MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ScdInterface.hpp"#include "moab/Core.hpp"#include "TestUtil.hpp"#include <iostream>
Include dependency graph for scd_test_partn.cpp:Go to the source code of this file.
Functions | |
| void | test_sqijk () |
| int | main (int argc, char **argv) |
Variables | |
| int | gdims [6] |
| int | np |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 39 of file scd_test_partn.cpp.
References gdims, np, RUN_TEST, and test_sqijk().
if( argc < 2 )
std::cout << "Usage: " << argv[0] << " <#proc> [<imax> [<jmax> <kmax>]]" << std::endl;
std::cout << "Using default parameters for autotest purposes." << std::endl;
np = 4;
gdims[0] = gdims[1] = gdims[2] = 0;
gdims[3] = gdims[4] = gdims[5] = 100;
else if( argc < 3 )
np = atoi( argv[1] );
else if( argc < 4 )
gdims[3] = gdims[4] = gdims[5] = atoi( argv[2] );
else if( argc < 6 )
gdims[3] = atoi( argv[2] );
gdims[4] = atoi( argv[3] );
gdims[5] = atoi( argv[4] );
// test partition method
RUN_TEST( test_sqijk );
| void test_sqijk | ( | ) |
Definition at line 15 of file scd_test_partn.cpp.
References CHECK_ERR, moab::ScdInterface::compute_partition(), ErrorCode, gdims, moab::ScdParData::gDims, moab::ScdParData::gPeriodic, np, moab::ScdParData::partMethod, and moab::ScdParData::SQIJK.
Referenced by main().
Core moab;
ScdInterface* scd;
ErrorCode rval = moab.Interface::query_interface( scd );CHECK_ERR( rval );
int ldims[6];
ScdParData par_data;
std::copy( gdims, gdims + 6, par_data.gDims );
for( int i = 0; i < 3; i++ )
par_data.gPeriodic[i] = 0;
par_data.partMethod = ScdParData::SQIJK;
std::cout << "gDims = (" << par_data.gDims[0] << "," << par_data.gDims[1] << "," << par_data.gDims[2] << ")--("
<< par_data.gDims[3] << "," << par_data.gDims[4] << "," << par_data.gDims[5] << ")" << std::endl;
int lperiodic[3], pijk[3];
rval = ScdInterface::compute_partition( np, 0, par_data, ldims, lperiodic, pijk );CHECK_ERR( rval );
std::cout << "#proc in 3 directions = (" << pijk[0] << "," << pijk[1] << "," << pijk[2] << ")" << std::endl;
std::cout << "local dims are (" << ldims[0] << "," << ldims[1] << "," << ldims[2] << ")--(" << ldims[3] << ","
<< ldims[4] << "," << ldims[5] << ")\n";
| int gdims[6] |
Definition at line 13 of file scd_test_partn.cpp.
Referenced by main(), moab::ScdInterface::tag_shared_vertices(), test_parallel_partitions(), and test_sqijk().
| int np |
Referenced by moab::AdaptiveKDTree::best_vertex_median_plane(), check_shared_ents(), moab::ParCommGraph::compute_partition(), moab::ScdInterface::compute_partition_alljkbal(), moab::ScdInterface::compute_partition_alljorkori(), moab::ScdInterface::compute_partition_sqijk(), moab::ScdInterface::compute_partition_sqjk(), moab::IntxUtils::EdgeIntxRllCs(), moab::ScdInterface::get_neighbor_alljkbal(), moab::ScdInterface::get_neighbor_sqij(), moab::ScdInterface::get_neighbor_sqjk(), lobatto_nodes_aux(), main(), moab::putSpectralElementField(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), test_great_arc_clat_intx(), and test_sqijk().
