MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example ExtractLand.cpp 00002 * this tool will take an existing h5m pg2 mesh (fv) file and a land point cloud mesh 00003 * 00004 * will extract the corresponding land mesh 00005 * 00006 * example of usage: 00007 * ./ExtractLand -p wholeATM_PG2.h5m -l wholeLnd.h5m -o LandMesh.h5m 00008 * 00009 * the *PG2" style atm mesh is available in E3SM only for pg2 runs, something like 00010 * --res ne30pg2_r05_oECv3_ICG --compset A_WCYCL1850S_CMIP6 00011 * or 00012 * --res ne4pg2_ne4pg2 --compset FC5AV1C-L 00013 */ 00014 #include "moab/ProgOptions.hpp" 00015 #include "moab/Core.hpp" 00016 00017 #include <cmath> 00018 #include <sstream> 00019 00020 using namespace moab; 00021 00022 int main( int argc, char* argv[] ) 00023 { 00024 00025 ProgOptions opts; 00026 00027 std::string pg2file, lndfile, outfile; 00028 00029 opts.addOpt< std::string >( "land,l", "phys grid filename", &lndfile ); 00030 opts.addOpt< std::string >( "pg2file,p", "pg2 mesh file", &pg2file ); 00031 opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile ); 00032 00033 opts.parseCommandLine( argc, argv ); 00034 00035 std::cout << " land file " << lndfile << "\n"; 00036 std::cout << "pg2 mesh file: " << pg2file << "\n"; 00037 std::cout << "output file: " << outfile << "\n"; 00038 00039 if( lndfile.empty() || pg2file.empty() || outfile.empty() ) 00040 { 00041 opts.printHelp(); 00042 return 0; 00043 } 00044 ErrorCode rval; 00045 Core* mb = new Core(); 00046 00047 rval = mb->load_file( lndfile.c_str() );MB_CHK_SET_ERR( rval, "can't load land pc file" ); 00048 00049 Core* mb2 = new Core(); 00050 rval = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" ); 00051 00052 Tag globalIDTag1 = mb->globalId_tag(); 00053 00054 Tag globalIDTag2 = mb2->globalId_tag(); 00055 00056 Range verts1; 00057 rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " ); 00058 00059 Range cells; 00060 rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " ); 00061 00062 std::vector< int > globalIdsCells; 00063 globalIdsCells.resize( cells.size() ); 00064 rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); 00065 00066 std::vector< int > globalIdsVerts; 00067 globalIdsVerts.resize( verts1.size() ); 00068 rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); 00069 00070 // now, every cell will be put into one set, by looking at the global id of cell 00071 00072 std::map< int, EntityHandle > gidToCell; 00073 int i = 0; 00074 for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ ) 00075 { 00076 gidToCell[globalIdsCells[i]] = *it; 00077 } 00078 // create a new file set with land cells 00079 EntityHandle fileSet; 00080 rval = mb2->create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" ); 00081 // empty all sets 00082 00083 Range landCells; 00084 // look now at gid values for vertices 00085 for( i = 0; i < (int)verts1.size(); i++ ) 00086 { 00087 int gid = globalIdsVerts[i]; 00088 landCells.insert(gidToCell[gid]); 00089 } 00090 00091 rval = mb2->add_entities(fileSet, landCells);;MB_CHK_SET_ERR( rval, "can't add land cells" ); 00092 00093 rval = mb2->write_file( outfile.c_str(), 0, 0, &fileSet, 1 );MB_CHK_SET_ERR( rval, "can't write file" ); 00094 00095 // write the original with mask 0/1, default -1 00096 Tag mask; 00097 double def_val=-1.; 00098 rval = mb2->tag_get_handle( "mask", 1, MB_TYPE_DOUBLE, mask, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't create mask tag" ); 00099 for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ ) 00100 { 00101 EntityHandle cell = *it; 00102 // set to 0 00103 double val = 0.; 00104 rval = mb2->tag_set_data(mask, &cell, 1, &val); MB_CHK_SET_ERR( rval, "can't set mask tag" ); 00105 } 00106 00107 for( Range::iterator it = landCells.begin(); it != landCells.end(); ++it, i++ ) 00108 { 00109 EntityHandle cell = *it; 00110 // set to 0 00111 double val = 1.; 00112 rval = mb2->tag_set_data(mask, &cell, 1, &val); MB_CHK_SET_ERR( rval, "can't set mask tag" ); 00113 } 00114 rval = mb2->delete_entities(&fileSet, 1); MB_CHK_SET_ERR( rval, "can't delete set" ); 00115 rval = mb2->write_file( "AtmWithLandMask.h5m" );MB_CHK_SET_ERR( rval, "can't write file" ); 00116 delete mb; 00117 delete mb2; 00118 00119 return 0; 00120 }
