MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * migrate_nontrivial.cpp 00003 * 00004 * migrate_nontrivial will contain tests for migrating meshes in parallel environments, with iMOAB 00005 * api, using nontrivial partitions; for starters, we will use zoltan to compute partition in 00006 * parallel, and then use the result to migrate the mesh trivial partition gave terrible results for 00007 * mpas type meshes, that were numbered like a fractal; the resulting migrations were like Swiss 00008 * cheese, full of holes a mesh is read on senders tasks we will use graph like methods or geometry 00009 * methods, and will modify the ZoltanPartitioner to add needed methods 00010 * 00011 * mesh will be sent to receivers tasks, with nonblocking MPI_Isend calls, and then received 00012 * with blocking MPI_Recv calls; 00013 * 00014 * we will not modify the GLOBAL_ID tag, we assume it was set correctly before we started 00015 */ 00016 00017 #include "moab/ParallelComm.hpp" 00018 #include "moab/Core.hpp" 00019 #include "moab_mpi.h" 00020 #include "moab/iMOAB.h" 00021 #include "TestUtil.hpp" 00022 #include "moab/ProgOptions.hpp" 00023 00024 #define RUN_TEST_ARG2( A, B ) run_test( &( A ), #A, B ) 00025 00026 using namespace moab; 00027 00028 //#define GRAPH_INFO 00029 00030 #define CHECKRC( rc, message ) \ 00031 if( 0 != ( rc ) ) \ 00032 { \ 00033 printf( "Error: %s\n", message ); \ 00034 return MB_FAILURE; \ 00035 } 00036 00037 int is_any_proc_error( int is_my_error ) 00038 { 00039 int result = 0; 00040 int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD ); 00041 return err || result; 00042 } 00043 00044 int run_test( ErrorCode ( *func )( const char* ), const char* func_name, const char* file_name ) 00045 { 00046 ErrorCode result = ( *func )( file_name ); 00047 int is_err = is_any_proc_error( ( MB_SUCCESS != result ) ); 00048 int rank; 00049 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00050 if( rank == 0 ) 00051 { 00052 if( is_err ) 00053 std::cout << func_name << " : FAILED!!" << std::endl; 00054 else 00055 std::cout << func_name << " : success" << std::endl; 00056 } 00057 00058 return is_err; 00059 } 00060 00061 ErrorCode migrate_graph( const char* filename ); 00062 ErrorCode migrate_geom( const char* filename ); 00063 ErrorCode migrate_trivial( const char* filename ); 00064 00065 // some global variables, used by all tests 00066 int rank, size, ierr; 00067 00068 int compid1, compid2; // component ids are unique over all pes, and established in advance; 00069 int nghlay; // number of ghost layers for loading the file 00070 std::vector< int > groupTasks; // at most 4 tasks 00071 int startG1, startG2, endG1, endG2; 00072 00073 MPI_Comm jcomm; // will be a copy of the global 00074 MPI_Group jgroup; 00075 00076 ErrorCode migrate_smart( const char* filename, const char* outfile, int partMethod ) 00077 { 00078 // first create MPI groups 00079 00080 std::string filen( filename ); 00081 MPI_Group group1, group2; 00082 groupTasks.resize( endG1 - startG1 + 1 ); 00083 for( int i = startG1; i <= endG1; i++ ) 00084 groupTasks[i - startG1] = i; 00085 00086 ierr = MPI_Group_incl( jgroup, endG1 - startG1 + 1, &groupTasks[0], &group1 ); 00087 CHECKRC( ierr, "can't create group1" ) 00088 00089 groupTasks.resize( endG2 - startG2 + 1 ); 00090 for( int i = startG2; i <= endG2; i++ ) 00091 groupTasks[i - startG2] = i; 00092 00093 ierr = MPI_Group_incl( jgroup, endG2 - startG2 + 1, &groupTasks[0], &group2 ); 00094 CHECKRC( ierr, "can't create group2" ) 00095 00096 // create 2 communicators, one for each group 00097 int tagcomm1 = 1, tagcomm2 = 2; 00098 int context_id = -1; // plain migrate, default context 00099 MPI_Comm comm1, comm2; 00100 ierr = MPI_Comm_create_group( jcomm, group1, tagcomm1, &comm1 ); 00101 CHECKRC( ierr, "can't create comm1" ) 00102 00103 ierr = MPI_Comm_create_group( jcomm, group2, tagcomm2, &comm2 ); 00104 CHECKRC( ierr, "can't create comm2" ) 00105 00106 ierr = iMOAB_Initialize( 0, 0 ); // not really needed anything from argc, argv, yet; maybe we should 00107 CHECKRC( ierr, "can't initialize iMOAB" ) 00108 00109 // give some dummy values to component ids, just to differentiate between them 00110 // the par comm graph is unique between components 00111 compid1 = 4; 00112 compid2 = 7; 00113 00114 int appID1; 00115 iMOAB_AppID pid1 = &appID1; 00116 int appID2; 00117 iMOAB_AppID pid2 = &appID2; 00118 00119 if( comm1 != MPI_COMM_NULL ) 00120 { 00121 ierr = iMOAB_RegisterApplication( "APP1", &comm1, &compid1, pid1 ); 00122 CHECKRC( ierr, "can't register app1 " ) 00123 } 00124 if( comm2 != MPI_COMM_NULL ) 00125 { 00126 ierr = iMOAB_RegisterApplication( "APP2", &comm2, &compid2, pid2 ); 00127 CHECKRC( ierr, "can't register app2 " ) 00128 } 00129 00130 if( comm1 != MPI_COMM_NULL ) 00131 { 00132 00133 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00134 00135 nghlay = 0; 00136 00137 ierr = iMOAB_LoadMesh( pid1, filen.c_str(), readopts.c_str(), &nghlay ); 00138 CHECKRC( ierr, "can't load mesh " ) 00139 ierr = iMOAB_SendMesh( pid1, &jcomm, &group2, &compid2, &partMethod ); // send to component 2 00140 CHECKRC( ierr, "cannot send elements" ) 00141 #ifdef GRAPH_INFO 00142 int is_sender = 1; 00143 int context = compid2; 00144 iMOAB_DumpCommGraph( pid1, &context, &is_sender, "MigrateS" ); 00145 #endif 00146 } 00147 00148 if( comm2 != MPI_COMM_NULL ) 00149 { 00150 ierr = iMOAB_ReceiveMesh( pid2, &jcomm, &group1, &compid1 ); // receive from component 1 00151 CHECKRC( ierr, "cannot receive elements" ) 00152 std::string wopts; 00153 wopts = "PARALLEL=WRITE_PART;"; 00154 ierr = iMOAB_WriteMesh( pid2, outfile, wopts.c_str() ); 00155 CHECKRC( ierr, "cannot write received mesh" ) 00156 #ifdef GRAPH_INFO 00157 int is_sender = 0; 00158 int context = compid1; 00159 iMOAB_DumpCommGraph( pid2, &context, &is_sender, "MigrateR" ); 00160 #endif 00161 } 00162 00163 MPI_Barrier( jcomm ); 00164 00165 // we can now free the sender buffers 00166 context_id = compid2; // even for default migrate, be more explicit 00167 if( comm1 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid1, &context_id ); 00168 00169 if( comm2 != MPI_COMM_NULL ) 00170 { 00171 ierr = iMOAB_DeregisterApplication( pid2 ); 00172 CHECKRC( ierr, "cannot deregister app 2 receiver" ) 00173 } 00174 00175 if( comm1 != MPI_COMM_NULL ) 00176 { 00177 ierr = iMOAB_DeregisterApplication( pid1 ); 00178 CHECKRC( ierr, "cannot deregister app 1 sender" ) 00179 } 00180 00181 ierr = iMOAB_Finalize(); 00182 CHECKRC( ierr, "did not finalize iMOAB" ) 00183 00184 if( MPI_COMM_NULL != comm1 ) MPI_Comm_free( &comm1 ); 00185 if( MPI_COMM_NULL != comm2 ) MPI_Comm_free( &comm2 ); 00186 00187 MPI_Group_free( &group1 ); 00188 MPI_Group_free( &group2 ); 00189 return MB_SUCCESS; 00190 } 00191 // migrate from 2 tasks to 3 tasks 00192 ErrorCode migrate_graph( const char* filename ) 00193 { 00194 return migrate_smart( filename, "migrate_graph.h5m", 1 ); 00195 } 00196 00197 ErrorCode migrate_geom( const char* filename ) 00198 { 00199 return migrate_smart( filename, "migrate_geom.h5m", 2 ); 00200 } 00201 00202 ErrorCode migrate_trivial( const char* filename ) 00203 { 00204 return migrate_smart( filename, "migrate_trivial.h5m", 0 ); 00205 } 00206 00207 int main( int argc, char* argv[] ) 00208 { 00209 MPI_Init( &argc, &argv ); 00210 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00211 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00212 00213 MPI_Comm_dup( MPI_COMM_WORLD, &jcomm ); 00214 MPI_Comm_group( jcomm, &jgroup ); 00215 00216 ProgOptions opts; 00217 int typeTest = 3; 00218 // std::string inputfile, outfile("out.h5m"), netcdfFile, variable_name, sefile_name; 00219 std::string filename; 00220 filename = TestDir + "unittest/field1.h5m"; 00221 startG1 = 0; 00222 startG2 = 0; 00223 endG1 = 0; 00224 endG2 = 1; 00225 00226 opts.addOpt< std::string >( "file,f", "source file", &filename ); 00227 00228 opts.addOpt< int >( "startSender,a", "start task for source layout", &startG1 ); 00229 opts.addOpt< int >( "endSender,b", "end task for source layout", &endG1 ); 00230 opts.addOpt< int >( "startRecv,c", "start task for receiver layout", &startG2 ); 00231 opts.addOpt< int >( "endRecv,d", "end task for receiver layout", &endG2 ); 00232 00233 opts.addOpt< int >( "typeTest,t", "test types (0 - trivial, 1 graph, 2 geom, 3 both graph and geometry", 00234 &typeTest ); 00235 00236 opts.parseCommandLine( argc, argv ); 00237 00238 if( rank == 0 ) 00239 { 00240 std::cout << " input file : " << filename << "\n"; 00241 std::cout << " sender on tasks: " << startG1 << ":" << endG1 << "\n"; 00242 std::cout << " receiver on tasks: " << startG2 << ":" << endG2 << "\n"; 00243 std::cout << " type migrate: " << typeTest << " (0 - trivial, 1 graph , 2 geom, 3 both graph and geom ) \n"; 00244 } 00245 00246 int num_errors = 0; 00247 00248 if( 0 == typeTest ) num_errors += RUN_TEST_ARG2( migrate_trivial, filename.c_str() ); 00249 if( 3 == typeTest || 1 == typeTest ) num_errors += RUN_TEST_ARG2( migrate_graph, filename.c_str() ); 00250 if( 3 == typeTest || 2 == typeTest ) num_errors += RUN_TEST_ARG2( migrate_geom, filename.c_str() ); 00251 00252 if( rank == 0 ) 00253 { 00254 if( !num_errors ) 00255 std::cout << "All tests passed" << std::endl; 00256 else 00257 std::cout << num_errors << " TESTS FAILED!" << std::endl; 00258 } 00259 00260 MPI_Group_free( &jgroup ); 00261 MPI_Comm_free( &jcomm ); 00262 MPI_Finalize(); 00263 return num_errors; 00264 } 00265 00266 #undef VERBOSE
