MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <vector>#include <sstream>#include <string>#include "moab/Core.hpp"#include "MBTagConventions.hpp"#include "moab/FileOptions.hpp"
Include dependency graph for VisTags.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 42 of file VisTags.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::FileOptions::get_strs_option(), levels, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MESH_DIR, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_iterate(), and moab::Interface::write_file().
#ifdef MOAB_HAVE_NETCDF
#ifdef MOAB_HAVE_MPI
MPI_Init( &argc, &argv );
#endif
ErrorCode rval;
string file_input, file_output;
string read_opts, tags; // Tags to write, separated by commas; it is the name of the tag
if( argc < 2 )
file_input = string( MESH_DIR ) + string( "/io/gcrm_r3.nc" );
file_output = "VisTagsOut.vtk";
else
file_input = argv[1];
file_output = argv[2];
read_opts = "";
tags = "";
// Instantiate
Interface* mb = new( std::nothrow ) Core;
if( NULL == mb ) return 1;
int dimension = 2;
// In MOAB, it may have index after reading (T0, T1, etc)
char* levels = NULL; // Levels, separated by commas, no spaces (like 0, 1, 19)
if( argc > 3 )
int index = 3;
while( index < argc )
if( !strcmp( argv[index], "-O" ) ) // This is for reading options, optional
read_opts = argv[++index];
if( !strcmp( argv[index], "-t" ) ) tags = argv[++index];
if( !strcmp( argv[index], "-l" ) ) levels = argv[++index];
if( !strcmp( argv[index], "-d" ) ) dimension = atoi( argv[++index] );
index++;
ostringstream opts;
opts << ";;TAGS=" << tags << ";LEVELS=" << levels << "\0";
FileOptions fo( opts.str().c_str() );
vector< string > tagsNames;
vector< int > levelsArray;
fo.get_strs_option( "TAGS", tagsNames );
fo.get_ints_option( "LEVELS", levelsArray );
// Load the input file with the specified options
rval = mb->load_file( file_input.c_str(), 0, read_opts.c_str() );MB_CHK_SET_ERR( rval, "not loading file" );
Range ents;
rval = mb->get_entities_by_dimension( 0, dimension, ents );MB_CHK_SET_ERR( rval, "not getting ents" );
// Now create double tags for entities of dimension
for( size_t i = 0; i < tagsNames.size(); i++ )
string tagName = tagsNames[i];
Tag tagh;
rval = mb->tag_get_handle( tagName.c_str(), tagh );
if( MB_SUCCESS != rval )
cout << "not getting tag " << tagName.c_str() << "\n";
continue;
int len = 0;
rval = mb->tag_get_length( tagh, len );
cout << "not getting tag len " << tagName.c_str() << "\n";
continue;
DataType type;
rval = mb->tag_get_data_type( tagh, type );
cout << "not getting tag type " << tagName.c_str() << "\n";
continue;
int count;
void* dataptr; // Assume double tags, for simplicity
rval = mb->tag_iterate( tagh, ents.begin(), ents.end(), count, dataptr );
if( MB_SUCCESS != rval || count != (int)ents.size() )
cout << "not getting tag iterate right " << tagName.c_str() << "\n";
continue;
// Now create a new tag, with a new name, concatenated, and copy data there , for each level
for( size_t j = 0; j < levelsArray.size(); j++ )
int level = levelsArray[j];
if( level >= len )
cout << "level too big at " << level << "\n";
continue;
ostringstream newTagName;
newTagName << tagName << "_" << level;
Tag newTagh;
rval = mb->tag_get_handle( newTagName.str().c_str(), 1, type, newTagh, MB_TAG_DENSE | MB_TAG_CREAT );
cout << "not getting new tag " << newTagName.str() << "\n";
continue;
void* newDataPtr;
rval = mb->tag_iterate( newTagh, ents.begin(), ents.end(), count, newDataPtr );
cout << "not getting new tag iterate " << newTagName.str() << "\n";
continue;
if( MB_TYPE_DOUBLE == type )
double* ptrD = (double*)newDataPtr;
double* oldData = (double*)dataptr;
for( int k = 0; k < count; k++, ptrD++ )
*ptrD = oldData[level + count * k];
} // for (size_t j = 0; j < levelsArray.size(); j++)
mb->tag_delete( tagh ); // No need for the tag anymore, write it to the new file
} // for (size_t i = 0; i < tagsNames.size(); i++)
rval = mb->write_file( file_output.c_str() );MB_CHK_SET_ERR( rval, "Can't write file " << file_output );
cout << "Successfully wrote file " << file_output << "\n";
delete mb;
MPI_Finalize();
#endif
#else
std::cout << " configure with netcdf for this example to work\n";
#endif
return 0;
