECK_EQUAL( 10, number_of_surfs ); 00637 #else 00638 CHECK_EQUAL( 9, number_of_surfs ); 00639 #endif 00640 // Get surface handles 00641 Range surfs; 00642 rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, surfs );CHECK_ERR( rval ); 00643 00644 // Establish GeomTopoTool instance needed to get surf data 00645 moab::GeomTopoTool gt( mb, false ); 00646 std::vector< EntityHandle > vols; 00647 std::vector< int > senses; 00648 std::vector< int > known_vol_ids; 00649 std::vector< int > known_senses; 00650 00651 for( unsigned int i = 0; i < surfs.size(); i++ ) 00652 { 00653 // Clean data from previous surface 00654 vols.clear(); 00655 senses.clear(); 00656 // Get sense information for the current 00657 // surface from the mesh 00658 rval = gt.get_senses( surfs[i], vols, senses );CHECK_ERR( rval ); 00659 // Clear previous reverence data 00660 known_vol_ids.clear(); 00661 known_senses.clear(); 00662 // Load known surface-volume data 00663 // for this surface and check that it's correct 00664 #ifdef HAVE_OCC_STEP 00665 if( CGM_MAJOR_VERSION >= 14 ) 00666 { 00667 rval = load_stp_surf_sense_data( mb, surfs[i], known_vol_ids, known_senses ); 00668 } 00669 else 00670 { 00671 rval = load_precgm14_stp_surf_sense_data( mb, surfs[i], known_vol_ids, known_senses ); 00672 } 00673 CHECK_ERR( rval ); 00674 #else 00675 rval = load_sat_surf_sense_data( mb, surfs[i], known_vol_ids, known_senses );CHECK_ERR( rval ); 00676 #endif 00677 // Check sense information from the loaded mesh against 00678 // reference sense information 00679 check_sense_data( mb, vols, senses, known_vol_ids, known_senses ); 00680 } 00681 } 00682 00683 // Loads reference surface to volume sense data into the reference vectors 00684 ErrorCode load_sat_surf_sense_data( Interface* moab, 00685 EntityHandle surf, 00686 std::vector< int >& vol_ids_out, 00687 std::vector< int >& senses_out ) 00688 { 00689 00690 int surf_id = geom_id_by_handle( moab, surf ); 00691 switch( surf_id ) 00692 { 00693 case 1: 00694 vol_ids_out.push_back( 1 ); 00695 senses_out.push_back( SENSE_FORWARD ); 00696 break; 00697 00698 case 2: 00699 vol_ids_out.push_back( 1 ); 00700 senses_out.push_back( SENSE_FORWARD ); 00701 break; 00702 00703 case 3: 00704 vol_ids_out.push_back( 1 ); 00705 senses_out.push_back( SENSE_FORWARD ); 00706 break; 00707 00708 case 4: 00709 vol_ids_out.push_back( 1 ); 00710 senses_out.push_back( SENSE_FORWARD ); 00711 break; 00712 00713 case 5: 00714 vol_ids_out.push_back( 1 ); 00715 senses_out.push_back( SENSE_FORWARD ); 00716 break; 00717 00718 case 6: 00719 vol_ids_out.push_back( 1 ); 00720 senses_out.push_back( SENSE_FORWARD ); 00721 break; 00722 00723 case 7: 00724 vol_ids_out.push_back( 2 ); 00725 senses_out.push_back( SENSE_FORWARD ); 00726 break; 00727 00728 case 8: 00729 vol_ids_out.push_back( 2 ); 00730 senses_out.push_back( SENSE_FORWARD ); 00731 break; 00732 00733 case 9: 00734 vol_ids_out.push_back( 2 ); 00735 senses_out.push_back( SENSE_FORWARD ); 00736 break; 00737 default: 00738 return MB_FAILURE; 00739 } 00740 return MB_SUCCESS; 00741 } 00742 00743 // Loads reference surface to volume sense data into the reference vectors 00744 ErrorCode load_stp_surf_sense_data( Interface* moab, 00745 EntityHandle surf, 00746 std::vector< int >& vol_ids_out, 00747 std::vector< int >& senses_out ) 00748 { 00749 00750 int surf_id = geom_id_by_handle( moab, surf ); 00751 switch( surf_id ) 00752 { 00753 case 1: 00754 vol_ids_out.push_back( 1 ); 00755 senses_out.push_back( SENSE_FORWARD ); 00756 break; 00757 00758 case 2: 00759 vol_ids_out.push_back( 1 ); 00760 senses_out.push_back( SENSE_REVERSE ); 00761 break; 00762 00763 case 3: 00764 vol_ids_out.push_back( 1 ); 00765 senses_out.push_back( SENSE_REVERSE ); 00766 break; 00767 00768 case 4: 00769 vol_ids_out.push_back( 1 ); 00770 senses_out.push_back( SENSE_REVERSE ); 00771 break; 00772 00773 case 5: 00774 vol_ids_out.push_back( 1 ); 00775 senses_out.push_back( SENSE_REVERSE ); 00776 break; 00777 00778 case 6: 00779 vol_ids_out.push_back( 1 ); 00780 senses_out.push_back( SENSE_REVERSE ); 00781 break; 00782 00783 case 7: 00784 vol_ids_out.push_back( 2 ); 00785 senses_out.push_back( SENSE_FORWARD ); 00786 break; 00787 00788 case 8: 00789 vol_ids_out.push_back( 2 ); 00790 senses_out.push_back( SENSE_FORWARD ); 00791 break; 00792 00793 case 9: 00794 vol_ids_out.push_back( 2 ); 00795 senses_out.push_back( SENSE_FORWARD ); 00796 break; 00797 00798 case 10: 00799 vol_ids_out.push_back( 2 ); 00800 senses_out.push_back( SENSE_FORWARD ); 00801 break; 00802 default: 00803 std::cout << "Failure to find surface sense reference data. Returning failure..." << std::endl; 00804 return MB_FAILURE; 00805 } 00806 return MB_SUCCESS; 00807 } 00808 00809 // Loads reference surface to volume sense data into the reference vectors 00810 ErrorCode load_precgm14_stp_surf_sense_data( Interface* moab, 00811 EntityHandle surf, 00812 std::vector< int >& vol_ids_out, 00813 std::vector< int >& senses_out ) 00814 { 00815 00816 int surf_id = geom_id_by_handle( moab, surf ); 00817 switch( surf_id ) 00818 { 00819 case 1: 00820 case 2: 00821 case 3: 00822 case 4: 00823 case 5: 00824 case 6: 00825 vol_ids_out.push_back( 1 ); 00826 senses_out.push_back( SENSE_FORWARD ); 00827 break; 00828 00829 case 7: 00830 case 8: 00831 case 9: 00832 case 10: 00833 vol_ids_out.push_back( 2 ); 00834 senses_out.push_back( SENSE_FORWARD ); 00835 break; 00836 00837 default: 00838 std::cout << "Failure to find surface sense reference data. Returning failure..." << std::endl; 00839 return MB_FAILURE; 00840 } 00841 return MB_SUCCESS; 00842 }
