MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*! \file NestedRefine.hpp 00002 * This class implements the generation of a hierarchy of meshes via uniform refinement from an 00003 * input mesh. The internal upper bound on the number of levels is set to 20. 00004 */ 00005 00006 #ifndef NESTED_REFINE_HPP 00007 #define NESTED_REFINE_HPP 00008 00009 #include "moab/MOABConfig.h" 00010 #include "moab/Range.hpp" 00011 #include "moab/CN.hpp" 00012 #include <map> 00013 #include <set> 00014 00015 namespace moab 00016 { 00017 00018 #define MAX_DEGREE 3 00019 #define MAX_VERTS 64 00020 #define MAX_CHILDRENS 27 00021 #define MAX_HE 12 00022 #define MAX_HF 6 00023 #define MAX_CONN 8 00024 #define MAX_VHF 20 00025 #define MAX_LEVELS 20 00026 #define MAX_PROCS 64 00027 00028 // Forward Declarations 00029 class Core; 00030 class HalfFacetRep; 00031 class ParallelComm; 00032 class CpuTimer; 00033 00034 class NestedRefine 00035 { 00036 00037 public: 00038 NestedRefine( Core* impl, ParallelComm* comm = 0, EntityHandle rset = 0 ); 00039 00040 ~NestedRefine(); 00041 00042 ErrorCode initialize(); 00043 00044 //! \brief Generate a mesh hierarchy. 00045 /** Given a mesh, generate a sequence of meshes via uniform refinement. The inputs are: a) an 00046 * array(level_degrees) storing the degrees which will be used to refine the previous level mesh 00047 * to generate a new level and b) the total number of levels(should be same length as that of 00048 * the array in a). Each mesh level in the hierarchy are stored in different meshsets whose 00049 * handles are returned after the hierarchy generation. These handles can be used to work with a 00050 * specific mesh level. \param level_degrees Integer array storing the degrees used in each 00051 * level. \param num_level The total number of levels in the hierarchy. \param hm_set 00052 * EntityHandle STL vector that returns the handles of the sets created for each mesh level. 00053 */ 00054 00055 ErrorCode generate_mesh_hierarchy( int num_level, 00056 int* level_degrees, 00057 std::vector< EntityHandle >& level_sets, 00058 bool optimize = false ); 00059 00060 //! Given an entity and its level, return its connectivity. 00061 /** Given an entity at a certain level, it finds the connectivity via direct access to a stored 00062 * internal pointer to the memory to connectivity sequence for the given level. \param ent 00063 * EntityHandle of the entity \param level Integer level of the entity for which connectivity is 00064 * requested \param conn std::vector returning the connectivity of the entity 00065 */ 00066 00067 ErrorCode get_connectivity( EntityHandle ent, int level, std::vector< EntityHandle >& conn ); 00068 00069 //! Given a vector of vertices and their level, return its coordinates. 00070 /** Given a vector of vertices at a certain level, it finds the coordinates via direct access to 00071 * a stored internal pointer to the memory to coordinate sequence for the given level. \param 00072 * verts std::vector of the entity handles of the vertices \param num_verts The number of 00073 * vertices \param level Integer level of the entity for which connectivity is requested \param 00074 * coords double pointer returning the coordinates of the vertices 00075 */ 00076 00077 ErrorCode get_coordinates( EntityHandle* verts, int num_verts, int level, double* coords ); 00078 00079 //! Get the adjacencies associated with an entity. 00080 /** Given an entity of dimension <em>d</em>, gather all the adjacent <em>D</em> dimensional 00081 * entities where <em>D >, = , < d </em>. 00082 * 00083 * \param source_entity EntityHandle to which adjacent entities have to be found. 00084 * \param target_dimension Int Dimension of the desired adjacent entities. 00085 * \param target_entities Vector in which the adjacent EntityHandle are returned. 00086 */ 00087 00088 ErrorCode get_adjacencies( const EntityHandle source_entity, 00089 const unsigned int target_dimension, 00090 std::vector< EntityHandle >& target_entities ); 00091 00092 // Interlevel parent-child or vice-versa queries 00093 /** Given an entity from a certain level, it returns a pointer to its parent at the requested 00094 * parent level. NOTE: This query does not support vertices. 00095 * 00096 * \param child EntityHandle of the entity whose parent is requested 00097 * \param child_level Mesh level where the child exists 00098 * \param parent_level Mesh level from which parent is requested 00099 * \param parent Pointer to the parent in the requested parent_level 00100 */ 00101 00102 ErrorCode child_to_parent( EntityHandle child, int child_level, int parent_level, EntityHandle* parent ); 00103 00104 /** Given an entity from a certain level, it returns a std::vector of all its children from the 00105 * requested child level. NOTE: This query does not support vertices. 00106 * 00107 * \param parent EntityHandle of the entity whose children in subsequent level is requested 00108 * \param parent_level Mesh level where the parent exists 00109 * \param child_level Mesh level from which its children are requested 00110 * \param children Vector containing all childrens from the requested child_level 00111 */ 00112 00113 ErrorCode parent_to_child( EntityHandle parent, 00114 int parent_level, 00115 int child_level, 00116 std::vector< EntityHandle >& children ); 00117 00118 /** Given a vertex from a certain level, it returns a std::vector of all entities from any 00119 * previous levels that contains it. 00120 * 00121 * \param vertex EntityHandle of the vertex 00122 * \param vert_level Mesh level of the vertex 00123 * \param parent_level Mesh level from which entities containing vertex is requested 00124 * \param incident_entities Vector containing entities from the parent level incident on the 00125 * vertex 00126 */ 00127 00128 ErrorCode vertex_to_entities_up( EntityHandle vertex, 00129 int vert_level, 00130 int parent_level, 00131 std::vector< EntityHandle >& incident_entities ); 00132 00133 /** Given a vertex from a certain level, it returns a std::vector of all children entities of 00134 * incident entities to vertex from any subsequent levels 00135 * 00136 * \param vertex EntityHandle of the vertex 00137 * \param vert_level Mesh level of the vertex 00138 * \param child_level Mesh level from which child entities are requested 00139 * \param incident_entities Vector containing entities from the child level 00140 */ 00141 00142 ErrorCode vertex_to_entities_down( EntityHandle vertex, 00143 int vert_level, 00144 int child_level, 00145 std::vector< EntityHandle >& incident_entities ); 00146 00147 ErrorCode get_vertex_duplicates( EntityHandle vertex, int level, EntityHandle& dupvertex ); 00148 00149 /** Given an entity at a certain level, it returns a boolean value true if it lies on the domain 00150 * boundary. \param entity 00151 */ 00152 00153 bool is_entity_on_boundary( const EntityHandle& entity ); 00154 00155 ErrorCode exchange_ghosts( std::vector< EntityHandle >& lsets, int num_glayers ); 00156 00157 ErrorCode update_special_tags( int level, EntityHandle& lset ); 00158 00159 struct codeperf 00160 { 00161 double tm_total; 00162 double tm_refine; 00163 double tm_resolve; 00164 }; 00165 00166 codeperf timeall; 00167 00168 protected: 00169 Core* mbImpl; 00170 ParallelComm* pcomm; 00171 HalfFacetRep* ahf; 00172 CpuTimer* tm; 00173 EntityHandle _rset; 00174 00175 Range _inverts, _inedges, _infaces, _incells; 00176 00177 EntityType elementype; 00178 int meshdim, nlevels; 00179 int level_dsequence[MAX_LEVELS]; 00180 std::map< int, int > deg_index; 00181 bool hasghost; 00182 00183 /*! \struct refPatterns 00184 * Refinement patterns w.r.t the reference element. It consists of a locally indexed vertex list 00185 * along with their natural coordinates, the connectivity of the subdivided entities with local 00186 * indices, their local AHF maps along with other helper fields to aid in general book keeping 00187 * such as avoiding vertex duplication during refinement. The entity and degree specific values 00188 * are stored in the Templates.hpp. \sa Templates.hpp 00189 */ 00190 00191 //! refPatterns 00192 struct refPatterns 00193 { 00194 //! Number of new vertices on edge 00195 short int nv_edge; 00196 //! Number of new vertices on face, does not include those on edge 00197 short int nv_face; 00198 //! Number of new vertices in cell 00199 short int nv_cell; 00200 //! Total number of new vertices per entity 00201 short int total_new_verts; 00202 //! Total number of new child entities 00203 short int total_new_ents; 00204 //! Lower and upper indices of the new vertices 00205 int vert_index_bnds[2]; 00206 //! Natural coordinates of the new vertices w.r.t reference 00207 double vert_nat_coord[MAX_VERTS][3]; 00208 //! Connectivity of the new entities 00209 int ents_conn[MAX_CHILDRENS][MAX_CONN]; 00210 //! Vertex to half-facet map of the new vertices 00211 int v2hf[MAX_VERTS][2]; 00212 //! Opposite half-facet map of the new entities 00213 int ents_opphfs[MAX_CHILDRENS][2 * MAX_CONN]; 00214 //! Helper: storing the local ids of vertices on each local edge 00215 int vert_on_edges[MAX_HE][MAX_VHF]; 00216 //! Helper: storing local ids of verts on each local face, doesnt include those on edges of 00217 //! the face 00218 int vert_on_faces[MAX_HF][MAX_VHF]; 00219 //! Helper: stores child half-facets incident on parent half-facet. First column contain the 00220 //! number of such children 00221 int ents_on_pent[MAX_HF][MAX_CHILDRENS]; 00222 //! Helper: stores child ents incident on new verts on edge. 00223 // Each triad in the column consists of : 00224 // 1) a local child incident on the vertex on the edge 00225 // 2) the local face id from the child 00226 // 3) the local vertex id wrt the child connectivity 00227 int ents_on_vedge[MAX_HE][MAX_VHF * 3]; 00228 }; 00229 //! refPatterns 00230 00231 static const refPatterns refTemplates[9][MAX_DEGREE]; 00232 00233 //! Helper 00234 struct intFEdge 00235 { 00236 //! Number of edges interior to a face 00237 short int nie; 00238 //! Local connectivity of the interior edges 00239 int ieconn[12][2]; 00240 }; 00241 static const intFEdge intFacEdg[2][2]; 00242 00243 int get_index_from_degree( int degree ); 00244 00245 // HM Storage Helper 00246 struct level_memory 00247 { 00248 int num_verts, num_edges, num_faces, num_cells; 00249 EntityHandle start_vertex, start_edge, start_face, start_cell; 00250 std::vector< double* > coordinates; 00251 EntityHandle *edge_conn, *face_conn, *cell_conn; 00252 Range verts, edges, faces, cells; 00253 }; 00254 00255 level_memory level_mesh[MAX_LEVELS]; 00256 00257 // Basic Functions 00258 00259 // Estimate and create storage for the levels 00260 ErrorCode estimate_hm_storage( EntityHandle set, int level_degree, int cur_level, int hmest[4] ); 00261 ErrorCode create_hm_storage_single_level( EntityHandle* set, int cur_level, int estL[4] ); 00262 00263 // Generate HM : Construct the hierarchical mesh: 1D, 2D, 3D 00264 ErrorCode generate_hm( int* level_degrees, int num_level, EntityHandle* hm_set, bool optimize ); 00265 ErrorCode construct_hm_entities( int cur_level, int deg ); 00266 ErrorCode construct_hm_1D( int cur_level, int deg ); 00267 ErrorCode construct_hm_1D( int cur_level, int deg, EntityType type, std::vector< EntityHandle >& trackverts ); 00268 ErrorCode construct_hm_2D( int cur_level, int deg ); 00269 ErrorCode construct_hm_2D( int cur_level, 00270 int deg, 00271 EntityType type, 00272 std::vector< EntityHandle >& trackvertsC_edg, 00273 std::vector< EntityHandle >& trackvertsF ); 00274 ErrorCode construct_hm_3D( int cur_level, int deg ); 00275 00276 ErrorCode subdivide_cells( EntityType type, int cur_level, int deg ); 00277 ErrorCode subdivide_tets( int cur_level, int deg ); 00278 00279 // General helper functions 00280 ErrorCode copy_vertices_from_prev_level( int cur_level ); 00281 ErrorCode count_subentities( EntityHandle set, int cur_level, int* nedges, int* nfaces ); 00282 ErrorCode get_octahedron_corner_coords( int cur_level, int deg, EntityHandle* vbuffer, double* ocoords ); 00283 int find_shortest_diagonal_octahedron( int cur_level, int deg, EntityHandle* vbuffer ); 00284 int get_local_vid( EntityHandle vid, EntityHandle ent, int level ); 00285 00286 // Book-keeping functions 00287 ErrorCode update_tracking_verts( EntityHandle cid, 00288 int cur_level, 00289 int deg, 00290 std::vector< EntityHandle >& trackvertsC_edg, 00291 std::vector< EntityHandle >& trackvertsC_face, 00292 EntityHandle* vbuffer ); 00293 ErrorCode reorder_indices( int cur_level, 00294 int deg, 00295 EntityHandle cell, 00296 int lfid, 00297 EntityHandle sib_cell, 00298 int sib_lfid, 00299 int index, 00300 int* id_sib ); 00301 ErrorCode reorder_indices( int deg, 00302 EntityHandle* face1_conn, 00303 EntityHandle* face2_conn, 00304 int nvF, 00305 std::vector< int >& lemap, 00306 std::vector< int >& vidx, 00307 int* leorient = NULL ); 00308 ErrorCode reorder_indices( int deg, int nvF, int comb, int* childfid_map ); 00309 ErrorCode reorder_indices( EntityHandle* face1_conn, 00310 EntityHandle* face2_conn, 00311 int nvF, 00312 int* conn_map, 00313 int& comb, 00314 int* orient = NULL ); 00315 ErrorCode get_lid_inci_child( EntityType type, 00316 int deg, 00317 int lfid, 00318 int leid, 00319 std::vector< int >& child_ids, 00320 std::vector< int >& child_lvids ); 00321 00322 // Permutation matrices 00323 struct pmat 00324 { 00325 short int num_comb; // Number of combinations 00326 int comb[MAX_HE][MAX_HE]; // Combinations 00327 int lemap[MAX_HE][MAX_HE]; // Local edge map 00328 int orient[MAX_HE]; // Orientation 00329 int porder2[MAX_HE][MAX_HE]; // Permuted order degree 2 00330 int porder3[MAX_HE][MAX_HE]; // Permuted order degree 3 00331 }; 00332 00333 static const pmat permutation[2]; 00334 00335 // Print functions 00336 ErrorCode print_maps_1D( int level ); 00337 ErrorCode print_maps_2D( int level, EntityType type ); 00338 ErrorCode print_maps_3D( int level, EntityType type ); 00339 00340 // Coordinates 00341 ErrorCode compute_coordinates( int cur_level, 00342 int deg, 00343 EntityType type, 00344 EntityHandle* vbuffer, 00345 int vtotal, 00346 double* corner_coords, 00347 std::vector< int >& vflag, 00348 int nverts_prev ); 00349 00350 // Update the ahf maps 00351 00352 ErrorCode update_local_ahf( int deg, EntityType type, EntityHandle* vbuffer, EntityHandle* ent_buffer, int etotal ); 00353 00354 ErrorCode update_local_ahf( int deg, 00355 EntityType type, 00356 int pat_id, 00357 EntityHandle* vbuffer, 00358 EntityHandle* ent_buffer, 00359 int etotal ); 00360 00361 // ErrorCode update_global_ahf(EntityType type, int cur_level, int deg); 00362 00363 // ErrorCode update_global_ahf(int cur_level, int deg, std::vector<int> &pattern_ids); 00364 00365 ErrorCode update_global_ahf( EntityType type, int cur_level, int deg, std::vector< int >* pattern_ids = NULL ); 00366 00367 ErrorCode update_global_ahf_1D( int cur_level, int deg ); 00368 00369 ErrorCode update_global_ahf_1D_sub( int cur_level, int deg ); 00370 00371 ErrorCode update_ahf_1D( int cur_level ); 00372 00373 ErrorCode update_global_ahf_2D( int cur_level, int deg ); 00374 00375 ErrorCode update_global_ahf_2D_sub( int cur_level, int deg ); 00376 00377 ErrorCode update_global_ahf_3D( int cur_level, int deg, std::vector< int >* pattern_ids = NULL ); 00378 00379 // ErrorCode update_global_ahf_3D(int cur_level, int deg); 00380 00381 // ErrorCode update_global_ahf_3D(int cur_level, int deg, std::vector<int> &pattern_ids); 00382 00383 /** Boundary extraction functions 00384 * Given a vertex at a certain level, it returns a boolean value true if it lies on the domain 00385 * boundary. Note: This is a specialization of the NestedRefine::is_entity_on_boundary function 00386 * and applies only to vertex queries. \param entity 00387 */ 00388 bool is_vertex_on_boundary( const EntityHandle& entity ); 00389 bool is_edge_on_boundary( const EntityHandle& entity ); 00390 bool is_face_on_boundary( const EntityHandle& entity ); 00391 bool is_cell_on_boundary( const EntityHandle& entity ); 00392 00393 // ErrorCode find_skin_faces(EntityHandle set, int level, int nskinF); 00394 00395 /** Parallel communication routines 00396 * We implement two strategies to resolve the shared entities of the newly created entities. 00397 * The first strategy is to use the existing parallel merge capability which essentially uses 00398 * a coordinate-based matching of vertices and subsequently the entity handles through 00399 * their connectivities. The second strategy is an optimized and a new algorithm. It uses 00400 * the existing shared information from the coarse entities and propagates the parallel 00401 * information appropriately. 00402 */ 00403 00404 // Send/Recv Buffer storage 00405 /* struct pbuffer{ 00406 int rank; 00407 std::vector<int> msgsize; 00408 std::vector<EntityHandle> localBuff; 00409 std::vector<EntityHandle> remoteBuff; 00410 }; 00411 00412 pbuffer commBuffers[MAX_PROCS]; 00413 00414 //Parallel tag values 00415 struct parinfo{ 00416 std::multimap<EntityHandle, int> remoteps; 00417 std::multimap<EntityHandle, EntityHandle> remotehs; 00418 }; 00419 00420 parinfo parallelInfo[MAX_LEVELS];*/ 00421 00422 #ifdef MOAB_HAVE_MPI 00423 00424 ErrorCode resolve_shared_ents_parmerge( int level, EntityHandle levelset ); 00425 ErrorCode resolve_shared_ents_opt( EntityHandle* hm_set, int num_levels ); 00426 00427 ErrorCode collect_shared_entities_by_dimension( Range sharedEnts, Range& allEnts ); 00428 ErrorCode collect_FList( int to_proc, 00429 Range faces, 00430 std::vector< EntityHandle >& FList, 00431 std::vector< EntityHandle >& RList ); 00432 ErrorCode collect_EList( int to_proc, 00433 Range edges, 00434 std::vector< EntityHandle >& EList, 00435 std::vector< EntityHandle >& RList ); 00436 ErrorCode collect_VList( int to_proc, 00437 Range verts, 00438 std::vector< EntityHandle >& VList, 00439 std::vector< EntityHandle >& RList ); 00440 00441 ErrorCode decipher_remote_handles( std::vector< int >& sharedprocs, 00442 std::vector< std::vector< int > >& auxinfo, 00443 std::vector< std::vector< EntityHandle > >& localbuffers, 00444 std::vector< std::vector< EntityHandle > >& remotebuffers, 00445 std::multimap< EntityHandle, int >& remProcs, 00446 std::multimap< EntityHandle, EntityHandle >& remHandles ); 00447 00448 ErrorCode decipher_remote_handles_face( int shared_proc, 00449 int numfaces, 00450 std::vector< EntityHandle >& localFaceList, 00451 std::vector< EntityHandle >& remFaceList, 00452 std::multimap< EntityHandle, int >& remProcs, 00453 std::multimap< EntityHandle, EntityHandle >& remHandles ); 00454 00455 ErrorCode decipher_remote_handles_edge( int shared_proc, 00456 int numedges, 00457 std::vector< EntityHandle >& localEdgeList, 00458 std::vector< EntityHandle >& remEdgeList, 00459 std::multimap< EntityHandle, int >& remProcs, 00460 std::multimap< EntityHandle, EntityHandle >& remHandles ); 00461 00462 ErrorCode decipher_remote_handles_vertex( int shared_proc, 00463 int numverts, 00464 std::vector< EntityHandle >& localVertexList, 00465 std::vector< EntityHandle >& remVertexList, 00466 std::multimap< EntityHandle, int >& remProcs, 00467 std::multimap< EntityHandle, EntityHandle >& remHandles ); 00468 00469 ErrorCode update_parallel_tags( std::multimap< EntityHandle, int >& remProcs, 00470 std::multimap< EntityHandle, EntityHandle >& remHandles ); 00471 00472 ErrorCode get_data_from_buff( int dim, 00473 int type, 00474 int level, 00475 int entityidx, 00476 int nentities, 00477 std::vector< EntityHandle >& buffer, 00478 std::vector< EntityHandle >& data ); 00479 00480 bool check_for_parallelinfo( EntityHandle entity, int proc, std::multimap< EntityHandle, int >& remProcs ); 00481 00482 ErrorCode check_for_parallelinfo( EntityHandle entity, 00483 int proc, 00484 std::multimap< EntityHandle, EntityHandle >& remHandles, 00485 std::multimap< EntityHandle, int >& remProcs, 00486 EntityHandle& rhandle ); 00487 00488 #endif 00489 }; 00490 00491 } // namespace moab 00492 #endif
