MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "SysUtil.hpp"#include <fstream>#include <algorithm>#include <cassert>#include "moab/EntityHandle.hpp"
Include dependency graph for SysUtil.cpp:Go to the source code of this file.
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
| namespace | moab::SysUtil |
Functions | |
| void | moab::SysUtil::setmem (void *mem, const void *value, unsigned value_size, size_t num_elem) |
| Similar to memset, but accepts values larger than 1 char. | |
| long | moab::SysUtil::filesize (FILE *filp) |
| Get size of file (if it is a regular file) | |
| long | moab::SysUtil::filesize (std::ifstream &str) |
| void | moab::SysUtil::byteswap (void *data, unsigned value_size, size_t num_elem) |
| Swap byte order (e.g. change from big-endian to little-endian) | |
| static uint16_t | moab::SysUtil::swap_bytes (uint16_t value) |
| static uint32_t | moab::SysUtil::swap_bytes (uint32_t value) |
| static uint64_t | moab::SysUtil::swap_bytes (uint64_t value) |
| void | moab::SysUtil::byteswap2 (void *data, size_t num_elem) |
| Alternate byteswap optimized for 2-byte values. | |
| void | moab::SysUtil::byteswap4 (void *data, size_t num_elem) |
| Alternate byteswap optimized for 4-byte values. | |
| void | moab::SysUtil::byteswap8 (void *data, size_t num_elem) |
| Alternate byteswap optimized for 8-byte values. | |
Variables | |
| const uint64_t | moab::SysUtil::m64b1 = 0xFF |
| const uint64_t | moab::SysUtil::m64b2 = m64b1 << 8 |
| const uint64_t | moab::SysUtil::m64b3 = m64b1 << 16 |
| const uint64_t | moab::SysUtil::m64b4 = m64b1 << 24 |
| const uint64_t | moab::SysUtil::m64b5 = m64b1 << 32 |
| const uint64_t | moab::SysUtil::m64b6 = m64b1 << 40 |
| const uint64_t | moab::SysUtil::m64b7 = m64b1 << 48 |
