MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <GeomQueryTool.hpp>
Public Member Functions | |
| void | reset () |
| void | reset_to_last_intersection () |
| void | rollback_last_intersection () |
| ErrorCode | get_last_intersection (EntityHandle &last_facet_hit) const |
| int | size () const |
| bool | in_history (EntityHandle ent) const |
| void | add_entity (EntityHandle ent) |
Private Attributes | |
| std::vector< EntityHandle > | prev_facets |
Friends | |
| class | GeomQueryTool |
Definition at line 61 of file GeomQueryTool.hpp.
Add entity to the RayHistory
Definition at line 733 of file GeomQueryTool.cpp.
prev_facets.push_back( ent );
| ErrorCode moab::GeomQueryTool::RayHistory::get_last_intersection | ( | EntityHandle & | last_facet_hit | ) | const |
Get the last intersection in the RayHistory. This will return a null EntityHandle (0) if the history is empty.
Definition at line 715 of file GeomQueryTool.cpp.
References MB_ENTITY_NOT_FOUND, and MB_SUCCESS.
if( prev_facets.size() > 0 )
last_facet_hit = prev_facets.back();
return MB_SUCCESS;
else
return MB_ENTITY_NOT_FOUND;
| bool moab::GeomQueryTool::RayHistory::in_history | ( | EntityHandle | ent | ) | const |
Definition at line 728 of file GeomQueryTool.cpp.
return std::find( prev_facets.begin(), prev_facets.end(), ent ) != prev_facets.end();
Clear this entire history-- logically equivalent to creating a new history, but probably more efficient.
Definition at line 695 of file GeomQueryTool.cpp.
References prev_facets.
Referenced by gqt_outside_face_rayfire_history(), and gqt_outside_face_rayfire_history_fail().
prev_facets.clear();
Clear the history up to the most recent intersection. This should be called when a ray changes direction at the site of a surface crossing, a situation that most commonly occurs at a reflecting boundary.
Definition at line 700 of file GeomQueryTool.cpp.
if( prev_facets.size() > 1 )
prev_facets[0] = prev_facets.back();
prev_facets.resize( 1 );
Remove the most recent intersection. This allows a subsequent call along the same ray to return the same intersection.
Definition at line 710 of file GeomQueryTool.cpp.
if( prev_facets.size() ) prev_facets.pop_back();
| int moab::GeomQueryTool::RayHistory::size | ( | ) | const [inline] |
Definition at line 93 of file GeomQueryTool.hpp.
Referenced by gqt_outside_face_rayfire_history().
return prev_facets.size();
friend class GeomQueryTool [friend] |
Definition at line 111 of file GeomQueryTool.hpp.
std::vector< EntityHandle > moab::GeomQueryTool::RayHistory::prev_facets [private] |
Definition at line 109 of file GeomQueryTool.hpp.
Referenced by moab::GeomQueryTool::get_normal(), moab::GeomQueryTool::point_in_volume(), moab::GeomQueryTool::ray_fire(), reset(), size(), and moab::GeomQueryTool::test_volume_boundary().
