MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 00004 using namespace moab; 00005 00006 std::string example_eul = TestDir + "unittest/io/eul3x48x96.t.3.nc"; 00007 std::string example_fv = TestDir + "unittest/io/fv3x46x72.t.3.nc"; 00008 std::string example_domain = TestDir + "unittest/io/domain.ocn.ne4np4_oQU240.160614.nc"; 00009 std::string example_scrip = TestDir + "unittest/io/ocean.QU.240km.scrip.151209.nc"; 00010 00011 #ifdef MOAB_HAVE_MPI 00012 #include "moab_mpi.h" 00013 #include "moab/ParallelComm.hpp" 00014 #endif 00015 00016 // CAM-EUL 00017 void test_read_eul_all(); 00018 void test_read_eul_onevar(); 00019 void test_read_eul_onetimestep(); 00020 void test_read_eul_nomesh(); 00021 void test_read_eul_novars(); 00022 00023 // CAM-FV 00024 void test_read_fv_all(); 00025 void test_read_fv_onevar(); 00026 void test_read_fv_onetimestep(); 00027 void test_read_fv_nomesh(); 00028 void test_read_fv_novars(); 00029 #ifdef MOAB_HAVE_MPI 00030 void test_read_fv_ghosting(); 00031 #endif 00032 00033 // Domain file 00034 void test_read_domain(); 00035 // scrip file 00036 void test_read_scrip(); 00037 00038 ErrorCode get_options( std::string& opts ); 00039 00040 const int levels = 3; 00041 00042 int main( int argc, char* argv[] ) 00043 { 00044 int result = 0; 00045 00046 #ifdef MOAB_HAVE_MPI 00047 int fail = MPI_Init( &argc, &argv ); 00048 if( fail ) return 1; 00049 #else 00050 argv[0] = argv[argc - argc]; // To remove the warnings in serial mode about unused variables 00051 #endif 00052 00053 result += RUN_TEST( test_read_eul_all ); 00054 result += RUN_TEST( test_read_eul_onevar ); 00055 result += RUN_TEST( test_read_eul_onetimestep ); 00056 result += RUN_TEST( test_read_eul_nomesh ); 00057 result += RUN_TEST( test_read_eul_novars ); 00058 result += RUN_TEST( test_read_domain ); 00059 result += RUN_TEST( test_read_scrip ); 00060 // Exclude test_read_fv_all() since reading edge data is not implemented in MOAB yet 00061 // result += RUN_TEST(test_read_fv_all); 00062 result += RUN_TEST( test_read_fv_onevar ); 00063 result += RUN_TEST( test_read_fv_onetimestep ); 00064 result += RUN_TEST( test_read_fv_nomesh ); 00065 result += RUN_TEST( test_read_fv_novars ); 00066 00067 #ifdef MOAB_HAVE_MPI 00068 // Before ghosting issues with ownership were fixed, this test failed on 4 processors 00069 result += RUN_TEST( test_read_fv_ghosting ); 00070 #endif 00071 00072 #ifdef MOAB_HAVE_MPI 00073 fail = MPI_Finalize(); 00074 if( fail ) return 1; 00075 #endif 00076 00077 return result; 00078 } 00079 00080 void test_read_eul_all() 00081 { 00082 Core moab; 00083 Interface& mb = moab; 00084 00085 std::string opts; 00086 ErrorCode rval = get_options( opts );CHECK_ERR( rval ); 00087 00088 rval = mb.load_file( example_eul.c_str(), NULL, opts.c_str() );CHECK_ERR( rval ); 00089 00090 // Check for proper tags 00091 Tag Ttag0, Ttag1, coordTag; 00092 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00093 00094 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00095 00096 rval = mb.tag_get_handle( "COORDS", 3, MB_TYPE_DOUBLE, coordTag );CHECK_ERR( rval ); 00097 00098 // Check for some tags with double underscore in the tag name 00099 Tag tempTag; 00100 rval = mb.tag_get_handle( "__lon_LOC_MINMAX", 2, MB_TYPE_INTEGER, tempTag );CHECK_ERR( rval ); 00101 00102 rval = mb.tag_get_handle( "__lon_LOC_VALS", 0, MB_TYPE_DOUBLE, tempTag, MB_TAG_VARLEN );CHECK_ERR( rval ); 00103 00104 rval = mb.tag_get_handle( "__lon_GLOBAL_MINMAX", 2, MB_TYPE_INTEGER, tempTag );CHECK_ERR( rval ); 00105 } 00106 00107 void test_read_eul_onevar() 00108 { 00109 Core moab; 00110 Interface& mb = moab; 00111 std::string opts; 00112 ErrorCode rval = get_options( opts );CHECK_ERR( rval ); 00113 00114 opts += std::string( ";VARIABLE=T" ); 00115 rval = mb.load_file( example_eul.c_str(), NULL, opts.c_str() );CHECK_ERR( rval ); 00116 00117 // Check for proper tags 00118 Tag Ttag0, Ttag1; 00119 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00120 00121 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00122 00123 // Check values of tag T0 (first level) at some strategically chosen places below 00124 #ifdef MOAB_HAVE_MPI 00125 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00126 int rank = pcomm->proc_config().proc_rank(); 00127 int procs = pcomm->proc_config().proc_size(); 00128 #else 00129 int rank = 0; 00130 int procs = 1; 00131 #endif 00132 00133 const double eps = 0.0001; 00134 double val[8 * levels]; 00135 00136 if( 1 == procs ) 00137 { 00138 Range global_quads; 00139 rval = mb.get_entities_by_type( 0, MBQUAD, global_quads );CHECK_ERR( rval ); 00140 CHECK_EQUAL( (size_t)4608, global_quads.size() ); 00141 00142 EntityHandle gloabl_quad_ents[] = { global_quads[0], global_quads[2255], global_quads[2304], 00143 global_quads[4559], global_quads[48], global_quads[2303], 00144 global_quads[2352], global_quads[4607] }; 00145 rval = mb.tag_get_data( Ttag0, &gloabl_quad_ents[0], 8, val ); 00146 00147 CHECK_REAL_EQUAL( 252.8529, val[0 * levels], eps ); // First global quad 00148 CHECK_REAL_EQUAL( 234.8390, val[1 * levels], eps ); // 2256th global quad 00149 CHECK_REAL_EQUAL( 232.6458, val[2 * levels], eps ); // 2305th global quad 00150 CHECK_REAL_EQUAL( 205.3905, val[3 * levels], eps ); // 4560th global quad 00151 CHECK_REAL_EQUAL( 252.7116, val[4 * levels], eps ); // 49th global quad 00152 CHECK_REAL_EQUAL( 232.6670, val[5 * levels], eps ); // 2304th global quad 00153 CHECK_REAL_EQUAL( 234.6922, val[6 * levels], eps ); // 2353th global quad 00154 CHECK_REAL_EQUAL( 200.6828, val[7 * levels], eps ); // Last global quad 00155 } 00156 else if( 2 == procs ) 00157 { 00158 Range local_quads; 00159 rval = mb.get_entities_by_type( 0, MBQUAD, local_quads );CHECK_ERR( rval ); 00160 CHECK_EQUAL( (size_t)2304, local_quads.size() ); 00161 00162 EntityHandle local_quad_ents[] = { local_quads[0], local_quads[1151], local_quads[1152], local_quads[2303] }; 00163 rval = mb.tag_get_data( Ttag0, &local_quad_ents[0], 4, val ); 00164 00165 if( 0 == rank ) 00166 { 00167 CHECK_REAL_EQUAL( 252.8529, val[0 * levels], 00168 eps ); // First local quad, first global quad 00169 CHECK_REAL_EQUAL( 234.8390, val[1 * levels], 00170 eps ); // Median local quad, 2256th global quad 00171 CHECK_REAL_EQUAL( 232.6458, val[2 * levels], 00172 eps ); // Median local quad, 2305th global quad 00173 CHECK_REAL_EQUAL( 205.3905, val[3 * levels], 00174 eps ); // Last local quad, 4560th global quad 00175 } 00176 else if( 1 == rank ) 00177 { 00178 CHECK_REAL_EQUAL( 252.7116, val[0 * levels], 00179 eps ); // First local quad, 49th global quad 00180 CHECK_REAL_EQUAL( 232.6670, val[1 * levels], 00181 eps ); // Median local quad, 2304th global quad 00182 CHECK_REAL_EQUAL( 234.6922, val[2 * levels], 00183 eps ); // Median local quad, 2353th global quad 00184 CHECK_REAL_EQUAL( 200.6828, val[3 * levels], 00185 eps ); // Last local quad, last global quad 00186 } 00187 } 00188 } 00189 00190 void test_read_eul_onetimestep() 00191 { 00192 Core moab; 00193 Interface& mb = moab; 00194 std::string opts; 00195 ErrorCode rval = get_options( opts );CHECK_ERR( rval ); 00196 00197 opts += std::string( ";VARIABLE=T;TIMESTEP=1" ); 00198 rval = mb.load_file( example_eul.c_str(), NULL, opts.c_str() );CHECK_ERR( rval ); 00199 00200 // Check for proper tags 00201 Tag Ttag0, Ttag1; 00202 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 ); 00203 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00204 00205 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00206 } 00207 00208 void test_read_eul_nomesh() 00209 { 00210 Core moab; 00211 Interface& mb = moab; 00212 00213 // Need a set for nomesh to work right 00214 EntityHandle set; 00215 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00216 00217 std::string orig, opts; 00218 rval = get_options( orig );CHECK_ERR( rval ); 00219 00220 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=0" ); 00221 rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00222 00223 // Check for proper tag 00224 Tag Ttag0, Ttag1; 00225 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00226 00227 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 ); 00228 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00229 00230 // Now read 2nd timestep with nomesh option 00231 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=1;NOMESH" ); 00232 rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00233 00234 // Check for proper tag 00235 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00236 } 00237 00238 void test_read_eul_novars() 00239 { 00240 Core moab; 00241 Interface& mb = moab; 00242 00243 // Need a set for nomesh to work right 00244 EntityHandle set; 00245 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00246 00247 std::string orig, opts; 00248 rval = get_options( orig );CHECK_ERR( rval ); 00249 00250 opts = orig + std::string( ";NOMESH;VARIABLE=" ); 00251 rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00252 00253 opts = orig + std::string( ";VARIABLE=;TIMESTEP=0" ); 00254 rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00255 00256 // Check for proper tag 00257 Tag Ttag0, Ttag1; 00258 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 ); 00259 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00260 00261 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=0;NOMESH" ); 00262 rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00263 00264 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00265 00266 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 ); 00267 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00268 00269 // Now read 2nd timestep with nomesh option 00270 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=1;NOMESH" ); 00271 rval = mb.load_file( example_eul.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00272 00273 // Check for proper tag 00274 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00275 } 00276 00277 void test_read_fv_all() 00278 { 00279 Core moab; 00280 Interface& mb = moab; 00281 00282 std::string opts; 00283 ErrorCode rval = get_options( opts );CHECK_ERR( rval ); 00284 00285 rval = mb.load_file( example_fv.c_str(), NULL, opts.c_str() );CHECK_ERR( rval ); 00286 00287 // Check for proper tags 00288 Tag Ttag0, Ttag1, coordTag; 00289 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00290 00291 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00292 00293 rval = mb.tag_get_handle( "COORDS", 3, MB_TYPE_DOUBLE, coordTag );CHECK_ERR( rval ); 00294 } 00295 00296 void test_read_fv_onevar() 00297 { 00298 Core moab; 00299 Interface& mb = moab; 00300 std::string opts; 00301 ErrorCode rval = get_options( opts );CHECK_ERR( rval ); 00302 00303 opts += std::string( ";VARIABLE=T" ); 00304 rval = mb.load_file( example_fv.c_str(), NULL, opts.c_str() );CHECK_ERR( rval ); 00305 00306 // Check for proper tags 00307 Tag Ttag0, Ttag1; 00308 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00309 00310 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00311 00312 // Check values of tag T0 (first level) at some strategically chosen places below 00313 #ifdef MOAB_HAVE_MPI 00314 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00315 int rank = pcomm->proc_config().proc_rank(); 00316 int procs = pcomm->proc_config().proc_size(); 00317 #else 00318 int rank = 0; 00319 int procs = 1; 00320 #endif 00321 00322 const double eps = 0.0001; 00323 double val[8 * levels]; 00324 00325 if( 1 == procs ) 00326 { 00327 Range global_quads; 00328 rval = mb.get_entities_by_type( 0, MBQUAD, global_quads );CHECK_ERR( rval ); 00329 CHECK_EQUAL( (size_t)3312, global_quads.size() ); 00330 00331 EntityHandle gloabl_quad_ents[] = { global_quads[0], global_quads[1619], global_quads[1656], 00332 global_quads[3275], global_quads[36], global_quads[1655], 00333 global_quads[1692], global_quads[3311] }; 00334 rval = mb.tag_get_data( Ttag0, &gloabl_quad_ents[0], 8, val ); 00335 00336 CHECK_REAL_EQUAL( 253.6048, val[0 * levels], eps ); // First global quad 00337 CHECK_REAL_EQUAL( 232.2170, val[1 * levels], eps ); // 1620th global quad 00338 CHECK_REAL_EQUAL( 232.7454, val[2 * levels], eps ); // 1657th global quad 00339 CHECK_REAL_EQUAL( 210.2581, val[3 * levels], eps ); // 3276th global quad 00340 CHECK_REAL_EQUAL( 253.6048, val[4 * levels], eps ); // 37th global quad 00341 CHECK_REAL_EQUAL( 232.9553, val[5 * levels], eps ); // 1656th global quad 00342 CHECK_REAL_EQUAL( 232.1704, val[6 * levels], eps ); // 1693th global quad 00343 CHECK_REAL_EQUAL( 210.2581, val[7 * levels], eps ); // Last global quad 00344 } 00345 else if( 2 == procs ) 00346 { 00347 Range local_quads; 00348 rval = mb.get_entities_by_type( 0, MBQUAD, local_quads );CHECK_ERR( rval ); 00349 CHECK_EQUAL( (size_t)1656, local_quads.size() ); 00350 00351 EntityHandle local_quad_ents[] = { local_quads[0], local_quads[827], local_quads[828], local_quads[1655] }; 00352 rval = mb.tag_get_data( Ttag0, &local_quad_ents[0], 4, val ); 00353 00354 if( 0 == rank ) 00355 { 00356 CHECK_REAL_EQUAL( 253.6048, val[0 * levels], 00357 eps ); // First local quad, first global quad 00358 CHECK_REAL_EQUAL( 232.2170, val[1 * levels], 00359 eps ); // Median local quad, 1620th global quad 00360 CHECK_REAL_EQUAL( 232.7454, val[2 * levels], 00361 eps ); // Median local quad, 1657th global quad 00362 CHECK_REAL_EQUAL( 210.2581, val[3 * levels], 00363 eps ); // Last local quad, 3276th global quad 00364 } 00365 else if( 1 == rank ) 00366 { 00367 CHECK_REAL_EQUAL( 253.6048, val[0 * levels], 00368 eps ); // First local quad, 37th global quad 00369 CHECK_REAL_EQUAL( 232.9553, val[1 * levels], 00370 eps ); // Median local quad, 1656th global quad 00371 CHECK_REAL_EQUAL( 232.1704, val[2 * levels], 00372 eps ); // Median local quad, 1693th global quad 00373 CHECK_REAL_EQUAL( 210.2581, val[3 * levels], 00374 eps ); // Last local quad, last global quad 00375 } 00376 } 00377 } 00378 00379 void test_read_fv_onetimestep() 00380 { 00381 Core moab; 00382 Interface& mb = moab; 00383 std::string opts; 00384 ErrorCode rval = get_options( opts );CHECK_ERR( rval ); 00385 00386 opts += std::string( ";VARIABLE=T;TIMESTEP=1" ); 00387 rval = mb.load_file( example_fv.c_str(), NULL, opts.c_str() );CHECK_ERR( rval ); 00388 00389 // Check for proper tags 00390 Tag Ttag0, Ttag1; 00391 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 ); 00392 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00393 00394 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00395 00396 // Check for some tags with double underscore in the tag name 00397 Tag tempTag; 00398 rval = mb.tag_get_handle( "__lon_LOC_MINMAX", 2, MB_TYPE_INTEGER, tempTag );CHECK_ERR( rval ); 00399 00400 rval = mb.tag_get_handle( "__lon_LOC_VALS", 0, MB_TYPE_DOUBLE, tempTag, MB_TAG_VARLEN );CHECK_ERR( rval ); 00401 00402 rval = mb.tag_get_handle( "__lon_GLOBAL_MINMAX", 2, MB_TYPE_INTEGER, tempTag );CHECK_ERR( rval ); 00403 } 00404 00405 void test_read_fv_nomesh() 00406 { 00407 Core moab; 00408 Interface& mb = moab; 00409 00410 // Need a set for nomesh to work right 00411 EntityHandle set; 00412 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00413 00414 std::string orig, opts; 00415 rval = get_options( orig );CHECK_ERR( rval ); 00416 00417 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=0" ); 00418 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00419 00420 // Check for proper tag 00421 Tag Ttag0, Ttag1; 00422 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00423 00424 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 ); 00425 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00426 00427 // Now read 2nd timestep with nomesh option 00428 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=1;NOMESH" ); 00429 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00430 00431 // Check for proper tag 00432 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00433 } 00434 00435 void test_read_fv_novars() 00436 { 00437 Core moab; 00438 Interface& mb = moab; 00439 00440 // Need a set for nomesh to work right 00441 EntityHandle set; 00442 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00443 00444 std::string orig, opts; 00445 rval = get_options( orig );CHECK_ERR( rval ); 00446 00447 opts = orig + std::string( ";NOMESH;VARIABLE=" ); 00448 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00449 00450 opts = orig + std::string( ";VARIABLE=;TIMESTEP=0" ); 00451 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00452 00453 // Check for proper tag 00454 Tag Ttag0, Ttag1; 00455 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 ); 00456 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00457 00458 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=0;NOMESH" ); 00459 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00460 00461 rval = mb.tag_get_handle( "T0", levels, MB_TYPE_DOUBLE, Ttag0 );CHECK_ERR( rval ); 00462 00463 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 ); 00464 CHECK_EQUAL( rval, MB_TAG_NOT_FOUND ); 00465 00466 // Now read 2nd timestep with nomesh option 00467 opts = orig + std::string( ";VARIABLE=T;TIMESTEP=1;NOMESH" ); 00468 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00469 00470 // Check for proper tag 00471 rval = mb.tag_get_handle( "T1", levels, MB_TYPE_DOUBLE, Ttag1 );CHECK_ERR( rval ); 00472 } 00473 00474 #ifdef MOAB_HAVE_MPI 00475 void test_read_fv_ghosting() 00476 { 00477 Core moab; 00478 Interface& mb = moab; 00479 00480 // Need a set for nomesh to work right 00481 EntityHandle set; 00482 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00483 00484 std::string orig, opts; 00485 rval = get_options( orig );CHECK_ERR( rval ); 00486 00487 opts = std::string( "PARALLEL=READ_PART;PARTITION;PARALLEL_GHOSTS=2.0.1;NOMESH;VARIABLE=;" 00488 "PARTITION_METHOD=SQIJ" ); 00489 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00490 00491 opts = std::string( "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=" 00492 "2.0.1;PARTITION_METHOD=SQIJ;VARIABLE=" ); 00493 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00494 00495 opts = std::string( "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=SQIJ;VARIABLE=TOT_CLD_" 00496 "VISTAU;NOMESH;TIMESTEP=0;" ); 00497 rval = mb.load_file( example_fv.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00498 } 00499 #endif 00500 00501 void test_read_domain() 00502 { 00503 Core moab; 00504 Interface& mb = moab; 00505 00506 // Need a set for nomesh to work right 00507 EntityHandle set; 00508 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00509 00510 std::string orig, opts; 00511 rval = get_options( orig );CHECK_ERR( rval ); 00512 00513 opts = orig + std::string( ";VARIABLE=" ); 00514 rval = mb.load_file( example_domain.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00515 } 00516 00517 void test_read_scrip() 00518 { 00519 Core moab; 00520 Interface& mb = moab; 00521 00522 // Need a set for nomesh to work right 00523 EntityHandle set; 00524 ErrorCode rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00525 00526 std::string orig, opts; 00527 rval = get_options( orig );CHECK_ERR( rval ); 00528 00529 opts = orig + std::string( ";VARIABLE=" ); 00530 rval = mb.load_file( example_scrip.c_str(), &set, opts.c_str() );CHECK_ERR( rval ); 00531 } 00532 00533 ErrorCode get_options( std::string& opts ) 00534 { 00535 #ifdef MOAB_HAVE_MPI 00536 // Use parallel options 00537 opts = std::string( ";;PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;DEBUG_IO=2;" ); 00538 return MB_SUCCESS; 00539 #else 00540 opts = std::string( ";;" ); 00541 return MB_SUCCESS; 00542 #endif 00543 }
