MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/FileOptions.hpp"
Include dependency graph for cgns_test.cpp:Go to the source code of this file.
Defines | |
| #define | IS_BUILDING_MB |
Functions | |
| void | test_read_write () |
| int | main () |
Variables | |
| std::string | cgnsfile = "unittest/io/2d_naca0012.cgns" |
| std::string | cgnsfilew = "unittest/io/test.cgns" |
| #define IS_BUILDING_MB |
Definition at line 3 of file cgns_test.cpp.
| int main | ( | ) |
Definition at line 14 of file cgns_test.cpp.
References RUN_TEST, and test_read_write().
int result = 0;
result += RUN_TEST( test_read_write );
return result;
| void test_read_write | ( | ) |
Definition at line 23 of file cgns_test.cpp.
References cgnsfile, cgnsfilew, CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, MB_SUCCESS, and moab::Interface::write_file().
Referenced by main().
ErrorCode rval;
Core moab;
Interface& mb = moab;
rval = mb.load_file( cgnsfile.c_str() );
if( MB_SUCCESS != rval ) std::cerr << "Trouble reading file " << cgnsfile << std::endl;CHECK_ERR( rval );
rval = mb.write_file( cgnsfilew.c_str() );
if( MB_SUCCESS != rval ) std::cerr << "Trouble writing file " << cgnsfilew << std::endl;CHECK_ERR( rval );
| std::string cgnsfile = "unittest/io/2d_naca0012.cgns" |
Definition at line 9 of file cgns_test.cpp.
Referenced by test_read_write().
| std::string cgnsfilew = "unittest/io/test.cgns" |
Definition at line 10 of file cgns_test.cpp.
