TestTypeSequenceManager.cpp File Reference
#include <thread>
#include <set>
#include "TypeSequenceManager.hpp"
#include "EntitySequence.hpp"
#include "SequenceData.hpp"
#include "TestUtil.hpp"
#include "moab/Error.hpp"
+ Include dependency graph for TestTypeSequenceManager.cpp:
Classes
class  DumSeq
Functions
void test_basic ()
void test_lower_bound ()
void test_upper_bound ()
void test_find ()
void test_get_entities ()
void test_insert_sequence_merge ()
void test_insert_sequence_nomerge ()
void test_remove_sequence ()
void test_replace_subsequence ()
void test_erase ()
void test_find_free_handle ()
void test_find_free_sequence ()
void test_is_free_sequence ()
void test_is_free_handle ()
void test_threaded_access (int n_threads)
void test_single_thread_access ()
void test_multi_thread_access ()
void regression_svn1952 ()
void regression_svn1958 ()
void regression_svn1960 ()
void make_basic_sequence (TypeSequenceManager &seq)
void make_basic_sequence (TypeSequenceManager &seq, EntitySequence *&seq3to7, EntitySequence *&seq100to111, EntitySequence *&seq1001)
bool seqman_equal (const EntityHandle pair_array[][2], unsigned num_pairs, const TypeSequenceManager &seqman)
ErrorCode insert_seq (TypeSequenceManager &seqman, EntityHandle start_handle, EntityID count, SequenceData *data, bool del_data=false)
int main ()
void call_find (TypeSequenceManager *seqman, const std::set< int > &removed, int num_orig_entities, int &n_failures)
Function Documentation
void call_find ( TypeSequenceManager *  seqman,
const std::set< int > &  removed,
int &  n_failures
Definition at line 1051 of file TestTypeSequenceManager.cpp.
References CHECK_EQUAL, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::find(), and MB_SUCCESS.
Referenced by test_threaded_access().
    ErrorCode rval = MB_SUCCESS;
    const EntitySequence* seq;
    int n_queries = 10000;
    for( int i = 0; i < n_queries; i++ )
        long unsigned idx = ( (double)rand() / RAND_MAX * num_orig_entities ) + 1;
        // do not check for entities we've removed
        if( removed.count( idx ) != 0 ) continue;
        // search for this entity in the sequence manager
        rval = seqman->find( idx, seq );
        CHECK_EQUAL( MB_SUCCESS, rval );
        // check that the returned sequence actually contains this entity
        // (this is where threaded access used to fail)
        if( idx < seq->start_handle() || idx > seq->end_handle() )
            n_failures += 1;
ErrorCode insert_seq ( TypeSequenceManager &  seqman,
EntityID  count,
SequenceData *  data,
bool  del_data = false
Definition at line 151 of file TestTypeSequenceManager.cpp.
References CHECK, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::insert_sequence(), MB_SUCCESS, and moab::EntitySequence::start_handle().
Referenced by make_basic_sequence(), regression_svn1952(), regression_svn1958(), regression_svn1960(), test_insert_sequence_merge(), test_insert_sequence_nomerge(), test_is_free_handle(), test_replace_subsequence(), and test_threaded_access().
    EntitySequence* seq = new DumSeq( start_handle, count, data );
    ErrorCode rval      = seqman.insert_sequence( seq );
    if( MB_SUCCESS != rval )
        delete seq;
        if( del_data ) delete data;
    else
        CHECK( start_handle >= seq->start_handle() );
        CHECK( start_handle + count - 1 <= seq->end_handle() );
    return rval;
int main ( )
Definition at line 61 of file TestTypeSequenceManager.cpp.
References error_count, regression_svn1952(), regression_svn1958(), regression_svn1960(), RUN_TEST, test_basic(), test_erase(), test_find(), test_find_free_handle(), test_find_free_sequence(), test_get_entities(), test_insert_sequence_merge(), test_insert_sequence_nomerge(), test_is_free_sequence(), test_lower_bound(), test_multi_thread_access(), test_remove_sequence(), test_replace_subsequence(), test_single_thread_access(), and test_upper_bound().
    if( RUN_TEST( test_basic ) )
        printf( "BASIC USE TEST FAILED\nCANNOT TEST FURTHER\n" );
        return 1;
    int error_count = 0;
    error_count += RUN_TEST( test_lower_bound );
    error_count += RUN_TEST( test_upper_bound );
    error_count += RUN_TEST( test_find );
    error_count += RUN_TEST( test_get_entities );
    error_count += RUN_TEST( test_insert_sequence_merge );
    error_count += RUN_TEST( test_insert_sequence_nomerge );
    error_count += RUN_TEST( test_remove_sequence );
    error_count += RUN_TEST( test_replace_subsequence );
    error_count += RUN_TEST( test_erase );
    error_count += RUN_TEST( test_find_free_handle );
    error_count += RUN_TEST( test_find_free_sequence );
    error_count += RUN_TEST( test_is_free_sequence );
#ifndef MOAB_FORCE_32_BIT_HANDLES
    error_count += RUN_TEST( test_single_thread_access );
    error_count += RUN_TEST( test_multi_thread_access );
#endif
    error_count += RUN_TEST( regression_svn1952 );
    error_count += RUN_TEST( regression_svn1958 );
    error_count += RUN_TEST( regression_svn1960 );
    if( !error_count )
        printf( "ALL TESTS PASSED\n" );
    else
        printf( "%d TESTS FAILED\n", error_count );
    return error_count;
void make_basic_sequence ( TypeSequenceManager &  seq,
EntitySequence *&  seq3to7,
EntitySequence *&  seq100to111,
EntitySequence *&  seq1001
Definition at line 172 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::EntitySequence::data(), moab::TypeSequenceManager::empty(), moab::TypeSequenceManager::end(), moab::EntitySequence::end_handle(), moab::TypeSequenceManager::get_number_entities(), insert_seq(), moab::EntitySequence::size(), and moab::EntitySequence::start_handle().
    CHECK( seqman.empty() );
    CHECK_EQUAL( (EntityID)0, seqman.get_number_entities() );
    SequenceData* data = new SequenceData( 0, 1, 22000 );CHECK_ERR( insert_seq( seqman, 3, 5, data ) );CHECK_ERR( insert_seq( seqman, 100, 12, data ) );CHECK_ERR( insert_seq( seqman, 1001, 1, data ) );
    CHECK( !seqman.empty() );
    CHECK_EQUAL( (EntityID)18, seqman.get_number_entities() );
    TypeSequenceManager::iterator iter = seqman.begin();
    CHECK( iter != seqman.end() );
    seq1 = *iter;
    CHECK_EQUAL( (EntityHandle)3, seq1->start_handle() );
    CHECK_EQUAL( (EntityHandle)7, seq1->end_handle() );
    CHECK_EQUAL( data, seq1->data() );
    CHECK_EQUAL( (EntityID)5, seq1->size() );
    ++iter;
    seq2 = *iter;
    CHECK_EQUAL( (EntityHandle)100, seq2->start_handle() );
    CHECK_EQUAL( (EntityHandle)111, seq2->end_handle() );
    CHECK_EQUAL( data, seq2->data() );
    CHECK_EQUAL( (EntityID)12, seq2->size() );
    ++iter;
    seq3 = *iter;
    CHECK_EQUAL( (EntityHandle)1001, seq3->start_handle() );
    CHECK_EQUAL( (EntityHandle)1001, seq3->end_handle() );
    CHECK_EQUAL( data, seq3->data() );
    CHECK_EQUAL( (EntityID)1, seq3->size() );
    ++iter;
    CHECK( iter == seqman.end() );
Definition at line 1149 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_ERR, moab::TypeSequenceManager::find_free_sequence(), and insert_seq().
Referenced by main().
    const EntityHandle last_handle = 50000;
    TypeSequenceManager seqman;
    SequenceData* data = new SequenceData( 0, 41673, last_handle );CHECK_ERR( insert_seq( seqman, 41686, 1000, data, true ) );
    SequenceData* result_data;
    EntityID result_size;
    EntityHandle result_handle;
    result_handle = seqman.find_free_sequence( 1686, 4000, 2 * last_handle, result_data, result_size );
    CHECK( result_handle > last_handle || result_handle + result_size <= 41673 );
    CHECK( result_handle + result_size <= 2 * last_handle );
Definition at line 1174 of file TestTypeSequenceManager.cpp.
    const int data_size           = 100;
    const EntityHandle data_start = 100;
    const EntityHandle data_end   = data_start + data_size - 1;
    const int seq_offset          = 2;
    SequenceData* data = new SequenceData( 0, data_start, data_end );CHECK_ERR( insert_seq( seqman, data_start + seq_offset, data_size - seq_offset, data, true ) );
    result_handle = seqman.find_free_sequence( data_start - 1, 1, 100000, result_data, result_size );
    CHECK( result_handle > data_end || result_handle + result_size <= data_start );
Definition at line 1198 of file TestTypeSequenceManager.cpp.
    const int data_size           = 6000;
    const EntityHandle data_start = 4000;
    const int seq_offset          = 1000;
    result_handle = seqman.find_free_sequence( data_start - 2, 1, 100000, result_data, result_size );
    CHECK( result_handle + result_size <= data_start );
bool seqman_equal ( const EntityHandle  pair_array[][2],
unsigned  num_pairs,
const TypeSequenceManager &  seqman
Definition at line 336 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), moab::EntitySequence::data(), moab::TypeSequenceManager::end(), moab::SequenceData::end_handle(), moab::EntitySequence::end_handle(), moab::ID_FROM_HANDLE(), moab::SequenceData::start_handle(), and moab::EntitySequence::start_handle().
Referenced by test_erase(), test_get_entities(), test_insert_sequence_merge(), test_insert_sequence_nomerge(), test_remove_sequence(), and test_replace_subsequence().
    unsigned i;
    TypeSequenceManager::const_iterator j = seqman.begin();
    EntitySequence* seq                   = 0;
    for( i = 0; i < num_pairs; ++i, ++j )
        if( j == seqman.end() ) break;
        if( seq && seq->end_handle() >= ( *j )->start_handle() )
            printf( "Sequence [%lu,%lu] overlaps sequence [%lu,%lu]\n",
                    (unsigned long)ID_FROM_HANDLE( seq->start_handle() ),
                    (unsigned long)ID_FROM_HANDLE( seq->end_handle() ),
                    (unsigned long)ID_FROM_HANDLE( ( *j )->start_handle() ),
                    (unsigned long)ID_FROM_HANDLE( ( *j )->end_handle() ) );
            return false;
        if( seq && seq->data() != ( *j )->data() && seq->data()->end_handle() >= ( *j )->data()->start_handle() )
            printf( "SequenceData [%lu,%lu] overlaps SequenceData [%lu,%lu]\n",
                    (unsigned long)ID_FROM_HANDLE( seq->data()->start_handle() ),
                    (unsigned long)ID_FROM_HANDLE( seq->data()->end_handle() ),
                    (unsigned long)ID_FROM_HANDLE( ( *j )->data()->start_handle() ),
                    (unsigned long)ID_FROM_HANDLE( ( *j )->data()->end_handle() ) );
            return false;
        seq = *j;
        if( seq->start_handle() > seq->end_handle() )
            printf( "Inverted sequence [%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( seq->start_handle() ),
                    (unsigned long)ID_FROM_HANDLE( seq->end_handle() ) );
            return false;
        if( pair_array[i][0] != seq->start_handle() || pair_array[i][1] != seq->end_handle() ) break;
        if( seq->data()->start_handle() > seq->start_handle() || seq->data()->end_handle() < seq->end_handle() )
            printf( "Sequence [%lu,%lu] has data [%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( seq->start_handle() ),
                    (unsigned long)ID_FROM_HANDLE( seq->data()->end_handle() ) );
            return false;
    if( i == num_pairs && j == seqman.end() ) return true;
    if( i < num_pairs )
        printf( "Sequence Mismatch: Expected: [%lu,%lu], got ", (unsigned long)ID_FROM_HANDLE( pair_array[i][0] ),
                (unsigned long)ID_FROM_HANDLE( pair_array[i][1] ) );
    else
        printf( "Sequence Mismatch: Expected END, got " );
        printf( "END.\n" );
    else
        printf( "[%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( ( *j )->start_handle() ),
    return false;
void test_basic ( )
Definition at line 213 of file TestTypeSequenceManager.cpp.
References make_basic_sequence().
void test_erase ( )
Definition at line 693 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::empty(), moab::TypeSequenceManager::erase(), make_basic_sequence(), MB_ENTITY_NOT_FOUND, and seqman_equal().
    make_basic_sequence( seqman );
    Error eh;
    // verify initial state
    EntityHandle exp1[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 } };
    CHECK( seqman_equal( exp1, 3, seqman ) );
    // try erasing invalid handles at start of existing sequence
    CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.erase( &eh, 1000, 1001 ) );
    // try erasing invalid entities at end of existing sequence
    CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.erase( &eh, 3, 8 ) );
    // erase from front of sequence
    CHECK_ERR( seqman.erase( &eh, 3, 6 ) );
    EntityHandle exp2[][2] = { { 7, 7 }, { 100, 111 }, { 1001, 1001 } };
    CHECK( seqman_equal( exp2, 3, seqman ) );
    // erase from end of sequence
    CHECK_ERR( seqman.erase( &eh, 110, 111 ) );
    EntityHandle exp3[][2] = { { 7, 7 }, { 100, 109 }, { 1001, 1001 } };
    CHECK( seqman_equal( exp3, 3, seqman ) );
    // erase from middle of sequence
    CHECK_ERR( seqman.erase( &eh, 105, 107 ) );
    EntityHandle exp4[][2] = { { 7, 7 }, { 100, 104 }, { 108, 109 }, { 1001, 1001 } };
    CHECK( seqman_equal( exp4, 4, seqman ) );
    // erase sequence
    CHECK_ERR( seqman.erase( &eh, 7, 7 ) );
    EntityHandle exp5[][2] = { { 100, 104 }, { 108, 109 }, { 1001, 1001 } };
    CHECK( seqman_equal( exp5, 3, seqman ) );
    // erase sequence
    CHECK_ERR( seqman.erase( &eh, 108, 109 ) );
    EntityHandle exp6[][2] = { { 100, 104 }, { 1001, 1001 } };
    CHECK( seqman_equal( exp6, 2, seqman ) );
    // erase sequence
    CHECK_ERR( seqman.erase( &eh, 100, 104 ) );
    EntityHandle exp7[][2] = { { 1001, 1001 } };
    CHECK( seqman_equal( exp7, 1, seqman ) );
    // erase sequence
    CHECK_ERR( seqman.erase( &eh, 1001, 1001 ) );
void test_find ( )
Definition at line 297 of file TestTypeSequenceManager.cpp.
References CHECK_EQUAL, moab::TypeSequenceManager::find(), and make_basic_sequence().
    EntitySequence *seq1,  // 3 to 7
        *seq2,             // 100 to 111
        *seq3,             // 1001
        *seq;
    make_basic_sequence( seqman, seq1, seq2, seq3 );
    seq = seqman.find( 2 );
    CHECK_EQUAL( NULL, seq );
    seq = seqman.find( 3 );
    CHECK_EQUAL( seq1, seq );
    seq = seqman.find( 4 );
    seq = seqman.find( 7 );
    seq = seqman.find( 8 );
    seq = seqman.find( 99 );
    seq = seqman.find( 100 );
    CHECK_EQUAL( seq2, seq );
    seq = seqman.find( 110 );
    seq = seqman.find( 111 );
    seq = seqman.find( 112 );
    seq = seqman.find( 1000 );
    seq = seqman.find( 1001 );
    CHECK_EQUAL( seq3, seq );
    seq = seqman.find( 1002 );
Definition at line 745 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::end(), moab::TypeSequenceManager::find_free_handle(), make_basic_sequence(), and MB_END_ID.
    bool append;
    TypeSequenceManager::iterator seq;
    make_basic_sequence( seqman );  // { [3,7], [100,111], [1001] }
    seq = seqman.find_free_handle( 0, MB_END_ID, append );
    CHECK( seq != seqman.end() );
    // expect the first available handle (2).
    CHECK_EQUAL( (EntityHandle)3, ( *seq )->start_handle() );
    CHECK_EQUAL( (EntityHandle)7, ( *seq )->end_handle() );
    CHECK( !append );
    // Expect end() if no adjacent sequence
    seq = seqman.find_free_handle( 9, 98, append );
    CHECK( seq == seqman.end() );
    // Try a limited handle range
    seq = seqman.find_free_handle( 8, 99, append );
    // expect the first available handle (8).
    CHECK( append );
    // Try an unambigious case (above tests have multiple
    // possible answers, were we assume the first available
    // handle).
    seq = seqman.find_free_handle( 8, 98, append );
    CHECK( append );
    // handle).
    seq = seqman.find_free_handle( 9, 99, append );
    CHECK_EQUAL( (EntityHandle)100, ( *seq )->start_handle() );
    CHECK_EQUAL( (EntityHandle)111, ( *seq )->end_handle() );
    CHECK( !append );
    // Try a case where the expected result handle
    // is in the middle of the input range.
    seq = seqman.find_free_handle( 900, 1100, append );
    CHECK_EQUAL( (EntityHandle)1001, ( *seq )->start_handle() );
    CHECK_EQUAL( (EntityHandle)1001, ( *seq )->end_handle() );
    // Expect first available handle
    CHECK( !append );
Definition at line 799 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, moab::TypeSequenceManager::find_free_sequence(), make_basic_sequence(), and MB_END_ID.
    EntityHandle start;
    SequenceData* data = 0;
    EntityID data_size = 0;
    SequenceData* expdata = ( *seqman.begin() )->data();
    start = seqman.find_free_sequence( 2, 1, 3, data, data_size );
    CHECK_EQUAL( expdata, data );
    CHECK_EQUAL( (EntityHandle)1, start );
    start = seqman.find_free_sequence( 3, 1, 7, data, data_size );
    CHECK_EQUAL( (EntityHandle)0, start );
    CHECK_EQUAL( NULL, data );
    start = seqman.find_free_sequence( 30, 1, 120, data, data_size );
    CHECK( start == 8 || start == 70 );
    start = seqman.find_free_sequence( 10, 92, 999, data, data_size );
    CHECK_EQUAL( (EntityHandle)112, start );
    start = seqman.find_free_sequence( 100, 1, 600, data, data_size );
    start = seqman.find_free_sequence( 1000, 1, MB_END_ID, data, data_size );
    CHECK_EQUAL( (EntityHandle)1002, start );
    start = seqman.find_free_sequence( 980, 1, 1800, data, data_size );
Definition at line 402 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::empty(), entities, moab::TypeSequenceManager::get_entities(), moab::TypeSequenceManager::get_number_entities(), make_basic_sequence(), and seqman_equal().
    Range entities;
    seqman.get_entities( entities );
    CHECK_EQUAL( (size_t)18, entities.size() );
    EntityHandle pairs[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 } };
    CHECK( seqman_equal( pairs, 3, seqman ) );
Definition at line 418 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, insert_seq(), make_basic_sequence(), MB_ALREADY_ALLOCATED, and seqman_equal().
    SequenceData* data = ( *seqman.begin() )->data();
    // append a sequence
    CHECK_ERR( insert_seq( seqman, 1003, 1, data ) );
    EntityHandle exp1[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 }, { 1003, 1003 } };
    CHECK( seqman_equal( exp1, 4, seqman ) );
    // prepend a sequence
    CHECK_ERR( insert_seq( seqman, 1, 1, data ) );
    EntityHandle exp2[][2] = { { 1, 1 }, { 3, 7 }, { 100, 111 }, { 1001, 1001 }, { 1003, 1003 } };
    CHECK( seqman_equal( exp2, 5, seqman ) );
    // insert sequence in middle
    CHECK_ERR( insert_seq( seqman, 150, 11, data ) );
    EntityHandle exp3[][2] = { { 1, 1 }, { 3, 7 }, { 100, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } };
    CHECK( seqman_equal( exp3, 6, seqman ) );
    // merge sequence with predecessor
    CHECK_ERR( insert_seq( seqman, 8, 13, data ) );
    EntityHandle exp4[][2] = { { 1, 1 }, { 3, 20 }, { 100, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } };
    CHECK( seqman_equal( exp4, 6, seqman ) );
    // merge sequence with following one
    CHECK_ERR( insert_seq( seqman, 87, 13, data ) );
    EntityHandle exp5[][2] = { { 1, 1 }, { 3, 20 }, { 87, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } };
    CHECK( seqman_equal( exp5, 6, seqman ) );
    // merge sequence with two adjacent ones
    CHECK_ERR( insert_seq( seqman, 2, 1, data ) );
    EntityHandle exp6[][2] = { { 1, 20 }, { 87, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } };
    CHECK( seqman_equal( exp6, 5, seqman ) );
    // try to insert a sequence that overlaps on the end
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, insert_seq( seqman, 900, 1001, data ) );
    // try to insert a sequence that overlaps at the start
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, insert_seq( seqman, 111, 140, data ) );
Definition at line 461 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::empty(), ErrorCode, insert_seq(), moab::TypeSequenceManager::insert_sequence(), MB_ALREADY_ALLOCATED, MB_SUCCESS, and seqman_equal().
    // make sure inserting a sequence w/out a SequenceData fails
    CHECK_EQUAL( MB_FAILURE, insert_seq( seqman, 1, 5, NULL ) );
    // Now set up a TypeSequenceManager for testing
    // Insert an EntitySequence for which the corresponding SequenceData
    // is exactly the same size.
    SequenceData* data1 = new SequenceData( 0, 3, 7 );
    DumSeq* seq         = new DumSeq( data1 );
    ErrorCode rval      = seqman.insert_sequence( seq );CHECK_ERR( rval );
        delete seq;
        delete data1;
        return;
    // Insert an EntitySequence with additional room on both ends of
    // the SequenceData
    SequenceData* data2 = new SequenceData( 0, 100, 999 );
    seq                 = new DumSeq( 200, 100, data2 );
        delete seq;
        delete data2;
        return;
    // Insert another EntitySequence sharing the previous SequenceData
    seq  = new DumSeq( 400, 100, data2 );
        delete seq;
        return;
    // Setup complete, begin tests
    // Test inserting sequence that appends an existing sequence
    // but overlaps underling SequenceData boundary
    SequenceData* data = new SequenceData( 0, 999, 1000 );
    seq                = new DumSeq( data );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, rval );
    delete seq;
    delete data;
    // Test inserting sequence that prepends an existing sequence
    data = new SequenceData( 0, 50, 199 );
    delete seq;
    delete data;
    // Test fits within existing, but has different SequenceData
    data = new SequenceData( 0, 500, 599 );
    delete seq;
    delete data;
    // Make sure we're starting out with what we expect
    EntityHandle exp1[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 } };
    // Test fits within existing, and has same data
    CHECK_ERR( insert_seq( seqman, 600, 100, data2 ) );
    EntityHandle exp2[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 }, { 600, 699 } };
    CHECK( seqman_equal( exp2, 4, seqman ) );
    // Test is entirely outside existing data
    CHECK_ERR( insert_seq( seqman, 2000, 2, new SequenceData( 0, 2000, 2001 ), true ) );
    EntityHandle exp3[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 }, { 600, 699 }, { 2000, 2001 } };
    CHECK( seqman_equal( exp3, 5, seqman ) );
    // Test abutts end of existing data
    CHECK_ERR( insert_seq( seqman, 1000, 6, new SequenceData( 0, 1000, 1005 ), true ) );
    EntityHandle exp4[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 }, { 600, 699 }, { 1000, 1005 }, { 2000, 2001 } };
    // Test abutts beginning of existing data
    CHECK_ERR( insert_seq( seqman, 50, 50, new SequenceData( 0, 50, 99 ), true ) );
    EntityHandle exp5[][2] = { { 3, 7 },     { 50, 99 },     { 200, 299 },  { 400, 499 },
    CHECK( seqman_equal( exp5, 7, seqman ) );
Definition at line 861 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::end(), ErrorCode, moab::GeomUtil::first(), insert_seq(), moab::TypeSequenceManager::is_free_handle(), MB_ALREADY_ALLOCATED, MB_END_ID, and MB_SUCCESS.
    // Construct a TypeSequenceManager with the following data:
    // EntitySequence: |[1,500]|   |[601,1000]|       |[2500,2599]|    |[2800,2999]|
    // SequenceData:   |       [1,1000]       |    |         [2001,3000]            |
    ErrorCode rval;
    SequenceData* data1 = new SequenceData( 0, 1, 1000 );
    SequenceData* data2 = new SequenceData( 0, 2001, 3000 );
    rval                = insert_seq( seqman, 1, 500, data1, true );CHECK_ERR( rval );
        // data1 has been deleted by insert_seq call above
        return;
    rval = insert_seq( seqman, 601, 400, data1, false );CHECK_ERR( rval );
    rval = insert_seq( seqman, 2500, 100, data2, true );CHECK_ERR( rval );
        // data2 has been deleted by insert_seq call above
        return;
    rval = insert_seq( seqman, 2800, 200, data2, false );CHECK_ERR( rval );
    // Begin tests
    SequenceData* data;
    EntityHandle first, last;
    // Test handle in use
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 1, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 300, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 500, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 601, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2500, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2599, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2800, seq, data, first, last ) );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2999, seq, data, first, last ) );
    // Test prepend to sequence
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 600, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)601, ( *seq )->start_handle() );
    CHECK_EQUAL( data1, data );
    CHECK_EQUAL( (EntityHandle)600, first );
    CHECK_EQUAL( (EntityHandle)600, last );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 2499, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)2500, ( *seq )->start_handle() );
    CHECK_EQUAL( data2, data );
    CHECK_EQUAL( (EntityHandle)2499, first );
    CHECK_EQUAL( (EntityHandle)2499, last );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 2799, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)2800, ( *seq )->start_handle() );
    CHECK_EQUAL( (EntityHandle)2799, first );
    CHECK_EQUAL( (EntityHandle)2799, last );
    // Test append to sequence
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 501, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)1, ( *seq )->start_handle() );
    CHECK_EQUAL( (EntityHandle)501, first );
    CHECK_EQUAL( (EntityHandle)501, last );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 2600, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)2600, first );
    CHECK_EQUAL( (EntityHandle)2600, last );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 3000, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)3000, first );
    CHECK_EQUAL( (EntityHandle)3000, last );
    // Test new sequence in existing SequenceData
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 502, seq, data, first, last ) );
    CHECK( seqman.end() == seq );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 599, seq, data, first, last ) );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 2001, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)2001, first );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 2498, seq, data, first, last ) );
    // Test new SequenceData
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 1001, seq, data, first, last ) );
    CHECK_EQUAL( (SequenceData*)0, data );
    CHECK_EQUAL( (EntityHandle)1001, first );
    CHECK_EQUAL( (EntityHandle)2000, last );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 1500, seq, data, first, last ) );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 2000, seq, data, first, last ) );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 3001, seq, data, first, last ) );
    CHECK_EQUAL( (EntityHandle)3001, first );
    CHECK_EQUAL( (EntityHandle)MB_END_ID, last );
    seq   = seqman.end();
    data  = 0;
    first = last = 0;
    CHECK( seqman.is_free_handle( 10000, seq, data, first, last ) );
Definition at line 837 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, moab::TypeSequenceManager::is_free_sequence(), and make_basic_sequence().
    CHECK( !seqman.is_free_sequence( 1, 3, data ) );
    CHECK( seqman.is_free_sequence( 1, 2, data ) );
    CHECK( !seqman.is_free_sequence( 7, 93, data ) );
    CHECK( !seqman.is_free_sequence( 8, 93, data ) );
    CHECK( seqman.is_free_sequence( 8, 92, data ) );
    CHECK( !seqman.is_free_sequence( 111, 890, data ) );
    CHECK( !seqman.is_free_sequence( 112, 890, data ) );
    CHECK( seqman.is_free_sequence( 112, 879, data ) );
    CHECK( seqman.is_free_sequence( 1002, 1, data ) );
    CHECK( seqman.is_free_sequence( 2000, 20000, data ) );
void test_lower_bound ( )
Definition at line 219 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::end(), moab::TypeSequenceManager::lower_bound(), and make_basic_sequence().
    TypeSequenceManager::const_iterator i;
        *seq3;             // 1001
    i = seqman.lower_bound( 2 );
    CHECK_EQUAL( seq1, *i );
    i = seqman.lower_bound( 3 );
    i = seqman.lower_bound( 4 );
    i = seqman.lower_bound( 7 );
    i = seqman.lower_bound( 8 );
    CHECK_EQUAL( seq2, *i );
    i = seqman.lower_bound( 99 );
    i = seqman.lower_bound( 100 );
    i = seqman.lower_bound( 110 );
    i = seqman.lower_bound( 111 );
    i = seqman.lower_bound( 112 );
    CHECK_EQUAL( seq3, *i );
    i = seqman.lower_bound( 1000 );
    i = seqman.lower_bound( 1001 );
    i = seqman.lower_bound( 1002 );
    CHECK( i == seqman.end() );
Definition at line 1124 of file TestTypeSequenceManager.cpp.
References test_threaded_access().
Definition at line 558 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::EntitySequence::data(), make_basic_sequence(), MB_ENTITY_NOT_FOUND, moab::TypeSequenceManager::remove_sequence(), and seqman_equal().
        *seq3;             // 1001
    // test removing something that hasn't been inserted
    bool last;
    DumSeq junk( 3, 5, NULL );
    CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.remove_sequence( &junk, last ) );
    // remove the middle sequence
    CHECK_ERR( seqman.remove_sequence( seq2, last ) );
    CHECK( !last );
    delete seq2;
    // remove the first sequence
    CHECK_ERR( seqman.remove_sequence( seq1, last ) );
    CHECK( !last );
    delete seq1;
    // remove the last sequence
    CHECK_ERR( seqman.remove_sequence( seq3, last ) );
    CHECK( last );
    SequenceData* data = seq3->data();
    delete seq3;
    delete data;
Definition at line 591 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, ErrorCode, insert_seq(), MB_SUCCESS, moab::TypeSequenceManager::replace_subsequence(), and seqman_equal().
    ErrorCode rval;
    // create an initial set
    SequenceData* data1 = new SequenceData( 0, 51, 950 );
    rval                = insert_seq( seqman, 101, 100, data1, true );CHECK_ERR( rval );
        return;
    rval = insert_seq( seqman, 301, 300, data1 );CHECK_ERR( rval );
    rval = insert_seq( seqman, 701, 100, data1 );CHECK_ERR( rval );
    // try a sequence that is outside all existing data
    SequenceData* data = new SequenceData( 0, 10, 20 );
    DumSeq* seq        = new DumSeq( data );
    rval               = seqman.replace_subsequence( seq, 0, 0 );
    CHECK_EQUAL( MB_FAILURE, rval );
    delete seq;
    delete data;
    // try a sequence that overlaps the start of the data
    data = new SequenceData( 0, 40, 60 );
    delete seq;
    delete data;
    // try a sequence that is within the data but not within any sequence
    data = new SequenceData( 0, 60, 70 );
    delete seq;
    delete data;
    // try a sequence that overlaps an existing sequence
    data = new SequenceData( 0, 60, 101 );
    delete seq;
    delete data;
    // try a sequence that should work, but with a SequenceData that
    // overlaps an existing sequence
    data = new SequenceData( 0, 150, 200 );
    seq  = new DumSeq( 190, 200, data );
    delete seq;
    delete data;
    // check that we're starting with what we expect
    EntityHandle exp1[][2] = { { 101, 200 }, { 301, 600 }, { 701, 800 } };
    // split at start of sequence
    data = new SequenceData( 0, 101, 105 );
    rval = seqman.replace_subsequence( seq, 0, 0 );CHECK_ERR( rval );
        delete seq;
        delete data;
        return;
    EntityHandle exp2[][2] = { { 101, 105 }, { 106, 200 }, { 301, 600 }, { 701, 800 } };
    // split at end of sequence
    data = new SequenceData( 0, 750, 800 );
        delete seq;
        delete data;
        return;
    EntityHandle exp3[][2] = { { 101, 105 }, { 106, 200 }, { 301, 600 }, { 701, 749 }, { 750, 800 } };
    // split at middle of sequence
    data = new SequenceData( 0, 400, 499 );
        delete seq;
        delete data;
        return;
    EntityHandle exp4[][2] = { { 101, 105 }, { 106, 200 }, { 301, 399 }, { 400, 499 },
                               { 500, 600 }, { 701, 749 }, { 750, 800 } };
    CHECK( seqman_equal( exp4, 7, seqman ) );
Definition at line 1119 of file TestTypeSequenceManager.cpp.
void test_threaded_access ( int  n_threads)
Definition at line 1075 of file TestTypeSequenceManager.cpp.
References call_find(), CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::erase(), and insert_seq().
Referenced by test_multi_thread_access(), and test_single_thread_access().
    std::set< int > removed_indices;
    // create a sequence from start to end
    EntityHandle start = 1, end = 200000;
    int i_end          = end;
    SequenceData* data = new SequenceData( 0, start, end );CHECK_ERR( insert_seq( seqman, start, end, data ) );
    // erase one hundred random entities from the sequence
    // to ensure a lot of switching of TypeSequenceManager::lastReferenced
    Error e;
    for( int i = 0; i < 100; i++ )
        int idx = ( (double)rand() / RAND_MAX * i_end ) + 1;
        removed_indices.insert( idx );
        seqman.erase( &e, idx );
    // create a set of quereies per thread
    std::vector< std::thread > threads;
    std::vector< int > failures( n_threads, 0 );
    for( int i = 0; i < n_threads; i++ )
        threads.push_back( std::thread( call_find, &seqman, removed_indices, i_end, std::ref< int >( failures[i] ) ) );
    // wait for threads to finish
    for( size_t i = 0; i < threads.size(); i++ )
        threads[i].join();
    int n_failures = 0;
    for( size_t i = 0; i < failures.size(); i++ )
        n_failures += failures[i];
    if( n_failures > 0 )
        std::cout << n_failures << " invalid sequences found." << std::endl;
    CHECK_EQUAL( 0, n_failures );
void test_upper_bound ( )
Definition at line 259 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::end(), make_basic_sequence(), and moab::TypeSequenceManager::upper_bound().
        *seq3;             // 1001
    i = seqman.upper_bound( 2 );
    i = seqman.upper_bound( 3 );
    i = seqman.upper_bound( 4 );
    i = seqman.upper_bound( 7 );
    i = seqman.upper_bound( 8 );
    i = seqman.upper_bound( 99 );
    i = seqman.upper_bound( 100 );
    i = seqman.upper_bound( 110 );
    i = seqman.upper_bound( 111 );
    i = seqman.upper_bound( 112 );
    i = seqman.upper_bound( 1000 );
    i = seqman.upper_bound( 1001 );
