MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /** 00017 * \class AffineXform 00018 * \brief Define an affine transformatino 00019 * \author Jason Kraftcheck ([email protected]) 00020 * \date August, 2006 00021 */ 00022 00023 #ifdef _WIN32 00024 #define _USE_MATH_DEFINES 00025 #endif 00026 00027 #include "AffineXform.hpp" 00028 #include "moab/Interface.hpp" 00029 #include <cassert> 00030 00031 /* 00032 namespace moab { 00033 00034 AffineXform AffineXform::rotation( const double* from_vec, const double* to_vec ) 00035 { 00036 CartVect from(from_vec); 00037 CartVect to(to_vec); 00038 CartVect a = from * to; 00039 double len = a.length(); 00040 00041 // If input vectors are not parallel (the normal case) 00042 if (len >= std::numeric_limits<double>::epsilon()) { 00043 from.normalize(); 00044 to.normalize(); 00045 return rotation( from % to, (from * to).length(), a/len ); 00046 } 00047 00048 // Vectors are parallel: 00049 // 00050 // If vectors are in same direction then rotation is identity (no transform) 00051 if (from % to >= 0.0) 00052 return AffineXform(); 00053 00054 // Parallel vectors in opposite directions: 00055 // 00056 // NOTE: This case is ill-defined. There are infinitely 00057 // many rotations that can align the two vectors. The angle 00058 // of rotation is 180 degrees, but the axis of rotation may 00059 // be any unit vector orthogonal to the input vectors. 00060 // 00061 from.normalize(); 00062 double lenxy = std::sqrt( from[0]*from[0] + from[1]*from[1] ); 00063 CartVect axis( -from[0]*from[2]/lenxy, 00064 -from[1]*from[2]/lenxy, 00065 lenxy ); 00066 return rotation( -1, 0, axis ); 00067 } 00068 00069 00070 } // namespace moab 00071 */ 00072 00073 using namespace moab; 00074 00075 #include <iostream> 00076 #define ASSERT_VECTORS_EQUAL( A, B ) assert_vectors_equal( ( A ), ( B ), #A, #B, __LINE__ ) 00077 #define ASSERT_DOUBLES_EQUAL( A, B ) assert_doubles_equal( ( A ), ( B ), #A, #B, __LINE__ ) 00078 #define ASSERT( B ) assert_bool( ( B ), #B, __LINE__ ) 00079 00080 const double TOL = 1e-6; 00081 00082 int error_count = 0; 00083 00084 void assert_vectors_equal( const double* a, const double* b, const char* sa, const char* sb, int lineno ) 00085 { 00086 if( fabs( a[0] - b[0] ) > TOL || fabs( a[1] - b[1] ) > TOL || fabs( a[2] - b[2] ) > TOL ) 00087 { 00088 std::cerr << "Assertion failed at line " << lineno << std::endl 00089 << "\t" << sa << " == " << sb << std::endl 00090 << "\t[" << a[0] << ", " << a[1] << ", " << a[2] << "] == [" << b[0] << ", " << b[1] << ", " << b[2] 00091 << "]" << std::endl; 00092 ++error_count; 00093 } 00094 } 00095 00096 void assert_vectors_equal( const CartVect& a, const CartVect& b, const char* sa, const char* sb, int lineno ) 00097 { 00098 assert_vectors_equal( a.array(), b.array(), sa, sb, lineno ); 00099 } 00100 00101 void assert_doubles_equal( double a, double b, const char* sa, const char* sb, int lineno ) 00102 { 00103 if( fabs( a - b ) > TOL ) 00104 { 00105 std::cerr << "Assertion failed at line " << lineno << std::endl 00106 << "\t" << sa << " == " << sb << std::endl 00107 << "\t" << a << " == " << b << std::endl; 00108 ++error_count; 00109 } 00110 } 00111 00112 void assert_bool( bool b, const char* sb, int lineno ) 00113 { 00114 if( !b ) 00115 { 00116 std::cerr << "Assertion failed at line " << lineno << std::endl << "\t" << sb << std::endl; 00117 ++error_count; 00118 } 00119 } 00120 00121 const CartVect point1( 0.0, 0.0, 0.0 ), point2( 3.5, 1000, -200 ); 00122 const CartVect vect1( 0.0, 0.0, -100.0 ), vect2( 1.0, 0.0, 1.0 ); 00123 00124 void test_none() 00125 { 00126 // default xform should do nothing. 00127 CartVect output; 00128 AffineXform none; 00129 none.xform_point( point1.array(), output.array() ); 00130 ASSERT_VECTORS_EQUAL( output, point1 ); 00131 none.xform_point( point2.array(), output.array() ); 00132 ASSERT_VECTORS_EQUAL( output, point2 ); 00133 none.xform_vector( vect1.array(), output.array() ); 00134 ASSERT_VECTORS_EQUAL( output, vect1 ); 00135 none.xform_vector( vect2.array(), output.array() ); 00136 ASSERT_VECTORS_EQUAL( output, vect2 ); 00137 } 00138 00139 void test_translation() 00140 { 00141 CartVect offset( 1.0, 2.0, 3.0 ); 00142 CartVect output; 00143 00144 AffineXform move = AffineXform::translation( offset.array() ); 00145 00146 // test that points are moved by offset 00147 move.xform_point( point1.array(), output.array() ); 00148 ASSERT_VECTORS_EQUAL( output, point1 + offset ); 00149 move.xform_point( point2.array(), output.array() ); 00150 ASSERT_VECTORS_EQUAL( output, point2 + offset ); 00151 00152 // vectors should not be changed by a translation 00153 move.xform_vector( vect1.array(), output.array() ); 00154 ASSERT_VECTORS_EQUAL( output, vect1 ); 00155 move.xform_vector( vect2.array(), output.array() ); 00156 ASSERT_VECTORS_EQUAL( output, vect2 ); 00157 } 00158 00159 void test_rotation() 00160 { 00161 CartVect output; 00162 00163 // rotate 90 degress about Z axis 00164 00165 AffineXform rot = AffineXform::rotation( M_PI / 2.0, CartVect( 0, 0, 1 ).array() ); 00166 ASSERT_DOUBLES_EQUAL( rot.matrix().determinant(), 1.0 ); 00167 00168 rot.xform_point( point1.array(), output.array() ); 00169 ASSERT_VECTORS_EQUAL( output, point1 ); // origin not affected by transform 00170 00171 CartVect expectedz( -point2[1], point2[0], point2[2] ); // in first quadrant 00172 rot.xform_point( point2.array(), output.array() ); 00173 ASSERT_DOUBLES_EQUAL( output.length(), point2.length() ); 00174 ASSERT_VECTORS_EQUAL( output, expectedz ); 00175 00176 rot.xform_vector( vect1.array(), output.array() ); 00177 ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() ); 00178 ASSERT_VECTORS_EQUAL( output, vect1 ); 00179 00180 rot.xform_vector( vect2.array(), output.array() ); 00181 ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() ); 00182 ASSERT_VECTORS_EQUAL( output, CartVect( 0, 1, 1 ) ); 00183 00184 // rotate 90 degress about Y axis 00185 00186 rot = AffineXform::rotation( M_PI / 2.0, CartVect( 0, 1, 0 ).array() ); 00187 ASSERT_DOUBLES_EQUAL( rot.matrix().determinant(), 1.0 ); 00188 00189 rot.xform_point( point1.array(), output.array() ); 00190 ASSERT_VECTORS_EQUAL( output, point1 ); // origin not affected by transform 00191 00192 CartVect expectedy( point2[2], point2[1], -point2[0] ); // in second quadrant 00193 rot.xform_point( point2.array(), output.array() ); 00194 ASSERT_DOUBLES_EQUAL( output.length(), point2.length() ); 00195 ASSERT_VECTORS_EQUAL( output, expectedy ); 00196 00197 rot.xform_vector( vect1.array(), output.array() ); 00198 ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() ); 00199 ASSERT_VECTORS_EQUAL( output, CartVect( -100, 0, 0 ) ); 00200 00201 rot.xform_vector( vect2.array(), output.array() ); 00202 ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() ); 00203 ASSERT_VECTORS_EQUAL( output, CartVect( 1, 0, -1 ) ); 00204 00205 // rotate 90 degress about X axis 00206 00207 rot = AffineXform::rotation( M_PI / 2.0, CartVect( 1, 0, 0 ).array() ); 00208 ASSERT_DOUBLES_EQUAL( rot.matrix().determinant(), 1.0 ); 00209 00210 rot.xform_point( point1.array(), output.array() ); 00211 ASSERT_VECTORS_EQUAL( output, point1 ); // origin not affected by transform 00212 00213 CartVect expectedx( point2[0], -point2[2], point2[1] ); // in third quadrant 00214 rot.xform_point( point2.array(), output.array() ); 00215 ASSERT_DOUBLES_EQUAL( output.length(), point2.length() ); 00216 ASSERT_VECTORS_EQUAL( output, expectedx ); 00217 00218 rot.xform_vector( vect1.array(), output.array() ); 00219 ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() ); 00220 ASSERT_VECTORS_EQUAL( output, CartVect( 0, 100, 0 ) ); 00221 00222 rot.xform_vector( vect2.array(), output.array() ); 00223 ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() ); 00224 ASSERT_VECTORS_EQUAL( output, CartVect( 1, -1, 0 ) ); 00225 00226 // rotate 180 degrees about vector in XY plane 00227 00228 rot = AffineXform::rotation( M_PI, CartVect( 1, 1, 0 ).array() ); 00229 ASSERT_DOUBLES_EQUAL( rot.matrix().determinant(), 1.0 ); 00230 00231 rot.xform_point( point1.array(), output.array() ); 00232 ASSERT_VECTORS_EQUAL( output, point1 ); // origin not affected by transform 00233 00234 rot.xform_point( point2.array(), output.array() ); 00235 ASSERT_DOUBLES_EQUAL( output.length(), point2.length() ); 00236 ASSERT_VECTORS_EQUAL( output, CartVect( point2[1], point2[0], -point2[2] ) ); 00237 00238 rot.xform_vector( vect1.array(), output.array() ); 00239 ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() ); 00240 ASSERT_VECTORS_EQUAL( output, -vect1 ); // vector is in xy plane 00241 00242 rot.xform_vector( vect2.array(), output.array() ); 00243 ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() ); 00244 ASSERT_VECTORS_EQUAL( output, CartVect( 0, 1, -1 ) ); 00245 } 00246 00247 void test_rotation_from_vec() 00248 { 00249 CartVect v1( 1, 1, 1 ); 00250 CartVect v2( 1, 0, 0 ); 00251 AffineXform rot = AffineXform::rotation( v1.array(), v2.array() ); 00252 CartVect result; 00253 rot.xform_vector( v1.array(), result.array() ); 00254 // vectors should be parallel, but not same length 00255 ASSERT_DOUBLES_EQUAL( result.length(), v1.length() ); 00256 result.normalize(); 00257 ASSERT_VECTORS_EQUAL( result, v2 ); 00258 00259 double v3[] = { -1, 0, 0 }; 00260 rot = AffineXform::rotation( v3, v2.array() ); 00261 rot.xform_vector( v3, result.array() ); 00262 ASSERT_VECTORS_EQUAL( result, v2 ); 00263 } 00264 00265 CartVect refl( const CartVect& vect, const CartVect& norm ) 00266 { 00267 CartVect n( norm ); 00268 n.normalize(); 00269 double d = vect % n; 00270 return vect - 2 * d * n; 00271 } 00272 00273 void test_reflection() 00274 { 00275 CartVect output; 00276 00277 // reflect about XY plane 00278 AffineXform ref = AffineXform::reflection( CartVect( 0, 0, 1 ).array() ); 00279 ASSERT_DOUBLES_EQUAL( ref.matrix().determinant(), -1.0 ); 00280 ref.xform_point( point1.array(), output.array() ); 00281 ASSERT_VECTORS_EQUAL( output, point1 ); 00282 ref.xform_point( point2.array(), output.array() ); 00283 ASSERT_DOUBLES_EQUAL( output.length(), point2.length() ); 00284 ASSERT_VECTORS_EQUAL( output, CartVect( point2[0], point2[1], -point2[2] ) ); 00285 ref.xform_vector( vect1.array(), output.array() ); 00286 ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() ); 00287 ASSERT_VECTORS_EQUAL( output, -vect1 ); 00288 ref.xform_vector( vect2.array(), output.array() ); 00289 ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() ); 00290 ASSERT_VECTORS_EQUAL( output, CartVect( 1, 0, -1 ) ); 00291 00292 // reflect about arbitrary palne 00293 CartVect norm( 3, 2, 1 ); 00294 ref = AffineXform::reflection( norm.array() ); 00295 ASSERT_DOUBLES_EQUAL( ref.matrix().determinant(), -1.0 ); 00296 ref.xform_point( point1.array(), output.array() ); 00297 ASSERT_VECTORS_EQUAL( output, point1 ); 00298 ref.xform_point( point2.array(), output.array() ); 00299 ASSERT_DOUBLES_EQUAL( output.length(), point2.length() ); 00300 ASSERT_VECTORS_EQUAL( output, refl( point2, norm ) ); 00301 ref.xform_vector( vect1.array(), output.array() ); 00302 ASSERT_DOUBLES_EQUAL( output.length(), vect1.length() ); 00303 ASSERT_VECTORS_EQUAL( output, refl( vect1, norm ) ); 00304 ref.xform_vector( vect2.array(), output.array() ); 00305 ASSERT_DOUBLES_EQUAL( output.length(), vect2.length() ); 00306 ASSERT_VECTORS_EQUAL( output, refl( vect2, norm ) ); 00307 } 00308 00309 void test_scale() 00310 { 00311 CartVect output; 00312 00313 AffineXform scale = AffineXform::scale( 1.0 ); 00314 ASSERT( !scale.scale() ); 00315 scale = AffineXform::scale( -1.0 ); 00316 ASSERT( !scale.scale() ); 00317 00318 // scale in X only 00319 scale = AffineXform::scale( CartVect( 2, 1, 1 ).array() ); 00320 ASSERT( scale.scale() ); 00321 scale.xform_point( point1.array(), output.array() ); 00322 ASSERT_VECTORS_EQUAL( output, CartVect( 2 * point1[0], point1[1], point1[2] ) ); 00323 scale.xform_point( point2.array(), output.array() ); 00324 ASSERT_VECTORS_EQUAL( output, CartVect( 2 * point2[0], point2[1], point2[2] ) ); 00325 scale.xform_vector( vect1.array(), output.array() ); 00326 ASSERT_VECTORS_EQUAL( output, CartVect( 2 * vect1[0], vect1[1], vect1[2] ) ); 00327 scale.xform_vector( vect2.array(), output.array() ); 00328 ASSERT_VECTORS_EQUAL( output, CartVect( 2 * vect2[0], vect2[1], vect2[2] ) ); 00329 00330 // scale in all 00331 scale = AffineXform::scale( CartVect( 0.5, 0.5, 0.5 ).array() ); 00332 ASSERT( scale.scale() ); 00333 scale.xform_point( point1.array(), output.array() ); 00334 ASSERT_VECTORS_EQUAL( output, 0.5 * point1 ); 00335 scale.xform_point( point2.array(), output.array() ); 00336 ASSERT_VECTORS_EQUAL( output, 0.5 * point2 ); 00337 scale.xform_vector( vect1.array(), output.array() ); 00338 ASSERT_VECTORS_EQUAL( output, 0.5 * vect1 ); 00339 scale.xform_vector( vect2.array(), output.array() ); 00340 ASSERT_VECTORS_EQUAL( output, 0.5 * vect2 ); 00341 } 00342 00343 void test_scale_point() 00344 { 00345 const double point[] = { 2, 3, 4 }; 00346 const double f[] = { 0.2, 0.1, 0.3 }; 00347 double result[3]; 00348 AffineXform scale = AffineXform::scale( f, point ); 00349 scale.xform_point( point, result ); 00350 ASSERT_VECTORS_EQUAL( result, point ); 00351 00352 const double delta[3] = { 1, 0, 2 }; 00353 const double pt2[] = { point[0] + delta[0], point[1] + delta[1], point[2] + delta[2] }; 00354 scale = AffineXform::scale( f, point ); 00355 scale.xform_point( pt2, result ); 00356 00357 const double expected[] = { point[0] + f[0] * delta[0], point[1] + f[1] * delta[1], point[2] + f[2] * delta[2] }; 00358 ASSERT_VECTORS_EQUAL( result, expected ); 00359 } 00360 00361 void test_accumulate() 00362 { 00363 CartVect indiv, accum; 00364 00365 // build an group of transforms. make sure translation is somewhere in the middle 00366 AffineXform move, scal, rot1, rot2, refl; 00367 move = AffineXform::translation( CartVect( 5, -5, 1 ).array() ); 00368 scal = AffineXform::scale( CartVect( 1, 0.5, 2 ).array() ); 00369 rot1 = AffineXform::rotation( M_PI / 3, CartVect( 0.5, 0.5, 1 ).array() ); 00370 rot2 = AffineXform::rotation( M_PI / 4, CartVect( 1.0, 0.0, 0.0 ).array() ); 00371 refl = AffineXform::reflection( CartVect( -1, -1, 0 ).array() ); 00372 AffineXform accu; 00373 accu.accumulate( scal ); 00374 accu.accumulate( rot1 ); 00375 accu.accumulate( move ); 00376 accu.accumulate( refl ); 00377 accu.accumulate( rot2 ); 00378 00379 accu.xform_point( point1.array(), accum.array() ); 00380 scal.xform_point( point1.array(), indiv.array() ); 00381 rot1.xform_point( indiv.array() ); 00382 move.xform_point( indiv.array() ); 00383 refl.xform_point( indiv.array() ); 00384 rot2.xform_point( indiv.array() ); 00385 ASSERT_VECTORS_EQUAL( accum, indiv ); 00386 00387 accu.xform_point( point2.array(), accum.array() ); 00388 scal.xform_point( point2.array(), indiv.array() ); 00389 rot1.xform_point( indiv.array() ); 00390 move.xform_point( indiv.array() ); 00391 refl.xform_point( indiv.array() ); 00392 rot2.xform_point( indiv.array() ); 00393 ASSERT_VECTORS_EQUAL( accum, indiv ); 00394 00395 accu.xform_vector( vect1.array(), accum.array() ); 00396 scal.xform_vector( vect1.array(), indiv.array() ); 00397 rot1.xform_vector( indiv.array() ); 00398 move.xform_vector( indiv.array() ); 00399 refl.xform_vector( indiv.array() ); 00400 rot2.xform_vector( indiv.array() ); 00401 ASSERT_VECTORS_EQUAL( accum, indiv ); 00402 00403 accu.xform_vector( vect2.array(), accum.array() ); 00404 scal.xform_vector( vect2.array(), indiv.array() ); 00405 rot1.xform_vector( indiv.array() ); 00406 move.xform_vector( indiv.array() ); 00407 refl.xform_vector( indiv.array() ); 00408 rot2.xform_vector( indiv.array() ); 00409 ASSERT_VECTORS_EQUAL( accum, indiv ); 00410 } 00411 00412 void test_inversion() 00413 { 00414 CartVect result; 00415 00416 // build an group of transforms. make sure translation is somewhere in the middle 00417 AffineXform move, scal, rot1, rot2, refl; 00418 move = AffineXform::translation( CartVect( 5, -5, 1 ).array() ); 00419 scal = AffineXform::scale( CartVect( 1, 0.5, 2 ).array() ); 00420 rot1 = AffineXform::rotation( M_PI / 3, CartVect( 0.5, 0.5, 1 ).array() ); 00421 rot2 = AffineXform::rotation( M_PI / 4, CartVect( 1.0, 0.0, 0.0 ).array() ); 00422 refl = AffineXform::reflection( CartVect( -1, -1, 0 ).array() ); 00423 AffineXform acc; 00424 acc.accumulate( scal ); 00425 acc.accumulate( rot1 ); 00426 acc.accumulate( move ); 00427 acc.accumulate( refl ); 00428 acc.accumulate( rot2 ); 00429 00430 AffineXform inv = acc.inverse(); 00431 00432 acc.xform_point( point1.array(), result.array() ); 00433 inv.xform_point( result.array() ); 00434 ASSERT_VECTORS_EQUAL( point1, result ); 00435 00436 acc.xform_point( point2.array(), result.array() ); 00437 inv.xform_point( result.array() ); 00438 ASSERT_VECTORS_EQUAL( point2, result ); 00439 00440 acc.xform_vector( vect1.array(), result.array() ); 00441 inv.xform_vector( result.array() ); 00442 ASSERT_VECTORS_EQUAL( vect1, result ); 00443 00444 acc.xform_vector( vect2.array(), result.array() ); 00445 inv.xform_vector( result.array() ); 00446 ASSERT_VECTORS_EQUAL( vect2, result ); 00447 } 00448 00449 void test_is_reflection() 00450 { 00451 AffineXform refl1, refl2, scale; 00452 refl1 = AffineXform::reflection( CartVect( -1, -1, 0 ).array() ); 00453 refl2 = AffineXform::reflection( CartVect( 1, 0, 0 ).array() ); 00454 scale = AffineXform::scale( CartVect( -1, 1, 1 ).array() ); 00455 00456 ASSERT( refl1.reflection() ); 00457 ASSERT( refl2.reflection() ); 00458 ASSERT( scale.reflection() ); 00459 00460 AffineXform inv1, inv2, inv3; 00461 inv1 = refl1.inverse(); 00462 inv2 = refl2.inverse(); 00463 inv3 = scale.inverse(); 00464 00465 ASSERT( inv1.reflection() ); 00466 ASSERT( inv2.reflection() ); 00467 ASSERT( inv3.reflection() ); 00468 00469 refl1.accumulate( refl2 ); 00470 refl2.accumulate( scale ); 00471 ASSERT( !refl1.reflection() ); 00472 ASSERT( !refl2.reflection() ); 00473 00474 AffineXform rot, mov; 00475 rot = AffineXform::rotation( M_PI / 4, CartVect( 1, 1, 1 ).array() ); 00476 mov = AffineXform::translation( CartVect( -5, 6, 7 ).array() ); 00477 ASSERT( !rot.reflection() ); 00478 ASSERT( !mov.reflection() ); 00479 } 00480 00481 int main() 00482 { 00483 test_none(); 00484 test_translation(); 00485 test_rotation(); 00486 test_reflection(); 00487 test_rotation_from_vec(); 00488 test_scale(); 00489 test_scale_point(); 00490 test_accumulate(); 00491 test_inversion(); 00492 test_is_reflection(); 00493 return error_count; 00494 }
