MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <ZoltanPartitioner.hpp>
Inheritance diagram for ZoltanPartitioner:
Collaboration diagram for ZoltanPartitioner:Public Member Functions | |
| ZoltanPartitioner (Interface *impl=NULL, const bool use_coords=false, int argc=0, char **argv=NULL) | |
| virtual | ~ZoltanPartitioner () |
| ErrorCode | balance_mesh (const char *zmethod, const char *other_method, const bool write_as_sets=true, const bool write_as_tags=false) |
| virtual ErrorCode | partition_mesh_and_geometry (const double part_geom_mesh_size, const int nparts, const char *zmethod, const char *other_method, double imbal_tol, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const int obj_weight=0, const int edge_weight=0, const bool part_surf=false, const bool ghost=false, const int projection_type=0, const bool recompute_rcb_box=false, const bool print_time=false) |
| virtual ErrorCode | partition_mesh (const int nparts, const char *method, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const bool partition_tagged_sets=false, const bool partition_tagged_ents=false, const char *aggregating_tag=NULL, const bool print_time=false) |
| ErrorCode | partition_inferred_mesh (EntityHandle sfileset, size_t num_parts, int part_dim=3, const bool write_as_sets=true, int projection_type=0) |
| virtual ErrorCode | write_partition (const int nparts, Range &elems, const int *assignment, const bool write_as_sets, const bool write_as_tags) |
| ErrorCode | repartition (std::vector< double > &x, std::vector< double > &y, std::vector< double > &z, int StartID, const char *zmethod, Range &localGIDs) |
| ErrorCode | partition_owned_cells (Range &owned, std::multimap< int, int > &extraGraphEdges, std::map< int, int > procs, int &numNewPartitions, std::map< int, Range > &distribution, int met) |
| ErrorCode | include_closure () |
| void | SetOCTPART_Parameters (const char *oct_method) |
| void | SetPARMETIS_Parameters (const char *parmetis_method) |
| void | SetHypergraph_Parameters (const char *phg_method) |
| void | SetHSFC_Parameters () |
| void | SetRIB_Parameters () |
| void | SetRCB_Parameters (const bool recompute_rcb_box=false) |
Private Member Functions | |
| int | mbGlobalSuccess (int rc) |
| void | mbPrintGlobalResult (const char *s, int begin, int import, int exp, int change) |
| void | mbShowError (int val, const char *s) |
| ErrorCode | assemble_graph (const int dimension, std::vector< double > &coords, std::vector< int > &moab_ids, std::vector< int > &adjacencies, std::vector< int > &length, Range &elems, bool part_geom=false, const int projection_type=0) |
| void | mbFinalizePoints (int npts, int numExport, ZOLTAN_ID_PTR exportLocalIDs, int *exportProcs, int **assignment) |
| int | mbInitializePoints (int npts, double *pts, int *ids, int *adjs, int *length, double *obj_weights=NULL, double *edge_weights=NULL, int *parts=NULL, bool part_geom=false) |
Private Attributes | |
| Zoltan * | myZZ |
| Range | partSets |
| int | myNumPts |
| int | argcArg |
| char ** | argvArg |
Definition at line 109 of file ZoltanPartitioner.hpp.
| ZoltanPartitioner::ZoltanPartitioner | ( | Interface * | impl = NULL, |
| const bool | use_coords = false, |
| int | argc = 0, |
| char ** | argv = NULL |
Definition at line 71 of file ZoltanPartitioner.cpp.
: PartitionerBase< int >( impl, use_coords #ifdef MOAB_HAVE_MPI , parcomm #endif ), myZZ( NULL ), myNumPts( 0 ), argcArg( argc ), argvArg( argv ) #ifdef MOAB_HAVE_CGM , gti( gqt ) #endif { }
| ZoltanPartitioner::~ZoltanPartitioner | ( | ) | [virtual] |
Definition at line 97 of file ZoltanPartitioner.cpp.
References myZZ.
| ErrorCode ZoltanPartitioner::assemble_graph | ( | const int | dimension, |
| std::vector< double > & | coords, | ||
| std::vector< int > & | moab_ids, | ||
| std::vector< int > & | adjacencies, | ||
| std::vector< int > & | length, | ||
| Range & | elems, | ||
| bool | part_geom = false, |
| const int | projection_type = 0 |
| ) | [private] |
Definition at line 794 of file ZoltanPartitioner.cpp.
References moab::ParallelComm::assign_global_ids(), PartitionerBase< int >::assign_global_ids, moab::Range::begin(), moab::Range::clear(), moab::debug, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::MeshTopoUtil::get_average_position(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::globalId_tag(), moab::MAX_SUB_ENTITIES, MB_SUCCESS, PartitionerBase< int >::mbImpl, mbpc, neighbors(), RR, moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by balance_mesh(), and partition_mesh_and_geometry().
// assemble a graph with vertices equal to elements of specified dimension, edges
// signified by list of other elements to which an element is connected
// get the elements of that dimension
ErrorCode result = mbImpl->get_entities_by_dimension( 0, dimension, elems );
if( MB_SUCCESS != result || elems.empty() ) return result;
// assign global ids
if( assign_global_ids )
EntityHandle rootset = 0;
result = mbpc->assign_global_ids( rootset, dimension, 1, true, true );RR;
// now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1
// dimensional neighbors
MeshTopoUtil mtu( mbImpl );
Range adjs;
// can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited
// by MBCN
int neighbors[5 * MAX_SUB_ENTITIES];
double avg_position[3];
int moab_id;
// get the global id tag handle
Tag gid = mbImpl->globalId_tag();
for( Range::iterator rit = elems.begin(); rit != elems.end(); ++rit )
if( !part_geom )
// get bridge adjacencies
adjs.clear();
result = mtu.get_bridge_adjacencies( *rit, ( dimension > 0 ? dimension - 1 : 3 ), dimension, adjs );RR;
// get the graph vertex ids of those
if( !adjs.empty() )
assert( adjs.size() < 5 * MAX_SUB_ENTITIES );
result = mbImpl->tag_get_data( gid, adjs, neighbors );RR;
// copy those into adjacencies vector
length.push_back( (int)adjs.size() );
std::copy( neighbors, neighbors + adjs.size(), std::back_inserter( adjacencies ) );
// get average position of vertices
result = mtu.get_average_position( *rit, avg_position );RR;
// get the graph vertex id for this element
result = mbImpl->tag_get_data( gid, &( *rit ), 1, &moab_id );RR;
// copy those into coords vector
moab_ids.push_back( moab_id );
// transform coordinates to spherical coordinates, if requested
if( projection_type > 0 ) IntxUtils::transform_coordinates( avg_position, projection_type );
std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) );
if( debug )
std::cout << "Length vector: " << std::endl;
std::copy( length.begin(), length.end(), std::ostream_iterator< int >( std::cout, ", " ) );
std::cout << std::endl;
std::cout << "Adjacencies vector: " << std::endl;
std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( std::cout, ", " ) );
std::cout << "Moab_ids vector: " << std::endl;
std::copy( moab_ids.begin(), moab_ids.end(), std::ostream_iterator< int >( std::cout, ", " ) );
std::cout << "Coords vector: " << std::endl;
std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( std::cout, ", " ) );
return MB_SUCCESS;
| ErrorCode ZoltanPartitioner::balance_mesh | ( | const char * | zmethod, |
| const char * | other_method, | ||
| const bool | write_as_sets = true, |
| const bool | write_as_tags = false |
Definition at line 102 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, assemble_graph(), moab::ParallelComm::comm(), ErrorCode, length(), MB_SUCCESS, mbFinalizePoints(), mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), mbGlobalSuccess(), mbInitializePoints(), mbpc, mbPrintGlobalResult(), myNumPts, myZZ, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), RR, SetHSFC_Parameters(), SetHypergraph_Parameters(), SetOCTPART_Parameters(), SetPARMETIS_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), and write_partition().
if( !strcmp( zmethod, "RR" ) && !strcmp( zmethod, "RCB" ) && !strcmp( zmethod, "RIB" ) &&
!strcmp( zmethod, "HSFC" ) && !strcmp( zmethod, "Hypergraph" ) && !strcmp( zmethod, "PHG" ) &&
!strcmp( zmethod, "PARMETIS" ) && !strcmp( zmethod, "OCTPART" ) )
std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be "
<< "RR, RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl;
return MB_FAILURE;
std::vector< double > pts; // x[0], y[0], z[0], ... from MOAB
std::vector< int > ids; // point ids from MOAB
std::vector< int > adjs, length;
Range elems;
// Get a mesh from MOAB and divide it across processors.
ErrorCode result;
if( mbpc->proc_config().proc_rank() == 0 )
result = assemble_graph( 3, pts, ids, adjs, length, elems );RR;
myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0] );
// Initialize Zoltan. This is a C call. The simple C++ code
// that creates Zoltan objects does not keep track of whether
// Zoltan_Initialize has been called.
float version;
Zoltan_Initialize( argcArg, argvArg, &version );
// Create Zoltan object. This calls Zoltan_Create.
if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
if( NULL == zmethod || !strcmp( zmethod, "RCB" ) )
SetRCB_Parameters();
else if( !strcmp( zmethod, "RIB" ) )
SetRIB_Parameters();
else if( !strcmp( zmethod, "HSFC" ) )
SetHSFC_Parameters();
else if( !strcmp( zmethod, "Hypergraph" ) || !strcmp( zmethod, "PHG" ) )
if( NULL == other_method )
SetHypergraph_Parameters( "auto" );
else
SetHypergraph_Parameters( other_method );
else if( !strcmp( zmethod, "PARMETIS" ) )
SetPARMETIS_Parameters( "RepartGDiffusion" );
else
SetPARMETIS_Parameters( other_method );
else if( !strcmp( zmethod, "OCTPART" ) )
SetOCTPART_Parameters( "2" );
else
SetOCTPART_Parameters( other_method );
// Call backs:
myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL );
myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL );
myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL );
myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL );
myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL );
myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL );
// Perform the load balancing partitioning
int changes;
int numGidEntries;
int numLidEntries;
int numImport;
ZOLTAN_ID_PTR importGlobalIds;
ZOLTAN_ID_PTR importLocalIds;
int* importProcs;
int* importToPart;
int numExport;
ZOLTAN_ID_PTR exportGlobalIds;
ZOLTAN_ID_PTR exportLocalIds;
int* exportProcs;
int* exportToPart;
int rc = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, numImport, importGlobalIds, importLocalIds,
importProcs, importToPart, numExport, exportGlobalIds, exportLocalIds, exportProcs,
exportToPart );
rc = mbGlobalSuccess( rc );
if( !rc )
mbPrintGlobalResult( "==============Result==============", myNumPts, numImport, numExport, changes );
else
return MB_FAILURE;
// take results & write onto MOAB partition sets
int* assignment;
mbFinalizePoints( (int)ids.size(), numExport, exportLocalIds, exportProcs, &assignment );
result = write_partition( mbpc->proc_config().proc_size(), elems, assignment, write_as_sets, write_as_tags );
if( MB_SUCCESS != result ) return result;
free( (int*)assignment );
// Free the memory allocated for lists returned by LB_Parition()
myZZ->LB_Free_Part( &importGlobalIds, &importLocalIds, &importProcs, &importToPart );
myZZ->LB_Free_Part( &exportGlobalIds, &exportLocalIds, &exportProcs, &exportToPart );
// Implementation note: A Zoltan object contains an MPI communicator.
// When the Zoltan object is destroyed, it uses it's MPI communicator.
// So it is important that the Zoltan object is destroyed before
// the MPI communicator is destroyed. To ensure this, dynamically
// allocate the Zoltan object, so you can explicitly destroy it.
// If you create a Zoltan object on the stack, it's destructor will
// be invoked atexit, possibly after the communicator's
// destructor.
return MB_SUCCESS;
| ErrorCode ZoltanPartitioner::include_closure | ( | ) | [virtual] |
Implements PartitionerBase< int >.
Definition at line 726 of file ZoltanPartitioner.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::find(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::intersect(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, PartitionerBase< int >::mbImpl, partSets, RR, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and smoab::UNION.
Referenced by main().
ErrorCode result;
Range ents;
Range adjs;
std::cout << "Adding closure..." << std::endl;
for( Range::iterator rit = partSets.begin(); rit != partSets.end(); ++rit )
// get the top-dimensional entities in the part
result = mbImpl->get_entities_by_handle( *rit, ents, true );RR;
if( ents.empty() ) continue;
// get intermediate-dimensional adjs and add to set
for( int d = mbImpl->dimension_from_handle( *ents.begin() ) - 1; d >= 1; d-- )
adjs.clear();
result = mbImpl->get_adjacencies( ents, d, false, adjs, Interface::UNION );RR;
result = mbImpl->add_entities( *rit, adjs );RR;
// now get vertices and add to set; only need to do for ents, not for adjs
adjs.clear();
result = mbImpl->get_adjacencies( ents, 0, false, adjs, Interface::UNION );RR;
ents.clear();
// now go over non-part entity sets, looking for contained entities
Range sets, part_ents;
result = mbImpl->get_entities_by_type( 0, MBENTITYSET, sets );RR;
for( Range::iterator rit = sets.begin(); rit != sets.end(); ++rit )
// skip parts
if( partSets.find( *rit ) != partSets.end() ) continue;
// get entities in this set, recursively
ents.clear();
// now check over all parts
for( Range::iterator rit2 = partSets.begin(); rit2 != partSets.end(); ++rit2 )
part_ents.clear();
result = mbImpl->get_entities_by_handle( *rit2, part_ents, false );RR;
Range int_range = intersect( ents, part_ents );
if( !int_range.empty() )
// non-empty intersection, add to part set
result = mbImpl->add_entities( *rit2, &( *rit ), 1 );RR;
// finally, mark all the part sets as having the closure
Tag closure_tag;
result =
mbImpl->tag_get_handle( "INCLUDES_CLOSURE", 1, MB_TYPE_INTEGER, closure_tag, MB_TAG_SPARSE | MB_TAG_CREAT );RR;
std::vector< int > closure_vals( partSets.size(), 1 );
result = mbImpl->tag_set_data( closure_tag, partSets, &closure_vals[0] );RR;
return MB_SUCCESS;
| void ZoltanPartitioner::mbFinalizePoints | ( | int | npts, |
| int | numExport, | ||
| ZOLTAN_ID_PTR | exportLocalIDs, | ||
| int * | exportProcs, | ||
| int ** | assignment | ||
| ) | [private] |
Definition at line 1975 of file ZoltanPartitioner.cpp.
References moab::ParallelComm::comm(), mbpc, NumPoints, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), and moab::ProcConfig::proc_size().
Referenced by balance_mesh().
int* MyAssignment;
int i;
int numPts;
MPI_Status stat;
int* recvA;
/* assign pts to start */
MyAssignment = (int*)malloc( sizeof( int ) * npts );
else
MyAssignment = (int*)malloc( sizeof( int ) * NumPoints );
for( i = 0; i < NumPoints; i++ )
MyAssignment[i] = mbpc->proc_config().proc_rank();
for( i = 0; i < numExport; i++ )
MyAssignment[exportLocalIDs[i]] = exportProcs[i];
/* collect pts */
recvA = MyAssignment + NumPoints;
for( i = 1; i < (int)mbpc->proc_config().proc_size(); i++ )
MPI_Recv( &numPts, 1, MPI_INT, i, 0x04, mbpc->comm(), &stat );
MPI_Recv( recvA, numPts, MPI_INT, i, 0x05, mbpc->comm(), &stat );
recvA += numPts;
*assignment = MyAssignment;
else
MPI_Send( &NumPoints, 1, MPI_INT, 0, 0x04, mbpc->comm() );
MPI_Send( MyAssignment, NumPoints, MPI_INT, 0, 0x05, mbpc->comm() );
free( MyAssignment );
| int ZoltanPartitioner::mbGlobalSuccess | ( | int | rc | ) | [private] |
Definition at line 2022 of file ZoltanPartitioner.cpp.
References moab::ParallelComm::comm(), fail(), mbpc, mbShowError(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), and moab::ProcConfig::proc_size().
int fail = 0;
unsigned int i;
int* vals = (int*)malloc( mbpc->proc_config().proc_size() * sizeof( int ) );
MPI_Allgather( &rc, 1, MPI_INT, vals, 1, MPI_INT, mbpc->comm() );
for( i = 0; i < mbpc->proc_config().proc_size(); i++ )
if( vals[i] != ZOLTAN_OK )
if( 0 == mbpc->proc_config().proc_rank() )
mbShowError( vals[i], "Result on process " );
fail = 1;
free( vals );
return fail;
| int ZoltanPartitioner::mbInitializePoints | ( | int | npts, |
| double * | pts, | ||
| int * | ids, | ||
| int * | adjs, | ||
| int * | length, | ||
| double * | obj_weights = NULL, |
| double * | edge_weights = NULL, |
| int * | parts = NULL, |
| bool | part_geom = false |
| ) | [private] |
Definition at line 1855 of file ZoltanPartitioner.cpp.
References moab::ParallelComm::comm(), EdgeWeights, GlobalIds, length(), mbpc, NborGlobalId, NborProcs, NumEdges, NumPoints, ObjWeights, Parts, Points, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), and moab::sum().
unsigned int i;
int j;
int *numPts, *nborProcs = NULL;
int sum, ptsPerProc, ptsAssigned, mySize;
MPI_Status stat;
double* sendPts;
int* sendIds;
int* sendEdges = NULL;
int* sendNborId = NULL;
int* sendProcs;
/* divide pts to start */
numPts = (int*)malloc( sizeof( int ) * mbpc->proc_config().proc_size() );
ptsPerProc = npts / mbpc->proc_config().proc_size();
ptsAssigned = 0;
for( i = 0; i < mbpc->proc_config().proc_size() - 1; i++ )
numPts[i] = ptsPerProc;
ptsAssigned += ptsPerProc;
numPts[mbpc->proc_config().proc_size() - 1] = npts - ptsAssigned;
mySize = numPts[mbpc->proc_config().proc_rank()];
sendPts = pts + ( 3 * numPts[0] );
sendIds = ids + numPts[0];
sum = 0; // possible no adjacency sent
if( !part_geom )
sendEdges = length + numPts[0];
for( j = 0; j < numPts[0]; j++ )
sum += length[j];
sendNborId = adjs + sum;
for( j = numPts[0]; j < npts; j++ )
sum += length[j];
nborProcs = (int*)malloc( sizeof( int ) * sum );
for( j = 0; j < sum; j++ )
if( ( i = adjs[j] / ptsPerProc ) < mbpc->proc_config().proc_size() )
nborProcs[j] = i;
else
nborProcs[j] = mbpc->proc_config().proc_size() - 1;
sendProcs = nborProcs + ( sendNborId - adjs );
for( i = 1; i < mbpc->proc_config().proc_size(); i++ )
MPI_Send( &numPts[i], 1, MPI_INT, i, 0x00, mbpc->comm() );
MPI_Send( sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01, mbpc->comm() );
MPI_Send( sendIds, numPts[i], MPI_INT, i, 0x03, mbpc->comm() );
MPI_Send( sendEdges, numPts[i], MPI_INT, i, 0x06, mbpc->comm() );
sum = 0;
for( j = 0; j < numPts[i]; j++ )
sum += sendEdges[j];
MPI_Send( sendNborId, sum, MPI_INT, i, 0x07, mbpc->comm() );
MPI_Send( sendProcs, sum, MPI_INT, i, 0x08, mbpc->comm() );
sendPts += ( 3 * numPts[i] );
sendIds += numPts[i];
sendEdges += numPts[i];
sendNborId += sum;
sendProcs += sum;
free( numPts );
else
MPI_Recv( &mySize, 1, MPI_INT, 0, 0x00, mbpc->comm(), &stat );
pts = (double*)malloc( sizeof( double ) * 3 * mySize );
ids = (int*)malloc( sizeof( int ) * mySize );
length = (int*)malloc( sizeof( int ) * mySize );
if( obj_weights != NULL ) obj_weights = (double*)malloc( sizeof( double ) * mySize );
MPI_Recv( pts, 3 * mySize, MPI_DOUBLE, 0, 0x01, mbpc->comm(), &stat );
MPI_Recv( ids, mySize, MPI_INT, 0, 0x03, mbpc->comm(), &stat );
MPI_Recv( length, mySize, MPI_INT, 0, 0x06, mbpc->comm(), &stat );
sum = 0;
for( j = 0; j < mySize; j++ )
sum += length[j];
adjs = (int*)malloc( sizeof( int ) * sum );
if( edge_weights != NULL ) edge_weights = (double*)malloc( sizeof( double ) * sum );
MPI_Recv( adjs, sum, MPI_INT, 0, 0x07, mbpc->comm(), &stat );
MPI_Recv( nborProcs, sum, MPI_INT, 0, 0x08, mbpc->comm(), &stat );
Points = pts;
GlobalIds = ids;
NumPoints = mySize;
NumEdges = length;
NborGlobalId = adjs;
NborProcs = nborProcs;
ObjWeights = obj_weights;
EdgeWeights = edge_weights;
Parts = parts;
return mySize;
| void ZoltanPartitioner::mbPrintGlobalResult | ( | const char * | s, |
| int | begin, | ||
| int | import, | ||
| int | exp, | ||
| int | change | ||
| ) | [private] |
Definition at line 2046 of file ZoltanPartitioner.cpp.
References moab::ParallelComm::comm(), mbpc, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), and moab::ProcConfig::proc_size().
unsigned int i;
int* v1 = (int*)malloc( 4 * sizeof( int ) );
int* v2 = NULL;
int* v;
v1[0] = begin;
v1[1] = import;
v1[2] = exp;
v1[3] = change;
v2 = (int*)malloc( 4 * mbpc->proc_config().proc_size() * sizeof( int ) );
MPI_Gather( v1, 4, MPI_INT, v2, 4, MPI_INT, 0, mbpc->comm() );
fprintf( stdout, "======%s======\n", s );
for( i = 0, v = v2; i < mbpc->proc_config().proc_size(); i++, v += 4 )
fprintf( stdout, "%u: originally had %d, import %d, exp %d, %s\n", i, v[0], v[1], v[2],
v[3] ? "a change of partitioning" : "no change" );
fprintf( stdout, "==========================================\n" );
fflush( stdout );
free( v2 );
free( v1 );
| void ZoltanPartitioner::mbShowError | ( | int | val, |
| const char * | s | ||
| ) | [private] |
Definition at line 2082 of file ZoltanPartitioner.cpp.
References mbpc, moab::ParallelComm::proc_config(), and moab::ProcConfig::proc_rank().
Referenced by mbGlobalSuccess().
if( s ) printf( "%s ", s );
switch( val )
case ZOLTAN_OK:
printf( "%d: SUCCESSFUL\n", mbpc->proc_config().proc_rank() );
break;
case ZOLTAN_WARN:
printf( "%d: WARNING\n", mbpc->proc_config().proc_rank() );
break;
case ZOLTAN_FATAL:
printf( "%d: FATAL ERROR\n", mbpc->proc_config().proc_rank() );
break;
case ZOLTAN_MEMERR:
printf( "%d: MEMORY ALLOCATION ERROR\n", mbpc->proc_config().proc_rank() );
break;
default:
printf( "%d: INVALID RETURN CODE\n", mbpc->proc_config().proc_rank() );
break;
| ErrorCode ZoltanPartitioner::partition_inferred_mesh | ( | EntityHandle | sfileset, |
| size_t | num_parts, | ||
| int | part_dim = 3, |
Definition at line 354 of file ZoltanPartitioner.cpp.
References moab::Interface::add_entities(), moab::Interface::add_parent_child(), moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), MB_SUCCESS, MBENTITYSET, PartitionerBase< int >::mbImpl, mbpc, MESHSET_SET, myZZ, moab::ParallelComm::partition_tag(), moab::Interface::remove_entities(), RR, moab::Range::size(), moab::Interface::tag_set_data(), and smoab::UNION.
ErrorCode result;
moab::Range elverts;
result = mbImpl->get_entities_by_dimension( sfileset, part_dim, elverts );RR;
std::vector< double > elcoords( elverts.size() * 3 );
result = mbImpl->get_coords( elverts, &elcoords[0] );RR;
std::vector< std::vector< EntityHandle > > part_assignments( num_parts );
int part, proc;
// Loop over coordinates
for( size_t iel = 0; iel < elverts.size(); iel++ )
// Gather coordinates into temporary array
double* ecoords = &elcoords[iel * 3];
// do a projection if needed
if( projection_type > 0 ) IntxUtils::transform_coordinates( ecoords, projection_type );
// Compute the coordinate's part assignment
myZZ->LB_Point_PP_Assign( ecoords, proc, part );
// Store the part assignment in the return array
part_assignments[part].push_back( elverts[iel] );
// get the partition set tag
Tag part_set_tag = mbpc->partition_tag();
// If some entity sets exist, let us delete those first.
if( write_as_sets )
moab::Range oldpsets;
result = mbImpl->get_entities_by_type_and_tag( sfileset, MBENTITYSET, &part_set_tag, NULL, 1, oldpsets,
result = mbImpl->remove_entities( sfileset, oldpsets );RR;
size_t nparts_assigned = 0;
for( size_t partnum = 0; partnum < num_parts; ++partnum )
std::vector< EntityHandle >& partvec = part_assignments[partnum];
nparts_assigned += ( partvec.size() ? 1 : 0 );
if( write_as_sets )
EntityHandle partNset;
result = mbImpl->create_meshset( moab::MESHSET_SET, partNset );RR;
if( partvec.size() )
result = mbImpl->add_entities( partNset, &partvec[0], partvec.size() );RR;
result = mbImpl->add_parent_child( sfileset, partNset );RR;
// part numbering should start from 0
int ipartnum = (int)partnum;
// assign partitions as a sparse tag by grouping elements under sets
result = mbImpl->tag_set_data( part_set_tag, &partNset, 1, &ipartnum );RR;
else
/* assign as a dense vector to all elements
allocate integer-size partitions */
std::vector< int > assignment( partvec.size(),
partnum ); // initialize all values to partnum
result = mbImpl->tag_set_data( part_set_tag, &partvec[0], partvec.size(), &assignment[0] );RR;
if( nparts_assigned != num_parts )
std::cout << "WARNING: The inference yielded lesser number of parts (" << nparts_assigned
<< ") than requested by user (" << num_parts << ").\n";
return MB_SUCCESS;
| ErrorCode ZoltanPartitioner::partition_mesh | ( | const int | nparts, |
| const char * | method, | ||
| const int | part_dim = 3, |
| const bool | write_as_tags = false, |
| const bool | partition_tagged_sets = false, |
| const bool | partition_tagged_ents = false, |
| const char * | aggregating_tag = NULL, |
| const bool | print_time = false |
| ) | [inline, virtual] |
Definition at line 297 of file ZoltanPartitioner.hpp.
return partition_mesh_and_geometry( -1.0, nparts, method, NULL, 1.03, part_dim, write_as_sets, write_as_tags, 0, 0,
false, false, 0, false, print_time );
| ErrorCode ZoltanPartitioner::partition_mesh_and_geometry | ( | const double | part_geom_mesh_size, |
| const int | nparts, | ||
| const char * | zmethod, | ||
| double | imbal_tol, | ||
| const int | obj_weight = 0, |
| const int | edge_weight = 0, |
| const bool | part_surf = false, |
| const bool | ghost = false, |
| const int | projection_type = 0, |
| const bool | recompute_rcb_box = false, |
| ) | [virtual] |
Definition at line 441 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, assemble_graph(), moab::ParallelComm::comm(), moab::debug, moab::Range::empty(), entities, ErrorCode, moab::Interface::get_entities_by_dimension(), length(), MB_SUCCESS, mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), mbGetPart(), PartitionerBase< int >::mbImpl, mbInitializePoints(), mbpc, myNumPts, myZZ, nparts, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), RR, SetHSFC_Parameters(), SetHypergraph_Parameters(), SetOCTPART_Parameters(), SetPARMETIS_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), moab::Range::size(), t, and write_partition().
// should only be called in serial
if( mbpc->proc_config().proc_size() != 1 )
std::cout << "ZoltanPartitioner::partition_mesh_and_geometry must be called in serial." << std::endl;
return MB_FAILURE;
clock_t t = clock();
if( NULL != zmethod && strcmp( zmethod, "RR" ) && strcmp( zmethod, "RCB" ) && strcmp( zmethod, "RIB" ) &&
strcmp( zmethod, "HSFC" ) && strcmp( zmethod, "Hypergraph" ) && strcmp( zmethod, "PHG" ) &&
strcmp( zmethod, "PARMETIS" ) && strcmp( zmethod, "OCTPART" ) )
<< "RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl;
return MB_FAILURE;
bool part_geom = false;
if( 0 == strcmp( zmethod, "RR" ) || 0 == strcmp( zmethod, "RCB" ) || 0 == strcmp( zmethod, "RIB" ) ||
0 == strcmp( zmethod, "HSFC" ) )
part_geom = true; // so no adjacency / edges needed
std::vector< int > adjs, length, parts;
std::vector< double > obj_weights, edge_weights;
Range elems;
DLIList< RefEntity* > entities;
#endif
// Get a mesh from MOAB and diide it across processors.
ErrorCode result = MB_SUCCESS;
// short-circuit everything if RR partition is requested
if( !strcmp( zmethod, "RR" ) )
if( part_geom_mesh_size < 0. )
// get all elements
result = mbImpl->get_entities_by_dimension( 0, part_dim, elems );RR;
if( elems.empty() ) return MB_FAILURE;
// make a trivial assignment vector
std::vector< int > assign_vec( elems.size() );
int num_per = elems.size() / nparts;
int extra = elems.size() % nparts;
if( extra ) num_per++;
int nstart = 0;
for( int i = 0; i < nparts; i++ )
if( i == extra ) num_per--;
std::fill( &assign_vec[nstart], &assign_vec[nstart + num_per], i );
nstart += num_per;
result = write_partition( nparts, elems, &assign_vec[0], write_as_sets, write_as_tags );RR;
else
result = partition_round_robin( nparts );RR;
#endif
return result;
std::cout << "Assembling graph..." << std::endl;
// if (!part_geom) {
result = assemble_graph( part_dim, pts, ids, adjs, length, elems, part_geom, projection_type );RR;
else
result = assemble_graph( part_dim, pts, ids, adjs, length, obj_weights, edge_weights, parts, entities,
part_geom_mesh_size, nparts );RR;
if( debug )
int n_ids = ids.size();
entities.reset();
int i_leng = 0;
for( int i = 0; i < n_ids; i++ )
std::cout << "graph_input_ids[" << i << "]=" << ids[i] << ",obj_weights=" << obj_weights[i]
<< ",entity_id=" << entities.get_and_step()->id() << ",part=" << parts[i] << std::endl;
for( int j = 0; j < length[i]; j++ )
std::cout << "adjs[" << j << "]=" << adjs[i_leng] << ",edge_weights=" << edge_weights[i_leng]
<< std::endl;
i_leng++;
#endif
if( print_time )
std::cout << " time to assemble graph: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
t = clock();
double* o_wgt = NULL;
double* e_wgt = NULL;
if( obj_weights.size() > 0 ) o_wgt = &obj_weights[0];
if( edge_weights.size() > 0 ) e_wgt = &edge_weights[0];
myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0], o_wgt, e_wgt, &parts[0],
part_geom );
if( print_time )
std::cout << " time to initialize points: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
t = clock();
float version;
std::cout << "Initializing zoltan..." << std::endl;
SetRCB_Parameters( recompute_rcb_box );
if( NULL == other_method || ( other_method[0] == '\0' ) )
else
if( imbal_tol )
std::ostringstream str;
str << imbal_tol;
myZZ->Set_Param( "IMBALANCE_TOL", str.str().c_str() ); // no debug messages
else
else
// set # requested partitions
char buff[10];
sprintf( buff, "%d", nparts );
int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff );
if( ZOLTAN_OK != retval ) return MB_FAILURE;
// request only partition assignments
retval = myZZ->Set_Param( "RETURN_LISTS", "PARTITION ASSIGNMENTS" );
if( obj_weight > 0 )
str << obj_weight;
retval = myZZ->Set_Param( "OBJ_WEIGHT_DIM", str.str().c_str() );
if( edge_weight > 0 )
str << edge_weight;
retval = myZZ->Set_Param( "EDGE_WEIGHT_DIM", str.str().c_str() );
// Call backs:
if( part_geom_mesh_size > 0. )
myZZ->Set_Part_Multi_Fn( mbGetPart, NULL );
int changes;
int numGidEntries;
int numLidEntries;
int dumnum1;
ZOLTAN_ID_PTR dum_local, dum_global;
int *dum1, *dum2;
int num_assign;
ZOLTAN_ID_PTR assign_gid, assign_lid;
int *assign_procs, *assign_parts;
std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nparts
<< " processors..." << std::endl;
#ifndef NDEBUG
#if 0
if (NULL == zmethod || !strcmp(zmethod, "RCB"))
Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 1, 0, 0);
if ( !strcmp(zmethod, "PHG"))
Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 0, 1, 1);
#endif
#endif
retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, dumnum1, dum_global, dum_local, dum1, dum2,
num_assign, assign_gid, assign_lid, assign_procs, assign_parts );
if( print_time )
std::cout << " time to LB_partition " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
t = clock();
std::cout << "Saving partition information to MOAB..." << std::endl;
result = write_partition( nparts, elems, assign_parts, write_as_sets, write_as_tags );
else
result = write_partition( nparts, entities, assign_parts, obj_weights, part_surf, ghost );
#endif
if( print_time )
std::cout << " time to write partition in memory " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
t = clock();
myZZ->LB_Free_Part( &assign_gid, &assign_lid, &assign_procs, &assign_parts );
return MB_SUCCESS;
| ErrorCode ZoltanPartitioner::partition_owned_cells | ( | Range & | owned, |
| std::multimap< int, int > & | extraGraphEdges, | ||
| std::map< int, int > | procs, | ||
| int & | numNewPartitions, | ||
| std::map< int, Range > & | distribution, | ||
| int | met | ||
Definition at line 2273 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, moab::Range::begin(), moab::Range::clear(), moab::ParallelComm::comm(), moab::Interface::dimension_from_handle(), EdgeWeights, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::MeshTopoUtil::get_average_position(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_coords(), moab::Interface::globalId_tag(), GlobalIds, moab::Range::insert(), length(), moab::MAX_SUB_ENTITIES, MB_CHK_ERR, MB_SUCCESS, mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), PartitionerBase< int >::mbImpl, mbpc, MBVERTEX, myZZ, NborGlobalId, NborProcs, neighbors(), NumEdges, NumPoints, ObjWeights, Parts, Points, rank, moab::ParallelComm::rank(), moab::Range::rbegin(), SetHypergraph_Parameters(), SetRCB_Parameters(), moab::Range::size(), swap(), moab::Interface::tag_get_data(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::ParCommGraph::compute_partition().
// start copy
Range adjs;
std::vector< int > adjacencies;
ids.resize( primary.size() );
std::vector< int > length;
std::vector< double > coords;
std::vector< int > nbor_proc;
// by MBCN
int neib_proc[5 * MAX_SUB_ENTITIES];
int moab_id;
int primaryDim = mbImpl->dimension_from_handle( *primary.rbegin() );
ErrorCode rval = mbImpl->tag_get_data( gid, primary, &ids[0] );MB_CHK_ERR( rval );
// mbpc is member in base class, PartitionerBase
int rank = mbpc->rank(); // current rank , will be put on regular neighbors
int i = 0;
for( Range::iterator rit = primary.begin(); rit != primary.end(); ++rit, i++ )
EntityHandle cell = *rit;
// get bridge adjacencies for each cell
if( 1 == met )
adjs.clear();
rval = mtu.get_bridge_adjacencies( cell, ( primaryDim > 0 ? primaryDim - 1 : 3 ), primaryDim, adjs );MB_CHK_ERR( rval );
if( !adjs.empty() )
rval = mbImpl->tag_get_data( gid, adjs, neighbors );MB_CHK_ERR( rval );
// if adjacent to neighbor partitions, add to the list
int size_adjs = (int)adjs.size();
moab_id = ids[i];
for( int k = 0; k < size_adjs; k++ )
neib_proc[k] = rank; // current rank
if( extraGraphEdges.find( moab_id ) != extraGraphEdges.end() )
// it means that the current cell is adjacent to a cell in another partition ; maybe
// a few
std::pair< std::multimap< int, int >::iterator, std::multimap< int, int >::iterator > ret;
ret = extraGraphEdges.equal_range( moab_id );
for( std::multimap< int, int >::iterator it = ret.first; it != ret.second; ++it )
int otherID = it->second;
neighbors[size_adjs] = otherID; // the id of the other cell, across partition
neib_proc[size_adjs] = procs[otherID]; // this is how we built this map, the cell id maps to
// what proc it came from
size_adjs++;
length.push_back( size_adjs );
std::copy( neighbors, neighbors + size_adjs, std::back_inserter( adjacencies ) );
std::copy( neib_proc, neib_proc + size_adjs, std::back_inserter( nbor_proc ) );
else if( 2 == met )
if( TYPE_FROM_HANDLE( cell ) == MBVERTEX )
rval = mbImpl->get_coords( &cell, 1, avg_position );MB_CHK_ERR( rval );
else
rval = mtu.get_average_position( cell, avg_position );MB_CHK_ERR( rval );
#ifdef VERBOSE
std::stringstream ff2;
ff2 << "zoltanInput_" << mbpc->rank() << ".txt";
std::ofstream ofs;
ofs.open( ff2.str().c_str(), std::ofstream::out );
ofs << "Length vector: " << std::endl;
std::copy( length.begin(), length.end(), std::ostream_iterator< int >( ofs, ", " ) );
ofs << std::endl;
ofs << "Adjacencies vector: " << std::endl;
std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( ofs, ", " ) );
ofs << std::endl;
ofs << "Moab_ids vector: " << std::endl;
std::copy( ids.begin(), ids.end(), std::ostream_iterator< int >( ofs, ", " ) );
ofs << std::endl;
ofs << "Coords vector: " << std::endl;
std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( ofs, ", " ) );
ofs << std::endl;
ofs.close();
#endif
// these are static var in this file, and used in the callbacks
Points = NULL;
if( 1 != met ) Points = &coords[0];
GlobalIds = &ids[0];
NumPoints = (int)ids.size();
NumEdges = &length[0];
NborGlobalId = &adjacencies[0];
NborProcs = &nbor_proc[0];
ObjWeights = NULL;
EdgeWeights = NULL;
Parts = NULL;
float version;
if( mbpc->rank() == 0 ) std::cout << "Initializing zoltan..." << std::endl;
char buff[10];
sprintf( buff, "%d", numNewPartitions );
// request parts assignment
retval = myZZ->Set_Param( "RETURN_LISTS", "PARTS" );
// due to a bug in zoltan, if method is graph partitioning, do not pass coordinates!!
if( 2 == met )
SetRCB_Parameters(); // geometry
else if( 1 == met )
int changes;
int numGidEntries;
int numLidEntries;
int num_import;
ZOLTAN_ID_PTR import_global_ids, import_local_ids;
int* import_procs;
int* import_to_part;
int num_export;
ZOLTAN_ID_PTR export_global_ids, export_local_ids;
std::cout << "Computing partition using method (1-graph, 2-geom):" << met << " for " << numNewPartitions
<< " parts..." << std::endl;
#ifndef NDEBUG
#if 0
static int counter=0; // it may be possible to call function multiple times in a simulation
// give a way to not overwrite the files
// it should work only with a modified version of Zoltan
std::stringstream basename;
if (1==met)
basename << "phg_" << counter++;
Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 0, 1, 0);
else if (2==met)
basename << "rcb_" << counter++;
Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 1, 0, 0);
#endif
#endif
retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids, import_local_ids,
import_procs, import_to_part, num_export, export_global_ids, export_local_ids,
#ifdef VERBOSE
std::stringstream ff3;
ff3 << "zoltanOutput_" << mbpc->rank() << ".txt";
std::ofstream ofs3;
ofs3.open( ff3.str().c_str(), std::ofstream::out );
ofs3 << " export elements on rank " << rank << " \n";
ofs3 << "\t index \t gb_id \t local \t proc \t part \n";
for( int k = 0; k < num_export; k++ )
ofs3 << "\t" << k << "\t" << export_global_ids[k] << "\t" << export_local_ids[k] << "\t" << assign_procs[k]
<< "\t" << assign_parts[k] << "\n";
ofs3.close();
#endif
// basically each local cell is assigned to a part
assert( num_export == (int)primary.size() );
for( i = 0; i < num_export; i++ )
EntityHandle cell = primary[export_local_ids[i]];
distribution[assign_parts[i]].insert( cell );
Zoltan::LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part );
Zoltan::LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts );
delete myZZ;
myZZ = NULL;
// clear arrays that were resized locally, to free up local memory
std::vector< int >().swap( adjacencies );
std::vector< int >().swap( ids );
std::vector< int >().swap( length );
std::vector< int >().swap( nbor_proc );
std::vector< double >().swap( coords );
return MB_SUCCESS;
| ErrorCode ZoltanPartitioner::repartition | ( | std::vector< double > & | x, |
| std::vector< double > & | y, | ||
| std::vector< double > & | z, | ||
| int | StartID, | ||
| Range & | localGIDs | ||
Definition at line 241 of file ZoltanPartitioner.cpp.
References argcArg, argvArg, moab::ParallelComm::comm(), EdgeWeights, GlobalIds, MB_SUCCESS, mbGetEdgeList(), mbGetNumberOfAssignedObjects(), mbGetNumberOfEdges(), mbGetObject(), mbGetObjectList(), mbGetObjectSize(), mbpc, myZZ, NborGlobalId, NborProcs, NumEdges, NumPoints, ObjWeights, Parts, Points, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), rank, SetHSFC_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), moab::subtract(), t, and moab::unite().
Referenced by moab::NCHelperScrip::create_mesh().
int nprocs = mbpc->proc_config().proc_size();
int rank = mbpc->proc_config().proc_rank();
// form pts and ids, as in assemble_graph
pts.resize( x.size() * 3 );
ids.resize( x.size() );
for( size_t i = 0; i < x.size(); i++ )
pts[3 * i] = x[i];
pts[3 * i + 1] = y[i];
pts[3 * i + 2] = z[i];
ids[i] = StartID + (int)i;
// do not get out until done!
Points = &pts[0];
NumPoints = (int)x.size();
NumEdges = NULL;
NborGlobalId = NULL;
NborProcs = NULL;
ObjWeights = NULL;
EdgeWeights = NULL;
Parts = NULL;
float version;
if( rank == 0 ) std::cout << "Initializing zoltan..." << std::endl;
char buff[10];
sprintf( buff, "%d", nprocs );
// request all, import and export
retval = myZZ->Set_Param( "RETURN_LISTS", "ALL" );
int changes;
int numGidEntries;
int numLidEntries;
int num_import;
int* import_procs;
int num_export;
if( rank == 0 )
std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nprocs
if( rank == 0 )
t = clock();
std::sort( import_global_ids, import_global_ids + num_import, std::greater< int >() );
std::sort( export_global_ids, export_global_ids + num_export, std::greater< int >() );
Range iniGids( (EntityHandle)StartID, (EntityHandle)StartID + x.size() - 1 );
Range imported, exported;
std::copy( import_global_ids, import_global_ids + num_import, range_inserter( imported ) );
std::copy( export_global_ids, export_global_ids + num_export, range_inserter( exported ) );
localGIDs = subtract( iniGids, exported );
localGIDs = unite( localGIDs, imported );
// Free data structures allocated by Zoltan::LB_Partition
retval = myZZ->LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part );
retval = myZZ->LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts );
return MB_SUCCESS;
Definition at line 1803 of file ZoltanPartitioner.cpp.
References mbpc, myZZ, moab::ParallelComm::proc_config(), and moab::ProcConfig::proc_rank().
Referenced by balance_mesh(), partition_mesh_and_geometry(), and repartition().
if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHilbert Space Filling Curve" << std::endl;
// General parameters:
myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages
myZZ->Set_Param( "LB_METHOD", "HSFC" ); // perform Hilbert space filling curve
// HSFC parameters:
myZZ->Set_Param( "KEEP_CUTS", "1" ); // save decomposition
| void ZoltanPartitioner::SetHypergraph_Parameters | ( | const char * | phg_method | ) |
Definition at line 1816 of file ZoltanPartitioner.cpp.
Referenced by balance_mesh(), partition_mesh_and_geometry(), and partition_owned_cells().
if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHypergraph (or PHG): " << std::endl;
myZZ->Set_Param( "LB_METHOD", "Hypergraph" ); // Hypergraph (or PHG)
// Hypergraph (or PHG) parameters:
myZZ->Set_Param( "PHG_COARSEPARTITION_METHOD", phg_method ); // CoarsePartitionMethod
| void ZoltanPartitioner::SetOCTPART_Parameters | ( | const char * | oct_method | ) |
Definition at line 1841 of file ZoltanPartitioner.cpp.
if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nOctree Partitioning: " << oct_method << std::endl;
myZZ->Set_Param( "LB_METHOD", "OCTPART" ); // octree partitioning
// OCTPART parameters:
myZZ->Set_Param( "OCT_METHOD", oct_method ); // the SFC to be used
myZZ->Set_Param( "OCT_OUTPUT_LEVEL", "3" );
| void ZoltanPartitioner::SetPARMETIS_Parameters | ( | const char * | parmetis_method | ) |
Definition at line 1828 of file ZoltanPartitioner.cpp.
if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
myZZ->Set_Param( "LB_METHOD", "PARMETIS" ); // the ParMETIS library
// PARMETIS parameters:
myZZ->Set_Param( "PARMETIS_METHOD", parmetis_method ); // method in the library
| void ZoltanPartitioner::SetRCB_Parameters | ( | const bool | recompute_rcb_box = false | ) |
Definition at line 1772 of file ZoltanPartitioner.cpp.
Referenced by balance_mesh(), partition_mesh_and_geometry(), partition_owned_cells(), and repartition().
if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
myZZ->Set_Param( "LB_METHOD", "RCB" ); // recursive coordinate bisection
// myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" ); // recompute RCB box if needed ?
// RCB parameters:
myZZ->Set_Param( "RCB_OUTPUT_LEVEL", "1" );
myZZ->Set_Param( "KEEP_CUTS", "1" ); // save decomposition so that we can infer partitions
// myZZ->Set_Param("RCB_RECTILINEAR_BLOCKS", "1"); // don't split point on boundary
if( recompute_rcb_box ) myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" );
| void ZoltanPartitioner::SetRIB_Parameters | ( | ) |
Definition at line 1789 of file ZoltanPartitioner.cpp.
if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Inertial Bisection" << std::endl;
myZZ->Set_Param( "LB_METHOD", "RIB" ); // Recursive Inertial Bisection
// RIB parameters:
myZZ->Set_Param( "AVERAGE_CUTS", "1" );
| ErrorCode ZoltanPartitioner::write_partition | ( | const int | nparts, |
| const int * | assignment, | ||
| const bool | write_as_sets, | ||
| const bool | write_as_tags | ||
| ) | [virtual] |
Definition at line 1658 of file ZoltanPartitioner.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::clear_meshset(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_handle(), moab::Range::insert(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, PartitionerBase< int >::mbImpl, MESHSET_SET, nparts, partSets, moab::Range::pop_back(), RR, moab::Range::size(), moab::Range::swap(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and smoab::UNION.
ErrorCode result;
Tag part_set_tag;
int dum_id = -1, i;
result = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag,
MB_TAG_SPARSE | MB_TAG_CREAT, &dum_id );RR;
// get any sets already with this tag, and clear them
Range tagged_sets;
result =
mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );RR;
if( !tagged_sets.empty() )
result = mbImpl->clear_meshset( tagged_sets );RR;
if( !write_as_sets )
result = mbImpl->tag_delete_data( part_set_tag, tagged_sets );RR;
if( write_as_sets )
// first, create partition sets and store in vector
partSets.clear();
if( nparts > (int)tagged_sets.size() )
// too few partition sets - create missing ones
int num_new = nparts - tagged_sets.size();
for( i = 0; i < num_new; i++ )
EntityHandle new_set;
result = mbImpl->create_meshset( MESHSET_SET, new_set );RR;
tagged_sets.insert( new_set );
else if( nparts < (int)tagged_sets.size() )
// too many partition sets - delete extras
int num_del = tagged_sets.size() - nparts;
for( i = 0; i < num_del; i++ )
EntityHandle old_set = tagged_sets.pop_back();
result = mbImpl->delete_entities( &old_set, 1 );RR;
// assign partition sets to vector
partSets.swap( tagged_sets );
// write a tag to those sets denoting they're partition sets, with a value of the
// proc number
int* dum_ids = new int[nparts];
for( i = 0; i < nparts; i++ )
dum_ids[i] = i;
result = mbImpl->tag_set_data( part_set_tag, partSets, dum_ids );RR;
// found out by valgrind when we run mbpart
delete[] dum_ids;
dum_ids = NULL;
// assign entities to the relevant sets
std::vector< EntityHandle > tmp_part_sets;
// int N = (int)elems.size();
std::copy( partSets.begin(), partSets.end(), std::back_inserter( tmp_part_sets ) );
/*Range::reverse_iterator riter;
for (i = N-1, riter = elems.rbegin(); riter != elems.rend(); ++riter, i--) {
int assigned_part = assignment[i];
part_ranges[assigned_part].insert(*riter);
//result = mbImpl->add_entities(tmp_part_sets[assignment[i]], &(*rit), 1); RR;
Range::iterator rit;
for( i = 0, rit = elems.begin(); rit != elems.end(); ++rit, i++ )
result = mbImpl->add_entities( tmp_part_sets[assignment[i]], &( *rit ), 1 );RR;
/*for (i=0; i<nparts; i++)
result = mbImpl->add_entities(tmp_part_sets[i], part_ranges[i]); RR;
delete [] part_ranges;*/
// check for empty sets, warn if there are any
Range empty_sets;
for( rit = partSets.begin(); rit != partSets.end(); ++rit )
int num_ents = 0;
result = mbImpl->get_number_entities_by_handle( *rit, num_ents );
if( MB_SUCCESS != result || !num_ents ) empty_sets.insert( *rit );
if( !empty_sets.empty() )
std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: ";
for( rit = empty_sets.begin(); rit != empty_sets.end(); ++rit )
std::cout << *rit << " ";
if( write_as_tags )
// allocate integer-size partitions
result = mbImpl->tag_set_data( part_set_tag, elems, assignment );RR;
return MB_SUCCESS;
int ZoltanPartitioner::argcArg [private] |
Definition at line 233 of file ZoltanPartitioner.hpp.
char** ZoltanPartitioner::argvArg [private] |
Definition at line 235 of file ZoltanPartitioner.hpp.
int ZoltanPartitioner::myNumPts [private] |
Definition at line 231 of file ZoltanPartitioner.hpp.
Zoltan* ZoltanPartitioner::myZZ [private] |
Definition at line 227 of file ZoltanPartitioner.hpp.
Referenced by balance_mesh(), partition_inferred_mesh(), partition_mesh_and_geometry(), partition_owned_cells(), repartition(), SetHSFC_Parameters(), SetHypergraph_Parameters(), SetOCTPART_Parameters(), SetPARMETIS_Parameters(), SetRCB_Parameters(), SetRIB_Parameters(), and ~ZoltanPartitioner().
Range ZoltanPartitioner::partSets [private] |
Reimplemented from PartitionerBase< int >.
Definition at line 229 of file ZoltanPartitioner.hpp.
Referenced by include_closure(), and write_partition().
