MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example ComputeTriDual.cpp \n 00002 * \brief Compute the polygonal (dual) mesh of the primal simplex grid in 2-D. \n 00003 * <b>To run</b>: ComputeTriDual input_file output_file \n 00004 * An example to demonstrate computing the dual polygonal grid of a triangulation 00005 * on a spherical surface. 00006 */ 00007 00008 #include <iostream> 00009 #include <vector> 00010 00011 // Include header for MOAB instance and tag conventions for 00012 #include "moab/Interface.hpp" 00013 #include "moab/Range.hpp" 00014 #include "moab/ProgOptions.hpp" 00015 #include "moab/CartVect.hpp" 00016 #include "moab/Core.hpp" 00017 #include "moab/ReadUtilIface.hpp" 00018 00019 #ifdef MOAB_HAVE_MPI 00020 #include "moab/ParallelComm.hpp" 00021 #endif 00022 00023 /////////////////////////////////////////////////////////////////////////////// 00024 00025 moab::ErrorCode compute_dual_mesh( moab::Interface* mb, moab::EntityHandle& dual_set, moab::Range& cells ) 00026 { 00027 moab::ErrorCode rval; 00028 00029 moab::Range verts; 00030 rval = mb->get_connectivity( cells, verts );MB_CHK_SET_ERR( rval, "Failed to get connectivity" ); 00031 00032 moab::ReadUtilIface* iface; 00033 rval = mb->query_interface( iface );MB_CHK_SET_ERR( rval, "Can't get reader interface" ); 00034 00035 moab::EntityHandle startv; 00036 std::vector< double* > ccenters; 00037 rval = iface->get_node_coords( 3, cells.size(), 0, startv, ccenters );MB_CHK_SET_ERR( rval, "Can't get node coords" ); 00038 00039 moab::Tag gidTag = mb->globalId_tag(); 00040 00041 std::vector< int > gids( cells.size() ); 00042 rval = mb->get_coords( cells, ccenters[0], ccenters[1], ccenters[2] );MB_CHK_SET_ERR( rval, "Failed to get coordinates" ); 00043 rval = mb->tag_get_data( gidTag, cells, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" ); 00044 00045 moab::Range dualverts( startv, startv + cells.size() - 1 ); 00046 rval = mb->add_entities( dual_set, dualverts );MB_CHK_SET_ERR( rval, "Can't add entities" ); 00047 rval = mb->tag_set_data( gidTag, dualverts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" ); 00048 00049 #define CC( ind ) moab::CartVect( ccenters[0][ind], ccenters[1][ind], ccenters[2][ind] ) 00050 #define CCXMY( ind, cv ) \ 00051 moab::CartVect( ccenters[0][ind] - ( cv )[0], ccenters[1][ind] - ( cv )[1], ccenters[2][ind] - ( cv )[2] ) 00052 00053 const moab::EntityHandle svtx = *( cells.begin() ); 00054 00055 // maintain block-wise polygon elements 00056 moab::Range dualcells; 00057 std::map< size_t, std::vector< moab::EntityHandle > > polygonConn; 00058 // Generate new Face array 00059 for( moab::Range::iterator vit = verts.begin(); vit != verts.end(); ++vit ) 00060 { 00061 moab::EntityHandle vtx = *vit; 00062 00063 std::vector< moab::EntityHandle > adjs; 00064 // generate all required adjacencies 00065 rval = mb->get_adjacencies( &vtx, 1, 2, true, adjs );MB_CHK_SET_ERR( rval, "Failed to get adjacencies" ); 00066 const size_t nEdges = adjs.size(); 00067 00068 double vxyz[3]; 00069 rval = mb->get_coords( &vtx, 1, vxyz );MB_CHK_SET_ERR( rval, "Failed to get coordinates" ); 00070 00071 // Reorient Faces 00072 moab::CartVect nodeCentral( vxyz ); 00073 moab::CartVect noderef = CC( adjs[0] - svtx ); 00074 moab::CartVect node0 = noderef - nodeCentral; 00075 double dNode0Mag = node0.length(); 00076 00077 moab::CartVect nodeCross = noderef * nodeCentral; 00078 00079 // Determine the angles about the central Node of each Face Node 00080 std::vector< double > dAngles; 00081 dAngles.resize( nEdges ); 00082 dAngles[0] = 0.0; 00083 00084 for( size_t j = 1; j < nEdges; j++ ) 00085 { 00086 moab::CartVect nodeDiff = CCXMY( adjs[j] - svtx, nodeCentral ); 00087 double dNodeDiffMag = nodeDiff.length(); 00088 00089 double dSide = nodeCross % nodeDiff; 00090 double dDotNorm = ( node0 % nodeDiff ) / ( dNode0Mag * dNodeDiffMag ); 00091 00092 // double dAngle; 00093 if( dDotNorm > 1.0 ) 00094 { 00095 dDotNorm = 1.0; 00096 } 00097 00098 dAngles[j] = acos( dDotNorm ); 00099 00100 if( dSide > 0.0 ) 00101 { 00102 dAngles[j] = -dAngles[j] + 2.0 * M_PI; 00103 } 00104 } 00105 00106 std::vector< moab::EntityHandle >& face = polygonConn[nEdges]; 00107 if( face.size() == 0 ) face.reserve( nEdges * verts.size() / 4 ); 00108 face.push_back( dualverts[adjs[0] - svtx] ); 00109 00110 // Orient each Face by putting Nodes in order of increasing angle 00111 double dCurrentAngle = 0.0; 00112 for( size_t j = 1; j < nEdges; j++ ) 00113 { 00114 int ixNextNode = 1; 00115 double dNextAngle = 2.0 * M_PI; 00116 00117 for( size_t k = 1; k < nEdges; k++ ) 00118 { 00119 if( ( dAngles[k] > dCurrentAngle ) && ( dAngles[k] < dNextAngle ) ) 00120 { 00121 ixNextNode = k; 00122 dNextAngle = dAngles[k]; 00123 } 00124 } 00125 00126 face.push_back( dualverts[adjs[ixNextNode] - svtx] ); 00127 dCurrentAngle = dNextAngle; 00128 } 00129 } 00130 00131 std::map< size_t, std::vector< moab::EntityHandle > >::iterator eit; 00132 for( eit = polygonConn.begin(); eit != polygonConn.end(); ++eit ) 00133 { 00134 const size_t nVPerE = eit->first; 00135 const size_t nElePerType = static_cast< int >( eit->second.size() / nVPerE ); 00136 00137 moab::EntityHandle starte; // Connectivity 00138 moab::EntityHandle* conn; 00139 00140 rval = iface->get_element_connect( nElePerType, eit->first, moab::MBPOLYGON, 0, starte, conn );MB_CHK_SET_ERR( rval, "Can't get element connectivity" ); 00141 00142 // copy the connectivity that we have accumulated 00143 std::copy( eit->second.begin(), eit->second.end(), conn ); 00144 eit->second.clear(); 00145 00146 // add this polygon sequence to the aggregate data 00147 moab::Range mbcells( starte, starte + nElePerType - 1 ); 00148 dualcells.merge( mbcells ); 00149 } 00150 00151 // add the computed dual cells to mesh 00152 rval = mb->add_entities( dual_set, dualcells );MB_CHK_SET_ERR( rval, "Can't add polygonal entities" ); 00153 00154 // Assign global IDs to all the dual cells - same as original vertices 00155 assert( dualcells.size() == verts.size() ); 00156 gids.resize( verts.size() ); 00157 rval = mb->tag_get_data( gidTag, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" ); 00158 if( gids[0] == gids[1] && gids[0] < 0 ) 00159 { 00160 #ifdef MOAB_HAVE_MPI 00161 moab::ParallelComm pcomm( mb, MPI_COMM_WORLD ); 00162 00163 rval = pcomm.assign_global_ids( dual_set, 2, 1, false, true, true );MB_CHK_SET_ERR( rval, "Can't assign global_ids" ); 00164 #else 00165 // No global ID assigned to input vertices. 00166 // Can we use std::iota ?? 00167 for( size_t ix = 0; ix < gids.size(); ++ix ) 00168 gids[ix] = ix + 1; 00169 00170 // set GID tag 00171 rval = mb->tag_set_data( gidTag, dualcells, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global_id tag" ); 00172 std::cout << "GIDs: " << gids[0] << " " << gids[1] << " " << gids[2] << " " << gids[3] << " " << gids[4] << " " 00173 << gids[5] << "\n"; 00174 #endif 00175 } 00176 gids.clear(); 00177 00178 // delete the original entities from the mesh 00179 rval = mb->delete_entities( cells );MB_CHK_SET_ERR( rval, "Can't remove entities" ); 00180 rval = mb->delete_entities( verts );MB_CHK_SET_ERR( rval, "Can't remove entities" ); 00181 00182 return moab::MB_SUCCESS; 00183 } 00184 00185 /////////////////////////////////////////////////////////////////////////////// 00186 00187 int main( int argc, char** argv ) 00188 { 00189 moab::ErrorCode rval; 00190 ProgOptions opts; 00191 00192 // Get MOAB instance 00193 moab::Interface* mb = new( std::nothrow ) moab::Core; 00194 if( NULL == mb ) return 1; 00195 00196 std::string inputFile = std::string( MESH_DIR ) + "/globalmpas_deltri.h5m"; 00197 opts.addOpt< std::string >( "inFile,i", "Specify the input file name string ", &inputFile ); 00198 #ifdef MOAB_HAVE_HDF5 00199 std::string outputFile = "outDualMesh.h5m"; 00200 #else 00201 std::string outputFile = "outDualMesh.vtk"; 00202 #endif 00203 opts.addOpt< std::string >( "outFile,o", "Specify the input file name string ", &outputFile ); 00204 00205 opts.parseCommandLine( argc, argv ); 00206 00207 moab::EntityHandle triangle_set, dual_set; 00208 rval = mb->create_meshset( moab::MESHSET_SET, triangle_set );MB_CHK_SET_ERR( rval, "Can't create new set" ); 00209 rval = mb->create_meshset( moab::MESHSET_SET, dual_set );MB_CHK_SET_ERR( rval, "Can't create new set" ); 00210 00211 // This file is in the mesh files directory 00212 const char* readopts = ""; 00213 rval = mb->load_file( inputFile.c_str(), &triangle_set, readopts );MB_CHK_SET_ERR( rval, "Failed to read" ); 00214 00215 // get all cells of dimension 2; 00216 moab::Range cells; 00217 rval = mb->get_entities_by_dimension( triangle_set, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" ); 00218 00219 std::cout << "Original number of triangular cells : " << cells.size() << "\n"; 00220 00221 // call the routine to compute the dual grid 00222 rval = compute_dual_mesh( mb, dual_set, cells );MB_CHK_SET_ERR( rval, "Failed to compute dual mesh" ); 00223 00224 // write the mesh to disk 00225 rval = mb->write_file( outputFile.c_str() );MB_CHK_SET_ERR( rval, "Failed to write new file" ); 00226 00227 cells.clear(); 00228 rval = mb->get_entities_by_dimension( dual_set, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" ); 00229 std::cout << "Wrote the dual mesh: " << outputFile << " containing " << cells.size() << " polygonal cells\n"; 00230 00231 delete mb; 00232 00233 return 0; 00234 }
