MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/MeshGeneration.hpp" 00003 #include "TestUtil.hpp" 00004 #include "moab/ProgOptions.hpp" 00005 00006 #ifdef MOAB_HAVE_MPI 00007 #include "moab_mpi.h" 00008 #include "moab/ParallelComm.hpp" 00009 #include "MBParallelConventions.h" 00010 #endif 00011 00012 using namespace moab; 00013 using std::string; 00014 00015 int main( int argc, char* argv[] ) 00016 { 00017 #ifdef MOAB_HAVE_MPI 00018 MPI_Init( &argc, &argv ); 00019 #endif 00020 Core mcore; 00021 Interface* mb = &mcore; 00022 EntityHandle fileset; 00023 MeshGeneration::BrickOpts opts; 00024 // default options 00025 opts.A = opts.B = opts.C = 2; 00026 opts.M = opts.N = opts.K = 1; 00027 opts.blockSize = 4; 00028 opts.xsize = opts.ysize = opts.zsize = 1.; 00029 opts.ui = CartVect( 1., 0, 0. ); 00030 opts.uj = CartVect( 0., 1., 0. ); 00031 opts.uk = CartVect( 0., 0., 1. ); 00032 opts.newMergeMethod = opts.quadratic = opts.keep_skins = opts.tetra = false; 00033 opts.adjEnts = opts.parmerge = false; 00034 opts.GL = 0; 00035 00036 ProgOptions popts; 00037 00038 popts.addOpt< int >( string( "blockSize,b" ), string( "Block size of mesh (default=4)" ), &opts.blockSize ); 00039 popts.addOpt< int >( string( "xproc,M" ), string( "Number of processors in x dir (default=1)" ), &opts.M ); 00040 popts.addOpt< int >( string( "yproc,N" ), string( "Number of processors in y dir (default=1)" ), &opts.N ); 00041 popts.addOpt< int >( string( "zproc,K" ), string( "Number of processors in z dir (default=1)" ), &opts.K ); 00042 00043 popts.addOpt< int >( string( "xblocks,A" ), string( "Number of blocks on a task in x dir (default=2)" ), &opts.A ); 00044 popts.addOpt< int >( string( "yblocks,B" ), string( "Number of blocks on a task in y dir (default=2)" ), &opts.B ); 00045 popts.addOpt< int >( string( "zblocks,C" ), string( "Number of blocks on a task in x dir (default=2)" ), &opts.C ); 00046 00047 popts.addOpt< double >( string( "xsize,x" ), string( "Total size in x direction (default=1.)" ), &opts.xsize ); 00048 popts.addOpt< double >( string( "ysize,y" ), string( "Total size in y direction (default=1.)" ), &opts.ysize ); 00049 popts.addOpt< double >( string( "zsize,z" ), string( "Total size in z direction (default=1.)" ), &opts.zsize ); 00050 00051 popts.addOpt< void >( "newMerge,w", "use new merging method", &opts.newMergeMethod ); 00052 00053 popts.addOpt< void >( "quadratic,q", "use hex 27 elements", &opts.quadratic ); 00054 00055 popts.addOpt< void >( "keep_skins,k", "keep skins with shared entities", &opts.keep_skins ); 00056 00057 popts.addOpt< void >( "tetrahedrons,t", "generate tetrahedrons", &opts.tetra ); 00058 00059 popts.addOpt< void >( "faces_edges,f", "create all faces and edges", &opts.adjEnts ); 00060 00061 popts.addOpt< int >( string( "ghost_layers,g" ), string( "Number of ghost layers (default=0)" ), &opts.GL ); 00062 00063 popts.addOpt< void >( "parallel_merge,p", "use parallel mesh merge, not vertex ID based merge", &opts.parmerge ); 00064 00065 popts.parseCommandLine( argc, argv ); 00066 00067 ErrorCode rval = mb->create_meshset( MESHSET_SET, fileset );MB_CHK_ERR( rval ); 00068 00069 #ifdef MOAB_HAVE_MPI 00070 ParallelComm* pc = new ParallelComm( mb, MPI_COMM_WORLD ); 00071 MeshGeneration* mgen = new MeshGeneration( mb, pc, fileset ); 00072 #else 00073 MeshGeneration* mgen = new MeshGeneration( mb, fileset ); 00074 #endif 00075 00076 rval = mgen->BrickInstance( opts );MB_CHK_ERR( rval ); 00077 00078 return 0; 00079 }
