MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include "moab/Interface.hpp"#include "TestUtil.hpp"#include "Internals.hpp"#include "moab/Core.hpp"#include "moab/GeomTopoTool.hpp"#include "moab/GeomQueryTool.hpp"
Include dependency graph for gqt_simple_test.cpp:Go to the source code of this file.
Defines | |
| #define | IS_BUILDING_MB |
| #define | CHKERR(A) |
Functions | |
| void | gqt_load_file () |
| void | gqt_load_file_dagmc_build_obb () |
| void | gqt_load_file_dagmc_via_moab_build_obb () |
| void | gqt_load_file_dagmc_internal_build_obb () |
| void | gqt_test_obb_retreval () |
| void | gqt_create_impl_compl () |
| void | gqt_build_obb () |
| void | gqt_num_vols () |
| void | gqt_point_in () |
| void | gqt_test_obb_retreval_rayfire () |
| void | gqt_rayfire () |
| void | gqt_closest_to () |
| void | gqt_test_boundary () |
| void | gqt_point_in_box_1 () |
| void | gqt_point_in_box_2 () |
| void | gqt_point_in_box_3 () |
| void | gqt_point_in_box_4 () |
| void | gqt_point_in_box_5 () |
| void | cleanup () |
| int | main (int, char **) |
Variables | |
| GeomTopoTool * | GTT |
| GeomQueryTool * | GQT |
| Interface * | MBI |
| const std::string | input_file = "unittest/test_geom.h5m" |
| #define CHKERR | ( | A | ) |
do \ { \ if( MB_SUCCESS != ( A ) ) \ { \ std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ return A; \ } \ } while( false )
Definition at line 19 of file gqt_simple_test.cpp.
| #define IS_BUILDING_MB |
Definition at line 4 of file gqt_simple_test.cpp.
| void cleanup | ( | ) |
| void gqt_build_obb | ( | ) |
Definition at line 126 of file gqt_simple_test.cpp.
References CHECK_ERR, moab::GeomTopoTool::construct_obb_trees(), ErrorCode, GQT, and moab::GeomQueryTool::gttool().
Referenced by main().
ErrorCode rval = GQT->gttool()->construct_obb_trees();CHECK_ERR( rval );
| void gqt_closest_to | ( | ) |
Definition at line 242 of file gqt_simple_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, moab::GeomQueryTool::closest_to_location(), moab::GeomTopoTool::entity_by_id(), eps, ErrorCode, GQT, and moab::GeomQueryTool::gttool().
const double eps = 1e-6; // epsilon for test, faceting tol?
int vol_idx = 1;
// note model is cube of side 10, centred at 0,0,0, so ray fire along
// any unit direction should be exactly 5.0
double xyz[3] = { -6.0, 0.0, 0.0 };
double distance; // distance from point to nearest surface
double expect_distance = 1.0;
EntityHandle vol_h;
ErrorCode rval;
// get the volume handle
vol_h = GQT->gttool()->entity_by_id( 3, vol_idx );
// test closest to location
rval = GQT->closest_to_location( vol_h, xyz, distance );CHECK_ERR( rval );
// distance should be 1.0 cm
CHECK_REAL_EQUAL( expect_distance, distance, eps );
| void gqt_create_impl_compl | ( | ) |
Definition at line 121 of file gqt_simple_test.cpp.
References CHECK_ERR, ErrorCode, GQT, moab::GeomQueryTool::gttool(), and moab::GeomTopoTool::setup_implicit_complement().
ErrorCode rval = GQT->gttool()->setup_implicit_complement();CHECK_ERR( rval );
| void gqt_load_file | ( | ) |
Definition at line 31 of file gqt_simple_test.cpp.
References CHECK_ERR, ErrorCode, GQT, GTT, input_file, and MBI.
MBI = new moab::Core();
ErrorCode rval = MBI->load_file( input_file.c_str() ); // open the
CHECK_ERR( rval );
GTT = new GeomTopoTool( MBI, true );
GQT = new GeomQueryTool( GTT );
| void gqt_load_file_dagmc_build_obb | ( | ) |
Definition at line 40 of file gqt_simple_test.cpp.
References CHECK_ERR, ErrorCode, GQT, GTT, moab::GeomQueryTool::initialize(), input_file, and MBI.
/* 1 - Test with external moab, load file in GTT/GQT*/
// make new moab core
ErrorCode rval;
// load a file
CHECK_ERR( rval );
GTT = new GeomTopoTool( MBI );
rval = GQT->initialize();CHECK_ERR( rval );
Definition at line 72 of file gqt_simple_test.cpp.
References CHECK_ERR, moab::GeomTopoTool::construct_obb_trees(), ErrorCode, GQT, GTT, moab::GeomQueryTool::gttool(), input_file, MBI, and moab::GeomTopoTool::setup_implicit_complement().
/* 3 - Test with internal moab, load file in MOAB*/
// find geomsets, build implicit complement, and construct obb trees
ErrorCode rval;
CHECK_ERR( rval );
GTT = new GeomTopoTool( MBI, true, 0 );
Definition at line 55 of file gqt_simple_test.cpp.
/* 2 - Test with external moab, load file in MOAB*/
// build implicit complement and obb trees
ErrorCode rval;
// load file
rval = MBI->load_file( input_file.c_str() ); // open the file
CHECK_ERR( rval );
// create obb trees
| void gqt_num_vols | ( | ) |
Definition at line 131 of file gqt_simple_test.cpp.
References CHECK_EQUAL, GQT, moab::GeomQueryTool::gttool(), and moab::GeomTopoTool::num_ents_of_dim().
int expect_num_vols = 2;
int num_vols = GQT->gttool()->num_ents_of_dim( 3 );
CHECK_EQUAL( expect_num_vols, num_vols );
| void gqt_point_in | ( | ) |
Definition at line 138 of file gqt_simple_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, GTT, moab::GeomQueryTool::gttool(), moab::GeomQueryTool::initialize(), input_file, MBI, and moab::GeomQueryTool::point_in_volume().
int result = 0;
int expect_result = 1;
int vol_idx = 1;
double xyz[3] = { 0.0, 0.0, 0.0 };
EntityHandle vol_h;
// load file and create instances
CHECK_ERR( rval );
// initialize for geom queries
GQT->initialize();
// get volume
// test point in volume
GQT->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval );
CHECK_EQUAL( expect_result, result );
| void gqt_point_in_box_1 | ( | ) |
Definition at line 283 of file gqt_simple_test.cpp.
References CHECK_EQUAL, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, moab::GeomQueryTool::gttool(), MB_SUCCESS, origin, and moab::GeomQueryTool::point_in_box().
int vol_id = 1;
double origin[3] = { 0.0, 0.0, 0.0 };
EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id );
int result;
ErrorCode rval = GQT->point_in_box( vol_h, origin, result );
CHECK_EQUAL( rval, moab::MB_SUCCESS );
CHECK_EQUAL( result, 1 ); // inside
| void gqt_point_in_box_2 | ( | ) |
Definition at line 294 of file gqt_simple_test.cpp.
int vol_id = 1;
double origin[3] = { 5.0, 0.0, 0.0 };
int result;
| void gqt_point_in_box_3 | ( | ) |
Definition at line 305 of file gqt_simple_test.cpp.
int vol_id = 1;
double origin[3] = { 5.1, 0.0, 0.0 };
int result;
CHECK_EQUAL( result, 0 ); // outside
| void gqt_point_in_box_4 | ( | ) |
Definition at line 316 of file gqt_simple_test.cpp.
int vol_id = 1;
double origin[3] = { 5.1, 5.1, 5.1 };
int result;
| void gqt_point_in_box_5 | ( | ) |
Definition at line 327 of file gqt_simple_test.cpp.
int vol_id = 1;
double origin[3] = { 5.0 - 1.e-308, 5.0 - 1.e-308, 5.0 - 1.e-308 };
int result;
CHECK_EQUAL( result, 1 ); // outside
| void gqt_rayfire | ( | ) |
Definition at line 215 of file gqt_simple_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), eps, ErrorCode, GQT, GTT, moab::GeomQueryTool::gttool(), moab::GeomQueryTool::initialize(), input_file, MBI, and moab::GeomQueryTool::ray_fire().
int vol_idx = 1;
double dir[3] = { 0.0, 0.0, 1.0 };
EntityHandle next_surf;
double next_surf_dist;
double expect_next_surf_dist = 5.0;
EntityHandle vol_h;
ErrorCode rval;
CHECK_ERR( rval );
rval = GQT->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps );
| void gqt_test_boundary | ( | ) |
Definition at line 265 of file gqt_simple_test.cpp.
References CHECK_EQUAL, CHECK_ERR, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, moab::GeomQueryTool::gttool(), and moab::GeomQueryTool::test_volume_boundary().
int vol_idx = 1;
EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_idx );
int surf_idx = 1;
EntityHandle surf_h = GQT->gttool()->entity_by_id( 2, surf_idx );
double xyz[3] = { 0.0, 0.0, 5.0 };
int result;
int expect_result = 0;
// test vol boundary
ErrorCode rval = GQT->test_volume_boundary( vol_h, surf_h, xyz, dir, result );CHECK_ERR( rval );
// check ray leaving volume
| void gqt_test_obb_retreval | ( | ) |
Definition at line 87 of file gqt_simple_test.cpp.
// make new dagmc
std::cout << "test_obb_retreval" << std::endl;
ErrorCode rval;
// load a file
CHECK_ERR( rval );
// write to file
rval = MBI->write_file( "fcad" );CHECK_ERR( rval );
// cleanup instances
delete GQT;
delete GTT;
delete MBI;
// re-load written file
rval = MBI->load_file( "fcad" ); // open the
CHECK_ERR( rval );
// remove file
remove( "fcad" );
| void gqt_test_obb_retreval_rayfire | ( | ) |
Definition at line 162 of file gqt_simple_test.cpp.
// make new dagmc
std::cout << "test_obb_retreval and ray_fire" << std::endl;
ErrorCode rval;
// load file and initialize
CHECK_ERR( rval );
// write to file
// delete instances
delete GTT;
delete GQT;
delete MBI;
// load the file that was written and initialize
CHECK_ERR( rval );
// remove generated test file
remove( "fcad" );
// now perform full ray fire
double eps = 1.e-6;
int vol_idx = 1;
EntityHandle vol_h;
// get volume handle to fire on
// test ray fire
| int main | ( | int | , |
| char ** | |||
Definition at line 346 of file gqt_simple_test.cpp.
References cleanup(), gqt_build_obb(), gqt_closest_to(), gqt_create_impl_compl(), gqt_load_file(), gqt_load_file_dagmc_build_obb(), gqt_load_file_dagmc_internal_build_obb(), gqt_load_file_dagmc_via_moab_build_obb(), gqt_num_vols(), gqt_point_in(), gqt_rayfire(), gqt_test_boundary(), gqt_test_obb_retreval(), gqt_test_obb_retreval_rayfire(), and RUN_TEST.
int result = 0;
result += RUN_TEST( gqt_load_file ); // test ray fire
result += RUN_TEST( gqt_build_obb ); // build the obb
result += RUN_TEST( gqt_create_impl_compl ); // build the obb
result += RUN_TEST( gqt_num_vols ); // make sure the num of vols correct
cleanup();
result += RUN_TEST( gqt_load_file_dagmc_build_obb ); //
cleanup();
result += RUN_TEST( gqt_load_file_dagmc_via_moab_build_obb ); //
cleanup();
result += RUN_TEST( gqt_load_file_dagmc_internal_build_obb ); //
cleanup();
result += RUN_TEST( gqt_test_obb_retreval ); // check that we are retreving loaded obbs
cleanup();
result += RUN_TEST( gqt_test_obb_retreval_rayfire ); // check that we can ray fire on loaded obbs
cleanup();
result += RUN_TEST( gqt_point_in ); // check entity by point
cleanup();
result += RUN_TEST( gqt_rayfire ); // ensure ray fire distance is correct
result += RUN_TEST( gqt_closest_to ); // check the distance to surface nearest point
result += RUN_TEST( gqt_test_boundary ); // check particle entering leaving
cleanup();
return result;
Definition at line 16 of file gqt_simple_test.cpp.
Definition at line 15 of file gqt_simple_test.cpp.
| const std::string input_file = "unittest/test_geom.h5m" |
Definition at line 29 of file gqt_simple_test.cpp.
Definition at line 17 of file gqt_simple_test.cpp.
