MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for V_PyramidMetric.cpp:Go to the source code of this file.
Defines | |
| #define | VERDICT_EXPORTS |
Functions | |
| C_FUNC_DEF double | v_pyramid_volume (int num_nodes, double coordinates[][3]) |
| Calculates pyramid volume. | |
| C_FUNC_DEF void | v_pyramid_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, PyramidMetricVals *metric_vals) |
| Calculates quality metrics for pyramid elements. | |
| #define VERDICT_EXPORTS |
Definition at line 23 of file V_PyramidMetric.cpp.
| C_FUNC_DEF void v_pyramid_quality | ( | int | num_nodes, |
| double | coordinates[][3], | ||
| unsigned int | metrics_request_flag, | ||
| PyramidMetricVals * | metric_vals | ||
Definition at line 96 of file V_PyramidMetric.cpp.
References V_PYRAMID_VOLUME, v_pyramid_volume(), and PyramidMetricVals::volume.
memset( metric_vals, 0, sizeof( PyramidMetricVals ) );
if( metrics_request_flag & V_PYRAMID_VOLUME ) metric_vals->volume = v_pyramid_volume( num_nodes, coordinates );
| C_FUNC_DEF double v_pyramid_volume | ( | int | num_nodes, |
| double | coordinates[][3] | ||
the volume of a pyramid
the volume is calculated by dividing the pyramid into 2 tets and summing the volumes of the 2 tets.
Definition at line 59 of file V_PyramidMetric.cpp.
References VerdictVector::set().
Referenced by v_pyramid_quality().
double volume = 0;
VerdictVector side1, side2, side3;
if( num_nodes == 5 )
// divide the pyramid into 2 tets and calculate each
side1.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
coordinates[1][2] - coordinates[0][2] );
side2.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
coordinates[3][2] - coordinates[0][2] );
side3.set( coordinates[4][0] - coordinates[0][0], coordinates[4][1] - coordinates[0][1],
coordinates[4][2] - coordinates[0][2] );
// volume of the first tet
volume = ( side3 % ( side1 * side2 ) ) / 6.0;
side1.set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
coordinates[3][2] - coordinates[2][2] );
side2.set( coordinates[1][0] - coordinates[2][0], coordinates[1][1] - coordinates[2][1],
coordinates[1][2] - coordinates[2][2] );
side3.set( coordinates[4][0] - coordinates[2][0], coordinates[4][1] - coordinates[2][1],
coordinates[4][2] - coordinates[2][2] );
// volume of the second tet
volume += ( side3 % ( side1 * side2 ) ) / 6.0;
return (double)volume;
