MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include <H5Tpublic.h> 00017 #include <H5Gpublic.h> 00018 #include <H5Ppublic.h> 00019 #include "mhdf.h" 00020 #include "util.h" 00021 #include "file-handle.h" 00022 #include "status.h" 00023 #include "names-and-paths.h" 00024 00025 int mhdf_haveAdjacency( mhdf_FileHandle file, const char* elem_group, mhdf_Status* status ) 00026 { 00027 FileHandle* file_ptr; 00028 hid_t elem_id; 00029 int result; 00030 API_BEGIN; 00031 00032 file_ptr = (FileHandle*)( file ); 00033 if( !mhdf_check_valid_file( file_ptr, status ) ) return -1; 00034 00035 if( elem_group == mhdf_node_type_handle() ) 00036 { 00037 #if defined( H5Gopen_vers ) && H5Gopen_vers > 1 00038 elem_id = H5Gopen( file_ptr->hdf_handle, NODE_GROUP, H5P_DEFAULT ); 00039 #else 00040 elem_id = H5Gopen( file_ptr->hdf_handle, NODE_GROUP ); 00041 #endif 00042 if( elem_id < 0 ) 00043 { 00044 mhdf_setFail( status, "H5Gopen( \"%s\" ) failed.\n", NODE_GROUP ); 00045 return -1; 00046 } 00047 } 00048 else 00049 { 00050 elem_id = mhdf_elem_group_from_handle( file_ptr, elem_group, status ); 00051 if( elem_id < 0 ) return -1; 00052 } 00053 00054 result = mhdf_is_in_group( elem_id, ADJACENCY_NAME, status ); 00055 H5Gclose( elem_id ); 00056 mhdf_setOkay( status ); 00057 API_END; 00058 return result; 00059 } 00060 00061 hid_t mhdf_createAdjacency( mhdf_FileHandle file, const char* elem_handle, long adj_list_size, mhdf_Status* status ) 00062 { 00063 FileHandle* file_ptr; 00064 hid_t elem_id, table_id; 00065 hsize_t dim = (hsize_t)adj_list_size; 00066 API_BEGIN; 00067 00068 file_ptr = (FileHandle*)( file ); 00069 if( !mhdf_check_valid_file( file_ptr, status ) ) return -1; 00070 00071 if( adj_list_size < 1 ) 00072 { 00073 mhdf_setFail( status, "Invalid argument.\n" ); 00074 return -1; 00075 } 00076 00077 if( elem_handle == mhdf_node_type_handle() ) 00078 { 00079 table_id = mhdf_create_table( file_ptr->hdf_handle, NODE_ADJCY_PATH, file_ptr->id_type, 1, &dim, status ); 00080 } 00081 else 00082 { 00083 elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status ); 00084 if( elem_id < 0 ) return -1; 00085 00086 table_id = mhdf_create_table( elem_id, ADJACENCY_NAME, file_ptr->id_type, 1, &dim, status ); 00087 H5Gclose( elem_id ); 00088 } 00089 00090 API_END_H( 1 ); 00091 return table_id; 00092 } 00093 00094 hid_t mhdf_openAdjacency( mhdf_FileHandle file, const char* elem_handle, long* adj_list_size_out, mhdf_Status* status ) 00095 00096 { 00097 FileHandle* file_ptr; 00098 hid_t elem_id, table_id; 00099 hsize_t dim; 00100 API_BEGIN; 00101 00102 file_ptr = (FileHandle*)( file ); 00103 if( !mhdf_check_valid_file( file_ptr, status ) ) return -1; 00104 00105 if( !adj_list_size_out ) 00106 { 00107 mhdf_setFail( status, "Invalid argument.\n" ); 00108 return -1; 00109 } 00110 00111 if( elem_handle == mhdf_node_type_handle() ) 00112 { 00113 table_id = mhdf_open_table( file_ptr->hdf_handle, NODE_ADJCY_PATH, 1, &dim, status ); 00114 } 00115 else 00116 { 00117 elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status ); 00118 if( elem_id < 0 ) return -1; 00119 table_id = mhdf_open_table( elem_id, ADJACENCY_NAME, 1, &dim, status ); 00120 H5Gclose( elem_id ); 00121 } 00122 00123 *adj_list_size_out = (long)dim; 00124 API_END_H( 1 ); 00125 return table_id; 00126 } 00127 00128 void mhdf_writeAdjacency( hid_t table_id, long offset, long count, hid_t type, const void* data, mhdf_Status* status ) 00129 { 00130 API_BEGIN; 00131 mhdf_write_data( table_id, offset, count, type, data, H5P_DEFAULT, status ); 00132 API_END; 00133 } 00134 00135 void mhdf_writeAdjacencyWithOpt( hid_t table_id, 00136 long offset, 00137 long count, 00138 hid_t type, 00139 const void* data, 00140 hid_t prop, 00141 mhdf_Status* status ) 00142 { 00143 API_BEGIN; 00144 mhdf_write_data( table_id, offset, count, type, data, prop, status ); 00145 API_END; 00146 } 00147 00148 void mhdf_readAdjacency( hid_t table_id, long offset, long count, hid_t type, void* data, mhdf_Status* status ) 00149 { 00150 API_BEGIN; 00151 mhdf_read_data( table_id, offset, count, type, data, H5P_DEFAULT, status ); 00152 API_END; 00153 } 00154 void mhdf_readAdjacencyWithOpt( hid_t table_id, 00155 long offset, 00156 long count, 00157 hid_t type, 00158 void* data, 00159 hid_t prop, 00160 mhdf_Status* status ) 00161 { 00162 API_BEGIN; 00163 mhdf_read_data( table_id, offset, count, type, data, prop, status ); 00164 API_END; 00165 }
