MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef MOAB_GEOM_QUERY_TOOL_HPP 00002 #define MOAB_GEOM_QUERY_TOOL_HPP 00003 00004 #ifdef _MSC_VER /* windows */ 00005 #define _USE_MATH_DEFINES // For M_PI 00006 #endif 00007 00008 #include "MBTagConventions.hpp" 00009 #include "moab/CartVect.hpp" 00010 #include "moab/Range.hpp" 00011 #include "moab/Core.hpp" 00012 #include "moab/GeomUtil.hpp" 00013 #include "moab/FileOptions.hpp" 00014 #include "moab/EntityHandle.hpp" 00015 #include "moab/GeomTopoTool.hpp" 00016 #include "moab/OrientedBoxTreeTool.hpp" 00017 00018 #include <vector> 00019 #include <map> 00020 #include <string> 00021 #include <cassert> 00022 00023 namespace moab 00024 { 00025 00026 /** \class GeomQueryTool 00027 * 00028 * \brief Tool for querying different aspects of geometric topology sets in MOAB 00029 * 00030 * Given the conventions established in GeomTopoTool for representing 00031 * geometric topology through a hierarchy of meshsets, this tool provides a 00032 * set of methods to query different geometric aspects of those geometric 00033 * topology sets including: 00034 * 00035 * * measures of surface area and volume 00036 * * distance to a bounding surface from a point within a volume 00037 * * test the inclusion of a point within a volume 00038 * * find the angle of a surface at a point 00039 * 00040 * A feature of these queries is that there is some support for overlapping 00041 * geometries. 00042 * 00043 */ 00044 00045 class GeomQueryTool 00046 { 00047 public: 00048 /* \class RayHistory 00049 * 00050 * In many use cases, it is useful to track some of the history of a ray as 00051 * it passes through a geometry, particularly a geometry represented by 00052 * facets. For example, given round-off erorr in ray-triangle tests 00053 * (GeomUtil::ray_tri_intersect) used as part of a test for ray-surface 00054 * intersection, it is possible for subsequent queries to oscillate between 00055 * adjacent surfaces. This class stores information about history of a ray 00056 * that can be used to test for such circumstances so that they can be 00057 * accommodated. 00058 * 00059 */ 00060 00061 class RayHistory 00062 { 00063 00064 public: 00065 /** 00066 * Clear this entire history-- logically equivalent to creating a new history, 00067 * but probably more efficient. 00068 */ 00069 void reset(); 00070 00071 /** 00072 * Clear the history up to the most recent intersection. This should be 00073 * called when a ray changes direction at the site of a surface crossing, 00074 * a situation that most commonly occurs at a reflecting boundary. 00075 */ 00076 void reset_to_last_intersection(); 00077 00078 /** 00079 * Remove the most recent intersection. This allows a subsequent call 00080 * along the same ray to return the same intersection. 00081 */ 00082 void rollback_last_intersection(); 00083 00084 /** 00085 * Get the last intersection in the RayHistory. This will return a null 00086 * EntityHandle (0) if the history is empty. 00087 */ 00088 ErrorCode get_last_intersection( EntityHandle& last_facet_hit ) const; 00089 00090 /** 00091 * @return the number of surface crossings currently represented by this ray history 00092 */ 00093 int size() const 00094 { 00095 return prev_facets.size(); 00096 } 00097 00098 /** 00099 * @return Boolean indicating if this entity is in the RayHistory 00100 */ 00101 bool in_history( EntityHandle ent ) const; 00102 00103 /** 00104 * Add entity to the RayHistory 00105 */ 00106 void add_entity( EntityHandle ent ); 00107 00108 private: 00109 std::vector< EntityHandle > prev_facets; 00110 00111 friend class GeomQueryTool; 00112 }; 00113 00114 // Constructors 00115 00116 GeomQueryTool( Interface* impl, 00117 bool find_geoments = false, 00118 EntityHandle modelRootSet = 0, 00119 bool p_rootSets_vector = true, 00120 bool restore_rootSets = true, 00121 bool trace_counting = false, 00122 double overlap_thickness = 0., 00123 double numerical_precision = 0.001 ); 00124 00125 GeomQueryTool( GeomTopoTool* geomtopotool, 00126 bool trace_counting = false, 00127 double overlap_thickness = 0., 00128 double numerical_precision = 0.001 ); 00129 00130 // Destructor 00131 ~GeomQueryTool(); 00132 00133 ErrorCode initialize(); 00134 00135 /**\brief find the next surface crossing from a given point in a given direction 00136 * 00137 * This is the primary method to enable ray tracing through a geometry. 00138 * Given a volume and a ray, it determines the distance to the nearest intersection 00139 * with a bounding surface of that volume and returns that distance and the 00140 * EntityHandle indicating on which surface that intersection occurs. 00141 * The caller can compute the location of the intersection by adding the 00142 * distance to the ray. 00143 * 00144 * When a series of calls to this function are made along the same ray (e.g. for 00145 * the purpose of tracking a ray through several volumes), the optional history 00146 * argument should be given. The history prevents previously intersected facets 00147 * from being intersected again. A single history should be used as long as a 00148 * ray is proceeding forward without changing direction. This situation is 00149 * sometimes referred to as "streaming." 00150 * 00151 * If a ray changes direction at an intersection site, the caller should call 00152 * reset_to_last_intersection() on the history object before the next ray fire. 00153 * 00154 * @param volume The volume at which to fire the ray 00155 * @param ray_start An array of x,y,z coordinates from which to start the ray. 00156 * @param ray_dir An array of x,y,z coordinates indicating the direction of the ray. 00157 * Must be of unit length. 00158 * @param next_surf Output parameter indicating the next surface intersected by the ray. 00159 * If no intersection is found, will be set to 0. 00160 * @param next_surf_dist Output parameter indicating distance to next_surf. If next_surf is 00161 * 0, this value is undefined and should not be used. 00162 * @param history Optional RayHistory object. If provided, the facets in the history are 00163 * assumed to not intersect with the given ray. The facet intersected 00164 * by this query will also be added to the history. 00165 * @param dist_limit Optional distance limit. If provided and > 0, no intersections at a 00166 * distance further than this value will be returned. 00167 * @param ray_orientation Optional ray orientation. If provided determines intersections 00168 * along the normal provided, e.g. if -1 allows intersections back along the 00169 * the ray direction, Default is 1, i.e. exit intersections 00170 * @param stats Optional TrvStats object used to measure performance of underlying OBB 00171 * ray-firing query. See OrientedBoxTreeTool.hpp for details. 00172 * 00173 */ 00174 ErrorCode ray_fire( const EntityHandle volume, 00175 const double ray_start[3], 00176 const double ray_dir[3], 00177 EntityHandle& next_surf, 00178 double& next_surf_dist, 00179 RayHistory* history = NULL, 00180 double dist_limit = 0, 00181 int ray_orientation = 1, 00182 OrientedBoxTreeTool::TrvStats* stats = NULL ); 00183 00184 /**\brief Test if a point is inside or outside a volume 00185 * 00186 * This method finds the point on the boundary of the volume that is nearest 00187 * the test point (x,y,z). If that point is "close" to a surface, a boundary test 00188 * is performed based on the normal of the surface at that point and the 00189 * optional ray direction (u,v,w). 00190 * @param volume The volume to test 00191 * @param xyz The location to test for volume containment 00192 * @param result Set to 0 if xyz it outside volume, 1 if inside, and -1 if on boundary. 00193 * @param Optional direction to use for underlying ray fire query. Used to ensure 00194 * consistent results when a ray direction is known. If NULL or {0,0,0} is 00195 * given, a random direction will be used. 00196 * @param history Optional RayHistory object to pass to underlying ray fire query. 00197 * The history is not modified by this call. 00198 */ 00199 ErrorCode point_in_volume( const EntityHandle volume, 00200 const double xyz[3], 00201 int& result, 00202 const double* uvw = NULL, 00203 const RayHistory* history = NULL ); 00204 00205 /**\brief Robust test if a point is inside or outside a volume using unit sphere area method 00206 * 00207 * This test may be more robust that the standard point_in_volume, but is much slower. 00208 * It does not detect 'on boundary' situations as point_in_volume does. 00209 * @param volume The volume to test 00210 * @param xyz The location to test for volume containment 00211 * @param result Set to 0 if xyz it outside volume, 1 if inside. 00212 */ 00213 ErrorCode point_in_volume_slow( const EntityHandle volume, const double xyz[3], int& result ); 00214 00215 /**\brief Find volume for a given location. 00216 * 00217 * Determines which volume contains the point if possible. If no volume is found, 00218 * a null EntityHandle is returned along with a MB_ENTITY_NOT_FOUND ErrorCode. 00219 * @param xyz The location to test 00220 * @param volume Set to volume handle containing the location if found 00221 * @param dir Optional direction to use for underlying ray fire query. Used to ensure 00222 * consistent results when a ray direction is known. If NULL or {0,0,0} is 00223 * given, a random direction will be used. 00224 */ 00225 ErrorCode find_volume( const double xyz[3], EntityHandle& volume, const double* dir = NULL ); 00226 00227 /**\brief Find volume for a given location using loop. (slow) 00228 * 00229 * Loops over all volumes in the model, checking for point containment 00230 * @param xyz The location to test 00231 * @param volume Set to volume handle containing the location if found 00232 * @param dir Optional direction to use for underlying ray fire query. Used to ensure 00233 * consistent results when a ray direction is known. If NULL or {0,0,0} is 00234 * given, a random direction will be used. 00235 */ 00236 ErrorCode find_volume_slow( const double xyz[3], EntityHandle& volume, const double* dir = NULL ); 00237 00238 /**\brief Test if a point is inside or outsize a volume's axis-aligned bounding box 00239 * 00240 * This is used as a fast way to determine whether a point is inside or outside of a volume 00241 * before performing a point_in_volume test which involves firing a ray. 00242 * @param volume The volume to test 00243 * @param point The location to test for bounding box containment 00244 * @param inside set to 0 if point is outside the box, 1 if inside 00245 */ 00246 ErrorCode point_in_box( const EntityHandle volume, const double point[3], int& inside ); 00247 00248 /** \brief Given a ray starting at a surface of a volume, check whether the ray enters or exits 00249 * the volume 00250 * 00251 * This function is most useful for rays that change directions at a surface crossing. 00252 * It can be used to check whether a direction change redirects the ray back into the 00253 * originating volume. 00254 * 00255 * @param volume The volume to test 00256 * @param surface A surface on volume 00257 * @param xyz A point location on surface 00258 * @param uvw A (unit) direction vector 00259 * @param result Set to 1 if ray is entering volume, or 0 if it is leaving 00260 * @param history Optional ray history object from a previous call to ray_fire. If present and 00261 * non-empty, the history is used to look up the surface facet at which the ray begins. Absent 00262 * a history, the facet nearest to xyz will be looked up. The history should always be provided 00263 * if available, as it avoids the computational expense of a nearest-facet query. 00264 */ 00265 ErrorCode test_volume_boundary( const EntityHandle volume, 00266 const EntityHandle surface, 00267 const double xyz[3], 00268 const double uvw[3], 00269 int& result, 00270 const RayHistory* history = NULL ); 00271 00272 /**\brief Find the distance to the point on the boundary of the volume closest to the test point 00273 * 00274 * @param volume Volume to query 00275 * @param point Coordinates of test point 00276 * @param result Set to the minimum distance from point to a surface in volume 00277 */ 00278 ErrorCode closest_to_location( EntityHandle volume, 00279 const double point[3], 00280 double& result, 00281 EntityHandle* closest_surface = 0 ); 00282 00283 /** Calculate the volume contained in a 'volume' */ 00284 ErrorCode measure_volume( EntityHandle volume, double& result ); 00285 00286 /** Calculate sum of area of triangles */ 00287 ErrorCode measure_area( EntityHandle surface, double& result ); 00288 00289 /** Get the normal to a given surface at the point on the surface closest to a given point 00290 * 00291 * This method first identifies which facet contains this point and then 00292 * calculates the unit outward normal of that facet. The facet of the 00293 * provided volume that is nearest the provided point is used for this 00294 * calculation. The search for that facet can be circumvented by providing 00295 * a RayHistory, in which case the last facet of the history will be used. 00296 * 00297 * @param surf Surface on which to get normal 00298 * @param xyz Point on surf 00299 * @param angle Set to coordinates of surface normal nearest xyz 00300 * @param history Optional ray history from a previous call to ray_fire(). 00301 * If present and non-empty, return the normal 00302 * of the most recently intersected facet, ignoring xyz. 00303 */ 00304 ErrorCode get_normal( EntityHandle surf, const double xyz[3], double angle[3], const RayHistory* history = NULL ); 00305 00306 private: 00307 /**\brief determine the point membership when the point is effectively on the boundary 00308 * 00309 * Called by point_in_volume when the point is with tolerance of the boundary. Compares the 00310 * ray direction with the surface normal to determine a volume membership. 00311 */ 00312 ErrorCode boundary_case( EntityHandle volume, 00313 int& result, 00314 double u, 00315 double v, 00316 double w, 00317 EntityHandle facet, 00318 EntityHandle surface ); 00319 00320 /** get the solid angle projected by a facet on a unit sphere around a point 00321 * - used by point_in_volume_slow 00322 */ 00323 ErrorCode poly_solid_angle( EntityHandle face, const CartVect& point, double& area ); 00324 00325 /**\brief State object used in calls to ray_fire() 00326 * 00327 * Storage for the "history" of a ray. This represents the surface facets 00328 * that the ray is known to have crossed, which cannot be crossed again 00329 * as long as the ray does not change direction. It is intended to be used 00330 * with a series of consecutive calls to ray_fire(), in which a ray passes 00331 * over potentially many surfaces. 00332 */ 00333 00334 public: 00335 /* 00336 Overlap Thickness: 00337 This tolerance is the maximum distance across an overlap. It should be zero 00338 unless the geometry has overlaps. The overlap thickness is set using the dagmc 00339 card. Overlaps must be small enough not to significantly affect physics. 00340 Performance: increasing tolerance decreases performance 00341 Robustness: increasing tolerance increases robustness 00342 Knowledge: user must have intuition of overlap thickness 00343 */ 00344 00345 /** Attempt to set a new overlap thickness tolerance, first checking for sanity */ 00346 00347 void set_overlap_thickness( double new_overlap_thickness ); 00348 00349 /* 00350 Numerical Precision: 00351 This tolerance is used for obb.intersect_ray, finding neighborhood of 00352 adjacent triangle for edge/node intersections, and error in advancing 00353 geometric position of particle (x' ~= x + d*u). When determining the 00354 neighborhood of adjacent triangles for edge/node intersections, the facet 00355 based model is expected to be watertight. 00356 Performance: increasing tolerance decreases performance (but not very much) 00357 Robustness: increasing tolerance increases robustness 00358 Knowledge: user should not change this tolerance 00359 */ 00360 00361 /** Attempt to set a new numerical precision , first checking for sanity 00362 * Use of this function is discouraged. 00363 */ 00364 void set_numerical_precision( double new_precision ); 00365 00366 void set_verbosity( bool value ) 00367 { 00368 verbose = value; 00369 } 00370 00371 bool get_verbosity() const 00372 { 00373 return verbose; 00374 } 00375 00376 double get_numerical_precision() 00377 { 00378 return numericalPrecision; 00379 } 00380 00381 double get_overlap_thickness() 00382 { 00383 return overlapThickness; 00384 } 00385 00386 GeomTopoTool* gttool() 00387 { 00388 return geomTopoTool; 00389 } 00390 00391 Interface* moab_instance() 00392 { 00393 return MBI; 00394 } 00395 00396 private: 00397 GeomTopoTool* geomTopoTool; 00398 bool verbose; 00399 bool owns_gtt; 00400 Interface* MBI; 00401 OrientedBoxTreeTool* obbTreeTool; 00402 bool counting; 00403 long long int n_pt_in_vol_calls; 00404 long long int n_ray_fire_calls; 00405 double overlapThickness, numericalPrecision; 00406 Tag senseTag; 00407 }; 00408 00409 } // namespace moab 00410 00411 #endif
