MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/MeshGeneration.hpp"#include "TestUtil.hpp"#include "moab/ProgOptions.hpp"
Include dependency graph for mgen_test.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 15 of file mgen_test.cpp.
References moab::MeshGeneration::BrickOpts::A, ProgOptions::addOpt(), moab::MeshGeneration::BrickOpts::adjEnts, moab::MeshGeneration::BrickOpts::B, moab::MeshGeneration::BrickOpts::blockSize, moab::MeshGeneration::BrickInstance(), moab::MeshGeneration::BrickOpts::C, moab::Interface::create_meshset(), ErrorCode, moab::MeshGeneration::BrickOpts::GL, moab::MeshGeneration::BrickOpts::K, moab::MeshGeneration::BrickOpts::keep_skins, moab::MeshGeneration::BrickOpts::M, mb, MB_CHK_ERR, MESHSET_SET, MPI_COMM_WORLD, moab::MeshGeneration::BrickOpts::N, moab::MeshGeneration::BrickOpts::newMergeMethod, moab::MeshGeneration::BrickOpts::parmerge, ProgOptions::parseCommandLine(), moab::MeshGeneration::BrickOpts::quadratic, moab::MeshGeneration::BrickOpts::tetra, moab::MeshGeneration::BrickOpts::ui, moab::MeshGeneration::BrickOpts::uj, moab::MeshGeneration::BrickOpts::uk, moab::MeshGeneration::BrickOpts::xsize, moab::MeshGeneration::BrickOpts::ysize, and moab::MeshGeneration::BrickOpts::zsize.
#ifdef MOAB_HAVE_MPI
MPI_Init( &argc, &argv );
#endif
Core mcore;
Interface* mb = &mcore;
EntityHandle fileset;
MeshGeneration::BrickOpts opts;
// default options
opts.A = opts.B = opts.C = 2;
opts.M = opts.N = opts.K = 1;
opts.blockSize = 4;
opts.xsize = opts.ysize = opts.zsize = 1.;
opts.ui = CartVect( 1., 0, 0. );
opts.uj = CartVect( 0., 1., 0. );
opts.uk = CartVect( 0., 0., 1. );
opts.newMergeMethod = opts.quadratic = opts.keep_skins = opts.tetra = false;
opts.adjEnts = opts.parmerge = false;
opts.GL = 0;
ProgOptions popts;
popts.addOpt< int >( string( "blockSize,b" ), string( "Block size of mesh (default=4)" ), &opts.blockSize );
popts.addOpt< int >( string( "xproc,M" ), string( "Number of processors in x dir (default=1)" ), &opts.M );
popts.addOpt< int >( string( "yproc,N" ), string( "Number of processors in y dir (default=1)" ), &opts.N );
popts.addOpt< int >( string( "zproc,K" ), string( "Number of processors in z dir (default=1)" ), &opts.K );
popts.addOpt< int >( string( "xblocks,A" ), string( "Number of blocks on a task in x dir (default=2)" ), &opts.A );
popts.addOpt< int >( string( "yblocks,B" ), string( "Number of blocks on a task in y dir (default=2)" ), &opts.B );
popts.addOpt< int >( string( "zblocks,C" ), string( "Number of blocks on a task in x dir (default=2)" ), &opts.C );
popts.addOpt< double >( string( "xsize,x" ), string( "Total size in x direction (default=1.)" ), &opts.xsize );
popts.addOpt< double >( string( "ysize,y" ), string( "Total size in y direction (default=1.)" ), &opts.ysize );
popts.addOpt< double >( string( "zsize,z" ), string( "Total size in z direction (default=1.)" ), &opts.zsize );
popts.addOpt< void >( "newMerge,w", "use new merging method", &opts.newMergeMethod );
popts.addOpt< void >( "quadratic,q", "use hex 27 elements", &opts.quadratic );
popts.addOpt< void >( "keep_skins,k", "keep skins with shared entities", &opts.keep_skins );
popts.addOpt< void >( "tetrahedrons,t", "generate tetrahedrons", &opts.tetra );
popts.addOpt< void >( "faces_edges,f", "create all faces and edges", &opts.adjEnts );
popts.addOpt< int >( string( "ghost_layers,g" ), string( "Number of ghost layers (default=0)" ), &opts.GL );
popts.addOpt< void >( "parallel_merge,p", "use parallel mesh merge, not vertex ID based merge", &opts.parmerge );
popts.parseCommandLine( argc, argv );
ErrorCode rval = mb->create_meshset( MESHSET_SET, fileset );MB_CHK_ERR( rval );
ParallelComm* pc = new ParallelComm( mb, MPI_COMM_WORLD );
MeshGeneration* mgen = new MeshGeneration( mb, pc, fileset );
#else
MeshGeneration* mgen = new MeshGeneration( mb, fileset );
#endif
rval = mgen->BrickInstance( opts );MB_CHK_ERR( rval );
return 0;
