, including all inherited members.
| argcArg | ZoltanPartitioner | [private] |
| argvArg | ZoltanPartitioner | [private] |
| assemble_graph(const int dimension, std::vector< double > &coords, std::vector< int > &moab_ids, std::vector< int > &adjacencies, std::vector< int > &length, Range &elems, bool part_geom=false, const int projection_type=0) | ZoltanPartitioner | [private] |
| assign_global_ids | PartitionerBase< int > | [protected] |
| balance_mesh(const char *zmethod, const char *other_method, const bool write_as_sets=true, const bool write_as_tags=false) | ZoltanPartitioner | |
| get_global_id_option() | PartitionerBase< int > | [inline] |
| include_closure() | ZoltanPartitioner | [virtual] |
| mbFinalizePoints(int npts, int numExport, ZOLTAN_ID_PTR exportLocalIDs, int *exportProcs, int **assignment) | ZoltanPartitioner | [private] |
| mbGlobalSuccess(int rc) | ZoltanPartitioner | [private] |
| mbImpl | PartitionerBase< int > | [protected] |
| mbInitializePoints(int npts, double *pts, int *ids, int *adjs, int *length, double *obj_weights=NULL, double *edge_weights=NULL, int *parts=NULL, bool part_geom=false) | ZoltanPartitioner | [private] |
| mbPrintGlobalResult(const char *s, int begin, int import, int exp, int change) | ZoltanPartitioner | [private] |
| mbShowError(int val, const char *s) | ZoltanPartitioner | [private] |
| myNumPts | ZoltanPartitioner | [private] |
| myZZ | ZoltanPartitioner | [private] |
| newComm | PartitionerBase< int > | [protected] |
| part_sets() | PartitionerBase< int > | [inline] |
| part_sets() const | PartitionerBase< int > | [inline] |
| partition_inferred_mesh(EntityHandle sfileset, size_t num_parts, int part_dim=3, const bool write_as_sets=true, int projection_type=0) | ZoltanPartitioner | |
| partition_mesh(const int nparts, const char *method, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const bool partition_tagged_sets=false, const bool partition_tagged_ents=false, const char *aggregating_tag=NULL, const bool print_time=false) | ZoltanPartitioner | [inline, virtual] |
| partition_mesh_and_geometry(const double part_geom_mesh_size, const int nparts, const char *zmethod, const char *other_method, double imbal_tol, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const int obj_weight=0, const int edge_weight=0, const bool part_surf=false, const bool ghost=false, const int projection_type=0, const bool recompute_rcb_box=false, const bool print_time=false) | ZoltanPartitioner | [virtual] |
| partition_owned_cells(Range &owned, std::multimap< int, int > &extraGraphEdges, std::map< int, int > procs, int &numNewPartitions, std::map< int, Range > &distribution, int met) | ZoltanPartitioner | |
| PartitionerBase(Interface *impl=NULL, const bool use_coords=false) | PartitionerBase< int > | |
| partSets | ZoltanPartitioner | [private] |
| repartition(std::vector< double > &x, std::vector< double > &y, std::vector< double > &z, int StartID, const char *zmethod, Range &localGIDs) | ZoltanPartitioner | |
| set_global_id_option(bool id_opt) | PartitionerBase< int > | [inline] |
| SetHSFC_Parameters() | ZoltanPartitioner | |
| SetHypergraph_Parameters(const char *phg_method) | ZoltanPartitioner | |
| SetOCTPART_Parameters(const char *oct_method) | ZoltanPartitioner | |
| SetPARMETIS_Parameters(const char *parmetis_method) | ZoltanPartitioner | |
| SetRCB_Parameters(const bool recompute_rcb_box=false) | ZoltanPartitioner | |
| SetRIB_Parameters() | ZoltanPartitioner | |
| useCoords | PartitionerBase< int > | [protected] |
| write_partition(const int nparts, Range &elems, const int *assignment, const bool write_as_sets, const bool write_as_tags) | ZoltanPartitioner | [virtual] |
| PartitionerBase< int >::write_partition(const intnparts, Range &elems, const int *assignment, const bool write_as_sets, const bool write_as_tags)=0 | PartitionerBase< int > | [pure virtual] |
| ZoltanPartitioner(Interface *impl=NULL, const bool use_coords=false, int argc=0, char **argv=NULL) | ZoltanPartitioner | |
| ~PartitionerBase() | PartitionerBase< int > | [virtual] |
| ~ZoltanPartitioner() | ZoltanPartitioner | [virtual] |
