MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * ParCommGraph.cpp 00003 * 00004 */ 00005 00006 #include "moab/ParCommGraph.hpp" 00007 // we need to recompute adjacencies for merging to work 00008 #include "moab/Core.hpp" 00009 #include "AEntityFactory.hpp" 00010 00011 #ifdef MOAB_HAVE_ZOLTAN 00012 #include "moab/ZoltanPartitioner.hpp" 00013 #endif 00014 00015 // #define VERBOSE 00016 // #define GRAPH_INFO 00017 00018 namespace moab 00019 { 00020 ParCommGraph::ParCommGraph( MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, int coid2 ) 00021 : comm( joincomm ), compid1( coid1 ), compid2( coid2 ) 00022 { 00023 // find out the tasks from each group, in the joint communicator 00024 find_group_ranks( group1, comm, senderTasks ); 00025 find_group_ranks( group2, comm, receiverTasks ); 00026 00027 rootSender = rootReceiver = false; 00028 rankInGroup1 = rankInGroup2 = rankInJoin = -1; // not initialized, or not part of the group 00029 00030 int mpierr = MPI_Group_rank( group1, &rankInGroup1 ); 00031 if( MPI_SUCCESS != mpierr || rankInGroup1 == MPI_UNDEFINED ) rankInGroup1 = -1; 00032 00033 mpierr = MPI_Group_rank( group2, &rankInGroup2 ); 00034 if( MPI_SUCCESS != mpierr || rankInGroup2 == MPI_UNDEFINED ) rankInGroup2 = -1; 00035 00036 mpierr = MPI_Comm_rank( comm, &rankInJoin ); 00037 if( MPI_SUCCESS != mpierr ) // it should be a fatal error 00038 rankInJoin = -1; 00039 00040 mpierr = MPI_Comm_size( comm, &joinSize ); 00041 if( MPI_SUCCESS != mpierr ) // it should be a fatal error 00042 joinSize = -1; 00043 00044 if( 0 == rankInGroup1 ) rootSender = true; 00045 if( 0 == rankInGroup2 ) rootReceiver = true; 00046 graph_type = INITIAL_MIGRATE; // 0 00047 comm_graph = NULL; 00048 context_id = -1; 00049 cover_set = 0; // refers to nothing yet 00050 } 00051 00052 // copy constructor will copy only few basic things; split ranges will not be copied 00053 ParCommGraph::ParCommGraph( const ParCommGraph& src ) 00054 { 00055 comm = src.comm; 00056 senderTasks = src.senderTasks; // these are the sender tasks in joint comm 00057 receiverTasks = src.receiverTasks; // these are all the receiver tasks in joint comm 00058 rootSender = src.rootSender; 00059 rootReceiver = src.rootReceiver; 00060 rankInGroup1 = src.rankInGroup1; 00061 rankInGroup2 = src.rankInGroup2; // group 1 is sender, 2 is receiver 00062 rankInJoin = src.rankInJoin; 00063 joinSize = src.joinSize; 00064 compid1 = src.compid1; 00065 compid2 = src.compid2; 00066 comm_graph = NULL; 00067 graph_type = src.graph_type; 00068 context_id = src.context_id; 00069 cover_set = src.cover_set; 00070 return; 00071 } 00072 00073 ParCommGraph::~ParCommGraph() 00074 { 00075 // TODO Auto-generated destructor stub 00076 } 00077 00078 // utility to find out the ranks of the processes of a group, with respect to a joint comm, 00079 // which spans for sure the group 00080 // it is used locally (in the constructor), but it can be used as a utility 00081 void ParCommGraph::find_group_ranks( MPI_Group group, MPI_Comm joincomm, std::vector< int >& ranks ) 00082 { 00083 MPI_Group global_grp; 00084 MPI_Comm_group( joincomm, &global_grp ); 00085 00086 int grp_size; 00087 00088 MPI_Group_size( group, &grp_size ); 00089 std::vector< int > rks( grp_size ); 00090 ranks.resize( grp_size ); 00091 00092 for( int i = 0; i < grp_size; i++ ) 00093 rks[i] = i; 00094 00095 MPI_Group_translate_ranks( group, grp_size, &rks[0], global_grp, &ranks[0] ); 00096 MPI_Group_free( &global_grp ); 00097 return; 00098 } 00099 00100 ErrorCode ParCommGraph::compute_trivial_partition( std::vector< int >& numElemsPerTaskInGroup1 ) 00101 { 00102 00103 recv_graph.clear(); 00104 recv_sizes.clear(); 00105 sender_graph.clear(); 00106 sender_sizes.clear(); 00107 00108 if( numElemsPerTaskInGroup1.size() != senderTasks.size() ) 00109 return MB_FAILURE; // each sender has a number of elements that it owns 00110 00111 // first find out total number of elements to be sent from all senders 00112 int total_elems = 0; 00113 std::vector< int > accum; 00114 accum.push_back( 0 ); 00115 00116 int num_senders = (int)senderTasks.size(); 00117 00118 for( size_t k = 0; k < numElemsPerTaskInGroup1.size(); k++ ) 00119 { 00120 total_elems += numElemsPerTaskInGroup1[k]; 00121 accum.push_back( total_elems ); 00122 } 00123 00124 int num_recv = ( (int)receiverTasks.size() ); 00125 // in trivial partition, every receiver should get about total_elems/num_receivers elements 00126 int num_per_receiver = (int)( total_elems / num_recv ); 00127 int leftover = total_elems - num_per_receiver * num_recv; 00128 00129 // so receiver k will receive [starts[k], starts[k+1] ) interval 00130 std::vector< int > starts; 00131 starts.resize( num_recv + 1 ); 00132 starts[0] = 0; 00133 for( int k = 0; k < num_recv; k++ ) 00134 { 00135 starts[k + 1] = starts[k] + num_per_receiver; 00136 if( k < leftover ) starts[k + 1]++; 00137 } 00138 00139 // each sender will send to a number of receivers, based on how the 00140 // arrays starts[0:num_recv] and accum[0:sendr] overlap 00141 int lastUsedReceiverRank = 0; // first receiver was not treated yet 00142 for( int j = 0; j < num_senders; j++ ) 00143 { 00144 // we could start the receiver loop with the latest receiver that received from previous 00145 // sender 00146 for( int k = lastUsedReceiverRank; k < num_recv; k++ ) 00147 { 00148 // if overlap: 00149 if( starts[k] < accum[j + 1] && starts[k + 1] > accum[j] ) 00150 { 00151 recv_graph[receiverTasks[k]].push_back( senderTasks[j] ); 00152 sender_graph[senderTasks[j]].push_back( receiverTasks[k] ); 00153 00154 // we still need to decide what is the overlap 00155 int sizeOverlap = 1; // at least 1, for sure 00156 // 1 00157 if( starts[k] >= accum[j] ) // one end is starts[k] 00158 { 00159 if( starts[k + 1] >= accum[j + 1] ) // the other end is accum[j+1] 00160 sizeOverlap = accum[j + 1] - starts[k]; 00161 else // 00162 sizeOverlap = starts[k + 1] - starts[k]; 00163 } 00164 else // one end is accum[j] 00165 { 00166 if( starts[k + 1] >= accum[j + 1] ) // the other end is accum[j+1] 00167 sizeOverlap = accum[j + 1] - accum[j]; 00168 else 00169 sizeOverlap = starts[k + 1] - accum[j]; 00170 } 00171 recv_sizes[receiverTasks[k]].push_back( sizeOverlap ); // basically, task k will receive from 00172 // sender j, sizeOverlap elems 00173 sender_sizes[senderTasks[j]].push_back( sizeOverlap ); 00174 if( starts[k] > accum[j + 1] ) 00175 { 00176 lastUsedReceiverRank = k - 1; // so next k loop will start a little higher, we 00177 // probably finished with first few receivers (up 00178 // to receiver lastUsedReceiverRank) 00179 break; // break the k loop, we distributed all elements from sender j to some 00180 // receivers 00181 } 00182 } 00183 } 00184 } 00185 00186 return MB_SUCCESS; 00187 } 00188 00189 ErrorCode ParCommGraph::pack_receivers_graph( std::vector< int >& packed_recv_array ) 00190 { 00191 // it will basically look at local data, to pack communication graph, each receiver task will 00192 // have to post receives for each sender task that will send data to it; the array will be 00193 // communicated to root receiver, and eventually distributed to receiver tasks 00194 00195 /* 00196 * packed_array will have receiver, number of senders, then senders, etc 00197 */ 00198 if( recv_graph.size() < receiverTasks.size() ) 00199 { 00200 // big problem, we have empty partitions in receive 00201 std::cout << " WARNING: empty partitions, some receiver tasks will receive nothing.\n"; 00202 } 00203 for( std::map< int, std::vector< int > >::iterator it = recv_graph.begin(); it != recv_graph.end(); it++ ) 00204 { 00205 int recv = it->first; 00206 std::vector< int >& senders = it->second; 00207 packed_recv_array.push_back( recv ); 00208 packed_recv_array.push_back( (int)senders.size() ); 00209 00210 for( int k = 0; k < (int)senders.size(); k++ ) 00211 packed_recv_array.push_back( senders[k] ); 00212 } 00213 00214 return MB_SUCCESS; 00215 } 00216 00217 ErrorCode ParCommGraph::split_owned_range( int sender_rank, Range& owned ) 00218 { 00219 int senderTask = senderTasks[sender_rank]; 00220 std::vector< int >& distribution = sender_sizes[senderTask]; 00221 std::vector< int >& receivers = sender_graph[senderTask]; 00222 if( distribution.size() != receivers.size() ) // 00223 return MB_FAILURE; 00224 00225 Range current = owned; // get the full range first, then we will subtract stuff, for 00226 // the following ranges 00227 00228 Range rleftover = current; 00229 for( size_t k = 0; k < receivers.size(); k++ ) 00230 { 00231 Range newr; 00232 newr.insert( current.begin(), current.begin() + distribution[k] ); 00233 split_ranges[receivers[k]] = newr; 00234 00235 rleftover = subtract( current, newr ); 00236 current = rleftover; 00237 } 00238 00239 return MB_SUCCESS; 00240 } 00241 00242 // use for this the corresponding tasks and sizes 00243 ErrorCode ParCommGraph::split_owned_range( Range& owned ) 00244 { 00245 if( corr_tasks.size() != corr_sizes.size() ) // 00246 return MB_FAILURE; 00247 00248 Range current = owned; // get the full range first, then we will subtract stuff, for 00249 // the following ranges 00250 00251 Range rleftover = current; 00252 for( size_t k = 0; k < corr_tasks.size(); k++ ) 00253 { 00254 Range newr; 00255 newr.insert( current.begin(), current.begin() + corr_sizes[k] ); 00256 split_ranges[corr_tasks[k]] = newr; 00257 00258 rleftover = subtract( current, newr ); 00259 current = rleftover; 00260 } 00261 00262 return MB_SUCCESS; 00263 } 00264 00265 ErrorCode ParCommGraph::send_graph( MPI_Comm jcomm ) 00266 { 00267 if( is_root_sender() ) 00268 { 00269 int ierr; 00270 // will need to build a communication graph, because each sender knows now to which receiver 00271 // to send data the receivers need to post receives for each sender that will send data to 00272 // them will need to gather on rank 0 on the sender comm, global ranks of sender with 00273 // receivers to send build communication matrix, each receiver will receive from what sender 00274 00275 std::vector< int > packed_recv_array; 00276 ErrorCode rval = pack_receivers_graph( packed_recv_array ); 00277 if( MB_SUCCESS != rval ) return rval; 00278 00279 int size_pack_array = (int)packed_recv_array.size(); 00280 comm_graph = new int[size_pack_array + 1]; 00281 comm_graph[0] = size_pack_array; 00282 for( int k = 0; k < size_pack_array; k++ ) 00283 comm_graph[k + 1] = packed_recv_array[k]; 00284 // will add 2 requests 00285 /// use tag 10 to send size and tag 20 to send the packed array 00286 sendReqs.resize( 1 ); 00287 // do not send the size in advance, because we use probe now 00288 /*ierr = MPI_Isend(&comm_graph[0], 1, MPI_INT, receiver(0), 10, jcomm, &sendReqs[0]); // we 00289 have to use global communicator if (ierr!=0) return MB_FAILURE;*/ 00290 ierr = MPI_Isend( &comm_graph[1], size_pack_array, MPI_INT, receiver( 0 ), 20, jcomm, 00291 &sendReqs[0] ); // we have to use global communicator 00292 if( ierr != 0 ) return MB_FAILURE; 00293 } 00294 return MB_SUCCESS; 00295 } 00296 00297 // pco has MOAB too get_moab() 00298 // do we need to store "method" as a member variable ? 00299 ErrorCode ParCommGraph::send_mesh_parts( MPI_Comm jcomm, ParallelComm* pco, Range& owned ) 00300 { 00301 00302 ErrorCode rval; 00303 if( split_ranges.empty() ) // in trivial partition 00304 { 00305 rval = split_owned_range( rankInGroup1, owned ); 00306 if( rval != MB_SUCCESS ) return rval; 00307 // we know this on the sender side: 00308 corr_tasks = sender_graph[senderTasks[rankInGroup1]]; // copy 00309 corr_sizes = sender_sizes[senderTasks[rankInGroup1]]; // another copy 00310 } 00311 00312 int indexReq = 0; 00313 int ierr; // MPI error 00314 if( is_root_sender() ) indexReq = 1; // for sendReqs 00315 sendReqs.resize( indexReq + split_ranges.size() ); 00316 for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ ) 00317 { 00318 int receiver_proc = it->first; 00319 Range ents = it->second; 00320 00321 // add necessary vertices too 00322 Range verts; 00323 rval = pco->get_moab()->get_adjacencies( ents, 0, false, verts, Interface::UNION ); 00324 if( rval != MB_SUCCESS ) 00325 { 00326 std::cout << " can't get adjacencies. for entities to send\n"; 00327 return rval; 00328 } 00329 ents.merge( verts ); 00330 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( ParallelComm::INITIAL_BUFF_SIZE ); 00331 buffer->reset_ptr( sizeof( int ) ); 00332 rval = pco->pack_buffer( ents, false, true, false, -1, buffer ); 00333 if( rval != MB_SUCCESS ) 00334 { 00335 std::cout << " can't pack buffer for entities to send\n"; 00336 return rval; 00337 } 00338 int size_pack = buffer->get_current_size(); 00339 00340 // TODO there could be an issue with endian things; check !!!!! 00341 // we are sending the size of the buffer first as an int!!! 00342 /// not anymore ! 00343 /* ierr = MPI_Isend(buffer->mem_ptr, 1, MPI_INT, receiver_proc, 1, jcomm, 00344 &sendReqs[indexReq]); // we have to use global communicator if (ierr!=0) return MB_FAILURE; 00345 indexReq++;*/ 00346 00347 ierr = MPI_Isend( buffer->mem_ptr, size_pack, MPI_CHAR, receiver_proc, 2, jcomm, 00348 &sendReqs[indexReq] ); // we have to use global communicator 00349 if( ierr != 0 ) return MB_FAILURE; 00350 indexReq++; 00351 localSendBuffs.push_back( buffer ); 00352 } 00353 return MB_SUCCESS; 00354 } 00355 00356 // this is called on receiver side 00357 ErrorCode ParCommGraph::receive_comm_graph( MPI_Comm jcomm, ParallelComm* pco, std::vector< int >& pack_array ) 00358 { 00359 // first, receive from sender_rank 0, the communication graph (matrix), so each receiver 00360 // knows what data to expect 00361 MPI_Comm receive = pco->comm(); 00362 int size_pack_array, ierr; 00363 MPI_Status status; 00364 if( rootReceiver ) 00365 { 00366 /* 00367 * MPI_Probe( 00368 int source, 00369 int tag, 00370 MPI_Comm comm, 00371 MPI_Status* status) 00372 * 00373 */ 00374 ierr = MPI_Probe( sender( 0 ), 20, jcomm, &status ); 00375 if( 0 != ierr ) 00376 { 00377 std::cout << " MPI_Probe failure: " << ierr << "\n"; 00378 return MB_FAILURE; 00379 } 00380 // get the count of data received from the MPI_Status structure 00381 ierr = MPI_Get_count( &status, MPI_INT, &size_pack_array ); 00382 if( 0 != ierr ) 00383 { 00384 std::cout << " MPI_Get_count failure: " << ierr << "\n"; 00385 return MB_FAILURE; 00386 } 00387 #ifdef VERBOSE 00388 std::cout << " receive comm graph size: " << size_pack_array << "\n"; 00389 #endif 00390 pack_array.resize( size_pack_array ); 00391 ierr = MPI_Recv( &pack_array[0], size_pack_array, MPI_INT, sender( 0 ), 20, jcomm, &status ); 00392 if( 0 != ierr ) return MB_FAILURE; 00393 #ifdef VERBOSE 00394 std::cout << " receive comm graph "; 00395 for( int k = 0; k < (int)pack_array.size(); k++ ) 00396 std::cout << " " << pack_array[k]; 00397 std::cout << "\n"; 00398 #endif 00399 } 00400 00401 // now broadcast this whole array to all receivers, so they know what to expect 00402 ierr = MPI_Bcast( &size_pack_array, 1, MPI_INT, 0, receive ); 00403 if( 0 != ierr ) return MB_FAILURE; 00404 pack_array.resize( size_pack_array ); 00405 ierr = MPI_Bcast( &pack_array[0], size_pack_array, MPI_INT, 0, receive ); 00406 if( 0 != ierr ) return MB_FAILURE; 00407 return MB_SUCCESS; 00408 } 00409 00410 ErrorCode ParCommGraph::receive_mesh( MPI_Comm jcomm, 00411 ParallelComm* pco, 00412 EntityHandle local_set, 00413 std::vector< int >& senders_local ) 00414 { 00415 ErrorCode rval; 00416 int ierr; 00417 MPI_Status status; 00418 // we also need to fill corresponding mesh info on the other side 00419 corr_tasks = senders_local; 00420 Range newEnts; 00421 00422 Tag orgSendProcTag; // this will be a tag set on the received mesh, with info about from what 00423 // task / PE the 00424 // primary element came from, in the joint communicator ; this will be forwarded by coverage 00425 // mesh 00426 int defaultInt = -1; // no processor, so it was not migrated from somewhere else 00427 rval = pco->get_moab()->tag_get_handle( "orig_sending_processor", 1, MB_TYPE_INTEGER, orgSendProcTag, 00428 MB_TAG_DENSE | MB_TAG_CREAT, &defaultInt );MB_CHK_SET_ERR( rval, "can't create original sending processor tag" ); 00429 if( !senders_local.empty() ) 00430 { 00431 for( size_t k = 0; k < senders_local.size(); k++ ) 00432 { 00433 int sender1 = senders_local[k]; 00434 // first receive the size of the buffer using probe 00435 /* 00436 * MPI_Probe( 00437 int source, 00438 int tag, 00439 MPI_Comm comm, 00440 MPI_Status* status) 00441 * 00442 */ 00443 ierr = MPI_Probe( sender1, 2, jcomm, &status ); 00444 if( 0 != ierr ) 00445 { 00446 std::cout << " MPI_Probe failure in ParCommGraph::receive_mesh " << ierr << "\n"; 00447 return MB_FAILURE; 00448 } 00449 // get the count of data received from the MPI_Status structure 00450 int size_pack; 00451 ierr = MPI_Get_count( &status, MPI_CHAR, &size_pack ); 00452 if( 0 != ierr ) 00453 { 00454 std::cout << " MPI_Get_count failure in ParCommGraph::receive_mesh " << ierr << "\n"; 00455 return MB_FAILURE; 00456 } 00457 00458 /* ierr = MPI_Recv (&size_pack, 1, MPI_INT, sender1, 1, jcomm, &status); 00459 if (0!=ierr) return MB_FAILURE;*/ 00460 // now resize the buffer, then receive it 00461 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_pack ); 00462 // buffer->reserve(size_pack); 00463 00464 ierr = MPI_Recv( buffer->mem_ptr, size_pack, MPI_CHAR, sender1, 2, jcomm, &status ); 00465 if( 0 != ierr ) 00466 { 00467 std::cout << " MPI_Recv failure in ParCommGraph::receive_mesh " << ierr << "\n"; 00468 return MB_FAILURE; 00469 } 00470 // now unpack the buffer we just received 00471 Range entities; 00472 std::vector< std::vector< EntityHandle > > L1hloc, L1hrem; 00473 std::vector< std::vector< int > > L1p; 00474 std::vector< EntityHandle > L2hloc, L2hrem; 00475 std::vector< unsigned int > L2p; 00476 00477 buffer->reset_ptr( sizeof( int ) ); 00478 std::vector< EntityHandle > entities_vec( entities.size() ); 00479 std::copy( entities.begin(), entities.end(), entities_vec.begin() ); 00480 rval = pco->unpack_buffer( buffer->buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, 00481 entities_vec ); 00482 delete buffer; 00483 if( MB_SUCCESS != rval ) return rval; 00484 00485 std::copy( entities_vec.begin(), entities_vec.end(), range_inserter( entities ) ); 00486 // we have to add them to the local set 00487 rval = pco->get_moab()->add_entities( local_set, entities ); 00488 if( MB_SUCCESS != rval ) return rval; 00489 // corr_sizes is the size of primary entities received 00490 Range verts = entities.subset_by_dimension( 0 ); 00491 Range local_primary_ents = subtract( entities, verts ); 00492 if( local_primary_ents.empty() ) 00493 { 00494 // it is possible that all ents sent were vertices (point cloud) 00495 // then consider primary entities the vertices 00496 local_primary_ents = verts; 00497 } 00498 else 00499 { 00500 // set a tag with the original sender for the primary entity 00501 // will be used later for coverage mesh 00502 std::vector< int > orig_senders( local_primary_ents.size(), sender1 ); 00503 rval = pco->get_moab()->tag_set_data( orgSendProcTag, local_primary_ents, &orig_senders[0] ); 00504 } 00505 corr_sizes.push_back( (int)local_primary_ents.size() ); 00506 00507 newEnts.merge( entities ); 00508 // make these in split ranges 00509 split_ranges[sender1] = local_primary_ents; 00510 00511 #ifdef VERBOSE 00512 std::ostringstream partial_outFile; 00513 00514 partial_outFile << "part_send_" << sender1 << "." 00515 << "recv" << rankInJoin << ".vtk"; 00516 00517 // the mesh contains ghosts too, but they are not part of mat/neumann set 00518 // write in serial the file, to see what tags are missing 00519 std::cout << " writing from receiver " << rankInJoin << " from sender " << sender1 00520 << " entities: " << entities.size() << std::endl; 00521 rval = pco->get_moab()->write_file( partial_outFile.str().c_str(), 0, 0, &local_set, 00522 1 ); // everything on local set received 00523 if( MB_SUCCESS != rval ) return rval; 00524 #endif 00525 } 00526 } 00527 // make sure adjacencies are updated on the new elements 00528 00529 if( newEnts.empty() ) 00530 { 00531 std::cout << " WARNING: this task did not receive any entities \n"; 00532 } 00533 // in order for the merging to work, we need to be sure that the adjacencies are updated 00534 // (created) 00535 Range local_verts = newEnts.subset_by_type( MBVERTEX ); 00536 newEnts = subtract( newEnts, local_verts ); 00537 Core* mb = (Core*)pco->get_moab(); 00538 AEntityFactory* adj_fact = mb->a_entity_factory(); 00539 if( !adj_fact->vert_elem_adjacencies() ) 00540 adj_fact->create_vert_elem_adjacencies(); 00541 else 00542 { 00543 for( Range::iterator it = newEnts.begin(); it != newEnts.end(); ++it ) 00544 { 00545 EntityHandle eh = *it; 00546 const EntityHandle* conn = NULL; 00547 int num_nodes = 0; 00548 rval = mb->get_connectivity( eh, conn, num_nodes );MB_CHK_ERR( rval ); 00549 adj_fact->notify_create_entity( eh, conn, num_nodes ); 00550 } 00551 } 00552 00553 return MB_SUCCESS; 00554 } 00555 00556 // VSM: Why is the communicator never used. Remove the argument ? 00557 ErrorCode ParCommGraph::release_send_buffers() 00558 { 00559 int ierr, nsize = (int)sendReqs.size(); 00560 std::vector< MPI_Status > mult_status; 00561 mult_status.resize( sendReqs.size() ); 00562 ierr = MPI_Waitall( nsize, &sendReqs[0], &mult_status[0] ); 00563 00564 if( ierr != 0 ) return MB_FAILURE; 00565 // now we can free all buffers 00566 delete[] comm_graph; 00567 comm_graph = NULL; 00568 std::vector< ParallelComm::Buffer* >::iterator vit; 00569 for( vit = localSendBuffs.begin(); vit != localSendBuffs.end(); ++vit ) 00570 delete( *vit ); 00571 localSendBuffs.clear(); 00572 return MB_SUCCESS; 00573 } 00574 00575 // again, will use the send buffers, for nonblocking sends; 00576 // should be the receives non-blocking too? 00577 ErrorCode ParCommGraph::send_tag_values( MPI_Comm jcomm, 00578 ParallelComm* pco, 00579 Range& owned, 00580 std::vector< Tag >& tag_handles ) 00581 { 00582 // basically, owned.size() needs to be equal to sum(corr_sizes) 00583 // get info about the tag size, type, etc 00584 int ierr; 00585 Core* mb = (Core*)pco->get_moab(); 00586 // get info about the tag 00587 //! Get the size of the specified tag in bytes 00588 int total_bytes_per_entity = 0; // we need to know, to allocate buffers 00589 ErrorCode rval; 00590 std::vector< int > vect_bytes_per_tag; 00591 #ifdef VERBOSE 00592 std::vector< int > tag_sizes; 00593 #endif 00594 for( size_t i = 0; i < tag_handles.size(); i++ ) 00595 { 00596 int bytes_per_tag; 00597 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00598 int tag_size1; // length 00599 rval = mb->tag_get_length( tag_handles[i], tag_size1 );MB_CHK_ERR( rval ); 00600 if( graph_type == DOF_BASED ) 00601 bytes_per_tag = bytes_per_tag / tag_size1; // we know we have one double per tag , per ID sent; 00602 // could be 8 for double, 4 for int, etc 00603 total_bytes_per_entity += bytes_per_tag; 00604 vect_bytes_per_tag.push_back( bytes_per_tag ); 00605 #ifdef VERBOSE 00606 int tag_size; 00607 rval = mb->tag_get_length( tag_handles[i], tag_size );MB_CHK_ERR( rval ); 00608 tag_sizes.push_back( tag_size ); 00609 #endif 00610 } 00611 00612 int indexReq = 0; 00613 if( graph_type == INITIAL_MIGRATE ) // original send 00614 { 00615 // use the buffers data structure to allocate memory for sending the tags 00616 sendReqs.resize( split_ranges.size() ); 00617 00618 for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ ) 00619 { 00620 int receiver_proc = it->first; 00621 Range ents = it->second; // primary entities, with the tag data 00622 int size_buffer = 4 + total_bytes_per_entity * 00623 (int)ents.size(); // hopefully, below 2B; if more, we have a big problem ... 00624 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00625 00626 buffer->reset_ptr( sizeof( int ) ); 00627 for( size_t i = 0; i < tag_handles.size(); i++ ) 00628 { 00629 // copy tag data to buffer->buff_ptr, and send the buffer (we could have used 00630 // regular char arrays) 00631 rval = mb->tag_get_data( tag_handles[i], ents, (void*)( buffer->buff_ptr ) );MB_CHK_ERR( rval ); 00632 // advance the butter 00633 buffer->buff_ptr += vect_bytes_per_tag[i] * ents.size(); 00634 } 00635 *( (int*)buffer->mem_ptr ) = size_buffer; 00636 // int size_pack = buffer->get_current_size(); // debug check 00637 ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm, 00638 &sendReqs[indexReq] ); // we have to use global communicator 00639 if( ierr != 0 ) return MB_FAILURE; 00640 indexReq++; 00641 localSendBuffs.push_back( buffer ); // we will release them after nonblocking sends are completed 00642 } 00643 } 00644 else if( graph_type == COVERAGE ) 00645 { 00646 // we know that we will need to send some tag data in a specific order 00647 // first, get the ids of the local elements, from owned Range; arrange the buffer in order 00648 // of increasing global id 00649 Tag gidTag = mb->globalId_tag(); 00650 std::vector< int > gids; 00651 gids.resize( owned.size() ); 00652 rval = mb->tag_get_data( gidTag, owned, &gids[0] );MB_CHK_ERR( rval ); 00653 std::map< int, EntityHandle > gidToHandle; 00654 size_t i = 0; 00655 for( Range::iterator it = owned.begin(); it != owned.end(); it++ ) 00656 { 00657 EntityHandle eh = *it; 00658 gidToHandle[gids[i++]] = eh; 00659 } 00660 // now, pack the data and send it 00661 sendReqs.resize( involved_IDs_map.size() ); 00662 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00663 mit != involved_IDs_map.end(); mit++ ) 00664 { 00665 int receiver_proc = mit->first; 00666 std::vector< int >& eids = mit->second; 00667 int size_buffer = 4 + total_bytes_per_entity * 00668 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00669 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00670 buffer->reset_ptr( sizeof( int ) ); 00671 #ifdef VERBOSE 00672 std::ofstream dbfile; 00673 std::stringstream outf; 00674 outf << "from_" << rankInJoin << "_send_to_" << receiver_proc << ".txt"; 00675 dbfile.open( outf.str().c_str() ); 00676 dbfile << "from " << rankInJoin << " send to " << receiver_proc << "\n"; 00677 #endif 00678 // copy tag data to buffer->buff_ptr, and send the buffer (we could have used regular 00679 // char arrays) pack data by tag, to be consistent with above, even though we loop 00680 // through the entities for each tag 00681 00682 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++ ) 00683 { 00684 int eID = *it; 00685 EntityHandle eh = gidToHandle[eID]; 00686 for( i = 0; i < tag_handles.size(); i++ ) 00687 { 00688 rval = mb->tag_get_data( tag_handles[i], &eh, 1, (void*)( buffer->buff_ptr ) ); 00689 if( rval != MB_SUCCESS ) 00690 { 00691 delete buffer; // free parallel comm buffer first 00692 00693 MB_SET_ERR( rval, "Tag get data failed" ); 00694 } 00695 #ifdef VERBOSE 00696 dbfile << "global ID " << eID << " local handle " << mb->id_from_handle( eh ) << " vals: "; 00697 double* vals = (double*)( buffer->buff_ptr ); 00698 for( int kk = 0; kk < tag_sizes[i]; kk++ ) 00699 { 00700 dbfile << " " << *vals; 00701 vals++; 00702 } 00703 dbfile << "\n"; 00704 #endif 00705 buffer->buff_ptr += vect_bytes_per_tag[i]; 00706 } 00707 } 00708 00709 #ifdef VERBOSE 00710 dbfile.close(); 00711 #endif 00712 *( (int*)buffer->mem_ptr ) = size_buffer; 00713 // int size_pack = buffer->get_current_size(); // debug check 00714 ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm, 00715 &sendReqs[indexReq] ); // we have to use global communicator 00716 if( ierr != 0 ) return MB_FAILURE; 00717 indexReq++; 00718 localSendBuffs.push_back( buffer ); // we will release them after nonblocking sends are completed 00719 } 00720 } 00721 else if( graph_type == DOF_BASED ) 00722 { 00723 // need to fill up the buffer, in the order desired, send it 00724 // get all the tags, for all owned entities, and pack the buffers accordingly 00725 // we do not want to get the tags by entity, it may be too expensive 00726 std::vector< std::vector< double > > valuesTags; 00727 valuesTags.resize( tag_handles.size() ); 00728 for( size_t i = 0; i < tag_handles.size(); i++ ) 00729 { 00730 00731 int bytes_per_tag; 00732 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00733 valuesTags[i].resize( owned.size() * bytes_per_tag / sizeof( double ) ); 00734 // fill the whole array, we will pick up from here 00735 rval = mb->tag_get_data( tag_handles[i], owned, (void*)( &( valuesTags[i][0] ) ) );MB_CHK_ERR( rval ); 00736 } 00737 // now, pack the data and send it 00738 sendReqs.resize( involved_IDs_map.size() ); 00739 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00740 mit != involved_IDs_map.end(); mit++ ) 00741 { 00742 int receiver_proc = mit->first; 00743 std::vector< int >& eids = mit->second; 00744 std::vector< int >& index_in_values = map_index[receiver_proc]; 00745 std::vector< int >& index_ptr = map_ptr[receiver_proc]; // this is eids.size()+1; 00746 int size_buffer = 4 + total_bytes_per_entity * 00747 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00748 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00749 buffer->reset_ptr( sizeof( int ) ); 00750 #ifdef VERBOSE 00751 std::ofstream dbfile; 00752 std::stringstream outf; 00753 outf << "from_" << rankInJoin << "_send_to_" << receiver_proc << ".txt"; 00754 dbfile.open( outf.str().c_str() ); 00755 dbfile << "from " << rankInJoin << " send to " << receiver_proc << "\n"; 00756 #endif 00757 // copy tag data to buffer->buff_ptr, and send the buffer 00758 // pack data by tag, to be consistent with above 00759 int j = 0; 00760 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++, j++ ) 00761 { 00762 int index_in_v = index_in_values[index_ptr[j]]; 00763 for( size_t i = 0; i < tag_handles.size(); i++ ) 00764 { 00765 // right now, move just doubles; but it could be any type of tag 00766 *( (double*)( buffer->buff_ptr ) ) = valuesTags[i][index_in_v]; 00767 buffer->buff_ptr += 8; // we know we are working with doubles only !!! 00768 } 00769 }; 00770 *( (int*)buffer->mem_ptr ) = size_buffer; 00771 // int size_pack = buffer->get_current_size(); // debug check 00772 ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm, 00773 &sendReqs[indexReq] ); // we have to use global communicator 00774 if( ierr != 0 ) return MB_FAILURE; 00775 indexReq++; 00776 localSendBuffs.push_back( buffer ); // we will release them after nonblocking sends are completed 00777 } 00778 } 00779 return MB_SUCCESS; 00780 } 00781 00782 ErrorCode ParCommGraph::receive_tag_values( MPI_Comm jcomm, 00783 ParallelComm* pco, 00784 Range& owned, 00785 std::vector< Tag >& tag_handles ) 00786 { 00787 // opposite to sending, we will use blocking receives 00788 int ierr; 00789 MPI_Status status; 00790 // basically, owned.size() needs to be equal to sum(corr_sizes) 00791 // get info about the tag size, type, etc 00792 Core* mb = (Core*)pco->get_moab(); 00793 // get info about the tag 00794 //! Get the size of the specified tag in bytes 00795 ErrorCode rval; 00796 int total_bytes_per_entity = 0; 00797 std::vector< int > vect_bytes_per_tag; 00798 #ifdef VERBOSE 00799 std::vector< int > tag_sizes; 00800 #endif 00801 for( size_t i = 0; i < tag_handles.size(); i++ ) 00802 { 00803 int bytes_per_tag; 00804 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00805 total_bytes_per_entity += bytes_per_tag; 00806 vect_bytes_per_tag.push_back( bytes_per_tag ); 00807 #ifdef VERBOSE 00808 int tag_size; 00809 rval = mb->tag_get_length( tag_handles[i], tag_size );MB_CHK_ERR( rval ); 00810 tag_sizes.push_back( tag_size ); 00811 #endif 00812 } 00813 00814 if( graph_type == INITIAL_MIGRATE ) 00815 { 00816 // std::map<int, Range> split_ranges; 00817 // rval = split_owned_range ( owned);MB_CHK_ERR ( rval ); 00818 00819 // use the buffers data structure to allocate memory for receiving the tags 00820 for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ ) 00821 { 00822 int sender_proc = it->first; 00823 Range ents = it->second; // primary entities, with the tag data, we will receive 00824 int size_buffer = 4 + total_bytes_per_entity * 00825 (int)ents.size(); // hopefully, below 2B; if more, we have a big problem ... 00826 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00827 00828 buffer->reset_ptr( sizeof( int ) ); 00829 00830 *( (int*)buffer->mem_ptr ) = size_buffer; 00831 // int size_pack = buffer->get_current_size(); // debug check 00832 00833 ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status ); 00834 if( ierr != 0 ) return MB_FAILURE; 00835 // now set the tag 00836 // copy to tag 00837 00838 for( size_t i = 0; i < tag_handles.size(); i++ ) 00839 { 00840 rval = mb->tag_set_data( tag_handles[i], ents, (void*)( buffer->buff_ptr ) ); 00841 buffer->buff_ptr += vect_bytes_per_tag[i] * ents.size(); 00842 } 00843 delete buffer; // no need for it afterwards 00844 MB_CHK_ERR( rval ); 00845 } 00846 } 00847 else if( graph_type == COVERAGE ) // receive buffer, then extract tag data, in a loop 00848 { 00849 // we know that we will need to receive some tag data in a specific order (by ids stored) 00850 // first, get the ids of the local elements, from owned Range; unpack the buffer in order 00851 Tag gidTag = mb->globalId_tag(); 00852 std::vector< int > gids; 00853 gids.resize( owned.size() ); 00854 rval = mb->tag_get_data( gidTag, owned, &gids[0] );MB_CHK_ERR( rval ); 00855 std::map< int, EntityHandle > gidToHandle; 00856 size_t i = 0; 00857 for( Range::iterator it = owned.begin(); it != owned.end(); it++ ) 00858 { 00859 EntityHandle eh = *it; 00860 gidToHandle[gids[i++]] = eh; 00861 } 00862 // 00863 // now, unpack the data and set it to the tag 00864 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00865 mit != involved_IDs_map.end(); mit++ ) 00866 { 00867 int sender_proc = mit->first; 00868 std::vector< int >& eids = mit->second; 00869 int size_buffer = 4 + total_bytes_per_entity * 00870 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00871 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00872 buffer->reset_ptr( sizeof( int ) ); 00873 *( (int*)buffer->mem_ptr ) = size_buffer; // this is really not necessary, it should receive this too 00874 00875 // receive the buffer 00876 ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status ); 00877 if( ierr != 0 ) return MB_FAILURE; 00878 // start copy 00879 #ifdef VERBOSE 00880 std::ofstream dbfile; 00881 std::stringstream outf; 00882 outf << "recvFrom_" << sender_proc << "_on_proc_" << rankInJoin << ".txt"; 00883 dbfile.open( outf.str().c_str() ); 00884 dbfile << "recvFrom_" << sender_proc << " on proc " << rankInJoin << "\n"; 00885 #endif 00886 00887 // copy tag data from buffer->buff_ptr 00888 // data is arranged by tag , and repeat the loop for each entity () 00889 // maybe it should be arranged by entity now, not by tag (so one loop for entities, 00890 // outside) 00891 00892 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++ ) 00893 { 00894 int eID = *it; 00895 std::map< int, EntityHandle >::iterator mit2 = gidToHandle.find( eID ); 00896 if( mit2 == gidToHandle.end() ) 00897 { 00898 std::cout << " on rank: " << rankInJoin << " cannot find entity handle with global ID " << eID 00899 << "\n"; 00900 return MB_FAILURE; 00901 } 00902 EntityHandle eh = mit2->second; 00903 for( i = 0; i < tag_handles.size(); i++ ) 00904 { 00905 rval = mb->tag_set_data( tag_handles[i], &eh, 1, (void*)( buffer->buff_ptr ) );MB_CHK_ERR( rval ); 00906 #ifdef VERBOSE 00907 dbfile << "global ID " << eID << " local handle " << mb->id_from_handle( eh ) << " vals: "; 00908 double* vals = (double*)( buffer->buff_ptr ); 00909 for( int kk = 0; kk < tag_sizes[i]; kk++ ) 00910 { 00911 dbfile << " " << *vals; 00912 vals++; 00913 } 00914 dbfile << "\n"; 00915 #endif 00916 buffer->buff_ptr += vect_bytes_per_tag[i]; 00917 } 00918 } 00919 00920 // delete receive buffer 00921 delete buffer; 00922 #ifdef VERBOSE 00923 dbfile.close(); 00924 #endif 00925 } 00926 } 00927 else if( graph_type == DOF_BASED ) 00928 { 00929 // need to fill up the values for each tag, in the order desired, from the buffer received 00930 // 00931 // get all the tags, for all owned entities, and pack the buffers accordingly 00932 // we do not want to get the tags by entity, it may be too expensive 00933 std::vector< std::vector< double > > valuesTags; 00934 valuesTags.resize( tag_handles.size() ); 00935 for( size_t i = 0; i < tag_handles.size(); i++ ) 00936 { 00937 int bytes_per_tag; 00938 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00939 valuesTags[i].resize( owned.size() * bytes_per_tag / sizeof( double ) ); 00940 // fill the whole array, we will pick up from here 00941 // we will fill this array, using data from received buffer 00942 // rval = mb->tag_get_data(owned, (void*)( &(valuesTags[i][0])) );MB_CHK_ERR ( rval ); 00943 } 00944 // now, unpack the data and set the tags 00945 sendReqs.resize( involved_IDs_map.size() ); 00946 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00947 mit != involved_IDs_map.end(); mit++ ) 00948 { 00949 int sender_proc = mit->first; 00950 std::vector< int >& eids = mit->second; 00951 std::vector< int >& index_in_values = map_index[sender_proc]; 00952 std::vector< int >& index_ptr = map_ptr[sender_proc]; // this is eids.size()+1; 00953 int size_buffer = 4 + total_bytes_per_entity * 00954 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00955 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00956 buffer->reset_ptr( sizeof( int ) ); 00957 00958 // receive the buffer 00959 ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status ); 00960 if( ierr != 0 ) return MB_FAILURE; 00961 // use the values in buffer to populate valuesTag arrays, fill it up! 00962 int j = 0; 00963 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++, j++ ) 00964 { 00965 for( size_t i = 0; i < tag_handles.size(); i++ ) 00966 { 00967 // right now, move just doubles; but it could be any type of tag 00968 double val = *( (double*)( buffer->buff_ptr ) ); 00969 buffer->buff_ptr += 8; // we know we are working with doubles only !!! 00970 for( int k = index_ptr[j]; k < index_ptr[j + 1]; k++ ) 00971 valuesTags[i][index_in_values[k]] = val; 00972 } 00973 } 00974 // we are done with the buffer in which we received tags, release / delete it 00975 delete buffer; 00976 } 00977 // now we populated the values for all tags; set now the tags! 00978 for( size_t i = 0; i < tag_handles.size(); i++ ) 00979 { 00980 // we will fill this array, using data from received buffer 00981 rval = mb->tag_set_data( tag_handles[i], owned, (void*)( &( valuesTags[i][0] ) ) );MB_CHK_ERR( rval ); 00982 } 00983 } 00984 return MB_SUCCESS; 00985 } 00986 /* 00987 * for example 00988 */ 00989 ErrorCode ParCommGraph::settle_send_graph( TupleList& TLcovIDs ) 00990 { 00991 // fill involved_IDs_map with data 00992 // will have "receiving proc" and global id of element 00993 int n = TLcovIDs.get_n(); 00994 graph_type = COVERAGE; // do not rely only on involved_IDs_map.size(); this can be 0 in some cases 00995 for( int i = 0; i < n; i++ ) 00996 { 00997 int to_proc = TLcovIDs.vi_wr[2 * i]; 00998 int globalIdElem = TLcovIDs.vi_wr[2 * i + 1]; 00999 involved_IDs_map[to_proc].push_back( globalIdElem ); 01000 } 01001 #ifdef VERBOSE 01002 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); mit != involved_IDs_map.end(); 01003 mit++ ) 01004 { 01005 std::cout << " towards task " << mit->first << " send: " << mit->second.size() << " cells " << std::endl; 01006 for( size_t i = 0; i < mit->second.size(); i++ ) 01007 { 01008 std::cout << " " << mit->second[i]; 01009 } 01010 std::cout << std::endl; 01011 } 01012 #endif 01013 return MB_SUCCESS; 01014 } 01015 01016 // this will set involved_IDs_map will store all ids to be received from one sender task 01017 void ParCommGraph::SetReceivingAfterCoverage( 01018 std::map< int, std::set< int > >& idsFromProcs ) // will make sense only on receivers, right now after cov 01019 { 01020 for( std::map< int, std::set< int > >::iterator mt = idsFromProcs.begin(); mt != idsFromProcs.end(); mt++ ) 01021 { 01022 int fromProc = mt->first; 01023 std::set< int >& setIds = mt->second; 01024 involved_IDs_map[fromProc].resize( setIds.size() ); 01025 std::vector< int >& listIDs = involved_IDs_map[fromProc]; 01026 size_t indx = 0; 01027 for( std::set< int >::iterator st = setIds.begin(); st != setIds.end(); st++ ) 01028 { 01029 int valueID = *st; 01030 listIDs[indx++] = valueID; 01031 } 01032 } 01033 graph_type = COVERAGE; 01034 return; 01035 } 01036 //#define VERBOSE 01037 void ParCommGraph::settle_comm_by_ids( int comp, TupleList& TLBackToComp, std::vector< int >& valuesComp ) 01038 { 01039 // settle comm graph on comp 01040 if( rootSender || rootReceiver ) std::cout << " settle comm graph by id on component " << comp << "\n"; 01041 int n = TLBackToComp.get_n(); 01042 // third_method = true; // do not rely only on involved_IDs_map.size(); this can be 0 in some 01043 // cases 01044 std::map< int, std::set< int > > uniqueIDs; 01045 01046 for( int i = 0; i < n; i++ ) 01047 { 01048 int to_proc = TLBackToComp.vi_wr[3 * i + 2]; 01049 int globalId = TLBackToComp.vi_wr[3 * i + 1]; 01050 uniqueIDs[to_proc].insert( globalId ); 01051 } 01052 01053 // Vector to store element 01054 // with respective present index 01055 std::vector< std::pair< int, int > > vp; 01056 vp.reserve( valuesComp.size() ); 01057 01058 // Inserting element in pair vector 01059 // to keep track of previous indexes in valuesComp 01060 for( int i = 0; i < (int)valuesComp.size(); ++i ) 01061 { 01062 vp.push_back( std::make_pair( valuesComp[i], i ) ); 01063 } 01064 // Sorting pair vector 01065 sort( vp.begin(), vp.end() ); 01066 01067 // vp[i].first, second 01068 01069 // count now how many times some value appears in ordered (so in valuesComp) 01070 for( std::map< int, std::set< int > >::iterator it = uniqueIDs.begin(); it != uniqueIDs.end(); it++ ) 01071 { 01072 int procId = it->first; 01073 std::set< int >& nums = it->second; 01074 std::vector< int >& indx = map_ptr[procId]; 01075 std::vector< int >& indices = map_index[procId]; 01076 indx.resize( nums.size() + 1 ); 01077 int indexInVp = 0; 01078 int indexVal = 0; 01079 indx[0] = 0; // start from 0 01080 for( std::set< int >::iterator sst = nums.begin(); sst != nums.end(); sst++, indexVal++ ) 01081 { 01082 int val = *sst; 01083 involved_IDs_map[procId].push_back( val ); 01084 indx[indexVal + 1] = indx[indexVal]; 01085 while( ( indexInVp < (int)valuesComp.size() ) && ( vp[indexInVp].first <= val ) ) // should be equal ! 01086 { 01087 if( vp[indexInVp].first == val ) 01088 { 01089 indx[indexVal + 1]++; 01090 indices.push_back( vp[indexInVp].second ); 01091 } 01092 indexInVp++; 01093 } 01094 } 01095 } 01096 #ifdef VERBOSE 01097 std::stringstream f1; 01098 std::ofstream dbfile; 01099 f1 << "Involve_" << comp << "_" << rankInJoin << ".txt"; 01100 dbfile.open( f1.str().c_str() ); 01101 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); mit != involved_IDs_map.end(); 01102 mit++ ) 01103 { 01104 int corrTask = mit->first; 01105 std::vector< int >& corrIds = mit->second; 01106 std::vector< int >& indx = map_ptr[corrTask]; 01107 std::vector< int >& indices = map_index[corrTask]; 01108 01109 dbfile << " towards proc " << corrTask << " \n"; 01110 for( int i = 0; i < (int)corrIds.size(); i++ ) 01111 { 01112 dbfile << corrIds[i] << " [" << indx[i] << "," << indx[i + 1] << ") : "; 01113 for( int j = indx[i]; j < indx[i + 1]; j++ ) 01114 dbfile << indices[j] << " "; 01115 dbfile << "\n"; 01116 } 01117 dbfile << " \n"; 01118 } 01119 dbfile.close(); 01120 #endif 01121 01122 graph_type = DOF_BASED; 01123 // now we need to fill back and forth information, needed to fill the arrays 01124 // for example, from spectral to involved_IDs_map, in case we want to send data from 01125 // spectral to phys 01126 } 01127 //#undef VERBOSE 01128 // new partition calculation 01129 ErrorCode ParCommGraph::compute_partition( ParallelComm* pco, Range& owned, int met ) 01130 { 01131 // we are on a task on sender, and need to compute a new partition; 01132 // primary cells need to be distributed to nb receivers tasks 01133 // first, we will use graph partitioner, with zoltan; 01134 // in the graph that we need to build, the first layer of ghosts is needed; 01135 // can we avoid that ? For example, we can find out from each boundary edge/face what is the 01136 // other cell (on the other side), then form the global graph, and call zoltan in parallel met 1 01137 // would be a geometric partitioner, and met 2 would be a graph partitioner for method 1 we do 01138 // not need any ghost exchange 01139 01140 // find first edges that are shared 01141 if( owned.empty() ) 01142 return MB_SUCCESS; // nothing to do? empty partition is not allowed, maybe we should return 01143 // error? 01144 Core* mb = (Core*)pco->get_moab(); 01145 01146 double t1, t2, t3; 01147 t1 = MPI_Wtime(); 01148 int primaryDim = mb->dimension_from_handle( *owned.rbegin() ); 01149 int interfaceDim = primaryDim - 1; // should be 1 or 2 01150 Range sharedEdges; 01151 ErrorCode rval; 01152 01153 std::vector< int > shprocs( MAX_SHARING_PROCS ); 01154 std::vector< EntityHandle > shhandles( MAX_SHARING_PROCS ); 01155 01156 Tag gidTag = mb->globalId_tag(); 01157 int np; 01158 unsigned char pstatus; 01159 01160 std::multimap< int, int > extraGraphEdges; 01161 // std::map<int, int> adjCellsId; 01162 std::map< int, int > extraCellsProc; 01163 // if method is 2, no need to do the exchange for adjacent cells across partition boundary 01164 // these maps above will be empty for method 2 (geometry) 01165 if( 1 == met ) 01166 { 01167 rval = pco->get_shared_entities( /*int other_proc*/ -1, sharedEdges, interfaceDim, 01168 /*const bool iface*/ true );MB_CHK_ERR( rval ); 01169 01170 #ifdef VERBOSE 01171 std::cout << " on sender task " << pco->rank() << " number of shared interface cells " << sharedEdges.size() 01172 << "\n"; 01173 #endif 01174 // find to what processors we need to send the ghost info about the edge 01175 // first determine the local graph; what elements are adjacent to each cell in owned range 01176 // cells that are sharing a partition interface edge, are identified first, and form a map 01177 TupleList TLe; // tuple list for cells 01178 TLe.initialize( 2, 0, 1, 0, sharedEdges.size() ); // send to, id of adj cell, remote edge 01179 TLe.enableWriteAccess(); 01180 01181 std::map< EntityHandle, int > edgeToCell; // from local boundary edge to adjacent cell id 01182 // will be changed after 01183 for( Range::iterator eit = sharedEdges.begin(); eit != sharedEdges.end(); eit++ ) 01184 { 01185 EntityHandle edge = *eit; 01186 // get the adjacent cell 01187 Range adjEnts; 01188 rval = mb->get_adjacencies( &edge, 1, primaryDim, false, adjEnts );MB_CHK_ERR( rval ); 01189 if( adjEnts.size() > 0 ) 01190 { 01191 EntityHandle adjCell = adjEnts[0]; 01192 int gid; 01193 rval = mb->tag_get_data( gidTag, &adjCell, 1, &gid );MB_CHK_ERR( rval ); 01194 rval = pco->get_sharing_data( edge, &shprocs[0], &shhandles[0], pstatus, np );MB_CHK_ERR( rval ); 01195 int n = TLe.get_n(); 01196 TLe.vi_wr[2 * n] = shprocs[0]; 01197 TLe.vi_wr[2 * n + 1] = gid; 01198 TLe.vul_wr[n] = shhandles[0]; // the remote edge corresponding to shared edge 01199 edgeToCell[edge] = gid; // store the map between edge and local id of adj cell 01200 TLe.inc_n(); 01201 } 01202 } 01203 01204 #ifdef VERBOSE 01205 std::stringstream ff2; 01206 ff2 << "TLe_" << pco->rank() << ".txt"; 01207 TLe.print_to_file( ff2.str().c_str() ); 01208 #endif 01209 // send the data to the other processors: 01210 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLe, 0 ); 01211 // on receiver side, each local edge will have the remote cell adjacent to it! 01212 01213 int ne = TLe.get_n(); 01214 for( int i = 0; i < ne; i++ ) 01215 { 01216 int sharedProc = TLe.vi_rd[2 * i]; // this info is coming from here, originally 01217 int remoteCellID = TLe.vi_rd[2 * i + 1]; // this is the id of the remote cell, on sharedProc 01218 EntityHandle localCell = TLe.vul_rd[i]; // this is now local edge/face on this proc 01219 int localCellId = edgeToCell[localCell]; // this is the local cell adjacent to edge/face 01220 // now, we will need to add to the graph the pair <localCellId, remoteCellID> 01221 std::pair< int, int > extraAdj = std::make_pair( localCellId, remoteCellID ); 01222 extraGraphEdges.insert( extraAdj ); 01223 // adjCellsId [edgeToCell[localCell]] = remoteCellID; 01224 extraCellsProc[remoteCellID] = sharedProc; 01225 #ifdef VERBOSE 01226 std::cout << "local ID " << edgeToCell[localCell] << " remote cell ID: " << remoteCellID << "\n"; 01227 #endif 01228 } 01229 } 01230 t2 = MPI_Wtime(); 01231 if( rootSender ) std::cout << " time preparing the input for Zoltan:" << t2 - t1 << " seconds. \n"; 01232 // so adj cells ids; need to call zoltan for parallel partition 01233 #ifdef MOAB_HAVE_ZOLTAN 01234 ZoltanPartitioner* mbZTool = new ZoltanPartitioner( mb, pco ); 01235 if( 1 <= met ) // partition in zoltan, either graph or geometric partitioner 01236 { 01237 std::map< int, Range > distribution; // how to distribute owned elements by processors in receiving groups 01238 // in how many tasks do we want to be distributed? 01239 int numNewPartitions = (int)receiverTasks.size(); 01240 Range primaryCells = owned.subset_by_dimension( primaryDim ); 01241 rval = mbZTool->partition_owned_cells( primaryCells, extraGraphEdges, extraCellsProc, numNewPartitions, 01242 distribution, met );MB_CHK_ERR( rval ); 01243 for( std::map< int, Range >::iterator mit = distribution.begin(); mit != distribution.end(); mit++ ) 01244 { 01245 int part_index = mit->first; 01246 assert( part_index < numNewPartitions ); 01247 split_ranges[receiverTasks[part_index]] = mit->second; 01248 } 01249 } 01250 // delete now the partitioner 01251 delete mbZTool; 01252 #endif 01253 t3 = MPI_Wtime(); 01254 if( rootSender ) std::cout << " time spent by Zoltan " << t3 - t2 << " seconds. \n"; 01255 return MB_SUCCESS; 01256 } 01257 01258 // after map read, we need to know what entities we need to send to receiver 01259 ErrorCode ParCommGraph::set_split_ranges( int comp, 01260 TupleList& TLBackToComp1, 01261 std::vector< int >& valuesComp1, 01262 int lenTag, 01263 Range& ents_of_interest, 01264 int /*type*/ ) 01265 { 01266 // settle split_ranges // same role as partitioning 01267 if( rootSender ) std::cout << " find split_ranges on component " << comp << " according to read map \n"; 01268 // Vector to store element 01269 // with respective present index 01270 int n = TLBackToComp1.get_n(); 01271 // third_method = true; // do not rely only on involved_IDs_map.size(); this can be 0 in some 01272 // cases 01273 std::map< int, std::set< int > > uniqueIDs; 01274 01275 for( int i = 0; i < n; i++ ) 01276 { 01277 int to_proc = TLBackToComp1.vi_wr[3 * i + 2]; 01278 int globalId = TLBackToComp1.vi_wr[3 * i + 1]; 01279 uniqueIDs[to_proc].insert( globalId ); 01280 } 01281 01282 for( int i = 0; i < (int)ents_of_interest.size(); i++ ) 01283 { 01284 EntityHandle ent = ents_of_interest[i]; 01285 for( int j = 0; j < lenTag; j++ ) 01286 { 01287 int marker = valuesComp1[i * lenTag + j]; 01288 for( auto mit = uniqueIDs.begin(); mit != uniqueIDs.end(); mit++ ) 01289 { 01290 int proc = mit->first; 01291 std::set< int >& setIds = mit->second; 01292 if( setIds.find( marker ) != setIds.end() ) 01293 { 01294 split_ranges[proc].insert( ent ); 01295 } 01296 } 01297 } 01298 } 01299 01300 return MB_SUCCESS; 01301 } 01302 01303 // new methods to migrate mesh after reading map 01304 ErrorCode ParCommGraph::form_tuples_to_migrate_mesh( Interface* mb, 01305 TupleList& TLv, 01306 TupleList& TLc, 01307 int type, 01308 int lenTagType1 ) 01309 { 01310 // we will always need GlobalID tag 01311 Tag gidtag = mb->globalId_tag(); 01312 // for Type1, we need GLOBAL_DOFS tag; 01313 Tag gds; 01314 ErrorCode rval; 01315 if( type == 1 ) 01316 { 01317 rval = mb->tag_get_handle( "GLOBAL_DOFS", gds ); 01318 } 01319 // find vertices to be sent, for each of the split_ranges procs 01320 std::map< int, Range > verts_to_proc; 01321 int numv = 0, numc = 0; 01322 for( auto it = split_ranges.begin(); it != split_ranges.end(); it++ ) 01323 { 01324 int to_proc = it->first; 01325 Range verts; 01326 if( type != 2 ) 01327 { 01328 rval = mb->get_connectivity( it->second, verts );MB_CHK_ERR( rval ); 01329 numc += (int)it->second.size(); 01330 } 01331 else 01332 verts = it->second; 01333 verts_to_proc[to_proc] = verts; 01334 numv += (int)verts.size(); 01335 } 01336 // first vertices: 01337 TLv.initialize( 2, 0, 0, 3, numv ); // to proc, GLOBAL ID, 3 real coordinates 01338 TLv.enableWriteAccess(); 01339 // use the global id of vertices for connectivity 01340 for( auto it = verts_to_proc.begin(); it != verts_to_proc.end(); it++ ) 01341 { 01342 int to_proc = it->first; 01343 Range& verts = it->second; 01344 for( Range::iterator vit = verts.begin(); vit != verts.end(); ++vit ) 01345 { 01346 EntityHandle v = *vit; 01347 int n = TLv.get_n(); // current size of tuple list 01348 TLv.vi_wr[2 * n] = to_proc; // send to processor 01349 01350 rval = mb->tag_get_data( gidtag, &v, 1, &( TLv.vi_wr[2 * n + 1] ) );MB_CHK_ERR( rval ); 01351 rval = mb->get_coords( &v, 1, &( TLv.vr_wr[3 * n] ) );MB_CHK_ERR( rval ); 01352 TLv.inc_n(); // increment tuple list size 01353 } 01354 } 01355 if( type == 2 ) return MB_SUCCESS; // no need to fill TLc 01356 // to proc, ID cell, gdstag, nbv, id conn, 01357 int size_tuple = 2 + ( ( type != 1 ) ? 0 : lenTagType1 ) + 1 + 10; // 10 is the max number of vertices in cell 01358 01359 std::vector< int > gdvals; 01360 01361 TLc.initialize( size_tuple, 0, 0, 0, numc ); // to proc, GLOBAL ID, 3 real coordinates 01362 TLc.enableWriteAccess(); 01363 for( auto it = split_ranges.begin(); it != split_ranges.end(); it++ ) 01364 { 01365 int to_proc = it->first; 01366 Range& cells = it->second; 01367 for( Range::iterator cit = cells.begin(); cit != cells.end(); ++cit ) 01368 { 01369 EntityHandle cell = *cit; 01370 int n = TLc.get_n(); // current size of tuple list 01371 TLc.vi_wr[size_tuple * n] = to_proc; 01372 int current_index = 2; 01373 rval = mb->tag_get_data( gidtag, &cell, 1, &( TLc.vi_wr[size_tuple * n + 1] ) );MB_CHK_ERR( rval ); 01374 if( 1 == type ) 01375 { 01376 rval = mb->tag_get_data( gds, &cell, 1, &( TLc.vi_wr[size_tuple * n + current_index] ) );MB_CHK_ERR( rval ); 01377 current_index += lenTagType1; 01378 } 01379 // now get connectivity 01380 const EntityHandle* conn = NULL; 01381 int nnodes = 0; 01382 rval = mb->get_connectivity( cell, conn, nnodes );MB_CHK_ERR( rval ); 01383 // fill nnodes: 01384 TLc.vi_wr[size_tuple * n + current_index] = nnodes; 01385 rval = mb->tag_get_data( gidtag, conn, nnodes, &( TLc.vi_wr[size_tuple * n + current_index + 1] ) );MB_CHK_ERR( rval ); 01386 TLc.inc_n(); // increment tuple list size 01387 } 01388 } 01389 return MB_SUCCESS; 01390 } 01391 ErrorCode ParCommGraph::form_mesh_from_tuples( Interface* mb, 01392 TupleList& TLv, 01393 TupleList& TLc, 01394 int type, 01395 int lenTagType1, 01396 EntityHandle fset, 01397 Range& primary_ents, 01398 std::vector< int >& values_entities ) 01399 { 01400 // might need to fill also the split_range things 01401 // we will always need GlobalID tag 01402 Tag gidtag = mb->globalId_tag(); 01403 // for Type1, we need GLOBAL_DOFS tag; 01404 Tag gds; 01405 ErrorCode rval; 01406 std::vector< int > def_val( lenTagType1, 0 ); 01407 if( type == 1 ) 01408 { 01409 // we may need to create this tag 01410 rval = mb->tag_get_handle( "GLOBAL_DOFS", lenTagType1, MB_TYPE_INTEGER, gds, MB_TAG_CREAT | MB_TAG_DENSE, 01411 &def_val[0] );MB_CHK_ERR( rval ); 01412 } 01413 01414 std::map< int, EntityHandle > vertexMap; // 01415 Range verts; 01416 // always form vertices and add them to the fset; 01417 int n = TLv.get_n(); 01418 EntityHandle vertex; 01419 for( int i = 0; i < n; i++ ) 01420 { 01421 int gid = TLv.vi_rd[2 * i + 1]; 01422 if( vertexMap.find( gid ) == vertexMap.end() ) 01423 { 01424 // need to form this vertex 01425 rval = mb->create_vertex( &( TLv.vr_rd[3 * i] ), vertex );MB_CHK_ERR( rval ); 01426 vertexMap[gid] = vertex; 01427 verts.insert( vertex ); 01428 rval = mb->tag_set_data( gidtag, &vertex, 1, &gid );MB_CHK_ERR( rval ); 01429 // if point cloud, 01430 } 01431 if( 2 == type ) // point cloud, add it to the split_ranges ? 01432 { 01433 split_ranges[TLv.vi_rd[2 * i]].insert( vertexMap[gid] ); 01434 } 01435 // todo : when to add the values_entities ? 01436 } 01437 rval = mb->add_entities( fset, verts );MB_CHK_ERR( rval ); 01438 if( 2 == type ) 01439 { 01440 primary_ents = verts; 01441 values_entities.resize( verts.size() ); // just get the ids of vertices 01442 rval = mb->tag_get_data( gidtag, verts, &values_entities[0] );MB_CHK_ERR( rval ); 01443 return MB_SUCCESS; 01444 } 01445 01446 n = TLc.get_n(); 01447 int size_tuple = 2 + ( ( type != 1 ) ? 0 : lenTagType1 ) + 1 + 10; // 10 is the max number of vertices in cell 01448 01449 EntityHandle new_element; 01450 Range cells; 01451 std::map< int, EntityHandle > cellMap; // do no tcreate one if it already exists, maybe from other processes 01452 for( int i = 0; i < n; i++ ) 01453 { 01454 int from_proc = TLc.vi_rd[size_tuple * i]; 01455 int globalIdEl = TLc.vi_rd[size_tuple * i + 1]; 01456 if( cellMap.find( globalIdEl ) == cellMap.end() ) // need to create the cell 01457 { 01458 int current_index = 2; 01459 if( 1 == type ) current_index += lenTagType1; 01460 int nnodes = TLc.vi_rd[size_tuple * i + current_index]; 01461 std::vector< EntityHandle > conn; 01462 conn.resize( nnodes ); 01463 for( int j = 0; j < nnodes; j++ ) 01464 { 01465 conn[j] = vertexMap[TLc.vi_rd[size_tuple * i + current_index + j + 1]]; 01466 } 01467 // 01468 EntityType entType = MBQUAD; 01469 if( nnodes > 4 ) entType = MBPOLYGON; 01470 if( nnodes < 4 ) entType = MBTRI; 01471 rval = mb->create_element( entType, &conn[0], nnodes, new_element );MB_CHK_SET_ERR( rval, "can't create new element " ); 01472 cells.insert( new_element ); 01473 cellMap[globalIdEl] = new_element; 01474 rval = mb->tag_set_data( gidtag, &new_element, 1, &globalIdEl );MB_CHK_SET_ERR( rval, "can't set global id tag on cell " ); 01475 if( 1 == type ) 01476 { 01477 // set the gds tag 01478 rval = mb->tag_set_data( gds, &new_element, 1, &( TLc.vi_rd[size_tuple * i + 2] ) );MB_CHK_SET_ERR( rval, "can't set gds tag on cell " ); 01479 } 01480 } 01481 split_ranges[from_proc].insert( cellMap[globalIdEl] ); 01482 } 01483 rval = mb->add_entities( fset, cells );MB_CHK_ERR( rval ); 01484 primary_ents = cells; 01485 if( 1 == type ) 01486 { 01487 values_entities.resize( lenTagType1 * primary_ents.size() ); 01488 rval = mb->tag_get_data( gds, primary_ents, &values_entities[0] );MB_CHK_ERR( rval ); 01489 } 01490 else // type == 3 01491 { 01492 values_entities.resize( primary_ents.size() ); // just get the ids ! 01493 rval = mb->tag_get_data( gidtag, primary_ents, &values_entities[0] );MB_CHK_ERR( rval ); 01494 } 01495 return MB_SUCCESS; 01496 } 01497 01498 // at this moment, each sender task has split_ranges formed; 01499 // we need to aggregate that info and send it to receiver 01500 ErrorCode ParCommGraph::send_graph_partition( ParallelComm* pco, MPI_Comm jcomm ) 01501 { 01502 // first, accumulate the info to root of sender; use gatherv 01503 // first, accumulate number of receivers from each sender, to the root receiver 01504 int numberReceivers = 01505 (int)split_ranges.size(); // these are ranges of elements to be sent to each receiver, from this task 01506 int nSenders = (int)senderTasks.size(); // 01507 // this sender will have to send to this many receivers 01508 std::vector< int > displs( 1 ); // displacements for gatherv 01509 std::vector< int > counts( 1 ); 01510 if( is_root_sender() ) 01511 { 01512 displs.resize( nSenders + 1 ); 01513 counts.resize( nSenders ); 01514 } 01515 01516 int ierr = MPI_Gather( &numberReceivers, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, pco->comm() ); 01517 if( ierr != MPI_SUCCESS ) return MB_FAILURE; 01518 // compute now displacements 01519 if( is_root_sender() ) 01520 { 01521 displs[0] = 0; 01522 for( int k = 0; k < nSenders; k++ ) 01523 { 01524 displs[k + 1] = displs[k] + counts[k]; 01525 } 01526 } 01527 std::vector< int > buffer; 01528 if( is_root_sender() ) buffer.resize( displs[nSenders] ); // the last one will have the total count now 01529 01530 std::vector< int > recvs; 01531 for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ ) 01532 { 01533 recvs.push_back( mit->first ); 01534 } 01535 ierr = 01536 MPI_Gatherv( &recvs[0], numberReceivers, MPI_INT, &buffer[0], &counts[0], &displs[0], MPI_INT, 0, pco->comm() ); 01537 if( ierr != MPI_SUCCESS ) return MB_FAILURE; 01538 01539 // now form recv_graph map; points from the 01540 // now form the graph to be sent to the other side; only on root 01541 if( is_root_sender() ) 01542 { 01543 #ifdef GRAPH_INFO 01544 std::ofstream dbfileSender; 01545 std::stringstream outf; 01546 outf << "S_" << compid1 << "_R_" << compid2 << "_SenderGraph.txt"; 01547 dbfileSender.open( outf.str().c_str() ); 01548 dbfileSender << " number senders: " << nSenders << "\n"; 01549 dbfileSender << " senderRank \treceivers \n"; 01550 for( int k = 0; k < nSenders; k++ ) 01551 { 01552 int indexInBuff = displs[k]; 01553 int senderTask = senderTasks[k]; 01554 dbfileSender << senderTask << "\t\t"; 01555 for( int j = 0; j < counts[k]; j++ ) 01556 { 01557 int recvTask = buffer[indexInBuff + j]; 01558 dbfileSender << recvTask << " "; 01559 } 01560 dbfileSender << "\n"; 01561 } 01562 dbfileSender.close(); 01563 #endif 01564 for( int k = 0; k < nSenders; k++ ) 01565 { 01566 int indexInBuff = displs[k]; 01567 int senderTask = senderTasks[k]; 01568 for( int j = 0; j < counts[k]; j++ ) 01569 { 01570 int recvTask = buffer[indexInBuff + j]; 01571 recv_graph[recvTask].push_back( senderTask ); // this will be packed and sent to root receiver, with 01572 // nonblocking send 01573 } 01574 } 01575 #ifdef GRAPH_INFO 01576 std::ofstream dbfile; 01577 std::stringstream outf2; 01578 outf2 << "S_" << compid1 << "_R_" << compid2 << "_RecvGraph.txt"; 01579 dbfile.open( outf2.str().c_str() ); 01580 dbfile << " number receivers: " << recv_graph.size() << "\n"; 01581 dbfile << " receiverRank \tsenders \n"; 01582 for( std::map< int, std::vector< int > >::iterator mit = recv_graph.begin(); mit != recv_graph.end(); mit++ ) 01583 { 01584 int recvTask = mit->first; 01585 std::vector< int >& senders = mit->second; 01586 dbfile << recvTask << "\t\t"; 01587 for( std::vector< int >::iterator vit = senders.begin(); vit != senders.end(); vit++ ) 01588 dbfile << *vit << " "; 01589 dbfile << "\n"; 01590 } 01591 dbfile.close(); 01592 #endif 01593 // this is the same as trivial partition 01594 ErrorCode rval = send_graph( jcomm );MB_CHK_ERR( rval ); 01595 } 01596 01597 return MB_SUCCESS; 01598 } 01599 // method to expose local graph info: sender id, receiver id, sizes of elements to send, after or 01600 // before intersection 01601 ErrorCode ParCommGraph::dump_comm_information( std::string prefix, int is_send ) 01602 { 01603 // 01604 if( -1 != rankInGroup1 && 1 == is_send ) // it is a sender task 01605 { 01606 std::ofstream dbfile; 01607 std::stringstream outf; 01608 outf << prefix << "_sender_" << rankInGroup1 << "_joint" << rankInJoin << "_type_" << (int)graph_type << ".txt"; 01609 dbfile.open( outf.str().c_str() ); 01610 01611 if( graph_type == COVERAGE ) 01612 { 01613 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01614 mit != involved_IDs_map.end(); mit++ ) 01615 { 01616 int receiver_proc = mit->first; 01617 std::vector< int >& eids = mit->second; 01618 dbfile << "receiver: " << receiver_proc << " size:" << eids.size() << "\n"; 01619 } 01620 } 01621 else if( graph_type == INITIAL_MIGRATE ) // just after migration 01622 { 01623 for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ ) 01624 { 01625 int receiver_proc = mit->first; 01626 Range& eids = mit->second; 01627 dbfile << "receiver: " << receiver_proc << " size:" << eids.size() << "\n"; 01628 } 01629 } 01630 else if( graph_type == DOF_BASED ) // just after migration, or from computeGraph 01631 { 01632 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01633 mit != involved_IDs_map.end(); mit++ ) 01634 { 01635 int receiver_proc = mit->first; 01636 dbfile << "receiver: " << receiver_proc << " size:" << mit->second.size() << "\n"; 01637 } 01638 } 01639 dbfile.close(); 01640 } 01641 if( -1 != rankInGroup2 && 0 == is_send ) // it is a receiver task 01642 { 01643 std::ofstream dbfile; 01644 std::stringstream outf; 01645 outf << prefix << "_receiver_" << rankInGroup2 << "_joint" << rankInJoin << "_type_" << (int)graph_type 01646 << ".txt"; 01647 dbfile.open( outf.str().c_str() ); 01648 01649 if( graph_type == COVERAGE ) 01650 { 01651 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01652 mit != involved_IDs_map.end(); mit++ ) 01653 { 01654 int sender_proc = mit->first; 01655 std::vector< int >& eids = mit->second; 01656 dbfile << "sender: " << sender_proc << " size:" << eids.size() << "\n"; 01657 } 01658 } 01659 else if( graph_type == INITIAL_MIGRATE ) // just after migration 01660 { 01661 for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ ) 01662 { 01663 int sender_proc = mit->first; 01664 Range& eids = mit->second; 01665 dbfile << "sender: " << sender_proc << " size:" << eids.size() << "\n"; 01666 } 01667 } 01668 else if( graph_type == DOF_BASED ) // just after migration 01669 { 01670 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01671 mit != involved_IDs_map.end(); mit++ ) 01672 { 01673 int sender_proc = mit->first; 01674 dbfile << "receiver: " << sender_proc << " size:" << mit->second.size() << "\n"; 01675 } 01676 } 01677 dbfile.close(); 01678 } 01679 return MB_SUCCESS; 01680 } 01681 } // namespace moab
