MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include <iostream>#include <fstream>#include <cstring>#include "moab/FBEngine.hpp"#include "moab/GeomTopoTool.hpp"#include "TestUtil.hpp"
Include dependency graph for crop_vol_test.cpp:Go to the source code of this file.
Functions | |
| ErrorCode | volume_test (FBEngine *pFacet) |
| void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
| int | main (int argc, char *argv[]) |
Variables | |
| std::string | filename_top |
| std::string | filename_bot |
| std::string | polygon_file_name |
| double | min_dot = 0.8 |
| std::string | vol_file |
| int | number_tests_successful = 0 |
| int | number_tests_failed = 0 |
| void handle_error_code | ( | ErrorCode | rv, |
| int & | number_failed, | ||
| int & | number_successful | ||
Definition at line 36 of file crop_vol_test.cpp.
References MB_SUCCESS.
if( rv == MB_SUCCESS )
std::cout << "Success";
number_successful++;
else
std::cout << "Failure";
number_failed++;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 50 of file crop_vol_test.cpp.
References ErrorCode, filename_bot, filename_top, handle_error_code(), moab::FBEngine::Init(), moab::Interface::load_file(), mb, MB_CHK_SET_ERR, mbcore, min_dot, number_tests_failed, number_tests_successful, polygon_file_name, vol_file, and volume_test().
filename_bot = TestDir + "unittest/BedCrop2.h5m";
filename_top = TestDir + "unittest/SECrop2.h5m"; //"/polyPB.txt";
polygon_file_name = TestDir + "unittest/poly14.txt";
vol_file = "volIce.h5m"; // output
number_tests_successful = 0;
bool remove_output = true;
if( argc == 1 )
std::cout << "Using default input files: " << filename_bot << " " << filename_top << " " << polygon_file_name
<< " " << min_dot << " " << vol_file << std::endl;
std::cout << " default output file: " << vol_file << " will be deleted \n";
else if( argc == 6 )
remove_output = false;
filename_bot = argv[1];
filename_top = argv[2];
polygon_file_name = argv[3];
min_dot = atof( argv[4] );
vol_file = argv[5];
else
std::cout << " wrong number of arguments\n";
return 1; // fail
Core mbcore;
Interface* mb = &mbcore;
ErrorCode rval = mb->load_file( filename_bot.c_str() );MB_CHK_SET_ERR( rval, "failed to load bed file" );
rval = mb->load_file( filename_top.c_str() ); // load the second face (we know we have one face in each file)
MB_CHK_SET_ERR( rval, "failed to load top file" );
FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed
if( !pFacet ) return 1; // error
// should the init be part of constructor or not?
// this is where the obb tree is constructed, and smooth faceting initialized, too.
rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" );
std::cout << "volume creation test: ";
rval = volume_test( pFacet );
handle_error_code( rval, number_tests_failed, number_tests_successful );
std::cout << "\n";
if( remove_output )
remove( vol_file.c_str() );
return number_tests_failed;
| ErrorCode volume_test | ( | FBEngine * | pFacet | ) |
Definition at line 108 of file crop_vol_test.cpp.
References moab::FBEngine::create_volume_with_direction(), moab::FBEngine::delete_smooth_tags(), moab::GeomTopoTool::duplicate_model(), ErrorCode, moab::FBEngine::get_gtt(), moab::GeomTopoTool::get_root_model_set(), moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), mb, MB_CHK_SET_ERR, min_dot, moab::FBEngine::moab_instance(), nr, polygon_file_name, root_set, moab::Range::size(), moab::FBEngine::split_surface_with_direction(), vol_file, and moab::Interface::write_file().
Referenced by main().
// there should be 2 faces in the model
std::ifstream datafile( polygon_file_name.c_str(), std::ifstream::in );
if( !datafile )
std::cout << "can't read file\n";
return MB_FAILURE;
char temp[100];
double direction[3]; // normalized
double gridSize;
datafile.getline( temp, 100 ); // first line
// get direction and mesh size along polygon segments, from file
sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize );
// NORMALIZE(direction);// just to be sure
std::vector< double > xyz;
while( !datafile.eof() )
// int id = 0;
double x, y, z;
int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z );
if( nr == 3 )
xyz.push_back( x );
xyz.push_back( y );
xyz.push_back( z );
int sizePolygon = (int)xyz.size() / 3;
if( sizePolygon < 3 )
std::cerr << " Not enough points in the polygon" << std::endl;
return MB_FAILURE;
EntityHandle root_set;
ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" );
int top = 2; // iBase_FACE;
Range faces;
rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in volume_test." );
if( 2 != faces.size() )
std::cerr << "expected 2 faces, top and bottom\n";
return MB_FAILURE;
EntityHandle newFace1; // first test is with closed surface
rval = pFacet->split_surface_with_direction( faces[0], xyz, direction, /*closed*/ 1, min_dot, newFace1 );MB_CHK_SET_ERR( rval, "Failed to crop first face." );
EntityHandle newFace2; // first test is with closed surface
rval = pFacet->split_surface_with_direction( faces[1], xyz, direction, /*closed*/ 1, min_dot, newFace2 );MB_CHK_SET_ERR( rval, "Failed to crop second face." );
// here we make the assumption that the edges, vertices are matching fine...
EntityHandle volume;
rval = pFacet->create_volume_with_direction( newFace1, newFace2, direction, volume );MB_CHK_SET_ERR( rval, "Failed to create volume." );
Interface* mb = pFacet->moab_instance();
pFacet->delete_smooth_tags();
// duplicate -- extract a new geom topo tool
GeomTopoTool* gtt = pFacet->get_gtt();
GeomTopoTool* duplicate = NULL;
std::vector< EntityHandle > gents;
gents.push_back( volume );
rval = gtt->duplicate_model( duplicate, &gents );MB_CHK_SET_ERR( rval, "Failed to extract volume." );
EntityHandle newRootSet = duplicate->get_root_model_set();
delete pFacet;
pFacet = NULL; // try not to write the obb tree
delete duplicate;
rval = mb->write_file( vol_file.c_str(), NULL, NULL, &newRootSet, 1 );
return rval;
| std::string filename_bot |
Definition at line 24 of file crop_vol_test.cpp.
| std::string filename_top |
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 23 of file crop_vol_test.cpp.
| double min_dot = 0.8 |
Definition at line 26 of file crop_vol_test.cpp.
Referenced by moab::FBEngine::initializeSmoothing(), main(), split_test(), and volume_test().
| int number_tests_failed = 0 |
Definition at line 30 of file crop_vol_test.cpp.
| int number_tests_successful = 0 |
Definition at line 29 of file crop_vol_test.cpp.
| std::string polygon_file_name |
Definition at line 25 of file crop_vol_test.cpp.
Referenced by main(), split_test(), and volume_test().
| std::string vol_file |
Definition at line 27 of file crop_vol_test.cpp.
Referenced by main(), and volume_test().
