moab::ScdParData Class Reference
struct for keeping parallel data in one place More...
#include <ScdInterface.hpp>
+ Collaboration diagram for moab::ScdParData:
Public Types
enum  PartitionMethod {
  ALLJORKORI = 0, ALLJKBAL, SQIJ, SQJK,
  SQIJK, TRIVIAL, RCBZOLTAN, NOPART
Public Member Functions
 ScdParData ()
Public Attributes
int partMethod
 partition method used to partition global parametric space
int gDims [6]
 lower and upper corners of global box
int gPeriodic [3]
 is globally periodic in i or j or k
int pDims [3]
 number of procs in each direction
ParallelComm * pComm
 parallel communicator object for this par scd mesh
Static Public Attributes
static MOAB_EXPORT const char * PartitionMethodNames [NOPART+1]
 Partition method names.
Detailed Description
Definition at line 107 of file ScdInterface.hpp.
Member Enumeration Documentation
Partition method enumeration; these strategies are described in comments for compute_partition_alljorkori, compute_partition_alljkbal, compute_partition_sqij, compute_partition_sqjk, and compute_partition_sqijk
Enumerator:
ALLJORKORI
ALLJKBAL
SQIJ
SQJK
SQIJK
TRIVIAL
RCBZOLTAN
NOPART
Definition at line 120 of file ScdInterface.hpp.
Definition at line 110 of file ScdInterface.hpp.
References gDims, gPeriodic, and pDims.
                 : partMethod( NOPART ), pComm( NULL )
        gDims[0] = gDims[1] = gDims[2] = gDims[3] = gDims[4] = gDims[5] = 0;
        gPeriodic[0] = gPeriodic[1] = gPeriodic[2] = 0;
        pDims[0] = pDims[1] = pDims[2] = 0;
Member Data Documentation
Initial value:
 { "alljorkori", "alljkbal", "sqij",      "sqjk",
                                                   "sqijk",      "trivial",  "rcbzoltan", "nopart" }
Definition at line 133 of file ScdInterface.hpp.
Referenced by moab::operator<<(), and moab::ReadNC::parse_options().
Definition at line 148 of file ScdInterface.hpp.
Referenced by moab::ScdInterface::construct_box(), and create_parallel_mesh().
List of all members.
