MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <vector>#include "moab/Interface.hpp"#include "moab/Range.hpp"#include "moab/ProgOptions.hpp"#include "moab/CartVect.hpp"#include "moab/Core.hpp"#include "moab/ReadUtilIface.hpp"
Include dependency graph for ComputeTriDual.cpp:Go to the source code of this file.
Defines | |
| #define | CC(ind) moab::CartVect( ccenters[0][ind], ccenters[1][ind], ccenters[2][ind] ) |
| #define | CCXMY(ind, cv) moab::CartVect( ccenters[0][ind] - ( cv )[0], ccenters[1][ind] - ( cv )[1], ccenters[2][ind] - ( cv )[2] ) |
Functions | |
| moab::ErrorCode | compute_dual_mesh (moab::Interface *mb, moab::EntityHandle &dual_set, moab::Range &cells) |
| int | main (int argc, char **argv) |
| #define CC | ( | ind | ) | moab::CartVect( ccenters[0][ind], ccenters[1][ind], ccenters[2][ind] ) |
Referenced by moab::MeshGeneration::BrickInstance(), and compute_dual_mesh().
| #define CCXMY | ( | ind, | |
| cv | |||
| ) | moab::CartVect( ccenters[0][ind] - ( cv )[0], ccenters[1][ind] - ( cv )[1], ccenters[2][ind] - ( cv )[2] ) |
Referenced by compute_dual_mesh().
| moab::ErrorCode compute_dual_mesh | ( | moab::Interface * | mb, |
| moab::EntityHandle & | dual_set, | ||
| moab::Range & | cells | ||
Definition at line 25 of file ComputeTriDual.cpp.
References moab::Interface::add_entities(), moab::ParallelComm::assign_global_ids(), moab::Range::begin(), CC, CCXMY, moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), moab::Interface::globalId_tag(), iface, moab::CartVect::length(), MB_CHK_SET_ERR, MB_SUCCESS, MBPOLYGON, moab::Range::merge(), MPI_COMM_WORLD, moab::Interface::query_interface(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and vtx().
Referenced by main().
moab::ErrorCode rval;
moab::Range verts;
rval = mb->get_connectivity( cells, verts );MB_CHK_SET_ERR( rval, "Failed to get connectivity" );
moab::ReadUtilIface* iface;
rval = mb->query_interface( iface );MB_CHK_SET_ERR( rval, "Can't get reader interface" );
moab::EntityHandle startv;
std::vector< double* > ccenters;
rval = iface->get_node_coords( 3, cells.size(), 0, startv, ccenters );MB_CHK_SET_ERR( rval, "Can't get node coords" );
moab::Tag gidTag = mb->globalId_tag();
std::vector< int > gids( cells.size() );
rval = mb->get_coords( cells, ccenters[0], ccenters[1], ccenters[2] );MB_CHK_SET_ERR( rval, "Failed to get coordinates" );
rval = mb->tag_get_data( gidTag, cells, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" );
moab::Range dualverts( startv, startv + cells.size() - 1 );
rval = mb->add_entities( dual_set, dualverts );MB_CHK_SET_ERR( rval, "Can't add entities" );
rval = mb->tag_set_data( gidTag, dualverts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" );
#define CC( ind ) moab::CartVect( ccenters[0][ind], ccenters[1][ind], ccenters[2][ind] )
#define CCXMY( ind, cv ) \
const moab::EntityHandle svtx = *( cells.begin() );
// maintain block-wise polygon elements
moab::Range dualcells;
std::map< size_t, std::vector< moab::EntityHandle > > polygonConn;
// Generate new Face array
for( moab::Range::iterator vit = verts.begin(); vit != verts.end(); ++vit )
moab::EntityHandle vtx = *vit;
std::vector< moab::EntityHandle > adjs;
// generate all required adjacencies
rval = mb->get_adjacencies( &vtx, 1, 2, true, adjs );MB_CHK_SET_ERR( rval, "Failed to get adjacencies" );
const size_t nEdges = adjs.size();
double vxyz[3];
rval = mb->get_coords( &vtx, 1, vxyz );MB_CHK_SET_ERR( rval, "Failed to get coordinates" );
// Reorient Faces
moab::CartVect nodeCentral( vxyz );
moab::CartVect noderef = CC( adjs[0] - svtx );
moab::CartVect node0 = noderef - nodeCentral;
double dNode0Mag = node0.length();
moab::CartVect nodeCross = noderef * nodeCentral;
// Determine the angles about the central Node of each Face Node
std::vector< double > dAngles;
dAngles.resize( nEdges );
dAngles[0] = 0.0;
for( size_t j = 1; j < nEdges; j++ )
moab::CartVect nodeDiff = CCXMY( adjs[j] - svtx, nodeCentral );
double dNodeDiffMag = nodeDiff.length();
double dSide = nodeCross % nodeDiff;
double dDotNorm = ( node0 % nodeDiff ) / ( dNode0Mag * dNodeDiffMag );
// double dAngle;
if( dDotNorm > 1.0 )
dDotNorm = 1.0;
dAngles[j] = acos( dDotNorm );
if( dSide > 0.0 )
dAngles[j] = -dAngles[j] + 2.0 * M_PI;
std::vector< moab::EntityHandle >& face = polygonConn[nEdges];
if( face.size() == 0 ) face.reserve( nEdges * verts.size() / 4 );
face.push_back( dualverts[adjs[0] - svtx] );
// Orient each Face by putting Nodes in order of increasing angle
double dCurrentAngle = 0.0;
int ixNextNode = 1;
double dNextAngle = 2.0 * M_PI;
for( size_t k = 1; k < nEdges; k++ )
if( ( dAngles[k] > dCurrentAngle ) && ( dAngles[k] < dNextAngle ) )
ixNextNode = k;
dNextAngle = dAngles[k];
face.push_back( dualverts[adjs[ixNextNode] - svtx] );
dCurrentAngle = dNextAngle;
std::map< size_t, std::vector< moab::EntityHandle > >::iterator eit;
for( eit = polygonConn.begin(); eit != polygonConn.end(); ++eit )
const size_t nVPerE = eit->first;
const size_t nElePerType = static_cast< int >( eit->second.size() / nVPerE );
moab::EntityHandle starte; // Connectivity
moab::EntityHandle* conn;
rval = iface->get_element_connect( nElePerType, eit->first, moab::MBPOLYGON, 0, starte, conn );MB_CHK_SET_ERR( rval, "Can't get element connectivity" );
// copy the connectivity that we have accumulated
std::copy( eit->second.begin(), eit->second.end(), conn );
eit->second.clear();
// add this polygon sequence to the aggregate data
moab::Range mbcells( starte, starte + nElePerType - 1 );
dualcells.merge( mbcells );
// add the computed dual cells to mesh
rval = mb->add_entities( dual_set, dualcells );MB_CHK_SET_ERR( rval, "Can't add polygonal entities" );
// Assign global IDs to all the dual cells - same as original vertices
assert( dualcells.size() == verts.size() );
gids.resize( verts.size() );
rval = mb->tag_get_data( gidTag, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" );
if( gids[0] == gids[1] && gids[0] < 0 )
#ifdef MOAB_HAVE_MPI
moab::ParallelComm pcomm( mb, MPI_COMM_WORLD );
rval = pcomm.assign_global_ids( dual_set, 2, 1, false, true, true );MB_CHK_SET_ERR( rval, "Can't assign global_ids" );
#else
// No global ID assigned to input vertices.
// Can we use std::iota ??
for( size_t ix = 0; ix < gids.size(); ++ix )
gids[ix] = ix + 1;
// set GID tag
rval = mb->tag_set_data( gidTag, dualcells, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" );
std::cout << "GIDs: " << gids[0] << " " << gids[1] << " " << gids[2] << " " << gids[3] << " " << gids[4] << " "
<< gids[5] << "\n";
#endif
gids.clear();
// delete the original entities from the mesh
rval = mb->delete_entities( cells );MB_CHK_SET_ERR( rval, "Can't remove entities" );
rval = mb->delete_entities( verts );MB_CHK_SET_ERR( rval, "Can't remove entities" );
return moab::MB_SUCCESS;
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 187 of file ComputeTriDual.cpp.
References ProgOptions::addOpt(), moab::Range::clear(), compute_dual_mesh(), moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::load_file(), mb, MB_CHK_SET_ERR, MESH_DIR, MESHSET_SET, ProgOptions::parseCommandLine(), readopts(), moab::Range::size(), and moab::Interface::write_file().
ProgOptions opts;
// Get MOAB instance
moab::Interface* mb = new( std::nothrow ) moab::Core;
if( NULL == mb ) return 1;
std::string inputFile = std::string( MESH_DIR ) + "/globalmpas_deltri.h5m";
opts.addOpt< std::string >( "inFile,i", "Specify the input file name string ", &inputFile );
#ifdef MOAB_HAVE_HDF5
std::string outputFile = "outDualMesh.h5m";
#else
std::string outputFile = "outDualMesh.vtk";
#endif
opts.addOpt< std::string >( "outFile,o", "Specify the input file name string ", &outputFile );
opts.parseCommandLine( argc, argv );
moab::EntityHandle triangle_set, dual_set;
rval = mb->create_meshset( moab::MESHSET_SET, triangle_set );MB_CHK_SET_ERR( rval, "Can't create new set" );
rval = mb->create_meshset( moab::MESHSET_SET, dual_set );MB_CHK_SET_ERR( rval, "Can't create new set" );
// This file is in the mesh files directory
const char* readopts = "";
rval = mb->load_file( inputFile.c_str(), &triangle_set, readopts );MB_CHK_SET_ERR( rval, "Failed to read" );
// get all cells of dimension 2;
moab::Range cells;
rval = mb->get_entities_by_dimension( triangle_set, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" );
std::cout << "Original number of triangular cells : " << cells.size() << "\n";
// call the routine to compute the dual grid
rval = compute_dual_mesh( mb, dual_set, cells );MB_CHK_SET_ERR( rval, "Failed to compute dual mesh" );
// write the mesh to disk
rval = mb->write_file( outputFile.c_str() );MB_CHK_SET_ERR( rval, "Failed to write new file" );
cells.clear();
rval = mb->get_entities_by_dimension( dual_set, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" );
std::cout << "Wrote the dual mesh: " << outputFile << " containing " << cells.size() << " polygonal cells\n";
delete mb;
return 0;
