MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <sstream>#include <ctime>#include <cstdlib>#include <cstdio>#include <cstring>#include "moab/Types.hpp"#include "moab/IntxMesh/IntxUtils.hpp"#include "TestUtil.hpp"
Include dependency graph for arc_intx_tests.cpp:Go to the source code of this file.
Functions | |
| void | test_great_arc_intx () |
| void | test_great_arc_clat_intx () |
| int | main () |
| int main | ( | ) |
Definition at line 47 of file arc_intx_tests.cpp.
References RUN_TEST, test_great_arc_clat_intx(), and test_great_arc_intx().
int failures = 0;
failures += RUN_TEST( test_great_arc_intx );
failures += RUN_TEST( test_great_arc_clat_intx );
return failures;
| void test_great_arc_clat_intx | ( | ) |
Definition at line 30 of file arc_intx_tests.cpp.
References CHECK, CHECK_ERR, moab::E, ErrorCode, moab::F, moab::IntxUtils::intersect_great_circle_arc_with_clat_arc(), np, and moab::R.
Referenced by main().
double d3 = 1 / sqrt( 3. );
double A[3] = { 0., 0., 1. };
double B[3] = { 1., 0., 0. };
double C[3] = { d3, d3, d3 };
double D[3] = { d3, -d3, d3 };
double E[9];
double R = 1.0;
int np = 0;
ErrorCode rval = moab::IntxUtils::intersect_great_circle_arc_with_clat_arc( A, B, C, D, R, E, np );CHECK_ERR( rval );
std::cout << "E: " << E[0] << " " << E[1] << " " << E[2] << "\n";
double F[3] = { -d3, d3, d3 };
rval = moab::IntxUtils::intersect_great_circle_arc_with_clat_arc( A, B, C, F, R, E, np );
CHECK( rval == MB_FAILURE );
| void test_great_arc_intx | ( | ) |
Definition at line 16 of file arc_intx_tests.cpp.
References CHECK, CHECK_ERR, moab::E, ErrorCode, moab::IntxUtils::intersect_great_circle_arcs(), and moab::R.
double C[3] = { 0., 0.6, 0.8 };
double D[3] = { 0.6, -0.8, 0. };
double E[3];
double R = 1.0;
ErrorCode rval = moab::IntxUtils::intersect_great_circle_arcs( A, B, C, D, R, E );CHECK_ERR( rval );
rval = moab::IntxUtils::intersect_great_circle_arcs( A, C, B, D, R, E );
