MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for ExtractLand.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 22 of file ExtractLand.cpp.
References moab::Core::add_entities(), ProgOptions::addOpt(), moab::Range::begin(), moab::Core::create_meshset(), moab::Core::delete_entities(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::globalId_tag(), moab::Range::insert(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MESHSET_SET, outfile, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), moab::Core::tag_set_data(), and moab::Core::write_file().
ProgOptions opts;
std::string pg2file, lndfile, outfile;
opts.addOpt< std::string >( "land,l", "phys grid filename", &lndfile );
opts.addOpt< std::string >( "pg2file,p", "pg2 mesh file", &pg2file );
opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
opts.parseCommandLine( argc, argv );
std::cout << " land file " << lndfile << "\n";
std::cout << "pg2 mesh file: " << pg2file << "\n";
std::cout << "output file: " << outfile << "\n";
if( lndfile.empty() || pg2file.empty() || outfile.empty() )
opts.printHelp();
return 0;
ErrorCode rval;
Core* mb = new Core();
rval = mb->load_file( lndfile.c_str() );MB_CHK_SET_ERR( rval, "can't load land pc file" );
Core* mb2 = new Core();
rval = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" );
Tag globalIDTag1 = mb->globalId_tag();
Tag globalIDTag2 = mb2->globalId_tag();
Range verts1;
rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " );
Range cells;
rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " );
std::vector< int > globalIdsCells;
globalIdsCells.resize( cells.size() );
rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " );
std::vector< int > globalIdsVerts;
globalIdsVerts.resize( verts1.size() );
rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " );
// now, every cell will be put into one set, by looking at the global id of cell
std::map< int, EntityHandle > gidToCell;
int i = 0;
for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ )
gidToCell[globalIdsCells[i]] = *it;
// create a new file set with land cells
EntityHandle fileSet;
rval = mb2->create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" );
// empty all sets
Range landCells;
// look now at gid values for vertices
for( i = 0; i < (int)verts1.size(); i++ )
int gid = globalIdsVerts[i];
landCells.insert(gidToCell[gid]);
rval = mb2->add_entities(fileSet, landCells);;MB_CHK_SET_ERR( rval, "can't add land cells" );
rval = mb2->write_file( outfile.c_str(), 0, 0, &fileSet, 1 );MB_CHK_SET_ERR( rval, "can't write file" );
// write the original with mask 0/1, default -1
Tag mask;
double def_val=-1.;
rval = mb2->tag_get_handle( "mask", 1, MB_TYPE_DOUBLE, mask, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't create mask tag" );
EntityHandle cell = *it;
// set to 0
double val = 0.;
rval = mb2->tag_set_data(mask, &cell, 1, &val); MB_CHK_SET_ERR( rval, "can't set mask tag" );
for( Range::iterator it = landCells.begin(); it != landCells.end(); ++it, i++ )
// set to 0
double val = 1.;
rval = mb2->delete_entities(&fileSet, 1); MB_CHK_SET_ERR( rval, "can't delete set" );
rval = mb2->write_file( "AtmWithLandMask.h5m" );MB_CHK_SET_ERR( rval, "can't write file" );
delete mb;
delete mb2;
return 0;
