MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*This unit test is for the uniform refinement capability based on AHF datastructures*/ 00002 #include <iostream> 00003 #include "moab/Core.hpp" 00004 #include "moab/NestedRefine.hpp" 00005 00006 using namespace moab; 00007 00008 int main( int argc, char* argv[] ) 00009 { 00010 Core mb; 00011 Interface* mbImpl = &mb; 00012 ErrorCode error; 00013 00014 if( argc == 1 ) 00015 { 00016 std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl; 00017 return 1; 00018 } 00019 00020 const char* filename = argv[1]; 00021 error = mbImpl->load_file( filename );MB_CHK_ERR( error ); 00022 00023 NestedRefine uref( &mb ); 00024 00025 // Usage: The level degrees array controls number of refinemetns and 00026 // the degree of refinement at each level. 00027 // Example: int level_degrees[4] = {2,3,2,3}; 00028 std::vector< int > level_degrees; 00029 if( argc > 2 ) 00030 { 00031 level_degrees.resize( argc - 2 ); 00032 for( int i = 2; i < argc; ++i ) 00033 level_degrees[i - 2] = atoi( argv[i] ); 00034 } 00035 else 00036 { 00037 level_degrees.resize( 2 ); 00038 } 00039 int num_levels = static_cast< int >( level_degrees.size() ); 00040 00041 std::cout << "Starting hierarchy generation" << std::endl; 00042 std::vector< EntityHandle > set; 00043 error = uref.generate_mesh_hierarchy( num_levels, level_degrees.data(), set );MB_CHK_ERR( error ); 00044 std::cout << "Finished hierarchy generation" << std::endl; 00045 00046 std::stringstream file; 00047 file << "mesh_hierarchy.h5m"; 00048 error = mbImpl->write_file( file.str().c_str() );MB_CHK_ERR( error ); 00049 return 0; 00050 }
