MOAB: Mesh Oriented datABase
(version 5.4.1)
test mbground, a test for the FBEngine class, which is providing iGeom like methods to a MOAB db More...
#include "moab/Core.hpp"#include <iostream>#include <fstream>#include <set>#include <algorithm>#include <vector>#include <iterator>#include <iomanip>#include <cassert>#include <cstring>#include <cmath>#include "moab/FBEngine.hpp"#include "moab/GeomTopoTool.hpp"#include "TestUtil.hpp"
Include dependency graph for mbground_test.cpp:Go to the source code of this file.
Functions | |
| ErrorCode | split_test_across () |
| ErrorCode | verify_split () |
| void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
| int | main (int argc, char *argv[]) |
Variables | |
| std::string | filename |
| std::string | filename_out |
| std::string | polyline_file_name |
| double | min_dot = 0.8 |
| bool | keep_output |
| int | number_tests_successful = 0 |
| int | number_tests_failed = 0 |
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition in file mbground_test.cpp.
| void handle_error_code | ( | ErrorCode | rv, |
| int & | number_failed, | ||
| int & | number_successful | ||
Definition at line 44 of file mbground_test.cpp.
References MB_SUCCESS.
if( rv == MB_SUCCESS )
std::cout << "Success";
number_successful++;
else
std::cout << "Failure";
number_failed++;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 58 of file mbground_test.cpp.
References ErrorCode, filename, filename_out, handle_error_code(), moab::FBEngine::Init(), keep_output, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, mbcore, min_dot, number_tests_failed, number_tests_successful, polyline_file_name, split_test_across(), and verify_split().
filename = TestDir + "unittest/PB.h5m";
polyline_file_name = TestDir + "unittest/polyline.txt";
filename_out = "PB_ground.h5m";
min_dot = 0.8;
keep_output = false;
if( argc == 1 )
std::cout << "Using default input " << filename << " " << polyline_file_name << " " << min_dot << " "
<< filename_out << std::endl;
std::cout << " default output file: " << filename_out << " will be deleted \n";
else if( argc == 5 )
filename = argv[1];
polyline_file_name = argv[2];
min_dot = atof( argv[3] );
filename_out = argv[4];
keep_output = true;
else
std::cerr << "Usage: " << argv[0] << " [geom_filename] [polygon_file] [min_dot] [output_file]" << std::endl;
return 1;
Core mbcore;
Interface* mb = &mbcore;
ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load input file" );
FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed
if( !pFacet ) return 1; // error
// should the init be part of constructor or not?
// this is where the obb tree is constructed, and smooth faceting initialized, too.
rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" );
delete pFacet;
pFacet = NULL;
// split_test_across
std::cout << " split across test: ";
rval = split_test_across();
handle_error_code( rval, number_tests_failed, number_tests_successful );
std::cout << "\n";
std::cout << " verify split ";
rval = verify_split();
std::cout << "\n";
// when we are done, remove modified file if we want to
if( !keep_output )
remove( filename_out.c_str() );
return number_tests_failed;
Definition at line 124 of file mbground_test.cpp.
References moab::FBEngine::delete_smooth_tags(), ErrorCode, filename, filename_out, moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), moab::FBEngine::Init(), moab::Interface::load_file(), mb, MB_CHK_ERR, MB_CHK_SET_ERR, mbcore, nr, polyline_file_name, root_set, moab::Range::size(), moab::FBEngine::split_surface_with_direction(), and moab::Interface::write_file().
Referenced by main().
Core mbcore;
ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load already modified file" );
EntityHandle root_set;
rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" );
int top = 2; // iBase_FACE;
Range faces;
rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." );
if( faces.size() != 1 )
std::cout << "num faces model:" << faces.size() << "\n";
return MB_FAILURE; //
// check only the second face
EntityHandle second_face = faces[0];
// use the polyPB.txt file to get the trimming polygon
// read the file with the polygon user data
std::ifstream datafile( polyline_file_name.c_str(), std::ifstream::in );
if( !datafile )
std::cout << "can't read file\n";
return MB_FAILURE;
char temp[100];
double direction[3]; // normalized
double gridSize;
datafile.getline( temp, 100 ); // first line
// get direction and mesh size along polygon segments, from file
sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize );
// NORMALIZE(direction);// just to be sure
std::vector< double > xyz;
while( !datafile.eof() )
// int id = 0;
double x, y, z;
int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z );
if( nr == 3 )
xyz.push_back( x );
xyz.push_back( y );
xyz.push_back( z );
int sizePolygon = (int)xyz.size() / 3;
if( sizePolygon < 2 )
std::cerr << " Not enough points in the polygon" << std::endl;
return MB_FAILURE;
EntityHandle newFace; // this test is with a "grounding" line
// the second face should be the one that we want for test
rval = pFacet->split_surface_with_direction( second_face, xyz, direction, /*closed*/ 0,
/*min_dot */ 0.8, newFace );MB_CHK_ERR( rval );
// save a new database, with 3 faces, eventually
pFacet->delete_smooth_tags();
delete pFacet;
pFacet = NULL; // try not to write the obb tree
rval = mb->write_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "Writing mesh file failed\n" );
return rval;
Definition at line 206 of file mbground_test.cpp.
References moab::GeomTopoTool::check_model(), ErrorCode, filename_out, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, and MB_SUCCESS.
Interface* mb = new Core();
ErrorCode rval = mb->load_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "Loading mesh file failed\n" );
moab::GeomTopoTool gTopoTool( mb, true, 0, true, false );
if( !gTopoTool.check_model() ) return MB_FAILURE;
delete mb;
return MB_SUCCESS;
| std::string filename |
Definition at line 31 of file mbground_test.cpp.
| std::string filename_out |
Definition at line 32 of file mbground_test.cpp.
| bool keep_output |
Definition at line 35 of file mbground_test.cpp.
| double min_dot = 0.8 |
Definition at line 34 of file mbground_test.cpp.
| int number_tests_failed = 0 |
Definition at line 37 of file mbground_test.cpp.
| int number_tests_successful = 0 |
Definition at line 36 of file mbground_test.cpp.
| std::string polyline_file_name |
Definition at line 33 of file mbground_test.cpp.
Referenced by main(), and split_test_across().
