MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/Range.hpp"#include "MBCN.hpp"#include "MBTagConventions.hpp"#include "moab/GeomTopoTool.hpp"#include <iostream>#include <cassert>
Include dependency graph for GeomSetHierarchy.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
Variables | |
| const char * | ent_names [] = { "Vertex", "Edge", "Face", "Region" } |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 11 of file GeomSetHierarchy.cpp.
References moab::Range::begin(), moab::Range::clear(), dim, moab::Range::end(), ent_names, ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_parent_meshsets(), moab::GeomTopoTool::get_sense(), moab::GeomTopoTool::get_senses(), moab::Interface::globalId_tag(), moab::Interface::load_file(), mb, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
if( 1 == argc )
std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
return 0;
// instantiate & load a file
moab::Interface* mb = new moab::Core();
moab::ErrorCode rval = mb->load_file( argv[1] );
assert( moab::MB_SUCCESS == rval );
// get the geometric topology tag handle
moab::Tag geom_tag, gid_tag;
rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, moab::MB_TYPE_INTEGER, geom_tag );
gid_tag = mb->globalId_tag();
assert( NULL != gid_tag );
// traverse the model, from dimension 3 downward
moab::Range psets, chsets;
std::vector< moab::EntityHandle > sense_ents;
std::vector< int > senses;
int dim, pgid, chgid;
void* dim_ptr = &dim;
int sense;
moab::GeomTopoTool gt( mb, true );
for( dim = 3; dim >= 0; dim-- )
// get parents at this dimension
chsets.clear();
rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, &dim_ptr, 1, chsets, 1, false );
// for each child, get parents and do something with them
moab::Range::iterator ch_it, p_it;
for( ch_it = chsets.begin(); ch_it != chsets.end(); ++ch_it )
// get the children and put in child set list
psets.clear();
rval = mb->get_parent_meshsets( *ch_it, psets );
rval = mb->tag_get_data( gid_tag, &( *ch_it ), 1, &chgid );
// print # parents
std::cout << ent_names[dim] << " " << chgid << " has " << psets.size() << " parents." << std::endl;
if( 2 == dim )
for( p_it = psets.begin(); p_it != psets.end(); ++p_it )
rval = mb->tag_get_data( gid_tag, &( *p_it ), 1, &pgid );
rval = gt.get_sense( *ch_it, *p_it, sense );
if( moab::MB_SUCCESS != rval ) continue;
std::cout << ent_names[dim + 1] << " " << pgid << ", " << ent_names[dim] << " " << chgid
<< " sense is: ";
if( 1 == sense )
std::cout << "FORWARD" << std::endl;
else
std::cout << "REVERSE" << std::endl;
else if( 1 == dim )
sense_ents.clear();
senses.clear();
rval = gt.get_senses( *ch_it, sense_ents, senses );
for( unsigned int i = 0; i < sense_ents.size(); i++ )
rval = mb->tag_get_data( gid_tag, &sense_ents[i], 1, &pgid );
<< " sense is: ";
if( -1 == senses[i] )
std::cout << "REVERSED" << std::endl;
else if( 0 == senses[i] )
std::cout << "BOTH" << std::endl;
else if( 1 == senses[i] )
else
std::cout << "(invalid)" << std::endl;
delete mb;
return 0;
| const char* ent_names[] = { "Vertex", "Edge", "Face", "Region" } |
Definition at line 9 of file GeomSetHierarchy.cpp.
Referenced by main().
