MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <GmshUtil.hpp>
Collaboration diagram for moab::GmshElemType:Public Attributes | |
| const char * | name |
| String name for use in error messages. | |
| unsigned | gmsh_type |
| GMsh integer type. | |
| EntityType | mb_type |
| MOAB type. | |
| unsigned | num_nodes |
| Number of nodes (0 for polygon) | |
| const int * | node_order |
Structure defining relation between MOAB and VTK element types. VTK had different types for quadratic than linear elements, so a tuple of the MOAB type and number of elements maps to a VTK type.
Definition at line 28 of file GmshUtil.hpp.
| unsigned moab::GmshElemType::gmsh_type |
GMsh integer type.
Definition at line 31 of file GmshUtil.hpp.
| EntityType moab::GmshElemType::mb_type |
MOAB type.
Definition at line 32 of file GmshUtil.hpp.
Referenced by moab::ReadGmsh::create_elements(), and moab::GmshUtil::get_gmsh_type().
| const char* moab::GmshElemType::name |
Definition at line 30 of file GmshUtil.hpp.
| const int* moab::GmshElemType::node_order |
Gmsh element node ordering, indexed by the Gmsh node position and containing the corresponding MOAB node position. NOTE: This field is NULL if MOAB and Gmsh ordering is the same!
Definition at line 34 of file GmshUtil.hpp.
Referenced by moab::ReadGmsh::create_elements(), and moab::WriteGmsh::write_file().
| unsigned moab::GmshElemType::num_nodes |
Definition at line 33 of file GmshUtil.hpp.
Referenced by moab::ReadGmsh::create_elements(), and moab::ReadGmsh::load_file().
