MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab_mpi.h"#include "moab/ParallelComm.hpp"#include "MBParallelConventions.h"#include "moab/iMOAB.h"#include "TestUtil.hpp"#include "moab/CpuTimer.hpp"#include "moab/ProgOptions.hpp"#include <iostream>#include <sstream>#include "imoab_coupler_utils.hpp"
Include dependency graph for imoab_apg2_ol_coupler.cpp:Go to the source code of this file.
Defines | |
| #define | ENABLE_ATMOCN_COUPLING |
| #define | ENABLE_ATMLND_COUPLING |
Functions | |
| int | main (int argc, char *argv[]) |
| #define ENABLE_ATMLND_COUPLING |
Definition at line 48 of file imoab_apg2_ol_coupler.cpp.
| #define ENABLE_ATMOCN_COUPLING |
Definition at line 45 of file imoab_apg2_ol_coupler.cpp.
| int main | ( | int | argc, |
| char * | argv[] | ||
we will use the element global id, which should uniquely identify the element
Definition at line 50 of file imoab_apg2_ol_coupler.cpp.
References ProgOptions::addOpt(), atmFilename, CHECKIERR, cmpatm, create_group_and_comm(), create_joint_comm_group(), DENSE_DOUBLE, endG1, endG2, fileWriteOptions(), groupTasks, ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_GetMeshInfo(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorage(), iMOAB_WriteMesh(), jgroup, MPI_COMM_WORLD, nghlay, numProcesses, ProgOptions::parseCommandLine(), POP_TIMER, PUSH_TIMER, rankInAtmComm, rankInGlobalComm, readopts(), setup_component_coupler_meshes(), startG1, startG2, typeA, and typeB.
int ierr;
int rankInGlobalComm, numProcesses;
MPI_Group jgroup;
std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" );
std::string readoptsPhysAtm( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" );
/*if (argc < 2)
return 0; // no test; we will force naming the land domain file*/
// Timer data
moab::CpuTimer timer;
double timer_ops;
std::string opName;
int repartitioner_scheme = 0;
#ifdef MOAB_HAVE_ZOLTAN
repartitioner_scheme = 2; // use the geometry partitioner in that case
#endif
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm );
MPI_Comm_size( MPI_COMM_WORLD, &numProcesses );
MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup
std::string atmFilename =
"../../sandbox/MeshFiles/e3sm/ne4pg2_o240/ne4pg2_p8.h5m"; // we should use only mesh from here
std::string atmPhysMesh =
"../../sandbox/MeshFiles/e3sm/ne4pg2_o240/AtmPhys_pg2.h5m"; // it has some data associated to vertices, T_ph,
// u_ph, v_ph
// we will eventually project that data to ocean mesh, after intx atm/ocn
// on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ;
// intx atm/ocn is not in e3sm yet, give a number
// 6 * 100 + 18 = 618 : atmocnid
// 18 * 100 + 6 = 1806 : ocnatmid on coupler pes!
// 9 LND, 10 CPLLND
// 6 * 100 + 10 = 610 atmlndid:
// 10 * 100 + 6 = 1006 lndatmid: on coupler pes
// cmpatm is for atm on atm pes
// cmpocn is for ocean, on ocean pe
// cplatm is for atm on coupler pes
// cplocn is for ocean on coupler pes
// atmocnid is for intx atm / ocn on coupler pes
int rankInAtmComm = -1;
int cmpatm = 5, cplatm = 6; // component ids are unique over all pes, and established in advance;
int cmpPhysAtm = 105; // different from atm spectral ?
#ifdef ENABLE_ATMOCN_COUPLING
std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m";
int rankInOcnComm = -1;
int cmpocn = 17, cplocn = 18, atmocnid = 618,
ocnatmid = 1806; // component ids are unique over all pes, and established in advance;
#endif
#ifdef ENABLE_ATMLND_COUPLING
std::string lndFilename = "../../sandbox/MeshFiles/e3sm/ne4pg2_o240/land_p8.h5m";
int rankInLndComm = -1;
int cpllnd = 10, cmplnd = 9, atmlndid = 610,
lndatmid = 1006; // component ids are unique over all pes, and established in advance;
#endif
int rankInCouComm = -1;
int nghlay = 0; // number of ghost layers for loading the file
std::vector< int > groupTasks;
int startG1 = 0, startG2 = 0, endG1 = numProcesses - 1, endG2 = numProcesses - 1, startG3 = startG1, endG3 = endG1;
int startG4 = startG1, endG4 = endG1; // these are for coupler layout
int context_id = -1; // used now for freeing buffers
// default: load atm on 2 proc, ocean on 2, land on 2; migrate to 2 procs, then compute intx
// later, we need to compute weight matrix with tempestremap
ProgOptions opts;
opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename );
opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename );
#endif
opts.addOpt< std::string >( "land,l", "land mesh filename (target)", &lndFilename );
#endif
opts.addOpt< std::string >( "physgrid,q", "physics grid file", &atmPhysMesh );
opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 );
opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 );
opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 );
opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 );
#endif
opts.addOpt< int >( "startLnd,e", "start task for land layout", &startG3 );
opts.addOpt< int >( "endLnd,f", "end task for land layout", &endG3 );
#endif
opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 );
opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 );
opts.addOpt< int >( "partitioning,p", "partitioning option for migration", &repartitioner_scheme );
opts.parseCommandLine( argc, argv );
char fileWriteOptions[] = "PARALLEL=WRITE_PART";
if( !rankInGlobalComm )
std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 <<
"\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 <<
#endif
"\n land file: " << lndFilename << "\n on tasks : " << startG3 << ":" << endG3 <<
#endif
"\n atm phys file: " << atmPhysMesh << "\n on tasks : " << startG1 << ":" << endG1 <<
"\n partitioning (0 trivial, 1 graph, 2 geometry) " << repartitioner_scheme << "\n ";
// load files on 3 different communicators, groups
// first groups has task 0, second group tasks 0 and 1
// coupler will be on joint tasks, will be on a third group (0 and 1, again)
MPI_Group atmPEGroup;
MPI_Comm atmComm;
ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm );
CHECKIERR( ierr, "Cannot create atm MPI group and communicator " )
MPI_Group ocnPEGroup;
MPI_Comm ocnComm;
ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm );
CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " )
#endif
MPI_Group lndPEGroup;
MPI_Comm lndComm;
ierr = create_group_and_comm( startG3, endG3, jgroup, &lndPEGroup, &lndComm );
CHECKIERR( ierr, "Cannot create lnd MPI group and communicator " )
#endif
// we will always have a coupler
MPI_Group couPEGroup;
MPI_Comm couComm;
ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm );
CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " )
// now, create the joint communicators atm_coupler, ocn_coupler, lnd_coupler
// for each, we will have to create the group first, then the communicator
// atm_coupler
MPI_Group joinAtmCouGroup;
MPI_Comm atmCouComm;
ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm );
CHECKIERR( ierr, "Cannot create joint atm cou communicator" )
// ocn_coupler
MPI_Group joinOcnCouGroup;
MPI_Comm ocnCouComm;
ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm );
CHECKIERR( ierr, "Cannot create joint ocn cou communicator" )
#endif
// lnd_coupler
MPI_Group joinLndCouGroup;
MPI_Comm lndCouComm;
ierr = create_joint_comm_group( lndPEGroup, couPEGroup, &joinLndCouGroup, &lndCouComm );
#endif
ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should
CHECKIERR( ierr, "Cannot initialize iMOAB" )
int cmpAtmAppID = -1;
iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm
int cplAtmAppID = -1; // -1 means it is not initialized
iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs
int cmpOcnAppID = -1;
iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn
int cplOcnAppID = -1, cplAtmOcnAppID = -1, cplOcnAtmAppID = -1; // -1 means it is not initialized
iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs
iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm - ocn on coupler PEs
iMOAB_AppID cplOcnAtmPID = &cplOcnAtmAppID; // intx ocn - atm on coupler PEs
#endif
int cmpLndAppID = -1;
iMOAB_AppID cmpLndPID = &cmpLndAppID; // lnd
int cplLndAppID = -1, cplAtmLndAppID = -1, cplLndAtmAppID = -1; // -1 means it is not initialized
iMOAB_AppID cplLndPID = &cplLndAppID; // land on coupler PEs
iMOAB_AppID cplAtmLndPID = &cplAtmLndAppID; // intx atm - lnd on coupler PEs will be similar to ocn atm intx
iMOAB_AppID cplLndAtmPID = &cplLndAtmAppID;
#endif
int cmpPhysAtmID = -1;
iMOAB_AppID cmpPhAtmPID = &cmpPhysAtmID; // phys atm; we do not need to move it to cpl!
if( couComm != MPI_COMM_NULL )
MPI_Comm_rank( couComm, &rankInCouComm );
// Register all the applications on the coupler PEs
ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, cplAtmPID ); // atm on coupler pes
CHECKIERR( ierr, "Cannot register ATM over coupler PEs" )
ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, cplOcnPID ); // ocn on coupler pes
CHECKIERR( ierr, "Cannot register OCN over coupler PEs" )
#endif
ierr = iMOAB_RegisterApplication( "LNDX", &couComm, &cpllnd, cplLndPID ); // lnd on coupler pes
CHECKIERR( ierr, "Cannot register LND over coupler PEs" )
#endif
if( atmComm != MPI_COMM_NULL )
MPI_Comm_rank( atmComm, &rankInAtmComm );
ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID );
CHECKIERR( ierr, "Cannot register ATM App" )
if( ocnComm != MPI_COMM_NULL )
MPI_Comm_rank( ocnComm, &rankInOcnComm );
ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID );
CHECKIERR( ierr, "Cannot register OCN App" )
#endif
// atm
ierr =
setup_component_coupler_meshes( cmpAtmPID, cmpatm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm,
&couPEGroup, &atmCouComm, atmFilename, readopts, nghlay, repartitioner_scheme );
CHECKIERR( ierr, "Cannot load and migrate atm mesh" )
MPI_Barrier( MPI_COMM_WORLD );
// ocean
ierr =
setup_component_coupler_meshes( cmpOcnPID, cmpocn, cplOcnPID, cplocn, &ocnComm, &ocnPEGroup, &couComm,
&couPEGroup, &ocnCouComm, ocnFilename, readopts, nghlay, repartitioner_scheme );
CHECKIERR( ierr, "Cannot load and migrate ocn mesh" )
char outputFileTgt3[] = "recvOcn3.h5m";
PUSH_TIMER( "Write migrated OCN mesh on coupler PEs" )
ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt3, fileWriteOptions );
CHECKIERR( ierr, "cannot write ocn mesh after receiving" )
POP_TIMER( couComm, rankInCouComm )
#endif // #ifdef ENABLE_ATMOCN_COUPLING
// load phys atm mesh, with some data on it already
ierr = iMOAB_RegisterApplication( "PhysAtm", &atmComm, &cmpPhysAtm, cmpPhAtmPID );
CHECKIERR( ierr, "Cannot register Phys Atm App " )
// load the next component mesh
PUSH_TIMER( "Load Phys Atm mesh" )
ierr = iMOAB_LoadMesh( cmpPhAtmPID, atmPhysMesh.c_str(), readoptsPhysAtm.c_str(), &nghlay );
CHECKIERR( ierr, "Cannot load Atm Phys mesh on atm pes" )
POP_TIMER( atmComm, rankInAtmComm )
int nverts[3], nelem[3];
ierr = iMOAB_GetMeshInfo( cmpPhAtmPID, nverts, nelem, 0, 0, 0 );
CHECKIERR( ierr, "failed to get mesh info" );
printf( "Phys Atm Component Mesh: %d vertices and %d elements\n", nverts[0], nelem[0] );
// land
if( lndComm != MPI_COMM_NULL )
ierr = iMOAB_RegisterApplication( "LND1", &lndComm, &cmplnd, cmpLndPID );
CHECKIERR( ierr, "Cannot register LND App " )
ierr = setup_component_coupler_meshes( cmpLndPID, cmplnd, cplLndPID, cpllnd, &lndComm, &lndPEGroup, &couComm,
&couPEGroup, &lndCouComm, lndFilename, readoptsPhysAtm, nghlay,
{ // write only for n==1 case
char outputFileLnd[] = "recvLnd.h5m";
ierr = iMOAB_WriteMesh( cplLndPID, outputFileLnd, fileWriteOptions );
CHECKIERR( ierr, "cannot write lnd mesh after receiving" )
#endif // #ifdef ENABLE_ATMLND_COUPLING
// now compute intersection between OCNx and ATMx on coupler PEs
ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID );
CHECKIERR( ierr, "Cannot register ocn_atm intx over coupler pes " )
ierr = iMOAB_RegisterApplication( "OCNATM", &couComm, &ocnatmid, cplOcnAtmPID );
CHECKIERR( ierr, "Cannot register atm_ocn intx over coupler pes " )
#endif
// now compute intersection between LNDx and ATMx on coupler PEs
ierr = iMOAB_RegisterApplication( "ATMLND", &couComm, &atmlndid, cplAtmLndPID );
CHECKIERR( ierr, "Cannot register atm_lnd intx over coupler pes " )
// now compute intersection between ATMx and LNDx on coupler PEs
ierr = iMOAB_RegisterApplication( "LNDATM", &couComm, &lndatmid, cplLndAtmPID );
CHECKIERR( ierr, "Cannot register lnd_atm intx over coupler pes " )
#endif
const char* weights_identifiers[2] = { "scalar", "scalar-pc" };
int disc_orders[3] = { 4, 1, 1 };
const char* disc_methods[3] = { "cgll", "fv", "pcloud" };
const char* dof_tag_names[3] = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" };
PUSH_TIMER( "Compute ATM-OCN mesh intersection" )
ierr = iMOAB_ComputeMeshIntersectionOnSphere(
cplAtmPID, cplOcnPID, cplAtmOcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes
// basically, atm was redistributed according to target (ocean) partition, to "cover" the ocean partitions
// check if intx valid, write some h5m intx file
CHECKIERR( ierr, "cannot compute intersection" )
PUSH_TIMER( "Compute OCN-ATM mesh intersection" )
ierr =
iMOAB_ComputeMeshIntersectionOnSphere( cplOcnPID, cplAtmPID, cplOcnAtmPID ); // coverage mesh was computed
if( atmCouComm != MPI_COMM_NULL )
// the new graph will be for sending data from atm comp to coverage mesh;
// it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID
// results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh
// after this, the sending of tags from atm pes to coupler pes will use the new par comm graph, that has more
// precise info about what to send for ocean cover ; every time, we will
// use the element global id, which should uniquely identify the element
PUSH_TIMER( "Compute OCN coverage graph for ATM mesh" )
ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, &cmpatm, &cplatm,
&cplocn ); // it happens over joint communicator
CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean" )
POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank
if( ocnCouComm != MPI_COMM_NULL )
// now for the second intersection, ocn-atm; will be sending data from ocean to atm
// Can we reuse the intx atm-ocn? Not sure yet; we will compute everything again :(
// the new graph will be for sending data from ocn comp to coverage mesh over atm;
// it involves initial ocn app; cmpOcnPID; also migrated ocn mesh on coupler pes, cplOcnPID
// results are in cplOcnAtmPID, intx mesh; remapper also has some info about coverage mesh
// after this, the sending of tags from ocn pes to coupler pes will use the new par comm graph, that has more
// precise info about what to send for atm cover ; every time, we will
PUSH_TIMER( "Compute ATM coverage graph for OCN mesh" )
ierr = iMOAB_CoverageGraph( &ocnCouComm, cmpOcnPID, cplOcnPID, cplOcnAtmPID, &cmpocn, &cplocn,
&cplatm ); // it happens over joint communicator, ocean + coupler
CHECKIERR( ierr, "cannot recompute direct coverage graph for atm" )
POP_TIMER( ocnCouComm, rankInOcnComm ) // hijack this rank
// need to compute graph between phys atm and atm/ocn intx coverage
int typeA = 2; // point cloud, phys mesh
int typeB = 3; // cells of atmosphere, dof based; maybe need another type for ParCommGraph graphtype ?
ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmOcnPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB,
&cmpPhysAtm, &atmocnid );
CHECKIERR( ierr, "cannot compute graph between phys grid on atm and intx between FV atm and ocn" )
// also
// need to compute graph between ocn/atm intx and phys atm mesh
/*if( atmCouComm != MPI_COMM_NULL )
int typeA = 3; // cells of atmosphere, dof based; maybe need another type for ParCommGraph graphtype ?
int typeB = 2; // point cloud, phys mesh
ierr = iMOAB_ComputeCommGraph( cplOcnAtmPID, cmpPhAtmPID, &atmCouComm, &couPEGroup, &atmPEGroup, &typeA, &typeB,
&ocnatmid, &cmpatm );
// need to compute graph between atm on coupler and phys atm mesh on component
int typeB = 3; // cells of atmosphere, dof based; need another type for ParCommGraph graphtype ?
ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB,
&cmpPhysAtm, &cplatm );
CHECKIERR( ierr, "cannot compute graph between phys grid on atm and FV atm on coupler" )
#endif
PUSH_TIMER( "Compute ATM-LND mesh intersection" )
ierr = iMOAB_ComputeMeshIntersectionOnSphere( cplAtmPID, cplLndPID, cplAtmLndPID );
CHECKIERR( ierr, "failed to compute atm - land intx for mapping" );
PUSH_TIMER( "Compute LND-ATM mesh intersection" )
ierr =
iMOAB_ComputeMeshIntersectionOnSphere( cplLndPID, cplAtmPID, cplLndAtmPID ); // coverage mesh was computed
// the new graph will be for sending data from atm comp to coverage mesh for land mesh;
// results are in cplAtmLndPID, intx mesh; remapper also has some info about coverage mesh
// precise info about what to send (specifically for land cover); every time,
/// we will use the element global id, which should uniquely identify the element
PUSH_TIMER( "Compute LND coverage graph for ATM mesh" )
ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmLndPID, &cmpatm, &cplatm,
&cpllnd ); // it happens over joint communicator
CHECKIERR( ierr, "cannot recompute direct coverage graph for land" )
// we will compute comm graph between atm phys and land, directly;
// on the new TriGrid workflow, we do need intersection between atm and land;
int typeB = 3; // type 3 for land on coupler, based on global ids for land cells ?
ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmLndPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB,
&cmpPhysAtm, &atmlndid );
CHECKIERR( ierr, "cannot compute comm graph between atm and atm/lnd intersection" )
// for reverse direction, lnd - atm intx:
if( lndCouComm != MPI_COMM_NULL )
// now for the second intersection, lnd-atm; will be sending data from lnd to atm
// Can we reuse the intx atm-lnd? Not sure yet; we will compute everything again :(
// the new graph will be for sending data from lnd comp to coverage mesh over atm;
// it involves initial lnd app; cmpLndPID; also migrated lnd mesh on coupler pes, cplLndPID
// results are in cplLndAtmPID, intx mesh; remapper also has some info about coverage mesh
// after this, the sending of tags from lnd pes to coupler pes will use the new par comm graph, that has more
PUSH_TIMER( "Compute ATM coverage graph for LND mesh" )
ierr = iMOAB_CoverageGraph( &lndCouComm, cmpLndPID, cplLndPID, cplLndAtmPID, &cmplnd, &cpllnd,
CHECKIERR( ierr, "cannot recompute direct coverage graph for atm for intx with land" )
POP_TIMER( lndCouComm, rankInLndComm )
#endif
int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 1, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0;
#ifdef VERBOSE
char serialWriteOptions[] = ""; // for writing in serial
std::stringstream outf;
outf << "intxAtmOcn_" << rankInCouComm << ".h5m";
std::string intxfile = outf.str(); // write in serial the intx file, for debugging
ierr = iMOAB_WriteMesh( cplAtmOcnPID, intxfile.c_str(), serialWriteOptions );
CHECKIERR( ierr, "cannot write intx file result" )
#endif
PUSH_TIMER( "Compute the projection weights with TempestRemap" )
ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0], disc_methods[1],
&disc_orders[1], // fv
disc_methods[1], &disc_orders[1], // fv
&fNoBubble, &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap,
&fNoConserve, &fValidate, dof_tag_names[1], dof_tag_names[1] );
CHECKIERR( ierr, "cannot compute scalar projection weights" )
// now compute weight maps for ocn to atm mapping;
PUSH_TIMER( "Compute the projection weights with TempestRemap for ocn - atm map" )
ierr = iMOAB_ComputeScalarProjectionWeights( cplOcnAtmPID, weights_identifiers[0], disc_methods[1],
#endif
// we do not need to compute weights ? just send tags between dofs ?
// Compute the weights to project the solution from ATM component to LND component
PUSH_TIMER( "Compute ATM-LND remapping weights" )
ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmLndPID, weights_identifiers[0], disc_methods[1],
&disc_orders[1], disc_methods[1], &disc_orders[1], &fNoBubble,
&fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve,
CHECKIERR( ierr, "failed to compute remapping projection weights for ATM-LND scalar non-conservative field" );
// Compute the weights to project the solution from LND component to ATM component
PUSH_TIMER( "Compute LND-ATM remapping weights" )
ierr = iMOAB_ComputeScalarProjectionWeights( cplLndAtmPID, weights_identifiers[0], disc_methods[1],
CHECKIERR( ierr, "failed to compute remapping projection weights for LND-ATM scalar non-conservative field" );
#endif
int tagIndex[2];
int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE };
int atmCompNDoFs = 1 /* FV disc_orders[0]*disc_orders[0] */, ocnCompNDoFs = 1 /*FV*/;
const char* bottomFields = "T_ph:u_ph:v_ph"; // same as on phys atm mesh
const char* bottomProjectedFields = "T_proj:u_proj:v_proj";
// coming from ocn to atm, project back from T_proj
const char* bottomFields2 = "T2_ph:u2_ph:v2_ph"; // same as on phys atm mesh
// coming from lnd to atm, project back from T_proj
const char* bottomFields3 = "T3_ph:u3_ph:v3_ph"; // same as on phys atm mesh
// tags on phys grid atm mesh
const char* bottomPhProjectedFields = "Tph_proj:uph_proj:vph_proj";
const char* bottomPhLndProjectedFields =
"TphL_proj:uphL_proj:vphL_proj"; // L and Lnd signify the fields projected from land
ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
CHECKIERR( ierr, "failed to define the field tags T_ph, u_ph, v_ph " );
ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] );
CHECKIERR( ierr, "failed to define the field tags T_proj, u_proj, v_proj " );
#endif
// need to define tag storage for land; will use the same T_proj, u_proj, v_proj name, because it will be
// used to send between point clouds !
// use the same ndof and same size as ocnCompNDoFs (1) !!
ierr = iMOAB_DefineTagStorage( cplLndPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] );
CHECKIERR( ierr, "failed to define the field tags T_proj, u_proj, v_proj" );
#endif
// need to make sure that the coverage mesh (created during intx method) received the tag that need to be projected
// to target so far, the coverage mesh has only the ids and global dofs; need to change the migrate method to
// accommodate any GLL tag now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh
// (cplAtmPID), using the new coverage graph communicator
// make the tag 0, to check we are actually sending needed data
if( cplAtmAppID >= 0 )
int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3];
* Each process in the communicator will have access to a local mesh instance, which will contain the
* original cells in the local partition and ghost entities. Number of vertices, primary cells, visible
* blocks, number of sidesets and nodesets boundary conditions will be returned in numProcesses 3 arrays,
* for local, ghost and total numbers.
ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc );
CHECKIERR( ierr, "failed to get num primary elems" );
int numAllElem = nelem[2];
std::vector< double > vals;
int storLeng = atmCompNDoFs * numAllElem * 3; // 3 tags
vals.resize( storLeng );
for( int k = 0; k < storLeng; k++ )
vals[k] = 0.;
int eetype = 1;
ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFields, &storLeng, &eetype, &vals[0] );
CHECKIERR( ierr, "cannot make tag nul" )
// set the tag to 0
PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" )
// as always, use nonblocking sends
// this is for projection to ocean:
ierr = iMOAB_SendElementTag( cmpPhAtmPID, "T_ph:u_ph:v_ph", &atmCouComm, &atmocnid );
CHECKIERR( ierr, "cannot send tag values" )
// receive on atm on coupler pes, that was redistributed according to coverage
ierr = iMOAB_ReceiveElementTag( cplAtmOcnPID, "T_ph:u_ph:v_ph", &atmCouComm, &cmpPhysAtm );
CHECKIERR( ierr, "cannot receive tag values on intx atm ocn" )
POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm )
// we can now free the sender buffers
ierr = iMOAB_FreeSenderBuffers( cmpPhAtmPID, &atmocnid ); // context is for ocean
CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" )
#ifdef VERBOSE
if (couComm != MPI_COMM_NULL) {
char outputFileRecvd[] = "recvAtmCoupOcn.h5m";
ierr = iMOAB_WriteMesh(cplAtmPID, outputFileRecvd, fileWriteOptions );
#endif
const char* concat_fieldname = "T_ph:u_ph:v_ph";
const char* concat_fieldnameT = "T_proj:u_proj:v_proj";
/* We have the remapping weights now. Let us apply the weights onto the tag we defined
on the source mesh and get the projection on the target mesh */
PUSH_TIMER( "Apply Scalar projection weights" )
ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0], concat_fieldname,
concat_fieldnameT );
CHECKIERR( ierr, "failed to compute projection weight application" );
char outputFileTgt[] = "fOcnOnCpl3.h5m";
ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions );
CHECKIERR( ierr, "failed to write fOcnOnCpl3.h5m " );
// send the projected tag back to ocean pes, with send/receive tag
int tagIndexIn2;
ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 );
CHECKIERR( ierr,
"failed to define the field tag for receiving back the tag T_proj, u_proj, v_proj on ocn pes" );
// send the tag to ocean pes, from ocean mesh on coupler pes
// from couComm, using common joint comm ocn_coupler
// original graph (context is -1_
context_id = cmpocn;
ierr = iMOAB_SendElementTag( cplOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &context_id );
CHECKIERR( ierr, "cannot send tag values back to ocean pes" )
// receive on component 2, ocean
context_id = cplocn;
ierr = iMOAB_ReceiveElementTag( cmpOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &context_id );
CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" )
ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id );
CHECKIERR( ierr, "cannot free buffers related to send tag" )
char outputFileOcn[] = "OcnWithProj3.h5m";
ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions );
CHECKIERR( ierr, "cannot write OcnWithProj3.h5m" )
#endif
// start land proj:
// we used this to compute
// ierr = iMOAB_ComputeCommGraph(cmpPhAtmPID, cplLndPID, &atmCouComm, &atmPEGroup, &couPEGroup,
// &typeA, &typeB, &cmpPhysAtm, &atmlndid);
// end copy
PUSH_TIMER( "Send/receive data from phys comp atm to coupler land, using computed graph" )
// this is for projection to land:
ierr = iMOAB_SendElementTag( cmpPhAtmPID, "T_ph:u_ph:v_ph", &atmCouComm, &atmlndid );
CHECKIERR( ierr, "cannot send tag values towards cpl on land" )
// receive on lnd on coupler pes
ierr = iMOAB_ReceiveElementTag( cplAtmLndPID, "T_ph:u_ph:v_ph", &atmCouComm, &cmpPhysAtm );
CHECKIERR( ierr, "cannot receive tag values on land on coupler, for atm coupling" )
ierr = iMOAB_FreeSenderBuffers( cmpPhAtmPID, &atmlndid );
CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the land on coupler" )
ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmLndPID, weights_identifiers[0], concat_fieldname,
char outputFileTgt[] = "fLndOnCpl3.h5m";
ierr = iMOAB_WriteMesh( cplLndPID, outputFileTgt, fileWriteOptions );
CHECKIERR( ierr, "cannot write land on coupler" )
// end land proj
// send the tags back to land pes, from land mesh on coupler pes
// send from cplLndPID to cmpLndPID, using common joint comm
// original graph
// int context_id = -1;
// the land might not have these tags yet; it should be a different name for land
// in e3sm we do have different names
int tagIndexIn2;
ierr = iMOAB_DefineTagStorage( cmpLndPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 );
CHECKIERR( ierr,
"failed to define the field tag for receiving back the tag T_proj, u_proj, v_proj on lnd pes" );
context_id = cmplnd;
ierr = iMOAB_SendElementTag( cplLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &context_id );
CHECKIERR( ierr, "cannot send tag values back to land pes" )
// receive on component 3, land
context_id = cpllnd;
ierr = iMOAB_ReceiveElementTag( cmpLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &context_id );
CHECKIERR( ierr, "cannot receive tag values from land mesh on coupler pes" )
ierr = iMOAB_FreeSenderBuffers( cplLndPID, &context_id );
CHECKIERR( ierr, "cannot free buffers related to sending tags from coupler to land pes" )
char outputFileLnd[] = "LndWithProj3.h5m";
ierr = iMOAB_WriteMesh( cmpLndPID, outputFileLnd, fileWriteOptions );
CHECKIERR( ierr, "cannot write land file with projection" )
// we have received on ocean component some data projected from atm, on coupler
// path was T_ph (atm phys) towards atm on FV mesh, we projected, then we sent back to ocean comp
// start copy ocn atm coupling; go reverse direction now !!
PUSH_TIMER( "Send/receive data from ocn component to coupler in atm context" )
ierr = iMOAB_SendElementTag( cmpOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &cplatm );
CHECKIERR( ierr, "cannot send tag values T_proj, etc towards ocn coupler" )
// receive on ocn on coupler pes, that was redistributed according to coverage
ierr = iMOAB_ReceiveElementTag( cplOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &cplatm );
CHECKIERR( ierr, "cannot receive tag values" )
ierr = iMOAB_FreeSenderBuffers( cmpOcnPID, &cplatm ); // context is for atm
CHECKIERR( ierr, "cannot free buffers used to send ocn tag towards the coverage mesh for atm" )
//#ifdef VERBOSE
char outputFileRecvd[] = "recvOcnCpl.h5m";
ierr = iMOAB_WriteMesh( cplOcnPID, outputFileRecvd, fileWriteOptions );
CHECKIERR( ierr, "could not write recvOcnCplOcn.h5m to disk" )
//#endif
const char* concat_fieldname = "T_proj:u_proj:v_proj"; // this is now source tag
const char* concat_fieldnameT = "T2_ph:u2_ph:v2_ph"; // projected tag on
// make sure the new tags exist on atm coupler mesh;
ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields2, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
CHECKIERR( ierr, "failed to define the field tags T2_ph, u2_ph, v2_ph" );
ierr = iMOAB_ApplyScalarProjectionWeights( cplLndAtmPID, weights_identifiers[0], concat_fieldname,
char outputFileTgt[] = "fAtm2OnCpl2.h5m";
ierr = iMOAB_WriteMesh( cplAtmPID, outputFileTgt, fileWriteOptions );
CHECKIERR( ierr, "could not write fAtm2OnCpl.h5m to disk" )
// send the projected tag back to atm pes, with send/receive partial par graph computed
// from intx ocn/atm towards atm physics mesh !
int tagIndexIn2;
ierr =
iMOAB_DefineTagStorage( cmpPhAtmPID, bottomPhProjectedFields, &tagTypes[1], &atmCompNDoFs, &tagIndexIn2 );
CHECKIERR( ierr, "failed to define the field tag for receiving back the tag "
"Tph_proj, etc on atm pes" );
// send the tag to atm pes, from atm pg2 mesh on coupler pes
// from couComm, using common joint comm atm_coupler, and computed graph, phys-grid -> atm FV on cpl, in reverse
// graph context comes from commgraph ?
// ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA,
// &typeB,
// &cmpatm, &cplatm );
context_id = cmpPhysAtm;
ierr = iMOAB_SendElementTag( cplAtmPID, "T2_ph:u2_ph:v2_ph", &atmCouComm, &context_id );
CHECKIERR( ierr, "cannot send tag values back to atm pes" )
// receive on component atm phys mesh
context_id = cplatm;
ierr = iMOAB_ReceiveElementTag( cmpPhAtmPID, "Tph_proj:uph_proj:vph_proj", &atmCouComm, &context_id );
CHECKIERR( ierr, "cannot receive tag values from atm pg2 mesh on coupler pes" )
context_id = cmpatm;
ierr = iMOAB_FreeSenderBuffers( cplAtmPID, &context_id );
CHECKIERR( ierr, "cannot free buffers for sending T2_ph from cpl to phys atm" )
if( atmComm != MPI_COMM_NULL ) // write only for n==1 case
char outputFileAtmPh[] = "AtmPhysProj.h5m";
ierr = iMOAB_WriteMesh( cmpPhAtmPID, outputFileAtmPh, fileWriteOptions );
CHECKIERR( ierr, "could not write AtmPhysProj.h5m to disk" )
#endif
// end copy need more work for land
// start copy
// lnd atm coupling; go reverse direction now, from lnd to atm , using lnd - atm intx, weight gen
// send back the T_proj , etc , from lan comp to land coupler
PUSH_TIMER( "Send/receive data from lnd component to coupler in atm context" )
ierr = iMOAB_SendElementTag( cmpLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &cplatm );
CHECKIERR( ierr, "cannot send tag values T_proj, etc towards lnd coupler" )
ierr = iMOAB_ReceiveElementTag( cplLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &cplatm );
CHECKIERR( ierr, "cannot receive tag values on land" )
ierr = iMOAB_FreeSenderBuffers( cmpLndPID, &cplatm ); // context is for atm
CHECKIERR( ierr, "cannot free buffers used to send lnd tag towards the coverage mesh for atm" )
//#ifdef VERBOSE
char outputFileRecvd[] = "recvLndCpl.h5m";
ierr = iMOAB_WriteMesh( cplLndPID, outputFileRecvd, fileWriteOptions );
CHECKIERR( ierr, "could not write recvLndCpl.h5m to disk" )
//#endif
PUSH_TIMER( "Apply Scalar projection weights for lnd - atm coupling" )
const char* concat_fieldname = "T_proj:u_proj:v_proj"; // this is now source tag, on land cpl
const char* concat_fieldnameT = "T3_ph:u3_ph:v3_ph"; // projected tag on
ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields3, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
CHECKIERR( ierr, "failed to define the field tag T3_ph" );
CHECKIERR( ierr, "failed to compute projection weight application from lnd to atm " );
char outputFileTgt[] = "fAtm3OnCpl.h5m"; // this is for T3_ph, etc
CHECKIERR( ierr, "could not write fAtm3OnCpl.h5m to disk" )
// from intx lnd/atm towards atm physics mesh !
int tagIndexIn2;
ierr = iMOAB_DefineTagStorage( cmpPhAtmPID, bottomPhLndProjectedFields, &tagTypes[1], &atmCompNDoFs,
&tagIndexIn2 );
"TphL_proj, on atm pes" );
// &typeB,
ierr = iMOAB_SendElementTag( cplAtmPID, "T3_ph:u3_ph:v3_ph", &atmCouComm, &context_id );
ierr = iMOAB_ReceiveElementTag( cmpPhAtmPID, "TphL_proj:uphL_proj:vphL_proj", &atmCouComm, &context_id );
CHECKIERR( ierr, "cannot free buffers used for sending back atm tags " )
char outputFileAtmPh[] = "AtmPhysProj3.h5m";
CHECKIERR( ierr, "could not write AtmPhysProj3.h5m to disk" )
#endif
// we could deregister cplLndAtmPID
ierr = iMOAB_DeregisterApplication( cplLndAtmPID );
CHECKIERR( ierr, "cannot deregister app intx LA" )
// we could deregister cplAtmLndPID
ierr = iMOAB_DeregisterApplication( cplAtmLndPID );
CHECKIERR( ierr, "cannot deregister app intx AL" )
#endif // ENABLE_ATMLND_COUPLING
ierr = iMOAB_DeregisterApplication( cplOcnAtmPID );
CHECKIERR( ierr, "cannot deregister app intx OA" )
ierr = iMOAB_DeregisterApplication( cplAtmOcnPID );
CHECKIERR( ierr, "cannot deregister app intx AO" )
#endif
ierr = iMOAB_DeregisterApplication( cmpLndPID );
CHECKIERR( ierr, "cannot deregister app LND1" )
ierr = iMOAB_DeregisterApplication( cmpPhAtmPID );
CHECKIERR( ierr, "cannot deregister app PhysAtm " )
ierr = iMOAB_DeregisterApplication( cmpOcnPID );
CHECKIERR( ierr, "cannot deregister app OCN1" )
#endif // ENABLE_ATMOCN_COUPLING
ierr = iMOAB_DeregisterApplication( cmpAtmPID );
CHECKIERR( ierr, "cannot deregister app ATM1" )
ierr = iMOAB_DeregisterApplication( cplLndPID );
CHECKIERR( ierr, "cannot deregister app LNDX" )
ierr = iMOAB_DeregisterApplication( cplOcnPID );
CHECKIERR( ierr, "cannot deregister app OCNX" )
ierr = iMOAB_DeregisterApplication( cplAtmPID );
CHECKIERR( ierr, "cannot deregister app ATMX" )
//#endif
ierr = iMOAB_Finalize();
CHECKIERR( ierr, "did not finalize iMOAB" )
// free atm coupler group and comm
if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm );
MPI_Group_free( &joinAtmCouGroup );
if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm );
if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm );
// free ocn - coupler group and comm
if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm );
MPI_Group_free( &joinOcnCouGroup );
#endif
if( MPI_COMM_NULL != lndComm ) MPI_Comm_free( &lndComm );
// free land - coupler group and comm
if( MPI_COMM_NULL != lndCouComm ) MPI_Comm_free( &lndCouComm );
MPI_Group_free( &joinLndCouGroup );
#endif
if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm );
MPI_Group_free( &atmPEGroup );
MPI_Group_free( &ocnPEGroup );
#endif
MPI_Group_free( &lndPEGroup );
#endif
MPI_Group_free( &couPEGroup );
MPI_Group_free( &jgroup );
MPI_Finalize();
// endif #if 0
return 0;
