MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * This library is free software; you can redistribute it and/or 00003 * modify it under the terms of the GNU Lesser General Public 00004 * License as published by the Free Software Foundation; either 00005 * version 2.1 of the License, or (at your option) any later version. 00006 * 00007 */ 00008 /** 00009 * \file mbground_test.cpp 00010 * 00011 * \brief test mbground, a test for the FBEngine class, which is providing iGeom like methods to a 00012 * MOAB db 00013 * 00014 */ 00015 #include "moab/Core.hpp" 00016 #include <iostream> 00017 #include <fstream> 00018 #include <set> 00019 #include <algorithm> 00020 #include <vector> 00021 #include <iterator> 00022 #include <algorithm> 00023 #include <iomanip> 00024 #include <cassert> 00025 #include <cstring> 00026 #include <cmath> 00027 #include "moab/FBEngine.hpp" 00028 #include "moab/GeomTopoTool.hpp" 00029 #include "TestUtil.hpp" 00030 00031 std::string filename; 00032 std::string filename_out; 00033 std::string polyline_file_name; 00034 double min_dot = 0.8; 00035 bool keep_output; 00036 int number_tests_successful = 0; 00037 int number_tests_failed = 0; 00038 00039 using namespace moab; 00040 00041 ErrorCode split_test_across(); 00042 ErrorCode verify_split(); 00043 00044 void handle_error_code( ErrorCode rv, int& number_failed, int& number_successful ) 00045 { 00046 if( rv == MB_SUCCESS ) 00047 { 00048 std::cout << "Success"; 00049 number_successful++; 00050 } 00051 else 00052 { 00053 std::cout << "Failure"; 00054 number_failed++; 00055 } 00056 } 00057 00058 int main( int argc, char* argv[] ) 00059 { 00060 filename = TestDir + "unittest/PB.h5m"; 00061 polyline_file_name = TestDir + "unittest/polyline.txt"; 00062 filename_out = "PB_ground.h5m"; 00063 min_dot = 0.8; 00064 00065 keep_output = false; 00066 00067 if( argc == 1 ) 00068 { 00069 std::cout << "Using default input " << filename << " " << polyline_file_name << " " << min_dot << " " 00070 << filename_out << std::endl; 00071 std::cout << " default output file: " << filename_out << " will be deleted \n"; 00072 } 00073 else if( argc == 5 ) 00074 { 00075 filename = argv[1]; 00076 polyline_file_name = argv[2]; 00077 min_dot = atof( argv[3] ); 00078 filename_out = argv[4]; 00079 keep_output = true; 00080 } 00081 else 00082 { 00083 std::cerr << "Usage: " << argv[0] << " [geom_filename] [polygon_file] [min_dot] [output_file]" << std::endl; 00084 return 1; 00085 } 00086 00087 Core mbcore; 00088 Interface* mb = &mbcore; 00089 00090 ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load input file" ); 00091 00092 FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed 00093 00094 if( !pFacet ) return 1; // error 00095 00096 // should the init be part of constructor or not? 00097 // this is where the obb tree is constructed, and smooth faceting initialized, too. 00098 rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); 00099 00100 delete pFacet; 00101 pFacet = NULL; 00102 00103 // split_test_across 00104 std::cout << " split across test: "; 00105 rval = split_test_across(); 00106 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00107 std::cout << "\n"; 00108 00109 std::cout << " verify split "; 00110 rval = verify_split(); 00111 handle_error_code( rval, number_tests_failed, number_tests_successful ); 00112 std::cout << "\n"; 00113 // when we are done, remove modified file if we want to 00114 if( !keep_output ) 00115 { 00116 remove( filename_out.c_str() ); 00117 } 00118 return number_tests_failed; 00119 } 00120 00121 // this test will test a split like the one for grounding line 00122 // the first and last point of the polyline should be close to the 00123 // initial boundary of the face to be split 00124 ErrorCode split_test_across() 00125 { 00126 Core mbcore; 00127 Interface* mb = &mbcore; 00128 00129 ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load already modified file" ); 00130 00131 FBEngine* pFacet = new FBEngine( mb, NULL, true ); 00132 00133 rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); 00134 00135 EntityHandle root_set; 00136 rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); 00137 int top = 2; // iBase_FACE; 00138 00139 Range faces; 00140 rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." ); 00141 00142 if( faces.size() != 1 ) 00143 { 00144 std::cout << "num faces model:" << faces.size() << "\n"; 00145 return MB_FAILURE; // 00146 } 00147 // check only the second face 00148 00149 EntityHandle second_face = faces[0]; 00150 // use the polyPB.txt file to get the trimming polygon 00151 ; 00152 // read the file with the polygon user data 00153 00154 std::ifstream datafile( polyline_file_name.c_str(), std::ifstream::in ); 00155 if( !datafile ) 00156 { 00157 std::cout << "can't read file\n"; 00158 return MB_FAILURE; 00159 } 00160 // 00161 char temp[100]; 00162 double direction[3]; // normalized 00163 double gridSize; 00164 datafile.getline( temp, 100 ); // first line 00165 00166 // get direction and mesh size along polygon segments, from file 00167 sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize ); 00168 // NORMALIZE(direction);// just to be sure 00169 00170 std::vector< double > xyz; 00171 while( !datafile.eof() ) 00172 { 00173 datafile.getline( temp, 100 ); 00174 // int id = 0; 00175 double x, y, z; 00176 int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z ); 00177 if( nr == 3 ) 00178 { 00179 xyz.push_back( x ); 00180 xyz.push_back( y ); 00181 xyz.push_back( z ); 00182 } 00183 } 00184 int sizePolygon = (int)xyz.size() / 3; 00185 if( sizePolygon < 2 ) 00186 { 00187 std::cerr << " Not enough points in the polygon" << std::endl; 00188 return MB_FAILURE; 00189 } 00190 00191 EntityHandle newFace; // this test is with a "grounding" line 00192 // the second face should be the one that we want for test 00193 rval = pFacet->split_surface_with_direction( second_face, xyz, direction, /*closed*/ 0, 00194 /*min_dot */ 0.8, newFace );MB_CHK_ERR( rval ); 00195 00196 // save a new database, with 3 faces, eventually 00197 pFacet->delete_smooth_tags(); 00198 delete pFacet; 00199 pFacet = NULL; // try not to write the obb tree 00200 00201 rval = mb->write_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "Writing mesh file failed\n" ); 00202 00203 return rval; 00204 } 00205 00206 ErrorCode verify_split() 00207 { 00208 Interface* mb = new Core(); 00209 00210 ErrorCode rval = mb->load_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "Loading mesh file failed\n" ); 00211 00212 moab::GeomTopoTool gTopoTool( mb, true, 0, true, false ); 00213 00214 if( !gTopoTool.check_model() ) return MB_FAILURE; 00215 00216 delete mb; 00217 return MB_SUCCESS; 00218 }
