MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestRunner.hpp"#include "iMesh.h"#include "iMesh_extensions.h"#include "MBiMesh.hpp"#include "moab/Core.hpp"#include <algorithm>
Include dependency graph for MOAB_iMesh_extensions_tests.cpp:Go to the source code of this file.
Functions | |
| void | test_tag_iterate () |
| void | test_step_iter () |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 11 of file MOAB_iMesh_extensions_tests.cpp.
References REGISTER_TEST, RUN_TESTS, test_step_iter(), and test_tag_iterate().
REGISTER_TEST( test_tag_iterate );
REGISTER_TEST( test_step_iter );
return RUN_TESTS( argc, argv );
| void test_step_iter | ( | ) |
Definition at line 96 of file MOAB_iMesh_extensions_tests.cpp.
References CHECK_EQUAL, iBase_ALL_TYPES, iBase_FAILURE, iBase_INTERLEAVED, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_createVtxArr, iMesh_dtor, iMesh_endEntArrIter, iMesh_endEntIter, iMesh_getRootSet, iMesh_initEntArrIter, iMesh_initEntIter, iMesh_newMesh, iMesh_stepEntArrIter, iMesh_stepEntIter, mesh, and root_set.
Referenced by main().
iMesh_Instance mesh;
int err;
iMesh_newMesh( "", &mesh, &err, 0 );
CHECK_EQUAL( iBase_SUCCESS, err );
iBase_EntitySetHandle root_set;
iMesh_getRootSet( mesh, &root_set, &err );
iBase_EntityHandle* verts = 0;
int verts_alloc = 0, verts_size = 0;
double coords[] = { 0, 0, 0, 1, 1, 1, 2, 2, 2, 3, 3, 3, 4, 4, 4, 5, 5, 5 };
iMesh_createVtxArr( mesh, 6, iBase_INTERLEAVED, coords, 18, &verts, &verts_alloc, &verts_size, &err );
/* make a non-array iterator and test stepping over it */
iBase_EntityIterator iter;
int atend;
iMesh_initEntIter( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, 0, &iter, &err );
iMesh_stepEntIter( mesh, iter, 2, &atend, &err );
/* shouldn't be at end yet */
if( atend ) CHECK_EQUAL( iBase_SUCCESS, iBase_FAILURE );
iMesh_stepEntIter( mesh, iter, 4, &atend, &err );
/* should be at end now */
if( !atend ) CHECK_EQUAL( iBase_SUCCESS, iBase_FAILURE );
iMesh_endEntIter( mesh, iter, &err );
/* make an array iterator and test stepping over it */
iBase_EntityArrIterator arr_iter;
iMesh_initEntArrIter( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, 6, 0, &arr_iter, &err );
iMesh_stepEntArrIter( mesh, arr_iter, 2, &atend, &err );
iMesh_stepEntArrIter( mesh, arr_iter, 4, &atend, &err );
iMesh_endEntArrIter( mesh, arr_iter, &err );
iMesh_dtor( mesh, &err );
free( verts );
| void test_tag_iterate | ( | ) |
Definition at line 19 of file MOAB_iMesh_extensions_tests.cpp.
References CHECK_EQUAL, iBase_ALL_TYPES, iBase_DOUBLE, iBase_FAILURE, iBase_INTERLEAVED, iBase_SUCCESS, iMesh_addEntArrToSet, iMesh_ALL_TOPOLOGIES, iMesh_createEntSet, iMesh_createTagWithOptions, iMesh_createVtxArr, iMesh_dtor, iMesh_endEntArrIter, iMesh_getRootSet, iMesh_initEntArrIter, iMesh_newMesh, iMesh_setDblArrData, iMesh_stepEntArrIter, iMesh_tagIterate, mesh, and root_set.
int err;
iBase_EntitySetHandle root_set, entset;
/* create an entity set with two subranges */
iMesh_createEntSet( mesh, 0, &entset, &err );
iMesh_addEntArrToSet( mesh, verts, 2, entset, &err );
iMesh_addEntArrToSet( mesh, &verts[3], 3, entset, &err );
/* create a dbl tag and set vertices */
iBase_TagHandle tagh;
iMesh_createTagWithOptions( mesh, "dum", "moab:TAG_STORAGE_TYPE=DENSE", 1, iBase_DOUBLE, &tagh, &err, 3, 27 );
iMesh_setDblArrData( mesh, verts, 6, tagh, coords + 3, 6, &err );
/* get an iterator over the root set, and check tag iterator for that */
iBase_EntityArrIterator iter;
int count, atend;
double* data;
iMesh_initEntArrIter( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, 6, 0, &iter, &err );
iMesh_tagIterate( mesh, tagh, iter, &data, &count, &err );
if( count != 6 ) CHECK_EQUAL( iBase_SUCCESS, iBase_FAILURE );
for( int i = 0; i < 6; i++ )
if( data[i] != coords[i + 3] ) CHECK_EQUAL( iBase_SUCCESS, iBase_FAILURE );
iMesh_endEntArrIter( mesh, iter, &err );
iter = 0; // iMesh_endEntArrIter frees iter
/* get an iterator over the set with two subranges, and check tag iterator for that */
iMesh_initEntArrIter( mesh, entset, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, 6, 0, &iter, &err );
if( count != 2 || data[0] != coords[3] || data[1] != coords[4] ) CHECK_EQUAL( iBase_SUCCESS, iBase_FAILURE );
iMesh_stepEntArrIter( mesh, iter, 2, &atend, &err );
if( count != 3 || data[0] != coords[6] || data[1] != coords[7] ) CHECK_EQUAL( iBase_SUCCESS, iBase_FAILURE );
iMesh_stepEntArrIter( mesh, iter, 3, &atend, &err );
free( verts );
