MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * imoab_apg2_ol_coupler.cpp 00003 * 00004 * This imoab_apg2_ol_coupler test will simulate coupling between 3 components 00005 * meshes will be loaded from 3 files (atm phys + atm pg2, ocean, and land), and 00006 * Atm and ocn will be migrated to coupler pes and compute intx on them 00007 * then, intx will be performed between migrated meshes 00008 * and weights will be generated, such that a field from phys atm will be transferred to ocn 00009 * currently, the phys atm will send some data to be projected to ocean 00010 * similar for land, but land will be intersected too with the atm pg2 00011 * Land is defined by the domain mesh 00012 * 00013 * first, intersect atm and ocn, and recompute comm graph 1 between atm phys and atm_cx, for ocn intx 00014 * repeat the same for land; for atm/lnd coupling will use similar Fv -Fv maps; maybe later will identify some 00015 * equivalent to bilinear maps 00016 */ 00017 00018 #include "moab/Core.hpp" 00019 #ifndef MOAB_HAVE_MPI 00020 #error imoab coupler test requires MPI configuration 00021 #endif 00022 00023 // MPI includes 00024 #include "moab_mpi.h" 00025 #include "moab/ParallelComm.hpp" 00026 #include "MBParallelConventions.h" 00027 00028 #include "moab/iMOAB.h" 00029 #include "TestUtil.hpp" 00030 #include "moab/CpuTimer.hpp" 00031 #include "moab/ProgOptions.hpp" 00032 #include <iostream> 00033 #include <sstream> 00034 00035 #include "imoab_coupler_utils.hpp" 00036 00037 using namespace moab; 00038 00039 // #define VERBOSE 00040 00041 #ifndef MOAB_HAVE_TEMPESTREMAP 00042 #error The climate coupler test example requires MOAB configuration with TempestRemap 00043 #endif 00044 00045 #define ENABLE_ATMOCN_COUPLING 00046 // for land coupling with phys atm, we do not have to "compute" intersection 00047 // it is enough to know that the ids are the same, we can project from atm to land that way, using a computed graph 00048 #define ENABLE_ATMLND_COUPLING 00049 00050 int main( int argc, char* argv[] ) 00051 { 00052 int ierr; 00053 int rankInGlobalComm, numProcesses; 00054 MPI_Group jgroup; 00055 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00056 std::string readoptsPhysAtm( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); 00057 00058 /*if (argc < 2) 00059 return 0; // no test; we will force naming the land domain file*/ 00060 // Timer data 00061 moab::CpuTimer timer; 00062 double timer_ops; 00063 std::string opName; 00064 00065 int repartitioner_scheme = 0; 00066 #ifdef MOAB_HAVE_ZOLTAN 00067 repartitioner_scheme = 2; // use the geometry partitioner in that case 00068 #endif 00069 00070 MPI_Init( &argc, &argv ); 00071 MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); 00072 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00073 00074 MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup 00075 00076 std::string atmFilename = 00077 "../../sandbox/MeshFiles/e3sm/ne4pg2_o240/ne4pg2_p8.h5m"; // we should use only mesh from here 00078 std::string atmPhysMesh = 00079 "../../sandbox/MeshFiles/e3sm/ne4pg2_o240/AtmPhys_pg2.h5m"; // it has some data associated to vertices, T_ph, 00080 // u_ph, v_ph 00081 // we will eventually project that data to ocean mesh, after intx atm/ocn 00082 00083 // on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ; 00084 // intx atm/ocn is not in e3sm yet, give a number 00085 // 6 * 100 + 18 = 618 : atmocnid 00086 // 18 * 100 + 6 = 1806 : ocnatmid on coupler pes! 00087 // 9 LND, 10 CPLLND 00088 // 6 * 100 + 10 = 610 atmlndid: 00089 // 10 * 100 + 6 = 1006 lndatmid: on coupler pes 00090 // cmpatm is for atm on atm pes 00091 // cmpocn is for ocean, on ocean pe 00092 // cplatm is for atm on coupler pes 00093 // cplocn is for ocean on coupler pes 00094 // atmocnid is for intx atm / ocn on coupler pes 00095 // 00096 int rankInAtmComm = -1; 00097 int cmpatm = 5, cplatm = 6; // component ids are unique over all pes, and established in advance; 00098 int cmpPhysAtm = 105; // different from atm spectral ? 00099 #ifdef ENABLE_ATMOCN_COUPLING 00100 std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m"; 00101 int rankInOcnComm = -1; 00102 int cmpocn = 17, cplocn = 18, atmocnid = 618, 00103 ocnatmid = 1806; // component ids are unique over all pes, and established in advance; 00104 #endif 00105 #ifdef ENABLE_ATMLND_COUPLING 00106 std::string lndFilename = "../../sandbox/MeshFiles/e3sm/ne4pg2_o240/land_p8.h5m"; 00107 int rankInLndComm = -1; 00108 int cpllnd = 10, cmplnd = 9, atmlndid = 610, 00109 lndatmid = 1006; // component ids are unique over all pes, and established in advance; 00110 #endif 00111 00112 int rankInCouComm = -1; 00113 00114 int nghlay = 0; // number of ghost layers for loading the file 00115 std::vector< int > groupTasks; 00116 int startG1 = 0, startG2 = 0, endG1 = numProcesses - 1, endG2 = numProcesses - 1, startG3 = startG1, endG3 = endG1; 00117 int startG4 = startG1, endG4 = endG1; // these are for coupler layout 00118 int context_id = -1; // used now for freeing buffers 00119 00120 // default: load atm on 2 proc, ocean on 2, land on 2; migrate to 2 procs, then compute intx 00121 // later, we need to compute weight matrix with tempestremap 00122 00123 ProgOptions opts; 00124 opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename ); 00125 #ifdef ENABLE_ATMOCN_COUPLING 00126 opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename ); 00127 #endif 00128 00129 #ifdef ENABLE_ATMLND_COUPLING 00130 opts.addOpt< std::string >( "land,l", "land mesh filename (target)", &lndFilename ); 00131 #endif 00132 00133 opts.addOpt< std::string >( "physgrid,q", "physics grid file", &atmPhysMesh ); 00134 00135 opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 ); 00136 opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 ); 00137 #ifdef ENABLE_ATMOCN_COUPLING 00138 opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 ); 00139 opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 ); 00140 #endif 00141 00142 #ifdef ENABLE_ATMLND_COUPLING 00143 opts.addOpt< int >( "startLnd,e", "start task for land layout", &startG3 ); 00144 opts.addOpt< int >( "endLnd,f", "end task for land layout", &endG3 ); 00145 #endif 00146 00147 opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 ); 00148 opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 ); 00149 00150 opts.addOpt< int >( "partitioning,p", "partitioning option for migration", &repartitioner_scheme ); 00151 00152 opts.parseCommandLine( argc, argv ); 00153 00154 char fileWriteOptions[] = "PARALLEL=WRITE_PART"; 00155 00156 if( !rankInGlobalComm ) 00157 { 00158 std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 << 00159 #ifdef ENABLE_ATMOCN_COUPLING 00160 "\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 << 00161 #endif 00162 #ifdef ENABLE_ATMLND_COUPLING 00163 "\n land file: " << lndFilename << "\n on tasks : " << startG3 << ":" << endG3 << 00164 #endif 00165 00166 "\n atm phys file: " << atmPhysMesh << "\n on tasks : " << startG1 << ":" << endG1 << 00167 00168 "\n partitioning (0 trivial, 1 graph, 2 geometry) " << repartitioner_scheme << "\n "; 00169 } 00170 // load files on 3 different communicators, groups 00171 // first groups has task 0, second group tasks 0 and 1 00172 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00173 MPI_Group atmPEGroup; 00174 MPI_Comm atmComm; 00175 ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm ); 00176 CHECKIERR( ierr, "Cannot create atm MPI group and communicator " ) 00177 00178 #ifdef ENABLE_ATMOCN_COUPLING 00179 MPI_Group ocnPEGroup; 00180 MPI_Comm ocnComm; 00181 ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm ); 00182 CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " ) 00183 #endif 00184 00185 #ifdef ENABLE_ATMLND_COUPLING 00186 MPI_Group lndPEGroup; 00187 MPI_Comm lndComm; 00188 ierr = create_group_and_comm( startG3, endG3, jgroup, &lndPEGroup, &lndComm ); 00189 CHECKIERR( ierr, "Cannot create lnd MPI group and communicator " ) 00190 #endif 00191 00192 // we will always have a coupler 00193 MPI_Group couPEGroup; 00194 MPI_Comm couComm; 00195 ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm ); 00196 CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " ) 00197 00198 // now, create the joint communicators atm_coupler, ocn_coupler, lnd_coupler 00199 // for each, we will have to create the group first, then the communicator 00200 00201 // atm_coupler 00202 MPI_Group joinAtmCouGroup; 00203 MPI_Comm atmCouComm; 00204 ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm ); 00205 CHECKIERR( ierr, "Cannot create joint atm cou communicator" ) 00206 00207 #ifdef ENABLE_ATMOCN_COUPLING 00208 // ocn_coupler 00209 MPI_Group joinOcnCouGroup; 00210 MPI_Comm ocnCouComm; 00211 ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm ); 00212 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00213 #endif 00214 00215 #ifdef ENABLE_ATMLND_COUPLING 00216 // lnd_coupler 00217 MPI_Group joinLndCouGroup; 00218 MPI_Comm lndCouComm; 00219 ierr = create_joint_comm_group( lndPEGroup, couPEGroup, &joinLndCouGroup, &lndCouComm ); 00220 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00221 #endif 00222 00223 ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should 00224 CHECKIERR( ierr, "Cannot initialize iMOAB" ) 00225 00226 int cmpAtmAppID = -1; 00227 iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm 00228 int cplAtmAppID = -1; // -1 means it is not initialized 00229 iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs 00230 #ifdef ENABLE_ATMOCN_COUPLING 00231 int cmpOcnAppID = -1; 00232 iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn 00233 int cplOcnAppID = -1, cplAtmOcnAppID = -1, cplOcnAtmAppID = -1; // -1 means it is not initialized 00234 iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs 00235 iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm - ocn on coupler PEs 00236 iMOAB_AppID cplOcnAtmPID = &cplOcnAtmAppID; // intx ocn - atm on coupler PEs 00237 00238 #endif 00239 00240 #ifdef ENABLE_ATMLND_COUPLING 00241 int cmpLndAppID = -1; 00242 iMOAB_AppID cmpLndPID = &cmpLndAppID; // lnd 00243 int cplLndAppID = -1, cplAtmLndAppID = -1, cplLndAtmAppID = -1; // -1 means it is not initialized 00244 iMOAB_AppID cplLndPID = &cplLndAppID; // land on coupler PEs 00245 iMOAB_AppID cplAtmLndPID = &cplAtmLndAppID; // intx atm - lnd on coupler PEs will be similar to ocn atm intx 00246 00247 iMOAB_AppID cplLndAtmPID = &cplLndAtmAppID; 00248 #endif 00249 00250 int cmpPhysAtmID = -1; 00251 iMOAB_AppID cmpPhAtmPID = &cmpPhysAtmID; // phys atm; we do not need to move it to cpl! 00252 00253 if( couComm != MPI_COMM_NULL ) 00254 { 00255 MPI_Comm_rank( couComm, &rankInCouComm ); 00256 // Register all the applications on the coupler PEs 00257 ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, cplAtmPID ); // atm on coupler pes 00258 CHECKIERR( ierr, "Cannot register ATM over coupler PEs" ) 00259 #ifdef ENABLE_ATMOCN_COUPLING 00260 ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, cplOcnPID ); // ocn on coupler pes 00261 CHECKIERR( ierr, "Cannot register OCN over coupler PEs" ) 00262 #endif 00263 00264 #ifdef ENABLE_ATMLND_COUPLING 00265 ierr = iMOAB_RegisterApplication( "LNDX", &couComm, &cpllnd, cplLndPID ); // lnd on coupler pes 00266 CHECKIERR( ierr, "Cannot register LND over coupler PEs" ) 00267 #endif 00268 } 00269 00270 if( atmComm != MPI_COMM_NULL ) 00271 { 00272 MPI_Comm_rank( atmComm, &rankInAtmComm ); 00273 ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID ); 00274 CHECKIERR( ierr, "Cannot register ATM App" ) 00275 } 00276 00277 #ifdef ENABLE_ATMOCN_COUPLING 00278 if( ocnComm != MPI_COMM_NULL ) 00279 { 00280 MPI_Comm_rank( ocnComm, &rankInOcnComm ); 00281 ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID ); 00282 CHECKIERR( ierr, "Cannot register OCN App" ) 00283 } 00284 #endif 00285 00286 // atm 00287 ierr = 00288 setup_component_coupler_meshes( cmpAtmPID, cmpatm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm, 00289 &couPEGroup, &atmCouComm, atmFilename, readopts, nghlay, repartitioner_scheme ); 00290 CHECKIERR( ierr, "Cannot load and migrate atm mesh" ) 00291 00292 MPI_Barrier( MPI_COMM_WORLD ); 00293 00294 #ifdef ENABLE_ATMOCN_COUPLING 00295 // ocean 00296 ierr = 00297 setup_component_coupler_meshes( cmpOcnPID, cmpocn, cplOcnPID, cplocn, &ocnComm, &ocnPEGroup, &couComm, 00298 &couPEGroup, &ocnCouComm, ocnFilename, readopts, nghlay, repartitioner_scheme ); 00299 CHECKIERR( ierr, "Cannot load and migrate ocn mesh" ) 00300 00301 if( couComm != MPI_COMM_NULL ) 00302 { 00303 char outputFileTgt3[] = "recvOcn3.h5m"; 00304 PUSH_TIMER( "Write migrated OCN mesh on coupler PEs" ) 00305 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt3, fileWriteOptions ); 00306 CHECKIERR( ierr, "cannot write ocn mesh after receiving" ) 00307 POP_TIMER( couComm, rankInCouComm ) 00308 } 00309 #endif // #ifdef ENABLE_ATMOCN_COUPLING 00310 00311 MPI_Barrier( MPI_COMM_WORLD ); 00312 // load phys atm mesh, with some data on it already 00313 if( atmComm != MPI_COMM_NULL ) 00314 { 00315 00316 ierr = iMOAB_RegisterApplication( "PhysAtm", &atmComm, &cmpPhysAtm, cmpPhAtmPID ); 00317 CHECKIERR( ierr, "Cannot register Phys Atm App " ) 00318 00319 // load the next component mesh 00320 PUSH_TIMER( "Load Phys Atm mesh" ) 00321 ierr = iMOAB_LoadMesh( cmpPhAtmPID, atmPhysMesh.c_str(), readoptsPhysAtm.c_str(), &nghlay ); 00322 CHECKIERR( ierr, "Cannot load Atm Phys mesh on atm pes" ) 00323 POP_TIMER( atmComm, rankInAtmComm ) 00324 00325 int nverts[3], nelem[3]; 00326 ierr = iMOAB_GetMeshInfo( cmpPhAtmPID, nverts, nelem, 0, 0, 0 ); 00327 CHECKIERR( ierr, "failed to get mesh info" ); 00328 printf( "Phys Atm Component Mesh: %d vertices and %d elements\n", nverts[0], nelem[0] ); 00329 } 00330 00331 MPI_Barrier( MPI_COMM_WORLD ); 00332 00333 #ifdef ENABLE_ATMLND_COUPLING 00334 // land 00335 if( lndComm != MPI_COMM_NULL ) 00336 { 00337 ierr = iMOAB_RegisterApplication( "LND1", &lndComm, &cmplnd, cmpLndPID ); 00338 CHECKIERR( ierr, "Cannot register LND App " ) 00339 } 00340 ierr = setup_component_coupler_meshes( cmpLndPID, cmplnd, cplLndPID, cpllnd, &lndComm, &lndPEGroup, &couComm, 00341 &couPEGroup, &lndCouComm, lndFilename, readoptsPhysAtm, nghlay, 00342 repartitioner_scheme ); 00343 00344 if( couComm != MPI_COMM_NULL ) 00345 { // write only for n==1 case 00346 char outputFileLnd[] = "recvLnd.h5m"; 00347 ierr = iMOAB_WriteMesh( cplLndPID, outputFileLnd, fileWriteOptions ); 00348 CHECKIERR( ierr, "cannot write lnd mesh after receiving" ) 00349 } 00350 00351 #endif // #ifdef ENABLE_ATMLND_COUPLING 00352 00353 #ifdef ENABLE_ATMOCN_COUPLING 00354 if( couComm != MPI_COMM_NULL ) 00355 { 00356 // now compute intersection between OCNx and ATMx on coupler PEs 00357 ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID ); 00358 CHECKIERR( ierr, "Cannot register ocn_atm intx over coupler pes " ) 00359 00360 ierr = iMOAB_RegisterApplication( "OCNATM", &couComm, &ocnatmid, cplOcnAtmPID ); 00361 CHECKIERR( ierr, "Cannot register atm_ocn intx over coupler pes " ) 00362 } 00363 #endif 00364 00365 #ifdef ENABLE_ATMLND_COUPLING 00366 if( couComm != MPI_COMM_NULL ) 00367 { 00368 // now compute intersection between LNDx and ATMx on coupler PEs 00369 ierr = iMOAB_RegisterApplication( "ATMLND", &couComm, &atmlndid, cplAtmLndPID ); 00370 CHECKIERR( ierr, "Cannot register atm_lnd intx over coupler pes " ) 00371 // now compute intersection between ATMx and LNDx on coupler PEs 00372 ierr = iMOAB_RegisterApplication( "LNDATM", &couComm, &lndatmid, cplLndAtmPID ); 00373 CHECKIERR( ierr, "Cannot register lnd_atm intx over coupler pes " ) 00374 } 00375 #endif 00376 00377 const char* weights_identifiers[2] = { "scalar", "scalar-pc" }; 00378 int disc_orders[3] = { 4, 1, 1 }; 00379 const char* disc_methods[3] = { "cgll", "fv", "pcloud" }; 00380 const char* dof_tag_names[3] = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" }; 00381 #ifdef ENABLE_ATMOCN_COUPLING 00382 if( couComm != MPI_COMM_NULL ) 00383 { 00384 PUSH_TIMER( "Compute ATM-OCN mesh intersection" ) 00385 ierr = iMOAB_ComputeMeshIntersectionOnSphere( 00386 cplAtmPID, cplOcnPID, cplAtmOcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes 00387 // basically, atm was redistributed according to target (ocean) partition, to "cover" the ocean partitions 00388 // check if intx valid, write some h5m intx file 00389 CHECKIERR( ierr, "cannot compute intersection" ) 00390 POP_TIMER( couComm, rankInCouComm ) 00391 00392 PUSH_TIMER( "Compute OCN-ATM mesh intersection" ) 00393 ierr = 00394 iMOAB_ComputeMeshIntersectionOnSphere( cplOcnPID, cplAtmPID, cplOcnAtmPID ); // coverage mesh was computed 00395 CHECKIERR( ierr, "cannot compute intersection" ) 00396 POP_TIMER( couComm, rankInCouComm ) 00397 } 00398 00399 if( atmCouComm != MPI_COMM_NULL ) 00400 { 00401 // the new graph will be for sending data from atm comp to coverage mesh; 00402 // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID 00403 // results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh 00404 // after this, the sending of tags from atm pes to coupler pes will use the new par comm graph, that has more 00405 // precise info about what to send for ocean cover ; every time, we will 00406 // use the element global id, which should uniquely identify the element 00407 PUSH_TIMER( "Compute OCN coverage graph for ATM mesh" ) 00408 ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, &cmpatm, &cplatm, 00409 &cplocn ); // it happens over joint communicator 00410 CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean" ) 00411 POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank 00412 } 00413 if( ocnCouComm != MPI_COMM_NULL ) 00414 { 00415 // now for the second intersection, ocn-atm; will be sending data from ocean to atm 00416 // Can we reuse the intx atm-ocn? Not sure yet; we will compute everything again :( 00417 // the new graph will be for sending data from ocn comp to coverage mesh over atm; 00418 // it involves initial ocn app; cmpOcnPID; also migrated ocn mesh on coupler pes, cplOcnPID 00419 // results are in cplOcnAtmPID, intx mesh; remapper also has some info about coverage mesh 00420 // after this, the sending of tags from ocn pes to coupler pes will use the new par comm graph, that has more 00421 // precise info about what to send for atm cover ; every time, we will 00422 // use the element global id, which should uniquely identify the element 00423 PUSH_TIMER( "Compute ATM coverage graph for OCN mesh" ) 00424 ierr = iMOAB_CoverageGraph( &ocnCouComm, cmpOcnPID, cplOcnPID, cplOcnAtmPID, &cmpocn, &cplocn, 00425 &cplatm ); // it happens over joint communicator, ocean + coupler 00426 CHECKIERR( ierr, "cannot recompute direct coverage graph for atm" ) 00427 POP_TIMER( ocnCouComm, rankInOcnComm ) // hijack this rank 00428 } 00429 00430 // need to compute graph between phys atm and atm/ocn intx coverage 00431 if( atmCouComm != MPI_COMM_NULL ) 00432 { 00433 int typeA = 2; // point cloud, phys mesh 00434 int typeB = 3; // cells of atmosphere, dof based; maybe need another type for ParCommGraph graphtype ? 00435 ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmOcnPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB, 00436 &cmpPhysAtm, &atmocnid ); 00437 CHECKIERR( ierr, "cannot compute graph between phys grid on atm and intx between FV atm and ocn" ) 00438 } 00439 00440 // also 00441 // need to compute graph between ocn/atm intx and phys atm mesh 00442 /*if( atmCouComm != MPI_COMM_NULL ) 00443 { 00444 int typeA = 3; // cells of atmosphere, dof based; maybe need another type for ParCommGraph graphtype ? 00445 int typeB = 2; // point cloud, phys mesh 00446 ierr = iMOAB_ComputeCommGraph( cplOcnAtmPID, cmpPhAtmPID, &atmCouComm, &couPEGroup, &atmPEGroup, &typeA, &typeB, 00447 &ocnatmid, &cmpatm ); 00448 }*/ 00449 // need to compute graph between atm on coupler and phys atm mesh on component 00450 if( atmCouComm != MPI_COMM_NULL ) 00451 { 00452 int typeA = 2; // point cloud, phys mesh 00453 int typeB = 3; // cells of atmosphere, dof based; need another type for ParCommGraph graphtype ? 00454 ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB, 00455 &cmpPhysAtm, &cplatm ); 00456 CHECKIERR( ierr, "cannot compute graph between phys grid on atm and FV atm on coupler" ) 00457 } 00458 #endif 00459 00460 #ifdef ENABLE_ATMLND_COUPLING 00461 if( couComm != MPI_COMM_NULL ) 00462 { 00463 PUSH_TIMER( "Compute ATM-LND mesh intersection" ) 00464 ierr = iMOAB_ComputeMeshIntersectionOnSphere( cplAtmPID, cplLndPID, cplAtmLndPID ); 00465 CHECKIERR( ierr, "failed to compute atm - land intx for mapping" ); 00466 POP_TIMER( couComm, rankInCouComm ) 00467 00468 PUSH_TIMER( "Compute LND-ATM mesh intersection" ) 00469 ierr = 00470 iMOAB_ComputeMeshIntersectionOnSphere( cplLndPID, cplAtmPID, cplLndAtmPID ); // coverage mesh was computed 00471 CHECKIERR( ierr, "cannot compute intersection" ) 00472 POP_TIMER( couComm, rankInCouComm ) 00473 } 00474 if( atmCouComm != MPI_COMM_NULL ) 00475 { 00476 // the new graph will be for sending data from atm comp to coverage mesh for land mesh; 00477 // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID 00478 // results are in cplAtmLndPID, intx mesh; remapper also has some info about coverage mesh 00479 // after this, the sending of tags from atm pes to coupler pes will use the new par comm graph, that has more 00480 // precise info about what to send (specifically for land cover); every time, 00481 /// we will use the element global id, which should uniquely identify the element 00482 PUSH_TIMER( "Compute LND coverage graph for ATM mesh" ) 00483 ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmLndPID, &cmpatm, &cplatm, 00484 &cpllnd ); // it happens over joint communicator 00485 CHECKIERR( ierr, "cannot recompute direct coverage graph for land" ) 00486 POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank 00487 } 00488 00489 // we will compute comm graph between atm phys and land, directly; 00490 // on the new TriGrid workflow, we do need intersection between atm and land; 00491 if( atmCouComm != MPI_COMM_NULL ) 00492 { 00493 int typeA = 2; // point cloud 00494 int typeB = 3; // type 3 for land on coupler, based on global ids for land cells ? 00495 ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmLndPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, &typeB, 00496 &cmpPhysAtm, &atmlndid ); 00497 CHECKIERR( ierr, "cannot compute comm graph between atm and atm/lnd intersection" ) 00498 } 00499 00500 // for reverse direction, lnd - atm intx: 00501 if( lndCouComm != MPI_COMM_NULL ) 00502 { 00503 // now for the second intersection, lnd-atm; will be sending data from lnd to atm 00504 // Can we reuse the intx atm-lnd? Not sure yet; we will compute everything again :( 00505 // the new graph will be for sending data from lnd comp to coverage mesh over atm; 00506 // it involves initial lnd app; cmpLndPID; also migrated lnd mesh on coupler pes, cplLndPID 00507 // results are in cplLndAtmPID, intx mesh; remapper also has some info about coverage mesh 00508 // after this, the sending of tags from lnd pes to coupler pes will use the new par comm graph, that has more 00509 // precise info about what to send for atm cover ; every time, we will 00510 // use the element global id, which should uniquely identify the element 00511 PUSH_TIMER( "Compute ATM coverage graph for LND mesh" ) 00512 ierr = iMOAB_CoverageGraph( &lndCouComm, cmpLndPID, cplLndPID, cplLndAtmPID, &cmplnd, &cpllnd, 00513 &cplatm ); // it happens over joint communicator, ocean + coupler 00514 CHECKIERR( ierr, "cannot recompute direct coverage graph for atm for intx with land" ) 00515 POP_TIMER( lndCouComm, rankInLndComm ) 00516 } 00517 #endif 00518 MPI_Barrier( MPI_COMM_WORLD ); 00519 00520 int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 1, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0; 00521 00522 #ifdef ENABLE_ATMOCN_COUPLING 00523 #ifdef VERBOSE 00524 if( couComm != MPI_COMM_NULL ) 00525 { 00526 char serialWriteOptions[] = ""; // for writing in serial 00527 std::stringstream outf; 00528 outf << "intxAtmOcn_" << rankInCouComm << ".h5m"; 00529 std::string intxfile = outf.str(); // write in serial the intx file, for debugging 00530 ierr = iMOAB_WriteMesh( cplAtmOcnPID, intxfile.c_str(), serialWriteOptions ); 00531 CHECKIERR( ierr, "cannot write intx file result" ) 00532 } 00533 #endif 00534 00535 if( couComm != MPI_COMM_NULL ) 00536 { 00537 PUSH_TIMER( "Compute the projection weights with TempestRemap" ) 00538 ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0], disc_methods[1], 00539 &disc_orders[1], // fv 00540 disc_methods[1], &disc_orders[1], // fv 00541 &fNoBubble, &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, 00542 &fNoConserve, &fValidate, dof_tag_names[1], dof_tag_names[1] ); 00543 CHECKIERR( ierr, "cannot compute scalar projection weights" ) 00544 POP_TIMER( couComm, rankInCouComm ) 00545 } 00546 00547 // now compute weight maps for ocn to atm mapping; 00548 if( couComm != MPI_COMM_NULL ) 00549 { 00550 PUSH_TIMER( "Compute the projection weights with TempestRemap for ocn - atm map" ) 00551 ierr = iMOAB_ComputeScalarProjectionWeights( cplOcnAtmPID, weights_identifiers[0], disc_methods[1], 00552 &disc_orders[1], // fv 00553 disc_methods[1], &disc_orders[1], // fv 00554 &fNoBubble, &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, 00555 &fNoConserve, &fValidate, dof_tag_names[1], dof_tag_names[1] ); 00556 CHECKIERR( ierr, "cannot compute scalar projection weights" ) 00557 POP_TIMER( couComm, rankInCouComm ) 00558 } 00559 00560 #endif 00561 00562 MPI_Barrier( MPI_COMM_WORLD ); 00563 00564 // we do not need to compute weights ? just send tags between dofs ? 00565 00566 #ifdef ENABLE_ATMLND_COUPLING 00567 if( couComm != MPI_COMM_NULL ) 00568 { 00569 // Compute the weights to project the solution from ATM component to LND component 00570 PUSH_TIMER( "Compute ATM-LND remapping weights" ) 00571 ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmLndPID, weights_identifiers[0], disc_methods[1], 00572 &disc_orders[1], disc_methods[1], &disc_orders[1], &fNoBubble, 00573 &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, 00574 &fValidate, dof_tag_names[1], dof_tag_names[1] ); 00575 CHECKIERR( ierr, "failed to compute remapping projection weights for ATM-LND scalar non-conservative field" ); 00576 POP_TIMER( couComm, rankInCouComm ) 00577 00578 // Compute the weights to project the solution from LND component to ATM component 00579 PUSH_TIMER( "Compute LND-ATM remapping weights" ) 00580 ierr = iMOAB_ComputeScalarProjectionWeights( cplLndAtmPID, weights_identifiers[0], disc_methods[1], 00581 &disc_orders[1], disc_methods[1], &disc_orders[1], &fNoBubble, 00582 &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, 00583 &fValidate, dof_tag_names[1], dof_tag_names[1] ); 00584 CHECKIERR( ierr, "failed to compute remapping projection weights for LND-ATM scalar non-conservative field" ); 00585 POP_TIMER( couComm, rankInCouComm ) 00586 } 00587 #endif 00588 00589 int tagIndex[2]; 00590 int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE }; 00591 int atmCompNDoFs = 1 /* FV disc_orders[0]*disc_orders[0] */, ocnCompNDoFs = 1 /*FV*/; 00592 00593 const char* bottomFields = "T_ph:u_ph:v_ph"; // same as on phys atm mesh 00594 00595 const char* bottomProjectedFields = "T_proj:u_proj:v_proj"; 00596 00597 // coming from ocn to atm, project back from T_proj 00598 const char* bottomFields2 = "T2_ph:u2_ph:v2_ph"; // same as on phys atm mesh 00599 00600 // coming from lnd to atm, project back from T_proj 00601 const char* bottomFields3 = "T3_ph:u3_ph:v3_ph"; // same as on phys atm mesh 00602 00603 // tags on phys grid atm mesh 00604 const char* bottomPhProjectedFields = "Tph_proj:uph_proj:vph_proj"; 00605 00606 // tags on phys grid atm mesh 00607 const char* bottomPhLndProjectedFields = 00608 "TphL_proj:uphL_proj:vphL_proj"; // L and Lnd signify the fields projected from land 00609 00610 if( couComm != MPI_COMM_NULL ) 00611 { 00612 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00613 CHECKIERR( ierr, "failed to define the field tags T_ph, u_ph, v_ph " ); 00614 #ifdef ENABLE_ATMOCN_COUPLING 00615 00616 ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00617 CHECKIERR( ierr, "failed to define the field tags T_proj, u_proj, v_proj " ); 00618 #endif 00619 00620 #ifdef ENABLE_ATMLND_COUPLING 00621 // need to define tag storage for land; will use the same T_proj, u_proj, v_proj name, because it will be 00622 // used to send between point clouds ! 00623 // use the same ndof and same size as ocnCompNDoFs (1) !! 00624 ierr = iMOAB_DefineTagStorage( cplLndPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00625 CHECKIERR( ierr, "failed to define the field tags T_proj, u_proj, v_proj" ); 00626 #endif 00627 } 00628 // need to make sure that the coverage mesh (created during intx method) received the tag that need to be projected 00629 // to target so far, the coverage mesh has only the ids and global dofs; need to change the migrate method to 00630 // accommodate any GLL tag now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh 00631 // (cplAtmPID), using the new coverage graph communicator 00632 00633 // make the tag 0, to check we are actually sending needed data 00634 { 00635 if( cplAtmAppID >= 0 ) 00636 { 00637 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00638 /* 00639 * Each process in the communicator will have access to a local mesh instance, which will contain the 00640 * original cells in the local partition and ghost entities. Number of vertices, primary cells, visible 00641 * blocks, number of sidesets and nodesets boundary conditions will be returned in numProcesses 3 arrays, 00642 * for local, ghost and total numbers. 00643 */ 00644 ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); 00645 CHECKIERR( ierr, "failed to get num primary elems" ); 00646 int numAllElem = nelem[2]; 00647 std::vector< double > vals; 00648 int storLeng = atmCompNDoFs * numAllElem * 3; // 3 tags 00649 vals.resize( storLeng ); 00650 for( int k = 0; k < storLeng; k++ ) 00651 vals[k] = 0.; 00652 int eetype = 1; 00653 ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFields, &storLeng, &eetype, &vals[0] ); 00654 CHECKIERR( ierr, "cannot make tag nul" ) 00655 // set the tag to 0 00656 } 00657 } 00658 00659 #ifdef ENABLE_ATMOCN_COUPLING 00660 PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" ) 00661 if( atmComm != MPI_COMM_NULL ) 00662 { 00663 // as always, use nonblocking sends 00664 // this is for projection to ocean: 00665 ierr = iMOAB_SendElementTag( cmpPhAtmPID, "T_ph:u_ph:v_ph", &atmCouComm, &atmocnid ); 00666 CHECKIERR( ierr, "cannot send tag values" ) 00667 } 00668 if( couComm != MPI_COMM_NULL ) 00669 { 00670 // receive on atm on coupler pes, that was redistributed according to coverage 00671 ierr = iMOAB_ReceiveElementTag( cplAtmOcnPID, "T_ph:u_ph:v_ph", &atmCouComm, &cmpPhysAtm ); 00672 CHECKIERR( ierr, "cannot receive tag values on intx atm ocn" ) 00673 } 00674 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00675 00676 // we can now free the sender buffers 00677 if( atmComm != MPI_COMM_NULL ) 00678 { 00679 ierr = iMOAB_FreeSenderBuffers( cmpPhAtmPID, &atmocnid ); // context is for ocean 00680 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00681 } 00682 /* 00683 #ifdef VERBOSE 00684 if (couComm != MPI_COMM_NULL) { 00685 char outputFileRecvd[] = "recvAtmCoupOcn.h5m"; 00686 ierr = iMOAB_WriteMesh(cplAtmPID, outputFileRecvd, fileWriteOptions ); 00687 } 00688 #endif 00689 */ 00690 00691 if( couComm != MPI_COMM_NULL ) 00692 { 00693 const char* concat_fieldname = "T_ph:u_ph:v_ph"; 00694 const char* concat_fieldnameT = "T_proj:u_proj:v_proj"; 00695 00696 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00697 on the source mesh and get the projection on the target mesh */ 00698 PUSH_TIMER( "Apply Scalar projection weights" ) 00699 ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0], concat_fieldname, 00700 concat_fieldnameT ); 00701 CHECKIERR( ierr, "failed to compute projection weight application" ); 00702 POP_TIMER( couComm, rankInCouComm ) 00703 00704 char outputFileTgt[] = "fOcnOnCpl3.h5m"; 00705 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); 00706 CHECKIERR( ierr, "failed to write fOcnOnCpl3.h5m " ); 00707 } 00708 // send the projected tag back to ocean pes, with send/receive tag 00709 if( ocnComm != MPI_COMM_NULL ) 00710 { 00711 int tagIndexIn2; 00712 ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); 00713 CHECKIERR( ierr, 00714 "failed to define the field tag for receiving back the tag T_proj, u_proj, v_proj on ocn pes" ); 00715 } 00716 // send the tag to ocean pes, from ocean mesh on coupler pes 00717 // from couComm, using common joint comm ocn_coupler 00718 // as always, use nonblocking sends 00719 // original graph (context is -1_ 00720 if( couComm != MPI_COMM_NULL ) 00721 { 00722 context_id = cmpocn; 00723 ierr = iMOAB_SendElementTag( cplOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &context_id ); 00724 CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) 00725 } 00726 00727 // receive on component 2, ocean 00728 if( ocnComm != MPI_COMM_NULL ) 00729 { 00730 context_id = cplocn; 00731 ierr = iMOAB_ReceiveElementTag( cmpOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &context_id ); 00732 CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) 00733 } 00734 00735 MPI_Barrier( MPI_COMM_WORLD ); 00736 00737 if( couComm != MPI_COMM_NULL ) 00738 { 00739 context_id = cmpocn; 00740 ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); 00741 CHECKIERR( ierr, "cannot free buffers related to send tag" ) 00742 } 00743 if( ocnComm != MPI_COMM_NULL ) 00744 { 00745 char outputFileOcn[] = "OcnWithProj3.h5m"; 00746 ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); 00747 CHECKIERR( ierr, "cannot write OcnWithProj3.h5m" ) 00748 } 00749 #endif 00750 00751 MPI_Barrier( MPI_COMM_WORLD ); 00752 00753 #ifdef ENABLE_ATMLND_COUPLING 00754 // start land proj: 00755 00756 // we used this to compute 00757 // ierr = iMOAB_ComputeCommGraph(cmpPhAtmPID, cplLndPID, &atmCouComm, &atmPEGroup, &couPEGroup, 00758 // &typeA, &typeB, &cmpPhysAtm, &atmlndid); 00759 00760 // end copy 00761 PUSH_TIMER( "Send/receive data from phys comp atm to coupler land, using computed graph" ) 00762 if( atmComm != MPI_COMM_NULL ) 00763 { 00764 00765 // as always, use nonblocking sends 00766 // this is for projection to land: 00767 ierr = iMOAB_SendElementTag( cmpPhAtmPID, "T_ph:u_ph:v_ph", &atmCouComm, &atmlndid ); 00768 CHECKIERR( ierr, "cannot send tag values towards cpl on land" ) 00769 } 00770 if( couComm != MPI_COMM_NULL ) 00771 { 00772 // receive on lnd on coupler pes 00773 ierr = iMOAB_ReceiveElementTag( cplAtmLndPID, "T_ph:u_ph:v_ph", &atmCouComm, &cmpPhysAtm ); 00774 CHECKIERR( ierr, "cannot receive tag values on land on coupler, for atm coupling" ) 00775 } 00776 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00777 00778 // we can now free the sender buffers 00779 if( atmComm != MPI_COMM_NULL ) 00780 { 00781 ierr = iMOAB_FreeSenderBuffers( cmpPhAtmPID, &atmlndid ); 00782 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the land on coupler" ) 00783 } 00784 00785 if( couComm != MPI_COMM_NULL ) 00786 { 00787 const char* concat_fieldname = "T_ph:u_ph:v_ph"; 00788 const char* concat_fieldnameT = "T_proj:u_proj:v_proj"; 00789 00790 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00791 on the source mesh and get the projection on the target mesh */ 00792 PUSH_TIMER( "Apply Scalar projection weights" ) 00793 ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmLndPID, weights_identifiers[0], concat_fieldname, 00794 concat_fieldnameT ); 00795 CHECKIERR( ierr, "failed to compute projection weight application" ); 00796 POP_TIMER( couComm, rankInCouComm ) 00797 00798 char outputFileTgt[] = "fLndOnCpl3.h5m"; 00799 ierr = iMOAB_WriteMesh( cplLndPID, outputFileTgt, fileWriteOptions ); 00800 CHECKIERR( ierr, "cannot write land on coupler" ) 00801 } 00802 00803 // end land proj 00804 // send the tags back to land pes, from land mesh on coupler pes 00805 // send from cplLndPID to cmpLndPID, using common joint comm 00806 // as always, use nonblocking sends 00807 // original graph 00808 // int context_id = -1; 00809 // the land might not have these tags yet; it should be a different name for land 00810 // in e3sm we do have different names 00811 if( lndComm != MPI_COMM_NULL ) 00812 { 00813 int tagIndexIn2; 00814 ierr = iMOAB_DefineTagStorage( cmpLndPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); 00815 CHECKIERR( ierr, 00816 "failed to define the field tag for receiving back the tag T_proj, u_proj, v_proj on lnd pes" ); 00817 } 00818 if( couComm != MPI_COMM_NULL ) 00819 { 00820 context_id = cmplnd; 00821 ierr = iMOAB_SendElementTag( cplLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &context_id ); 00822 CHECKIERR( ierr, "cannot send tag values back to land pes" ) 00823 } 00824 // receive on component 3, land 00825 if( lndComm != MPI_COMM_NULL ) 00826 { 00827 context_id = cpllnd; 00828 ierr = iMOAB_ReceiveElementTag( cmpLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &context_id ); 00829 CHECKIERR( ierr, "cannot receive tag values from land mesh on coupler pes" ) 00830 } 00831 00832 MPI_Barrier( MPI_COMM_WORLD ); 00833 if( couComm != MPI_COMM_NULL ) 00834 { 00835 context_id = cmplnd; 00836 ierr = iMOAB_FreeSenderBuffers( cplLndPID, &context_id ); 00837 CHECKIERR( ierr, "cannot free buffers related to sending tags from coupler to land pes" ) 00838 } 00839 if( lndComm != MPI_COMM_NULL ) 00840 { 00841 char outputFileLnd[] = "LndWithProj3.h5m"; 00842 ierr = iMOAB_WriteMesh( cmpLndPID, outputFileLnd, fileWriteOptions ); 00843 CHECKIERR( ierr, "cannot write land file with projection" ) 00844 } 00845 00846 // we have received on ocean component some data projected from atm, on coupler 00847 00848 // path was T_ph (atm phys) towards atm on FV mesh, we projected, then we sent back to ocean comp 00849 // start copy ocn atm coupling; go reverse direction now !! 00850 #ifdef ENABLE_ATMOCN_COUPLING 00851 PUSH_TIMER( "Send/receive data from ocn component to coupler in atm context" ) 00852 if( ocnComm != MPI_COMM_NULL ) 00853 { 00854 // as always, use nonblocking sends 00855 // this is for projection to ocean: 00856 ierr = iMOAB_SendElementTag( cmpOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &cplatm ); 00857 CHECKIERR( ierr, "cannot send tag values T_proj, etc towards ocn coupler" ) 00858 } 00859 if( couComm != MPI_COMM_NULL ) 00860 { 00861 // receive on ocn on coupler pes, that was redistributed according to coverage 00862 ierr = iMOAB_ReceiveElementTag( cplOcnPID, "T_proj:u_proj:v_proj", &ocnCouComm, &cplatm ); 00863 CHECKIERR( ierr, "cannot receive tag values" ) 00864 } 00865 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00866 00867 // we can now free the sender buffers 00868 if( ocnComm != MPI_COMM_NULL ) 00869 { 00870 ierr = iMOAB_FreeSenderBuffers( cmpOcnPID, &cplatm ); // context is for atm 00871 CHECKIERR( ierr, "cannot free buffers used to send ocn tag towards the coverage mesh for atm" ) 00872 } 00873 //#ifdef VERBOSE 00874 if( couComm != MPI_COMM_NULL ) 00875 { 00876 // write only for n==1 case 00877 char outputFileRecvd[] = "recvOcnCpl.h5m"; 00878 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileRecvd, fileWriteOptions ); 00879 CHECKIERR( ierr, "could not write recvOcnCplOcn.h5m to disk" ) 00880 } 00881 //#endif 00882 00883 if( couComm != MPI_COMM_NULL ) 00884 { 00885 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00886 on the source mesh and get the projection on the target mesh */ 00887 00888 const char* concat_fieldname = "T_proj:u_proj:v_proj"; // this is now source tag 00889 const char* concat_fieldnameT = "T2_ph:u2_ph:v2_ph"; // projected tag on 00890 // make sure the new tags exist on atm coupler mesh; 00891 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields2, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00892 CHECKIERR( ierr, "failed to define the field tags T2_ph, u2_ph, v2_ph" ); 00893 00894 PUSH_TIMER( "Apply Scalar projection weights" ) 00895 ierr = iMOAB_ApplyScalarProjectionWeights( cplLndAtmPID, weights_identifiers[0], concat_fieldname, 00896 concat_fieldnameT ); 00897 CHECKIERR( ierr, "failed to compute projection weight application" ); 00898 POP_TIMER( couComm, rankInCouComm ) 00899 00900 char outputFileTgt[] = "fAtm2OnCpl2.h5m"; 00901 ierr = iMOAB_WriteMesh( cplAtmPID, outputFileTgt, fileWriteOptions ); 00902 CHECKIERR( ierr, "could not write fAtm2OnCpl.h5m to disk" ) 00903 } 00904 00905 // send the projected tag back to atm pes, with send/receive partial par graph computed 00906 // from intx ocn/atm towards atm physics mesh ! 00907 if( atmComm != MPI_COMM_NULL ) 00908 { 00909 int tagIndexIn2; 00910 ierr = 00911 iMOAB_DefineTagStorage( cmpPhAtmPID, bottomPhProjectedFields, &tagTypes[1], &atmCompNDoFs, &tagIndexIn2 ); 00912 CHECKIERR( ierr, "failed to define the field tag for receiving back the tag " 00913 "Tph_proj, etc on atm pes" ); 00914 } 00915 // send the tag to atm pes, from atm pg2 mesh on coupler pes 00916 // from couComm, using common joint comm atm_coupler, and computed graph, phys-grid -> atm FV on cpl, in reverse 00917 // as always, use nonblocking sends 00918 // graph context comes from commgraph ? 00919 00920 // ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, 00921 // &typeB, 00922 // &cmpatm, &cplatm ); 00923 00924 if( couComm != MPI_COMM_NULL ) 00925 { 00926 context_id = cmpPhysAtm; 00927 ierr = iMOAB_SendElementTag( cplAtmPID, "T2_ph:u2_ph:v2_ph", &atmCouComm, &context_id ); 00928 CHECKIERR( ierr, "cannot send tag values back to atm pes" ) 00929 } 00930 00931 // receive on component atm phys mesh 00932 if( atmComm != MPI_COMM_NULL ) 00933 { 00934 context_id = cplatm; 00935 ierr = iMOAB_ReceiveElementTag( cmpPhAtmPID, "Tph_proj:uph_proj:vph_proj", &atmCouComm, &context_id ); 00936 CHECKIERR( ierr, "cannot receive tag values from atm pg2 mesh on coupler pes" ) 00937 } 00938 00939 MPI_Barrier( MPI_COMM_WORLD ); 00940 00941 if( couComm != MPI_COMM_NULL ) 00942 { 00943 context_id = cmpatm; 00944 ierr = iMOAB_FreeSenderBuffers( cplAtmPID, &context_id ); 00945 CHECKIERR( ierr, "cannot free buffers for sending T2_ph from cpl to phys atm" ) 00946 } 00947 if( atmComm != MPI_COMM_NULL ) // write only for n==1 case 00948 { 00949 char outputFileAtmPh[] = "AtmPhysProj.h5m"; 00950 ierr = iMOAB_WriteMesh( cmpPhAtmPID, outputFileAtmPh, fileWriteOptions ); 00951 CHECKIERR( ierr, "could not write AtmPhysProj.h5m to disk" ) 00952 } 00953 #endif 00954 // end copy need more work for land 00955 // start copy 00956 // lnd atm coupling; go reverse direction now, from lnd to atm , using lnd - atm intx, weight gen 00957 // send back the T_proj , etc , from lan comp to land coupler 00958 #ifdef ENABLE_ATMLND_COUPLING 00959 PUSH_TIMER( "Send/receive data from lnd component to coupler in atm context" ) 00960 if( lndComm != MPI_COMM_NULL ) 00961 { 00962 // as always, use nonblocking sends 00963 ierr = iMOAB_SendElementTag( cmpLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &cplatm ); 00964 CHECKIERR( ierr, "cannot send tag values T_proj, etc towards lnd coupler" ) 00965 } 00966 if( couComm != MPI_COMM_NULL ) 00967 { 00968 // receive on ocn on coupler pes, that was redistributed according to coverage 00969 ierr = iMOAB_ReceiveElementTag( cplLndPID, "T_proj:u_proj:v_proj", &lndCouComm, &cplatm ); 00970 CHECKIERR( ierr, "cannot receive tag values on land" ) 00971 } 00972 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00973 00974 // we can now free the sender buffers 00975 if( lndComm != MPI_COMM_NULL ) 00976 { 00977 ierr = iMOAB_FreeSenderBuffers( cmpLndPID, &cplatm ); // context is for atm 00978 CHECKIERR( ierr, "cannot free buffers used to send lnd tag towards the coverage mesh for atm" ) 00979 } 00980 //#ifdef VERBOSE 00981 if( couComm != MPI_COMM_NULL ) 00982 { 00983 00984 char outputFileRecvd[] = "recvLndCpl.h5m"; 00985 ierr = iMOAB_WriteMesh( cplLndPID, outputFileRecvd, fileWriteOptions ); 00986 CHECKIERR( ierr, "could not write recvLndCpl.h5m to disk" ) 00987 } 00988 //#endif 00989 00990 if( couComm != MPI_COMM_NULL ) 00991 { 00992 PUSH_TIMER( "Apply Scalar projection weights for lnd - atm coupling" ) 00993 const char* concat_fieldname = "T_proj:u_proj:v_proj"; // this is now source tag, on land cpl 00994 const char* concat_fieldnameT = "T3_ph:u3_ph:v3_ph"; // projected tag on 00995 // make sure the new tags exist on atm coupler mesh; 00996 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields3, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00997 CHECKIERR( ierr, "failed to define the field tag T3_ph" ); 00998 00999 ierr = iMOAB_ApplyScalarProjectionWeights( cplLndAtmPID, weights_identifiers[0], concat_fieldname, 01000 concat_fieldnameT ); 01001 CHECKIERR( ierr, "failed to compute projection weight application from lnd to atm " ); 01002 POP_TIMER( couComm, rankInCouComm ) 01003 01004 char outputFileTgt[] = "fAtm3OnCpl.h5m"; // this is for T3_ph, etc 01005 ierr = iMOAB_WriteMesh( cplAtmPID, outputFileTgt, fileWriteOptions ); 01006 CHECKIERR( ierr, "could not write fAtm3OnCpl.h5m to disk" ) 01007 } 01008 01009 // send the projected tag back to atm pes, with send/receive partial par graph computed 01010 // from intx lnd/atm towards atm physics mesh ! 01011 if( atmComm != MPI_COMM_NULL ) 01012 { 01013 int tagIndexIn2; 01014 ierr = iMOAB_DefineTagStorage( cmpPhAtmPID, bottomPhLndProjectedFields, &tagTypes[1], &atmCompNDoFs, 01015 &tagIndexIn2 ); 01016 CHECKIERR( ierr, "failed to define the field tag for receiving back the tag " 01017 "TphL_proj, on atm pes" ); 01018 } 01019 // send the tag to atm pes, from atm pg2 mesh on coupler pes 01020 // from couComm, using common joint comm atm_coupler, and computed graph, phys-grid -> atm FV on cpl, in reverse 01021 // as always, use nonblocking sends 01022 // graph context comes from commgraph ? 01023 01024 // ierr = iMOAB_ComputeCommGraph( cmpPhAtmPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &typeA, 01025 // &typeB, 01026 // &cmpatm, &cplatm ); 01027 01028 if( couComm != MPI_COMM_NULL ) 01029 { 01030 context_id = cmpPhysAtm; 01031 ierr = iMOAB_SendElementTag( cplAtmPID, "T3_ph:u3_ph:v3_ph", &atmCouComm, &context_id ); 01032 CHECKIERR( ierr, "cannot send tag values back to atm pes" ) 01033 } 01034 01035 // receive on component atm phys mesh 01036 if( atmComm != MPI_COMM_NULL ) 01037 { 01038 context_id = cplatm; 01039 ierr = iMOAB_ReceiveElementTag( cmpPhAtmPID, "TphL_proj:uphL_proj:vphL_proj", &atmCouComm, &context_id ); 01040 CHECKIERR( ierr, "cannot receive tag values from atm pg2 mesh on coupler pes" ) 01041 } 01042 01043 MPI_Barrier( MPI_COMM_WORLD ); 01044 01045 if( couComm != MPI_COMM_NULL ) 01046 { 01047 context_id = cmpatm; 01048 ierr = iMOAB_FreeSenderBuffers( cplAtmPID, &context_id ); 01049 CHECKIERR( ierr, "cannot free buffers used for sending back atm tags " ) 01050 } 01051 if( atmComm != MPI_COMM_NULL ) // write only for n==1 case 01052 { 01053 char outputFileAtmPh[] = "AtmPhysProj3.h5m"; 01054 ierr = iMOAB_WriteMesh( cmpPhAtmPID, outputFileAtmPh, fileWriteOptions ); 01055 CHECKIERR( ierr, "could not write AtmPhysProj3.h5m to disk" ) 01056 } 01057 #endif 01058 // we could deregister cplLndAtmPID 01059 if( couComm != MPI_COMM_NULL ) 01060 { 01061 ierr = iMOAB_DeregisterApplication( cplLndAtmPID ); 01062 CHECKIERR( ierr, "cannot deregister app intx LA" ) 01063 } 01064 01065 // we could deregister cplAtmLndPID 01066 if( couComm != MPI_COMM_NULL ) 01067 { 01068 ierr = iMOAB_DeregisterApplication( cplAtmLndPID ); 01069 CHECKIERR( ierr, "cannot deregister app intx AL" ) 01070 } 01071 #endif // ENABLE_ATMLND_COUPLING 01072 01073 #ifdef ENABLE_ATMOCN_COUPLING 01074 if( couComm != MPI_COMM_NULL ) 01075 { 01076 ierr = iMOAB_DeregisterApplication( cplOcnAtmPID ); 01077 CHECKIERR( ierr, "cannot deregister app intx OA" ) 01078 } 01079 if( couComm != MPI_COMM_NULL ) 01080 { 01081 ierr = iMOAB_DeregisterApplication( cplAtmOcnPID ); 01082 CHECKIERR( ierr, "cannot deregister app intx AO" ) 01083 } 01084 #endif 01085 01086 #ifdef ENABLE_ATMLND_COUPLING 01087 if( lndComm != MPI_COMM_NULL ) 01088 { 01089 ierr = iMOAB_DeregisterApplication( cmpLndPID ); 01090 CHECKIERR( ierr, "cannot deregister app LND1" ) 01091 } 01092 #endif // ENABLE_ATMLND_COUPLING 01093 if( atmComm != MPI_COMM_NULL ) 01094 { 01095 ierr = iMOAB_DeregisterApplication( cmpPhAtmPID ); 01096 CHECKIERR( ierr, "cannot deregister app PhysAtm " ) 01097 } 01098 #ifdef ENABLE_ATMOCN_COUPLING 01099 if( ocnComm != MPI_COMM_NULL ) 01100 { 01101 ierr = iMOAB_DeregisterApplication( cmpOcnPID ); 01102 CHECKIERR( ierr, "cannot deregister app OCN1" ) 01103 } 01104 #endif // ENABLE_ATMOCN_COUPLING 01105 01106 if( atmComm != MPI_COMM_NULL ) 01107 { 01108 ierr = iMOAB_DeregisterApplication( cmpAtmPID ); 01109 CHECKIERR( ierr, "cannot deregister app ATM1" ) 01110 } 01111 01112 #ifdef ENABLE_ATMLND_COUPLING 01113 if( couComm != MPI_COMM_NULL ) 01114 { 01115 ierr = iMOAB_DeregisterApplication( cplLndPID ); 01116 CHECKIERR( ierr, "cannot deregister app LNDX" ) 01117 } 01118 #endif // ENABLE_ATMLND_COUPLING 01119 01120 #ifdef ENABLE_ATMOCN_COUPLING 01121 if( couComm != MPI_COMM_NULL ) 01122 { 01123 ierr = iMOAB_DeregisterApplication( cplOcnPID ); 01124 CHECKIERR( ierr, "cannot deregister app OCNX" ) 01125 } 01126 #endif // ENABLE_ATMOCN_COUPLING 01127 01128 if( couComm != MPI_COMM_NULL ) 01129 { 01130 ierr = iMOAB_DeregisterApplication( cplAtmPID ); 01131 CHECKIERR( ierr, "cannot deregister app ATMX" ) 01132 } 01133 01134 //#endif 01135 ierr = iMOAB_Finalize(); 01136 CHECKIERR( ierr, "did not finalize iMOAB" ) 01137 01138 // free atm coupler group and comm 01139 if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm ); 01140 MPI_Group_free( &joinAtmCouGroup ); 01141 if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm ); 01142 01143 #ifdef ENABLE_ATMOCN_COUPLING 01144 if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm ); 01145 // free ocn - coupler group and comm 01146 if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm ); 01147 MPI_Group_free( &joinOcnCouGroup ); 01148 #endif 01149 01150 #ifdef ENABLE_ATMLND_COUPLING 01151 if( MPI_COMM_NULL != lndComm ) MPI_Comm_free( &lndComm ); 01152 // free land - coupler group and comm 01153 if( MPI_COMM_NULL != lndCouComm ) MPI_Comm_free( &lndCouComm ); 01154 MPI_Group_free( &joinLndCouGroup ); 01155 #endif 01156 01157 if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm ); 01158 01159 MPI_Group_free( &atmPEGroup ); 01160 #ifdef ENABLE_ATMOCN_COUPLING 01161 MPI_Group_free( &ocnPEGroup ); 01162 #endif 01163 #ifdef ENABLE_ATMLND_COUPLING 01164 MPI_Group_free( &lndPEGroup ); 01165 #endif 01166 MPI_Group_free( &couPEGroup ); 01167 MPI_Group_free( &jgroup ); 01168 01169 MPI_Finalize(); 01170 // endif #if 0 01171 01172 return 0; 01173 }
