moab::SMF_State Class Reference
#include <SMF_State.hpp>
+ Collaboration diagram for moab::SMF_State:
Public Member Functions
 SMF_State (const SMF_ivars &ivar, SMF_State *next=0)
void set_vertex_correction (int i)
void inc (const char *var, int delta=1)
void dec (const char *var, int delta=1)
void mmult (const AffineXform &)
void mload (const AffineXform &)
void vertex (double v[3])
void normal (double n[3])
void face (int *, const SMF_ivars &ivar)
Private Attributes
int first_vertex
int vertex_correction
AffineXform xform
Detailed Description
Definition at line 17 of file SMF_State.hpp.
moab::SMF_State::SMF_State ( const SMF_ivars &  ivar,
SMF_State *  next = 0
Definition at line 10 of file SMF_State.cpp.
References first_vertex, moab::SMF_ivars::next_vertex, vertex_correction, and xform.
    first_vertex = ivar.next_vertex;
    if( next )
        vertex_correction = next->vertex_correction;
        xform             = next->xform;
    else
        vertex_correction = 0;
        AffineXform identity;
        xform = identity;
Member Function Documentation
void moab::SMF_State::dec ( const char *  var,
int  delta = 1
void moab::SMF_State::face ( int *  verts,
Definition at line 36 of file SMF_State.cpp.
References first_vertex, moab::SMF_ivars::next_vertex, and vertex_correction.
    for( int i = 0; i < 3; i++ )
        if( verts[i] < 0 )
            verts[i] += ivar.next_vertex;
        else
            verts[i] += vertex_correction + ( first_vertex - 1 );
void moab::SMF_State::inc ( const char *  var,
int  delta = 1
void moab::SMF_State::mload ( const AffineXform &  M)
Definition at line 62 of file SMF_State.cpp.
References xform.
    xform = M;
void moab::SMF_State::mmult ( const AffineXform &  M)
Definition at line 52 of file SMF_State.cpp.
References moab::AffineXform::accumulate(), and xform.
    // initially, we tried this:
    // xform.accumulate(M);
    // maybe we should do M.accumulate(xform)
    AffineXform tmp = M;
    tmp.accumulate( xform );
    xform = tmp;
void moab::SMF_State::normal ( double  n[3])
Definition at line 31 of file SMF_State.cpp.
References xform, and moab::AffineXform::xform_vector().
    xform.xform_vector( nrm );
Definition at line 47 of file SMF_State.cpp.
References vertex_correction.
void moab::SMF_State::vertex ( double  v[3])
Definition at line 26 of file SMF_State.cpp.
References xform, and moab::AffineXform::xform_point().
    xform.xform_point( v );
Member Data Documentation
Definition at line 22 of file SMF_State.hpp.
Referenced by face(), and SMF_State().
Definition at line 23 of file SMF_State.hpp.
Referenced by face(), set_vertex_correction(), and SMF_State().
Definition at line 24 of file SMF_State.hpp.
Referenced by mload(), mmult(), normal(), SMF_State(), and vertex().
List of all members.
