augment_with_ghosts.cpp File Reference
#include "moab/ParallelComm.hpp"
#include "moab/Core.hpp"
#include "moab_mpi.h"
#include "TestUtil.hpp"
#include "MBTagConventions.hpp"
#include <iostream>
#include <sstream>
+ Include dependency graph for augment_with_ghosts.cpp:
Functions
void report_sets (moab::Core *mb, int rank, int nproc)
void test_read_with_ghost ()
void test_read_and_ghost_after ()
void test_read_with_ghost_no_augment ()
int main (int argc, char *argv[])
Variables
std::string filename = "unittest/io/p8ex1.h5m"
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 129 of file augment_with_ghosts.cpp.
References filename, RUN_TEST, test_read_and_ghost_after(), test_read_with_ghost(), and test_read_with_ghost_no_augment().
    MPI_Init( &argc, &argv );
    int result = 0;
    if( argc >= 2 ) filename = argv[1];
    result += RUN_TEST( test_read_with_ghost );
    result += RUN_TEST( test_read_and_ghost_after );
    result += RUN_TEST( test_read_with_ghost_no_augment );
    MPI_Finalize();
    return 0;
void report_sets ( moab::Core *  mb,
int  rank,
int  nproc
Definition at line 12 of file augment_with_ghosts.cpp.
References moab::Range::begin(), CHECK_ERR, DIRICHLET_SET_TAG_NAME, moab::Range::end(), ErrorCode, moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type_and_tag(), moab::Core::id_from_handle(), MATERIAL_SET_TAG_NAME, MB_TAG_ANY, MB_TYPE_INTEGER, MBENTITYSET, MPI_COMM_WORLD, NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME, moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), and moab::Interface::UNION.
Referenced by test_read_and_ghost_after(), test_read_with_ghost(), and test_read_with_ghost_no_augment().
    // check neumann and material sets, and see if their number of quads / hexes  in them
    const char* const shared_set_tag_names[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME,
                                                 PARALLEL_PARTITION_TAG_NAME };
    int num_tags = sizeof( shared_set_tag_names ) / sizeof( shared_set_tag_names[0] );
    for( int p = 0; p < nproc; p++ )
        if( rank == p )
            std::cout << " Task no:" << rank << "\n";
            for( int i = 0; i < num_tags; i++ )
                Tag tag;
                ErrorCode rval = mb->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tag, MB_TAG_ANY );CHECK_ERR( rval );
                Range sets;
                rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets, Interface::UNION );CHECK_ERR( rval );
                std::vector< int > vals( sets.size() );
                rval = mb->tag_get_data( tag, sets, &vals[0] );CHECK_ERR( rval );
                std::cout << "  sets: " << shared_set_tag_names[i] << "\n";
                int j = 0;
                for( Range::iterator it = sets.begin(); it != sets.end(); it++, j++ )
                    Range ents;
                    rval = mb->get_entities_by_handle( *it, ents );CHECK_ERR( rval );
                    std::cout << "    set " << mb->id_from_handle( *it ) << " with tagval=" << vals[j] << " has "
                              << ents.size() << " entities\n";
        MPI_Barrier( MPI_COMM_WORLD );
Definition at line 72 of file augment_with_ghosts.cpp.
References moab::ParallelComm::augment_default_sets_with_ghosts(), CHECK_ERR, ErrorCode, moab::ParallelComm::exchange_ghost_cells(), filename, layers, moab::Core::load_file(), mb, MB_SUCCESS, MPI_COMM_WORLD, outfile, rank, report_sets(), moab::ParallelComm::set_debug_verbosity(), and moab::Core::write_file().
Referenced by main().
    int nproc, rank;
    MPI_Comm_size( MPI_COMM_WORLD, &nproc );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    moab::Core* mb         = new moab::Core();
    moab::ParallelComm* pc = new moab::ParallelComm( mb, MPI_COMM_WORLD );
    ErrorCode rval         = MB_SUCCESS;
    // first read in parallel, then ghost, then augment
    char read_opts[] = "PARALLEL=READ_PART;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION=PARALLEL_PARTITION";
    rval             = mb->load_file( filename.c_str(), 0, read_opts );CHECK_ERR( rval );
    int ghost_dim = 3, bridge = 0, layers = 1, addl_ents = 3;
    rval = pc->exchange_ghost_cells( ghost_dim, bridge, layers, addl_ents, true, true );CHECK_ERR( rval );
    pc->set_debug_verbosity( 1 );
    rval = pc->augment_default_sets_with_ghosts( 0 );CHECK_ERR( rval );
    report_sets( mb, rank, nproc );
    // write in serial the database , on each rank
    std::ostringstream outfile;
    outfile << "TaskMesh_n" << nproc << "." << rank << ".h5m";
    // the mesh contains ghosts too, but they were not part of mat/neumann set
    // write in serial the file, to see what tags are missing / or not
    rval = mb->write_file( outfile.str().c_str() );  // everything on root
    CHECK_ERR( rval );
    delete pc;
    delete mb;
Definition at line 48 of file augment_with_ghosts.cpp.
References CHECK_ERR, ErrorCode, filename, moab::Core::load_file(), mb, MB_SUCCESS, MPI_COMM_WORLD, outfile, rank, report_sets(), and moab::Core::write_file().
    int nproc, rank;
    char read_opts[] = "PARALLEL=READ_PART;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1.3;"
                       "PARTITION=PARALLEL_PARTITION";
    outfile << "testReadGhost_n" << nproc << "." << rank << ".h5m";
    CHECK_ERR( rval );
    delete mb;
Definition at line 106 of file augment_with_ghosts.cpp.
    int nproc, rank;
                       "PARTITION=PARALLEL_PARTITION;SKIP_AUGMENT_WITH_GHOSTS";
    CHECK_ERR( rval );
    delete mb;
Variable Documentation
Definition at line 9 of file augment_with_ghosts.cpp.
