MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for UniformRefinement.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 8 of file UniformRefinement.cpp.
References moab::error(), ErrorCode, filename, moab::NestedRefine::generate_mesh_hierarchy(), moab::Interface::load_file(), mb, MB_CHK_ERR, and moab::Interface::write_file().
Core mb;
Interface* mbImpl = &mb;
ErrorCode error;
if( argc == 1 )
std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
return 1;
const char* filename = argv[1];
error = mbImpl->load_file( filename );MB_CHK_ERR( error );
NestedRefine uref( &mb );
// Usage: The level degrees array controls number of refinemetns and
// the degree of refinement at each level.
// Example: int level_degrees[4] = {2,3,2,3};
std::vector< int > level_degrees;
if( argc > 2 )
level_degrees.resize( argc - 2 );
for( int i = 2; i < argc; ++i )
level_degrees[i - 2] = atoi( argv[i] );
else
level_degrees.resize( 2 );
int num_levels = static_cast< int >( level_degrees.size() );
std::cout << "Starting hierarchy generation" << std::endl;
std::vector< EntityHandle > set;
error = uref.generate_mesh_hierarchy( num_levels, level_degrees.data(), set );MB_CHK_ERR( error );
std::cout << "Finished hierarchy generation" << std::endl;
std::stringstream file;
file << "mesh_hierarchy.h5m";
error = mbImpl->write_file( file.str().c_str() );MB_CHK_ERR( error );
return 0;
