MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * arc_intx_tests.cpp 00003 */ 00004 #include <iostream> 00005 #include <sstream> 00006 #include <ctime> 00007 #include <cstdlib> 00008 #include <cstdio> 00009 #include <cstring> 00010 #include "moab/Types.hpp" 00011 #include "moab/IntxMesh/IntxUtils.hpp" 00012 00013 #include "TestUtil.hpp" 00014 00015 using namespace moab; 00016 void test_great_arc_intx() 00017 { 00018 double A[3] = { 0., 0., 1. }; 00019 double B[3] = { 1., 0., 0. }; 00020 double C[3] = { 0., 0.6, 0.8 }; 00021 double D[3] = { 0.6, -0.8, 0. }; 00022 00023 double E[3]; 00024 double R = 1.0; 00025 ErrorCode rval = moab::IntxUtils::intersect_great_circle_arcs( A, B, C, D, R, E );CHECK_ERR( rval ); 00026 std::cout << "E: " << E[0] << " " << E[1] << " " << E[2] << "\n"; 00027 rval = moab::IntxUtils::intersect_great_circle_arcs( A, C, B, D, R, E ); 00028 CHECK( rval == MB_FAILURE ); 00029 } 00030 void test_great_arc_clat_intx() 00031 { 00032 double d3 = 1 / sqrt( 3. ); 00033 double A[3] = { 0., 0., 1. }; 00034 double B[3] = { 1., 0., 0. }; 00035 double C[3] = { d3, d3, d3 }; 00036 double D[3] = { d3, -d3, d3 }; 00037 00038 double E[9]; 00039 double R = 1.0; 00040 int np = 0; 00041 ErrorCode rval = moab::IntxUtils::intersect_great_circle_arc_with_clat_arc( A, B, C, D, R, E, np );CHECK_ERR( rval ); 00042 std::cout << "E: " << E[0] << " " << E[1] << " " << E[2] << "\n"; 00043 double F[3] = { -d3, d3, d3 }; 00044 rval = moab::IntxUtils::intersect_great_circle_arc_with_clat_arc( A, B, C, F, R, E, np ); 00045 CHECK( rval == MB_FAILURE ); 00046 } 00047 int main() 00048 { 00049 int failures = 0; 00050 failures += RUN_TEST( test_great_arc_intx ); 00051 failures += RUN_TEST( test_great_arc_clat_intx ); 00052 return failures; 00053 }
