MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <cstdlib>#include <cstdio>#include <cstring>#include <cctype>#include "moab/mhdf_public.h"
Include dependency graph for mhdf_public_test.cpp:Go to the source code of this file.
Functions | |
| static int | print_file_summary (MHDF_FileDesc *data) |
| int | main (int argc, char *argv[]) |
| static void | print_ent_desc (const char *name, const char *subname, MHDF_EntDesc *data, const char *vals_label, const char *extra_label, MHDF_FileDesc *all) |
| static void | print_elem_desc (MHDF_ElemDesc *data, MHDF_FileDesc *all) |
| static const char * | tag_type_name (MHDF_TagDataType type) |
| static const char * | string_tag_value (const void *value, MHDF_TagDataType type, int size) |
| static const char * | ent_desc_name (MHDF_FileDesc *all, int idx) |
| static void | print_tag_desc (MHDF_TagDesc *data, MHDF_FileDesc *all) |
| static const char* ent_desc_name | ( | MHDF_FileDesc * | all, |
| int | idx | ||
| ) | [static] |
Definition at line 218 of file mhdf_public_test.cpp.
References mhdf_FileDesc::elems, mhdf_ElemDesc::handle, and mhdf_FileDesc::num_elem_desc.
Referenced by print_tag_desc().
static const char nodes[] = "Nodes";
static const char sets[] = "Sets";
static const char invalid[] = "<INVALID INDEX!>";
if( idx == -2 ) return sets;
if( idx == -1 ) return nodes;
if( idx >= all->num_elem_desc || idx < -2 ) return invalid;
return all->elems[idx].handle;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 9 of file mhdf_public_test.cpp.
References mhdf_closeFile(), mhdf_getFileSummary(), mhdf_isError(), mhdf_message(), mhdf_openFile(), and print_file_summary().
int result;
MHDF_FileHandle file;
MHDF_Status status;
unsigned long max_id;
MHDF_FileDesc* data;
if( argc != 2 )
fprintf( stderr, "Usage: %s <filename>\n", argv[0] );
return 0;
file = mhdf_openFile( argv[1], 0, &max_id, -1, &status );
if( mhdf_isError( &status ) )
fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) );
return 1;
data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status, 1 );
return 1;
mhdf_closeFile( file, &status );
printf( "%s:\n", argv[1] );
result = print_file_summary( data );
free( data );
return result;
| static void print_elem_desc | ( | MHDF_ElemDesc * | data, |
| MHDF_FileDesc * | all | ||
| ) | [static] |
Definition at line 77 of file mhdf_public_test.cpp.
References mhdf_ElemDesc::desc, mhdf_ElemDesc::handle, mhdf_ElemDesc::have_adj, print_ent_desc(), and mhdf_ElemDesc::type.
Referenced by print_file_summary().
const char* adj = data->have_adj ? "adjacencies" : "no adjencies";
print_ent_desc( data->handle, data->type, &data->desc, "nodes per element", adj, all );
| static void print_ent_desc | ( | const char * | name, |
| const char * | subname, | ||
| MHDF_EntDesc * | data, | ||
| const char * | vals_label, | ||
| const char * | extra_label, | ||
| ) | [static] |
Definition at line 45 of file mhdf_public_test.cpp.
References mhdf_EntDesc::count, mhdf_EntDesc::dense_tag_indices, mhdf_TagDesc::name, mhdf_EntDesc::num_dense_tags, mhdf_EntDesc::start_id, mhdf_FileDesc::tags, and mhdf_EntDesc::vals_per_ent.
Referenced by print_elem_desc(), and print_file_summary().
int i, len = 10;
if( vals_label && (int)strlen( vals_label ) > len ) len = strlen( vals_label );
if( extra_label && (int)strlen( extra_label ) > len ) len = strlen( extra_label );
if( subname )
printf( " %s (%s):\n", name, subname );
else
printf( " %s:\n", name );
if( vals_label ) printf( " %-*s: %d\n", len, vals_label, data->vals_per_ent );
printf( " %-*s: %ld [%ld - %ld]\n", len, "entities", data->count, data->start_id,
data->start_id + data->count - 1 );
if( extra_label ) printf( " %-*s\n", len, extra_label );
if( !data->num_dense_tags ) return;
printf( " %-*s: \"%s\"", len, "dense tags", all->tags[data->dense_tag_indices[0]].name );
for( i = 1; i < data->num_dense_tags; ++i )
printf( ", \"%s\"", all->tags[data->dense_tag_indices[i]].name );
printf( "\n" );
| static int print_file_summary | ( | MHDF_FileDesc * | data | ) | [static] |
Definition at line 265 of file mhdf_public_test.cpp.
References mhdf_FileDesc::defTagsEntSets, mhdf_FileDesc::defTagsVals, mhdf_FileDesc::elems, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::num_tag_desc, mhdf_FileDesc::numEntSets, print_elem_desc(), print_ent_desc(), print_tag_desc(), mhdf_FileDesc::sets, and mhdf_FileDesc::tags.
Referenced by main().
int i;
printf( " Entities:\n" );
print_ent_desc( "Nodes", NULL, &data->nodes, "dimension", NULL, data );
for( i = 0; i < data->num_elem_desc; ++i )
print_elem_desc( data->elems + i, data );
print_ent_desc( "Sets", NULL, &data->sets, NULL, NULL, data );
printf( " Tags:\n" );
for( i = 0; i < data->num_tag_desc; ++i )
print_tag_desc( data->tags + i, data );
printf( " Number partitions: %d\n", data->numEntSets[0] );
for( i = 0; i < data->numEntSets[0]; i++ )
printf( " set id %d value %d \n", data->defTagsEntSets[0][i], data->defTagsVals[0][i] );
printf( "\n Number material sets: %d\n", data->numEntSets[1] );
for( i = 0; i < data->numEntSets[1]; i++ )
printf( " set id %d value %d \n", data->defTagsEntSets[1][i], data->defTagsVals[1][i] );
printf( "\n Number neumann sets: %d\n", data->numEntSets[2] );
for( i = 0; i < data->numEntSets[2]; i++ )
printf( " set id %d value %d \n", data->defTagsEntSets[2][i], data->defTagsVals[2][i] );
printf( "\n Number dirichlet sets: %d\n", data->numEntSets[3] );
for( i = 0; i < data->numEntSets[3]; i++ )
printf( " set id %d value %d \n", data->defTagsEntSets[3][i], data->defTagsVals[3][i] );
printf( "\n Number geometry sets: %d\n", data->numEntSets[4] );
for( i = 0; i < data->numEntSets[4]; i++ )
printf( " set id %d value %d \n", data->defTagsEntSets[4][i], data->defTagsVals[4][i] );
return 0;
| static void print_tag_desc | ( | MHDF_TagDesc * | data, |
| ) | [static] |
Definition at line 229 of file mhdf_public_test.cpp.
References mhdf_TagDesc::bytes, mhdf_TagDesc::default_value, mhdf_TagDesc::default_value_size, mhdf_TagDesc::dense_elem_indices, ent_desc_name(), mhdf_TagDesc::global_value, mhdf_TagDesc::global_value_size, mhdf_TagDesc::have_sparse, mhdf_TagDesc::name, mhdf_TagDesc::num_dense_indices, mhdf_TagDesc::size, mhdf_TagDesc::storage, string_tag_value(), tag_type_name(), and mhdf_TagDesc::type.
int i, width = 8;
printf( " \"%s\":\n", data->name );
printf( " %-*s: %s\n", width, "type", tag_type_name( data->type ) );
if( data->size < 0 )
printf( " %-*s: (variable)\n", width, "size" );
else
printf( " %-*s: %d (%d bytes)\n", width, "size", data->size, data->bytes );
printf( " %-*s: %x\n", width, "flags", data->storage );
if( data->default_value )
printf( " %-*s: %s\n", width, "default",
string_tag_value( data->default_value, data->type, data->default_value_size ) );
if( data->global_value )
printf( " %-*s: %s\n", width, "mesh val",
string_tag_value( data->global_value, data->type, data->global_value_size ) );
if( data->have_sparse )
printf( " %-*s: (sparse)", width, "tables" );
for( i = 0; i < data->num_dense_indices; ++i )
printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) );
else if( data->num_dense_indices )
printf( " %-*s: %s", width, "tables", ent_desc_name( all, data->dense_elem_indices[0] ) );
for( i = 1; i < data->num_dense_indices; ++i )
else
printf( " %-*s: (none)", width, "tables" );
printf( "\n" );
| static const char* string_tag_value | ( | const void * | value, |
| MHDF_TagDataType | type, | ||
| int | size | ||
| ) | [static] |
Definition at line 110 of file mhdf_public_test.cpp.
References buffer, mhdf_BITFIELD, mhdf_BOOLEAN, mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_INTEGER, mhdf_OPAQUE, and size.
static char buffer[1024];
const char* data = (const char*)value;
char* offset = buffer;
int print, i;
const int* intptr = (const int*)value;
const double* dblptr = (const double*)value;
const unsigned long* idptr = (const unsigned long*)value;
if( size <= 0 )
*buffer = '\0';
return buffer;
switch( type )
case mhdf_OPAQUE:
print = 1;
for( i = 0; i < size; ++i )
if( !isprint( data[i] ) ) print = 0;
if( print )
offset[0] = '"';
memcpy( offset + 1, data, size );
offset[size + 1] = '"';
offset[size + 2] = '\0';
offset += size + 2;
else
strcpy( offset, "0x" );
offset += 2;
offset += sprintf( offset, "%02x", (unsigned int)data[i] );
break;
case mhdf_INTEGER:
if( size == 1 )
offset += sprintf( offset, "%d", intptr[0] );
else
offset += sprintf( offset, "{%d", intptr[0] );
for( i = 1; i < size; ++i )
offset += sprintf( offset, ",%d", intptr[i] );
offset += sprintf( offset, "}" );
break;
case mhdf_FLOAT:
if( size == 1 )
offset += sprintf( offset, "%g", dblptr[0] );
else
offset += sprintf( offset, "{%g", dblptr[0] );
offset += sprintf( offset, ",%g", dblptr[i] );
break;
case mhdf_BITFIELD:
if( size > 8 )
offset += sprintf( offset, "(more than 8 bits)" );
else
for( i = size - 1; i >= 0; --i )
*( offset++ ) = (char)( *data & ( 1 << i ) ? '1' : '0' );
*offset = '\0';
break;
case mhdf_BOOLEAN:
if( size == 1 )
offset += sprintf( offset, "%s", data[0] ? "true" : "false" );
else
offset += sprintf( offset, "{%s", data[0] ? "true" : "false" );
offset += sprintf( offset, ",%s", data[i] ? "true" : "false" );
break;
case mhdf_ENTITY_ID:
if( size == 1 )
offset += sprintf( offset, "%lu", idptr[0] );
else
offset += sprintf( offset, "{%lu", idptr[0] );
offset += sprintf( offset, ",%lu", idptr[i] );
break;
default:
strcpy( buffer, "(unknown data type)" );
break;
return buffer;
| static const char* tag_type_name | ( | MHDF_TagDataType | type | ) | [static] |
Definition at line 83 of file mhdf_public_test.cpp.
References mhdf_BITFIELD, mhdf_BOOLEAN, mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_INTEGER, and mhdf_OPAQUE.
static const char opaque[] = "opaque";
static const char integer[] = "integer";
static const char real[] = "real";
static const char bits[] = "bit field";
static const char boolean[] = "boolean";
static const char id[] = "entity id";
static const char unknown[] = "(UNKNOWN TYPE ID)";
switch( type )
case mhdf_OPAQUE:
return opaque;
case mhdf_INTEGER:
return integer;
case mhdf_FLOAT:
return real;
case mhdf_BITFIELD:
return bits;
case mhdf_BOOLEAN:
return boolean;
return id;
return unknown;
