MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* $Id$ 00002 * 00003 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00004 * storing and accessing finite element mesh data. 00005 * 00006 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00007 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00008 * retains certain rights in this software. 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or (at your option) any later version. 00014 * 00015 */ 00016 00017 /** Get a mesh from MOAB and write a Zoltan partition set back into MOAB and to 00018 * a file 00019 * 00020 * 00021 */ 00022 00023 #include <iostream> 00024 #include <cassert> 00025 #include <sstream> 00026 #include <algorithm> 00027 00028 #include "moab/ZoltanPartitioner.hpp" 00029 #include "moab/Interface.hpp" 00030 #include "Internals.hpp" 00031 #include "moab/Range.hpp" 00032 #include "moab/WriteUtilIface.hpp" 00033 #include "moab/MeshTopoUtil.hpp" 00034 #include "MBTagConventions.hpp" 00035 #include "moab/CN.hpp" 00036 // used for gnomonic projection 00037 #include "moab/IntxMesh/IntxUtils.hpp" 00038 00039 #ifdef MOAB_HAVE_CGM 00040 #include "CGMConfig.h" 00041 #include <limits> 00042 #include "RefEntity.hpp" 00043 #include "RefFace.hpp" 00044 #include "RefEdge.hpp" 00045 #include "RefVertex.hpp" 00046 #include "Body.hpp" 00047 #include "TopologyEntity.hpp" 00048 #include "CastTo.hpp" 00049 #include "CABodies.hpp" 00050 #include "TDParallel.hpp" 00051 #include "TDUniqueId.hpp" 00052 #endif 00053 00054 using namespace moab; 00055 00056 #define RR \ 00057 if( MB_SUCCESS != result ) return result 00058 00059 static double* Points = NULL; 00060 static int* GlobalIds = NULL; 00061 static int NumPoints = 0; 00062 static int* NumEdges = NULL; 00063 static int* NborGlobalId = NULL; 00064 static int* NborProcs = NULL; 00065 static double* ObjWeights = NULL; 00066 static double* EdgeWeights = NULL; 00067 static int* Parts = NULL; 00068 00069 const bool debug = false; 00070 00071 ZoltanPartitioner::ZoltanPartitioner( Interface* impl, 00072 #ifdef MOAB_HAVE_MPI 00073 ParallelComm* parcomm, 00074 #endif 00075 const bool use_coords, 00076 int argc, 00077 char** argv 00078 #ifdef MOAB_HAVE_CGM 00079 , 00080 GeometryQueryTool* gqt 00081 #endif 00082 00083 ) 00084 : PartitionerBase< int >( impl, use_coords 00085 #ifdef MOAB_HAVE_MPI 00086 , 00087 parcomm 00088 #endif 00089 ), myZZ( NULL ), myNumPts( 0 ), argcArg( argc ), argvArg( argv ) 00090 #ifdef MOAB_HAVE_CGM 00091 , 00092 gti( gqt ) 00093 #endif 00094 { 00095 } 00096 00097 ZoltanPartitioner::~ZoltanPartitioner() 00098 { 00099 if( NULL != myZZ ) delete myZZ; 00100 } 00101 00102 ErrorCode ZoltanPartitioner::balance_mesh( const char* zmethod, 00103 const char* other_method, 00104 const bool write_as_sets, 00105 const bool write_as_tags ) 00106 { 00107 if( !strcmp( zmethod, "RR" ) && !strcmp( zmethod, "RCB" ) && !strcmp( zmethod, "RIB" ) && 00108 !strcmp( zmethod, "HSFC" ) && !strcmp( zmethod, "Hypergraph" ) && !strcmp( zmethod, "PHG" ) && 00109 !strcmp( zmethod, "PARMETIS" ) && !strcmp( zmethod, "OCTPART" ) ) 00110 { 00111 std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be " 00112 << "RR, RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl; 00113 return MB_FAILURE; 00114 } 00115 00116 std::vector< double > pts; // x[0], y[0], z[0], ... from MOAB 00117 std::vector< int > ids; // point ids from MOAB 00118 std::vector< int > adjs, length; 00119 Range elems; 00120 00121 // Get a mesh from MOAB and divide it across processors. 00122 00123 ErrorCode result; 00124 00125 if( mbpc->proc_config().proc_rank() == 0 ) 00126 { 00127 result = assemble_graph( 3, pts, ids, adjs, length, elems );RR; 00128 } 00129 00130 myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0] ); 00131 00132 // Initialize Zoltan. This is a C call. The simple C++ code 00133 // that creates Zoltan objects does not keep track of whether 00134 // Zoltan_Initialize has been called. 00135 00136 float version; 00137 00138 Zoltan_Initialize( argcArg, argvArg, &version ); 00139 00140 // Create Zoltan object. This calls Zoltan_Create. 00141 if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() ); 00142 00143 if( NULL == zmethod || !strcmp( zmethod, "RCB" ) ) 00144 SetRCB_Parameters(); 00145 else if( !strcmp( zmethod, "RIB" ) ) 00146 SetRIB_Parameters(); 00147 else if( !strcmp( zmethod, "HSFC" ) ) 00148 SetHSFC_Parameters(); 00149 else if( !strcmp( zmethod, "Hypergraph" ) || !strcmp( zmethod, "PHG" ) ) 00150 if( NULL == other_method ) 00151 SetHypergraph_Parameters( "auto" ); 00152 else 00153 SetHypergraph_Parameters( other_method ); 00154 else if( !strcmp( zmethod, "PARMETIS" ) ) 00155 { 00156 if( NULL == other_method ) 00157 SetPARMETIS_Parameters( "RepartGDiffusion" ); 00158 else 00159 SetPARMETIS_Parameters( other_method ); 00160 } 00161 else if( !strcmp( zmethod, "OCTPART" ) ) 00162 { 00163 if( NULL == other_method ) 00164 SetOCTPART_Parameters( "2" ); 00165 else 00166 SetOCTPART_Parameters( other_method ); 00167 } 00168 00169 // Call backs: 00170 00171 myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL ); 00172 myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL ); 00173 myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL ); 00174 myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL ); 00175 myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL ); 00176 myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL ); 00177 00178 // Perform the load balancing partitioning 00179 00180 int changes; 00181 int numGidEntries; 00182 int numLidEntries; 00183 int numImport; 00184 ZOLTAN_ID_PTR importGlobalIds; 00185 ZOLTAN_ID_PTR importLocalIds; 00186 int* importProcs; 00187 int* importToPart; 00188 int numExport; 00189 ZOLTAN_ID_PTR exportGlobalIds; 00190 ZOLTAN_ID_PTR exportLocalIds; 00191 int* exportProcs; 00192 int* exportToPart; 00193 00194 int rc = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, numImport, importGlobalIds, importLocalIds, 00195 importProcs, importToPart, numExport, exportGlobalIds, exportLocalIds, exportProcs, 00196 exportToPart ); 00197 00198 rc = mbGlobalSuccess( rc ); 00199 00200 if( !rc ) 00201 { 00202 mbPrintGlobalResult( "==============Result==============", myNumPts, numImport, numExport, changes ); 00203 } 00204 else 00205 { 00206 return MB_FAILURE; 00207 } 00208 00209 // take results & write onto MOAB partition sets 00210 00211 int* assignment; 00212 00213 mbFinalizePoints( (int)ids.size(), numExport, exportLocalIds, exportProcs, &assignment ); 00214 00215 if( mbpc->proc_config().proc_rank() == 0 ) 00216 { 00217 result = write_partition( mbpc->proc_config().proc_size(), elems, assignment, write_as_sets, write_as_tags ); 00218 00219 if( MB_SUCCESS != result ) return result; 00220 00221 free( (int*)assignment ); 00222 } 00223 00224 // Free the memory allocated for lists returned by LB_Parition() 00225 00226 myZZ->LB_Free_Part( &importGlobalIds, &importLocalIds, &importProcs, &importToPart ); 00227 myZZ->LB_Free_Part( &exportGlobalIds, &exportLocalIds, &exportProcs, &exportToPart ); 00228 00229 // Implementation note: A Zoltan object contains an MPI communicator. 00230 // When the Zoltan object is destroyed, it uses it's MPI communicator. 00231 // So it is important that the Zoltan object is destroyed before 00232 // the MPI communicator is destroyed. To ensure this, dynamically 00233 // allocate the Zoltan object, so you can explicitly destroy it. 00234 // If you create a Zoltan object on the stack, it's destructor will 00235 // be invoked atexit, possibly after the communicator's 00236 // destructor. 00237 00238 return MB_SUCCESS; 00239 } 00240 00241 ErrorCode ZoltanPartitioner::repartition( std::vector< double >& x, 00242 std::vector< double >& y, 00243 std::vector< double >& z, 00244 int StartID, 00245 const char* zmethod, 00246 Range& localGIDs ) 00247 { 00248 // 00249 int nprocs = mbpc->proc_config().proc_size(); 00250 int rank = mbpc->proc_config().proc_rank(); 00251 clock_t t = clock(); 00252 // form pts and ids, as in assemble_graph 00253 std::vector< double > pts; // x[0], y[0], z[0], ... from MOAB 00254 pts.resize( x.size() * 3 ); 00255 std::vector< int > ids; // point ids from MOAB 00256 ids.resize( x.size() ); 00257 for( size_t i = 0; i < x.size(); i++ ) 00258 { 00259 pts[3 * i] = x[i]; 00260 pts[3 * i + 1] = y[i]; 00261 pts[3 * i + 2] = z[i]; 00262 ids[i] = StartID + (int)i; 00263 } 00264 // do not get out until done! 00265 00266 Points = &pts[0]; 00267 GlobalIds = &ids[0]; 00268 NumPoints = (int)x.size(); 00269 NumEdges = NULL; 00270 NborGlobalId = NULL; 00271 NborProcs = NULL; 00272 ObjWeights = NULL; 00273 EdgeWeights = NULL; 00274 Parts = NULL; 00275 00276 float version; 00277 if( rank == 0 ) std::cout << "Initializing zoltan..." << std::endl; 00278 00279 Zoltan_Initialize( argcArg, argvArg, &version ); 00280 00281 // Create Zoltan object. This calls Zoltan_Create. 00282 if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() ); 00283 00284 if( NULL == zmethod || !strcmp( zmethod, "RCB" ) ) 00285 SetRCB_Parameters(); 00286 else if( !strcmp( zmethod, "RIB" ) ) 00287 SetRIB_Parameters(); 00288 else if( !strcmp( zmethod, "HSFC" ) ) 00289 SetHSFC_Parameters(); 00290 00291 // set # requested partitions 00292 char buff[10]; 00293 sprintf( buff, "%d", nprocs ); 00294 int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff ); 00295 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00296 00297 // request all, import and export 00298 retval = myZZ->Set_Param( "RETURN_LISTS", "ALL" ); 00299 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00300 00301 myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL ); 00302 myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL ); 00303 myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL ); 00304 myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL ); 00305 myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL ); 00306 myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL ); 00307 00308 // Perform the load balancing partitioning 00309 00310 int changes; 00311 int numGidEntries; 00312 int numLidEntries; 00313 int num_import; 00314 ZOLTAN_ID_PTR import_global_ids, import_local_ids; 00315 int* import_procs; 00316 int* import_to_part; 00317 int num_export; 00318 ZOLTAN_ID_PTR export_global_ids, export_local_ids; 00319 int *assign_procs, *assign_parts; 00320 00321 if( rank == 0 ) 00322 std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nprocs 00323 << " processors..." << std::endl; 00324 00325 retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids, import_local_ids, 00326 import_procs, import_to_part, num_export, export_global_ids, export_local_ids, 00327 assign_procs, assign_parts ); 00328 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00329 00330 if( rank == 0 ) 00331 { 00332 std::cout << " time to LB_partition " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00333 t = clock(); 00334 } 00335 00336 std::sort( import_global_ids, import_global_ids + num_import, std::greater< int >() ); 00337 std::sort( export_global_ids, export_global_ids + num_export, std::greater< int >() ); 00338 00339 Range iniGids( (EntityHandle)StartID, (EntityHandle)StartID + x.size() - 1 ); 00340 Range imported, exported; 00341 std::copy( import_global_ids, import_global_ids + num_import, range_inserter( imported ) ); 00342 std::copy( export_global_ids, export_global_ids + num_export, range_inserter( exported ) ); 00343 localGIDs = subtract( iniGids, exported ); 00344 localGIDs = unite( localGIDs, imported ); 00345 // Free data structures allocated by Zoltan::LB_Partition 00346 retval = myZZ->LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part ); 00347 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00348 retval = myZZ->LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts ); 00349 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00350 00351 return MB_SUCCESS; 00352 } 00353 00354 ErrorCode ZoltanPartitioner::partition_inferred_mesh( EntityHandle sfileset, 00355 size_t num_parts, 00356 int part_dim, 00357 const bool write_as_sets, 00358 int projection_type ) 00359 { 00360 ErrorCode result; 00361 00362 moab::Range elverts; 00363 result = mbImpl->get_entities_by_dimension( sfileset, part_dim, elverts );RR; 00364 00365 std::vector< double > elcoords( elverts.size() * 3 ); 00366 result = mbImpl->get_coords( elverts, &elcoords[0] );RR; 00367 00368 std::vector< std::vector< EntityHandle > > part_assignments( num_parts ); 00369 int part, proc; 00370 00371 // Loop over coordinates 00372 for( size_t iel = 0; iel < elverts.size(); iel++ ) 00373 { 00374 // Gather coordinates into temporary array 00375 double* ecoords = &elcoords[iel * 3]; 00376 00377 // do a projection if needed 00378 if( projection_type > 0 ) IntxUtils::transform_coordinates( ecoords, projection_type ); 00379 00380 // Compute the coordinate's part assignment 00381 myZZ->LB_Point_PP_Assign( ecoords, proc, part ); 00382 00383 // Store the part assignment in the return array 00384 part_assignments[part].push_back( elverts[iel] ); 00385 } 00386 00387 // get the partition set tag 00388 Tag part_set_tag = mbpc->partition_tag(); 00389 00390 // If some entity sets exist, let us delete those first. 00391 if( write_as_sets ) 00392 { 00393 moab::Range oldpsets; 00394 result = mbImpl->get_entities_by_type_and_tag( sfileset, MBENTITYSET, &part_set_tag, NULL, 1, oldpsets, 00395 Interface::UNION );RR; 00396 result = mbImpl->remove_entities( sfileset, oldpsets );RR; 00397 } 00398 00399 size_t nparts_assigned = 0; 00400 for( size_t partnum = 0; partnum < num_parts; ++partnum ) 00401 { 00402 std::vector< EntityHandle >& partvec = part_assignments[partnum]; 00403 00404 nparts_assigned += ( partvec.size() ? 1 : 0 ); 00405 00406 if( write_as_sets ) 00407 { 00408 EntityHandle partNset; 00409 result = mbImpl->create_meshset( moab::MESHSET_SET, partNset );RR; 00410 if( partvec.size() ) 00411 { 00412 result = mbImpl->add_entities( partNset, &partvec[0], partvec.size() );RR; 00413 } 00414 result = mbImpl->add_parent_child( sfileset, partNset );RR; 00415 00416 // part numbering should start from 0 00417 int ipartnum = (int)partnum; 00418 00419 // assign partitions as a sparse tag by grouping elements under sets 00420 result = mbImpl->tag_set_data( part_set_tag, &partNset, 1, &ipartnum );RR; 00421 } 00422 else 00423 { 00424 /* assign as a dense vector to all elements 00425 allocate integer-size partitions */ 00426 std::vector< int > assignment( partvec.size(), 00427 partnum ); // initialize all values to partnum 00428 result = mbImpl->tag_set_data( part_set_tag, &partvec[0], partvec.size(), &assignment[0] );RR; 00429 } 00430 } 00431 00432 if( nparts_assigned != num_parts ) 00433 { 00434 std::cout << "WARNING: The inference yielded lesser number of parts (" << nparts_assigned 00435 << ") than requested by user (" << num_parts << ").\n"; 00436 } 00437 00438 return MB_SUCCESS; 00439 } 00440 00441 ErrorCode ZoltanPartitioner::partition_mesh_and_geometry( const double part_geom_mesh_size, 00442 const int nparts, 00443 const char* zmethod, 00444 const char* other_method, 00445 double imbal_tol, 00446 const int part_dim, 00447 const bool write_as_sets, 00448 const bool write_as_tags, 00449 const int obj_weight, 00450 const int edge_weight, 00451 #ifdef MOAB_HAVE_CGM 00452 const bool part_surf, 00453 const bool ghost, 00454 #else 00455 const bool, 00456 const bool, 00457 #endif 00458 const int projection_type, 00459 const bool recompute_rcb_box, 00460 const bool print_time ) 00461 { 00462 // should only be called in serial 00463 if( mbpc->proc_config().proc_size() != 1 ) 00464 { 00465 std::cout << "ZoltanPartitioner::partition_mesh_and_geometry must be called in serial." << std::endl; 00466 return MB_FAILURE; 00467 } 00468 clock_t t = clock(); 00469 if( NULL != zmethod && strcmp( zmethod, "RR" ) && strcmp( zmethod, "RCB" ) && strcmp( zmethod, "RIB" ) && 00470 strcmp( zmethod, "HSFC" ) && strcmp( zmethod, "Hypergraph" ) && strcmp( zmethod, "PHG" ) && 00471 strcmp( zmethod, "PARMETIS" ) && strcmp( zmethod, "OCTPART" ) ) 00472 { 00473 std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be " 00474 << "RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl; 00475 return MB_FAILURE; 00476 } 00477 00478 bool part_geom = false; 00479 if( 0 == strcmp( zmethod, "RR" ) || 0 == strcmp( zmethod, "RCB" ) || 0 == strcmp( zmethod, "RIB" ) || 00480 0 == strcmp( zmethod, "HSFC" ) ) 00481 part_geom = true; // so no adjacency / edges needed 00482 std::vector< double > pts; // x[0], y[0], z[0], ... from MOAB 00483 std::vector< int > ids; // point ids from MOAB 00484 std::vector< int > adjs, length, parts; 00485 std::vector< double > obj_weights, edge_weights; 00486 Range elems; 00487 #ifdef MOAB_HAVE_CGM 00488 DLIList< RefEntity* > entities; 00489 #endif 00490 00491 // Get a mesh from MOAB and diide it across processors. 00492 00493 ErrorCode result = MB_SUCCESS; 00494 00495 // short-circuit everything if RR partition is requested 00496 if( !strcmp( zmethod, "RR" ) ) 00497 { 00498 if( part_geom_mesh_size < 0. ) 00499 { 00500 // get all elements 00501 result = mbImpl->get_entities_by_dimension( 0, part_dim, elems );RR; 00502 if( elems.empty() ) return MB_FAILURE; 00503 // make a trivial assignment vector 00504 std::vector< int > assign_vec( elems.size() ); 00505 int num_per = elems.size() / nparts; 00506 int extra = elems.size() % nparts; 00507 if( extra ) num_per++; 00508 int nstart = 0; 00509 for( int i = 0; i < nparts; i++ ) 00510 { 00511 if( i == extra ) num_per--; 00512 std::fill( &assign_vec[nstart], &assign_vec[nstart + num_per], i ); 00513 nstart += num_per; 00514 } 00515 00516 result = write_partition( nparts, elems, &assign_vec[0], write_as_sets, write_as_tags );RR; 00517 } 00518 else 00519 { 00520 #ifdef MOAB_HAVE_CGM 00521 result = partition_round_robin( nparts );RR; 00522 #endif 00523 } 00524 00525 return result; 00526 } 00527 00528 std::cout << "Assembling graph..." << std::endl; 00529 00530 if( part_geom_mesh_size < 0. ) 00531 { 00532 // if (!part_geom) { 00533 result = assemble_graph( part_dim, pts, ids, adjs, length, elems, part_geom, projection_type );RR; 00534 } 00535 else 00536 { 00537 #ifdef MOAB_HAVE_CGM 00538 result = assemble_graph( part_dim, pts, ids, adjs, length, obj_weights, edge_weights, parts, entities, 00539 part_geom_mesh_size, nparts );RR; 00540 00541 if( debug ) 00542 { 00543 int n_ids = ids.size(); 00544 entities.reset(); 00545 int i_leng = 0; 00546 for( int i = 0; i < n_ids; i++ ) 00547 { 00548 std::cout << "graph_input_ids[" << i << "]=" << ids[i] << ",obj_weights=" << obj_weights[i] 00549 << ",entity_id=" << entities.get_and_step()->id() << ",part=" << parts[i] << std::endl; 00550 for( int j = 0; j < length[i]; j++ ) 00551 { 00552 std::cout << "adjs[" << j << "]=" << adjs[i_leng] << ",edge_weights=" << edge_weights[i_leng] 00553 << std::endl; 00554 i_leng++; 00555 } 00556 } 00557 } 00558 #endif 00559 } 00560 if( print_time ) 00561 { 00562 std::cout << " time to assemble graph: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00563 t = clock(); 00564 } 00565 double* o_wgt = NULL; 00566 double* e_wgt = NULL; 00567 if( obj_weights.size() > 0 ) o_wgt = &obj_weights[0]; 00568 if( edge_weights.size() > 0 ) e_wgt = &edge_weights[0]; 00569 00570 myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0], o_wgt, e_wgt, &parts[0], 00571 part_geom ); 00572 00573 // Initialize Zoltan. This is a C call. The simple C++ code 00574 // that creates Zoltan objects does not keep track of whether 00575 // Zoltan_Initialize has been called. 00576 00577 if( print_time ) 00578 { 00579 std::cout << " time to initialize points: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00580 t = clock(); 00581 } 00582 float version; 00583 00584 std::cout << "Initializing zoltan..." << std::endl; 00585 00586 Zoltan_Initialize( argcArg, argvArg, &version ); 00587 00588 // Create Zoltan object. This calls Zoltan_Create. 00589 if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() ); 00590 00591 if( NULL == zmethod || !strcmp( zmethod, "RCB" ) ) 00592 SetRCB_Parameters( recompute_rcb_box ); 00593 else if( !strcmp( zmethod, "RIB" ) ) 00594 SetRIB_Parameters(); 00595 else if( !strcmp( zmethod, "HSFC" ) ) 00596 SetHSFC_Parameters(); 00597 else if( !strcmp( zmethod, "Hypergraph" ) || !strcmp( zmethod, "PHG" ) ) 00598 { 00599 if( NULL == other_method || ( other_method[0] == '\0' ) ) 00600 SetHypergraph_Parameters( "auto" ); 00601 else 00602 SetHypergraph_Parameters( other_method ); 00603 00604 if( imbal_tol ) 00605 { 00606 std::ostringstream str; 00607 str << imbal_tol; 00608 myZZ->Set_Param( "IMBALANCE_TOL", str.str().c_str() ); // no debug messages 00609 } 00610 } 00611 else if( !strcmp( zmethod, "PARMETIS" ) ) 00612 { 00613 if( NULL == other_method ) 00614 SetPARMETIS_Parameters( "RepartGDiffusion" ); 00615 else 00616 SetPARMETIS_Parameters( other_method ); 00617 } 00618 else if( !strcmp( zmethod, "OCTPART" ) ) 00619 { 00620 if( NULL == other_method ) 00621 SetOCTPART_Parameters( "2" ); 00622 else 00623 SetOCTPART_Parameters( other_method ); 00624 } 00625 00626 // set # requested partitions 00627 char buff[10]; 00628 sprintf( buff, "%d", nparts ); 00629 int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff ); 00630 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00631 00632 // request only partition assignments 00633 retval = myZZ->Set_Param( "RETURN_LISTS", "PARTITION ASSIGNMENTS" ); 00634 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00635 00636 if( obj_weight > 0 ) 00637 { 00638 std::ostringstream str; 00639 str << obj_weight; 00640 retval = myZZ->Set_Param( "OBJ_WEIGHT_DIM", str.str().c_str() ); 00641 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00642 } 00643 00644 if( edge_weight > 0 ) 00645 { 00646 std::ostringstream str; 00647 str << edge_weight; 00648 retval = myZZ->Set_Param( "EDGE_WEIGHT_DIM", str.str().c_str() ); 00649 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00650 } 00651 00652 // Call backs: 00653 00654 myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL ); 00655 myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL ); 00656 myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL ); 00657 myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL ); 00658 myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL ); 00659 myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL ); 00660 if( part_geom_mesh_size > 0. ) 00661 { 00662 myZZ->Set_Part_Multi_Fn( mbGetPart, NULL ); 00663 } 00664 00665 // Perform the load balancing partitioning 00666 00667 int changes; 00668 int numGidEntries; 00669 int numLidEntries; 00670 int dumnum1; 00671 ZOLTAN_ID_PTR dum_local, dum_global; 00672 int *dum1, *dum2; 00673 int num_assign; 00674 ZOLTAN_ID_PTR assign_gid, assign_lid; 00675 int *assign_procs, *assign_parts; 00676 00677 std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nparts 00678 << " processors..." << std::endl; 00679 #ifndef NDEBUG 00680 #if 0 00681 if (NULL == zmethod || !strcmp(zmethod, "RCB")) 00682 Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 1, 0, 0); 00683 00684 if ( !strcmp(zmethod, "PHG")) 00685 Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 0, 1, 1); 00686 #endif 00687 #endif 00688 retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, dumnum1, dum_global, dum_local, dum1, dum2, 00689 num_assign, assign_gid, assign_lid, assign_procs, assign_parts ); 00690 if( ZOLTAN_OK != retval ) return MB_FAILURE; 00691 00692 if( print_time ) 00693 { 00694 std::cout << " time to LB_partition " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00695 t = clock(); 00696 } 00697 // take results & write onto MOAB partition sets 00698 std::cout << "Saving partition information to MOAB..." << std::endl; 00699 00700 if( part_geom_mesh_size < 0. ) 00701 { 00702 // if (!part_geom) { 00703 result = write_partition( nparts, elems, assign_parts, write_as_sets, write_as_tags ); 00704 } 00705 else 00706 { 00707 #ifdef MOAB_HAVE_CGM 00708 result = write_partition( nparts, entities, assign_parts, obj_weights, part_surf, ghost ); 00709 #endif 00710 } 00711 00712 if( print_time ) 00713 { 00714 std::cout << " time to write partition in memory " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00715 t = clock(); 00716 } 00717 00718 if( MB_SUCCESS != result ) return result; 00719 00720 // Free the memory allocated for lists returned by LB_Parition() 00721 myZZ->LB_Free_Part( &assign_gid, &assign_lid, &assign_procs, &assign_parts ); 00722 00723 return MB_SUCCESS; 00724 } 00725 00726 ErrorCode ZoltanPartitioner::include_closure() 00727 { 00728 ErrorCode result; 00729 Range ents; 00730 Range adjs; 00731 std::cout << "Adding closure..." << std::endl; 00732 00733 for( Range::iterator rit = partSets.begin(); rit != partSets.end(); ++rit ) 00734 { 00735 00736 // get the top-dimensional entities in the part 00737 result = mbImpl->get_entities_by_handle( *rit, ents, true );RR; 00738 00739 if( ents.empty() ) continue; 00740 00741 // get intermediate-dimensional adjs and add to set 00742 for( int d = mbImpl->dimension_from_handle( *ents.begin() ) - 1; d >= 1; d-- ) 00743 { 00744 adjs.clear(); 00745 result = mbImpl->get_adjacencies( ents, d, false, adjs, Interface::UNION );RR; 00746 result = mbImpl->add_entities( *rit, adjs );RR; 00747 } 00748 00749 // now get vertices and add to set; only need to do for ents, not for adjs 00750 adjs.clear(); 00751 result = mbImpl->get_adjacencies( ents, 0, false, adjs, Interface::UNION );RR; 00752 result = mbImpl->add_entities( *rit, adjs );RR; 00753 00754 ents.clear(); 00755 } 00756 00757 // now go over non-part entity sets, looking for contained entities 00758 Range sets, part_ents; 00759 result = mbImpl->get_entities_by_type( 0, MBENTITYSET, sets );RR; 00760 for( Range::iterator rit = sets.begin(); rit != sets.end(); ++rit ) 00761 { 00762 // skip parts 00763 if( partSets.find( *rit ) != partSets.end() ) continue; 00764 00765 // get entities in this set, recursively 00766 ents.clear(); 00767 result = mbImpl->get_entities_by_handle( *rit, ents, true );RR; 00768 00769 // now check over all parts 00770 for( Range::iterator rit2 = partSets.begin(); rit2 != partSets.end(); ++rit2 ) 00771 { 00772 part_ents.clear(); 00773 result = mbImpl->get_entities_by_handle( *rit2, part_ents, false );RR; 00774 Range int_range = intersect( ents, part_ents ); 00775 if( !int_range.empty() ) 00776 { 00777 // non-empty intersection, add to part set 00778 result = mbImpl->add_entities( *rit2, &( *rit ), 1 );RR; 00779 } 00780 } 00781 } 00782 00783 // finally, mark all the part sets as having the closure 00784 Tag closure_tag; 00785 result = 00786 mbImpl->tag_get_handle( "INCLUDES_CLOSURE", 1, MB_TYPE_INTEGER, closure_tag, MB_TAG_SPARSE | MB_TAG_CREAT );RR; 00787 00788 std::vector< int > closure_vals( partSets.size(), 1 ); 00789 result = mbImpl->tag_set_data( closure_tag, partSets, &closure_vals[0] );RR; 00790 00791 return MB_SUCCESS; 00792 } 00793 00794 ErrorCode ZoltanPartitioner::assemble_graph( const int dimension, 00795 std::vector< double >& coords, 00796 std::vector< int >& moab_ids, 00797 std::vector< int >& adjacencies, 00798 std::vector< int >& length, 00799 Range& elems, 00800 bool part_geom, 00801 int projection_type ) 00802 { 00803 // assemble a graph with vertices equal to elements of specified dimension, edges 00804 // signified by list of other elements to which an element is connected 00805 00806 // get the elements of that dimension 00807 ErrorCode result = mbImpl->get_entities_by_dimension( 0, dimension, elems ); 00808 if( MB_SUCCESS != result || elems.empty() ) return result; 00809 00810 // assign global ids 00811 if( assign_global_ids ) 00812 { 00813 EntityHandle rootset = 0; 00814 result = mbpc->assign_global_ids( rootset, dimension, 1, true, true );RR; 00815 } 00816 00817 // now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1 00818 // dimensional neighbors 00819 MeshTopoUtil mtu( mbImpl ); 00820 Range adjs; 00821 // can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited 00822 // by MBCN 00823 int neighbors[5 * MAX_SUB_ENTITIES]; 00824 double avg_position[3]; 00825 int moab_id; 00826 00827 // get the global id tag handle 00828 Tag gid = mbImpl->globalId_tag(); 00829 00830 for( Range::iterator rit = elems.begin(); rit != elems.end(); ++rit ) 00831 { 00832 00833 if( !part_geom ) 00834 { 00835 // get bridge adjacencies 00836 adjs.clear(); 00837 result = mtu.get_bridge_adjacencies( *rit, ( dimension > 0 ? dimension - 1 : 3 ), dimension, adjs );RR; 00838 00839 // get the graph vertex ids of those 00840 if( !adjs.empty() ) 00841 { 00842 assert( adjs.size() < 5 * MAX_SUB_ENTITIES ); 00843 result = mbImpl->tag_get_data( gid, adjs, neighbors );RR; 00844 } 00845 00846 // copy those into adjacencies vector 00847 length.push_back( (int)adjs.size() ); 00848 std::copy( neighbors, neighbors + adjs.size(), std::back_inserter( adjacencies ) ); 00849 } 00850 00851 // get average position of vertices 00852 result = mtu.get_average_position( *rit, avg_position );RR; 00853 00854 // get the graph vertex id for this element 00855 result = mbImpl->tag_get_data( gid, &( *rit ), 1, &moab_id );RR; 00856 00857 // copy those into coords vector 00858 moab_ids.push_back( moab_id ); 00859 // transform coordinates to spherical coordinates, if requested 00860 if( projection_type > 0 ) IntxUtils::transform_coordinates( avg_position, projection_type ); 00861 00862 std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) ); 00863 } 00864 00865 if( debug ) 00866 { 00867 std::cout << "Length vector: " << std::endl; 00868 std::copy( length.begin(), length.end(), std::ostream_iterator< int >( std::cout, ", " ) ); 00869 std::cout << std::endl; 00870 std::cout << "Adjacencies vector: " << std::endl; 00871 std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( std::cout, ", " ) ); 00872 std::cout << std::endl; 00873 std::cout << "Moab_ids vector: " << std::endl; 00874 std::copy( moab_ids.begin(), moab_ids.end(), std::ostream_iterator< int >( std::cout, ", " ) ); 00875 std::cout << std::endl; 00876 std::cout << "Coords vector: " << std::endl; 00877 std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( std::cout, ", " ) ); 00878 std::cout << std::endl; 00879 } 00880 00881 return MB_SUCCESS; 00882 } 00883 00884 #ifdef MOAB_HAVE_CGM 00885 ErrorCode ZoltanPartitioner::assemble_graph( const int /* dimension */, 00886 std::vector< double >& /* coords */, 00887 std::vector< int >& moab_ids, 00888 std::vector< int >& adjacencies, 00889 std::vector< int >& length, 00890 std::vector< double >& obj_weights, 00891 std::vector< double >& edge_weights, 00892 std::vector< int >& parts, 00893 DLIList< RefEntity* >& entities, 00894 const double part_geom_mesh_size, 00895 const int n_part ) 00896 { 00897 // get body vertex weights 00898 DLIList< RefEntity* > body_list; 00899 gti->ref_entity_list( "body", body_list, CUBIT_FALSE ); 00900 DLIList< RefFace* > all_shared_surfs; 00901 int n_bodies = body_list.size(); 00902 int body_map_index = 1; 00903 int surf_map_index = n_bodies + 1; 00904 int n_bodies_proc = n_bodies / n_part; // # of entities per processor 00905 int i_bodies_proc = n_bodies_proc; // entity index limit for each processor 00906 int proc = 0; 00907 00908 body_list.reset(); 00909 for( int i = 0; i < n_bodies; i++ ) 00910 { 00911 // assign part in round-robin 00912 if( i == i_bodies_proc ) 00913 { 00914 proc++; 00915 if( proc < n_part ) 00916 i_bodies_proc += n_bodies_proc; 00917 else 00918 { 00919 proc %= n_part; 00920 i_bodies_proc++; 00921 } 00922 } 00923 parts.push_back( proc ); 00924 00925 // volume mesh generation load estimation 00926 RefEntity* body = body_list.get_and_step(); 00927 double vertex_w = body->measure(); 00928 vertex_w /= part_geom_mesh_size * part_geom_mesh_size * part_geom_mesh_size; 00929 vertex_w = 3.8559e-5 * vertex_w * log( vertex_w ); 00930 00931 // add child non-interface face weights 00932 DLIList< RefFace* > shared_surfs; 00933 DLIList< RefFace* > faces; 00934 ( dynamic_cast< TopologyEntity* >( body ) )->ref_faces( faces ); 00935 int n_face = faces.size(); 00936 faces.reset(); 00937 for( int j = 0; j < n_face; j++ ) 00938 { 00939 RefFace* face = faces.get_and_step(); 00940 TopologyEntity* te = CAST_TO( face, TopologyEntity ); 00941 if( te->bridge_manager()->number_of_bridges() > 1 ) 00942 { // shared 00943 shared_surfs.append( face ); 00944 } 00945 else 00946 { // non-shared 00947 vertex_w += estimate_face_mesh_load( face, face->measure() ); 00948 } 00949 } 00950 00951 int temp_index = body_map_index++; 00952 body_vertex_map[body->id()] = temp_index; 00953 moab_ids.push_back( temp_index ); // add body as graph vertex 00954 obj_weights.push_back( vertex_w ); // add weight for body graph vertex 00955 00956 if( debug ) 00957 { 00958 std::cout << "body=" << body->id() << ",graph_id=" << temp_index << ",weight=" << vertex_w 00959 << ",part=" << proc << std::endl; 00960 } 00961 00962 // treat shared surfaces connected to this body 00963 int n_shared = shared_surfs.size(); 00964 shared_surfs.reset(); 00965 for( int k = 0; k < n_shared; k++ ) 00966 { // add adjacencies 00967 RefFace* face = shared_surfs.get_and_step(); 00968 std::map< int, int >::iterator iter = surf_vertex_map.find( face->id() ); 00969 if( iter != surf_vertex_map.end() ) 00970 { 00971 temp_index = ( *iter ).second; 00972 } 00973 else 00974 { 00975 temp_index = surf_map_index++; 00976 surf_vertex_map[face->id()] = temp_index; 00977 all_shared_surfs.append( face ); 00978 } 00979 adjacencies.push_back( temp_index ); 00980 double tmp_sw = estimate_face_comm_load( face, part_geom_mesh_size ); 00981 edge_weights.push_back( tmp_sw ); 00982 00983 if( debug ) 00984 { 00985 std::cout << "adjac=" << temp_index << ",weight=" << tmp_sw << std::endl; 00986 } 00987 } 00988 length.push_back( n_shared ); 00989 } 00990 entities += body_list; 00991 00992 // add shared surface as graph vertex 00993 int n_all_shared_surf = all_shared_surfs.size(); 00994 all_shared_surfs.reset(); 00995 for( int i = 0; i < n_all_shared_surf; i++ ) 00996 { 00997 RefEntity* face = all_shared_surfs.get_and_step(); 00998 moab_ids.push_back( surf_vertex_map[face->id()] ); 00999 double face_mesh_load = estimate_face_mesh_load( face, part_geom_mesh_size ); 01000 obj_weights.push_back( face_mesh_load ); 01001 01002 // set surface object graph edges 01003 int min_ind = -1; 01004 double min_load = std::numeric_limits< double >::max(); 01005 ; 01006 DLIList< Body* > parents; 01007 dynamic_cast< TopologyEntity* >( face )->bodies( parents ); 01008 int n_parents = parents.size(); 01009 parents.reset(); 01010 for( int j = 0; j < n_parents; j++ ) 01011 { 01012 int body_gid = body_vertex_map[parents.get_and_step()->id()]; 01013 adjacencies.push_back( body_gid ); // add adjacency 01014 edge_weights.push_back( estimate_face_comm_load( face, part_geom_mesh_size ) ); 01015 01016 if( obj_weights[body_gid - 1] < min_load ) 01017 { 01018 min_ind = body_gid - 1; 01019 min_load = obj_weights[min_ind]; 01020 } 01021 } 01022 length.push_back( n_parents ); 01023 entities.append( dynamic_cast< RefEntity* >( face ) ); 01024 obj_weights[min_ind] += face_mesh_load; 01025 parts.push_back( parts[min_ind] ); 01026 01027 if( debug ) 01028 { 01029 std::cout << "shared_surf=" << face->id() << ",graph_id=" << surf_vertex_map[face->id()] 01030 << ",weight=" << face_mesh_load << ",part=" << parts[min_ind] << std::endl; 01031 } 01032 } 01033 01034 for( size_t i = 0; i < obj_weights.size(); i++ ) 01035 if( obj_weights[i] < 1. ) obj_weights[i] = 1.; 01036 for( size_t i = 0; i < edge_weights.size(); i++ ) 01037 if( edge_weights[i] < 1. ) edge_weights[i] = 1.; 01038 01039 return MB_SUCCESS; 01040 } 01041 01042 double ZoltanPartitioner::estimate_face_mesh_load( RefEntity* face, const double h ) 01043 { 01044 GeometryType type = CAST_TO( face, RefFace )->geometry_type(); 01045 double n = face->measure() / h / h; 01046 double n_logn = n * log( n ); 01047 01048 if( type == PLANE_SURFACE_TYPE ) 01049 { 01050 return 1.536168737505151e-4 * n_logn; 01051 } 01052 else if( type == SPLINE_SURFACE_TYPE ) 01053 { 01054 return 5.910511018383144e-4 * n_logn; 01055 } 01056 else if( type == CONE_SURFACE_TYPE || type == SPHERE_SURFACE_TYPE || type == TORUS_SURFACE_TYPE ) 01057 { 01058 return 2.352511671418708e-4 * n_logn; 01059 } 01060 01061 return 0.0; 01062 } 01063 01064 double ZoltanPartitioner::estimate_face_comm_load( RefEntity* face, const double h ) 01065 { 01066 double peri = 0.; 01067 #if( ( CGM_MAJOR_VERSION == 14 && CGM_MINOR_VERSION > 2 ) || CGM_MAJOR_VERSION >= 15 ) 01068 DLIList< DLIList< RefEdge* > > ref_edge_loops; 01069 #else 01070 DLIList< DLIList< RefEdge* >* > ref_edge_loops; 01071 #endif 01072 CAST_TO( face, RefFace )->ref_edge_loops( ref_edge_loops ); 01073 ref_edge_loops.reset(); 01074 01075 #if( ( CGM_MAJOR_VERSION == 14 && CGM_MINOR_VERSION > 2 ) || CGM_MAJOR_VERSION >= 15 ) 01076 for( int i = 0; i < ref_edge_loops.size(); i++ ) 01077 { 01078 DLIList< RefEdge* > eloop = ref_edge_loops.get_and_step(); 01079 eloop.reset(); 01080 for( int j = 0; j < eloop.size(); j++ ) 01081 { 01082 peri += eloop.get_and_step()->measure(); 01083 } 01084 } 01085 #else 01086 for( int i = 0; i < ref_edge_loops.size(); i++ ) 01087 { 01088 DLIList< RefEdge* >* eloop = ref_edge_loops.get_and_step(); 01089 eloop->reset(); 01090 for( int j = 0; j < eloop->size(); j++ ) 01091 { 01092 peri += eloop->get_and_step()->measure(); 01093 } 01094 } 01095 #endif 01096 01097 // return 104*face->measure()/sqrt(3)/h/h + 56/3*peri/h; 01098 return ( 104 * face->measure() / sqrt( 3 ) / h / h + 56 / 3 * peri / h ) / 700000.; 01099 } 01100 01101 ErrorCode ZoltanPartitioner::write_partition( const int nparts, 01102 DLIList< RefEntity* > entities, 01103 const int* assignment, 01104 std::vector< double >& obj_weights, 01105 const bool part_surf, 01106 const bool ghost ) 01107 { 01108 ErrorCode result; 01109 01110 // actuate CA_BODIES and turn on auto flag for other attributes 01111 CGMApp::instance()->attrib_manager()->register_attrib_type( CA_BODIES, "bodies", "BODIES", CABodies_creator, 01112 CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE, 01113 CUBIT_TRUE, CUBIT_FALSE ); 01114 CGMApp::instance()->attrib_manager()->auto_flag( CUBIT_TRUE ); 01115 01116 // set partition info to Body at first 01117 int n_entities = entities.size(); 01118 entities.reset(); 01119 for( int i = 0; i < n_entities; i++ ) 01120 { 01121 int proc = assignment[i]; 01122 DLIList< int > shared_procs; 01123 RefEntity* entity = entities.get_and_step(); 01124 01125 if( entity->entity_type_info() == typeid( Body ) ) 01126 { 01127 shared_procs.append( proc ); 01128 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel ); 01129 if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs ); 01130 01131 if( debug ) 01132 { 01133 std::cout << "body" << entity->id() << "_is_partitioned_to_p" << proc << std::endl; 01134 } 01135 01136 // assign to volumes, it should be removed in future 01137 DLIList< RefVolume* > volumes; 01138 ( dynamic_cast< TopologyEntity* >( entity ) )->ref_volumes( volumes ); 01139 int n_vol = volumes.size(); 01140 volumes.reset(); 01141 for( int j = 0; j < n_vol; j++ ) 01142 { 01143 RefEntity* vol = volumes.get_and_step(); 01144 td_par = (TDParallel*)vol->get_TD( &TDParallel::is_parallel ); 01145 if( td_par == NULL ) td_par = new TDParallel( vol, NULL, &shared_procs ); 01146 } 01147 } 01148 } 01149 01150 // set partition info to shared surfaces 01151 entities.reset(); 01152 for( int i = 0; i < n_entities; i++ ) 01153 { 01154 int proc = assignment[i]; 01155 DLIList< int > shared_procs; 01156 RefEntity* entity = entities.get_and_step(); 01157 01158 if( entity->entity_type_info() == typeid( RefFace ) ) 01159 { // surface 01160 DLIList< Body* > parents; 01161 ( dynamic_cast< TopologyEntity* >( entity ) )->bodies( parents ); 01162 int n_parents = parents.size(); 01163 if( n_parents != 2 ) 01164 { // check # of parents 01165 std::cerr << "# of parent bodies of interface surface should be 2." << std::endl; 01166 return MB_FAILURE; 01167 } 01168 shared_procs.append( proc ); // local proc 01169 parents.reset(); 01170 for( int j = 0; j < 2; j++ ) 01171 { 01172 RefEntity* parent = parents.get_and_step(); 01173 TDParallel* parent_td = (TDParallel*)parent->get_TD( &TDParallel::is_parallel ); 01174 01175 if( parent_td == NULL ) 01176 { 01177 std::cerr << "parent body should have balanced process." << std::endl; 01178 return MB_FAILURE; 01179 } 01180 int temp_proc = parent_td->get_charge_proc(); 01181 if( temp_proc != proc ) shared_procs.append( temp_proc ); // remote proc 01182 } 01183 01184 if( shared_procs.size() > 1 ) 01185 { // if it is shared by 2 processors 01186 int merge_id = TDUniqueId::get_unique_id( entity ); 01187 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel ); 01188 if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs, NULL, merge_id, 1 ); 01189 01190 if( debug ) 01191 { 01192 std::cout << "surf" << entity->id() << "_is_partitioned_to_p"; 01193 for( int j = 0; j < shared_procs.size(); j++ ) 01194 { 01195 std::cout << "," << shared_procs[j]; 01196 } 01197 std::cout << std::endl; 01198 } 01199 } 01200 } 01201 } 01202 01203 // do non-shared surface partition too 01204 if( part_surf ) 01205 { 01206 result = partition_surface( nparts, entities, assignment, obj_weights );RR; 01207 } 01208 01209 // partition shared edges and vertex 01210 result = partition_child_entities( 1, nparts, part_surf, ghost );RR; 01211 result = partition_child_entities( 0, nparts, part_surf );RR; 01212 01213 if( debug ) 01214 { 01215 entities.reset(); 01216 for( int i = 0; i < n_entities; i++ ) 01217 { 01218 RefEntity* entity = entities.get_and_step(); 01219 if( entity->entity_type_info() == typeid( Body ) ) 01220 { 01221 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel ); 01222 CubitString st = entity->entity_name(); 01223 DLIList< int >* sp = td_par->get_shared_proc_list(); 01224 int n_sp = sp->size(); 01225 sp->reset(); 01226 for( int j = 0; j < n_sp; j++ ) 01227 { 01228 std::cout << "partitioned_" << st.c_str() << ",proc=" << sp->get_and_step() << std::endl; 01229 } 01230 DLIList< int >* gp = td_par->get_ghost_proc_list(); 01231 int n_gp = gp->size(); 01232 sp->reset(); 01233 for( int j = 0; j < n_gp; j++ ) 01234 { 01235 std::cout << "partitioned_" << st.c_str() << ",ghost=" << gp->get_and_step() << std::endl; 01236 } 01237 } 01238 } 01239 } 01240 01241 return MB_SUCCESS; 01242 } 01243 01244 ErrorCode ZoltanPartitioner::partition_surface( const int nparts, 01245 DLIList< RefEntity* > entities, 01246 const int* assignment, 01247 std::vector< double >& obj_weights ) 01248 { 01249 int i; 01250 double ave_load = 0.; 01251 double* loads = new double[nparts]; 01252 for( i = 0; i < nparts; i++ ) 01253 loads[i] = 0.; 01254 01255 int n_entities = entities.size(); 01256 entities.reset(); 01257 for( i = 0; i < n_entities; i++ ) 01258 { 01259 loads[assignment[i]] += obj_weights[i]; 01260 ave_load += obj_weights[i]; 01261 } 01262 ave_load /= nparts; 01263 01264 if( debug ) 01265 { 01266 for( i = 0; i < nparts; i++ ) 01267 { 01268 std::cout << "loads_before_surface_partition[" << i << "]=" << loads[i] << std::endl; 01269 } 01270 } 01271 01272 int n_iter = 0; 01273 bool b_stop = false; 01274 do 01275 { 01276 // get max and min load processors 01277 int max_proc = nparts, min_proc = 0; 01278 double min_load = std::numeric_limits< double >::max(); 01279 double max_load = std::numeric_limits< double >::min(); 01280 for( i = 0; i < nparts; i++ ) 01281 { 01282 if( loads[i] < min_load ) 01283 { 01284 min_load = loads[i]; 01285 min_proc = i; 01286 } 01287 if( loads[i] > max_load ) 01288 { 01289 max_load = loads[i]; 01290 max_proc = i; 01291 } 01292 } 01293 01294 double load_diff = max_load - ave_load; 01295 if( load_diff > ave_load / 10. ) 01296 { 01297 bool b_moved = false; 01298 entities.reset(); 01299 for( i = 0; i < n_entities; i++ ) 01300 { 01301 if( b_moved ) break; 01302 if( assignment[i] == max_proc && // find maximum load processor bodies 01303 entities[i]->entity_type_info() == typeid( Body ) ) 01304 { 01305 DLIList< RefFace* > faces; 01306 ( dynamic_cast< TopologyEntity* >( entities[i] ) )->ref_faces( faces ); 01307 int n_face = faces.size(); 01308 faces.reset(); 01309 for( int j = 0; j < n_face; j++ ) 01310 { 01311 RefFace* face = faces.get_and_step(); 01312 TopologyEntity* te = CAST_TO( face, TopologyEntity ); 01313 if( te->bridge_manager()->number_of_bridges() < 2 ) 01314 { // non-shared 01315 TDParallel* td_par = (TDParallel*)face->get_TD( &TDParallel::is_parallel ); 01316 if( td_par == NULL ) 01317 { // only consider unpartitioned surfaces 01318 double face_load = face->measure(); 01319 if( load_diff > min_load + face_load - ave_load ) 01320 { 01321 loads[max_proc] -= face_load; 01322 loads[min_proc] += face_load; 01323 int merge_id = TDUniqueId::get_unique_id( face ); 01324 DLIList< int > shared_procs; 01325 shared_procs.append( min_proc ); 01326 shared_procs.append( max_proc ); 01327 td_par = new TDParallel( face, NULL, &shared_procs, NULL, merge_id, 1 ); 01328 01329 if( debug ) 01330 { 01331 std::cout << "non-shared surface " << face->id() << " is moved from p" 01332 << max_proc << " to p" << min_proc << std::endl; 01333 } 01334 b_moved = true; 01335 break; 01336 } 01337 } 01338 } 01339 } 01340 } 01341 } 01342 } 01343 else 01344 b_stop = true; 01345 01346 n_iter++; 01347 } while( !b_stop && n_iter < 50 ); 01348 01349 if( debug ) 01350 { 01351 for( i = 0; i < nparts; i++ ) 01352 { 01353 std::cout << "loads_after_surface_partition[" << i << "]=" << loads[i] << std::endl; 01354 } 01355 } 01356 01357 delete loads; 01358 return MB_SUCCESS; 01359 } 01360 01361 ErrorCode ZoltanPartitioner::partition_round_robin( const int n_part ) 01362 { 01363 int i, j, k; 01364 double* loads = new double[n_part]; // estimated loads for each processor 01365 double* ve_loads = new double[n_part]; // estimated loads for each processor 01366 for( i = 0; i < n_part; i++ ) 01367 { 01368 loads[i] = 0.0; 01369 ve_loads[i] = 0.0; 01370 } 01371 DLIList< RefEntity* > body_entity_list; 01372 gti->ref_entity_list( "body", body_entity_list, CUBIT_FALSE ); 01373 int n_entity = body_entity_list.size(); 01374 int n_entity_proc = n_entity / n_part; // # of entities per processor 01375 int i_entity_proc = n_entity_proc; // entity index limit for each processor 01376 int proc = 0; 01377 RefEntity* entity; 01378 01379 // assign processors to bodies 01380 body_entity_list.reset(); 01381 for( i = 0; i < n_entity; i++ ) 01382 { 01383 if( i == i_entity_proc ) 01384 { 01385 proc++; 01386 if( proc < n_part ) 01387 i_entity_proc += n_entity_proc; 01388 else 01389 { 01390 proc %= n_part; 01391 i_entity_proc++; 01392 } 01393 } 01394 01395 // assign to bodies 01396 entity = body_entity_list.get_and_step(); 01397 DLIList< int > shared_procs; 01398 shared_procs.append( proc ); 01399 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel ); 01400 if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs ); 01401 loads[proc] += entity->measure(); 01402 01403 // assign to volumes, it should be removed in future 01404 DLIList< RefVolume* > volumes; 01405 ( dynamic_cast< TopologyEntity* >( entity ) )->ref_volumes( volumes ); 01406 int n_vol = volumes.size(); 01407 volumes.reset(); 01408 for( j = 0; j < n_vol; j++ ) 01409 { 01410 RefEntity* vol = volumes.get_and_step(); 01411 td_par = (TDParallel*)vol->get_TD( &TDParallel::is_parallel ); 01412 if( td_par == NULL ) td_par = new TDParallel( vol, NULL, &shared_procs ); 01413 } 01414 01415 // add local surface load 01416 DLIList< RefFace* > faces; 01417 ( dynamic_cast< TopologyEntity* >( entity ) )->ref_faces( faces ); 01418 int n_face = faces.size(); 01419 faces.reset(); 01420 for( j = 0; j < n_face; j++ ) 01421 { 01422 RefFace* face = faces.get_and_step(); 01423 TopologyEntity* te = CAST_TO( face, TopologyEntity ); 01424 if( te->bridge_manager()->number_of_bridges() < 2 ) loads[proc] = loads[proc] + face->measure(); 01425 } 01426 01427 // Get all child entities 01428 DLIList< RefEntity* > child_list; 01429 RefEntity::get_all_child_ref_entities( body_entity_list, child_list ); 01430 int n_child = child_list.size(); 01431 01432 // assign processors to interface entities 01433 child_list.reset(); 01434 for( j = 0; j < n_child; j++ ) 01435 { 01436 entity = child_list.get_and_step(); 01437 TopologyEntity* te = CAST_TO( entity, TopologyEntity ); 01438 01439 if( te->bridge_manager()->number_of_bridges() > 1 ) 01440 { 01441 DLIList< Body* > parent_bodies; 01442 DLIList< int > child_shared_procs; // Shared processors of each child entity 01443 ( dynamic_cast< TopologyEntity* >( entity ) )->bodies( parent_bodies ); 01444 int n_parent = parent_bodies.size(); 01445 01446 for( k = 0; k < n_parent; k++ ) 01447 { 01448 RefEntity* parent_vol = CAST_TO( parent_bodies.get_and_step(), RefEntity ); 01449 TDParallel* parent_td = (TDParallel*)parent_vol->get_TD( &TDParallel::is_parallel ); 01450 01451 if( parent_td == NULL ) 01452 { 01453 PRINT_ERROR( "parent Volume has to be partitioned." ); 01454 delete[] loads; 01455 delete[] ve_loads; 01456 return MB_FAILURE; 01457 } 01458 child_shared_procs.append_unique( parent_td->get_charge_proc() ); 01459 } 01460 01461 if( child_shared_procs.size() > 1 ) 01462 { // if it is interface 01463 td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel ); 01464 if( td_par == NULL ) 01465 { 01466 int merge_id = TDUniqueId::get_unique_id( entity ); 01467 if( entity->entity_type_info() == typeid( RefFace ) ) 01468 { // face 01469 if( child_shared_procs.size() != 2 ) 01470 { 01471 PRINT_ERROR( "Error: # of shared processors of interface surface " 01472 "should be 2." ); 01473 delete[] loads; 01474 delete[] ve_loads; 01475 return MB_FAILURE; 01476 } 01477 01478 // balance interface surface loads 01479 if( loads[child_shared_procs[0]] > loads[child_shared_procs[1]] ) 01480 child_shared_procs.reverse(); 01481 01482 loads[child_shared_procs[0]] = loads[child_shared_procs[0]] + entity->measure(); 01483 td_par = new TDParallel( entity, NULL, &child_shared_procs, NULL, merge_id, 1 ); 01484 } // face 01485 else if( entity->entity_type_info() == typeid( RefEdge ) || 01486 entity->entity_type_info() == typeid( RefVertex ) ) 01487 { // edge or vertex 01488 // balance interface surface loads 01489 int min_p = child_shared_procs[0]; 01490 int n_shared_proc = child_shared_procs.size(); 01491 for( k = 1; k < n_shared_proc; k++ ) 01492 { 01493 if( ve_loads[child_shared_procs[k]] < ve_loads[min_p] ) min_p = child_shared_procs[k]; 01494 } 01495 ve_loads[min_p] = ve_loads[min_p] + entity->measure(); 01496 child_shared_procs.remove( min_p ); 01497 child_shared_procs.insert_first( min_p ); 01498 td_par = new TDParallel( entity, NULL, &child_shared_procs, NULL, merge_id, 1 ); 01499 } // edge or vertex 01500 } // if (td_par == NULL) 01501 } // if it is interface 01502 } // if (te->bridge_manager()->number_of_bridges() > 1) 01503 } // for (j = 0; j < n_child; j++) 01504 } // for (i = 0; i < n_entity; i++) 01505 01506 delete[] loads; 01507 delete[] ve_loads; 01508 01509 return MB_SUCCESS; 01510 } 01511 01512 // partition child entities to one of parent entity shared processors 01513 ErrorCode ZoltanPartitioner::partition_child_entities( const int dim, 01514 const int n_part, 01515 const bool part_surf, 01516 const bool ghost ) 01517 { 01518 DLIList< RefEntity* > entity_list; 01519 if( dim == 0 ) 01520 gti->ref_entity_list( "vertex", entity_list, CUBIT_FALSE ); 01521 else if( dim == 1 ) 01522 gti->ref_entity_list( "curve", entity_list, CUBIT_FALSE ); 01523 else 01524 { 01525 std::cerr << "Dimention should be from 0 to 1." << std::endl; 01526 return MB_FAILURE; 01527 } 01528 01529 int i, j, k; 01530 int n_entity = entity_list.size(); 01531 double* loads = new double[n_part]; 01532 for( i = 0; i < n_part; i++ ) 01533 loads[i] = 0.; 01534 entity_list.reset(); 01535 01536 for( i = 0; i < n_entity; i++ ) 01537 { // for all entities 01538 RefEntity* entity = entity_list.get_and_step(); 01539 TopologyEntity* te = CAST_TO( entity, TopologyEntity ); 01540 01541 if( !part_surf && te->bridge_manager()->number_of_bridges() < 2 ) continue; 01542 01543 DLIList< int > shared_procs; 01544 DLIList< Body* > parents; 01545 ( dynamic_cast< TopologyEntity* >( entity ) )->bodies( parents ); 01546 int n_parents = parents.size(); 01547 std::set< int > s_proc; 01548 parents.reset(); 01549 01550 // get shared processors from parent bodies 01551 for( j = 0; j < n_parents; j++ ) 01552 { 01553 RefEntity* parent = parents.get_and_step(); 01554 TDParallel* parent_td = (TDParallel*)parent->get_TD( &TDParallel::is_parallel ); 01555 01556 if( parent_td != NULL ) 01557 { 01558 DLIList< int >* parent_procs = parent_td->get_shared_proc_list(); 01559 int n_shared = parent_procs->size(); 01560 parent_procs->reset(); 01561 for( k = 0; k < n_shared; k++ ) 01562 { 01563 int p = parent_procs->get_and_step(); 01564 s_proc.insert( p ); 01565 } 01566 } 01567 } 01568 01569 if( part_surf ) 01570 { // also get shared procs from parent surfaces 01571 DLIList< RefFace* > parent_faces; 01572 ( dynamic_cast< TopologyEntity* >( entity ) )->ref_faces( parent_faces ); 01573 int n_pface = parent_faces.size(); 01574 parent_faces.reset(); 01575 01576 // get shared processors from parent faces 01577 for( j = 0; j < n_pface; j++ ) 01578 { 01579 RefEntity* parent = parent_faces.get_and_step(); 01580 TDParallel* parent_td = (TDParallel*)parent->get_TD( &TDParallel::is_parallel ); 01581 01582 if( parent_td != NULL ) 01583 { 01584 DLIList< int >* parent_procs = parent_td->get_shared_proc_list(); 01585 int n_shared = parent_procs->size(); 01586 parent_procs->reset(); 01587 01588 for( k = 0; k < n_shared; k++ ) 01589 { 01590 int p = parent_procs->get_and_step(); 01591 s_proc.insert( p ); 01592 } 01593 } 01594 } 01595 } 01596 01597 // find the minimum load processor and put it 01598 // at the front of the shared_procs list 01599 if( s_proc.size() > 1 ) 01600 { 01601 int min_proc = 0; 01602 double min_load = std::numeric_limits< double >::max(); 01603 std::set< int >::iterator iter = s_proc.begin(); 01604 std::set< int >::iterator end_iter = s_proc.end(); 01605 for( ; iter != end_iter; ++iter ) 01606 { 01607 if( loads[*iter] < min_load ) 01608 { 01609 min_load = loads[*iter]; 01610 min_proc = *iter; 01611 } 01612 } 01613 01614 if( dim == 1 ) 01615 loads[min_proc] += entity->measure(); 01616 else if( dim == 0 ) 01617 loads[min_proc] += 1.; 01618 shared_procs.append( min_proc ); 01619 iter = s_proc.begin(); 01620 end_iter = s_proc.end(); 01621 for( ; iter != end_iter; ++iter ) 01622 { 01623 if( *iter != min_proc ) 01624 { 01625 shared_procs.append( *iter ); 01626 } 01627 } 01628 01629 // add ghost geometries to shared processors for edge 01630 if( ghost ) 01631 { 01632 parents.reset(); 01633 for( j = 0; j < n_parents; j++ ) 01634 { // for all parent bodies 01635 RefEntity* parent_vol = CAST_TO( parents.get_and_step(), RefEntity ); 01636 TDParallel* parent_td = (TDParallel*)parent_vol->get_TD( &TDParallel::is_parallel ); 01637 int n_shared_proc = shared_procs.size(); 01638 01639 for( k = 0; k < n_shared_proc; k++ ) 01640 { 01641 parent_td->add_ghost_proc( shared_procs[k] ); 01642 } 01643 } 01644 } 01645 01646 // initialize tool data 01647 int merge_id = TDUniqueId::get_unique_id( entity ); 01648 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel ); 01649 if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs, NULL, merge_id, 1 ); 01650 } 01651 } 01652 01653 delete loads; 01654 return MB_SUCCESS; 01655 } 01656 #endif 01657 01658 ErrorCode ZoltanPartitioner::write_partition( const int nparts, 01659 Range& elems, 01660 const int* assignment, 01661 const bool write_as_sets, 01662 const bool write_as_tags ) 01663 { 01664 ErrorCode result; 01665 01666 // get the partition set tag 01667 Tag part_set_tag; 01668 int dum_id = -1, i; 01669 result = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag, 01670 MB_TAG_SPARSE | MB_TAG_CREAT, &dum_id );RR; 01671 01672 // get any sets already with this tag, and clear them 01673 Range tagged_sets; 01674 result = 01675 mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );RR; 01676 if( !tagged_sets.empty() ) 01677 { 01678 result = mbImpl->clear_meshset( tagged_sets );RR; 01679 if( !write_as_sets ) 01680 { 01681 result = mbImpl->tag_delete_data( part_set_tag, tagged_sets );RR; 01682 } 01683 } 01684 01685 if( write_as_sets ) 01686 { 01687 // first, create partition sets and store in vector 01688 partSets.clear(); 01689 01690 if( nparts > (int)tagged_sets.size() ) 01691 { 01692 // too few partition sets - create missing ones 01693 int num_new = nparts - tagged_sets.size(); 01694 for( i = 0; i < num_new; i++ ) 01695 { 01696 EntityHandle new_set; 01697 result = mbImpl->create_meshset( MESHSET_SET, new_set );RR; 01698 tagged_sets.insert( new_set ); 01699 } 01700 } 01701 else if( nparts < (int)tagged_sets.size() ) 01702 { 01703 // too many partition sets - delete extras 01704 int num_del = tagged_sets.size() - nparts; 01705 for( i = 0; i < num_del; i++ ) 01706 { 01707 EntityHandle old_set = tagged_sets.pop_back(); 01708 result = mbImpl->delete_entities( &old_set, 1 );RR; 01709 } 01710 } 01711 // assign partition sets to vector 01712 partSets.swap( tagged_sets ); 01713 01714 // write a tag to those sets denoting they're partition sets, with a value of the 01715 // proc number 01716 int* dum_ids = new int[nparts]; 01717 for( i = 0; i < nparts; i++ ) 01718 dum_ids[i] = i; 01719 01720 result = mbImpl->tag_set_data( part_set_tag, partSets, dum_ids );RR; 01721 // found out by valgrind when we run mbpart 01722 delete[] dum_ids; 01723 dum_ids = NULL; 01724 01725 // assign entities to the relevant sets 01726 std::vector< EntityHandle > tmp_part_sets; 01727 // int N = (int)elems.size(); 01728 std::copy( partSets.begin(), partSets.end(), std::back_inserter( tmp_part_sets ) ); 01729 /*Range::reverse_iterator riter; 01730 for (i = N-1, riter = elems.rbegin(); riter != elems.rend(); ++riter, i--) { 01731 int assigned_part = assignment[i]; 01732 part_ranges[assigned_part].insert(*riter); 01733 //result = mbImpl->add_entities(tmp_part_sets[assignment[i]], &(*rit), 1); RR; 01734 }*/ 01735 01736 Range::iterator rit; 01737 for( i = 0, rit = elems.begin(); rit != elems.end(); ++rit, i++ ) 01738 { 01739 result = mbImpl->add_entities( tmp_part_sets[assignment[i]], &( *rit ), 1 );RR; 01740 } 01741 /*for (i=0; i<nparts; i++) 01742 { 01743 result = mbImpl->add_entities(tmp_part_sets[i], part_ranges[i]); RR; 01744 } 01745 delete [] part_ranges;*/ 01746 // check for empty sets, warn if there are any 01747 Range empty_sets; 01748 for( rit = partSets.begin(); rit != partSets.end(); ++rit ) 01749 { 01750 int num_ents = 0; 01751 result = mbImpl->get_number_entities_by_handle( *rit, num_ents ); 01752 if( MB_SUCCESS != result || !num_ents ) empty_sets.insert( *rit ); 01753 } 01754 if( !empty_sets.empty() ) 01755 { 01756 std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: "; 01757 for( rit = empty_sets.begin(); rit != empty_sets.end(); ++rit ) 01758 std::cout << *rit << " "; 01759 std::cout << std::endl; 01760 } 01761 } 01762 01763 if( write_as_tags ) 01764 { 01765 // allocate integer-size partitions 01766 result = mbImpl->tag_set_data( part_set_tag, elems, assignment );RR; 01767 } 01768 01769 return MB_SUCCESS; 01770 } 01771 01772 void ZoltanPartitioner::SetRCB_Parameters( const bool recompute_rcb_box ) 01773 { 01774 if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Coordinate Bisection" << std::endl; 01775 // General parameters: 01776 01777 myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages 01778 myZZ->Set_Param( "LB_METHOD", "RCB" ); // recursive coordinate bisection 01779 // myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" ); // recompute RCB box if needed ? 01780 01781 // RCB parameters: 01782 01783 myZZ->Set_Param( "RCB_OUTPUT_LEVEL", "1" ); 01784 myZZ->Set_Param( "KEEP_CUTS", "1" ); // save decomposition so that we can infer partitions 01785 // myZZ->Set_Param("RCB_RECTILINEAR_BLOCKS", "1"); // don't split point on boundary 01786 if( recompute_rcb_box ) myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" ); 01787 } 01788 01789 void ZoltanPartitioner::SetRIB_Parameters() 01790 { 01791 if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Inertial Bisection" << std::endl; 01792 // General parameters: 01793 01794 myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages 01795 myZZ->Set_Param( "LB_METHOD", "RIB" ); // Recursive Inertial Bisection 01796 01797 // RIB parameters: 01798 01799 myZZ->Set_Param( "KEEP_CUTS", "1" ); // save decomposition 01800 myZZ->Set_Param( "AVERAGE_CUTS", "1" ); 01801 } 01802 01803 void ZoltanPartitioner::SetHSFC_Parameters() 01804 { 01805 if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHilbert Space Filling Curve" << std::endl; 01806 // General parameters: 01807 01808 myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages 01809 myZZ->Set_Param( "LB_METHOD", "HSFC" ); // perform Hilbert space filling curve 01810 01811 // HSFC parameters: 01812 01813 myZZ->Set_Param( "KEEP_CUTS", "1" ); // save decomposition 01814 } 01815 01816 void ZoltanPartitioner::SetHypergraph_Parameters( const char* phg_method ) 01817 { 01818 if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHypergraph (or PHG): " << std::endl; 01819 // General parameters: 01820 01821 myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages 01822 myZZ->Set_Param( "LB_METHOD", "Hypergraph" ); // Hypergraph (or PHG) 01823 01824 // Hypergraph (or PHG) parameters: 01825 myZZ->Set_Param( "PHG_COARSEPARTITION_METHOD", phg_method ); // CoarsePartitionMethod 01826 } 01827 01828 void ZoltanPartitioner::SetPARMETIS_Parameters( const char* parmetis_method ) 01829 { 01830 if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nPARMETIS: " << parmetis_method << std::endl; 01831 // General parameters: 01832 01833 myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages 01834 myZZ->Set_Param( "LB_METHOD", "PARMETIS" ); // the ParMETIS library 01835 01836 // PARMETIS parameters: 01837 01838 myZZ->Set_Param( "PARMETIS_METHOD", parmetis_method ); // method in the library 01839 } 01840 01841 void ZoltanPartitioner::SetOCTPART_Parameters( const char* oct_method ) 01842 { 01843 if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nOctree Partitioning: " << oct_method << std::endl; 01844 // General parameters: 01845 01846 myZZ->Set_Param( "DEBUG_LEVEL", "0" ); // no debug messages 01847 myZZ->Set_Param( "LB_METHOD", "OCTPART" ); // octree partitioning 01848 01849 // OCTPART parameters: 01850 01851 myZZ->Set_Param( "OCT_METHOD", oct_method ); // the SFC to be used 01852 myZZ->Set_Param( "OCT_OUTPUT_LEVEL", "3" ); 01853 } 01854 01855 int ZoltanPartitioner::mbInitializePoints( int npts, 01856 double* pts, 01857 int* ids, 01858 int* adjs, 01859 int* length, 01860 double* obj_weights, 01861 double* edge_weights, 01862 int* parts, 01863 bool part_geom ) 01864 { 01865 unsigned int i; 01866 int j; 01867 int *numPts, *nborProcs = NULL; 01868 int sum, ptsPerProc, ptsAssigned, mySize; 01869 MPI_Status stat; 01870 double* sendPts; 01871 int* sendIds; 01872 int* sendEdges = NULL; 01873 int* sendNborId = NULL; 01874 int* sendProcs; 01875 01876 if( mbpc->proc_config().proc_rank() == 0 ) 01877 { 01878 /* divide pts to start */ 01879 01880 numPts = (int*)malloc( sizeof( int ) * mbpc->proc_config().proc_size() ); 01881 ptsPerProc = npts / mbpc->proc_config().proc_size(); 01882 ptsAssigned = 0; 01883 01884 for( i = 0; i < mbpc->proc_config().proc_size() - 1; i++ ) 01885 { 01886 numPts[i] = ptsPerProc; 01887 ptsAssigned += ptsPerProc; 01888 } 01889 01890 numPts[mbpc->proc_config().proc_size() - 1] = npts - ptsAssigned; 01891 01892 mySize = numPts[mbpc->proc_config().proc_rank()]; 01893 sendPts = pts + ( 3 * numPts[0] ); 01894 sendIds = ids + numPts[0]; 01895 sum = 0; // possible no adjacency sent 01896 if( !part_geom ) 01897 { 01898 sendEdges = length + numPts[0]; 01899 01900 for( j = 0; j < numPts[0]; j++ ) 01901 sum += length[j]; 01902 01903 sendNborId = adjs + sum; 01904 01905 for( j = numPts[0]; j < npts; j++ ) 01906 sum += length[j]; 01907 01908 nborProcs = (int*)malloc( sizeof( int ) * sum ); 01909 } 01910 for( j = 0; j < sum; j++ ) 01911 if( ( i = adjs[j] / ptsPerProc ) < mbpc->proc_config().proc_size() ) 01912 nborProcs[j] = i; 01913 else 01914 nborProcs[j] = mbpc->proc_config().proc_size() - 1; 01915 01916 sendProcs = nborProcs + ( sendNborId - adjs ); 01917 01918 for( i = 1; i < mbpc->proc_config().proc_size(); i++ ) 01919 { 01920 MPI_Send( &numPts[i], 1, MPI_INT, i, 0x00, mbpc->comm() ); 01921 MPI_Send( sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01, mbpc->comm() ); 01922 MPI_Send( sendIds, numPts[i], MPI_INT, i, 0x03, mbpc->comm() ); 01923 MPI_Send( sendEdges, numPts[i], MPI_INT, i, 0x06, mbpc->comm() ); 01924 sum = 0; 01925 01926 for( j = 0; j < numPts[i]; j++ ) 01927 sum += sendEdges[j]; 01928 01929 MPI_Send( sendNborId, sum, MPI_INT, i, 0x07, mbpc->comm() ); 01930 MPI_Send( sendProcs, sum, MPI_INT, i, 0x08, mbpc->comm() ); 01931 sendPts += ( 3 * numPts[i] ); 01932 sendIds += numPts[i]; 01933 sendEdges += numPts[i]; 01934 sendNborId += sum; 01935 sendProcs += sum; 01936 } 01937 01938 free( numPts ); 01939 } 01940 else 01941 { 01942 MPI_Recv( &mySize, 1, MPI_INT, 0, 0x00, mbpc->comm(), &stat ); 01943 pts = (double*)malloc( sizeof( double ) * 3 * mySize ); 01944 ids = (int*)malloc( sizeof( int ) * mySize ); 01945 length = (int*)malloc( sizeof( int ) * mySize ); 01946 if( obj_weights != NULL ) obj_weights = (double*)malloc( sizeof( double ) * mySize ); 01947 MPI_Recv( pts, 3 * mySize, MPI_DOUBLE, 0, 0x01, mbpc->comm(), &stat ); 01948 MPI_Recv( ids, mySize, MPI_INT, 0, 0x03, mbpc->comm(), &stat ); 01949 MPI_Recv( length, mySize, MPI_INT, 0, 0x06, mbpc->comm(), &stat ); 01950 sum = 0; 01951 01952 for( j = 0; j < mySize; j++ ) 01953 sum += length[j]; 01954 01955 adjs = (int*)malloc( sizeof( int ) * sum ); 01956 if( edge_weights != NULL ) edge_weights = (double*)malloc( sizeof( double ) * sum ); 01957 nborProcs = (int*)malloc( sizeof( int ) * sum ); 01958 MPI_Recv( adjs, sum, MPI_INT, 0, 0x07, mbpc->comm(), &stat ); 01959 MPI_Recv( nborProcs, sum, MPI_INT, 0, 0x08, mbpc->comm(), &stat ); 01960 } 01961 01962 Points = pts; 01963 GlobalIds = ids; 01964 NumPoints = mySize; 01965 NumEdges = length; 01966 NborGlobalId = adjs; 01967 NborProcs = nborProcs; 01968 ObjWeights = obj_weights; 01969 EdgeWeights = edge_weights; 01970 Parts = parts; 01971 01972 return mySize; 01973 } 01974 01975 void ZoltanPartitioner::mbFinalizePoints( int npts, 01976 int numExport, 01977 ZOLTAN_ID_PTR exportLocalIDs, 01978 int* exportProcs, 01979 int** assignment ) 01980 { 01981 int* MyAssignment; 01982 int i; 01983 int numPts; 01984 MPI_Status stat; 01985 int* recvA; 01986 01987 /* assign pts to start */ 01988 01989 if( mbpc->proc_config().proc_rank() == 0 ) 01990 MyAssignment = (int*)malloc( sizeof( int ) * npts ); 01991 else 01992 MyAssignment = (int*)malloc( sizeof( int ) * NumPoints ); 01993 01994 for( i = 0; i < NumPoints; i++ ) 01995 MyAssignment[i] = mbpc->proc_config().proc_rank(); 01996 01997 for( i = 0; i < numExport; i++ ) 01998 MyAssignment[exportLocalIDs[i]] = exportProcs[i]; 01999 02000 if( mbpc->proc_config().proc_rank() == 0 ) 02001 { 02002 /* collect pts */ 02003 recvA = MyAssignment + NumPoints; 02004 02005 for( i = 1; i < (int)mbpc->proc_config().proc_size(); i++ ) 02006 { 02007 MPI_Recv( &numPts, 1, MPI_INT, i, 0x04, mbpc->comm(), &stat ); 02008 MPI_Recv( recvA, numPts, MPI_INT, i, 0x05, mbpc->comm(), &stat ); 02009 recvA += numPts; 02010 } 02011 02012 *assignment = MyAssignment; 02013 } 02014 else 02015 { 02016 MPI_Send( &NumPoints, 1, MPI_INT, 0, 0x04, mbpc->comm() ); 02017 MPI_Send( MyAssignment, NumPoints, MPI_INT, 0, 0x05, mbpc->comm() ); 02018 free( MyAssignment ); 02019 } 02020 } 02021 02022 int ZoltanPartitioner::mbGlobalSuccess( int rc ) 02023 { 02024 int fail = 0; 02025 unsigned int i; 02026 int* vals = (int*)malloc( mbpc->proc_config().proc_size() * sizeof( int ) ); 02027 02028 MPI_Allgather( &rc, 1, MPI_INT, vals, 1, MPI_INT, mbpc->comm() ); 02029 02030 for( i = 0; i < mbpc->proc_config().proc_size(); i++ ) 02031 { 02032 if( vals[i] != ZOLTAN_OK ) 02033 { 02034 if( 0 == mbpc->proc_config().proc_rank() ) 02035 { 02036 mbShowError( vals[i], "Result on process " ); 02037 } 02038 fail = 1; 02039 } 02040 } 02041 02042 free( vals ); 02043 return fail; 02044 } 02045 02046 void ZoltanPartitioner::mbPrintGlobalResult( const char* s, int begin, int import, int exp, int change ) 02047 { 02048 unsigned int i; 02049 int* v1 = (int*)malloc( 4 * sizeof( int ) ); 02050 int* v2 = NULL; 02051 int* v; 02052 02053 v1[0] = begin; 02054 v1[1] = import; 02055 v1[2] = exp; 02056 v1[3] = change; 02057 02058 if( mbpc->proc_config().proc_rank() == 0 ) 02059 { 02060 v2 = (int*)malloc( 4 * mbpc->proc_config().proc_size() * sizeof( int ) ); 02061 } 02062 02063 MPI_Gather( v1, 4, MPI_INT, v2, 4, MPI_INT, 0, mbpc->comm() ); 02064 02065 if( mbpc->proc_config().proc_rank() == 0 ) 02066 { 02067 fprintf( stdout, "======%s======\n", s ); 02068 for( i = 0, v = v2; i < mbpc->proc_config().proc_size(); i++, v += 4 ) 02069 { 02070 fprintf( stdout, "%u: originally had %d, import %d, exp %d, %s\n", i, v[0], v[1], v[2], 02071 v[3] ? "a change of partitioning" : "no change" ); 02072 } 02073 fprintf( stdout, "==========================================\n" ); 02074 fflush( stdout ); 02075 02076 free( v2 ); 02077 } 02078 02079 free( v1 ); 02080 } 02081 02082 void ZoltanPartitioner::mbShowError( int val, const char* s ) 02083 { 02084 if( s ) printf( "%s ", s ); 02085 02086 switch( val ) 02087 { 02088 case ZOLTAN_OK: 02089 printf( "%d: SUCCESSFUL\n", mbpc->proc_config().proc_rank() ); 02090 break; 02091 case ZOLTAN_WARN: 02092 printf( "%d: WARNING\n", mbpc->proc_config().proc_rank() ); 02093 break; 02094 case ZOLTAN_FATAL: 02095 printf( "%d: FATAL ERROR\n", mbpc->proc_config().proc_rank() ); 02096 break; 02097 case ZOLTAN_MEMERR: 02098 printf( "%d: MEMORY ALLOCATION ERROR\n", mbpc->proc_config().proc_rank() ); 02099 break; 02100 default: 02101 printf( "%d: INVALID RETURN CODE\n", mbpc->proc_config().proc_rank() ); 02102 break; 02103 } 02104 } 02105 02106 /********************** 02107 ** call backs 02108 **********************/ 02109 02110 int mbGetNumberOfAssignedObjects( void* /* userDefinedData */, int* err ) 02111 { 02112 *err = 0; 02113 return NumPoints; 02114 } 02115 02116 void mbGetObjectList( void* /* userDefinedData */, 02117 int /* numGlobalIds */, 02118 int /* numLids */, 02119 ZOLTAN_ID_PTR gids, 02120 ZOLTAN_ID_PTR lids, 02121 int wgt_dim, 02122 float* obj_wgts, 02123 int* err ) 02124 { 02125 for( int i = 0; i < NumPoints; i++ ) 02126 { 02127 gids[i] = GlobalIds[i]; 02128 lids[i] = i; 02129 if( wgt_dim > 0 ) obj_wgts[i] = ObjWeights[i]; 02130 } 02131 02132 *err = 0; 02133 } 02134 02135 int mbGetObjectSize( void* /* userDefinedData */, int* err ) 02136 { 02137 *err = 0; 02138 return 3; 02139 } 02140 02141 void mbGetObject( void* /* userDefinedData */, 02142 int /* numGlobalIds */, 02143 int /* numLids */, 02144 int numObjs, 02145 ZOLTAN_ID_PTR /* gids */, 02146 ZOLTAN_ID_PTR lids, 02147 int numDim, 02148 double* pts, 02149 int* err ) 02150 { 02151 int i, id, id3; 02152 int next = 0; 02153 02154 if( numDim != 3 ) 02155 { 02156 *err = 1; 02157 return; 02158 } 02159 02160 for( i = 0; i < numObjs; i++ ) 02161 { 02162 id = lids[i]; 02163 02164 if( ( id < 0 ) || ( id >= NumPoints ) ) 02165 { 02166 *err = 1; 02167 return; 02168 } 02169 02170 id3 = lids[i] * 3; 02171 02172 pts[next++] = Points[id3]; 02173 pts[next++] = Points[id3 + 1]; 02174 pts[next++] = Points[id3 + 2]; 02175 } 02176 } 02177 02178 void mbGetNumberOfEdges( void* /* userDefinedData */, 02179 int /* numGlobalIds */, 02180 int /* numLids */, 02181 int numObjs, 02182 ZOLTAN_ID_PTR /* gids */, 02183 ZOLTAN_ID_PTR lids, 02184 int* numEdges, 02185 int* err ) 02186 { 02187 int i, id; 02188 int next = 0; 02189 02190 for( i = 0; i < numObjs; i++ ) 02191 { 02192 id = lids[i]; 02193 02194 if( ( id < 0 ) || ( id >= NumPoints ) ) 02195 { 02196 *err = 1; 02197 return; 02198 } 02199 02200 numEdges[next++] = NumEdges[id]; 02201 } 02202 } 02203 02204 void mbGetEdgeList( void* /* userDefinedData */, 02205 int /* numGlobalIds */, 02206 int /* numLids */, 02207 int numObjs, 02208 ZOLTAN_ID_PTR /* gids */, 02209 ZOLTAN_ID_PTR lids, 02210 int* /* numEdges */, 02211 ZOLTAN_ID_PTR nborGlobalIds, 02212 int* nborProcs, 02213 int wgt_dim, 02214 float* edge_wgts, 02215 int* err ) 02216 { 02217 int i, id, idSum, j; 02218 int next = 0; 02219 02220 for( i = 0; i < numObjs; i++ ) 02221 { 02222 id = lids[i]; 02223 02224 if( ( id < 0 ) || ( id >= NumPoints ) ) 02225 { 02226 *err = 1; 02227 return; 02228 } 02229 02230 idSum = 0; 02231 02232 for( j = 0; j < id; j++ ) 02233 idSum += NumEdges[j]; 02234 02235 for( j = 0; j < NumEdges[id]; j++ ) 02236 { 02237 nborGlobalIds[next] = NborGlobalId[idSum]; 02238 nborProcs[next] = NborProcs[idSum]; 02239 if( wgt_dim > 0 ) edge_wgts[next] = EdgeWeights[idSum]; 02240 next++; 02241 idSum++; 02242 } 02243 } 02244 } 02245 02246 void mbGetPart( void* /* userDefinedData */, 02247 int /* numGlobalIds */, 02248 int /* numLids */, 02249 int numObjs, 02250 ZOLTAN_ID_PTR /* gids */, 02251 ZOLTAN_ID_PTR lids, 02252 int* part, 02253 int* err ) 02254 { 02255 int i, id; 02256 int next = 0; 02257 02258 for( i = 0; i < numObjs; i++ ) 02259 { 02260 id = lids[i]; 02261 02262 if( ( id < 0 ) || ( id >= NumPoints ) ) 02263 { 02264 *err = 1; 02265 return; 02266 } 02267 02268 part[next++] = Parts[id]; 02269 } 02270 } 02271 02272 // new methods for partition in parallel, used by migrate in iMOAB 02273 ErrorCode ZoltanPartitioner::partition_owned_cells( Range& primary, 02274 std::multimap< int, int >& extraGraphEdges, 02275 std::map< int, int > procs, 02276 int& numNewPartitions, 02277 std::map< int, Range >& distribution, 02278 int met ) 02279 { 02280 // start copy 02281 MeshTopoUtil mtu( mbImpl ); 02282 Range adjs; 02283 02284 std::vector< int > adjacencies; 02285 std::vector< int > ids; 02286 ids.resize( primary.size() ); 02287 std::vector< int > length; 02288 std::vector< double > coords; 02289 std::vector< int > nbor_proc; 02290 // can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited 02291 // by MBCN 02292 int neighbors[5 * MAX_SUB_ENTITIES]; 02293 int neib_proc[5 * MAX_SUB_ENTITIES]; 02294 double avg_position[3]; 02295 int moab_id; 02296 int primaryDim = mbImpl->dimension_from_handle( *primary.rbegin() ); 02297 // get the global id tag handle 02298 Tag gid = mbImpl->globalId_tag(); 02299 02300 ErrorCode rval = mbImpl->tag_get_data( gid, primary, &ids[0] );MB_CHK_ERR( rval ); 02301 02302 // mbpc is member in base class, PartitionerBase 02303 int rank = mbpc->rank(); // current rank , will be put on regular neighbors 02304 int i = 0; 02305 for( Range::iterator rit = primary.begin(); rit != primary.end(); ++rit, i++ ) 02306 { 02307 EntityHandle cell = *rit; 02308 // get bridge adjacencies for each cell 02309 if( 1 == met ) 02310 { 02311 adjs.clear(); 02312 rval = mtu.get_bridge_adjacencies( cell, ( primaryDim > 0 ? primaryDim - 1 : 3 ), primaryDim, adjs );MB_CHK_ERR( rval ); 02313 02314 // get the graph vertex ids of those 02315 if( !adjs.empty() ) 02316 { 02317 assert( adjs.size() < 5 * MAX_SUB_ENTITIES ); 02318 rval = mbImpl->tag_get_data( gid, adjs, neighbors );MB_CHK_ERR( rval ); 02319 } 02320 // if adjacent to neighbor partitions, add to the list 02321 int size_adjs = (int)adjs.size(); 02322 moab_id = ids[i]; 02323 for( int k = 0; k < size_adjs; k++ ) 02324 neib_proc[k] = rank; // current rank 02325 if( extraGraphEdges.find( moab_id ) != extraGraphEdges.end() ) 02326 { 02327 // it means that the current cell is adjacent to a cell in another partition ; maybe 02328 // a few 02329 std::pair< std::multimap< int, int >::iterator, std::multimap< int, int >::iterator > ret; 02330 ret = extraGraphEdges.equal_range( moab_id ); 02331 for( std::multimap< int, int >::iterator it = ret.first; it != ret.second; ++it ) 02332 { 02333 int otherID = it->second; 02334 neighbors[size_adjs] = otherID; // the id of the other cell, across partition 02335 neib_proc[size_adjs] = procs[otherID]; // this is how we built this map, the cell id maps to 02336 // what proc it came from 02337 size_adjs++; 02338 } 02339 } 02340 // copy those into adjacencies vector 02341 length.push_back( size_adjs ); 02342 std::copy( neighbors, neighbors + size_adjs, std::back_inserter( adjacencies ) ); 02343 std::copy( neib_proc, neib_proc + size_adjs, std::back_inserter( nbor_proc ) ); 02344 } 02345 else if( 2 == met ) 02346 { 02347 if( TYPE_FROM_HANDLE( cell ) == MBVERTEX ) 02348 { 02349 rval = mbImpl->get_coords( &cell, 1, avg_position );MB_CHK_ERR( rval ); 02350 } 02351 else 02352 { 02353 rval = mtu.get_average_position( cell, avg_position );MB_CHK_ERR( rval ); 02354 } 02355 std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) ); 02356 } 02357 } 02358 02359 #ifdef VERBOSE 02360 std::stringstream ff2; 02361 ff2 << "zoltanInput_" << mbpc->rank() << ".txt"; 02362 std::ofstream ofs; 02363 ofs.open( ff2.str().c_str(), std::ofstream::out ); 02364 ofs << "Length vector: " << std::endl; 02365 std::copy( length.begin(), length.end(), std::ostream_iterator< int >( ofs, ", " ) ); 02366 ofs << std::endl; 02367 ofs << "Adjacencies vector: " << std::endl; 02368 std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( ofs, ", " ) ); 02369 ofs << std::endl; 02370 ofs << "Moab_ids vector: " << std::endl; 02371 std::copy( ids.begin(), ids.end(), std::ostream_iterator< int >( ofs, ", " ) ); 02372 ofs << std::endl; 02373 ofs << "Coords vector: " << std::endl; 02374 std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( ofs, ", " ) ); 02375 ofs << std::endl; 02376 ofs.close(); 02377 #endif 02378 02379 // these are static var in this file, and used in the callbacks 02380 Points = NULL; 02381 if( 1 != met ) Points = &coords[0]; 02382 GlobalIds = &ids[0]; 02383 NumPoints = (int)ids.size(); 02384 NumEdges = &length[0]; 02385 NborGlobalId = &adjacencies[0]; 02386 NborProcs = &nbor_proc[0]; 02387 ObjWeights = NULL; 02388 EdgeWeights = NULL; 02389 Parts = NULL; 02390 02391 float version; 02392 if( mbpc->rank() == 0 ) std::cout << "Initializing zoltan..." << std::endl; 02393 02394 Zoltan_Initialize( argcArg, argvArg, &version ); 02395 02396 // Create Zoltan object. This calls Zoltan_Create. 02397 if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() ); 02398 02399 // set # requested partitions 02400 char buff[10]; 02401 sprintf( buff, "%d", numNewPartitions ); 02402 int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff ); 02403 if( ZOLTAN_OK != retval ) return MB_FAILURE; 02404 02405 // request parts assignment 02406 retval = myZZ->Set_Param( "RETURN_LISTS", "PARTS" ); 02407 if( ZOLTAN_OK != retval ) return MB_FAILURE; 02408 02409 myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL ); 02410 myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL ); 02411 // due to a bug in zoltan, if method is graph partitioning, do not pass coordinates!! 02412 if( 2 == met ) 02413 { 02414 myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL ); 02415 myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL ); 02416 SetRCB_Parameters(); // geometry 02417 } 02418 else if( 1 == met ) 02419 { 02420 myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL ); 02421 myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL ); 02422 SetHypergraph_Parameters( "auto" ); 02423 } 02424 02425 // Perform the load balancing partitioning 02426 02427 int changes; 02428 int numGidEntries; 02429 int numLidEntries; 02430 int num_import; 02431 ZOLTAN_ID_PTR import_global_ids, import_local_ids; 02432 int* import_procs; 02433 int* import_to_part; 02434 int num_export; 02435 ZOLTAN_ID_PTR export_global_ids, export_local_ids; 02436 int *assign_procs, *assign_parts; 02437 02438 if( mbpc->rank() == 0 ) 02439 std::cout << "Computing partition using method (1-graph, 2-geom):" << met << " for " << numNewPartitions 02440 << " parts..." << std::endl; 02441 02442 #ifndef NDEBUG 02443 #if 0 02444 static int counter=0; // it may be possible to call function multiple times in a simulation 02445 // give a way to not overwrite the files 02446 // it should work only with a modified version of Zoltan 02447 std::stringstream basename; 02448 if (1==met) 02449 { 02450 basename << "phg_" << counter++; 02451 Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 0, 1, 0); 02452 } 02453 else if (2==met) 02454 { 02455 basename << "rcb_" << counter++; 02456 Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 1, 0, 0); 02457 } 02458 #endif 02459 #endif 02460 retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids, import_local_ids, 02461 import_procs, import_to_part, num_export, export_global_ids, export_local_ids, 02462 assign_procs, assign_parts ); 02463 if( ZOLTAN_OK != retval ) return MB_FAILURE; 02464 02465 #ifdef VERBOSE 02466 std::stringstream ff3; 02467 ff3 << "zoltanOutput_" << mbpc->rank() << ".txt"; 02468 std::ofstream ofs3; 02469 ofs3.open( ff3.str().c_str(), std::ofstream::out ); 02470 ofs3 << " export elements on rank " << rank << " \n"; 02471 ofs3 << "\t index \t gb_id \t local \t proc \t part \n"; 02472 for( int k = 0; k < num_export; k++ ) 02473 { 02474 ofs3 << "\t" << k << "\t" << export_global_ids[k] << "\t" << export_local_ids[k] << "\t" << assign_procs[k] 02475 << "\t" << assign_parts[k] << "\n"; 02476 } 02477 ofs3.close(); 02478 #endif 02479 02480 // basically each local cell is assigned to a part 02481 02482 assert( num_export == (int)primary.size() ); 02483 for( i = 0; i < num_export; i++ ) 02484 { 02485 EntityHandle cell = primary[export_local_ids[i]]; 02486 distribution[assign_parts[i]].insert( cell ); 02487 } 02488 02489 Zoltan::LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part ); 02490 Zoltan::LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts ); 02491 02492 delete myZZ; 02493 myZZ = NULL; 02494 02495 // clear arrays that were resized locally, to free up local memory 02496 02497 std::vector< int >().swap( adjacencies ); 02498 std::vector< int >().swap( ids ); 02499 std::vector< int >().swap( length ); 02500 std::vector< int >().swap( nbor_proc ); 02501 std::vector< double >().swap( coords ); 02502 02503 return MB_SUCCESS; 02504 }
