file-handle.h File Reference
#include "mhdf.h"
+ Include dependency graph for file-handle.h:
+ This graph shows which files directly or indirectly include this file:
Classes
struct  struct_FileHandle
Typedefs
typedef struct struct_FileHandle FileHandle
Functions
FileHandle * mhdf_alloc_FileHandle (hid_t hdf_handle, hid_t id_type, mhdf_Status *status)
int mhdf_check_valid_file (FileHandle *handle, mhdf_Status *status)
Typedef Documentation
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Function Documentation
FileHandle* mhdf_alloc_FileHandle ( hid_t  hdf_handle,
hid_t  id_type,
mhdf_Status *  status
Definition at line 43 of file file-handle.c.
References FILE_HANDLE_MAGIC, struct_FileHandle::hdf_handle, struct_FileHandle::id_type, struct_FileHandle::magic, struct_FileHandle::max_id, mhdf_malloc(), mhdf_setFail(), and struct_FileHandle::open_handle_count.
Referenced by mhdf_createFile(), and mhdf_openFileWithOpt().
    FileHandle* rval;
    /* check that id_type is sane */
    if( id_type == -1 )
        id_type = H5T_NATIVE_ULONG;
    else if( H5T_INTEGER != H5Tget_class( id_type ) )
        mhdf_setFail( status, "Invalid ID type: not integer class" );
        return 0;
    rval = (FileHandle*)mhdf_malloc( sizeof( FileHandle ), status );
    if( !rval ) return NULL;
    rval->magic             = FILE_HANDLE_MAGIC;
    rval->hdf_handle        = hdf_table;
    rval->open_handle_count = 0;
    rval->id_type           = id_type;
    rval->max_id            = 0L;
    return rval;
