MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <cstdlib> 00002 #include <cstdio> 00003 #include <cstring> 00004 #include <cctype> 00005 #include "moab/mhdf_public.h" 00006 00007 static int print_file_summary( MHDF_FileDesc* data ); 00008 00009 int main( int argc, char* argv[] ) 00010 { 00011 int result; 00012 MHDF_FileHandle file; 00013 MHDF_Status status; 00014 unsigned long max_id; 00015 MHDF_FileDesc* data; 00016 00017 if( argc != 2 ) 00018 { 00019 fprintf( stderr, "Usage: %s <filename>\n", argv[0] ); 00020 return 0; 00021 } 00022 00023 file = mhdf_openFile( argv[1], 0, &max_id, -1, &status ); 00024 if( mhdf_isError( &status ) ) 00025 { 00026 fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) ); 00027 return 1; 00028 } 00029 00030 data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status, 1 ); 00031 if( mhdf_isError( &status ) ) 00032 { 00033 fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) ); 00034 return 1; 00035 } 00036 00037 mhdf_closeFile( file, &status ); 00038 00039 printf( "%s:\n", argv[1] ); 00040 result = print_file_summary( data ); 00041 free( data ); 00042 return result; 00043 } 00044 00045 static void print_ent_desc( const char* name, 00046 const char* subname, 00047 MHDF_EntDesc* data, 00048 const char* vals_label, 00049 const char* extra_label, 00050 MHDF_FileDesc* all ) 00051 { 00052 int i, len = 10; 00053 00054 if( vals_label && (int)strlen( vals_label ) > len ) len = strlen( vals_label ); 00055 if( extra_label && (int)strlen( extra_label ) > len ) len = strlen( extra_label ); 00056 00057 if( subname ) 00058 printf( " %s (%s):\n", name, subname ); 00059 else 00060 printf( " %s:\n", name ); 00061 00062 if( vals_label ) printf( " %-*s: %d\n", len, vals_label, data->vals_per_ent ); 00063 00064 printf( " %-*s: %ld [%ld - %ld]\n", len, "entities", data->count, data->start_id, 00065 data->start_id + data->count - 1 ); 00066 00067 if( extra_label ) printf( " %-*s\n", len, extra_label ); 00068 00069 if( !data->num_dense_tags ) return; 00070 00071 printf( " %-*s: \"%s\"", len, "dense tags", all->tags[data->dense_tag_indices[0]].name ); 00072 for( i = 1; i < data->num_dense_tags; ++i ) 00073 printf( ", \"%s\"", all->tags[data->dense_tag_indices[i]].name ); 00074 printf( "\n" ); 00075 } 00076 00077 static void print_elem_desc( MHDF_ElemDesc* data, MHDF_FileDesc* all ) 00078 { 00079 const char* adj = data->have_adj ? "adjacencies" : "no adjencies"; 00080 print_ent_desc( data->handle, data->type, &data->desc, "nodes per element", adj, all ); 00081 } 00082 00083 static const char* tag_type_name( MHDF_TagDataType type ) 00084 { 00085 static const char opaque[] = "opaque"; 00086 static const char integer[] = "integer"; 00087 static const char real[] = "real"; 00088 static const char bits[] = "bit field"; 00089 static const char boolean[] = "boolean"; 00090 static const char id[] = "entity id"; 00091 static const char unknown[] = "(UNKNOWN TYPE ID)"; 00092 switch( type ) 00093 { 00094 case mhdf_OPAQUE: 00095 return opaque; 00096 case mhdf_INTEGER: 00097 return integer; 00098 case mhdf_FLOAT: 00099 return real; 00100 case mhdf_BITFIELD: 00101 return bits; 00102 case mhdf_BOOLEAN: 00103 return boolean; 00104 case mhdf_ENTITY_ID: 00105 return id; 00106 } 00107 return unknown; 00108 } 00109 00110 static const char* string_tag_value( const void* value, MHDF_TagDataType type, int size ) 00111 { 00112 static char buffer[1024]; 00113 const char* data = (const char*)value; 00114 char* offset = buffer; 00115 int print, i; 00116 const int* intptr = (const int*)value; 00117 const double* dblptr = (const double*)value; 00118 const unsigned long* idptr = (const unsigned long*)value; 00119 00120 if( size <= 0 ) 00121 { 00122 *buffer = '\0'; 00123 return buffer; 00124 } 00125 00126 switch( type ) 00127 { 00128 case mhdf_OPAQUE: 00129 print = 1; 00130 for( i = 0; i < size; ++i ) 00131 if( !isprint( data[i] ) ) print = 0; 00132 if( print ) 00133 { 00134 offset[0] = '"'; 00135 memcpy( offset + 1, data, size ); 00136 offset[size + 1] = '"'; 00137 offset[size + 2] = '\0'; 00138 offset += size + 2; 00139 } 00140 else 00141 { 00142 strcpy( offset, "0x" ); 00143 offset += 2; 00144 for( i = 0; i < size; ++i ) 00145 offset += sprintf( offset, "%02x", (unsigned int)data[i] ); 00146 } 00147 break; 00148 case mhdf_INTEGER: 00149 if( size == 1 ) 00150 { 00151 offset += sprintf( offset, "%d", intptr[0] ); 00152 } 00153 else 00154 { 00155 offset += sprintf( offset, "{%d", intptr[0] ); 00156 for( i = 1; i < size; ++i ) 00157 offset += sprintf( offset, ",%d", intptr[i] ); 00158 offset += sprintf( offset, "}" ); 00159 } 00160 break; 00161 case mhdf_FLOAT: 00162 if( size == 1 ) 00163 { 00164 offset += sprintf( offset, "%g", dblptr[0] ); 00165 } 00166 else 00167 { 00168 offset += sprintf( offset, "{%g", dblptr[0] ); 00169 for( i = 1; i < size; ++i ) 00170 offset += sprintf( offset, ",%g", dblptr[i] ); 00171 offset += sprintf( offset, "}" ); 00172 } 00173 break; 00174 case mhdf_BITFIELD: 00175 if( size > 8 ) 00176 offset += sprintf( offset, "(more than 8 bits)" ); 00177 else 00178 { 00179 for( i = size - 1; i >= 0; --i ) 00180 *( offset++ ) = (char)( *data & ( 1 << i ) ? '1' : '0' ); 00181 *offset = '\0'; 00182 } 00183 break; 00184 case mhdf_BOOLEAN: 00185 if( size == 1 ) 00186 { 00187 offset += sprintf( offset, "%s", data[0] ? "true" : "false" ); 00188 } 00189 else 00190 { 00191 offset += sprintf( offset, "{%s", data[0] ? "true" : "false" ); 00192 for( i = 1; i < size; ++i ) 00193 offset += sprintf( offset, ",%s", data[i] ? "true" : "false" ); 00194 offset += sprintf( offset, "}" ); 00195 } 00196 break; 00197 case mhdf_ENTITY_ID: 00198 if( size == 1 ) 00199 { 00200 offset += sprintf( offset, "%lu", idptr[0] ); 00201 } 00202 else 00203 { 00204 offset += sprintf( offset, "{%lu", idptr[0] ); 00205 for( i = 1; i < size; ++i ) 00206 offset += sprintf( offset, ",%lu", idptr[i] ); 00207 offset += sprintf( offset, "}" ); 00208 } 00209 break; 00210 default: 00211 strcpy( buffer, "(unknown data type)" ); 00212 break; 00213 } 00214 00215 return buffer; 00216 } 00217 00218 static const char* ent_desc_name( MHDF_FileDesc* all, int idx ) 00219 { 00220 static const char nodes[] = "Nodes"; 00221 static const char sets[] = "Sets"; 00222 static const char invalid[] = "<INVALID INDEX!>"; 00223 if( idx == -2 ) return sets; 00224 if( idx == -1 ) return nodes; 00225 if( idx >= all->num_elem_desc || idx < -2 ) return invalid; 00226 return all->elems[idx].handle; 00227 } 00228 00229 static void print_tag_desc( MHDF_TagDesc* data, MHDF_FileDesc* all ) 00230 { 00231 int i, width = 8; 00232 00233 printf( " \"%s\":\n", data->name ); 00234 printf( " %-*s: %s\n", width, "type", tag_type_name( data->type ) ); 00235 if( data->size < 0 ) 00236 printf( " %-*s: (variable)\n", width, "size" ); 00237 else 00238 printf( " %-*s: %d (%d bytes)\n", width, "size", data->size, data->bytes ); 00239 printf( " %-*s: %x\n", width, "flags", data->storage ); 00240 if( data->default_value ) 00241 printf( " %-*s: %s\n", width, "default", 00242 string_tag_value( data->default_value, data->type, data->default_value_size ) ); 00243 if( data->global_value ) 00244 printf( " %-*s: %s\n", width, "mesh val", 00245 string_tag_value( data->global_value, data->type, data->global_value_size ) ); 00246 if( data->have_sparse ) 00247 { 00248 printf( " %-*s: (sparse)", width, "tables" ); 00249 for( i = 0; i < data->num_dense_indices; ++i ) 00250 printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) ); 00251 } 00252 else if( data->num_dense_indices ) 00253 { 00254 printf( " %-*s: %s", width, "tables", ent_desc_name( all, data->dense_elem_indices[0] ) ); 00255 for( i = 1; i < data->num_dense_indices; ++i ) 00256 printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) ); 00257 } 00258 else 00259 { 00260 printf( " %-*s: (none)", width, "tables" ); 00261 } 00262 printf( "\n" ); 00263 } 00264 00265 static int print_file_summary( MHDF_FileDesc* data ) 00266 { 00267 int i; 00268 00269 printf( " Entities:\n" ); 00270 print_ent_desc( "Nodes", NULL, &data->nodes, "dimension", NULL, data ); 00271 for( i = 0; i < data->num_elem_desc; ++i ) 00272 print_elem_desc( data->elems + i, data ); 00273 print_ent_desc( "Sets", NULL, &data->sets, NULL, NULL, data ); 00274 00275 printf( " Tags:\n" ); 00276 for( i = 0; i < data->num_tag_desc; ++i ) 00277 print_tag_desc( data->tags + i, data ); 00278 00279 printf( " Number partitions: %d\n", data->numEntSets[0] ); 00280 for( i = 0; i < data->numEntSets[0]; i++ ) 00281 printf( " set id %d value %d \n", data->defTagsEntSets[0][i], data->defTagsVals[0][i] ); 00282 printf( "\n Number material sets: %d\n", data->numEntSets[1] ); 00283 for( i = 0; i < data->numEntSets[1]; i++ ) 00284 printf( " set id %d value %d \n", data->defTagsEntSets[1][i], data->defTagsVals[1][i] ); 00285 printf( "\n Number neumann sets: %d\n", data->numEntSets[2] ); 00286 for( i = 0; i < data->numEntSets[2]; i++ ) 00287 printf( " set id %d value %d \n", data->defTagsEntSets[2][i], data->defTagsVals[2][i] ); 00288 printf( "\n Number dirichlet sets: %d\n", data->numEntSets[3] ); 00289 for( i = 0; i < data->numEntSets[3]; i++ ) 00290 printf( " set id %d value %d \n", data->defTagsEntSets[3][i], data->defTagsVals[3][i] ); 00291 printf( "\n Number geometry sets: %d\n", data->numEntSets[4] ); 00292 for( i = 0; i < data->numEntSets[4]; i++ ) 00293 printf( " set id %d value %d \n", data->defTagsEntSets[4][i], data->defTagsVals[4][i] ); 00294 00295 return 0; 00296 }
