fileopts_test.cpp File Reference
#include "moab/FileOptions.hpp"
#include <cctype>
#include <cstdlib>
#include <cstring>
#include <algorithm>
#include <iostream>
+ Include dependency graph for fileopts_test.cpp:
Defines
#define CHECK(A)
#define EQUAL(A, B)
Functions
int main ()
Define Documentation
#define CHECK (   A)
Value:
if( MB_SUCCESS != ( A ) )        \
        std::cerr << "Failure at line " << __LINE__ << ": error code " << ( A ) << std::endl; \
        return 1;        \
Definition at line 31 of file fileopts_test.cpp.
Referenced by main().
#define EQUAL (   A,
  B
Value:
if( ( A ) != ( B ) )        \
        std::cerr << "Failure at line " << __LINE__ << ": expected " << ( B ) << " but got " << ( A ) << std::endl; \
        return 2;        \
Definition at line 38 of file fileopts_test.cpp.
Function Documentation
int main ( )
Definition at line 45 of file fileopts_test.cpp.
References moab::FileOptions::all_seen(), CHECK, moab::FileOptions::empty(), EQUAL, ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_ints_option(), moab::FileOptions::get_null_option(), moab::FileOptions::get_option(), moab::FileOptions::get_real_option(), moab::FileOptions::get_reals_option(), moab::FileOptions::get_str_option(), moab::FileOptions::get_strs_option(), moab::FileOptions::get_unseen_option(), MB_ENTITY_NOT_FOUND, MB_TYPE_OUT_OF_RANGE, and moab::FileOptions::size().
    FileOptions tool( "INT1=1;NUL1;STR1=ABC;DBL1=1.0;dbl2=2.0;DBL3=3.0;INT2=2;nul2;NUL3;INT3=3;str2=once upon a "
                      "time;str3==fubar=;;INTS=1-3,5,6;DBLS=1.0,2.0, 3.0;STRS=var1, var2_var2;STRS2=" );
    std::string s;
    int i;
    double d;
    ErrorCode rval;
    // test basic get_option method without deleting entry
    rval = tool.get_option( "STR1", s );
    CHECK( rval );
    EQUAL( s, "ABC" );
    // test basic get_option method again, this time deleting the entry
    CHECK( rval );
    EQUAL( s, "ABC" );
    // test basig get_option method with a null option
    rval = tool.get_option( "NUL2", s );
    CHECK( rval );
    EQUAL( s.empty(), true );
    // test null option
    rval = tool.get_null_option( "nul1" );
    CHECK( rval );
    // try null option method on non-null value
    rval = tool.get_null_option( "INT1" );
    EQUAL( rval, MB_TYPE_OUT_OF_RANGE );
    // test integer option
    rval = tool.get_int_option( "int1", i );
    CHECK( rval );
    EQUAL( i, 1 );
    rval = tool.get_int_option( "int2", i );
    CHECK( rval );
    EQUAL( i, 2 );
    // test integer option on non-integer value
    rval = tool.get_int_option( "dbl2", i );
    // test integer option on null value
    rval = tool.get_int_option( "NUL3", i );
    // test double option
    rval = tool.get_real_option( "dbl1", d );
    CHECK( rval );
    EQUAL( d, 1.0 );
    rval = tool.get_real_option( "dbl2", d );
    CHECK( rval );
    EQUAL( d, 2.0 );
    rval = tool.get_real_option( "int3", d );
    CHECK( rval );
    EQUAL( d, 3.0 );
    // test real option on non-real value
    rval = tool.get_real_option( "str2", d );
    // test real option on null value
    rval = tool.get_real_option( "NUL3", d );
    // test get a simple string option
    rval = tool.get_str_option( "DBL3", s );
    CHECK( rval );
    EQUAL( s, "3.0" );
    // test get a string with spaces
    rval = tool.get_str_option( "STR2", s );
    CHECK( rval );
    EQUAL( s, "once upon a time" );
    // try to get a string value for a null option
    rval = tool.get_str_option( "nul3", s );
    // We haven't looked at all of the options yet
    EQUAL( false, tool.all_seen() );
    rval = tool.get_unseen_option( s );
    CHECK( rval );
    EQUAL( s, "str3" );
    // test options using generic get_option method
    rval = tool.get_option( "NUL3", s );
    CHECK( rval );
    rval = tool.get_option( "STR3", s );
    CHECK( rval );
    EQUAL( s, "=fubar=" );
    // test size of options string
    unsigned l = tool.size();
    EQUAL( l, 16u );
    // test ints option
    std::vector< int > ivals;
    rval = tool.get_ints_option( "INTS", ivals );
    CHECK( rval );
    EQUAL( 5, ivals.size() );
    EQUAL( 1, ivals[0] );
    EQUAL( 2, ivals[1] );
    EQUAL( 3, ivals[2] );
    EQUAL( 5, ivals[3] );
    EQUAL( 6, ivals[4] );
    // test dbls option
    std::vector< double > vals;
    rval = tool.get_reals_option( "DBLS", vals );
    CHECK( rval );
    EQUAL( 3, vals.size() );
    EQUAL( 1.0, vals[0] );
    EQUAL( 2.0, vals[1] );
    EQUAL( 3.0, vals[2] );
    // test strs option
    std::vector< std::string > svals;
    rval = tool.get_strs_option( "STRS", svals );
    CHECK( rval );
    EQUAL( 2, svals.size() );
    EQUAL( "var1", svals[0] );
    EQUAL( "var2_var2", svals[1] );
    svals.clear();
    rval = tool.get_strs_option( "STRS2", svals );
    EQUAL( MB_TYPE_OUT_OF_RANGE, rval );
    // We requested every option
    EQUAL( true, tool.all_seen() );
    EQUAL( MB_ENTITY_NOT_FOUND, rval );
    // test alternate separator
    FileOptions tool2( ";+OPT1=ABC+OPT2=" );
    l = tool2.size();
    EQUAL( l, 2 );
    EQUAL( false, tool2.all_seen() );
    rval = tool2.get_unseen_option( s );
    CHECK( rval );
    EQUAL( s, "OPT1" );
    rval = tool2.get_option( "opt1", s );
    CHECK( rval );
    EQUAL( s, "ABC" );
    rval = tool2.get_option( "opt2", s );
    CHECK( rval );
    bool e = s.empty();
    EQUAL( e, true );
    l = tool2.size();
    EQUAL( l, 2 );
    EQUAL( true, tool2.all_seen() );
    // test empty options string
    FileOptions tool3( ";;;;" );
    e = tool3.empty();
    EQUAL( e, true );
    l = tool3.size();
    EQUAL( l, 0 );
    EQUAL( true, tool3.all_seen() );
    FileOptions tool4( NULL );
    e = tool4.empty();
    EQUAL( e, true );
    l = tool4.size();
    EQUAL( l, 0 );
    EQUAL( true, tool4.all_seen() );
    FileOptions tool5( ";+" );
    e = tool5.empty();
    EQUAL( e, true );
    l = tool5.size();
    EQUAL( l, 0 );
    EQUAL( true, tool5.all_seen() );
    // test copy constructor
    const FileOptions& tool6( tool2 );
    rval = tool6.get_option( "opt1", s );
    CHECK( rval );
    EQUAL( s, "ABC" );
    rval = tool6.get_option( "opt2", s );
    CHECK( rval );
    e = s.empty();
    EQUAL( e, true );
    l = tool6.size();
    EQUAL( l, 2 );
    const FileOptions& tool7( tool5 );
    e = tool7.empty();
    EQUAL( e, true );
    l = tool7.size();
    EQUAL( l, 0 );
    // test assignment operator
    FileOptions tool8( tool2 );
    tool8 = tool;
    EQUAL( tool8.size(), tool.size() );
    return 0;
